128.143.231.201
markfw
128.143.231.201
Post by markfw »
Here is the tail of the log file.
\x1b[93m10:30:18:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out\x1b[0m
10:30:18:WU01:FS00:Trying to send results to collection server
10:30:18:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
10:30:18:WU01:FS00:Connecting to 128.143.199.97:8080
\x1b[93m10:31:21:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80\x1b[0m
10:31:21:WU01:FS00:Connecting to 128.143.199.97:80
\x1b[91m10:32:24:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out\x1b[0m
11:15:11:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
11:15:11:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
11:15:11:WU01:FS00:Connecting to 128.143.231.201:8080
11:15:17:WU01:FS00:Upload 9.24%
11:15:23:WU01:FS00:Upload 17.19%
11:15:29:WU01:FS00:Upload 29.23%
11:15:35:WU01:FS00:Upload 51.93%
11:15:41:WU01:FS00:Upload 74.00%
11:15:47:WU01:FS00:Upload 96.13%
11:15:59:WU01:FS00:Upload complete
11:15:59:WU01:FS00:Server responded WORK_ACK (400)
11:15:59:WU01:FS00:Final credit estimate, 210185.00 points
11:15:59:WU01:FS00:Cleaning up
******************************** Date: 20/02/13 ********************************
16:11:57:Server connection id=24 on 0.0.0.0:36330 from 127.0.0.1
16:11:57:Server connection id=1 ended
My bos has been idle for almost a day now. Whats up ?
Mod Edit: Changed Thread Title & Move Thread To Appropriate Forum - PantherX
markfw
Re: bigadv works for 2 months, then stopped today ?
Post by markfw »
OK, I rebooted, and now it has a new unit. After 2 months with no problems. This is a server hardware box, 24 cores, and no problems?? WTF
markfw
Post by markfw »
Something going on. new log file after reboot
*********************** Log Started 2013-02-21T03:09:20Z ***********************
03:09:20:************************* Folding@home Client *************************
03:09:20:    Website: http://folding.stanford.edu/
03:09:20:  Copyright: (c) 2009-2012 Stanford University
03:09:20:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:09:20:       Args: --child --lifeline 1003 /etc/fahclient/config.xml --run-as
03:09:20:             fahclient --pid-file=/var/run/fahclient.pid --daemon
03:09:20:     Config: /etc/fahclient/config.xml
03:09:20:******************************** Build ********************************
03:09:20:    Version: 7.2.9
03:09:20:       Date: Oct 3 2012
03:09:20:       Time: 10:34:06
03:09:20:    SVN Rev: 3578
03:09:20:     Branch: fah/trunk/client
03:09:20:   Compiler: GNU 4.4.7
03:09:20:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
03:09:20:             -fno-unsafe-math-optimizations -msse2
03:09:20:   Platform: linux2 3.2.0-1-amd64
03:09:20:       Bits: 64
03:09:20:       Mode: Release
03:09:20:******************************* System ********************************
03:09:20:        CPU: AMD Opteron(TM) Processor 6234
03:09:20:     CPU ID: AuthenticAMD Family 21 Model 1 Stepping 2
03:09:20:       CPUs: 24
03:09:20:     Memory: 31.36GiB
03:09:20:Free Memory: 30.66GiB
03:09:20:    Threads: POSIX_THREADS
03:09:20: On Battery: false
03:09:20: UTC offset: -8
03:09:20:        PID: 1025
03:09:20:        CWD: /var/lib/fahclient
03:09:20:         OS: Linux 3.2.0-35-generic x86_64
03:09:20:    OS Arch: AMD64
03:09:20:       GPUs: 0
03:09:20:       CUDA: Not detected
03:09:20:***********************************************************************
03:09:20:<config>
03:09:20:  <!-- Folding Slot Configuration -->
03:09:20:  <smp v='false'/>
03:09:20:
03:09:20:  <!-- Network -->
03:09:20:  <proxy v=':8080'/>
03:09:20:
03:09:20:  <!-- Remote Command Server -->
03:09:20:  <command-allow v='127.0.0.1,192.168.1.2-192.168.1.254'/>
03:09:20:  <command-allow-no-pass v='127.0.0.1,192.168.1.2-192.168.1.254'/>
03:09:20:
03:09:20:  <!-- User Information -->
03:09:20:  <passkey v='********************************'/>
03:09:20:  <team v='198'/>
03:09:20:  <user v='Mark_F_Williams'/>
03:09:20:
03:09:20:  <!-- Folding Slots -->
03:09:20:  <slot id='0' type='SMP'>
03:09:20:    <client-type v='bigadv'/>
03:09:20:    <cpus v='-1'/>
03:09:20:    <max-packet-size v='big'/>
03:09:20:    <next-unit-percentage v='100'/>
03:09:20:  </slot>
03:09:20:</config>
03:09:20:Switching to user fahclient
03:09:20:Trying to access database...
