Upload to 171.64.65.55 rejected
calador
Post by calador »
Server is AFK. Server status page shows no CPU or Net Load, status is full and connect is Reject.
This is what my log shows for the last 14 hours:
01:13:46:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:13:46:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11071 run:5146 clone:0 gen:0 core:0xa3 unit:0x000001440a3b1e5b4ee924f68bf19b9b
01:13:46:WU01:FS00:Uploading 8.31MiB to 171.64.65.55
01:13:46:WU01:FS00:Connecting to 171.64.65.55:8080
01:14:07:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:14:07:WU01:FS00:Connecting to 171.64.65.55:80
01:14:28:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:14:28:WU01:FS00:Trying to send results to collection server
01:14:28:WU01:FS00:Uploading 8.31MiB to 171.67.108.26
01:14:28:WU01:FS00:Connecting to 171.67.108.26:8080
01:14:31:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:14:31:WU01:FS00:Connecting to 171.67.108.26:80
01:14:35:ERROR:WU01:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
01:14:35:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11071 run:5146 clone:0 gen:0 core:0xa3 unit:0x000001440a3b1e5b4ee924f68bf19b9b
01:14:35:WU01:FS00:Uploading 8.31MiB to 171.64.65.55
01:14:35:WU01:FS00:Connecting to 171.64.65.55:8080
01:14:56:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:14:56:WU01:FS00:Connecting to 171.64.65.55:80
01:15:17:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:15:17:WU01:FS00:Trying to send results to collection server
01:15:17:WU01:FS00:Uploading 8.31MiB to 171.67.108.26
01:15:17:WU01:FS00:Connecting to 171.67.108.26:8080
01:15:21:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
01:15:21:WU01:FS00:Connecting to 171.67.108.26:80
01:15:25:ERROR:WU01:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
Rinse. Repeat ad nauseum.
15:38:47:WU01:FS00:Uploading 8.31MiB to 171.64.65.55
15:38:47:WU01:FS00:Connecting to 171.64.65.55:8080
15:38:51:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
15:38:51:WU01:FS00:Connecting to 171.64.65.55:80
15:38:54:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
15:38:54:WU01:FS00:Trying to send results to collection server
15:38:54:WU01:FS00:Uploading 8.31MiB to 171.67.108.26
15:38:54:WU01:FS00:Connecting to 171.67.108.26:8080
15:38:58:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
15:38:58:WU01:FS00:Connecting to 171.67.108.26:80
15:39:02:ERROR:WU01:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
Re: Upload to 171.64.65.55 rejected
A report has been sent to the manager for this WS.
BrandonVeiga
Hardware configuration: Gigabyte GA-990FXA-UD3 | 8-Core AMD FX-8120 @ 3.1Ghz
Corsair Vengeance 8Gb DDR3 1866 | EVGA GTX460 1GB SC@ 867Mhz
630w PSU | 120Gb OCZ Vertex 4 SSD | ASUS PCI-E 802.11n
Windows 7 Ultimate 64-bit
171.64.65.55 - Send issues
Post by BrandonVeiga »
I've been running V7 and running into a problem where a WU will get stuck in "send" state. here is the excerpt from the log:
22:15:40:WU00:FS00:Trying to send results to collection server
22:15:40:WU00:FS00:Uploading 765.60KiB to 171.67.108.26
22:15:40:WU00:FS00:Connecting to 171.67.108.26:8080
22:15:40:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
22:15:40:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: A socket operation was attempted to an unreachable host.
22:18:30:WU01:FS00:0xa4:Completed 8700000 out of 10000000 steps (87%)
22:19:54:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11061 run:0 clone:2701 gen:47 core:0xa3
bollix47
Re: Send issues
Post by bollix47 »
Troubleshooting Server Issues
Your log shows the client trying to connect to a CS that hasn't worked in some time.
Earlier in the log you should see it trying to connect to a WS. That's the server needed to investigate your issue. Check the Server Status link to see if the WS is in Reject or Down.
BrandonVeiga
Re: Send issues
art_l_j_PlanetAMD64, doesn't appear to be the same issue but thank you.
bollix47, that link seems to provide my answer, thank you very much!
bollix47
Re: Send issues
Post by bollix47 »
Sorry, I removed Art's post because of that reason.
Which work server was involved? You can edit your first post and change the title to reflect which server is involved or let us know in a post here and we'll fix the title.
Without knowing the work server there is nothing we can do to rectify the situation.
