Can't get assignments since installing 7.3.6 on OS X
earthsaver
Post by earthsaver »
Folding@home 7.3.6 did a fine job completing the work unit that was in progress on my Mac running Mountain Lion after I installed it yesterday. However, it has been unable to get a new assignment from the assignment server. The log is reporting:
18:47:27:WU00:FS00:Connecting to assign3.stanford.edu:8080
18:47:27:WU00:FS00:News: Welcome to Folding@Home
18:47:27:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment
18:47:27:WU00:FS00:Connecting to assign4.stanford.edu:80
18:47:27:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment
18:47:27:ERROR:WU00:FS00:Exception: Could not get an assignment
Both of these servers (vsp10v-vz00 and vspg6-vz7) are reporting they are OK, however looking more closely at the server status list, it appears neither has WUs to give out. I hope more show up soon.
- Ben
M1 iMac
VijayPande
Pande Group Member
Re: Can't get assignments since installing 7.3.6 on OS X
Post by VijayPande »
THis message says that the AS doesn't have work for your client. Do you have any unusual restrictions (low memory, PPC processor, etc)?
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
schwancr
Pande Group Member
Post by schwancr »
Can you clarify what changed? It sounds like you upgraded to 7.3.6 and now could not get an assignment? Did anything else change?
Were you able to send back the work you had finished?
earthsaver
Nope, besides upgrading from 7.2.9 to 7.3.6, nothing else changed. I went back through the full log history for the last couple days. At 5:03 am this morning, my last unit reached 98% and the client tried to initiate a download of a new unit to begin upon completion. At 6:18 am, the unit was completed and successfully uploaded, and the server acknowledged the submission. However, the client was still unable to retrieve a new unit, as has continued to be the case throughout today.
The pande assignment servers are still reporting they have no units to dispense. However, are they not the assignment servers the client should be contacting? I just checked another client on which I upgraded FAH and it's processing happily, receiving units from vspg14b (171.64.65.104). How can I get the same love?
- Ben
M1 iMac
Please post your log file showing the beginning with the system information and configuration information and some of the download attempts. The log file can be located in:
Library --> Application Support --> FAHClient
That is the system-wide Library folder, not the one in your account directory.
earthsaver
Here's the section of interest. I also tried restoring a previous config file that identified my system type as SMP, which the client changed to CPU after I upgraded to 7.3.6.
*********************** Log Started 2013-02-19T18:11:24Z ***********************
18:11:24:************************* Folding@home Client *************************
18:11:24:    Website: http://folding.stanford.edu/
18:11:24:  Copyright: (c) 2009-2013 Stanford University
18:11:24:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:11:24:       Args:
18:11:24:     Config: /Library/Application Support/FAHClient/config.xml
18:11:24:******************************** Build ********************************
18:11:24:    Version: 7.3.6
18:11:24:       Date: Feb 18 2013
18:11:24:       Time: 15:24:11
18:11:24:    SVN Rev: 3923
18:11:24:     Branch: fah/trunk/client
18:11:24:   Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
18:11:24:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
18:11:24:             -fno-unsafe-math-optimizations -msse3 -arch x86_64
18:11:24:             -mmacosx-version-min=10.5 -isysroot /Developer/SDKs/MacOSX10.5.sdk
18:11:24:   Platform: darwin 10.8.0
18:11:24:       Bits: 64
18:11:24:       Mode: Release
18:11:24:******************************* System ********************************
18:11:24:        CPU: Intel(R) Core(TM)2 Duo CPU T9600 @ 2.80GHz
18:11:24:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
18:11:24:       CPUs: 2
18:11:24:     Memory: 8.00GiB
18:11:24:Free Memory: 112.23MiB
18:11:24:    Threads: POSIX_THREADS
18:11:24:Has Battery: true
18:11:24: On Battery: false
18:11:24: UTC offset: -8
18:11:24:        PID: 75667
18:11:24:        CWD: /Library/Application Support/FAHClient
18:11:24:         OS: Darwin 12.2.0 x86_64
18:11:24:    OS Arch: AMD64
18:11:24:       GPUs: 2
18:11:24:      GPU 0: NVIDIA:1 C79 [GeForce 9400M]
18:11:24:      GPU 1: NVIDIA:1 G96 [GeForce 9600M GT]
18:11:24:       CUDA: Not detected
18:11:24:***********************************************************************
18:11:24:<config>
18:11:24:  <!-- Network -->
18:11:24:  <proxy v=':8080'/>
18:11:24:
18:11:24:  <!-- User Information -->
18:11:24:  <passkey v='********************************'/>
18:11:24:  <team v='1971'/>
18:11:24:  <user v='Earthsaver'/>
18:11:24:
18:11:24:  <!-- Folding Slots -->
18:11:24:  <slot id='0' type='CPU'/>
18:11:24:</config>
18:11:24:Trying to access database...
