Project 7660 (Run 429, Clone 0, Gen 119) BAD_WORK_UNIT
davidcoton
Post by davidcoton »
Filtered log (FS01):
22:01:57:WU01:FS01:Starting
22:01:57:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/David/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 703 -lifeline 5576 -checkpoint 5 -gpu 0 -gpu-vendor nvidia -forceasm
22:01:57:WU01:FS01:Started FahCore on PID 1476
22:01:57:WU01:FS01:Core PID:5240
22:01:57:WU01:FS01:FahCore 0x15 started
22:01:58:WU01:FS01:0x15:
22:01:58:WU01:FS01:0x15:*------------------------------*
22:01:58:WU01:FS01:0x15:Folding@Home GPU Core
22:01:58:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
22:01:58:WU01:FS01:0x15:Build host             AmoebaRemote
22:01:58:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
22:01:58:WU01:FS01:0x15:Core                   15
22:01:58:WU01:FS01:0x15:Window's signal control handler registered.
22:01:58:WU01:FS01:0x15:Preparing to commence simulation
22:01:58:WU01:FS01:0x15:- Assembly optimizations manually forced on.
22:01:58:WU01:FS01:0x15:- Not checking prior termination.
22:01:58:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
22:01:58:WU01:FS01:0x15:- Expanded 79608 -> 307810 (decompressed 386.6 percent)
22:01:58:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=79608 data_size=307810, decompressed_data_size=307810 diff=0
22:01:58:WU01:FS01:0x15:- Digital signature verified
22:01:58:WU01:FS01:0x15:Project: 7660 (Run 429, Clone 0, Gen 119)
22:01:58:WU01:FS01:0x15:Assembly optimizations on if available.
22:01:58:WU01:FS01:0x15:Entering M.D.
22:02:00:WU01:FS01:0x15:Will resume from checkpoint file 01/wudata_01.ckp
22:02:00:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  1764449408 1480868224 1212840203 3808538766 2907388838
22:02:00:WU01:FS01:0x15:GPU device id=0
22:02:02:WU01:FS01:0x15:Working on Protein
22:02:02:WU01:FS01:0x15:Client config unavailable.
22:02:02:WU01:FS01:0x15:Starting GUI Server
22:04:13:WU01:FS01:0x15:Resuming from checkpoint
22:04:13:WU01:FS01:0x15:fcCheckPointResume: retreived and current tpr file hash:
22:04:13:WU01:FS01:0x15:   0   1764449408   1764449408
22:04:13:WU01:FS01:0x15:   1   1480868224   1480868224
22:04:13:WU01:FS01:0x15:   2   1212840203   1212840203
22:04:13:WU01:FS01:0x15:   3   3808538766   3808538766
22:04:13:WU01:FS01:0x15:   4   2907388838   2907388838
22:04:13:WU01:FS01:0x15:fcCheckPointResume: file hashes same.
22:04:13:WU01:FS01:0x15:fcCheckPointResume: state restored.
22:04:13:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
22:04:13:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
22:04:13:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
22:04:13:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
22:04:13:WU01:FS01:0x15:fcCheckPointResume: state restored 2
22:04:13:WU01:FS01:0x15:Resumed from checkpoint
22:04:13:WU01:FS01:0x15:Setting checkpoint frequency: 400000
22:04:13:WU01:FS01:0x15:Completed  13600001 out of 40000000 steps (34%).
23:45:20:WU01:FS01:0x15:Completed  28400000 out of 40000000 steps (71%).
23:48:03:WU01:FS01:0x15:Completed  28800000 out of 40000000 steps (72%).
23:49:08:WU01:FS01:0x15:Run: exception thrown in GuardedRun -- cannot continue further.
23:49:08:WU01:FS01:0x15:Going to send back what have done -- stepsTotalG=40000000
23:49:08:WU01:FS01:0x15:Work fraction=0.7240 steps=40000000.
23:49:12:WU01:FS01:0x15:logfile size=26469 infoLength=26469 edr=0 trr=23
23:49:12:WU01:FS01:0x15:+ Opened results file
23:49:12:WU01:FS01:0x15:- Writing 27005 bytes of core data to disk...
23:49:12:WU01:FS01:0x15:Done: 26493 -> 6067 (compressed to 22.9 percent)
23:49:12:WU01:FS01:0x15:  ... Done.