03:09:20:Successfully acquired database lock
03:09:20:Enabled folding slot 00: READY smp:24
03:09:20:WU00:FS00:Connecting to assign3.stanford.edu:8080
\x1b[93m03:09:20:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: No address associated with hostname\x1b[0m
03:09:20:WU00:FS00:Connecting to assign4.stanford.edu:80
\x1b[93m03:09:20:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: No address associated with hostname\x1b[0m
\x1b[91m03:09:20:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
03:09:21:WU00:FS00:Connecting to assign3.stanford.edu:8080
\x1b[93m03:09:21:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: No address associated with hostname\x1b[0m
03:09:21:WU00:FS00:Connecting to assign4.stanford.edu:80
\x1b[93m03:09:21:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: No address associated with hostname\x1b[0m
\x1b[91m03:09:21:ERROR:WU00:FS00:Exception: Could not get an assignment\x1b[0m
03:09:36:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
03:10:21:WU00:FS00:Connecting to assign3.stanford.edu:8080
03:10:21:WU00:FS00:News: Welcome to Folding@Home
03:10:21:WU00:FS00:Assigned to work server 128.143.231.201
03:10:21:WU00:FS00:Requesting new work unit for slot 00: READY smp:24 from 128.143.231.201
03:10:21:WU00:FS00:Connecting to 128.143.231.201:8080
03:10:27:WU00:FS00:Downloading 28.90MiB
03:10:33:WU00:FS00:Download 34.17%
03:10:39:WU00:FS00:Download 82.18%
03:10:41:WU00:FS00:Download complete
03:10:41:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8101 run:22 clone:2 gen:164 core:0xa5 unit:0x000000cf088988e14f999494af370e85
03:10:41:WU00:FS00:Starting
03:10:41:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a5.fah/FahCore_a5 -dir 00 -suffix 01 -version 702 -lifeline 1025 -checkpoint 15 -np 24
03:10:41:WU00:FS00:Started FahCore on PID 2101
03:10:41:WU00:FS00:Core PID:2105
03:10:41:WU00:FS00:FahCore 0xa5 started
03:10:41:WU00:FS00:Downloading project 8101 description
03:10:41:WU00:FS00:Connecting to fah-web.stanford.edu:80
03:10:41:WU00:FS00:Project 8101 description downloaded successfully
03:10:41:WU00:FS00:0xa5:
03:10:41:WU00:FS00:0xa5:*------------------------------*
03:10:41:WU00:FS00:0xa5:Folding@Home Gromacs SMP Core
03:10:41:WU00:FS00:0xa5:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
03:10:41:WU00:FS00:0xa5:Preparing to commence simulation
03:10:41:WU00:FS00:0xa5:- Looking at optimizations...
03:10:41:WU00:FS00:0xa5:- Created dyn
03:10:41:WU00:FS00:0xa5:- Files status OK
03:10:45:WU00:FS00:0xa5:- Expanded 30303557 -> 33158020 (decompressed 109.4 percent)
03:10:45:WU00:FS00:0xa5:Called DecompressByteArray: compressed_data_size=30303557 data_size=33158020, decompressed_data_size=33158020 diff=0
03:10:45:WU00:FS00:0xa5:- Digital signature verified
03:10:45:WU00:FS00:0xa5:Project: 8101 (Run 22, Clone 2, Gen 164)
03:10:45:WU00:FS00:0xa5:Assembly optimizations on if available.
