I have 5 Fermi GPU's waiting for work connected to 171.67.108.36
They all look like this:
15:58:23:WU01:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
15:58:23:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:58:23:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8070 run:285 clone:2 gen:111 core:0x15 unit:0x0000007f6652edb45122e091f32b32ee
15:58:23:WU01:FS00:Uploading 341.17KiB to 171.67.108.36
15:58:23:WU01:FS00:Connecting to 171.67.108.36:8080
15:59:00:WU01:FS00:Upload complete
15:59:00:WU01:FS00:Server responded WORK_ACK (400)
15:59:00:WU01:FS00:Final credit estimate, 3874.00 points
15:59:00:WU01:FS00:Cleaning up
Windows XP and 7
Client V7.2.x and 7.3.x
GPU3
The troubleshooting steps all gave me OK, but I'm not getting work.
AS 171.67.108.36 no work? (fixed)
Last edited by thebluebumblebee on Sat Apr 13, 2013 6:53 pm, edited 1 time in total.
Re: AS 171.67.108.36 no work?
Can a problem with one computer cascade across a network? I had one client/slot/computer do what's listed above and then every other client/slot that finished after that did the same. The only fix has been to restart the systems involved.
Re: AS 171.67.108.36 no work? (fixed)
Did you configure the next-unit-percentage value or not?
Can you find the following lines in your log:
12:32:05:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
12:32:07:WU01:FS00:News: Welcome to Folding@Home
12:32:07:WU01:FS00:Assigned to work server 171.67.108.149
12:32:07:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GF114 [GeForce GTX 675M]" from 171.67.108.149
12:32:07:WU01:FS00:Connecting to 171.67.108.149:8080
Sometimes, if there was a connectivity issue, the slot will be stuck, attempting to download a WU. Currently, that is fixed by restart the client or the system, depending on how it was installed.
Never touched the next-unit-percentage value. One of my systems has been running for a couple weeks and I had not touched it when this happened.
If that's the case, it should automatically attempt to get a new WU near 99% (if that's the default). This line indicates it and maybe you can try to find it in your log:
Normally, if it happened once, it can be chalked up to a rare glitch somewhere. However, if it happens often, then troubleshooting would be required.
