This message appears often, and it doesn't allow me to help. Complete message says:
FahCore_16.exe - System Error
The program can't start because OpenCL.dll is missing from your computer. Try reinstalling the program to fix this problem.
I already reinstalled it several times, and I'm still receiving the same message, any help?
Re: FahCore_16.exe - System Error
Welcome to the F@H Forum Krampus,
Can you please tell us which F@H Client you are using? Moreover, it would help us if you posted the log file here (viewtopic.php?f=61&t=16206) and told us what driver version you are using with your GPU.
OpenCL.dll should be delivered with the drivers for your GPU. Which version(s) of drivers are you running?
Thank you PhanterX for greeting me, it is my pleasure to be here.
I am not very familiar with forums, but instructions here are very clear, and as much as I would love to post my log file in the given URL (Welcome to the f@h forum), the topic is locked and I am unable to post the log there. I will leave the log info here for right now. Thanks in advance.
I am using F@H V.7.3.6
*********************** Log Started 2013-03-20T22:22:37Z ***********************
22:22:37:************************* Folding@home Client *************************
22:22:37: Website: http://folding.stanford.edu/
22:22:37: Copyright: (c) 2009-2013 Stanford University
22:22:37: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:22:37: Args: --open-web-control
22:22:37: Config: C:/Users/AAFES/AppData/Roaming/FAHClient/config.xml
22:22:37:******************************** Build ********************************
22:22:37: Version: 7.3.6
22:22:37: Date: Feb 18 2013
22:22:37: Time: 15:25:17
22:22:37: SVN Rev: 3923
22:22:37: Branch: fah/trunk/client
22:22:37: Compiler: Intel(R) C++ MSVC 1500 mode 1200
22:22:37: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
22:22:37: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
22:22:37: Platform: win32 XP
22:22:37: Bits: 32
22:22:37: Mode: Release
22:22:37:******************************* System ********************************
22:22:37: CPU: AMD A4-3300M APU with Radeon(tm) HD Graphics
22:22:37: CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
22:22:37: CPUs: 2
22:22:37: Memory: 3.48GiB
22:22:37: Free Memory: 1.76GiB
22:22:37: Threads: WINDOWS_THREADS
22:22:37: Has Battery: true
22:22:37: On Battery: true
22:22:37: UTC offset: -7
22:22:37: PID: 372
22:22:37: CWD: C:/Users/AAFES/AppData/Roaming/FAHClient
22:22:37: OS: Microsoft Windows XP Service Pack 2
22:22:37: OS Arch: AMD64
22:22:37: GPUs: 1
22:22:37: GPU 0: ATI:4 AMD Radeon(TM) HD 6480G
22:22:37: CUDA: Not detected
22:22:37:Win32 Service: false
22:22:37:***********************************************************************
22:22:37:<config>
22:22:37: <!-- Folding Slot Configuration -->
22:22:37: <power v='full'/>
22:22:37:
22:22:37: <!-- User Information -->
22:22:37: <passkey v='********************************'/>
22:22:37: <user v='Krampus'/>
22:22:37:
22:22:37: <!-- Folding Slots -->
22:22:37: <slot id='0' type='GPU'/>
22:22:37: <slot id='1' type='CPU'/>
22:22:37:</config>
22:22:37:Trying to access database...
22:22:37:Successfully acquired database lock
22:22:37:Enabled folding slot 00: PAUSED gpu:0:AMD Radeon(TM) HD 6480G (on battery)
22:22:37:Enabled folding slot 01: PAUSED cpu:1 (on battery)
22:22:47:3:127.0.0.1:New Web connection
22:25:23:WU00:FS01:Starting
22:25:23:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 372 -checkpoint 15
22:25:23:WU00:FS01:Started FahCore on PID 1196
22:25:26:WU00:FS01:Core PID:2156
22:25:26:WU00:FS01:FahCore 0xa4 started
22:25:27:WU01:FS00:Starting
22:25:27:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 372 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:25:27:WU01:FS00:Started FahCore on PID 5152
22:25:27:WU00:FS01:0xa4:
22:25:27:WU00:FS01:0xa4:*------------------------------*
22:25:27:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
22:25:27:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
22:25:27:WU00:FS01:0xa4:Preparing to commence simulation
22:25:27:WU00:FS01:0xa4:- Looking at optimizations...