23:49:12:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
23:49:13:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:49:13:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:7660 run:429 clone:0 gen:119 core:0x15 unit:0x00000083664f2dd150f83f622ccde0b5
23:49:13:WU01:FS01:Uploading 6.42KiB to 171.64.65.105
23:49:13:WU01:FS01:Connecting to 171.64.65.105:8080
23:49:13:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
23:49:14:WU01:FS01:Upload complete
23:49:14:WU01:FS01:Server responded WORK_ACK (400)
23:49:14:WU01:FS01:Cleaning up
Config (CPU not overclocked, generally stable):
*********************** Log Started 2013-03-30T22:01:45Z ***********************
22:01:45:************************* Folding@home Client *************************
22:01:45:      Website: http://folding.stanford.edu/
22:01:45:    Copyright: (c) 2009-2013 Stanford University
22:01:45:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:01:45:         Args:
22:01:45:       Config: C:/Users/David/AppData/Roaming/FAHClient/config.xml
22:01:45:******************************** Build ********************************
22:01:45:      Version: 7.3.6
22:01:45:         Date: Feb 18 2013
22:01:45:         Time: 15:25:17
22:01:45:      SVN Rev: 3923
22:01:45:       Branch: fah/trunk/client
22:01:45:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
22:01:45:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
22:01:45:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
22:01:45:     Platform: win32 XP
22:01:45:         Bits: 32
22:01:45:         Mode: Release
22:01:45:******************************* System ********************************
22:01:45:          CPU: AMD Athlon(tm) II X4 640 Processor
22:01:45:       CPU ID: AuthenticAMD Family 16 Model 5 Stepping 3
22:01:45:         CPUs: 4
22:01:45:       Memory: 3.50GiB
22:01:45:  Free Memory: 2.31GiB
22:01:45:      Threads: WINDOWS_THREADS
22:01:45:  Has Battery: false
22:01:45:   On Battery: false
22:01:45:   UTC offset: 0
22:01:45:          PID: 5576
22:01:45:          CWD: C:/Users/David/AppData/Roaming/FAHClient
22:01:45:           OS: Windows Vista (TM) Home Premium Service Pack 2
22:01:45:      OS Arch: X86
22:01:45:         GPUs: 1
22:01:45:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 660 Ti]
22:01:45:         CUDA: 3.0
22:01:45:  CUDA Driver: 5000
22:01:45:Win32 Service: false
22:01:45:***********************************************************************
22:01:45:<config>
22:01:45:  <service-description v='Folding@home Client'/>
22:01:45:  <service-restart v='true'/>
22:01:45:  <service-restart-delay v='5000'/>
22:01:45:
22:01:45:  <!-- Client Control -->
22:01:45:  <client-threads v='4'/>
22:01:45:  <cycle-rate v='4'/>
22:01:45:  <cycles v='-1'/>
22:01:45:  <data-directory v='.'/>
22:01:45:  <disable-sleep-when-active v='true'/>
22:01:45:  <exec-directory v='C:\Program Files\FAHClient'/>
22:01:45:  <exit-when-done v='false'/>
22:01:45:  <fold-anon v='false'/>
22:01:45:  <open-web-control v='false'/>
22:01:45:
22:01:45:  <!-- Configuration -->
22:01:45:  <config-rotate v='true'/>
22:01:45:  <config-rotate-dir v='configs'/>
22:01:45:  <config-rotate-max v='16'/>
22:01:45:
22:01:45:  <!-- Debugging -->
22:01:45:  <assignment-servers>
22:01:45:    assign3.stanford.edu:8080 assign4.stanford.edu:80
22:01:45:  </assignment-servers>
22:01:45:  <capture-directory v='capture'/>
22:01:45:  <capture-on-error v='false'/>
22:01:45:  <capture-packets v='false'/>
22:01:45:  <capture-requests v='false'/>
22:01:45:  <capture-responses v='false'/>
22:01:45:  <capture-sockets v='false'/>
22:01:45:  <debug-sockets v='false'/>
22:01:45:  <exception-locations v='true'/>
22:01:45:  <gpu-assignment-servers>
22:01:45:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
22:01:45:  </gpu-assignment-servers>
22:01:45:  <stack-traces v='false'/>
22:01:45:
22:01:45:  <!-- Error Handling -->
22:01:45:  <max-slot-errors v='5'/>
22:01:45:  <max-unit-errors v='5'/>
22:01:45:
22:01:45:  <!-- Folding Core -->