03:10:45:WU00:FS00:0xa5:Entering M.D.
03:10:52:WU00:FS00:0xa5:Mapping NT from 24 to 24
03:10:57:WU00:FS00:0xa5:Completed 0 out of 250000 steps  (0%)
03:13:23:Server connection id=2 on 0.0.0.0:36330 from 192.168.1.2
Mod note: Please use code tags around your logs as have been added for you. They can be selected from the top of the Full Editor posting screen.
mmonnin
Post by mmonnin »
DNS issues in your area?
markfw
Post by markfw »
mmonnin wrote:DNS issues in your area?
I doubt it, all my other computers are working perfectly to all other sites, including my other 12 other clients, including 9 v6, and 3 on another v7 client.
Re: 128.143.231.201
You have provided too short of an extract of the log of the failed download to see where the problem occurred. All of the messages there were connected to the upload. First the attempt that failed to connect and upload, and then the successful upload.
As for the log for after the reboot, at least at the beginning you had DNS problems. The error messages were all about the failure to resolve the assign3 and assign4 names to IP addresses. The download retry a minute later did resolve.
PinHead
Hardware configuration: Quad Q9550 2.83 contains the GPU 57xx - running SMP and GPU
Re: 128.143.231.201
Post by PinHead »
How about your NIC, this doesn't look right: hostname\x1b[0m
markfw
Re: 128.143.231.201
Post by markfw »
PinHead wrote:How about your NIC, this doesn't look right: hostname\x1b[0m
No idea. It was working fine in firefox. Its a server motherboard, not overclocked obviously.
So all the other computers in the house (all overclocked) and one server motherboard that works find in firefox, and I can see the log file using HFM.net over the internal network. The only problem is the v7 client running bigadv units. Logic does not point to my OS or hardware.
Amaruk
Re: 128.143.231.201
Post by Amaruk »
For what it's worth, I was able to replicate the errors in the second
log snippet by removing a machine from the net and starting the client.
*********************** Log Started 2013-02-21T07:48:43Z ***********************
07:48:43:************************* Folding@home Client *************************
07:48:43:    Website: http://folding.stanford.edu/
07:48:43:  Copyright: (c) 2009-2012 Stanford University
07:48:43:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:48:43:       Args: --lifeline 2995 --command-port=36330
07:48:43:     Config: /home/maus/.FAHClient/config.xml
07:48:43:******************************** Build ********************************
07:48:43:    Version: 7.2.9
07:48:43:       Date: Oct 3 2012
07:48:43:       Time: 10:34:06
07:48:43:    SVN Rev: 3578
07:48:43:     Branch: fah/trunk/client
07:48:43:   Compiler: GNU 4.4.7
07:48:43:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
07:48:43:             -fno-unsafe-math-optimizations -msse2
07:48:43:   Platform: linux2 3.2.0-1-amd64
07:48:43:       Bits: 64
07:48:43:       Mode: Release
07:48:43:******************************* System ********************************
07:48:43:        CPU: Intel(R) Xeon(R) CPU E5645 @ 2.40GHz
07:48:43:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
07:48:43:       CPUs: 24
07:48:43:     Memory: 11.73GiB
07:48:43:Free Memory: 10.67GiB
07:48:43:    Threads: POSIX_THREADS
07:48:43: On Battery: false
07:48:43: UTC offset: -8
07:48:43:        PID: 3002
07:48:43:        CWD: /home/maus/.FAHClient
07:48:43:         OS: Linux 3.2.0-37-generic x86_64
07:48:43:    OS Arch: AMD64
07:48:43:       GPUs: 1
07:48:43:      GPU 0: NVIDIA:1 G92 [GeForce 8800 GT]
07:48:43:       CUDA: Not detected
07:48:43:***********************************************************************
07:48:43:<config>
07:48:43:  <!-- Folding Slot Configuration -->
07:48:43:  <max-packet-size v='big'/>
07:48:43:
07:48:43:  <!-- Network -->
07:48:43:  <proxy v=':8080'/>
07:48:43:
07:48:43:  <!-- Remote Command Server -->
07:48:43:  <command-allow v='127.0.0.1,192.168.3.41'/>
07:48:43:  <command-allow-no-pass v='127.0.0.1,192.168.3.41'/>
07:48:43:
