171.67.108.21
Bobby-Uschi
Hardware configuration: PC1//C2Q-Q9450,GA-X48-DS5-NinjaMini,GTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit;
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB Western Sata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"
171.67.108.21
Post by Bobby-Uschi »
Sat Apr 27 13:00:15 PDT 2013 171.67.108.21 vsp07b vvoelz GPU full Reject 3.15 181 0 999 26815 7424 -176 198226 198226 198226 - - - - 0 0 - - 1  - 0 1 W; W; 1, 1 6.119, 6.119 - 49, 49 64, 64 - - 2, 2 F, A 8080G, 8080G
Sat Apr 27 13:20:12 PDT 2013 171.67.108.21 vsp07b vvoelz GPU full Reject 3.09 172 0 999 26815 7424 -175 198226 198226 198226 - - - - 0 0 - - 1  - 0 0 W; W; 1, 1 6.119, 6.119 - 49, 49 64, 64 - - 2, 2 F, A 8080G, 8080G
Sat Apr 27 13:40:14 PDT 2013 171.67.108.21 vsp07b vvoelz GPU full Accepting 3.09 150 0 999 26815 7424 -175 198226 198226 198226 - - - - 0 0 - - 1  - 0 1 W; W; 1, 1 6.119, 6.119 - 49, 49 64, 64 - - 2, 2 F, A 8080G, 8080G
Sat Apr 27 14:00:14 PDT 2013 171.67.108.21 vsp07b vvoelz GPU full Accepting 3.10 155 0 999 26815 7424 -176 198226 198226 198226 - - - - 0 0 - - 1  - 0 1 W; W; 1, 1 6.119, 6.119 - 49, 49 64, 64 - - 2, 2 F, A 8080G, 8080G
Sat Apr 27 14:20:11 PDT 2013 171.67.108.21 vsp07b vvoelz GPU full Accepting 3.77 168 0 999 26815 7424 -176 198226 198226 198226 - - 222 - 0 0 - - 1  - 0 1 W; W; 1, 1 6.119, 6.119 - 49, 49 64, 64 - - 2, 2 F, A 8080G, 8080G
Sat Apr 27 14:40:11 PDT 2013 171.67.108.21 vsp07b vvoelz GPU full Accepting 4.00 141 0 999 26815 7423 -176 198226 198226 198226 - - 223 - 0 0 - - 1  - 0 1 W; W; 1, 1 6.119, 6.119 - 49, 49 64, 64 - - 2, 2 F, A 8080G, 8080G
Sat Apr 27 15:00:11 PDT 2013 171.67.108.21 vsp07b vvoelz GPU full Accepting 4.07 160 0 999 26815 7423 -176 198226 198226 198226 - - 215 - 0 0 - - 1  - 0 0 W; W; 1, 1 6.119, 6.119 - 49, 49 64, 64 - - 2, 2 F, A 8080G, 8080G
Sat Apr 27 15:20:11 PDT 2013 171.67.108.21 vsp07b vvoelz GPU full Reject
once again does not
may need some oil? :e)
PC1//C2Q-Q9450,GA-X48-DS5-,2xGTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB WeSata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"stern
Re: 171.67.108.21
Something strange is going on but I'm not sure what it is. The server has been alternating between Accepting and Reject for quite some time. It's getting hit pretty hard. (Notice the column for port 80 that contains 222 / 223 / 215 in your post.)
What does your log show?
SupplyChain
Re: 171.67.108.21
Post by SupplyChain »
Hi Bruce, I'm also having a problem with this server. I arrived back home to find 0 of 6 gpu's (all GTX260s) with no work. I stopped the clients, rebooted, and got only 1 of the 6 gpu's to connect to the server.
Here's my log:
*********************** Log Started 2013-04-28T02:27:52Z ***********************
02:27:52:************************* Folding@home Client *************************
02:27:52:      Website: http://folding.stanford.edu/
02:27:52:    Copyright: (c) 2009-2013 Stanford University
02:27:52:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:27:52:         Args:
02:27:52:       Config: C:/Users/Jon/AppData/Roaming/FAHClient/config.xml
02:27:52:******************************** Build ********************************
02:27:52:      Version: 7.3.6
02:27:52:         Date: Feb 18 2013
02:27:52:         Time: 15:25:17
02:27:52:      SVN Rev: 3923
02:27:52:       Branch: fah/trunk/client
02:27:52:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:27:52:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:27:52:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:27:52:     Platform: win32 XP
02:27:52:         Bits: 32
02:27:52:         Mode: Release
02:27:52:******************************* System ********************************
02:27:52:          CPU: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz
02:27:52:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 7
02:27:52:         CPUs: 4
02:27:52:       Memory: 4.00GiB
02:27:52:  Free Memory: 2.84GiB
02:27:52:      Threads: WINDOWS_THREADS
02:27:52:  Has Battery: false
02:27:52:   On Battery: false
02:27:52:   UTC offset: -4
02:27:52:          PID: 4460
02:27:52:          CWD: C:/Users/Jon/AppData/Roaming/FAHClient
02:27:52:           OS: Windows 7 Professional
02:27:52:      OS Arch: AMD64
02:27:52:         GPUs: 3
02:27:52:        GPU 0: NVIDIA:1 GT200 [GeForce GTX 260]
02:27:52:        GPU 1: NVIDIA:1 GT200 [GeForce GTX 260]
02:27:52:        GPU 2: NVIDIA:1 GT200 [GeForce GTX 260]
02:27:52:         CUDA: 1.3
02:27:52:  CUDA Driver: 3020
02:27:52:Win32 Service: false
02:27:52:***********************************************************************
02:27:52:<config>
02:27:52:  <!-- Folding Slot Configuration -->
02:27:52:  <power v='full'/>
02:27:52:
02:27:52:  <!-- User Information -->
02:27:52:  <passkey v='********************************'/>
02:27:52:  <team v='111065'/>
02:27:52:  <user v='SupplyChain'/>
02:27:52:
02:27:52:  <!-- Folding Slots -->
02:27:52:  <slot id='0' type='GPU'/>
02:27:52:  <slot id='1' type='GPU'/>
02:27:52:  <slot id='2' type='GPU'/>
02:27:52:  <slot id='3' type='CPU'/>
02:27:52:</config>
02:27:52:Trying to access database...
02:27:54:Successfully acquired database lock
02:27:54:Enabled folding slot 00: READY gpu:0:GT200 [GeForce GTX 260]
02:27:54:Enabled folding slot 01: READY gpu:1:GT200 [GeForce GTX 260]
02:27:54:Enabled folding slot 02: READY gpu:2:GT200 [GeForce GTX 260]
02:27:54:Enabled folding slot 03: READY cpu:4
02:27:54:WU02:FS03:Starting
02:27:54:WU02:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Jon/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 4460 -checkpoint 15 -np 4
02:27:55:WU02:FS03:Started FahCore on PID 5460
02:27:59:WU02:FS03:Core PID:5560
02:27:59:WU02:FS03:FahCore 0xa4 started
02:28:00:WU02:FS03:0xa4:
02:28:00:WU02:FS03:0xa4:*------------------------------*
02:28:00:WU02:FS03:0xa4:Folding@Home Gromacs GB Core
02:28:00:WU02:FS03:0xa4:Version 2.27 (Dec. 15, 2010)
02:28:00:WU02:FS03:0xa4:Preparing to commence simulation
02:28:00:WU02:FS03:0xa4:- Looking at optimizations...
02:28:00:WU02:FS03:0xa4:- Files status OK
02:28:00:WU02:FS03:0xa4:- Expanded 2054086 -> 5365960 (decompressed 261.2 percent)
02:28:00:WU02:FS03:0xa4:Called DecompressByteArray: compressed_data_size=2054086 data_size=5365960, decompressed_data_size=5365960 diff=0
02:28:00:WU02:FS03:0xa4:- Digital signature verified
02:28:00:WU02:FS03:0xa4:Project: 7808 (Run 5, Clone 25, Gen 84)
02:28:00:WU02:FS03:0xa4:Assembly optimizations on if available.
02:28:00:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
02:28:00:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
02:28:00:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:28:00:WU02:FS03:0xa4:Entering M.D.