Normally we can check the Project Summary and find out the server involved but I can find no mention of project:11061 anywhere. :e?:
art_l_j_PlanetAMD64
Re: Send issues
Post by art_l_j_PlanetAMD64 »
bollix47 wrote:Sorry, I removed Art's post because of that reason.
Hey, no sweat, I really appreciate all the hard work you, bruce, P5-133XL, Joe_H, and everyone else at Stanford/PG do for us. I don't know how you put up with us sometimes! :D
bollix47 wrote:Normally we can check the Project Summary and find out the server involved but I can find no mention of project:11061 anywhere. :e?:
I found it in one of my logs here:
07:51:20:WU01:FS01:Connecting to assign3.stanford.edu:8080
07:51:22:WU01:FS01:News: Welcome to Folding@Home
07:51:22:WU01:FS01:Assigned to work server 171.64.65.55
07:51:22:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:4 from 171.64.65.55
07:51:22:WU01:FS01:Connecting to 171.64.65.55:8080
07:51:22:WU01:FS01:Downloading 747.48KiB
07:51:23:WU01:FS01:Download complete
07:51:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11061 run:0 clone:2391 gen:49 core:0xa3 unit:0x000000d90a3b1e5b4e026282d5dc2ec6
07:51:23:WU01:FS01:Downloading project 11061 description
07:51:23:WU01:FS01:Connecting to fah-web.stanford.edu:80
07:51:25:WU01:FS01:Project 11061 description downloaded successfully
art_l_j_PlanetAMD64
Over 1.04 Billion Total Points
Over 185,000 Work Units
Over 3,800,000 PPD
Overall rank (if points are combined) 20 of 1721690
In memory of my Mother May 12th 1923 - February 10th 2012
bollix47
Re: Send issues
Post by bollix47 »
Thanks Art.
That explains a couple of things:
1. The server has been Down/Reject/Not Accept over the course of the last 2-3 days.
2. It's not in the Project Summary because of #1.
Edited BrandonVeiga's first post title to reflect the server I.P. and merged posts with a previous thread concerning same problem.
OVV
Post by OVV »
I've the same problem, 2 WU that i can't upload to the server that is on standby from the 31 january. Any solution?
Thanks
At this time all you can do is wait until they fix whatever went wrong with the server. I have received a response from the manager of this server that he is looking into the problem.
OVV
Post by OVV »
Ok,
thank you!
OVV
Post by OVV »
Any news? The server is still not accepting.
My WU will expire in few days...
Thanks
I wish I could offer you some encouraging news, but I can't. Server 171.64.65.55 is listed as in "standby" which means it has been intentionally taken off-line. I have no details but that generally means something is seriously wrong and it will take time to fix it. Most likely your WU will just expire. :( On the other hand, maybe they're working on it right now and just minutes from bringing it back on-line.
heavykevie
171.64.65.55 server refuses to accept upload of results
Post by heavykevie »
Newbie here, f@h results server refuses to accept results. Here is the log:
********************* Log Started 2013-02-06T09:22:06Z ***********************
09:22:06:************************* Folding@home Client *************************
09:22:06:      Website: http://folding.stanford.edu/
09:22:06:    Copyright: (c) 2009-2012 Stanford University
09:22:06:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:22:06:         Args: --lifeline 2764 --command-port=36330
09:22:06:       Config: D:/Users/Kevin Smith/AppData/Roaming/FAHClient/config.xml
09:22:06:******************************** Build ********************************
09:22:06:      Version: 7.2.9
09:22:06:         Date: Oct 3 2012
09:22:06:         Time: 18:05:48
09:22:06:      SVN Rev: 3578
09:22:06:       Branch: fah/trunk/client
09:22:06:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
09:22:06:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
09:22:06:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
09:22:06:     Platform: win32 XP
09:22:06:         Bits: 32
09:22:06:         Mode: Release
09:22:06:******************************* System ********************************
09:22:06:          CPU: AMD FX(tm)-8320 Eight-Core Processor
09:22:06:       CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
09:22:06:         CPUs: 8
09:22:06:       Memory: 7.92GiB
09:22:06:  Free Memory: 6.49GiB
09:22:06:      Threads: WINDOWS_THREADS
09:22:06:   On Battery: false
09:22:06:   UTC offset: -5
09:22:06:          PID: 3284
09:22:06:          CWD: D:/Users/Kevin Smith/AppData/Roaming/FAHClient
09:22:06:           OS: Windows 7 Home Premium
09:22:06:      OS Arch: AMD64
09:22:06:         GPUs: 1
09:22:06:        GPU 0: UNSUPPORTED: Radeon HD 4770 [RV740]
09:22:06:         CUDA: Not detected
09:22:06:Win32 Service: false
09:22:06:***********************************************************************
09:22:06:<config>
09:22:06:  <!-- FahCore Control -->
09:22:06:  <core-priority v='low'/>
09:22:06:
09:22:06:  <!-- Folding Slot Configuration -->
09:22:06:  <gpu v='true'/>
09:22:06:
09:22:06:  <!-- Network -->
09:22:06:  <proxy v=':8080'/>
09:22:06:
09:22:06:  <!-- User Information -->
09:22:06:  <team v='159568'/>
09:22:06:  <user v='heavykevie'/>
09:22:06:
09:22:06:  <!-- Folding Slots -->
09:22:06:  <slot id='0' type='SMP'>
09:22:06:    <cpus v='2'/>
09:22:06:  </slot>
09:22:06:</config>
09:22:06:Trying to access database...
