Failed to get ID from ...
mlportersr
Post by mlportersr »
I just installed the client and can't get any work units. Just since midnight the following things have been logged:
08:18:17:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:18:38:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
08:18:38:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:18:57:WARNING:WU01:FS00:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 8 bytes, got 0
08:18:57:ERROR:WU01:FS00:Exception: Could not get an assignment ID
10:47:55:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:48:16:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
10:48:16:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:48:35:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 8 bytes, got 0
10:48:35:ERROR:WU00:FS01:Exception: Could not get an assignment ID
13:32:47:33:127.0.0.1:New Web connection
13:39:11:41:127.0.0.1:New Web connection
13:39:12:WARNING:47:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?sid: Session id= does not exist
13:39:12:ERROR:Exception in WebHandler: Session id= does not exist
13:39:41:WARNING:Exception: 46:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
The last few lines popped up when I opened up the Web Control page. I saw on another old thread to try connecting to assign3.stanford.edu:8080/ (I got OK from this one) and 171.67.108.59:8080/ (from this I got "Error 103 (net::ERR_CONNECTION_ABORTED): Unknown error.")
I am using the latest version of the client. Here's the section from the log describing my computer:
14:45:30:******************************* System ********************************
14:45:30:          CPU: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
14:45:30:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:45:30:         CPUs: 8
14:45:30:       Memory: 7.98GiB
14:45:30:  Free Memory: 5.72GiB
14:45:30:      Threads: WINDOWS_THREADS
14:45:30:  Has Battery: true
14:45:30:   On Battery: false
14:45:30:   UTC offset: -6
14:45:30:          PID: 7604
14:45:30:          CWD: C:/Users/mporter/AppData/Roaming/FAHClient
14:45:30:           OS: Windows 7 Professional
14:45:30:      OS Arch: AMD64
14:45:30:         GPUs: 1
14:45:30:        GPU 0: NVIDIA:2 GF106 [GeForce GTX 460M]
14:45:30:         CUDA: 2.1
14:45:30:  CUDA Driver: 3020
14:45:30:Win32 Service: false
14:45:30:***********************************************************************
The computer itself is a ASUS G73Sw Series notebook that is hardwired to the network. I also checked the Windows firewall and FAHClient is enabled for connecting to any port on any address.
Mike...
Re: Failed to get ID from ...
The "Received short response, expected 8 bytes, got 0" error messages indicate your connection is being blocked. Since it occurs on both port 80 and 8080, is this laptop connected to a network that uses a firewall or proxy server?
As for the troubleshooting of the connection you have tried so far, assign3.stanford.edu is an assignment server for SMP projects and 171.67.108.59 is the address of a server that is not currently active. What results do you get when trying to connect to assign-GPU.stanford.edu:80 and assign-GPU.stanford.edu:8080 in a browser?
Also, could you post the configuration information from your log that follows the System information that you posted already and the log entries that follow that. Is you laptop also configured with a CPU slot? If so include some of the log showing what happened when it connected to the servers to get an assignment.
mlportersr
I get OK from both the addresses you gave. Is this the information you mean? After this, the error messages start repeating,
14:45:30:<config>
14:45:30:  <!-- User Information -->
14:45:30:  <passkey v='********************************'/>
14:45:30:  <user v='Michael_L_Porter'/>
14:45:30:
14:45:30:  <!-- Folding Slots -->
14:45:30:  <slot id='0' type='GPU'/>
14:45:30:  <slot id='1' type='CPU'/>
14:45:30:</config>
14:45:30:Connecting to assign-GPU.stanford.edu:80
14:45:51:WARNING:Attempting to update GPUs.txt: Failed to read stream
14:45:51:Trying to access database...
14:45:52:Successfully acquired database lock
14:45:52:Enabled folding slot 00: PAUSED gpu:0:GF106 [GeForce GTX 460M] (waiting for idle)
14:45:52:Enabled folding slot 01: READY cpu:4
14:45:52:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
14:46:11:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
14:46:11:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
14:46:30:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 8 bytes, got 0
14:46:30:ERROR:WU00:FS01:Exception: Could not get an assignment ID
14:46:30:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
14:46:49:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
14:46:49:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
14:47:08:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 8 bytes, got 0
14:47:08:ERROR:WU00:FS01:Exception: Could not get an assignment ID
14:47:30:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
14:47:49:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
14:47:49:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
14:48:16:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 8 bytes, got 0
14:48:16:ERROR:WU00:FS01:Exception: Could not get an assignment ID
14:49:06:3:127.0.0.1:New Web connection
14:49:07:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
14:49:25:WARNING:Exception: 8:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
14:49:29:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
14:49:29:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
14:49:48:WARNING:WU00:FS01:Failed to get ID from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 8 bytes, got 0
14:49:48:ERROR:WU00:FS01:Exception: Could not get an assignment ID
14:49:55:12:127.0.0.1:New Web connection
14:50:06:WARNING:Exception: 17:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
14:50:17:Saving configuration to config.xml
14:50:17:<config>
14:50:17:  <!-- Folding Slot Configuration -->
14:50:17:  <power v='MEDIUM'/>
14:50:17:
14:50:17:  <!-- User Information -->
14:50:17:  <passkey v='********************************'/>
14:50:17:  <user v='Michael_L_Porter'/>
14:50:17:
14:50:17:  <!-- Folding Slots -->
14:50:17:  <slot id='0' type='GPU'/>
14:50:17:  <slot id='1' type='CPU'/>
14:50:17:</config>
14:51:45:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
14:51:54:Saving configuration to config.xml
14:51:54:<config>
Mike...
That your browser was able to connect to the two addresses means that you are not blocked on those two ports. The folding client uses the same type of connection as used by HTTP, there may be a security function on your PC that is blocking that since it is not coming from a browser. What software of this sort is running on your PC or the network you are attached to? Someone may recognize a known issue and be able to post on what settings need to adjusted to let the client download work.
mlportersr
I am running the standard windows 7 firewall and the client is allowed to connect to any address and any port. The only other thing is Avast antivirus, which doesn't appear to effect connectivity.
Mike...
There appears to also be a network issue on the Pande Group end at the moment. It looks like it started after the time in your log, but any changes made right now might not result in a successful download.
As for your connection, is this at home through an ISP, or at work or school?