02:28:01:WU03:FS02:News: Welcome to Folding@Home
02:28:01:WU03:FS02:Assigned to work server 171.67.108.21
02:28:01:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
02:28:01:WU00:FS00:News: Welcome to Folding@Home
02:28:01:WU00:FS00:Assigned to work server 171.67.108.21
02:28:01:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
02:28:01:WU01:FS01:News: Welcome to Folding@Home
02:28:01:WU01:FS01:Assigned to work server 171.67.108.21
02:28:01:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GT200 [GeForce GTX 260] from 171.67.108.21
02:28:01:WU03:FS02:Connecting to 171.67.108.21:8080
02:28:01:WU01:FS01:Connecting to 171.67.108.21:8080
02:28:01:WU00:FS00:Connecting to 171.67.108.21:8080
02:28:07:WU02:FS03:0xa4:Using Gromacs checkpoints
02:28:07:WU02:FS03:0xa4:Mapping NT from 4 to 4
02:28:15:WU02:FS03:0xa4:Resuming from checkpoint
02:28:15:WU02:FS03:0xa4:Verified 02/wudata_01.log
02:28:16:WU02:FS03:0xa4:Verified 02/wudata_01.trr
02:28:16:WU02:FS03:0xa4:Verified 02/wudata_01.xtc
02:28:16:WU02:FS03:0xa4:Verified 02/wudata_01.edr
02:28:17:WU02:FS03:0xa4:Completed 52860 out of 1500000 steps  (3%)
02:28:22:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:28:22:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:28:22:WU00:FS00:Connecting to 171.67.108.21:80
02:28:22:WU01:FS01:Connecting to 171.67.108.21:80
02:28:23:ERROR:WU03:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
02:28:23:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
02:28:24:WU03:FS02:News: Welcome to Folding@Home
02:28:24:WU03:FS02:Assigned to work server 171.67.108.21
02:28:24:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
02:28:24:WU03:FS02:Connecting to 171.67.108.21:8080
02:30:58:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
02:30:59:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:30:59:WU00:FS00:News: Welcome to Folding@Home
02:30:59:WU00:FS00:Assigned to work server 171.67.108.21
02:30:59:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
02:30:59:WU00:FS00:Connecting to 171.67.108.21:8080
02:31:00:ERROR:WU03:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
02:31:00:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
02:31:01:WU03:FS02:News: Welcome to Folding@Home
02:31:01:WU03:FS02:Assigned to work server 171.67.108.21
02:31:01:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
02:31:01:WU03:FS02:Connecting to 171.67.108.21:8080
02:31:04:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
02:31:05:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
02:31:05:WU01:FS01:News: Welcome to Folding@Home
02:31:05:WU01:FS01:Assigned to work server 171.67.108.21
02:31:05:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GT200 [GeForce GTX 260] from 171.67.108.21
02:31:05:WU01:FS01:Connecting to 171.67.108.21:8080
02:31:22:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
02:31:59:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:31:59:WU00:FS00:News: Welcome to Folding@Home
02:31:59:WU00:FS00:Assigned to work server 171.67.108.21
02:31:59:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
02:31:59:WU00:FS00:Connecting to 171.67.108.21:8080
02:33:37:ERROR:WU03:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
02:33:37:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
02:33:37:WU03:FS02:News: Welcome to Folding@Home
02:33:37:WU03:FS02:Assigned to work server 171.67.108.21
02:33:37:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
02:33:37:WU03:FS02:Connecting to 171.67.108.21:8080
02:33:41:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
02:33:42:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
02:33:42:WU01:FS01:News: Welcome to Folding@Home
02:33:42:WU01:FS01:Assigned to work server 171.67.108.21
02:33:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GT200 [GeForce GTX 260] from 171.67.108.21
02:33:42:WU01:FS01:Connecting to 171.67.108.21:8080
02:34:36:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
02:34:36:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:34:36:WU00:FS00:News: Welcome to Folding@Home
02:34:36:WU00:FS00:Assigned to work server 171.67.108.21
02:34:36:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
02:34:36:WU00:FS00:Connecting to 171.67.108.21:8080
02:36:14:ERROR:WU03:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
02:36:14:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
02:36:15:WU03:FS02:News: Welcome to Folding@Home
02:36:15:WU03:FS02:Assigned to work server 171.67.108.21
02:36:15:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
02:36:15:WU03:FS02:Connecting to 171.67.108.21:8080
02:36:18:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
02:36:18:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
02:36:19:WU01:FS01:News: Welcome to Folding@Home
02:36:19:WU01:FS01:Assigned to work server 171.67.108.21
02:36:19:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GT200 [GeForce GTX 260] from 171.67.108.21
02:36:19:WU01:FS01:Connecting to 171.67.108.21:8080
02:36:36:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
02:36:36:WU03:FS02:Connecting to 171.67.108.21:80
02:36:57:ERROR:WU03:FS02:Exception: Failed to connect to 171.67.108.21:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:37:18:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
02:37:19:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:37:19:WU00:FS00:News: Welcome to Folding@Home
02:37:19:WU00:FS00:Assigned to work server 171.67.108.21
02:37:19:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
02:37:19:WU00:FS00:Connecting to 171.67.108.21:8080
02:37:40:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:37:40:WU00:FS00:Connecting to 171.67.108.21:80
02:38:01:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.21:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:39:01:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
02:39:02:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
02:39:02:WU01:FS01:News: Welcome to Folding@Home
02:39:02:WU01:FS01:Assigned to work server 171.67.108.21
02:39:02:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GT200 [GeForce GTX 260] from 171.67.108.21
02:39:02:WU01:FS01:Connecting to 171.67.108.21:8080
02:39:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:39:23:WU01:FS01:Connecting to 171.67.108.21:80
02:39:44:ERROR:WU01:FS01:Exception: Failed to connect to 171.67.108.21:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:40:29:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
02:40:29:WU03:FS02:News: Welcome to Folding@Home
02:40:29:WU03:FS02:Assigned to work server 171.67.108.21
02:40:29:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
02:40:29:WU03:FS02:Connecting to 171.67.108.21:8080
02:40:48:ERROR:WU03:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
02:41:33:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:41:33:WU00:FS00:News: Welcome to Folding@Home
02:41:33:WU00:FS00:Assigned to work server 171.67.108.21
02:41:33:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
02:41:33:WU00:FS00:Connecting to 171.67.108.21:8080
02:43:16:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
02:43:16:WU01:FS01:News: Welcome to Folding@Home
02:43:16:WU01:FS01:Assigned to work server 171.67.108.21
02:43:16:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GT200 [GeForce GTX 260] from 171.67.108.21
02:43:16:WU01:FS01:Connecting to 171.67.108.21:8080
02:43:36:WU02:FS03:0xa4:Completed 60000 out of 1500000 steps  (4%)
02:43:37:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:43:37:WU01:FS01:Connecting to 171.67.108.21:80
02:43:59:ERROR:WU01:FS01:Exception: Failed to connect to 171.67.108.21:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:44:16:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
02:47:20:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
02:47:20:WU03:FS02:News: Welcome to Folding@Home
02:47:20:WU03:FS02:Assigned to work server 171.67.108.21
02:47:20:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
02:47:20:WU03:FS02:Connecting to 171.67.108.21:8080
02:47:39:ERROR:WU03:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
02:48:24:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:48:25:WU00:FS00:News: Welcome to Folding@Home
02:48:25:WU00:FS00:Assigned to work server 171.67.108.21
02:48:25:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
02:48:25:WU00:FS00:Connecting to 171.67.108.21:8080
02:50:07:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
02:50:08:WU01:FS01:News: Welcome to Folding@Home
02:50:08:WU01:FS01:Assigned to work server 171.67.108.11
02:50:08:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GT200 [GeForce GTX 260] from 171.67.108.11
02:50:08:WU01:FS01:Connecting to 171.67.108.11:8080
02:50:08:WU01:FS01:Downloading 46.14KiB
02:50:09:WU01:FS01:Download complete
02:50:09:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:5766 run:10 clone:288 gen:4350 core:0x11 unit:0x5827b675517c8e6610fe0120000a1686
02:50:09:WU01:FS01:Starting
02:50:09:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Jon/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 703 -lifeline 4460 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
02:50:09:WU01:FS01:Started FahCore on PID 5952
02:50:09:WU01:FS01:Core PID:6412
02:50:09:WU01:FS01:FahCore 0x11 started
02:50:09:WU01:FS01:0x11:
02:50:09:WU01:FS01:0x11:*------------------------------*
02:50:09:WU01:FS01:0x11:Folding@Home GPU Core
02:50:09:WU01:FS01:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
02:50:09:WU01:FS01:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
02:50:09:WU01:FS01:0x11:Build host: amoeba
02:50:09:WU01:FS01:0x11:Board Type: Nvidia
02:50:09:WU01:FS01:0x11:Core      :
02:50:09:WU01:FS01:0x11:Preparing to commence simulation
02:50:09:WU01:FS01:0x11:- Looking at optimizations...
02:50:09:WU01:FS01:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
02:50:09:WU01:FS01:0x11:- Created dyn
02:50:09:WU01:FS01:0x11:- Files status OK
02:50:09:WU01:FS01:0x11:- Expanded 46732 -> 252912 (decompressed 541.1 percent)
02:50:09:WU01:FS01:0x11:Called DecompressByteArray: compressed_data_size=46732 data_size=252912, decompressed_data_size=252912 diff=0
02:50:09:WU01:FS01:0x11:- Digital signature verified
02:50:09:WU01:FS01:0x11:Project: 5766 (Run 10, Clone 288, Gen 4350)
02:50:09:WU01:FS01:0x11:Assembly optimizations on if available.
02:50:09:WU01:FS01:0x11:Entering M.D.
02:50:15:WU01:FS01:0x11:Tpr hash 01/wudata_01.tpr:  1171101375 1791888414 1863819716 174455837 1812614878
02:50:15:WU01:FS01:0x11:Calling fah_main args: 14 usage=100
02:50:15:WU01:FS01:0x11:Working on Protein
02:50:16:WU01:FS01:0x11:Client config unavailable.
02:50:16:WU01:FS01:0x11:Starting GUI Server
02:50:53:WU01:FS01:0x11:Completed 1%
02:51:01:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
02:51:31:WU01:FS01:0x11:Completed 2%
02:52:09:WU01:FS01:0x11:Completed 3%
02:52:47:WU01:FS01:0x11:Completed 4%
02:53:25:WU01:FS01:0x11:Completed 5%
02:54:03:WU01:FS01:0x11:Completed 6%
02:54:40:WU01:FS01:0x11:Completed 7%
02:55:18:WU01:FS01:0x11:Completed 8%
02:55:56:WU01:FS01:0x11:Completed 9%
02:56:34:WU01:FS01:0x11:Completed 10%
02:57:12:WU01:FS01:0x11:Completed 11%
02:57:50:WU01:FS01:0x11:Completed 12%
02:58:25:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
02:58:26:WU03:FS02:News: Welcome to Folding@Home
02:58:26:WU03:FS02:Assigned to work server 171.67.108.21
02:58:26:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
02:58:26:WU03:FS02:Connecting to 171.67.108.21:8080
02:58:28:WU01:FS01:0x11:Completed 13%
02:59:07:WU01:FS01:0x11:Completed 14%
02:59:30:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:59:30:WU00:FS00:News: Welcome to Folding@Home
02:59:30:WU00:FS00:Assigned to work server 171.67.108.21
02:59:30:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
02:59:30:WU00:FS00:Connecting to 171.67.108.21:8080
02:59:45:WU01:FS01:0x11:Completed 15%
03:00:23:WU01:FS01:0x11:Completed 16%
03:01:00:WU01:FS01:0x11:Completed 17%
03:01:02:ERROR:WU03:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
03:01:38:WU01:FS01:0x11:Completed 18%
03:02:07:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
03:02:16:WU01:FS01:0x11:Completed 19%
03:02:54:WU01:FS01:0x11:Completed 20%
03:03:31:WU01:FS01:0x11:Completed 21%
03:04:09:WU01:FS01:0x11:Completed 22%
03:04:48:WU01:FS01:0x11:Completed 23%
03:05:25:WU01:FS01:0x11:Completed 24%
03:06:03:WU01:FS01:0x11:Completed 25%
03:06:41:WU01:FS01:0x11:Completed 26%
03:07:18:WU01:FS01:0x11:Completed 27%
03:07:56:WU01:FS01:0x11:Completed 28%
03:08:34:WU01:FS01:0x11:Completed 29%
03:09:15:WU01:FS01:0x11:Completed 30%
03:09:53:WU01:FS01:0x11:Completed 31%
03:10:30:WU01:FS01:0x11:Completed 32%
03:11:08:WU01:FS01:0x11:Completed 33%
03:11:46:WU01:FS01:0x11:Completed 34%
03:12:24:WU01:FS01:0x11:Completed 35%
03:13:02:WU01:FS01:0x11:Completed 36%
03:13:39:WU01:FS01:0x11:Completed 37%
03:14:17:WU01:FS01:0x11:Completed 38%
03:14:54:WU01:FS01:0x11:Completed 39%
03:15:32:WU01:FS01:0x11:Completed 40%
03:16:10:WU01:FS01:0x11:Completed 41%
03:16:22:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
03:16:22:WU03:FS02:News: Welcome to Folding@Home
03:16:22:WU03:FS02:Assigned to work server 171.67.108.21
03:16:22:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:GT200 [GeForce GTX 260] from 171.67.108.21
03:16:22:WU03:FS02:Connecting to 171.67.108.21:8080
03:16:48:WU01:FS01:0x11:Completed 42%
03:17:25:WU01:FS01:0x11:Completed 43%
03:17:27:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:17:27:WU00:FS00:News: Welcome to Folding@Home
03:17:27:WU00:FS00:Assigned to work server 171.67.108.21
03:17:27:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.21
03:17:27:WU00:FS00:Connecting to 171.67.108.21:8080
03:17:46:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
03:18:03:WU01:FS01:0x11:Completed 44%
03:18:41:WU01:FS01:0x11:Completed 45%
03:18:59:ERROR:WU03:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
03:19:19:WU01:FS01:0x11:Completed 46%
03:19:56:WU01:FS01:0x11:Completed 47%
03:20:00:WU02:FS03:0xa4:Completed 75000 out of 1500000 steps  (5%)
03:20:34:WU01:FS01:0x11:Completed 48%
03:21:12:WU01:FS01:0x11:Completed 49%
03:21:49:WU01:FS01:0x11:Completed 50%
03:22:27:WU01:FS01:0x11:Completed 51%
03:23:05:WU01:FS01:0x11:Completed 52%
03:23:43:WU01:FS01:0x11:Completed 53%
Is there something else I should try? Don't mean to highjack this thread from Bobby-Uschi.