18:11:24:Successfully acquired database lock
18:11:24:FS00:Set client configured
18:11:24:Enabled folding slot 00: READY cpu:1
18:11:24:WU00:FS00:Starting
[93m18:11:24:WARNING:WU00:FS00:Changed SMP threads from 2 to 1 this can cause some work units to fail[0m
18:11:24:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 00 -suffix 01 -version 703 -lifeline 75667 -checkpoint 15 -np 1
18:11:24:WU00:FS00:Started FahCore on PID 75785
18:11:26:WU00:FS00:Core PID:75789
18:11:26:WU00:FS00:FahCore 0xa4 started
18:11:26:WU00:FS00:0xa4:
18:11:26:WU00:FS00:0xa4:*------------------------------*
18:11:26:WU00:FS00:0xa4:Folding@Home Gromacs Core
18:11:26:WU00:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
18:11:26:WU00:FS00:0xa4:Preparing to commence simulation
18:11:26:WU00:FS00:0xa4:- Looking at optimizations...
18:11:26:WU00:FS00:0xa4:- Files status OK
18:11:26:WU00:FS00:0xa4:- Expanded 337563 -> 644556 (decompressed 190.9 percent)
18:11:26:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=337563 data_size=644556, decompressed_data_size=644556 diff=0
18:11:26:WU00:FS00:0xa4:- Digital signature verified
18:11:26:WU00:FS00:0xa4:Project: 7610 (Run 255, Clone 0, Gen 226)
18:11:26:WU00:FS00:0xa4:Assembly optimizations on if available.
18:11:26:WU00:FS00:0xa4:Entering M.D.
18:11:32:WU00:FS00:0xa4:Using Gromacs checkpoints
18:11:32:WU00:FS00:0xa4:Mapping NT from 1 to 1
18:11:32:WU00:FS00:0xa4:Resuming from checkpoint
18:11:32:WU00:FS00:0xa4:Verified 00/wudata_01.log
18:11:32:WU00:FS00:0xa4:Verified 00/wudata_01.trr
18:11:32:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
18:11:32:WU00:FS00:0xa4:Verified 00/wudata_01.edr
18:11:33:WU00:FS00:0xa4:Completed 1595230 out of 2000000 steps  (79%)
18:15:35:Caught signal SIGPIPE(13) on PID 75667
18:20:29:WU00:FS00:0xa4:Completed 1600000 out of 2000000 steps  (80%)
18:31:27:30:127.0.0.1:New Web connection
18:33:09:54:127.0.0.1:New Web connection
18:33:13:Caught signal SIGPIPE(13) on PID 75667
[93m18:33:13:WARNING:Exception: 40:127.0.0.1: Send error: 32: Broken pipe[0m
18:33:23:Caught signal SIGPIPE(13) on PID 75667
[93m18:33:23:WARNING:Exception: 47:127.0.0.1: Send error: 32: Broken pipe[0m
18:34:06:FS00:Shutting core down
18:34:07:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:34:07:WU00:FS00:Starting
[93m18:34:07:WARNING:WU00:FS00:Changed SMP threads from 1 to 2 this can cause some work units to fail[0m
18:34:07:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 00 -suffix 01 -version 703 -lifeline 75667 -checkpoint 15 -np 2
18:34:07:WU00:FS00:Started FahCore on PID 79340
18:34:07:WU00:FS00:Core PID:79341
18:34:07:WU00:FS00:FahCore 0xa4 started
18:34:08:WU00:FS00:0xa4:
18:34:08:WU00:FS00:0xa4:*------------------------------*
18:34:08:WU00:FS00:0xa4:Folding@Home Gromacs Core
18:34:08:WU00:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
18:34:08:WU00:FS00:0xa4:Preparing to commence simulation
18:34:08:WU00:FS00:0xa4:- Looking at optimizations...