07:48:43:  <!-- Slot Control -->
07:48:43:  <pause-on-start v='true'/>
07:48:43:
07:48:43:  <!-- User Information -->
07:48:43:  <passkey v='********************************'/>
07:48:43:  <team v='50625'/>
07:48:43:  <user v='Amaruk'/>
07:48:43:
07:48:43:  <!-- Folding Slots -->
07:48:43:  <slot id='0' type='SMP'>
07:48:43:    <client-type v='bigadv'/>
07:48:43:    <cpus v='-1'/>
07:48:43:    <next-unit-percentage v='100'/>
07:48:43:  </slot>
07:48:43:</config>
07:48:43:Trying to access database...
07:48:43:Successfully acquired database lock
07:48:43:Enabled folding slot 00: PAUSED smp:24
07:48:48:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
07:48:54:FS00:Unpaused
07:48:54:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m07:48:54:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: No address associated with hostname[0m
07:48:54:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m07:48:54:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: No address associated with hostname[0m
[91m07:48:54:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
07:49:54:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m07:49:54:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: No address associated with hostname[0m
07:49:54:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m07:49:54:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: No address associated with hostname[0m
[91m07:49:54:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
07:51:32:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m07:51:32:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: No address associated with hostname[0m
07:51:32:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m07:51:32:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: No address associated with hostname[0m
[91m07:51:32:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
07:53:14:Lost lifeline PID 2995, exiting
07:53:14:Server connection id=1 ended
07:53:15:Clean exit
However, I don't think that's your issue - I think it was likely FAHClient itself.
The first log snippet you posted shows the upload completing at 11:15:59,
after which the client did nothing for the next five hours. (16:11:57)
I seriously doubt that had anything to do with DNS/network issues.
What, if anything, happened between 16:11:57 and 03:09:20?
At what point did you stop/restart the client and/or reboot?
How much CPU was/is FAHClient using?
\x1b[0m is a formatting (end) code. That line is preceded by \x1b[93m, making
the text yellow. Other lines start with \x1b[91m which turns the text red.
Here is what the log I posted above looks like in terminal.
Re: 128.143.231.201
Amaruk -> Is this error reproducible on the latest public release, V7.3.6?
markfw
Re: 128.143.231.201
Post by markfw »
Since its always a pain to convert whatever time they show to PST, I am not sure what happened in the 2 time frames, but I work from home, my work PC's were fine, and all my clients (the other 12) were fine all machines and clients had no issues. All I can say is that a reboot fixed the problem. Why it was not crunching is what I am asking. This server has one purpose in life, FAH. No other use, no monitor active (on a KVM) most of the time. There is not even any software installed on this server except what comes with Ubuntu 12, and FAH.
Re: 128.143.231.201
If possible, please post more of the log where the client failed to download a new WU. Since no attempt to download was shown in your short extract, we are flying blind trying to figure out what may have happened. Showing the WU finishing up until it uploaded would be sufficient.
markfw
Re: 128.143.231.201
Post by markfw »
OK, bear with an ignorant Ubuntu user. If I right click on HFM.net from my XP64 main machine, I see the log file, but I think you want what would be fahlog_old.log or something like that. Where in the filesystem would this be in Ubuntu ?
Amaruk
Re: 128.143.231.201
Post by Amaruk »
markfw wrote:Where in the filesystem would this be in Ubuntu ?