22:25:27:WU00:FS01:0xa4:- Files status OK
22:25:27:WU00:FS01:0xa4:- Expanded 647188 -> 1659468 (decompressed 256.4 percent)
22:25:27:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=647188 data_size=1659468, decompressed_data_size=1659468 diff=0
22:25:27:WU00:FS01:0xa4:- Digital signature verified
22:25:27:WU00:FS01:0xa4:Project: 8079 (Run 495, Clone 2, Gen 12)
22:25:27:WU00:FS01:0xa4:Assembly optimizations on if available.
22:25:27:WU00:FS01:0xa4:Entering M.D.
22:25:28:WU01:FS00:Core PID:2704
22:25:28:WU01:FS00:FahCore 0x16 started
22:25:31:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:25:31:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
22:25:32:WU01:FS00:Starting
22:25:32:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 372 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:25:32:WU01:FS00:Started FahCore on PID 5344
22:25:32:WU01:FS00:Core PID:4112
22:25:32:WU01:FS00:FahCore 0x16 started
22:25:33:WU00:FS01:0xa4:Mapping NT from 1 to 1
22:25:34:WU00:FS01:0xa4:Completed 0 out of 500000 steps (0%)
22:25:35:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:25:35:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
22:25:35:WARNING:WU01:FS00:Too many errors, failing
22:25:35:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:11293 run:29 clone:215 gen:42 core:0x16 unit:0x0000035d6652edbc4d94bae89f2f175a
22:25:35:WU01:FS00:Connecting to 171.67.108.44:8080
22:25:35:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
22:25:35:WU01:FS00:Server responded WORK_QUIT (404)
22:25:35:WARNING:WU01:FS00:Server did not like results, dumping
22:25:36:WU01:FS00:Cleaning up
22:25:37:WU02:FS00:News: Welcome to Folding@Home
22:25:37:WU02:FS00:Assigned to work server 171.67.108.44
22:25:37:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:AMD Radeon(TM) HD 6480G from 171.67.108.44
22:25:37:WU02:FS00:Connecting to 171.67.108.44:8080
22:25:38:WU02:FS00:Downloading 44.39KiB
22:25:38:WU02:FS00:Download complete
22:25:38:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11292 run:11 clone:118 gen:18 core:0x16 unit:0x000001636652edbc4d62a42de73fc5f9
22:25:39:WU02:FS00:Starting
22:25:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 372 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:25:39:WU02:FS00:Started FahCore on PID 3344
22:25:39:WU02:FS00:Core PID:720
22:25:39:WU02:FS00:FahCore 0x16 started
22:25:41:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:25:41:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
22:25:42:WU02:FS00:Starting
22:25:42:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 372 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:25:42:WU02:FS00:Started FahCore on PID 4248
22:25:42:WU02:FS00:Core PID:4240
22:25:42:WU02:FS00:FahCore 0x16 started
22:25:44:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:25:44:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
22:25:51:FS01:Shutting core down
22:25:57:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
- Hardware configuration: i5-3570k plus GTX 560 Ti and GTX 460.
It looks like he's running Windows XP. I don't think ATI/AMD has released drivers for XP that supported OpenCL since 12.1 or so.
I tried with different settings, the previous log was according to windows troubleshooter, the best option to get it to work. Now I reinstall it, and I am using Win7.
This a new log, well it's just a different OS, but still, I have the same error message.