09:22:06:Successfully acquired database lock
09:22:06:Enabled folding slot 00: READY smp:2
09:22:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
09:22:06:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
09:22:06:WU01:FS00:Starting
09:22:06:WU00:FS00:Connecting to 171.64.65.55:8080
09:22:06:WU01:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:/Users/Kevin Smith/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 702 -lifeline 3284 -checkpoint 15 -np 2
09:22:06:WU01:FS00:Started FahCore on PID 3808
09:22:07:WU01:FS00:Core PID:3820
09:22:07:WU01:FS00:FahCore 0xa4 started
09:22:07:WU01:FS00:0xa4:
09:22:07:WU01:FS00:0xa4:*------------------------------*
09:22:07:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
09:22:07:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
09:22:07:WU01:FS00:0xa4:Preparing to commence simulation
09:22:07:WU01:FS00:0xa4:- Looking at optimizations...
09:22:07:WU01:FS00:0xa4:- Files status OK
09:22:07:WU01:FS00:0xa4:- Expanded 147131 -> 503128 (decompressed 341.9 percent)
09:22:07:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=147131 data_size=503128, decompressed_data_size=503128 diff=0
09:22:07:WU01:FS00:0xa4:- Digital signature verified
09:22:07:WU01:FS00:0xa4:Project: 7083 (Run 0, Clone 95, Gen 2)
09:22:07:WU01:FS00:0xa4:Assembly optimizations on if available.
09:22:07:WU01:FS00:0xa4:Entering M.D.
09:22:08:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:22:08:WU00:FS00:Connecting to 171.64.65.55:80
09:22:09:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
09:22:09:WU00:FS00:Trying to send results to collection server
09:22:09:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
09:22:09:WU00:FS00:Connecting to 171.67.108.26:8080
09:22:09:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
09:22:10:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:22:10:WU00:FS00:Connecting to 171.67.108.26:80
09:22:12:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
09:22:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
09:22:12:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
09:22:12:WU00:FS00:Connecting to 171.64.65.55:8080
09:22:13:WU01:FS00:0xa4:Using Gromacs checkpoints
09:22:13:WU01:FS00:0xa4:Mapping NT from 2 to 2
09:22:13:WU01:FS00:0xa4:Resuming from checkpoint
09:22:13:WU01:FS00:0xa4:Verified 01/wudata_01.log
09:22:13:WU01:FS00:0xa4:Verified 01/wudata_01.trr
09:22:13:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
09:22:13:WU01:FS00:0xa4:Verified 01/wudata_01.edr
09:22:13:WU01:FS00:0xa4:Completed 400001 out of 10000000 steps  (4%)
09:22:13:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:22:13:WU00:FS00:Connecting to 171.64.65.55:80
09:22:15:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
09:22:15:WU00:FS00:Trying to send results to collection server
09:22:15:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
09:22:15:WU00:FS00:Connecting to 171.67.108.26:8080
09:22:16:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:22:16:WU00:FS00:Connecting to 171.67.108.26:80
09:22:18:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
09:23:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
09:23:12:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
09:23:12:WU00:FS00:Connecting to 171.64.65.55:8080
09:23:13:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:23:13:WU00:FS00:Connecting to 171.64.65.55:80
09:23:15:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
09:23:15:WU00:FS00:Trying to send results to collection server
09:23:15:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
09:23:15:WU00:FS00:Connecting to 171.67.108.26:8080
09:23:16:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:23:16:WU00:FS00:Connecting to 171.67.108.26:80
09:23:18:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
09:24:49:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
09:24:49:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
09:24:49:WU00:FS00:Connecting to 171.64.65.55:8080
09:24:50:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:24:50:WU00:FS00:Connecting to 171.64.65.55:80
09:24:51:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
09:24:51:WU00:FS00:Trying to send results to collection server
09:24:51:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
09:24:51:WU00:FS00:Connecting to 171.67.108.26:8080
09:24:53:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:24:53:WU00:FS00:Connecting to 171.67.108.26:80
09:24:54:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
09:27:26:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
09:27:26:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