Per your System Info
the files are at /var/lib/fahclient
To get there using 12.04's GUI:
Open your home folder
Click on the back button in the upper left corner
Click on the disc icon
Open the var folder
Open the lib folder
Open the fahclient folder
The old log files will be in the logs folder. The format is log-date-time.
A log showing the download, processing and (delayed) upload of
project:8101 run:22 clone:12 gen:60 Would likely be the most helpful.
This would be the same log the snippet in your OP came from.
~~edit~~
Visual aid.
http://imageshack.us/a/img21/7499/wheretheyat.png
markfw
Re: 128.143.231.201
Post by markfw »
I hope this is it
WU01:FS00:0xa5:Completed 240000 out of 250000 steps  (96%)
07:14:00:WU01:FS00:0xa5:Completed 242500 out of 250000 steps  (97%)
07:45:36:WU01:FS00:0xa5:Completed 245000 out of 250000 steps  (98%)
08:17:02:WU01:FS00:0xa5:Completed 247500 out of 250000 steps  (99%)
08:48:48:WU01:FS00:0xa5:Completed 250000 out of 250000 steps  (100%)
08:48:49:WU00:FS00:Connecting to assign3.stanford.edu:8080
08:48:49:WU00:FS00:News: Welcome to Folding@Home
08:48:49:WU00:FS00:Assigned to work server 128.143.231.201
08:48:49:WU00:FS00:Requesting new work unit for slot 00: RUNNING smp:24 from 128.143.231.201
08:48:49:WU00:FS00:Connecting to 128.143.231.201:8080
08:49:02:WU01:FS00:0xa5:DynamicWrapper: Finished Work Unit: sleep=10000
08:49:12:WU01:FS00:0xa5:
08:49:12:WU01:FS00:0xa5:Finished Work Unit:
08:49:13:WU01:FS00:0xa5:- Reading up to 64340496 from "01/wudata_01.trr": Read 64340496
08:49:13:WU01:FS00:0xa5:trr file hash check passed.
08:49:13:WU01:FS00:0xa5:- Reading up to 31557624 from "01/wudata_01.xtc": Read 31557624
08:49:13:WU01:FS00:0xa5:xtc file hash check passed.
08:49:13:WU01:FS00:0xa5:edr file hash check passed.
08:49:13:WU01:FS00:0xa5:logfile size: 194534
08:49:13:WU01:FS00:0xa5:Leaving Run
08:49:18:WU01:FS00:0xa5:- Writing 96253530 bytes of core data to disk...
08:49:44:WU01:FS00:0xa5:Done: 96253018 -> 91488927 (compressed to 5.8 percent)
08:49:44:WU01:FS00:0xa5:  ... Done.
08:49:52:WU01:FS00:0xa5:- Shutting down core
08:49:52:WU01:FS00:0xa5:Folding@home Core Shutdown: FINISHED_UNIT
[93m08:49:53:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:49:53:WU00:FS00:Connecting to 128.143.231.201:80
08:49:53:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:49:53:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
08:49:53:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
08:49:53:WU01:FS00:Connecting to 128.143.231.201:8080
[91m08:50:56:ERROR:WU00:FS00:Exception: Failed to connect to 128.143.231.201:80: Connection timed out[0m
08:50:56:WU00:FS00:Connecting to assign3.stanford.edu:8080
08:50:56:WU00:FS00:News: Welcome to Folding@Home
08:50:56:WU00:FS00:Assigned to work server 128.143.231.201
08:50:56:WU00:FS00:Requesting new work unit for slot 00: READY smp:24 from 128.143.231.201
08:50:56:WU00:FS00:Connecting to 128.143.231.201:8080
[93m08:50:57:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:50:57:WU01:FS00:Connecting to 128.143.231.201:80
[93m08:51:59:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:51:59:WU00:FS00:Connecting to 128.143.231.201:80
[93m08:52:00:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
08:52:00:WU01:FS00:Trying to send results to collection server
08:52:00:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
08:52:00:WU01:FS00:Connecting to 128.143.199.97:8080
[91m08:53:02:ERROR:WU00:FS00:Exception: Failed to connect to 128.143.231.201:80: Connection timed out[0m
08:53:03:WU00:FS00:Connecting to assign3.stanford.edu:8080
08:53:03:WU00:FS00:News: Welcome to Folding@Home
08:53:03:WU00:FS00:Assigned to work server 128.143.231.201
08:53:03:WU00:FS00:Requesting new work unit for slot 00: READY smp:24 from 128.143.231.201
08:53:03:WU00:FS00:Connecting to 128.143.231.201:8080
[93m08:53:03:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:53:03:WU01:FS00:Connecting to 128.143.199.97:80
[91m08:54:06:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
[93m08:54:06:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:54:06:WU00:FS00:Connecting to 128.143.231.201:80
