FAULTY project:8077 run:14 clone:3 gen:25 + Another
Kornflake
Post by Kornflake »
*********************** Log Started 2013-02-24T16:09:49Z ***********************
16:09:49:************************* Folding@home Client *************************
16:09:49:      Website: http://folding.stanford.edu/
16:09:49:    Copyright: (c) 2009-2012 Stanford University
16:09:49:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:09:49:         Args: --lifeline 2224 --command-port=36330
16:09:49:       Config: C:/Users/user/AppData/Roaming/FAHClient/config.xml
16:09:49:******************************** Build ********************************
16:09:49:      Version: 7.2.9
16:09:49:         Date: Oct 3 2012
16:09:49:         Time: 18:05:48
16:09:49:      SVN Rev: 3578
16:09:49:       Branch: fah/trunk/client
16:09:49:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:09:49:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:09:49:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:09:49:     Platform: win32 XP
16:09:49:         Bits: 32
16:09:49:         Mode: Release
16:09:49:******************************* System ********************************
16:09:49:          CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
16:09:49:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:09:49:         CPUs: 4
16:09:49:       Memory: 2.97GiB
16:09:49:  Free Memory: 2.01GiB
16:09:49:      Threads: WINDOWS_THREADS
16:09:49:   On Battery: false
16:09:49:   UTC offset: -5
16:09:49:          PID: 2188
16:09:49:          CWD: C:/Users/user/AppData/Roaming/FAHClient
16:09:49:           OS: Windows 7 Ultimate
16:09:49:      OS Arch: AMD64
16:09:49:         GPUs: 1
16:09:49:        GPU 0: ATI:4 Cayman PRO [AMD Radeon 6900 Series]
16:09:49:         CUDA: Not detected
16:09:49:Win32 Service: false
16:09:49:***********************************************************************
16:09:49:<config>
16:09:49:  <!-- Folding Slot Configuration -->
16:09:49:  <gpu v='true'/>
16:09:49:
16:09:49:  <!-- Network -->
16:09:49:  <proxy v=':8080'/>
16:09:49:
16:09:49:  <!-- Slot Control -->
16:09:49:  <pause-on-start v='true'/>
16:09:49:
16:09:49:  <!-- User Information -->
16:09:49:  <passkey v='********************************'/>
16:09:49:  <team v='182919'/>
16:09:49:  <user v='Kornflake'/>
16:09:49:
16:09:49:  <!-- Folding Slots -->
16:09:49:  <slot id='0' type='GPU'/>
16:09:49:  <slot id='1' type='SMP'>
16:09:49:    <cpus v='3'/>
16:09:49:  </slot>
16:09:49:</config>
16:09:49:Trying to access database...
16:09:49:Successfully acquired database lock
16:09:49:Enabled folding slot 00: PAUSED gpu:0:"Cayman PRO [AMD Radeon 6900 Series]"
16:09:49:Enabled folding slot 01: PAUSED smp:3
16:09:52:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
23:39:52:WU02:FS01:Starting
23:39:52:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 702 -lifeline 2188 -checkpoint 15 -np 3
23:39:52:WU02:FS01:Started FahCore on PID 2956
23:39:52:WU02:FS01:Core PID:5656
23:39:52:WU02:FS01:FahCore 0xa4 started
23:39:52:WU01:FS00:Starting
23:39:52:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 702 -lifeline 2188 -checkpoint 15 -gpu 0
23:39:52:WU01:FS00:Started FahCore on PID 4480
23:39:52:WU01:FS00:Core PID:6136
23:39:52:WU01:FS00:FahCore 0x16 started
23:39:53:WU02:FS01:0xa4:
23:39:53:WU02:FS01:0xa4:*------------------------------*
23:39:53:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
23:39:53:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:39:53:WU02:FS01:0xa4:Preparing to commence simulation
23:39:53:WU02:FS01:0xa4:- Looking at optimizations...
23:39:53:WU02:FS01:0xa4:- Files status OK
23:39:53:WU02:FS01:0xa4:- Expanded 643011 -> 1746356 (decompressed 271.5 percent)
23:39:53:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=643011 data_size=1746356, decompressed_data_size=1746356 diff=0
23:39:53:WU02:FS01:0xa4:- Digital signature verified
23:39:53:WU02:FS01:0xa4:Project: 8077 (Run 20, Clone 17, Gen 6)
23:39:53:WU02:FS01:0xa4:Assembly optimizations on if available.