P5-133XL
Machine #2:
Machine 3:
Re: 171.67.108.21
Post by P5-133XL »
There is nothing a user can do to fix a server problem. That being said, you can try getting assigned to a different server by adding client-type = advanced to each GPU slot using the Advanced Control: right click the folding systray icon and choose Advanced Control and click configure then go to the slots tab and double click each GPU slot and add client-type with a value of advanced as an extra client option. Save
Bobby-Uschi
Re: 171.67.108.21
After reboot and delete only assignment ... 108.11 only runs wus .. 57reihe for 353pkt.hier is my log.jetzt go back to sleep
- Opening Log file [April 27 22:42:20 UTC]
                       Folding@Home Client Version 6.41r2
Launch directory: C:\Programme\Folding@home\Folding@home-gpu
Executable: C:\Programme\Folding@home\Folding@home-gpu\Folding@home-Win32-gpu.exe
Arguments: -verbosity 9 -advmethods -forcegpu nvidia_g80
[22:42:20] - Ask before connecting: No
[22:42:20] - User name: Bobby-Uschi (Team 34361)
[22:42:20] - User ID: 9BFD3CC3642A68A
[22:42:20] - Machine ID: 2
[22:42:20]
[22:42:20] Gpu type=2 species=11.
[22:42:20] Could not open work queue, generating new queue...
[22:42:20] - Preparing to get new work unit...
[22:42:20] Cleaning up work directory
[22:42:20] - Autosending finished units... [April 27 22:42:20 UTC]
[22:42:20] Trying to send all finished work units
[22:42:20] + Attempting to get work packet
[22:42:20] + No unsent completed units remaining.
[22:42:20] Passkey found
[22:42:20] - Autosend completed
[22:42:20] - Will indicate memory of 2046 MB
[22:42:20] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 7
[22:42:20] - Connecting to assignment server
[22:42:20] Connecting to http://assign-GPU.stanford.edu:8080/
[22:42:21] Posted data.
[22:42:21] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[22:42:21] + News From Folding@Home: Welcome to Folding@Home
[22:42:21] Loaded queue successfully.
[22:42:21] Gpu type=2 species=11.
[22:42:21] Sent data
[22:42:21] Connecting to http://171.67.108.21:8080/
[22:44:21] Posted data.
[22:45:55] Initial: 00AA; + Could not connect to Work Server
[22:45:55] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[22:46:14] + Attempting to get work packet
[22:46:14] Passkey found
[22:46:14] - Will indicate memory of 2046 MB
[22:46:14] Gpu type=2 species=11.
[22:46:14] - Connecting to assignment server
[22:46:14] Connecting to http://assign-GPU.stanford.edu:8080/
[22:46:15] Posted data.
[22:46:15] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[22:46:15] + News From Folding@Home: Welcome to Folding@Home
[22:46:15] Loaded queue successfully.
[22:46:15] Gpu type=2 species=11.
[22:46:15] Sent data
[22:46:15] Connecting to http://171.67.108.21:8080/
[22:48:16] Posted data.
[22:49:49] Initial: 00AA; + Could not connect to Work Server
[22:49:49] - Attempt #2  to get work failed, and no other work to do.
[22:50:08] + Attempting to get work packet
[22:50:08] Passkey found
[22:50:08] - Will indicate memory of 2046 MB
[22:50:08] Gpu type=2 species=11.
[22:50:08] - Connecting to assignment server
[22:50:08] Connecting to http://assign-GPU.stanford.edu:8080/
[22:50:09] Posted data.
[22:50:09] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[22:50:09] + News From Folding@Home: Welcome to Folding@Home
[22:50:09] Loaded queue successfully.
[22:50:09] Gpu type=2 species=11.
[22:50:09] Sent data
[22:50:09] Connecting to http://171.67.108.21:8080/
[22:50:30] - Couldn't send HTTP request to server
[22:50:30] + Could not connect to Work Server
[22:50:30] - Attempt #3  to get work failed, and no other work to do.
[22:51:01] + Attempting to get work packet
[22:51:01] Passkey found
[22:51:01] - Will indicate memory of 2046 MB
[22:51:01] Gpu type=2 species=11.
[22:51:01] - Connecting to assignment server
[22:51:01] Connecting to http://assign-GPU.stanford.edu:8080/
[22:51:02] Posted data.
[22:51:02] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[22:51:02] + News From Folding@Home: Welcome to Folding@Home
[22:51:02] Loaded queue successfully.
[22:51:02] Gpu type=2 species=11.
[22:51:02] Sent data
[22:51:02] Connecting to http://171.67.108.21:8080/
[22:51:23] - Couldn't send HTTP request to server
[22:51:23] + Could not connect to Work Server
[22:51:23] - Attempt #4  to get work failed, and no other work to do.
[22:52:16] + Attempting to get work packet
[22:52:16] Passkey found
[22:52:16] - Will indicate memory of 2046 MB
[22:52:16] Gpu type=2 species=11.
[22:52:16] - Connecting to assignment server
[22:52:16] Connecting to http://assign-GPU.stanford.edu:8080/
[22:52:17] Posted data.
[22:52:17] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[22:52:17] + News From Folding@Home: Welcome to Folding@Home
[22:52:17] Loaded queue successfully.
[22:52:17] Gpu type=2 species=11.
[22:52:17] Sent data
[22:52:17] Connecting to http://171.67.108.21:8080/
[22:54:27] Posted data.
[22:57:03] Initial: 00AA; + Could not connect to Work Server
[22:57:03] - Attempt #5  to get work failed, and no other work to do.
[22:58:27] + Attempting to get work packet
[22:58:27] Passkey found
[22:58:27] - Will indicate memory of 2046 MB
[22:58:27] Gpu type=2 species=11.
[22:58:27] - Connecting to assignment server
[22:58:27] Connecting to http://assign-GPU.stanford.edu:8080/
[22:58:28] Posted data.
[22:58:28] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[22:58:28] + News From Folding@Home: Welcome to Folding@Home
[22:58:28] Loaded queue successfully.
[22:58:28] Gpu type=2 species=11.
[22:58:28] Sent data
[22:58:28] Connecting to http://171.67.108.21:8080/
[22:58:49] - Couldn't send HTTP request to server
[22:58:49] + Could not connect to Work Server
[22:58:49] - Attempt #6  to get work failed, and no other work to do.
[23:01:33] + Attempting to get work packet
[23:01:33] Passkey found
[23:01:33] - Will indicate memory of 2046 MB
[23:01:33] Gpu type=2 species=11.
[23:01:33] - Connecting to assignment server
[23:01:33] Connecting to http://assign-GPU.stanford.edu:8080/
[23:01:34] Posted data.
[23:01:34] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[23:01:34] + News From Folding@Home: Welcome to Folding@Home
[23:01:34] Loaded queue successfully.
[23:01:34] Gpu type=2 species=11.
[23:01:34] Sent data
[23:01:34] Connecting to http://171.67.108.21:8080/
[23:03:34] Posted data.
[23:05:08] Initial: 00AA; + Could not connect to Work Server
[23:05:08] - Attempt #7  to get work failed, and no other work to do.
[23:10:31] + Attempting to get work packet
[23:10:31] Passkey found
[23:10:31] - Will indicate memory of 2046 MB
[23:10:31] Gpu type=2 species=11.
[23:10:31] - Connecting to assignment server
[23:10:31] Connecting to http://assign-GPU.stanford.edu:8080/
[23:10:32] Posted data.
[23:10:32] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[23:10:32] + News From Folding@Home: Welcome to Folding@Home
[23:10:32] Loaded queue successfully.
[23:10:32] Gpu type=2 species=11.
[23:10:32] Sent data
[23:10:32] Connecting to http://171.67.108.21:8080/
[23:10:54] - Couldn't send HTTP request to server
[23:10:54] + Could not connect to Work Server
[23:10:54] - Attempt #8  to get work failed, and no other work to do.
[23:13:06] ***** Got a SIGTERM signal (2)
[23:13:06] Killing all core threads
Folding@Home Client Shutdown.
 Opening Log file [April 27 23:13:17 UTC]
[23:13:17] - Ask before connecting: No
[23:13:17] - User name: Bobby-Uschi (Team 34361)
[23:13:17] - User ID: 9BFD3CC3642A68A
[23:13:17] - Machine ID: 2
[23:13:17]
[23:13:17] Gpu type=2 species=11.
[23:13:17] Loaded queue successfully.
[23:13:17] - Preparing to get new work unit...
[23:13:17] - Autosending finished units... [April 27 23:13:17 UTC]
[23:13:17] Cleaning up work directory
[23:13:17] Trying to send all finished work units
[23:13:17] + No unsent completed units remaining.
[23:13:17] - Autosend completed
[23:13:17] + Attempting to get work packet
[23:13:17] Passkey found
[23:13:17] - Will indicate memory of 2046 MB
[23:13:17] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 7
[23:13:17] - Connecting to assignment server
[23:13:17] Connecting to http://assign-GPU.stanford.edu:8080/
[23:13:18] Posted data.
[23:13:18] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[23:13:18] + News From Folding@Home: Welcome to Folding@Home
[23:13:19] Loaded queue successfully.
[23:13:19] Gpu type=2 species=11.
[23:13:19] Sent data
[23:13:19] Connecting to http://171.67.108.11:8080/
[23:13:19] Posted data.