08:54:06:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
08:54:06:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
08:54:06:WU01:FS00:Connecting to 128.143.231.201:8080
[91m08:55:09:ERROR:WU00:FS00:Exception: Failed to connect to 128.143.231.201:80: Connection timed out[0m
08:55:09:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m08:55:09:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:55:09:WU01:FS00:Connecting to 128.143.231.201:80
08:55:09:WU00:FS00:News: Welcome to Folding@Home
08:55:09:WU00:FS00:Assigned to work server 128.143.231.201
08:55:09:WU00:FS00:Requesting new work unit for slot 00: READY smp:24 from 128.143.231.201
08:55:09:WU00:FS00:Connecting to 128.143.231.201:8080
[93m08:56:12:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
08:56:12:WU01:FS00:Trying to send results to collection server
08:56:12:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
08:56:12:WU01:FS00:Connecting to 128.143.199.97:8080
[93m08:56:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:56:12:WU00:FS00:Connecting to 128.143.231.201:80
[93m08:57:15:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:57:15:WU01:FS00:Connecting to 128.143.199.97:80
[91m08:57:16:ERROR:WU00:FS00:Exception: Failed to connect to 128.143.231.201:80: Connection timed out[0m
08:57:46:WU00:FS00:Connecting to assign3.stanford.edu:8080
08:57:47:WU00:FS00:News: Welcome to Folding@Home
08:57:47:WU00:FS00:Assigned to work server 128.143.231.201
08:57:47:WU00:FS00:Requesting new work unit for slot 00: READY smp:24 from 128.143.231.201
08:57:47:WU00:FS00:Connecting to 128.143.231.201:8080
[91m08:58:19:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
08:58:19:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
08:58:19:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
08:58:19:WU01:FS00:Connecting to 128.143.231.201:8080
[93m08:58:50:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:58:50:WU00:FS00:Connecting to 128.143.231.201:80
[93m08:59:22:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
08:59:22:WU01:FS00:Connecting to 128.143.231.201:80
[91m08:59:53:ERROR:WU00:FS00:Exception: Failed to connect to 128.143.231.201:80: Connection timed out[0m
[93m09:00:25:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
09:00:25:WU01:FS00:Trying to send results to collection server
09:00:25:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
09:00:25:WU01:FS00:Connecting to 128.143.199.97:8080
[93m09:01:28:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:01:28:WU01:FS00:Connecting to 128.143.199.97:80
09:02:01:WU00:FS00:Connecting to assign3.stanford.edu:8080
09:02:01:WU00:FS00:News: Welcome to Folding@Home
09:02:01:WU00:FS00:Assigned to work server 128.143.231.201
09:02:01:WU00:FS00:Requesting new work unit for slot 00: READY smp:24 from 128.143.231.201
09:02:01:WU00:FS00:Connecting to 128.143.231.201:8080
[91m09:02:31:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
09:02:31:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
09:02:31:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
09:02:31:WU01:FS00:Connecting to 128.143.231.201:8080
[93m09:03:04:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:03:04:WU00:FS00:Connecting to 128.143.231.201:80
[93m09:03:34:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:03:34:WU01:FS00:Connecting to 128.143.231.201:80
09:03:47:WU00:FS00:Downloading 28.90MiB
[93m09:04:38:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
09:04:38:WU01:FS00:Trying to send results to collection server
09:04:38:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
09:04:38:WU01:FS00:Connecting to 128.143.199.97:8080
[93m09:05:41:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:05:41:WU01:FS00:Connecting to 128.143.199.97:80
[91m09:06:44:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
09:06:44:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
09:06:44:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
09:06:44:WU01:FS00:Connecting to 128.143.231.201:8080
[93m09:07:47:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:07:47:WU01:FS00:Connecting to 128.143.231.201:80
[93m09:08:50:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