09:27:26:WU00:FS00:Connecting to 171.64.65.55:8080
09:27:27:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:27:27:WU00:FS00:Connecting to 171.64.65.55:80
09:27:29:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
09:27:29:WU00:FS00:Trying to send results to collection server
09:27:29:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
09:27:29:WU00:FS00:Connecting to 171.67.108.26:8080
09:27:30:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:27:30:WU00:FS00:Connecting to 171.67.108.26:80
09:27:31:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
09:31:09:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
09:31:23:Server connection id=2 ended
09:31:41:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
09:31:41:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
09:31:41:WU00:FS00:Connecting to 171.64.65.55:8080
09:31:42:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:31:42:WU00:FS00:Connecting to 171.64.65.55:80
09:31:43:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
09:31:43:WU00:FS00:Trying to send results to collection server
09:31:43:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
09:31:43:WU00:FS00:Connecting to 171.67.108.26:8080
09:31:44:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:31:44:WU00:FS00:Connecting to 171.67.108.26:80
09:31:46:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
09:38:32:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
09:38:32:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
09:38:32:WU00:FS00:Connecting to 171.64.65.55:8080
09:38:33:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:38:33:WU00:FS00:Connecting to 171.64.65.55:80
09:38:34:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
09:38:34:WU00:FS00:Trying to send results to collection server
09:38:34:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
09:38:34:WU00:FS00:Connecting to 171.67.108.26:8080
09:38:36:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:38:36:WU00:FS00:Connecting to 171.67.108.26:80
09:38:37:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
09:49:37:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
09:49:37:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
09:49:37:WU00:FS00:Connecting to 171.64.65.55:8080
09:49:39:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:49:39:WU00:FS00:Connecting to 171.64.65.55:80
09:49:40:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
09:49:40:WU00:FS00:Trying to send results to collection server
09:49:40:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
09:49:40:WU00:FS00:Connecting to 171.67.108.26:8080
09:49:41:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:49:41:WU00:FS00:Connecting to 171.67.108.26:80
09:49:42:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
09:51:00:WU01:FS00:0xa4:Completed 500000 out of 10000000 steps  (5%)
10:07:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
10:07:34:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
10:07:34:WU00:FS00:Connecting to 171.64.65.55:8080
10:07:35:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:07:35:WU00:FS00:Connecting to 171.64.65.55:80
10:07:37:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
10:07:37:WU00:FS00:Trying to send results to collection server
10:07:37:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
10:07:37:WU00:FS00:Connecting to 171.67.108.26:8080
10:07:38:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:07:38:WU00:FS00:Connecting to 171.67.108.26:80
10:07:39:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
10:16:45:WU01:FS00:0xa4:Completed 600000 out of 10000000 steps  (6%)
10:36:36:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
10:36:36:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
10:36:36:WU00:FS00:Connecting to 171.64.65.55:8080
10:36:38:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:36:38:WU00:FS00:Connecting to 171.64.65.55:80
10:36:39:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
10:36:39:WU00:FS00:Trying to send results to collection server
10:36:39:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
10:36:39:WU00:FS00:Connecting to 171.67.108.26:8080
10:36:40:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:36:40:WU00:FS00:Connecting to 171.67.108.26:80
10:36:41:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
10:42:14:WU01:FS00:0xa4:Completed 700000 out of 10000000 steps  (7%)
11:07:45:WU01:FS00:0xa4:Completed 800000 out of 10000000 steps  (8%)
11:23:35:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
11:23:35:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
11:23:35:WU00:FS00:Connecting to 171.64.65.55:8080
