Project: 7809 (Run 2, Clone 36, Gen 40)
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Hello,
Was out of town for a couple of days, came back and see my old machine finished the Project: 7809 (Run 2, Clone 36, Gen 40) successfully.
Am checking to see if the 4543.00 points for the job were ever credited. From checking Extreme OverClocking, the last credit I received was on Feb 1st (CST) for 4,998 points. Were the 4543 points raised a few hundred more? Last time I checked, this job was running into early on Feb 2nd. At least my total points per the Extreme O/C, your site still match. The highlighted code below is near the bottom of the below log files.
07:46:37:WU01:FS00:Final credit estimate, 4543.00 points
Thanks,
Robby - Team Firefox
*********************** Log Started 2013-01-29T01:48:30Z ***********************
01:48:30:************************* Folding@home Client *************************
01:48:30:      Website: http://folding.stanford.edu/
01:48:30:    Copyright: (c) 2009-2012 Stanford University
01:48:30:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:48:30:         Args: --lifeline 6880 --command-port=36330
01:48:30:       Config: C:/Documents and Settings/Robby/Application
01:48:30:               Data/FAHClient/config.xml
01:48:30:******************************** Build ********************************
01:48:30:      Version: 7.2.9
01:48:30:         Date: Oct 3 2012
01:48:30:         Time: 18:05:48
01:48:30:      SVN Rev: 3578
01:48:30:       Branch: fah/trunk/client
01:48:30:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:48:30:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:48:30:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:48:30:     Platform: win32 XP
01:48:30:         Bits: 32
01:48:30:         Mode: Release
01:48:30:******************************* System ********************************
01:48:30:          CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
01:48:30:       CPU ID: AuthenticAMD Family 15 Model 75 Stepping 2
01:48:30:         CPUs: 2
01:48:30:       Memory: 3.00GiB
01:48:30:  Free Memory: 1.73GiB
01:48:30:      Threads: WINDOWS_THREADS
01:48:30:   On Battery: false
01:48:30:   UTC offset: -6
01:48:30:          PID: 7456
01:48:30:          CWD: C:/Documents and Settings/Robby/Application Data/FAHClient
01:48:30:           OS: Microsoft Windows XP Service Pack 3
01:48:30:      OS Arch: X86
01:48:30:         GPUs: 1
01:48:30:        GPU 0: UNSUPPORTED: RV730 PRO [Radeon HD 4650]
01:48:30:         CUDA: Not detected
01:48:30:Win32 Service: false
01:48:30:***********************************************************************
01:48:30:<config>
01:48:30:  <!-- Folding Slot Configuration -->
01:48:30:  <gpu v='true'/>
01:48:30:
01:48:30:  <!-- User Information -->
01:48:30:  <passkey v='********************************'/>
01:48:30:  <team v='39299'/>
01:48:30:  <user v='Robby'/>
01:48:30:
01:48:30:  <!-- Folding Slots -->
01:48:30:</config>
01:48:30:Trying to access database...
01:48:34:Successfully acquired database lock
01:48:35:Enabled folding slot 00: READY smp:2
01:48:35:WU01:FS00:Starting
01:48:35:WU01:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/Robby/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 702 -lifeline 7456 -checkpoint 15 -np 2
01:48:38:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
01:48:39:WU01:FS00:Started FahCore on PID 1204
01:48:48:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
01:48:52:WU01:FS00:Core PID:2716
01:48:52:WU01:FS00:FahCore 0xa4 started
01:48:53:WU01:FS00:0xa4:
01:48:53:WU01:FS00:0xa4:*------------------------------*
01:48:53:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
01:48:53:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:48:53:WU01:FS00:0xa4:Preparing to commence simulation
01:48:53:WU01:FS00:0xa4:- Looking at optimizations...
01:48:53:WU01:FS00:0xa4:- Files status OK
01:48:53:Server connection id=1 ended
01:48:54:WU01:FS00:0xa4:- Expanded 2079243 -> 5386224 (decompressed 259.0 percent)
01:48:54:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=2079243 data_size=5386224, decompressed_data_size=5386224 diff=0
01:48:54:WU01:FS00:0xa4:- Digital signature verified
01:48:54:WU01:FS00:0xa4:Project: 7809 (Run 2, Clone 36, Gen 40)
01:48:56:WU01:FS00:0xa4:Assembly optimizations on if available.
01:48:56:WU01:FS00:0xa4:Entering M.D.