23:39:53:WU02:FS01:0xa4:Entering M.D.
23:39:53:WU01:FS00:0x16:
23:39:53:WU01:FS00:0x16:*------------------------------*
23:39:53:WU01:FS00:0x16:Folding@Home GPU Core
23:39:53:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
23:39:53:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
23:39:53:WU01:FS00:0x16:Build host: user-f6d030f24f
23:39:53:WU01:FS00:0x16:Board Type: AMD/OpenCL
23:39:53:WU01:FS00:0x16:Core      : x=16
23:39:53:WU01:FS00:0x16: Window's signal control handler registered.
23:39:53:WU01:FS00:0x16:Preparing to commence simulation
23:39:53:WU01:FS00:0x16:- Looking at optimizations...
23:39:53:WU01:FS00:0x16:- Files status OK
23:39:53:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:39:53:WU01:FS00:0x16:- Expanded 44944 -> 171163 (decompressed 380.8 percent)
23:39:53:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=44944 data_size=171163, decompressed_data_size=171163 diff=0
23:39:53:WU01:FS00:0x16:- Digital signature verified
23:39:53:WU01:FS00:0x16:Project: 11293 (Run 29, Clone 186, Gen 42)
23:39:53:WU01:FS00:0x16:Assembly optimizations on if available.
23:39:53:WU01:FS00:0x16:Entering M.D.
23:39:55:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  105112227 1332888027 2270936023 2440698391 620152345
23:39:55:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
23:39:55:WU01:FS00:0x16:Client config unavailable.
23:39:55:WU01:FS00:0x16:Starting GUI Server
23:39:57:WU01:FS00:0x16:Setting checkpoint frequency: 500000
23:39:57:WU01:FS00:0x16:Completed         3 out of 50000000 steps (0%).
23:39:59:WU02:FS01:0xa4:Using Gromacs checkpoints
23:39:59:WU02:FS01:0xa4:Mapping NT from 3 to 3
23:39:59:WU02:FS01:0xa4:Resuming from checkpoint
23:39:59:WU02:FS01:0xa4:Verified 02/wudata_01.log
23:39:59:WU02:FS01:0xa4:Verified 02/wudata_01.trr
23:39:59:WU02:FS01:0xa4:Verified 02/wudata_01.xtc
23:39:59:WU02:FS01:0xa4:Verified 02/wudata_01.edr
23:39:59:WU02:FS01:0xa4:Completed 184240 out of 500000 steps  (36%)
02:12:26:WU02:FS01:0xa4:Completed 495000 out of 500000 steps  (99%)
02:12:27:WU00:FS01:Connecting to assign3.stanford.edu:8080
02:12:27:WU00:FS01:News: Welcome to Folding@Home
02:12:27:WU00:FS01:Assigned to work server 171.67.108.60
02:12:27:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:3 from 171.67.108.60
02:12:27:WU00:FS01:Connecting to 171.67.108.60:8080
02:12:28:WU00:FS01:Downloading 627.94KiB
02:12:30:WU00:FS01:Download complete
02:12:30:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8077 run:14 clone:3 gen:25 core:0xa4 unit:0x000000456652edcc5121ce9d428056db
******************************** Date: 15/03/13 ********************************
02:14:45:WU01:FS00:0x16:Completed  24000000 out of 50000000 steps (48%).
02:14:54:WU02:FS01:0xa4:Completed 500000 out of 500000 steps  (100%)
02:14:54:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:15:04:WU02:FS01:0xa4:
02:15:04:WU02:FS01:0xa4:Finished Work Unit:
02:15:04:WU02:FS01:0xa4:- Reading up to 869820 from "02/wudata_01.trr": Read 869820
02:15:04:WU02:FS01:0xa4:trr file hash check passed.
02:15:04:WU02:FS01:0xa4:- Reading up to 956432 from "02/wudata_01.xtc": Read 956432
02:15:04:WU02:FS01:0xa4:xtc file hash check passed.
02:15:04:WU02:FS01:0xa4:edr file hash check passed.