[23:13:19] Initial: 0000; - Receiving payload (expected size: 45909)
[23:13:20] - Downloaded at ~44 kB/s
[23:13:20] - Averaged speed for that direction ~67 kB/s
[23:13:20] + Received work.
[23:13:20] + Closed connections
[23:13:20]
[23:13:20] + Processing work unit
[23:13:20] Core required: FahCore_11.exe
[23:13:20] Core found.
[23:13:20] Working on queue slot 02 [April 27 23:13:20 UTC]
[23:13:20] + Working ...
[23:13:20] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -nice 19 -checkpoint 15 -verbose -lifeline 3572 -version 641'
[23:13:20]
[23:13:20] *------------------------------*
[23:13:20] Folding@Home GPU Core
[23:13:20] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:13:20]
[23:13:20] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:13:20] Build host: amoeba
[23:13:20] Board Type: Nvidia
[23:13:20] Core      :
[23:13:20] Preparing to commence simulation
[23:13:20] - Looking at optimizations...
[23:13:20] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[23:13:20] - Created dyn
[23:13:20] - Files status OK
[23:13:20] - Expanded 45397 -> 251112 (decompressed 553.1 percent)
[23:13:20] Called DecompressByteArray: compressed_data_size=45397 data_size=251112, decompressed_data_size=251112 diff=0
[23:13:20] - Digital signature verified
[23:13:20]
[23:13:20] Project: 5772 (Run 0, Clone 270, Gen 2970)
[23:13:20]
[23:13:20] Assembly optimizations on if available.
[23:13:20] Entering M.D.
[23:13:26] Tpr hash work/wudata_02.tpr:  1850308677 3956334916 1344244063 2649911690 3053957793
[23:13:26]
[23:13:26] Calling fah_main args: 14 usage=100
[23:13:26]
[23:13:27] Working on Protein
[23:13:27] Client config found, loading data.
[23:13:28] Starting GUI Server
[23:14:01] Completed 1%
[23:14:36] Completed 2%
[23:15:09] Completed 3%
[23:15:43] Completed 4%
[23:16:17] Completed 5%
[23:16:51] Completed 6%
[23:17:25] Completed 7%
[23:17:59] Completed 8%
[23:18:33] Completed 9%
[23:19:06] Completed 10%
[23:19:40] Completed 11%
[23:20:14] Completed 12%
[23:20:48] Completed 13%
[23:21:22] Completed 14%
[23:21:56] Completed 15%
[23:22:30] Completed 16%
[23:23:04] Completed 17%
[23:23:37] Completed 18%
[23:24:11] Completed 19%
[23:24:45] Completed 20%
[23:25:19] Completed 21%
[23:25:53] Completed 22%
[23:26:27] Completed 23%
[23:27:01] Completed 24%
[23:27:34] Completed 25%
[23:28:08] Completed 26%
[23:28:42] Completed 27%
[23:29:16] Completed 28%
[23:29:50] Completed 29%
[23:30:24] Completed 30%
[23:30:58] Completed 31%
[23:31:31] Completed 32%
[23:32:05] Completed 33%
[23:32:39] Completed 34%
[23:33:13] Completed 35%
[23:33:47] Completed 36%
[23:34:21] Completed 37%
[23:34:55] Completed 38%
[23:35:28] Completed 39%
[23:36:02] Completed 40%
[23:36:36] Completed 41%
[23:37:10] Completed 42%
[23:37:44] Completed 43%
[23:38:18] Completed 44%
[23:38:52] Completed 45%
[23:39:25] Completed 46%
[23:39:59] Completed 47%
[23:40:33] Completed 48%
[23:41:07] Completed 49%
[23:41:41] Completed 50%
[23:42:15] Completed 51%
[23:42:49] Completed 52%
[23:43:23] Completed 53%
[23:43:56] Completed 54%
[23:44:30] Completed 55%
[23:45:04] Completed 56%
[23:45:38] Completed 57%
[23:46:12] Completed 58%
[23:46:46] Completed 59%
[23:47:20] Completed 60%
[23:47:53] Completed 61%
[23:48:27] Completed 62%
[23:49:01] Completed 63%
[23:49:35] Completed 64%
[23:50:09] Completed 65%
[23:50:43] Completed 66%
[23:51:17] Completed 67%
[23:51:50] Completed 68%
[23:52:24] Completed 69%
[23:52:58] Completed 70%
[23:53:32] Completed 71%
[23:54:06] Completed 72%
[23:54:40] Completed 73%
[23:55:14] Completed 74%
[23:55:47] Completed 75%
[23:56:21] Completed 76%
[23:56:55] Completed 77%
[23:57:29] Completed 78%
[23:58:03] Completed 79%
[23:58:37] Completed 80%
[23:59:11] Completed 81%
[23:59:44] Completed 82%
[00:00:18] Completed 83%
[00:00:52] Completed 84%
[00:01:26] Completed 85%
[00:02:00] Completed 86%
[00:02:34] Completed 87%
[00:03:08] Completed 88%
[00:03:41] Completed 89%
[00:04:15] Completed 90%
[00:04:49] Completed 91%
[00:05:23] Completed 92%
[00:05:57] Completed 93%
[00:06:31] Completed 94%
[00:07:05] Completed 95%
[00:07:38] Completed 96%
[00:08:12] Completed 97%
[00:08:46] Completed 98%
[00:09:20] Completed 99%
[00:09:54] Completed 100%
[00:09:54] Successful run
[00:09:54] DynamicWrapper: Finished Work Unit: sleep=10000
[00:10:04] Reserved 76568 bytes for xtc file; Cosm status=0
[00:10:04] Allocated 76568 bytes for xtc file
[00:10:04] - Reading up to 76568 from "work/wudata_02.xtc": Read 76568
[00:10:04] Read 76568 bytes from xtc file; available packet space=786353896
[00:10:04] xtc file hash check passed.
[00:10:04] Reserved 15168 15168 786353896 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[00:10:04] Allocated 15168 bytes for arc file
[00:10:04] - Reading up to 15168 from "work/wudata_02.trr": Read 15168
[00:10:04] Read 15168 bytes from arc file; available packet space=786338728
[00:10:04] trr file hash check passed.
[00:10:04] Allocated 560 bytes for edr file
[00:10:04] Read bedfile
[00:10:04] edr file hash check passed.
[00:10:04] Allocated 33327 bytes for logfile
[00:10:04] Read logfile
[00:10:04] GuardedRun: success in DynamicWrapper
[00:10:04] GuardedRun: done
[00:10:04] Run: GuardedRun completed.
[00:10:06] + Opened results file
[00:10:06] - Writing 126135 bytes of core data to disk...
[00:10:06] Done: 125623 -> 100076 (compressed to 79.6 percent)
[00:10:06]   ... Done.
[00:10:06] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[00:10:06] Shutting down core
[00:10:06]
[00:10:06] Folding@home Core Shutdown: FINISHED_UNIT
[00:10:08] CoreStatus = 64 (100)
[00:10:08] Unit 2 finished with 99 percent of time to deadline remaining.
[00:10:08] Updated performance fraction: 0.986850
[00:10:08] Sending work to server
[00:10:08] Project: 5772 (Run 0, Clone 270, Gen 2970)
[00:10:08] - Read packet limit of 540015616... Set to 524286976.
[00:10:08] + Attempting to send results [April 28 00:10:08 UTC]
[00:10:08] - Reading file work/wuresults_02.dat from core
[00:10:08]   (Read 100588 bytes from disk)
[00:10:08] Gpu type=2 species=11.
[00:10:08] Connecting to http://171.67.108.11:8080/
[00:10:10] Posted data.
[00:10:10] Initial: 0000; - Uploaded at ~49 kB/s
[00:10:10] - Averaged speed for that direction ~74 kB/s
[00:10:10] + Results successfully sent
[00:10:10] Thank you for your contribution to Folding@Home.
[00:10:10] + Number of Units Completed: 2444
[00:10:14] Trying to send all finished work units
[00:10:14] + No unsent completed units remaining.
[00:10:14] - Preparing to get new work unit...
[00:10:14] Cleaning up work directory
[00:10:14] + Attempting to get work packet
[00:10:14] Passkey found
[00:10:14] - Will indicate memory of 2046 MB
[00:10:14] Gpu type=2 species=11.
[00:10:14] - Connecting to assignment server
[00:10:14] Connecting to http://assign-GPU.stanford.edu:8080/
[00:10:15] Posted data.
[00:10:15] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[00:10:15] + News From Folding@Home: Welcome to Folding@Home
[00:10:15] Loaded queue successfully.
[00:10:15] Gpu type=2 species=11.
[00:10:15] Sent data
[00:10:15] Connecting to http://171.67.108.11:8080/
[00:10:16] Posted data.
[00:10:16] Initial: 0000; - Receiving payload (expected size: 45982)
[00:10:17] - Downloaded at ~44 kB/s
[00:10:17] - Averaged speed for that direction ~59 kB/s
[00:10:17] + Received work.
[00:10:17] Trying to send all finished work units
[00:10:17] + No unsent completed units remaining.
[00:10:17] + Closed connections
[00:10:17]
[00:10:17] + Processing work unit
[00:10:17] Core required: FahCore_11.exe
[00:10:17] Core found.
[00:10:17] Working on queue slot 03 [April 28 00:10:17 UTC]
[00:10:17] + Working ...
[00:10:17] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -nice 19 -checkpoint 15 -verbose -lifeline 3572 -version 641'
[00:10:17]
[00:10:17] *------------------------------*
[00:10:17] Folding@Home GPU Core
[00:10:17] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[00:10:17]
[00:10:17] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:10:17] Build host: amoeba
[00:10:17] Board Type: Nvidia
[00:10:17] Core      :
[00:10:17] Preparing to commence simulation
[00:10:17] - Looking at optimizations...
[00:10:17] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[00:10:17] - Created dyn
[00:10:17] - Files status OK
[00:10:17] - Expanded 45470 -> 251112 (decompressed 552.2 percent)
[00:10:17] Called DecompressByteArray: compressed_data_size=45470 data_size=251112, decompressed_data_size=251112 diff=0
[00:10:17] - Digital signature verified
[00:10:17]
[00:10:17] Project: 5769 (Run 14, Clone 383, Gen 3441)
[00:10:17]
[00:10:17] Assembly optimizations on if available.
[00:10:17] Entering M.D.
[00:10:23] Tpr hash work/wudata_03.tpr:  2764467931 3204216501 233335564 1785370836 3172042767
[00:10:23]
[00:10:23] Calling fah_main args: 14 usage=100
[00:10:23]
[00:10:23] Working on Protein
[00:10:24] Client config found, loading data.