01:49:02:WU01:FS00:0xa4:Using Gromacs checkpoints
01:49:03:WU01:FS00:0xa4:Mapping NT from 2 to 2
01:49:04:WU01:FS00:0xa4:Resuming from checkpoint
01:49:04:WU01:FS00:0xa4:Verified 01/wudata_01.log
01:49:06:WU01:FS00:0xa4:Verified 01/wudata_01.trr
01:49:06:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
01:49:06:WU01:FS00:0xa4:Verified 01/wudata_01.edr
01:49:06:WU01:FS00:0xa4:Completed 418300 out of 1500000 steps  (27%)
02:01:19:WU01:FS00:0xa4:Completed 420000 out of 1500000 steps  (28%)
03:10:05:WU01:FS00:0xa4:Completed 435000 out of 1500000 steps  (29%)
04:16:59:WU01:FS00:0xa4:Completed 450000 out of 1500000 steps  (30%)
05:26:51:WU01:FS00:0xa4:Completed 465000 out of 1500000 steps  (31%)
06:32:47:WU01:FS00:0xa4:Completed 480000 out of 1500000 steps  (32%)
******************************** Date: 01/02/13 ********************************
00:59:51:WU01:FS00:0xa4:Completed 1410000 out of 1500000 steps  (94%)
02:02:42:WU01:FS00:0xa4:Completed 1425000 out of 1500000 steps  (95%)
03:07:35:WU01:FS00:0xa4:Completed 1440000 out of 1500000 steps  (96%)
04:13:16:WU01:FS00:0xa4:Completed 1455000 out of 1500000 steps  (97%)
05:34:31:WU01:FS00:0xa4:Completed 1470000 out of 1500000 steps  (98%)
06:42:57:WU01:FS00:0xa4:Completed 1485000 out of 1500000 steps  (99%)
06:42:58:WU00:FS00:Connecting to assign3.stanford.edu:8080
06:42:58:WU00:FS00:News: Welcome to Folding@Home
06:42:58:WU00:FS00:Assigned to work server 171.64.65.99
06:42:58:WU00:FS00:Requesting new work unit for slot 00: RUNNING smp:2 from 171.64.65.99
06:42:58:WU00:FS00:Connecting to 171.64.65.99:8080
06:43:00:WU00:FS00:Downloading 1.98MiB
06:43:03:WU00:FS00:Download complete
06:43:03:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7809 run:0 clone:492 gen:39 core:0xa4 unit:0x0000002e0a3b1e874e31069ffe59e3df
07:45:57:WU01:FS00:0xa4:Completed 1500000 out of 1500000 steps  (100%)
07:45:58:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
07:46:08:WU01:FS00:0xa4:
07:46:08:WU01:FS00:0xa4:Finished Work Unit:
07:46:08:WU01:FS00:0xa4:- Reading up to 2908800 from "01/wudata_01.trr": Read 2908800
07:46:08:WU01:FS00:0xa4:trr file hash check passed.
07:46:08:WU01:FS00:0xa4:- Reading up to 1554364 from "01/wudata_01.xtc": Read 1554364
07:46:09:WU01:FS00:0xa4:xtc file hash check passed.
07:46:09:WU01:FS00:0xa4:edr file hash check passed.
07:46:09:WU01:FS00:0xa4:logfile size: 50876
07:46:09:WU01:FS00:0xa4:Leaving Run
07:46:12:WU01:FS00:0xa4:- Writing 4519052 bytes of core data to disk...
07:46:14:WU01:FS00:0xa4:Done: 4518540 -> 4326672 (compressed to 95.7 percent)
07:46:14:WU01:FS00:0xa4:  ... Done.
07:46:18:WU01:FS00:0xa4:- Shutting down core
07:46:18:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
07:46:19:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:46:19:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7809 run:2 clone:36 gen:40 core:0xa4 unit:0x000000380a3b1e874e3108fe5d292c38
07:46:19:WU01:FS00:Uploading 4.13MiB to 171.64.65.99
07:46:19:WU01:FS00:Connecting to 171.64.65.99:8080
07:46:19:WU00:FS00:Starting
07:46:19:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/Robby/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 702 -lifeline 7456 -checkpoint 15 -np 2
07:46:19:WU00:FS00:Started FahCore on PID 5224
07:46:20:WU00:FS00:Core PID:5736
07:46:20:WU00:FS00:FahCore 0xa4 started
07:46:20:WU00:FS00:0xa4:
07:46:20:WU00:FS00:0xa4:*------------------------------*
07:46:20:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
07:46:20:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
07:46:20:WU00:FS00:0xa4:Preparing to commence simulation
07:46:20:WU00:FS00:0xa4:- Looking at optimizations...
07:46:20:WU00:FS00:0xa4:- Created dyn
07:46:20:WU00:FS00:0xa4:- Files status OK
07:46:21:WU00:FS00:0xa4:- Expanded 2079228 -> 5386224 (decompressed 259.0 percent)
07:46:21:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=2079228 data_size=5386224, decompressed_data_size=5386224 diff=0
07:46:21:WU00:FS00:0xa4:- Digital signature verified
07:46:21:WU00:FS00:0xa4:Project: 7809 (Run 0, Clone 492, Gen 39)
07:46:21:WU00:FS00:0xa4:Assembly optimizations on if available.
07:46:21:WU00:FS00:0xa4:Entering M.D.
07:46:25:WU01:FS00:Upload 40.89%
07:46:27:WU00:FS00:0xa4:Mapping NT from 2 to 2
07:46:28:WU00:FS00:0xa4:Completed 0 out of 1500000 steps  (0%)
07:46:31:WU01:FS00:Upload 72.70%
07:46:37:WU01:FS00:Upload complete
07:46:37:WU01:FS00:Server responded WORK_ACK (400)
07:46:37:WU01:FS00:Cleaning up
08:49:47:WU00:FS00:0xa4:Completed 15000 out of 1500000 steps  (1%)
09:52:40:WU00:FS00:0xa4:Completed 30000 out of 1500000 steps  (2%)
10:55:21:WU00:FS00:0xa4:Completed 45000 out of 1500000 steps  (3%)
11:57:56:WU00:FS00:0xa4:Completed 60000 out of 1500000 steps  (4%)
13:00:54:WU00:FS00:0xa4:Completed 75000 out of 1500000 steps  (5%)
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Re: Project: 7809 (Run 2, Clone 36, Gen 40)
Back in July, PG announced a 10% bonus for processing WU's that used the A4 folding core. That is where the extra points for the WU came from. The client does not have that bonus factored into the estimate reported in the log, it is added by the server when it receives the upload. The blog posting for that is here.
Hi Robby (team 39299),
Your WU (P7809 R2 C36 G40) was added to the stats database on 2013-02-01 00:08:46 for 4998.35 points of credit.