18:34:08:WU00:FS00:0xa4:- Files status OK
18:34:08:WU00:FS00:0xa4:- Expanded 337563 -> 644556 (decompressed 190.9 percent)
18:34:08:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=337563 data_size=644556, decompressed_data_size=644556 diff=0
18:34:08:WU00:FS00:0xa4:- Digital signature verified
18:34:08:WU00:FS00:0xa4:Project: 7610 (Run 255, Clone 0, Gen 226)
18:34:08:WU00:FS00:0xa4:Assembly optimizations on if available.
18:34:08:WU00:FS00:0xa4:Entering M.D.
18:34:14:WU00:FS00:0xa4:Using Gromacs checkpoints
18:34:14:WU00:FS00:0xa4:Mapping NT from 2 to 2
18:34:14:WU00:FS00:0xa4:Resuming from checkpoint
18:34:14:WU00:FS00:0xa4:Verified 00/wudata_01.log
18:34:14:WU00:FS00:0xa4:Verified 00/wudata_01.trr
18:34:14:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
18:34:14:WU00:FS00:0xa4:Verified 00/wudata_01.edr
18:34:15:WU00:FS00:0xa4:Completed 1603130 out of 2000000 steps  (80%)
18:34:15:FS00:Shutting core down
18:34:19:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:35:30:Removing old file 'configs/config-20121101-161442.xml'
18:35:30:Saving configuration to config.xml
18:35:30:<config>
18:35:30:  <!-- Folding Slot Configuration -->
18:35:30:  <power v='off'/>
18:35:30:
18:35:30:  <!-- Network -->
18:35:30:  <proxy v=':8080'/>
18:35:30:
18:35:30:  <!-- User Information -->
18:35:30:  <passkey v='********************************'/>
18:35:30:  <team v='1971'/>
18:35:30:  <user v='Earthsaver'/>
18:35:30:
18:35:30:  <!-- Folding Slots -->
18:35:30:  <slot id='0' type='CPU'/>
18:35:30:</config>
18:35:56:WU00:FS00:Starting
[93m18:35:56:WARNING:WU00:FS00:Changed SMP threads from 2 to 1 this can cause some work units to fail[0m
18:35:56:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 00 -suffix 01 -version 703 -lifeline 75667 -checkpoint 15 -np 1
18:35:56:WU00:FS00:Started FahCore on PID 79608
18:35:56:WU00:FS00:Core PID:79609
18:35:56:WU00:FS00:FahCore 0xa4 started
18:35:57:WU00:FS00:0xa4:
18:35:57:WU00:FS00:0xa4:*------------------------------*
18:35:57:WU00:FS00:0xa4:Folding@Home Gromacs Core
18:35:57:WU00:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
18:35:57:WU00:FS00:0xa4:Preparing to commence simulation
18:35:57:WU00:FS00:0xa4:- Looking at optimizations...
18:35:57:WU00:FS00:0xa4:- Files status OK
18:35:57:WU00:FS00:0xa4:- Expanded 337563 -> 644556 (decompressed 190.9 percent)
18:35:57:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=337563 data_size=644556, decompressed_data_size=644556 diff=0
18:35:57:WU00:FS00:0xa4:- Digital signature verified
18:35:57:WU00:FS00:0xa4:Project: 7610 (Run 255, Clone 0, Gen 226)
18:35:57:WU00:FS00:0xa4:Assembly optimizations on if available.
18:35:57:WU00:FS00:0xa4:Entering M.D.
