Cannot deliver WU
RMouse
Cannot deliver WU
Post by RMouse »
Any ideas how to get past this problem? Seems that there are several problems here.
15:07:23:WU00:FS00:Connecting to 171.67.108.11:8080
15:07:23:WU02:FS00:Started FahCore on PID 2620
15:07:23:WU02:FS00:Core PID:5144
15:07:23:WU02:FS00:FahCore 0x11 started
15:07:23:WU02:FS00:0x11:
15:07:23:WU02:FS00:0x11:*------------------------------*
15:07:23:WU02:FS00:0x11:Folding@Home GPU Core
15:07:23:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
15:07:23:WU02:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
15:07:23:WU02:FS00:0x11:Build host: amoeba
15:07:23:WU02:FS00:0x11:Board Type: Nvidia
15:07:23:WU02:FS00:0x11:Core      :
15:07:23:WU02:FS00:0x11:Preparing to commence simulation
15:07:23:WU02:FS00:0x11:- Looking at optimizations...
15:07:23:WU02:FS00:0x11:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
15:07:23:WU02:FS00:0x11:- Created dyn
15:07:23:WU02:FS00:0x11:- Files status OK
15:07:23:WU02:FS00:0x11:- Expanded 63043 -> 336763 (decompressed 534.1 percent)
15:07:23:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=63043 data_size=336763, decompressed_data_size=336763 diff=0
15:07:24:WU02:FS00:0x11:- Digital signature verified
15:07:24:WU02:FS00:0x11:Project: 10501 (Run 481, Clone 0, Gen 192)
15:07:24:WU02:FS00:0x11:Assembly optimizations on if available.
15:07:24:WU02:FS00:0x11:Entering M.D.
15:07:29:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr:  1650330257 3537884918 2745572320 4189392421 4201730613
15:07:29:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
15:07:30:WU02:FS00:0x11:Working on Protein
15:07:38:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:07:38:WU00:FS00:Connecting to 171.67.108.11:80
15:07:39:WU02:FS00:0x11:Client config unavailable.
15:07:40:WU02:FS00:0x11:Starting GUI Server
15:07:57:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:07:57:WU00:FS00:Trying to send results to collection server
15:07:57:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:07:57:WU00:FS00:Connecting to 171.67.108.25:8080
15:08:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:08:12:WU00:FS00:Connecting to 171.67.108.25:80
15:08:33:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:08:33:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
15:08:33:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
15:08:33:WU00:FS00:Connecting to 171.67.108.11:8080
15:08:38:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:08:38:WU00:FS00:Connecting to 171.67.108.11:80
15:08:52:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:08:52:WU00:FS00:Trying to send results to collection server
15:08:52:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:08:52:WU00:FS00:Connecting to 171.67.108.25:8080
15:08:56:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:08:56:WU00:FS00:Connecting to 171.67.108.25:80
15:08:58:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
15:09:33:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
15:09:33:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
15:09:33:WU00:FS00:Connecting to 171.67.108.11:8080
15:09:43:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:09:43:WU00:FS00:Connecting to 171.67.108.11:80
15:09:57:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:09:57:WU00:FS00:Trying to send results to collection server
15:09:57:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:09:57:WU00:FS00:Connecting to 171.67.108.25:8080
15:10:00:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:10:00:WU00:FS00:Connecting to 171.67.108.25:80
15:10:03:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
15:11:11:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
15:11:11:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
15:11:11:WU00:FS00:Connecting to 171.67.108.11:8080
15:11:25:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:11:25:WU00:FS00:Connecting to 171.67.108.11:80
15:11:33:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
15:11:33:WU00:FS00:Trying to send results to collection server
15:11:33:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:11:33:WU00:FS00:Connecting to 171.67.108.25:8080
15:11:35:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:11:35:WU00:FS00:Connecting to 171.67.108.25:80
15:11:49:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:13:48:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
15:13:48:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
15:13:48:WU00:FS00:Connecting to 171.67.108.11:8080
15:13:56:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:13:56:WU00:FS00:Connecting to 171.67.108.11:80
15:14:10:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:14:10:WU00:FS00:Trying to send results to collection server
15:14:10:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:14:10:WU00:FS00:Connecting to 171.67.108.25:8080
15:14:17:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:14:17:WU00:FS00:Connecting to 171.67.108.25:80
15:14:36:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:16:27:WU01:FS01:0xa4:Completed 112500 out of 750000 steps  (15%)
15:18:02:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
15:18:02:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
15:18:02:WU00:FS00:Connecting to 171.67.108.11:8080
15:18:21:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:18:21:WU00:FS00:Connecting to 171.67.108.11:80
15:18:31:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
15:18:31:WU00:FS00:Trying to send results to collection server
15:18:31:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:18:31:WU00:FS00:Connecting to 171.67.108.25:8080
