Did I get credit for a WU?
RMouse
Post by RMouse »
It appears that I shut down my client just as a WU was being uploaded. It is not clear to me from the log if this upload went smoothly. I dont see a work accepted notice. Did it go OK?
16:13:51:WU00:FS00:0x11:Completed 92%
******************************** Date: 09/04/13 ********************************
17:04:25:WU00:FS00:0x11:Completed 93%
17:24:39:WU01:FS01:0xa4:Completed 750000 out of 1500000 steps  (50%)
17:55:01:WU00:FS00:0x11:Completed 94%
18:40:42:WU01:FS01:0xa4:Completed 765000 out of 1500000 steps  (51%)
18:45:36:WU00:FS00:0x11:Completed 95%
19:36:10:WU00:FS00:0x11:Completed 96%
19:56:46:WU01:FS01:0xa4:Completed 780000 out of 1500000 steps  (52%)
20:26:44:WU00:FS00:0x11:Completed 97%
21:12:42:WU01:FS01:0xa4:Completed 795000 out of 1500000 steps  (53%)
21:17:19:WU00:FS00:0x11:Completed 98%
22:01:43:WU00:FS00:0x11:Completed 99%
22:01:44:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
22:01:45:WU02:FS00:News: Welcome to Folding@Home
22:01:45:WU02:FS00:Assigned to work server 171.67.108.21
22:01:45:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"G98M [Quadro NVS 160M]" from 171.67.108.21
22:01:45:WU02:FS00:Connecting to 171.67.108.21:8080
22:01:46:WU02:FS00:Downloading 61.84KiB
22:01:47:WU02:FS00:Download complete
22:01:47:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:10503 run:88 clone:1 gen:1579 core:0x11 unit:0x00000d0a6652eda54b716a2200002265
22:01:47:WU02:FS00:Downloading project 10503 description
22:01:47:WU02:FS00:Connecting to fah-web.stanford.edu:80
22:01:48:WU02:FS00:Project 10503 description downloaded successfully
22:27:23:WU01:FS01:0xa4:Completed 810000 out of 1500000 steps  (54%)
22:41:42:WU00:FS00:0x11:Completed 100%
22:41:42:WU00:FS00:0x11:Successful run
22:41:42:WU00:FS00:0x11:DynamicWrapper: Finished Work Unit: sleep=10000
22:41:52:WU00:FS00:0x11:Reserved 75808 bytes for xtc file; Cosm status=0
22:41:52:WU00:FS00:0x11:Allocated 75808 bytes for xtc file
22:41:52:WU00:FS00:0x11:- Reading up to 75808 from "00/wudata_01.xtc": Read 75808
22:41:52:WU00:FS00:0x11:Read 75808 bytes from xtc file; available packet space=786354656
22:41:52:WU00:FS00:0x11:xtc file hash check passed.
22:41:52:WU00:FS00:0x11:Reserved 15168 15168 786354656 bytes for arc file=<00/wudata_01.trr> Cosm status=0
22:41:52:WU00:FS00:0x11:Allocated 15168 bytes for arc file
22:41:52:WU00:FS00:0x11:- Reading up to 15168 from "00/wudata_01.trr": Read 15168
22:41:52:WU00:FS00:0x11:Read 15168 bytes from arc file; available packet space=786339488
22:41:52:WU00:FS00:0x11:trr file hash check passed.
22:41:52:WU00:FS00:0x11:Allocated 560 bytes for edr file
22:41:52:WU00:FS00:0x11:Read bedfile
22:41:52:WU00:FS00:0x11:edr file hash check passed.
22:41:52:WU00:FS00:0x11:Allocated 35759 bytes for logfile
22:41:52:WU00:FS00:0x11:Read logfile
22:41:52:WU00:FS00:0x11:GuardedRun: success in DynamicWrapper
22:41:52:WU00:FS00:0x11:GuardedRun: done
22:41:52:WU00:FS00:0x11:Run: GuardedRun completed.
22:41:55:WU00:FS00:0x11:+ Opened results file
22:41:55:WU00:FS00:0x11:- Writing 127807 bytes of core data to disk...
22:41:55:WU00:FS00:0x11:Done: 127295 -> 99721 (compressed to 78.3 percent)
22:41:55:WU00:FS00:0x11:  ... Done.