18:36:02:WU00:FS00:0xa4:Using Gromacs checkpoints
18:36:02:WU00:FS00:0xa4:Mapping NT from 1 to 1
18:36:02:WU00:FS00:0xa4:Resuming from checkpoint
18:36:02:WU00:FS00:0xa4:Verified 00/wudata_01.log
18:36:02:WU00:FS00:0xa4:Verified 00/wudata_01.trr
18:36:02:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
18:36:02:WU00:FS00:0xa4:Verified 00/wudata_01.edr
18:36:03:WU00:FS00:0xa4:Completed 1603130 out of 2000000 steps  (80%)
18:36:58:Removing old file 'configs/config-20121101-161508.xml'
18:36:58:Saving configuration to config.xml
18:36:58:<config>
18:36:58:  <!-- Network -->
18:36:58:  <proxy v=':8080'/>
18:36:58:
18:36:58:  <!-- User Information -->
18:36:58:  <passkey v='********************************'/>
18:36:58:  <team v='1971'/>
18:36:58:  <user v='Earthsaver'/>
18:36:58:
18:36:58:  <!-- Folding Slots -->
18:36:58:  <slot id='0' type='CPU'/>
18:36:58:</config>
18:39:41:88:127.0.0.1:New Web connection
[93m18:39:43:WARNING:Exception: 49:127.0.0.1: Send error: 32: Broken pipe[0m
18:39:43:Caught signal SIGPIPE(13) on PID 75667
18:40:41:99:127.0.0.1:New Web connection
19:10:32:WU00:FS00:0xa4:Completed 1620000 out of 2000000 steps  (81%)
19:44:02:WU00:FS00:0xa4:Completed 1640000 out of 2000000 steps  (82%)
20:18:13:WU00:FS00:0xa4:Completed 1660000 out of 2000000 steps  (83%)
20:52:04:WU00:FS00:0xa4:Completed 1680000 out of 2000000 steps  (84%)
21:25:57:WU00:FS00:0xa4:Completed 1700000 out of 2000000 steps  (85%)
21:59:15:WU00:FS00:0xa4:Completed 1720000 out of 2000000 steps  (86%)
22:33:03:WU00:FS00:0xa4:Completed 1740000 out of 2000000 steps  (87%)
23:06:56:WU00:FS00:0xa4:Completed 1760000 out of 2000000 steps  (88%)
23:40:36:WU00:FS00:0xa4:Completed 1780000 out of 2000000 steps  (89%)
23:55:09:457:127.0.0.1:New Web connection
[93m23:55:22:WARNING:Exception: 461:127.0.0.1: Send error: 32: Broken pipe[0m
23:55:22:Caught signal SIGPIPE(13) on PID 75667
[93m23:55:29:WARNING:Exception: 462:127.0.0.1: Send error: 32: Broken pipe[0m
23:55:29:Caught signal SIGPIPE(13) on PID 75667
23:55:56:466:127.0.0.1:New Web connection
[93m23:56:27:WARNING:Exception: 471:127.0.0.1: Send error: 32: Broken pipe[0m
23:56:27:Caught signal SIGPIPE(13) on PID 75667
23:57:00:Removing old file 'configs/config-20121101-161531.xml'
23:57:00:Saving configuration to config.xml
23:57:00:<config>
23:57:00:  <!-- Folding Slot Configuration -->
23:57:00:  <power v='medium'/>
23:57:00:
23:57:00:  <!-- Network -->
23:57:00:  <proxy v=':8080'/>
23:57:00:
23:57:00:  <!-- User Information -->
23:57:00:  <passkey v='********************************'/>
23:57:00:  <team v='1971'/>
23:57:00:  <user v='Earthsaver'/>
23:57:00:
23:57:00:  <!-- Folding Slots -->
23:57:00:  <slot id='0' type='CPU'/>
23:57:00:</config>
******************************* Date: 2013-02-20 *******************************
00:15:37:WU00:FS00:0xa4:Completed 1800000 out of 2000000 steps  (90%)
00:49:01:WU00:FS00:0xa4:Completed 1820000 out of 2000000 steps  (91%)
01:23:31:WU00:FS00:0xa4:Completed 1840000 out of 2000000 steps  (92%)
01:56:37:WU00:FS00:0xa4:Completed 1860000 out of 2000000 steps  (93%)
[93m02:31:59:WARNING:Exception: 626:127.0.0.1: Send error: 32: Broken pipe[0m
02:31:59:Caught signal SIGPIPE(13) on PID 75667
02:32:17:WU00:FS00:0xa4:Completed 1880000 out of 2000000 steps  (94%)
03:13:01:WU00:FS00:0xa4:Completed 1900000 out of 2000000 steps  (95%)
03:50:25:WU00:FS00:0xa4:Completed 1920000 out of 2000000 steps  (96%)
04:26:54:WU00:FS00:0xa4:Completed 1940000 out of 2000000 steps  (97%)
05:03:43:WU00:FS00:0xa4:Completed 1960000 out of 2000000 steps  (98%)
05:03:44:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:03:45:WU01:FS00:News: Welcome to Folding@Home
[93m05:03:45:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:03:45:WU01:FS00:Connecting to assign4.stanford.edu:80
[93m05:03:45:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:03:45:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
05:03:46:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:03:46:WU01:FS00:News: Welcome to Folding@Home