02:15:04:WU02:FS01:0xa4:logfile size: 28379
02:15:04:WU02:FS01:0xa4:Leaving Run
02:15:09:WU02:FS01:0xa4:- Writing 1867283 bytes of core data to disk...
02:15:09:WU02:FS01:0xa4:Done: 1866771 -> 1799810 (compressed to 96.4 percent)
02:15:09:WU02:FS01:0xa4:  ... Done.
02:15:09:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:15:09:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:8077 run:20 clone:17 gen:6 core:0xa4 unit:0x000000146652edcc5121cebfe65f2d53
02:15:09:WU02:FS01:Uploading 1.72MiB to 171.67.108.60
02:15:09:WU02:FS01:Connecting to 171.67.108.60:8080
02:15:10:WU00:FS01:Starting
02:15:10:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 702 -lifeline 2188 -checkpoint 15 -np 3
02:15:10:WU00:FS01:Started FahCore on PID 7004
02:15:10:WU00:FS01:Core PID:3876
02:15:10:WU00:FS01:FahCore 0xa4 started
02:15:10:WU00:FS01:0xa4:
02:15:10:WU00:FS01:0xa4:*------------------------------*
02:15:10:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
02:15:10:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
02:15:10:WU00:FS01:0xa4:Preparing to commence simulation
02:15:10:WU00:FS01:0xa4:- Looking at optimizations...
02:15:10:WU00:FS01:0xa4:- Created dyn
02:15:10:WU00:FS01:0xa4:- Files status OK
02:15:10:WU00:FS01:0xa4:- Expanded 642495 -> 1744484 (decompressed 271.5 percent)
02:15:10:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=642495 data_size=1744484, decompressed_data_size=1744484 diff=0
02:15:10:WU00:FS01:0xa4:- Digital signature verified
02:15:10:WU00:FS01:0xa4:Project: 8077 (Run 14, Clone 3, Gen 25)
02:15:10:WU00:FS01:0xa4:Assembly optimizations on if available.
02:15:10:WU00:FS01:0xa4:Entering M.D.
02:15:15:WU02:FS01:Upload 32.76%
02:15:16:WU00:FS01:0xa4:Mapping NT from 3 to 3
02:15:16:WU00:FS01:0xa4:Completed 0 out of 500000 steps  (0%)
02:15:16:WU00:FS01:0xa4:Gromacs cannot continue further.
02:15:16:WU00:FS01:0xa4:Going to send back what have done -- stepsTotalG=500000
02:15:16:WU00:FS01:0xa4:Work fraction=0.0000 steps=500000.
02:15:20:WU00:FS01:0xa4:logfile size=0 infoLength=0 edr=0 trr=23
02:15:20:WU00:FS01:0xa4:logfile size: 0 info=0 bed=0 hdr=23
02:15:20:WU00:FS01:0xa4:- Writing 638 bytes of core data to disk...
02:15:20:WU00:FS01:0xa4:Done: 126 -> 146 (compressed to 115.8 percent)
02:15:20:WU00:FS01:0xa4:  ... Done.
02:15:20:WU00:FS01:0xa4:Folding@home Core Shutdown: EARLY_UNIT_END
02:15:21:WU02:FS01:Upload 69.16%
02:15:21:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:15:21:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:8077 run:14 clone:3 gen:25 core:0xa4 unit:0x000000456652edcc5121ce9d428056db
02:15:21:WU00:FS01:Uploading 658B to 171.67.108.60
02:15:21:WU00:FS01:Connecting to 171.67.108.60:8080
02:15:21:WU03:FS01:Connecting to assign3.stanford.edu:8080
02:15:21:WU00:FS01:Upload complete
02:15:21:WU00:FS01:Server responded WORK_ACK (400)
02:15:21:WU00:FS01:Cleaning up
02:15:21:WU03:FS01:News: Welcome to Folding@Home
02:15:21:WU03:FS01:Assigned to work server 171.67.108.60
02:15:21:WU03:FS01:Requesting new work unit for slot 01: READY smp:3 from 171.67.108.60
02:15:21:WU03:FS01:Connecting to 171.67.108.60:8080
02:15:23:WU03:FS01:Downloading 84.92KiB
02:15:23:WU03:FS01:Download complete
02:15:23:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8076 run:208 clone:0 gen:16 core:0xa4 unit:0x000000346652edcc5121cd2ad12c2167
02:15:23:WU03:FS01:Starting
02:15:23:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 702 -lifeline 2188 -checkpoint 15 -np 3
02:15:23:WU03:FS01:Started FahCore on PID 2136
02:15:23:WU03:FS01:Core PID:5324
02:15:23:WU03:FS01:FahCore 0xa4 started
02:15:23:WU03:FS01:Downloading project 8076 description
02:15:23:WU03:FS01:Connecting to fah-web.stanford.edu:80
02:15:24:WU03:FS01:Project 8076 description downloaded successfully
02:15:24:WU03:FS01:0xa4:
02:15:24:WU03:FS01:0xa4:*------------------------------*
02:15:24:WU03:FS01:0xa4:Folding@Home Gromacs GB Core
02:15:24:WU03:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
02:15:24:WU03:FS01:0xa4:Preparing to commence simulation
02:15:24:WU03:FS01:0xa4:- Looking at optimizations...