15:18:35:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:18:35:WU00:FS00:Connecting to 171.67.108.25:80
15:18:40:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
15:24:54:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
15:24:54:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
15:24:54:WU00:FS00:Connecting to 171.67.108.11:8080
15:25:02:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:25:02:WU00:FS00:Connecting to 171.67.108.11:80
15:25:21:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:25:21:WU00:FS00:Trying to send results to collection server
15:25:21:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:25:21:WU00:FS00:Connecting to 171.67.108.25:8080
15:25:23:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:25:23:WU00:FS00:Connecting to 171.67.108.25:80
15:25:31:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
15:35:59:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
15:36:00:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
15:36:00:WU00:FS00:Connecting to 171.67.108.11:8080
15:36:03:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:36:03:WU00:FS00:Connecting to 171.67.108.11:80
15:36:07:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
15:36:07:WU00:FS00:Trying to send results to collection server
15:36:07:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:36:07:WU00:FS00:Connecting to 171.67.108.25:8080
15:36:17:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:36:17:WU00:FS00:Connecting to 171.67.108.25:80
15:36:31:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************** Date: 25/02/13 ********************************
15:46:54:WU01:FS01:0xa4:Completed 120000 out of 750000 steps  (16%)
15:53:56:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
15:53:56:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
15:53:56:WU00:FS00:Connecting to 171.67.108.11:8080
15:53:59:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:53:59:WU00:FS00:Connecting to 171.67.108.11:80
15:54:13:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:54:13:WU00:FS00:Trying to send results to collection server
15:54:13:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
15:54:13:WU00:FS00:Connecting to 171.67.108.25:8080
15:54:29:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:54:29:WU00:FS00:Connecting to 171.67.108.25:80
15:54:31:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
16:22:58:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
16:22:58:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
16:22:58:WU00:FS00:Connecting to 171.67.108.11:8080
16:23:14:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
16:23:14:WU00:FS00:Connecting to 171.67.108.11:80
16:23:19:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
16:23:19:WU00:FS00:Trying to send results to collection server
16:23:19:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
16:23:19:WU00:FS00:Connecting to 171.67.108.25:8080
16:23:38:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
16:23:38:WU00:FS00:Connecting to 171.67.108.25:80
16:23:41:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
16:24:54:WU01:FS01:0xa4:Completed 127500 out of 750000 steps  (17%)
16:44:34:WU02:FS00:0x11:Completed 1%
17:03:43:WU01:FS01:0xa4:Completed 135000 out of 750000 steps  (18%)
17:09:57:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
17:09:57:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
17:09:57:WU00:FS00:Connecting to 171.67.108.11:8080
17:10:07:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
17:10:07:WU00:FS00:Connecting to 171.67.108.11:80
17:10:09:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
17:10:09:WU00:FS00:Trying to send results to collection server
17:10:09:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
17:10:09:WU00:FS00:Connecting to 171.67.108.25:8080
17:10:14:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
17:10:14:WU00:FS00:Connecting to 171.67.108.25:80
17:10:19:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
17:34:47:WU01:FS01:0xa4:Completed 142500 out of 750000 steps  (19%)
18:12:04:WU01:FS01:0xa4:Completed 150000 out of 750000 steps  (20%)
18:22:37:WU02:FS00:0x11:Completed 2%
18:25:58:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:5768 run:12 clone:229 gen:2235 core:0x11 unit:0x703913865124aa0108bb00e5000c1688
18:25:58:WU00:FS00:Uploading 98.02KiB to 171.67.108.11
18:25:58:WU00:FS00:Connecting to 171.67.108.11:8080
18:26:18:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:26:18:WU00:FS00:Connecting to 171.67.108.11:80
18:26:20:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
18:26:20:WU00:FS00:Trying to send results to collection server
18:26:20:WU00:FS00:Uploading 98.02KiB to 171.67.108.25
18:26:20:WU00:FS00:Connecting to 171.67.108.25:8080
18:26:28:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:26:28:WU00:FS00:Connecting to 171.67.108.25:80
18:26:35:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
18:40:02:WU01:FS01:0xa4:Completed 157500 out of 750000 steps  (21%)
Re: Cannot deliver WU
Just a single problem, the VSP07 servers went down at the end of last week. 171.67.108.11 is back up, but is not accepting connections yet as it looks to need more work. When it does come back up fully, then your client can turn in the WU it is holding. 171.67.108.21 is up and sending and receiving WU's, that is why your GPU eventually got a new one to process. 171.67.108.25 is a CS that is offline and does not need to be reported. The main topic on the outage and the partial restoration so far is viewtopic.php?f=18&t=23759.
P.S. Dr. Pande just posted that 171.67.108.11 has also been brought back up.
RMouse
Post by RMouse »
Thank you. I was able to deliver the WU.