[00:10:24] Starting GUI Server
[00:10:58] Completed 1%
[00:11:31] Completed 2%
[00:12:05] Completed 3%
[00:12:39] Completed 4%
[00:13:13] Completed 5%
[00:13:47] Completed 6%
[00:14:20] Completed 7%
[00:14:54] Completed 8%
[00:15:28] Completed 9%
[00:16:02] Completed 10%
Re: 171.67.108.21
Count me in.
This server is down and the AS keeps assigning us to it, so it takes a long time before we get a WU from 171.67.108.11 ... and the same story restarts as soon as the current WU is completed :(
Is someone alive at Stanford to take a look ?
Re: 171.67.108.21
From the data I can see on serverstat, I don't understand what's wrong. Help me figure out the scope of the problem.
Is this a problem ONLY for V6 or can somebody post a log from V7 showing the same problem?
Is this a problem for folks who require port 80 access or for those who have port 8080 access too?
Re: 171.67.108.21
Here's an example from my v7 client which can access both 8080 and 80:
20:08:22:WU05:FS02:0xa4:Completed 37500 out of 250000 steps  (15%)
20:08:44:WU03:FS01:0x11:Completed 98%
20:09:04:WU04:FS00:0x11:Completed 99%
20:09:05:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
20:09:07:WU02:FS00:News: Welcome to Folding@Home
20:09:07:WU02:FS00:Assigned to work server 171.67.108.21
20:09:07:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:09:07:WU02:FS00:Connecting to 171.67.108.21:8080
20:09:28:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:09:28:WU02:FS00:Connecting to 171.67.108.21:80
20:09:32:WU03:FS01:0x11:Completed 99%
20:09:33:WU06:FS01:Connecting to assign-GPU.stanford.edu:80
20:09:34:WU06:FS01:News: Welcome to Folding@Home
20:09:34:WU06:FS01:Assigned to work server 171.67.108.21
20:09:34:WU06:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:09:34:WU06:FS01:Connecting to 171.67.108.21:8080
20:09:49:ERROR:WU02:FS00:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:09:49:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
20:09:50:WU02:FS00:News: Welcome to Folding@Home
20:09:50:WU02:FS00:Assigned to work server 171.67.108.21
20:09:50:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:09:50:WU02:FS00:Connecting to 171.67.108.21:8080
20:09:51:WU04:FS00:0x11:Completed 100%
20:09:52:WU04:FS00:0x11:Successful run
20:09:52:WU04:FS00:0x11:DynamicWrapper: Finished Work Unit: sleep=10000
20:09:55:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
20:09:55:WU06:FS01:Connecting to 171.67.108.21:80
20:10:02:WU04:FS00:0x11:Reserved 76264 bytes for xtc file; Cosm status=0
20:10:02:WU04:FS00:0x11:Allocated 76264 bytes for xtc file
20:10:02:WU04:FS00:0x11:- Reading up to 76264 from \"04/wudata_01.xtc\": Read 76264
20:10:02:WU04:FS00:0x11:Read 76264 bytes from xtc file; available packet space=786354200
20:10:02:WU04:FS00:0x11:xtc file hash check passed.
20:10:02:WU04:FS00:0x11:Reserved 15168 15168 786354200 bytes for arc file=<04/wudata_01.trr> Cosm status=0
20:10:02:WU04:FS00:0x11:Allocated 15168 bytes for arc file
20:10:02:WU04:FS00:0x11:- Reading up to 15168 from \"04/wudata_01.trr\": Read 15168
20:10:02:WU04:FS00:0x11:Read 15168 bytes from arc file; available packet space=786339032
20:10:02:WU04:FS00:0x11:trr file hash check passed.
20:10:02:WU04:FS00:0x11:Allocated 560 bytes for edr file
20:10:02:WU04:FS00:0x11:Read bedfile
20:10:02:WU04:FS00:0x11:edr file hash check passed.
20:10:02:WU04:FS00:0x11:Allocated 0 bytes for logfile
20:10:02:WU04:FS00:0x11:Could not open/read logfile=<04/wudata_01.log>; Cosm status=-1
20:10:02:WU04:FS00:0x11:GuardedRun: success in DynamicWrapper
20:10:02:WU04:FS00:0x11:GuardedRun: done
20:10:02:WU04:FS00:0x11:Run: GuardedRun completed.
20:10:04:WU04:FS00:0x11:+ Opened results file
20:10:04:WU04:FS00:0x11:- Writing 92504 bytes of core data to disk...
20:10:04:WU04:FS00:0x11:Done: 91992 -> 90668 (compressed to 98.5 percent)
20:10:04:WU04:FS00:0x11:  ... Done.
20:10:04:WU04:FS00:0x11:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
20:10:04:WU04:FS00:0x11:Shutting down core
20:10:04:WU04:FS00:0x11:Folding@home Core Shutdown: FINISHED_UNIT
20:10:05:WU04:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:10:05:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:5772 run:10 clone:343 gen:1830 core:0x11 unit:0x62a195f0517ec0f007260157000a168c
20:10:05:WU04:FS00:Uploading 89.04KiB to 171.67.108.11
20:10:05:WU04:FS00:Connecting to 171.67.108.11:8080
20:10:09:WU04:FS00:Upload complete
20:10:09:WU04:FS00:Server responded WORK_ACK (400)
20:10:09:WU04:FS00:Cleaning up
20:10:11:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:10:11:WU02:FS00:Connecting to 171.67.108.21:80
20:10:16:ERROR:WU06:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:10:16:WU06:FS01:Connecting to assign-GPU.stanford.edu:80
20:10:18:WU06:FS01:News: Welcome to Folding@Home
20:10:18:WU06:FS01:Assigned to work server 171.67.108.21
20:10:18:WU06:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:10:18:WU06:FS01:Connecting to 171.67.108.21:8080
20:10:20:WU03:FS01:0x11:Completed 100%
20:10:20:WU03:FS01:0x11:Successful run
20:10:20:WU03:FS01:0x11:DynamicWrapper: Finished Work Unit: sleep=10000
20:10:25:WU05:FS02:0xa4:Completed 40000 out of 250000 steps  (16%)
20:10:30:WU03:FS01:0x11:Reserved 75864 bytes for xtc file; Cosm status=0
20:10:30:WU03:FS01:0x11:Allocated 75864 bytes for xtc file
20:10:30:WU03:FS01:0x11:- Reading up to 75864 from \"03/wudata_01.xtc\": Read 75864
20:10:30:WU03:FS01:0x11:Read 75864 bytes from xtc file; available packet space=786354600
20:10:30:WU03:FS01:0x11:xtc file hash check passed.
20:10:30:WU03:FS01:0x11:Reserved 15168 15168 786354600 bytes for arc file=<03/wudata_01.trr> Cosm status=0
20:10:30:WU03:FS01:0x11:Allocated 15168 bytes for arc file
20:10:30:WU03:FS01:0x11:- Reading up to 15168 from \"03/wudata_01.trr\": Read 15168
20:10:30:WU03:FS01:0x11:Read 15168 bytes from arc file; available packet space=786339432
20:10:30:WU03:FS01:0x11:trr file hash check passed.
20:10:30:WU03:FS01:0x11:Allocated 560 bytes for edr file
20:10:30:WU03:FS01:0x11:Read bedfile
20:10:30:WU03:FS01:0x11:edr file hash check passed.
20:10:30:WU03:FS01:0x11:Allocated 0 bytes for logfile
20:10:30:WU03:FS01:0x11:Could not open/read logfile=<03/wudata_01.log>; Cosm status=-1
20:10:30:WU03:FS01:0x11:GuardedRun: success in DynamicWrapper
20:10:30:WU03:FS01:0x11:GuardedRun: done
20:10:30:WU03:FS01:0x11:Run: GuardedRun completed.
20:10:32:ERROR:WU02:FS00:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:10:32:WU03:FS01:0x11:+ Opened results file
20:10:32:WU03:FS01:0x11:- Writing 92104 bytes of core data to disk...
20:10:32:WU03:FS01:0x11:Done: 91592 -> 90344 (compressed to 98.6 percent)
20:10:32:WU03:FS01:0x11:  ... Done.