02:15:24:WU03:FS01:0xa4:- Created dyn
02:15:24:WU03:FS01:0xa4:- Files status OK
02:15:24:WU03:FS01:0xa4:- Expanded 86442 -> 1748668 (decompressed 2022.9 percent)
02:15:24:WU03:FS01:0xa4:Called DecompressByteArray: compressed_data_size=86442 data_size=1748668, decompressed_data_size=1748668 diff=0
02:15:24:WU03:FS01:0xa4:- Digital signature verified
02:15:24:WU03:FS01:0xa4:Project: 8076 (Run 208, Clone 0, Gen 16)
02:15:24:WU03:FS01:0xa4:Assembly optimizations on if available.
02:15:24:WU03:FS01:0xa4:Entering M.D.
02:15:26:WU02:FS01:Upload complete
02:15:26:WU02:FS01:Server responded WORK_ACK (400)
02:15:26:WU02:FS01:Final credit estimate, 1112.00 points
02:15:26:WU02:FS01:Cleaning up
02:15:29:WU03:FS01:0xa4:Mapping NT from 3 to 3
02:15:29:WU03:FS01:0xa4:mdrun returned 255
02:15:29:WU03:FS01:0xa4:Going to send back what have done -- stepsTotalG=500000
02:15:29:WU03:FS01:0xa4:Work fraction=0.0000 steps=500000.
02:15:33:WU03:FS01:0xa4:logfile size=0 infoLength=0 edr=0 trr=25
02:15:33:WU03:FS01:0xa4:logfile size: 0 info=0 bed=0 hdr=25
02:15:33:WU03:FS01:0xa4:- Writing 640 bytes of core data to disk...
02:15:33:WU03:FS01:0xa4:Done: 128 -> 144 (compressed to 112.5 percent)
02:15:33:WU03:FS01:0xa4:  ... Done.
02:15:33:WU03:FS01:0xa4:Folding@home Core Shutdown: EARLY_UNIT_END
02:15:34:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:15:34:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:8076 run:208 clone:0 gen:16 core:0xa4 unit:0x000000346652edcc5121cd2ad12c2167
02:15:34:WU03:FS01:Uploading 656B to 171.67.108.60
02:15:34:WU03:FS01:Connecting to 171.67.108.60:8080
02:15:34:WU00:FS01:Connecting to assign3.stanford.edu:8080
02:15:34:WU03:FS01:Upload complete
02:15:34:WU03:FS01:Server responded WORK_ACK (400)
02:15:34:WU03:FS01:Cleaning up
Re: FAULTY project:8077 run:14 clone:3 gen:25 + Another
Thanks, Kornflake.
The WU (P8077,R14,C3,G25) has been reported as a bad WU.
Kornflake
Post by Kornflake »
Thanks Bruce, the part that has me confused, though, is I got a second one in the log above, see the final lines:
I have reported that second bad WU. Has your system gone on to processing WU's successfully since then? If so, could just be coincidence that you happened to get two bad ones in a row. Otherwise check for overheating, faulty RAM, etc.
The WU (P8076,R208,C0,G16) has been reported as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
Kornflake
Post by Kornflake »
Everything seems to be running okay on my computer. I must be lucky to get my first two bad WUs at the same time!