[93m05:03:46:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:03:46:WU01:FS00:Connecting to assign4.stanford.edu:80
[93m05:03:46:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:03:46:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
05:04:46:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:04:47:WU01:FS00:News: Welcome to Folding@Home
[93m05:04:47:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:04:47:WU01:FS00:Connecting to assign4.stanford.edu:80
[93m05:04:47:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:04:47:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
05:06:23:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:06:23:WU01:FS00:News: Welcome to Folding@Home
[93m05:06:23:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:06:23:WU01:FS00:Connecting to assign4.stanford.edu:80
05:06:24:WU01:FS00:News: Welcome to Folding@Home
[93m05:06:24:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:06:24:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
05:09:00:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:09:01:WU01:FS00:News: Welcome to Folding@Home
[93m05:09:01:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:09:01:WU01:FS00:Connecting to assign4.stanford.edu:80
[93m05:09:01:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:09:01:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
05:13:14:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:13:15:WU01:FS00:News: Welcome to Folding@Home
[93m05:13:15:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:13:15:WU01:FS00:Connecting to assign4.stanford.edu:80
[93m05:13:15:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:13:15:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
05:20:06:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:20:06:WU01:FS00:News: Welcome to Folding@Home
[93m05:20:06:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:20:06:WU01:FS00:Connecting to assign4.stanford.edu:80
[93m05:20:06:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:20:06:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
05:31:11:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:31:12:WU01:FS00:News: Welcome to Folding@Home
[93m05:31:12:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:31:12:WU01:FS00:Connecting to assign4.stanford.edu:80
[93m05:31:12:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:31:12:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
05:42:47:WU00:FS00:0xa4:Completed 1980000 out of 2000000 steps  (99%)
05:49:08:WU01:FS00:Connecting to assign3.stanford.edu:8080
05:49:08:WU01:FS00:News: Welcome to Folding@Home
[93m05:49:08:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
05:49:08:WU01:FS00:Connecting to assign4.stanford.edu:80
05:49:09:WU01:FS00:News: Welcome to Folding@Home
[93m05:49:09:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m05:49:09:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
06:18:10:WU01:FS00:Connecting to assign3.stanford.edu:8080
06:18:11:WU01:FS00:News: Welcome to Folding@Home
[93m06:18:11:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
06:18:11:WU01:FS00:Connecting to assign4.stanford.edu:80
06:18:12:WU01:FS00:News: Welcome to Folding@Home
[93m06:18:12:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m06:18:12:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
06:18:50:WU00:FS00:0xa4:Completed 2000000 out of 2000000 steps  (100%)
06:18:52:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
06:19:02:WU00:FS00:0xa4:
06:19:02:WU00:FS00:0xa4:Finished Work Unit:
06:19:02:WU00:FS00:0xa4:- Reading up to 488544 from "00/wudata_01.trr": Read 488544
06:19:02:WU00:FS00:0xa4:trr file hash check passed.
06:19:02:WU00:FS00:0xa4:- Reading up to 58168 from "00/wudata_01.xtc": Read 58168
06:19:02:WU00:FS00:0xa4:xtc file hash check passed.
06:19:02:WU00:FS00:0xa4:edr file hash check passed.
06:19:02:WU00:FS00:0xa4:logfile size: 47520
06:19:02:WU00:FS00:0xa4:Leaving Run
06:19:03:WU00:FS00:0xa4:- Writing 618148 bytes of core data to disk...
06:19:03:WU00:FS00:0xa4:Done: 617636 -> 546487 (compressed to 88.4 percent)
06:19:03:WU00:FS00:0xa4:  ... Done.
