BigAdv Problem.
Qinsp
BigAdv Problem.
Post by Qinsp »
I have no idea how you get bigadv to run on 7.2.9 under Linux.
I hit the FINISH button and let it complete the SMP job. When it sent the job back then I went to switch over.
I went into the Expert>Clientside>Add>client-type>bigadv>save
It pretty much just put the computer on hold. No more log entries.
It listed two slots on the bottom window of STATUS (Finishing+Ready). But only listed one slot FINISHING on the top completed SMP slot that had already sent it's job home according to the log.
I then QUIT>launch FAH, but nothing changed. Still in a holding pattern. No CPU activity.
What am I doing wrong? User McSwain team 195247. I just reset everything and started folding SMP16 again.
Quality Inspection - Corona, CA, USA
Dimensional Inspection Laboratory
Pat McSwain, President
Re: BigAdv Problem.
As with troubleshooting all problems, it helps to post the system specs and a sample of the problem from the log.
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Re: BigAdv Problem.
Post by artoar_11 »
Expert ->Configure ->Slots ->SMP ->Edit ->Add; client-type/bigadv ->OK ->OK ->Save
P5-133XL
Machine #2:
Machine 3:
Re: BigAdv Problem.
Post by P5-133XL »
Remove the expert option that you added earlier (client-size = bigadv) since you really don't want that applied to all slots. What you want is to supply that option to only the SMP slot. You also need to set max-packet-size to big to the SMP slot
Expert ->Configure ->Slots ->SMP ->Edit ->Add; name=client-type; value=bigadv ->OK->Add; name=Max-packet-size; value=big ->OK ->OK ->Save