11:23:36:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
11:23:36:WU00:FS00:Connecting to 171.64.65.55:80
11:23:38:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
11:23:38:WU00:FS00:Trying to send results to collection server
11:23:38:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
11:23:38:WU00:FS00:Connecting to 171.67.108.26:8080
11:23:39:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
11:23:39:WU00:FS00:Connecting to 171.67.108.26:80
11:23:40:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
11:33:12:WU01:FS00:0xa4:Completed 900000 out of 10000000 steps  (9%)
11:58:50:WU01:FS00:0xa4:Completed 1000000 out of 10000000 steps  (10%)
12:24:15:WU01:FS00:0xa4:Completed 1100000 out of 10000000 steps  (11%)
12:39:36:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
12:39:36:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
12:39:36:WU00:FS00:Connecting to 171.64.65.55:8080
12:39:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
12:39:37:WU00:FS00:Connecting to 171.64.65.55:80
12:39:39:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
12:39:39:WU00:FS00:Trying to send results to collection server
12:39:39:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
12:39:39:WU00:FS00:Connecting to 171.67.108.26:8080
12:39:40:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
12:39:40:WU00:FS00:Connecting to 171.67.108.26:80
12:39:41:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
12:49:43:WU01:FS00:0xa4:Completed 1200000 out of 10000000 steps  (12%)
13:15:11:WU01:FS00:0xa4:Completed 1300000 out of 10000000 steps  (13%)
13:40:36:WU01:FS00:0xa4:Completed 1400000 out of 10000000 steps  (14%)
14:06:02:WU01:FS00:0xa4:Completed 1500000 out of 10000000 steps  (15%)
14:31:31:WU01:FS00:0xa4:Completed 1600000 out of 10000000 steps  (16%)
14:42:36:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
14:42:36:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
14:42:36:WU00:FS00:Connecting to 171.64.65.55:8080
14:42:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:42:37:WU00:FS00:Connecting to 171.64.65.55:80
14:42:38:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
14:42:38:WU00:FS00:Trying to send results to collection server
14:42:38:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
14:42:38:WU00:FS00:Connecting to 171.67.108.26:8080
14:42:39:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:42:40:WU00:FS00:Connecting to 171.67.108.26:80
14:42:41:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
14:57:00:WU01:FS00:0xa4:Completed 1700000 out of 10000000 steps  (17%)
******************************** Date: 06/02/13 ********************************
15:22:25:WU01:FS00:0xa4:Completed 1800000 out of 10000000 steps  (18%)
15:47:49:WU01:FS00:0xa4:Completed 1900000 out of 10000000 steps  (19%)
16:13:18:WU01:FS00:0xa4:Completed 2000000 out of 10000000 steps  (20%)
16:38:49:WU01:FS00:0xa4:Completed 2100000 out of 10000000 steps  (21%)
17:04:20:WU01:FS00:0xa4:Completed 2200000 out of 10000000 steps  (22%)
17:29:50:WU01:FS00:0xa4:Completed 2300000 out of 10000000 steps  (23%)
17:55:15:WU01:FS00:0xa4:Completed 2400000 out of 10000000 steps  (24%)
18:01:36:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11021 run:0 clone:2807 gen:49 core:0xa3 unit:0x000000fe0a3b1e5b4daf3d32a8bfb144
18:01:36:WU00:FS00:Uploading 8.30MiB to 171.64.65.55
18:01:36:WU00:FS00:Connecting to 171.64.65.55:8080
18:01:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:01:37:WU00:FS00:Connecting to 171.64.65.55:80
18:01:39:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.55:80: No connection could be made because the target machine actively refused it.
18:01:39:WU00:FS00:Trying to send results to collection server
18:01:39:WU00:FS00:Uploading 8.30MiB to 171.67.108.26
18:01:39:WU00:FS00:Connecting to 171.67.108.26:8080
18:01:40:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:01:40:WU00:FS00:Connecting to 171.67.108.26:80
18:01:41:ERROR:WU00:FS00:Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:20:44:WU01:FS00:0xa4:Completed 2500000 out of 10000000 steps  (25%)
18:46:12:WU01:FS00:0xa4:Completed 2600000 out of 10000000 steps  (26%)
19:11:37:WU01:FS00:0xa4:Completed 2700000 out of 10000000 steps  (27%)
19:37:02:WU01:FS00:0xa4:Completed 2800000 out of 10000000 steps  (28%)
20:02:30:WU01:FS00:0xa4:Completed 2900000 out of 10000000 steps  (29%)
So what am I doing wrong?
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
You haven't done anything wrong. You have no control over a down server. The client will periodically contact the server and when it comes back online it will deliver the results. Until then there is nothing to do but wait.