22:41:55:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
22:41:55:WU00:FS00:0x11:Shutting down core
22:41:55:WU00:FS00:0x11:Folding@home Core Shutdown: FINISHED_UNIT
22:41:55:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:41:55:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5765 run:1 clone:137 gen:2671 core:0x11 unit:0x2475d085515ee8850a6f008900011685
22:41:55:WU00:FS00:Uploading 97.88KiB to 171.67.108.11
22:41:55:WU02:FS00:Starting
22:41:55:WU00:FS00:Connecting to 171.67.108.11:8080
22:41:55:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/ /Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 2632 -checkpoint 15 -gpu 0
22:41:56:WU02:FS00:Started FahCore on PID 1372
22:41:56:WU02:FS00:Core PID:4292
22:41:56:WU02:FS00:FahCore 0x11 started
22:41:56:WU02:FS00:0x11:
22:41:56:WU02:FS00:0x11:*------------------------------*
22:41:56:WU02:FS00:0x11:Folding@Home GPU Core
22:41:56:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
22:41:56:WU02:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
22:41:56:WU02:FS00:0x11:Build host: amoeba
22:41:56:WU02:FS00:0x11:Board Type: Nvidia
22:41:56:WU02:FS00:0x11:Core      :
22:41:56:WU02:FS00:0x11:Preparing to commence simulation
22:41:56:WU02:FS00:0x11:- Looking at optimizations...
22:41:56:WU02:FS00:0x11:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
22:41:56:WU02:FS00:0x11:- Created dyn
22:41:56:WU02:FS00:0x11:- Files status OK
22:41:56:WU02:FS00:0x11:- Expanded 62808 -> 336799 (decompressed 536.2 percent)
22:41:56:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=62808 data_size=336799, decompressed_data_size=336799 diff=0
22:41:56:WU02:FS00:0x11:- Digital signature verified
22:41:56:WU02:FS00:0x11:Project: 10503 (Run 88, Clone 1, Gen 1579)
22:41:56:WU02:FS00:0x11:Assembly optimizations on if available.
22:41:56:WU02:FS00:0x11:Entering M.D.
22:41:58:WU00:FS00:Upload complete
22:41:58:WU00:FS00:Server responded WORK_ACK (400)
22:41:58:WU00:FS00:Cleaning up
22:42:02:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr:  3777764675 913588796 3470253201 2284722564 3863124111
22:42:02:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
22:42:03:WU02:FS00:0x11:Working on Protein
22:42:12:WU02:FS00:0x11:Client config unavailable.
22:42:12:WU02:FS00:0x11:Starting GUI Server
23:05:17:FS00:Paused
23:05:17:FS01:Paused
23:05:17:FS00:Shutting core down
23:05:17:FS01:Shutting core down
23:05:19:WU02:FS00:0x11:Client no longer detected. Shutting down core
23:05:19:WU02:FS00:0x11:Folding@home Core Shutdown: CLIENT_DIED
23:05:20:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:05:22:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
01:14:13:FS00:Unpaused
01:14:13:FS01:Unpaused
01:14:13:WU01:FS01:Starting
01:14:13:WU01:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/ /Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 2632 -checkpoint 15 -np 2
01:14:14:WU01:FS01:Started FahCore on PID 4904
01:14:15:WU01:FS01:Core PID:4688
01:14:15:WU01:FS01:FahCore 0xa4 started
01:14:15:WU02:FS00:Starting
01:14:15:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/ /Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 2632 -checkpoint 15 -gpu 0
01:14:15:WU02:FS00:Started FahCore on PID 5440
01:14:16:WU02:FS00:Core PID:5192
01:14:16:WU02:FS00:FahCore 0x11 started
01:14:16:WU01:FS01:0xa4:
01:14:16:WU01:FS01:0xa4:*------------------------------*
01:14:16:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
01:14:16:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
01:14:16:WU01:FS01:0xa4:Preparing to commence simulation
01:14:16:WU01:FS01:0xa4:- Looking at optimizations...
01:14:16:WU01:FS01:0xa4:- Files status OK
01:14:16:WU01:FS01:0xa4:- Expanded 2053776 -> 5365960 (decompressed 261.2 percent)
01:14:16:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2053776 data_size=5365960, decompressed_data_size=5365960 diff=0
01:14:16:WU01:FS01:0xa4:- Digital signature verified
01:14:16:WU01:FS01:0xa4:Project: 7808 (Run 0, Clone 342, Gen 35)
01:14:16:WU01:FS01:0xa4:Assembly optimizations on if available.