20:10:32:WU03:FS01:0x11:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
20:10:32:WU03:FS01:0x11:Shutting down core
20:10:32:WU03:FS01:0x11:Folding@home Core Shutdown: FINISHED_UNIT
20:10:33:WU03:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:10:33:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:5765 run:3 clone:239 gen:700 core:0x11 unit:0x1f7ff7fd517ec10702bc00ef00031685
20:10:33:WU03:FS01:Uploading 88.73KiB to 171.67.108.11
20:10:33:WU03:FS01:Connecting to 171.67.108.11:8080
20:10:35:WU03:FS01:Upload complete
20:10:35:WU03:FS01:Server responded WORK_ACK (400)
20:10:35:WU03:FS01:Cleaning up
20:10:39:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
20:10:39:WU06:FS01:Connecting to 171.67.108.21:80
20:10:49:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
20:10:50:WU02:FS00:News: Welcome to Folding@Home
20:10:50:WU02:FS00:Assigned to work server 171.67.108.21
20:10:50:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:10:50:WU02:FS00:Connecting to 171.67.108.21:8080
20:11:00:ERROR:WU06:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:11:16:WU06:FS01:Connecting to assign-GPU.stanford.edu:80
20:11:17:WU06:FS01:News: Welcome to Folding@Home
20:11:17:WU06:FS01:Assigned to work server 171.67.108.21
20:11:18:WU06:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:11:18:WU06:FS01:Connecting to 171.67.108.21:8080
20:11:36:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:11:39:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
20:11:39:WU06:FS01:Connecting to 171.67.108.21:80
20:11:55:WU05:FS02:0xa4:Completed 42500 out of 250000 steps  (17%)
20:12:00:ERROR:WU06:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:12:27:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
20:12:27:WU02:FS00:News: Welcome to Folding@Home
20:12:27:WU02:FS00:Assigned to work server 171.67.108.21
20:12:27:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:12:27:WU02:FS00:Connecting to 171.67.108.21:8080
20:12:48:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:12:48:WU02:FS00:Connecting to 171.67.108.21:80
20:12:53:WU06:FS01:Connecting to assign-GPU.stanford.edu:80
20:12:54:WU06:FS01:News: Welcome to Folding@Home
20:12:54:WU06:FS01:Assigned to work server 171.67.108.21
20:12:55:WU06:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:12:55:WU06:FS01:Connecting to 171.67.108.21:8080
20:13:16:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
20:13:16:WU06:FS01:Connecting to 171.67.108.21:80
20:13:23:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:13:25:WU05:FS02:0xa4:Completed 45000 out of 250000 steps  (18%)
20:13:38:ERROR:WU06:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:14:55:WU05:FS02:0xa4:Completed 47500 out of 250000 steps  (19%)
20:15:04:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
20:15:04:WU02:FS00:News: Welcome to Folding@Home
20:15:04:WU02:FS00:Assigned to work server 171.67.108.21
20:15:05:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:15:05:WU02:FS00:Connecting to 171.67.108.21:8080
20:15:30:WU06:FS01:Connecting to assign-GPU.stanford.edu:80
20:15:31:WU06:FS01:News: Welcome to Folding@Home
20:15:31:WU06:FS01:Assigned to work server 171.67.108.21
20:15:33:WU06:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:15:33:WU06:FS01:Connecting to 171.67.108.21:8080
20:15:54:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
20:15:54:WU06:FS01:Connecting to 171.67.108.21:80
20:16:15:ERROR:WU06:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:16:25:WU05:FS02:0xa4:Completed 50000 out of 250000 steps  (20%)
20:17:54:WU05:FS02:0xa4:Completed 52500 out of 250000 steps  (21%)
20:18:11:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:19:18:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
20:19:19:WU02:FS00:News: Welcome to Folding@Home
20:19:19:WU02:FS00:Assigned to work server 171.67.108.21
20:19:19:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:19:19:WU02:FS00:Connecting to 171.67.108.21:8080
20:19:25:WU05:FS02:0xa4:Completed 55000 out of 250000 steps  (22%)
20:19:40:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:19:40:WU02:FS00:Connecting to 171.67.108.21:80
20:19:45:WU06:FS01:Connecting to assign-GPU.stanford.edu:80
20:19:45:WU06:FS01:News: Welcome to Folding@Home
20:19:45:WU06:FS01:Assigned to work server 171.67.108.21
20:19:47:WU06:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:19:47:WU06:FS01:Connecting to 171.67.108.21:8080
20:20:08:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
20:20:08:WU06:FS01:Connecting to 171.67.108.21:80
20:20:19:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:20:19:WU02:FS00:Cleaning up
20:20:19:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
20:20:20:WU03:FS00:News: Welcome to Folding@Home
20:20:20:WU03:FS00:Assigned to work server 171.67.108.21
20:20:20:WU03:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:20:20:WU03:FS00:Connecting to 171.67.108.21:8080
20:20:29:ERROR:WU06:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:20:29:WU06:FS01:Cleaning up
20:20:29:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
20:20:30:WU02:FS01:News: Welcome to Folding@Home
20:20:30:WU02:FS01:Assigned to work server 171.67.108.21
20:20:30:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:20:30:WU02:FS01:Connecting to 171.67.108.21:8080
20:20:41:WARNING:WU03:FS00:WorkServer connection failed on port 8080 trying 80
20:20:41:WU03:FS00:Connecting to 171.67.108.21:80
20:20:51:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
20:20:51:WU02:FS01:Connecting to 171.67.108.21:80
20:20:55:WU05:FS02:0xa4:Completed 57500 out of 250000 steps  (23%)
20:21:02:ERROR:WU03:FS00:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:21:02:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
20:21:03:WU03:FS00:News: Welcome to Folding@Home
20:21:03:WU03:FS00:Assigned to work server 171.67.108.21
20:21:03:WU03:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:21:03:WU03:FS00:Connecting to 171.67.108.21:8080
20:21:12:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:21:12:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
20:21:13:WU02:FS01:News: Welcome to Folding@Home
20:21:13:WU02:FS01:Assigned to work server 171.67.108.21
20:21:13:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:21:13:WU02:FS01:Connecting to 171.67.108.21:8080
20:21:34:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
20:21:34:WU02:FS01:Connecting to 171.67.108.21:80
20:22:24:WU05:FS02:0xa4:Completed 60000 out of 250000 steps  (24%)
20:23:45:ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:23:45:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
20:23:46:WU03:FS00:News: Welcome to Folding@Home
20:23:46:WU03:FS00:Assigned to work server 171.67.108.21
20:23:46:WU03:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:23:46:WU03:FS00:Connecting to 171.67.108.21:8080
20:23:54:WU05:FS02:0xa4:Completed 62500 out of 250000 steps  (25%)
20:24:07:WARNING:WU03:FS00:WorkServer connection failed on port 8080 trying 80
20:24:07:WU03:FS00:Connecting to 171.67.108.21:80
20:24:10:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:24:11:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
20:24:11:WU02:FS01:News: Welcome to Folding@Home
20:24:11:WU02:FS01:Assigned to work server 171.67.108.21
20:24:11:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:24:11:WU02:FS01:Connecting to 171.67.108.21:8080
20:24:49:ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:25:14:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:25:23:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
20:25:23:WU03:FS00:News: Welcome to Folding@Home
20:25:23:WU03:FS00:Assigned to work server 171.67.108.21
20:25:23:WU03:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:25:23:WU03:FS00:Connecting to 171.67.108.21:8080
20:25:25:WU05:FS02:0xa4:Completed 65000 out of 250000 steps  (26%)
20:25:44:WARNING:WU03:FS00:WorkServer connection failed on port 8080 trying 80
20:25:44:WU03:FS00:Connecting to 171.67.108.21:80
20:25:48:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
20:25:48:WU02:FS01:News: Welcome to Folding@Home
20:25:48:WU02:FS01:Assigned to work server 171.67.108.21
20:25:49:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:25:49:WU02:FS01:Connecting to 171.67.108.21:8080
20:26:05:ERROR:WU03:FS00:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:26:10:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
20:26:10:WU02:FS01:Connecting to 171.67.108.21:80
20:26:31:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:26:55:WU05:FS02:0xa4:Completed 67500 out of 250000 steps  (27%)
20:28:00:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
20:28:00:WU03:FS00:News: Welcome to Folding@Home
20:28:00:WU03:FS00:Assigned to work server 171.67.108.21
20:28:01:WU03:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:28:01:WU03:FS00:Connecting to 171.67.108.21:8080
20:28:22:WARNING:WU03:FS00:WorkServer connection failed on port 8080 trying 80
20:28:22:WU03:FS00:Connecting to 171.67.108.21:80
20:28:24:WU05:FS02:0xa4:Completed 70000 out of 250000 steps  (28%)
20:28:25:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
20:28:26:WU02:FS01:News: Welcome to Folding@Home
20:28:26:WU02:FS01:Assigned to work server 171.67.108.21
20:28:26:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:28:26:WU02:FS01:Connecting to 171.67.108.21:8080
20:28:43:ERROR:WU03:FS00:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:29:54:WU05:FS02:0xa4:Completed 72500 out of 250000 steps  (29%)
20:31:23:WU05:FS02:0xa4:Completed 75000 out of 250000 steps  (30%)
20:31:26:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:32:14:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
20:32:15:WU03:FS00:News: Welcome to Folding@Home
20:32:15:WU03:FS00:Assigned to work server 171.67.108.21
20:32:15:WU03:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:32:15:WU03:FS00:Connecting to 171.67.108.21:8080
20:32:39:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
20:32:40:WU02:FS01:News: Welcome to Folding@Home
20:32:40:WU02:FS01:Assigned to work server 171.67.108.21
20:32:40:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:32:40:WU02:FS01:Connecting to 171.67.108.21:8080
20:32:53:WU05:FS02:0xa4:Completed 77500 out of 250000 steps  (31%)
20:32:56:ERROR:WU03:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:32:56:WU03:FS00:Cleaning up
20:32:56:WU04:FS00:Connecting to assign-GPU.stanford.edu:80
20:32:57:WU04:FS00:News: Welcome to Folding@Home
20:32:57:WU04:FS00:Assigned to work server 171.67.108.21
20:32:57:WU04:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:32:57:WU04:FS00:Connecting to 171.67.108.21:8080
20:33:01:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
20:33:01:WU02:FS01:Connecting to 171.67.108.21:80
20:33:22:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:33:23:WU02:FS01:Cleaning up
20:33:23:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
20:33:23:WU03:FS01:News: Welcome to Folding@Home
20:33:23:WU03:FS01:Assigned to work server 171.67.108.21
