In a single box, how many GPU FahCores do you run? poll
In a single box, what is the maximum number of GPU *clients* do you fold with?
Poll ended at Tue Mar 19, 2013 7:37 pm
1
13
31%
2
21
50%
3
4
10%
4
4
10%
5
0
No votes
6
0
No votes
7+
0
No votes
Total votes: 42
rhavern
Post by rhavern »
So, the question popped up, in a single box, how many GPU clients do you fold with? The answer is interesting to the software and core developers. If you have more than one GPU box folding, go with your box that has the highest number of GPU clients or slots.
Note I'm asking about the number of FahCores, not GPUs. For example, if you have a GTX590, that currently requires two GPU clients/slots to fully utilize, so answer accordingly. I'm going to run the poll for two weeks.
Many thanks!
P.S. - If you genuinely are running 7+, please leave a comment quickly describing what you are running and how you keep such a beast cool! :shock:
Folding since 1 WU=1 point
kiore
Re: In a single box, how many GPU FahCores do you run? poll
Post by kiore »
I only run 2 of new NV GPU's GTX 570 and 680's I have just take up too much room, used to run 4 GTX 260's and 9800GT's a few years ago..
hootis
Hardware configuration: AMD Phenom II 955 @ 3.8 +ATi HD 5870
AMD Athlon II 610e @ 2.5 + 2x Nvidia 560Ti @ 1ghz
AMD Athlon II 605e @ 2.4 +Nvidia 550Ti + Nvidia GT 240
AMD Athlon II 620 @ 3.3ghz
Post by hootis »
I said 4 only because there was a time I tried to fit 4 cards in one mobo without overheating and wasn't successful, currently running only 3 simultaneously
Things yet to materialize.
DarkFoss
Hardware configuration: AMD 5800X3D Asus ROG Strix X570-E Gaming WiFi II bios 5043 G-Skill TridentZ Neo 3600mhz Asrock Tachi RX 7900XTX Corsair rm850x psu Asus PG32UQXR/Sony Bravia 3(2024) EK Elite 360 D-rgb aio Win 11pro/Kubuntu 2404.3 LTS Kernel 6.14.x HWE Generic UPS BX1500G
Post by DarkFoss »
I answered 1 for now, just upgraded from a 6950 to a 7970. Once the new cores come out I may add a second 7970 if the results are good.
rhavern
Post by rhavern »
hootis wrote:I said 4 only because there was a time I tried to fit 4 cards in one mobo without overheating and wasn't successful, currently running only 3 simultaneously
Was that four single-width, a combination of single and double or a really big mobo?
Biffa
Hardware configuration: RTX2080Ti
Threadripper 1950X
Post by Biffa »
Most I have run is 4 GTX470's in one box. I was going to run 4 GTX690's with a total of 8 cores but sold them due to not enough time to commit to the build.
But I have plans.. oh yes :)
thebluebumblebee
Post by thebluebumblebee »
I answered 2, but it is my desire to get a 3 or 4 PCI-e slot motherboard to reduce the electrical overhead of running multiple systems. Would most likely run it as an open system - no case.
hootis
Post by hootis »
it was 3 double and one single; 3 560ti and 640
jimerickson
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16)
Post by jimerickson »
tyan S7025AGM2NR will hold 4 double slot 480's with only minor modification.