01:14:16:WU01:FS01:0xa4:Entering M.D.
01:14:17:WU02:FS00:0x11:
01:14:17:WU02:FS00:0x11:*------------------------------*
01:14:17:WU02:FS00:0x11:Folding@Home GPU Core
01:14:17:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
01:14:17:WU02:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
01:14:17:WU02:FS00:0x11:Build host: amoeba
01:14:17:WU02:FS00:0x11:Board Type: Nvidia
01:14:17:WU02:FS00:0x11:Core      :
01:14:17:WU02:FS00:0x11:Preparing to commence simulation
01:14:17:WU02:FS00:0x11:- Looking at optimizations...
01:14:17:WU02:FS00:0x11:- Files status OK
01:14:17:WU02:FS00:0x11:- Expanded 62808 -> 336799 (decompressed 536.2 percent)
01:14:17:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=62808 data_size=336799, decompressed_data_size=336799 diff=0
01:14:17:WU02:FS00:0x11:- Digital signature verified
01:14:17:WU02:FS00:0x11:Project: 10503 (Run 88, Clone 1, Gen 1579)
01:14:17:WU02:FS00:0x11:Assembly optimizations on if available.
01:14:17:WU02:FS00:0x11:Entering M.D.
01:14:23:WU01:FS01:0xa4:Using Gromacs checkpoints
01:14:23:WU02:FS00:0x11:Will resume from checkpoint file
01:14:23:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr:  3777764675 913588796 3470253201 2284722564 3863124111
01:14:23:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
01:14:23:WU01:FS01:0xa4:Mapping NT from 2 to 2
01:14:24:WU02:FS00:0x11:Working on Protein
01:14:24:WU01:FS01:0xa4:Resuming from checkpoint
01:14:24:WU01:FS01:0xa4:Verified 01/wudata_01.log
01:14:24:WU01:FS01:0xa4:Verified 01/wudata_01.trr
01:14:24:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
01:14:24:WU01:FS01:0xa4:Verified 01/wudata_01.edr
01:14:25:WU01:FS01:0xa4:Completed 815900 out of 1500000 steps  (54%)
01:14:27:WU02:FS00:0x11:Client config unavailable.
01:14:27:WU02:FS00:0x11:Starting GUI Server
01:14:27:WU02:FS00:0x11:Resuming from checkpoint
01:14:27:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
01:14:27:WU02:FS00:0x11:   0   3777764675   3777764675
01:14:27:WU02:FS00:0x11:   1    913588796    913588796
01:14:27:WU02:FS00:0x11:   2   3470253201   3470253201
01:14:27:WU02:FS00:0x11:   3   2284722564   2284722564
01:14:27:WU02:FS00:0x11:   4   3863124111   3863124111
01:14:27:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
01:14:27:WU02:FS00:0x11:fcCheckPointResume: state restored.
01:14:27:WU02:FS00:0x11:Verified 02/wudata_01.log
01:14:27:WU02:FS00:0x11:Verified 02/wudata_01.edr
01:14:27:WU02:FS00:0x11:Verified 02/wudata_01.xtc
Re: Did I get credit for a WU?
As best as I can tell, you mean this WU:
Hi RattyM (team 0),
Your WU (P5765 R1 C137 G2671) was added to the stats database on 2013-04-09 16:08:34 for 353 points of credit.
Yes it uploaded okay and you were credited for the WU.
The accepted notice was there:
Since this is a WU from an older server no estimated points will be reported in your log. That function is only available on servers running newer versions of the software.
RMouse
Post by RMouse »
Thanks....i missed that in all that data. Is there a danger in shutting down the client at the wrong moment? odds are I wont be in the middle of up an upload, but I should be more careful if there is a danger in losing data.
Yes, there are some points at which a client shutdown can cause problems. If it happens exactly as a checkpoint is being written, a crash can corrupt the checkpoint file in the process of being written to disk. Another time is the gap between when the core is finished processing the WU, it has reached 100%, and when the results are packed up to return. That is done when you see this kind of message in the log:
In this case it is only a few seconds, but a larger WU can take somewhat longer to be readied for return. Most other interruptions will at least restart from the last checkpoint, these rarer cases do happen occasionally.
RMouse
Post by RMouse »
Thank you!
