Keycode for SMP is qualifier?
Qinsp
Post by Qinsp »
Greetings,
I'm using the same keycode for all machines.
When I start a new username for a new machine (I segregate machines that I'm concerned about) and use the same keycode, it is automatically "qualified", or must it fold 10 WU's before getting bonus? Need to know so I can monitor initial performance.
Thanks
Quality Inspection - Corona, CA, USA
Dimensional Inspection Laboratory
Pat McSwain, President
bollix47
Re: Keycode for SMP is qualifier?
Post by bollix47 »
It is the combination of username and passkey that needs to be qualified. i.e. If you change either then you must meet the qualification criteria for the new combination before receiving the QRB.
Once a passkey is qualified for the QRB, all WU's from all systems it is used on should get the bonus. However if you use the passkey with different usernames, each combination of username and passkey will need to meet the qualifications before QRB points will be awarded.
Qinsp
Post by Qinsp »
Thanks!