*********************** Log Started 2013-03-21T10:02:10Z ***********************
10:02:10:************************* Folding@home Client *************************
10:02:10: Website: http://folding.stanford.edu/
10:02:10: Copyright: (c) 2009-2013 Stanford University
10:02:10: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:02:10: Args: --open-web-control
10:02:10: Config: C:/Users/AAFES/AppData/Roaming/FAHClient/config.xml
10:02:10:******************************** Build ********************************
10:02:10: Version: 7.3.6
10:02:10: Date: Feb 18 2013
10:02:10: Time: 15:25:17
10:02:10: SVN Rev: 3923
10:02:10: Branch: fah/trunk/client
10:02:10: Compiler: Intel(R) C++ MSVC 1500 mode 1200
10:02:10: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
10:02:10: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
10:02:10: Platform: win32 XP
10:02:10: Bits: 32
10:02:10: Mode: Release
10:02:10:******************************* System ********************************
10:02:10: CPU: AMD A4-3300M APU with Radeon(tm) HD Graphics
10:02:10: CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
10:02:10: CPUs: 2
10:02:10: Memory: 3.48GiB
10:02:10: Free Memory: 1.71GiB
10:02:10: Threads: WINDOWS_THREADS
10:02:10: Has Battery: true
10:02:10: On Battery: false
10:02:10: UTC offset: -7
10:02:10: PID: 3752
10:02:10: CWD: C:/Users/AAFES/AppData/Roaming/FAHClient
10:02:10: OS: Windows 7 Ultimate
10:02:10: OS Arch: AMD64
10:02:10: GPUs: 1
10:02:10: GPU 0: ATI:4 AMD Radeon(TM) HD 6480G
10:02:10: CUDA: Not detected
10:02:10:Win32 Service: false
10:02:10:***********************************************************************
10:02:10:<config>
10:02:10: <!-- Folding Slot Configuration -->
10:02:10: <power v='full'/>
10:02:10:
10:02:10: <!-- User Information -->
10:02:10: <passkey v='********************************'/>
10:02:10: <user v='Krampus'/>
10:02:10:
10:02:10: <!-- Folding Slots -->
10:02:10: <slot id='0' type='GPU'/>
10:02:10: <slot id='1' type='CPU'/>
10:02:10:</config>
10:02:10:Trying to access database...
10:02:10:Successfully acquired database lock
10:02:10:Enabled folding slot 00: READY gpu:0:AMD Radeon(TM) HD 6480G
10:02:10:Enabled folding slot 01: READY cpu:1
10:02:10:WU00:FS01:Starting
10:02:10:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 3752 -checkpoint 15
10:02:11:WU00:FS01:Started FahCore on PID 6804
10:02:12:WU00:FS01:Core PID:5092
10:02:12:WU00:FS01:FahCore 0xa4 started
10:02:12:WU02:FS00:Starting
10:02:12:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 3752 -checkpoint 15 -gpu 0 -gpu-vendor ati
10:02:12:WU02:FS00:Started FahCore on PID 4908
10:02:12:WU02:FS00:Core PID:1208
10:02:12:WU02:FS00:FahCore 0x16 started
10:02:12:WU00:FS01:0xa4:
10:02:12:WU00:FS01:0xa4:*------------------------------*
10:02:12:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
10:02:12:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
10:02:12:WU00:FS01:0xa4:Preparing to commence simulation
10:02:12:WU00:FS01:0xa4:- Looking at optimizations...
10:02:12:WU00:FS01:0xa4:- Files status OK
10:02:12:WU00:FS01:0xa4:- Expanded 647188 -> 1659468 (decompressed 256.4 percent)
10:02:12:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=647188 data_size=1659468, decompressed_data_size=1659468 diff=0
10:02:12:WU00:FS01:0xa4:- Digital signature verified
10:02:12:WU00:FS01:0xa4:Project: 8079 (Run 495, Clone 2, Gen 12)
10:02:12:WU00:FS01:0xa4:Assembly optimizations on if available.
10:02:12:WU00:FS01:0xa4:Entering M.D.