09:08:50:WU01:FS00:Trying to send results to collection server
09:08:50:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
09:08:50:WU01:FS00:Connecting to 128.143.199.97:8080
[93m09:09:53:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:09:53:WU01:FS00:Connecting to 128.143.199.97:80
[91m09:10:56:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
09:10:58:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
09:10:58:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
09:10:58:WU01:FS00:Connecting to 128.143.231.201:8080
[93m09:12:01:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:12:01:WU01:FS00:Connecting to 128.143.231.201:80
[93m09:13:04:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
09:13:04:WU01:FS00:Trying to send results to collection server
09:13:04:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
09:13:04:WU01:FS00:Connecting to 128.143.199.97:8080
[93m09:14:08:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:14:08:WU01:FS00:Connecting to 128.143.199.97:80
09:30:07:WU01:FS00:Upload 0.07%
[91m09:30:07:ERROR:WU01:FS00:Exception: Transfer failed[0m
09:30:07:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
09:30:07:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
09:30:07:WU01:FS00:Connecting to 128.143.231.201:8080
[93m09:31:11:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:31:11:WU01:FS00:Connecting to 128.143.231.201:80
[93m09:32:14:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
09:32:14:WU01:FS00:Trying to send results to collection server
09:32:14:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
09:32:14:WU01:FS00:Connecting to 128.143.199.97:8080
[93m09:33:17:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:33:17:WU01:FS00:Connecting to 128.143.199.97:80
[91m09:34:20:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
09:41:13:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
09:41:13:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
09:41:13:WU01:FS00:Connecting to 128.143.231.201:8080
[93m09:42:16:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:42:16:WU01:FS00:Connecting to 128.143.231.201:80
[93m09:43:19:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
09:43:19:WU01:FS00:Trying to send results to collection server
09:43:19:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
09:43:19:WU01:FS00:Connecting to 128.143.199.97:8080
[93m09:44:22:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
09:44:22:WU01:FS00:Connecting to 128.143.199.97:80
[91m09:45:25:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
09:59:10:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
09:59:10:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
09:59:10:WU01:FS00:Connecting to 128.143.231.201:8080
[93m10:00:13:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
10:00:13:WU01:FS00:Connecting to 128.143.231.201:80
[93m10:01:16:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
10:01:16:WU01:FS00:Trying to send results to collection server
10:01:16:WU01:FS00:Uploading 87.25MiB to 128.143.199.97
10:01:16:WU01:FS00:Connecting to 128.143.199.97:8080
[93m10:02:19:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
10:02:19:WU01:FS00:Connecting to 128.143.199.97:80
[91m10:03:22:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
10:28:12:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8101 run:22 clone:12 gen:60 core:0xa5 unit:0x0000004a088988e14f9994cda5efb145
10:28:12:WU01:FS00:Uploading 87.25MiB to 128.143.231.201
10:28:12:WU01:FS00:Connecting to 128.143.231.201:8080
[93m10:29:15:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
10:29:15:WU01:FS00:Connecting to 128.143.231.201:80
[93m10:30:18:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.231.201:80: Connection timed out[0m
[93m10:31:21:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
[91m10:32:24:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.199.97:80: Connection timed out[0m
******************************** Date: 21/02/13 ********************************
[93m03:02:56:WARNING:Caught signal SIGINT(2) on PID 1036[0m
03:02:56:Exiting, please wait. . .
03:02:59:Server connection id=24 ended