20:33:23:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:33:23:WU03:FS01:Connecting to 171.67.108.21:8080
20:33:33:ERROR:WU04:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:33:33:WU04:FS00:Connecting to assign-GPU.stanford.edu:80
20:33:34:WU04:FS00:News: Welcome to Folding@Home
20:33:34:WU04:FS00:Assigned to work server 171.67.108.21
20:33:34:WU04:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:33:34:WU04:FS00:Connecting to 171.67.108.21:8080
20:33:44:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:33:44:WU03:FS01:Connecting to 171.67.108.21:80
20:33:55:WARNING:WU04:FS00:WorkServer connection failed on port 8080 trying 80
20:33:55:WU04:FS00:Connecting to 171.67.108.21:80
20:34:16:ERROR:WU04:FS00:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:34:22:WU05:FS02:0xa4:Completed 80000 out of 250000 steps  (32%)
20:34:33:WU04:FS00:Connecting to assign-GPU.stanford.edu:80
20:34:34:WU04:FS00:News: Welcome to Folding@Home
20:34:34:WU04:FS00:Assigned to work server 171.67.108.21
20:34:34:WU04:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:34:34:WU04:FS00:Connecting to 171.67.108.21:8080
20:35:52:WU05:FS02:0xa4:Completed 82500 out of 250000 steps  (33%)
20:36:27:ERROR:WU03:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:36:27:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
20:36:27:WU03:FS01:News: Welcome to Folding@Home
20:36:27:WU03:FS01:Assigned to work server 171.67.108.21
20:36:27:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:36:27:WU03:FS01:Connecting to 171.67.108.21:8080
20:37:16:ERROR:WU04:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:37:17:WU04:FS00:Connecting to assign-GPU.stanford.edu:80
20:37:17:WU04:FS00:News: Welcome to Folding@Home
20:37:17:WU04:FS00:Assigned to work server 171.67.108.21
20:37:17:WU04:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:37:17:WU04:FS00:Connecting to 171.67.108.21:8080
20:37:22:WU05:FS02:0xa4:Completed 85000 out of 250000 steps  (34%)
20:38:52:WU05:FS02:0xa4:Completed 87500 out of 250000 steps  (35%)
20:39:04:ERROR:WU03:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:39:04:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
20:39:04:WU03:FS01:News: Welcome to Folding@Home
20:39:04:WU03:FS01:Assigned to work server 171.67.108.21
20:39:04:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:39:04:WU03:FS01:Connecting to 171.67.108.21:8080
20:39:25:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:39:25:WU03:FS01:Connecting to 171.67.108.21:80
20:39:46:ERROR:WU03:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:39:59:ERROR:WU04:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:40:00:WU04:FS00:Connecting to assign-GPU.stanford.edu:80
20:40:01:WU04:FS00:News: Welcome to Folding@Home
20:40:01:WU04:FS00:Assigned to work server 171.67.108.21
20:40:01:WU04:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:40:01:WU04:FS00:Connecting to 171.67.108.21:8080
20:40:22:WARNING:WU04:FS00:WorkServer connection failed on port 8080 trying 80
20:40:22:WU04:FS00:Connecting to 171.67.108.21:80
20:40:22:WU05:FS02:0xa4:Completed 90000 out of 250000 steps  (36%)
20:40:41:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
20:40:42:WU03:FS01:News: Welcome to Folding@Home
20:40:42:WU03:FS01:Assigned to work server 171.67.108.21
20:40:42:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:40:42:WU03:FS01:Connecting to 171.67.108.21:8080
20:40:43:ERROR:WU04:FS00:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:41:03:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:41:03:WU03:FS01:Connecting to 171.67.108.21:80
20:41:24:ERROR:WU03:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:41:52:WU05:FS02:0xa4:Completed 92500 out of 250000 steps  (37%)
20:43:18:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
20:43:19:WU03:FS01:News: Welcome to Folding@Home
20:43:19:WU03:FS01:Assigned to work server 171.67.108.21
20:43:19:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:43:19:WU03:FS01:Connecting to 171.67.108.21:8080
20:43:22:WU05:FS02:0xa4:Completed 95000 out of 250000 steps  (38%)
20:43:40:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:43:40:WU03:FS01:Connecting to 171.67.108.21:80
20:44:01:ERROR:WU03:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:44:14:WU04:FS00:Connecting to assign-GPU.stanford.edu:80
20:44:15:WU04:FS00:News: Welcome to Folding@Home
20:44:15:WU04:FS00:Assigned to work server 171.67.108.21
20:44:15:WU04:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:44:15:WU04:FS00:Connecting to 171.67.108.21:8080
20:44:52:WU05:FS02:0xa4:Completed 97500 out of 250000 steps  (39%)
20:46:22:WU05:FS02:0xa4:Completed 100000 out of 250000 steps  (40%)
20:47:16:ERROR:WU04:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:47:16:WU04:FS00:Cleaning up
20:47:16:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
20:47:16:WU02:FS00:News: Welcome to Folding@Home
20:47:16:WU02:FS00:Assigned to work server 171.67.108.21
20:47:16:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:47:16:WU02:FS00:Connecting to 171.67.108.21:8080
20:47:33:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
20:47:33:WU03:FS01:News: Welcome to Folding@Home
20:47:33:WU03:FS01:Assigned to work server 171.67.108.21
20:47:33:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:47:33:WU03:FS01:Connecting to 171.67.108.21:8080
20:47:52:WU05:FS02:0xa4:Completed 102500 out of 250000 steps  (41%)
20:47:54:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:47:54:WU03:FS01:Connecting to 171.67.108.21:80
20:48:15:ERROR:WU03:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:48:15:WU03:FS01:Cleaning up
20:48:16:WU04:FS01:Connecting to assign-GPU.stanford.edu:80
20:48:17:WU04:FS01:News: Welcome to Folding@Home
20:48:17:WU04:FS01:Assigned to work server 171.67.108.21
20:48:17:WU04:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.21
20:48:17:WU04:FS01:Connecting to 171.67.108.21:8080
20:48:38:WARNING:WU04:FS01:WorkServer connection failed on port 8080 trying 80
20:48:38:WU04:FS01:Connecting to 171.67.108.21:80
20:48:59:ERROR:WU04:FS01:Exception: Failed to connect to 171.67.108.21:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
20:48:59:WU04:FS01:Connecting to assign-GPU.stanford.edu:80
20:49:00:WU04:FS01:News: Welcome to Folding@Home
20:49:00:WU04:FS01:Assigned to work server 171.67.108.11
20:49:00:WU04:FS01:Requesting new work unit for slot 01: READY gpu:1:\"G92 [GeForce 9800 GTX]\" from 171.67.108.11
20:49:00:WU04:FS01:Connecting to 171.67.108.11:8080
20:49:00:WU04:FS01:Downloading 46.09KiB
20:49:01:WU04:FS01:Download complete
20:49:01:WU04:FS01:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:5765 run:1 clone:175 gen:2685 core:0x11 unit:0x328b1e85517edcc50a7d00af00011685
20:49:01:WU04:FS01:Starting
20:49:01:WU04:FS01:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/toTOW/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 04 -suffix 01 -version 702 -lifeline 2336 -checkpoint 15 -gpu 1
20:49:01:WU04:FS01:Started FahCore on PID 3428
20:49:01:Started thread 15 on PID 2336
20:49:01:WU04:FS01:Core PID:3616
20:49:01:WU04:FS01:FahCore 0x11 started
20:49:02:WU04:FS01:0x11:
20:49:02:WU04:FS01:0x11:*------------------------------*
20:49:02:WU04:FS01:0x11:Folding@Home GPU Core
20:49:02:WU04:FS01:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
20:49:02:WU04:FS01:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
20:49:02:WU04:FS01:0x11:Build host: amoeba
20:49:02:WU04:FS01:0x11:Board Type: Nvidia
20:49:02:WU04:FS01:0x11:Core      :
20:49:02:WU04:FS01:0x11:Preparing to commence simulation
20:49:02:WU04:FS01:0x11:- Looking at optimizations...
20:49:02:WU04:FS01:0x11:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
20:49:02:WU04:FS01:0x11:- Created dyn
20:49:02:WU04:FS01:0x11:- Files status OK
20:49:02:WU04:FS01:0x11:- Expanded 46689 -> 252912 (decompressed 541.6 percent)
20:49:02:WU04:FS01:0x11:Called DecompressByteArray: compressed_data_size=46689 data_size=252912, decompressed_data_size=252912 diff=0
20:49:02:WU04:FS01:0x11:- Digital signature verified
20:49:02:WU04:FS01:0x11:Project: 5765 (Run 1, Clone 175, Gen 2685)
20:49:02:WU04:FS01:0x11:Assembly optimizations on if available.
20:49:02:WU04:FS01:0x11:Entering M.D.
20:49:08:WU04:FS01:0x11:Tpr hash 04/wudata_01.tpr:  818174469 538218005 2953391151 2338264217 4186198845
20:49:08:WU04:FS01:0x11:Calling fah_main args: 14 usage=100
20:49:08:WU04:FS01:0x11:Working on Protein
20:49:08:WU04:FS01:0x11:Client config unavailable.
20:49:09:WU04:FS01:0x11:Starting GUI Server
20:49:25:WU05:FS02:0xa4:Completed 105000 out of 250000 steps  (42%)
20:49:56:WU04:FS01:0x11:Completed 1%
20:49:59:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:49:59:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
20:50:00:WU02:FS00:News: Welcome to Folding@Home
20:50:00:WU02:FS00:Assigned to work server 171.67.108.11
20:50:00:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:\"G92 [GeForce 9800 GTX]\" from 171.67.108.11
20:50:00:WU02:FS00:Connecting to 171.67.108.11:8080
20:50:00:WU02:FS00:Downloading 46.14KiB
20:50:01:WU02:FS00:Download complete
20:50:01:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:5766 run:7 clone:128 gen:2173 core:0x11 unit:0x4589a169517edd01087d008000071686
20:50:01:WU02:FS00:Starting
20:50:01:WU02:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/toTOW/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 02 -suffix 01 -version 702 -lifeline 2336 -checkpoint 15 -gpu 0
20:50:01:WU02:FS00:Started FahCore on PID 3656
20:50:01:Started thread 16 on PID 2336
20:50:01:WU02:FS00:Core PID:1168
20:50:01:WU02:FS00:FahCore 0x11 started
20:50:02:WU02:FS00:0x11:
20:50:02:WU02:FS00:0x11:*------------------------------*
20:50:02:WU02:FS00:0x11:Folding@Home GPU Core
20:50:02:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
20:50:02:WU02:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
20:50:02:WU02:FS00:0x11:Build host: amoeba
20:50:02:WU02:FS00:0x11:Board Type: Nvidia
20:50:02:WU02:FS00:0x11:Core      :
20:50:02:WU02:FS00:0x11:Preparing to commence simulation
20:50:02:WU02:FS00:0x11:- Looking at optimizations...
20:50:02:WU02:FS00:0x11:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
20:50:02:WU02:FS00:0x11:- Created dyn
20:50:02:WU02:FS00:0x11:- Files status OK
20:50:02:WU02:FS00:0x11:- Expanded 46735 -> 252912 (decompressed 541.1 percent)
20:50:02:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=46735 data_size=252912, decompressed_data_size=252912 diff=0
20:50:02:WU02:FS00:0x11:- Digital signature verified
20:50:02:WU02:FS00:0x11:Project: 5766 (Run 7, Clone 128, Gen 2173)
20:50:02:WU02:FS00:0x11:Assembly optimizations on if available.
20:50:02:WU02:FS00:0x11:Entering M.D.
20:50:07:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr:  2542483503 2170477300 3329825129 929152764 1433653268
20:50:07:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
20:50:08:WU02:FS00:0x11:Working on Protein
20:50:08:WU02:FS00:0x11:Client config unavailable.