10:02:14:3:127.0.0.1:New Web connection
10:02:14:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:02:14:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
10:02:14:WU02:FS00:Starting
10:02:14:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 3752 -checkpoint 15 -gpu 0 -gpu-vendor ati
10:02:15:WU02:FS00:Started FahCore on PID 3684
10:02:15:WU02:FS00:Core PID:4800
10:02:15:WU02:FS00:FahCore 0x16 started
10:02:19:WU00:FS01:0xa4:Mapping NT from 1 to 1
10:02:19:WU00:FS01:0xa4:Completed 0 out of 500000 steps (0%)
10:02:20:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:02:20:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
10:03:15:WU02:FS00:Starting
10:03:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 3752 -checkpoint 15 -gpu 0 -gpu-vendor ati
10:03:15:WU02:FS00:Started FahCore on PID 5740
10:03:15:WU02:FS00:Core PID:572
10:03:15:WU02:FS00:FahCore 0x16 started
10:03:18:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:03:18:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
10:04:15:WU02:FS00:Starting
10:04:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 3752 -checkpoint 15 -gpu 0 -gpu-vendor ati
10:04:15:WU02:FS00:Started FahCore on PID 5156
10:04:15:WU02:FS00:Core PID:2480
10:04:15:WU02:FS00:FahCore 0x16 started
10:04:19:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:04:19:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
10:05:15:WU02:FS00:Starting
10:05:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 3752 -checkpoint 15 -gpu 0 -gpu-vendor ati
10:05:15:WU02:FS00:Started FahCore on PID 2476
10:05:15:WU02:FS00:Core PID:4468
10:05:15:WU02:FS00:FahCore 0x16 started
10:05:18:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:05:18:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
10:05:18:WARNING:WU02:FS00:Too many errors, failing
10:05:18:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:11292 run:11 clone:25 gen:20 core:0x16 unit:0x000000c36652edbc4d07b995fad2d7fc
10:05:18:WU02:FS00:Connecting to 171.67.108.44:8080
10:05:19:WU02:FS00:Server responded WORK_QUIT (404)
10:05:19:WARNING:WU02:FS00:Server did not like results, dumping
10:05:19:WU02:FS00:Cleaning up
10:05:19:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
10:05:19:WU01:FS00:News: Welcome to Folding@Home
10:05:19:WU01:FS00:Assigned to work server 171.67.108.44
10:05:19:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:AMD Radeon(TM) HD 6480G from 171.67.108.44
10:05:19:WU01:FS00:Connecting to 171.67.108.44:8080
10:05:20:WU01:FS00:Downloading 44.57KiB
10:05:20:WU01:FS00:Download complete
10:05:20:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11292 run:3 clone:31 gen:14 core:0x16 unit:0x000000c26652edbc4d07b9714eebc380
10:05:20:WU01:FS00:Starting
10:05:20:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 3752 -checkpoint 15 -gpu 0 -gpu-vendor ati
10:05:20:WU01:FS00:Started FahCore on PID 4312
10:05:21:WU01:FS00:Core PID:5296
10:05:21:WU01:FS00:FahCore 0x16 started
10:05:27:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:05:27:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
10:05:27:WU01:FS00:Starting
10:05:27:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/AAFES/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 3752 -checkpoint 15 -gpu 0 -gpu-vendor ati
10:05:27:WU01:FS00:Started FahCore on PID 5692
10:05:27:WU01:FS00:Core PID:5384
10:05:27:WU01:FS00:FahCore 0x16 started
10:05:29:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:05:29:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
Machine #2:
Machine 3:
0xc0000135 is an error running the Microsoft .net framework. I'd suggest that you re-install .net
Nevermind, I checked my firewall and FahCore_16.exe wasn't being blocked, then I checked the antivirus firewall, I have Kaspersky Internet Security 2011, and there it was FahCore_16.exe being blocked, I gave it the privilege to send data and it worked. Thank you all anyways. Save and salvage some information for future wanderers like me. I also found that the antivirus was blocking another program which was HideConsole.exe, I also put that program into the antivirus whitelist so the Folding could start.