22:01:45:  <checkpoint v='5'/>
22:01:45:  <core-dir v='cores'/>
22:01:45:  <core-priority v='idle'/>
22:01:45:  <cpu-affinity v='false'/>
22:01:45:  <cpu-usage v='100'/>
22:01:45:  <gpu-usage v='100'/>
22:01:45:  <no-assembly v='false'/>
22:01:45:
22:01:45:  <!-- Folding Slot Configuration -->
22:01:45:  <cause v='ANY'/>
22:01:45:  <client-subtype v='STDCLI'/>
22:01:45:  <client-type v='advanced'/>
22:01:45:  <cpu-species v='X86_AMD'/>
22:01:45:  <cpu-type v='X86'/>
22:01:45:  <cpus v='-1'/>
22:01:45:  <cuda-index v='0'/>
22:01:45:  <extra-core-args v='-forceasm'/>
22:01:45:  <gpu v='true'/>
22:01:45:  <max-packet-size v='normal'/>
22:01:45:  <opencl-index v='0'/>
22:01:45:  <os-species v='UNKNOWN'/>
22:01:45:  <os-type v='WIN32'/>
22:01:45:  <power v='full'/>
22:01:45:  <project-key v='0'/>
22:01:45:  <smp v='true'/>
22:01:45:
22:01:45:  <!-- HTTP Server -->
22:01:45:  <allow v='127.0.0.1 192.168.1.0/24'/>
22:01:45:  <connection-timeout v='60'/>
22:01:45:  <deny v='0/0'/>
22:01:45:  <http-addresses v='0:7396'/>
22:01:45:  <https-addresses v=''/>
22:01:45:  <max-connect-time v='900'/>
22:01:45:  <max-connections v='800'/>
22:01:45:  <max-request-length v='52428800'/>
22:01:45:  <min-connect-time v='300'/>
22:01:45:  <threads v='4'/>
22:01:45:
22:01:45:  <!-- Logging -->
22:01:45:  <log v='log.txt'/>
22:01:45:  <log-color v='false'/>
22:01:45:  <log-crlf v='true'/>
22:01:45:  <log-date v='false'/>
22:01:45:  <log-date-periodically v='21600'/>
22:01:45:  <log-debug v='true'/>
22:01:45:  <log-domain v='false'/>
22:01:45:  <log-header v='true'/>
22:01:45:  <log-level v='true'/>
22:01:45:  <log-no-info-header v='true'/>
22:01:45:  <log-redirect v='false'/>
22:01:45:  <log-rotate v='true'/>
22:01:45:  <log-rotate-dir v='logs'/>
22:01:45:  <log-rotate-max v='16'/>
22:01:45:  <log-short-level v='false'/>
22:01:45:  <log-simple-domains v='true'/>
22:01:45:  <log-thread-id v='false'/>
22:01:45:  <log-thread-prefix v='true'/>
22:01:45:  <log-time v='true'/>
22:01:45:  <log-to-screen v='true'/>
22:01:45:  <log-truncate v='false'/>
22:01:45:  <verbosity v='5'/>
22:01:45:
22:01:45:  <!-- Network -->
22:01:45:  <proxy v=':8080'/>
22:01:45:  <proxy-enable v='false'/>
22:01:45:  <proxy-pass v=''/>
22:01:45:  <proxy-user v=''/>
22:01:45:
22:01:45:  <!-- Process Control -->
22:01:45:  <child v='false'/>
22:01:45:  <daemon v='false'/>
22:01:45:  <pid v='false'/>
22:01:45:  <pid-file v='Folding@home Client.pid'/>
22:01:45:  <respawn v='false'/>
22:01:45:  <service v='false'/>
22:01:45:
22:01:45:  <!-- Remote Command Server -->
22:01:45:  <command-address v='0.0.0.0'/>
22:01:45:  <command-allow-no-pass v='127.0.0.1'/>
22:01:45:  <command-deny-no-pass v='0/0'/>
22:01:45:  <command-port v='36330'/>
22:01:45:  <password v='*******'/>
22:01:45:
22:01:45:  <!-- Slot Control -->
22:01:45:  <idle v='false'/>
22:01:45:  <max-shutdown-wait v='60'/>
22:01:45:  <pause-on-battery v='true'/>
22:01:45:  <pause-on-start v='false'/>
22:01:45:
22:01:45:  <!-- User Information -->
22:01:45:  <machine-id v='0'/>
22:01:45:  <passkey v='********************************'/>
22:01:45:  <team v='0'/>
22:01:45:  <user v='davidcoton'/>
22:01:45:
22:01:45:  <!-- Web Server -->
22:01:45:  <session-timeout v='3600'/>
22:01:45:  <web-allow v='127.0.0.1'/>
22:01:45:  <web-deny v='0/0'/>
22:01:45:
22:01:45:  <!-- Work Unit Control -->
22:01:45:  <dump-after-deadline v='true'/>
22:01:45:  <max-queue v='16'/>
22:01:45:  <max-units v='0'/>
22:01:45:  <next-unit-percentage v='99'/>
22:01:45:
22:01:45:  <!-- Folding Slots -->
22:01:45:  <slot id='0' type='CPU'>
22:01:45:    <cpus v='4'/>
22:01:45:  </slot>
22:01:45:  <slot id='1' type='GPU'/>
22:01:45:</config>
David
bollix47
Re: Project 7660 (Run 429, Clone 0, Gen 119) BAD_WORK_UNIT
Post by bollix47 »
Another folder was able to complete this work unit for full credit:
Hi xxxxx (team xxx),
Your WU (P7660 R429 C0 G119) was added to the stats database on 2013-03-30 21:08:38 for 4431 points of credit.