06:19:05:WU00:FS00:0xa4:- Shutting down core
06:19:05:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
06:19:06:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:19:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:7610 run:255 clone:0 gen:226 core:0xa4 unit:0x00000126664f2dd04de6d393a376724b
06:19:06:WU00:FS00:Uploading 534.18KiB to 171.64.65.104
06:19:06:WU00:FS00:Connecting to 171.64.65.104:8080
06:19:12:WU00:FS00:Upload 95.85%
06:19:15:WU00:FS00:Upload complete
06:19:15:WU00:FS00:Server responded WORK_ACK (400)
06:19:15:WU00:FS00:Final credit estimate, 2179.00 points
06:19:15:WU00:FS00:Cleaning up
07:05:09:WU01:FS00:Connecting to assign3.stanford.edu:8080
07:05:10:WU01:FS00:News: Welcome to Folding@Home
[93m07:05:10:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
07:05:10:WU01:FS00:Connecting to assign4.stanford.edu:80
07:05:11:WU01:FS00:News: Welcome to Folding@Home
[93m07:05:11:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m07:05:11:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
08:21:10:WU01:FS00:Connecting to assign3.stanford.edu:8080
08:21:12:WU01:FS00:News: Welcome to Folding@Home
[93m08:21:12:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
08:21:12:WU01:FS00:Connecting to assign4.stanford.edu:80
08:21:14:WU01:FS00:News: Welcome to Folding@Home
[93m08:21:14:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m08:21:14:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
08:37:13:1010:127.0.0.1:New Web connection
10:24:10:WU01:FS00:Connecting to assign3.stanford.edu:8080
10:24:11:WU01:FS00:News: Welcome to Folding@Home
[93m10:24:11:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
10:24:11:WU01:FS00:Connecting to assign4.stanford.edu:80
[93m10:24:11:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m10:24:11:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
13:43:10:WU01:FS00:Connecting to assign3.stanford.edu:8080
13:43:10:WU01:FS00:News: Welcome to Folding@Home
[93m13:43:10:WARNING:WU01:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment[0m
13:43:10:WU01:FS00:Connecting to assign4.stanford.edu:80
13:43:11:WU01:FS00:News: Welcome to Folding@Home
[93m13:43:11:WARNING:WU01:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment[0m
[91m13:43:11:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
15:10:46:1416:127.0.0.1:New Web connection
- Ben
M1 iMac
earthsaver wrote:...the client tried to initiate a download of a new unit to begin upon completion. At 6:18 am, the unit was completed and successfully uploaded, and the server acknowledged the submission. However, the client was still unable to retrieve a new unit, as has continued to be the case throughout today.
The Assignment Servers do not dispense work units. They tell your client where to find a Work Server which has units to dispense. It's a lot easier to explain when we can see the log.
Can you explain how the client or the system that doesn't work is different than the system that does work?
earthsaver
The one that works is currently located in northwest Connecticut. It's a Mac Pro running OS X 10.7.5. The that doesn't is a MacBook Pro in Berkeley running OS X 10.8.2. What other details would help you troubleshoot? What would prevent an AS from telling my client from which WS to request a unit?
- Ben
M1 iMac
I'd guess that you opened the web client in the browser twice and then closed it causing the broken pipes. What happened in those first two minutes? It does look like the Client recognized that it was connecting to your browser.
Does 10.8.2 have tighter browser security than 10.7.5?
earthsaver
I don't think so, but why would that matter? I was using 7.2.9 on 10.8.2 on my MacBook Pro just yesterday, and a few days ago when my last work unit was downloaded.
- Ben
M1 iMac
earthsaver
The first time I tried opening the client in my browser, it crashed my browser. My main browser is OmniWeb, which is more fully featured but has its share of incompatibilities. It hasn't crashed since, but I've been opening the client in a different browser, too. Also, the browser interface isn't much use to me; I prefer to use FAHControl.
- Ben
M1 iMac
I would try moving the control back to Full in the Web Control or FAHControl, setting it at Medium has the client trying to get WU's set for a uniprocessor. I don't know how many are currently available for OS X. See the writeup on what the different Performance Levels translate to. As for the slot now being listed as CPU, that is a change in 7.3. Instead of separate slots for Uniprocessor and SMP, the CPU slot can be set to handle a single core or multi-core setup.
earthsaver
Setting to Full was the simple solution. Is the preferred method now to reduce CPU time instead of folding power?
- Ben
M1 iMac
earthsaver wrote:Setting to Full was the simple solution. Is the preferred method now to reduce CPU time instead of folding power?
Reducing the CPU power only worked for the Uniprocessor FahCore. If you have overheating problems or prefer to run at less than 100% of the CPUs, reducing the CPU count is the preferred method. For the novice, some assumptions had to be made. For the expert, if you want to run at 100% CPU, that's up to you.
The screensaver can avoid any potential screen-lag issues by only running your GPU when your computer is idle. (Ditto if you use your GPU for games.) If you choose not to run the FAH screensaver, the GPU slot should still start up when the mouse and keyboard are idle for a while. (I have not tested that, myself.) Again, the expert can choose.