20:50:08:WU02:FS00:0x11:Starting GUI Server
20:50:43:WU04:FS01:0x11:Completed 2%
20:50:56:WU02:FS00:0x11:Completed 1%
20:51:23:WU05:FS02:0xa4:Completed 107500 out of 250000 steps  (43%)
20:51:31:WU04:FS01:0x11:Completed 3%
20:51:43:WU02:FS00:0x11:Completed 2%
20:52:19:WU04:FS01:0x11:Completed 4%
20:52:31:WU02:FS00:0x11:Completed 3%
20:53:07:WU04:FS01:0x11:Completed 5%
20:53:19:WU02:FS00:0x11:Completed 4%
20:53:22:WU05:FS02:0xa4:Completed 110000 out of 250000 steps  (44%)
20:53:54:WU04:FS01:0x11:Completed 6%
20:54:07:WU02:FS00:0x11:Completed 5%
20:54:42:WU04:FS01:0x11:Completed 7%
20:54:55:WU02:FS00:0x11:Completed 6%
20:55:23:WU05:FS02:0xa4:Completed 112500 out of 250000 steps  (45%)
20:55:30:WU04:FS01:0x11:Completed 8%
20:55:43:WU02:FS00:0x11:Completed 7%
20:56:18:WU04:FS01:0x11:Completed 9%
20:56:31:WU02:FS00:0x11:Completed 8%
20:57:05:WU04:FS01:0x11:Completed 10%
20:57:16:WU05:FS02:0xa4:Completed 115000 out of 250000 steps  (46%)
20:57:19:WU02:FS00:0x11:Completed 9%
20:57:53:WU04:FS01:0x11:Completed 11%
20:58:06:WU02:FS00:0x11:Completed 10%
20:58:41:WU04:FS01:0x11:Completed 12%
20:58:54:WU02:FS00:0x11:Completed 11%
20:59:12:WU05:FS02:0xa4:Completed 117500 out of 250000 steps  (47%)
20:59:29:WU04:FS01:0x11:Completed 13%
20:59:42:WU02:FS00:0x11:Completed 12%
21:00:16:WU04:FS01:0x11:Completed 14%
21:00:30:WU02:FS00:0x11:Completed 13%
21:01:04:WU04:FS01:0x11:Completed 15%
21:01:13:WU05:FS02:0xa4:Completed 120000 out of 250000 steps  (48%)
21:01:18:WU02:FS00:0x11:Completed 14%
21:01:52:WU04:FS01:0x11:Completed 16%
21:02:06:WU02:FS00:0x11:Completed 15%
21:02:39:WU04:FS01:0x11:Completed 17%
21:02:54:WU02:FS00:0x11:Completed 16%
21:03:13:WU05:FS02:0xa4:Completed 122500 out of 250000 steps  (49%)
21:03:27:WU04:FS01:0x11:Completed 18%
21:03:42:WU02:FS00:0x11:Completed 17%
21:04:09:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10503 run:197 clone:0 gen:519 core:0x11 unit:0x000005906652eda54b716b1300004cf0
21:04:09:WU01:FS00:Uploading 128.31KiB to 171.67.108.21
21:04:09:WU01:FS00:Connecting to 171.67.108.21:8080
21:04:15:WU04:FS01:0x11:Completed 19%
21:04:30:WU02:FS00:0x11:Completed 18%
21:05:03:WU04:FS01:0x11:Completed 20%
21:05:03:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:10504 run:165 clone:1 gen:494 core:0x11 unit:0x0000059e6652eda54b75afd700004cb6
21:05:03:WU00:FS01:Uploading 127.84KiB to 171.67.108.21
21:05:03:WU00:FS01:Connecting to 171.67.108.21:8080
21:05:06:WU05:FS02:0xa4:Completed 125000 out of 250000 steps  (50%)
21:05:17:WU02:FS00:0x11:Completed 19%
21:05:24:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:05:24:WU00:FS01:Connecting to 171.67.108.21:80
21:05:50:WU04:FS01:0x11:Completed 21%
21:06:05:WU02:FS00:0x11:Completed 20%
21:06:38:WU04:FS01:0x11:Completed 22%
21:06:45:WU01:FS00:Upload 49.88%
21:06:45:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
21:06:45:WU01:FS00:Trying to send results to collection server
21:06:45:WU01:FS00:Uploading 128.31KiB to 171.67.108.26
21:06:45:WU01:FS00:Connecting to 171.67.108.26:8080
21:06:53:WU02:FS00:0x11:Completed 21%
21:06:58:WU05:FS02:0xa4:Completed 127500 out of 250000 steps  (51%)
21:07:06:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
21:07:06:WU01:FS00:Connecting to 171.67.108.26:80
21:07:26:WU04:FS01:0x11:Completed 23%
21:07:27:ERROR:WU01:FS00:Exception: Failed to connect to 171.67.108.26:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
21:07:41:WU02:FS00:0x11:Completed 22%
21:08:07:WU00:FS01:Upload 50.06%
21:08:07:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
21:08:07:WU00:FS01:Trying to send results to collection server
21:08:07:WU00:FS01:Uploading 127.84KiB to 171.67.108.26
21:08:07:WU00:FS01:Connecting to 171.67.108.26:8080
21:08:14:WU04:FS01:0x11:Completed 24%
21:08:28:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:08:28:WU00:FS01:Connecting to 171.67.108.26:80
21:08:29:WU02:FS00:0x11:Completed 23%
21:08:49:ERROR:WU00:FS01:Exception: Failed to connect to 171.67.108.26:80: Une tentative de connexion a ?chou? car le parti connect? n?a pas r?pondu convenablement au-del? d?une certaine dur?e ou une connexion ?tablie a ?chou? car l?h?te de connexion n?a pas r?pondu.
21:08:49:WU00:FS01:Downloading project 10504 description
21:08:49:WU00:FS01:Connecting to fah-web.stanford.edu:80
21:08:52:WU00:FS01:Project 10504 description downloaded successfully
21:09:00:WU05:FS02:0xa4:Completed 130000 out of 250000 steps  (52%)
21:09:01:WU04:FS01:0x11:Completed 25%
21:09:17:WU02:FS00:0x11:Completed 24%
21:09:49:WU04:FS01:0x11:Completed 26%
21:10:05:WU02:FS00:0x11:Completed 25%
21:10:37:WU04:FS01:0x11:Completed 27%
21:10:53:WU02:FS00:0x11:Completed 26%
21:10:59:WU05:FS02:0xa4:Completed 132500 out of 250000 steps  (53%)
21:11:24:WU04:FS01:0x11:Completed 28%
21:11:40:WU02:FS00:0x11:Completed 27%
21:12:12:WU04:FS01:0x11:Completed 29%
21:12:28:WU02:FS00:0x11:Completed 28%
21:12:54:WU05:FS02:0xa4:Completed 135000 out of 250000 steps  (54%)
21:13:00:WU04:FS01:0x11:Completed 30%
21:13:16:WU02:FS00:0x11:Completed 29%
21:13:48:WU04:FS01:0x11:Completed 31%
21:14:04:WU02:FS00:0x11:Completed 30%
21:14:35:WU04:FS01:0x11:Completed 32%
21:14:52:WU02:FS00:0x11:Completed 31%
21:14:59:WU05:FS02:0xa4:Completed 137500 out of 250000 steps  (55%)
Ripper36
Re: 171.67.108.21
Post by Ripper36 »
This is my v7 log after I deleted a completed unit that failed to upload, and started again
*********************** Log Started 2013-04-29T23:27:24Z ***********************
23:27:24:WU00:FS02:Cleaning up
23:27:25:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
23:27:26:WU00:FS02:News: Welcome to Folding@Home
23:27:26:WU00:FS02:Assigned to work server 171.67.108.21
23:27:26:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
23:27:26:WU00:FS02:Connecting to 171.67.108.21:8080
23:30:57:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
23:30:57:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
23:30:58:WU00:FS02:News: Welcome to Folding@Home
23:30:58:WU00:FS02:Assigned to work server 171.67.108.21
23:30:58:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
23:30:58:WU00:FS02:Connecting to 171.67.108.21:8080
23:33:19:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
23:33:19:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
23:33:20:WU00:FS02:News: Welcome to Folding@Home
23:33:20:WU00:FS02:Assigned to work server 171.67.108.21
23:33:20:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
23:33:20:WU00:FS02:Connecting to 171.67.108.21:8080
23:36:56:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
23:36:57:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
23:36:57:WU00:FS02:News: Welcome to Folding@Home
23:36:57:WU00:FS02:Assigned to work server 171.67.108.21
23:36:57:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
23:36:57:WU00:FS02:Connecting to 171.67.108.21:8080
23:39:33:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
23:39:34:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
23:39:35:WU00:FS02:News: Welcome to Folding@Home
23:39:35:WU00:FS02:Assigned to work server 171.67.108.21
23:39:35:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
23:39:35:WU00:FS02:Connecting to 171.67.108.21:8080
23:39:56:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
23:39:56:WU00:FS02:Connecting to 171.67.108.21:80
23:40:17:ERROR:WU00:FS02:Exception: Failed to connect to 171.67.108.21:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:43:48:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
23:43:49:WU00:FS02:News: Welcome to Folding@Home
23:43:49:WU00:FS02:Assigned to work server 171.67.108.21
23:43:49:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
23:43:49:WU00:FS02:Connecting to 171.67.108.21:8080
23:46:05:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
23:50:40:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
23:50:40:WU00:FS02:News: Welcome to Folding@Home
23:50:40:WU00:FS02:Assigned to work server 171.67.108.21
23:50:40:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
23:50:40:WU00:FS02:Connecting to 171.67.108.21:8080
23:54:17:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
00:01:45:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
00:01:46:WU00:FS02:News: Welcome to Folding@Home
00:01:46:WU00:FS02:Assigned to work server 171.67.108.21
00:01:46:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
00:01:46:WU00:FS02:Connecting to 171.67.108.21:8080
00:02:07:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
00:02:07:WU00:FS02:Connecting to 171.67.108.21:80
00:04:35:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
00:19:42:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
00:19:43:WU00:FS02:News: Welcome to Folding@Home
00:19:43:WU00:FS02:Assigned to work server 171.67.108.21
00:19:43:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
00:19:43:WU00:FS02:Connecting to 171.67.108.21:8080
00:22:03:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
00:48:44:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
00:48:45:WU00:FS02:News: Welcome to Folding@Home
00:48:45:WU00:FS02:Assigned to work server 171.67.108.21
00:48:45:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
00:48:45:WU00:FS02:Connecting to 171.67.108.21:8080
00:52:22:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
01:35:43:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
01:35:44:WU00:FS02:News: Welcome to Folding@Home
01:35:44:WU00:FS02:Assigned to work server 171.67.108.21
01:35:44:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
01:35:44:WU00:FS02:Connecting to 171.67.108.21:8080
01:38:57:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
02:51:44:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
02:51:45:WU00:FS02:News: Welcome to Folding@Home
02:51:45:WU00:FS02:Assigned to work server 171.67.108.21
02:51:45:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GT216 [GeForce GT 220] from 171.67.108.21
02:51:45:WU00:FS02:Connecting to 171.67.108.21:8080
02:55:45:ERROR:WU00:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
Re: 171.67.108.21
Your mistake was trying to "fix" something that you can't fix.
You already know that server 171.67.108.21 has a reported problem. My guess is that it probably needs a reboot and neither you nor I can do that. Until the server's manager intervenes you need to just be patient. They've been notified.
Messing with FAH's files on your computer is prohibited by the EULA -- and probably a bad idea, too, except maybe when you are directed to do something specific. Deleting a WU that "will not upload" is useless especially when it's hung. The client is designed to resend the WU whenever the server is working again. The "short response" message indicates that your client is still trying to upload to that server and the server is still unable to accept the upload. All you've done is to guarantee you will not get credit for it when the server is fixed.
DaveQual
Re: 171.67.108.21
Post by DaveQual »
I guess I will just keep an eye on this thread, and give my GTS250 a rest....
VijayPande
Pande Group Member
Re: 171.67.108.21
Post by VijayPande »
We're looking into this now.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
DaveQual
Re: 171.67.108.21
Post by DaveQual »
Do we have an update.....maybe?
Re: 171.67.108.21
They'll post again when they know more.
Re: 171.67.108.21
7im wrote:They'll post again when they know more.
... or not.
More often than not it just starts working again. :D
