Lost Points on PRCG 7022
Syn0101
Post by Syn0101 »
Hi,
Hours ago I've completed project:7022 run:2 clone:503 gen:28 and the final credit estimate is 2632.00 points. But instead, i'm only getting 895 points (on the 194th completed WU).
Previously, i've completed a couple or more of these related projects and the points given are near to the estimates with no issues. Not sure whether it is related to the repeated errors that I got on PRCG 6338 recently and hence affecting the bonus. Even so, the base points isn't 895.
Below is my log file.
*********************** Log Started 2013-01-31T02:33:11Z ***********************
02:33:11:************************* Folding@home Client *************************
02:33:11:      Website: http://folding.stanford.edu/
02:33:11:    Copyright: (c) 2009-2012 Stanford University
02:33:11:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:33:11:         Args: --lifeline 2504 --command-port=36330
02:33:11:       Config: C:/Users/User/AppData/Roaming/FAHClient/config.xml
02:33:11:******************************** Build ********************************
02:33:11:      Version: 7.2.9
02:33:11:         Date: Oct 3 2012
02:33:11:         Time: 18:05:48
02:33:11:      SVN Rev: 3578
02:33:11:       Branch: fah/trunk/client
02:33:11:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:33:11:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:33:11:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:33:11:     Platform: win32 XP
02:33:11:         Bits: 32
02:33:11:         Mode: Release
02:33:11:******************************* System ********************************
02:33:11:          CPU: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
02:33:11:       CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
02:33:11:         CPUs: 8
02:33:11:       Memory: 3.94GiB
02:33:11:  Free Memory: 2.73GiB
02:33:11:      Threads: WINDOWS_THREADS
02:33:11:   On Battery: false
02:33:11:   UTC offset: 8
02:33:11:          PID: 1852
02:33:11:          CWD: C:/Users/User/AppData/Roaming/FAHClient
02:33:11:           OS: Windows 7 Home Premium
02:33:11:      OS Arch: AMD64
02:33:11:         GPUs: 1
02:33:11:        GPU 0: NVIDIA:2 GF108 [GeForce GT 420M]
02:33:11:         CUDA: 2.1
02:33:11:  CUDA Driver: 3020
02:33:11:Win32 Service: false
02:33:11:***********************************************************************
02:33:11:<config>
02:33:11:  <!-- Folding Slot Configuration -->
02:33:11:  <cause-pref v='PARKINSONS'/>
02:33:11:  <max-packet-size v='small'/>
02:33:11:
02:33:11:  <!-- Network -->
02:33:11:  <proxy v=':8080'/>
02:33:11:
02:33:11:  <!-- User Information -->
02:33:11:  <passkey v='********************************'/>
02:33:11:  <team v='223274'/>
02:33:11:  <user v='Syn007'/>
02:33:11:
02:33:11:  <!-- Work Unit Control -->
02:33:11:  <next-unit-percentage v='100'/>
02:33:11:
02:33:11:  <!-- Folding Slots -->
02:33:11:  <slot id='0' type='SMP'>
02:33:11:    <cpus v='6'/>
02:33:11:  </slot>
02:33:11:  <slot id='1' type='GPU'>
02:33:11:    <pause-on-start v='true'/>
02:33:11:  </slot>
02:33:11:</config>
02:33:11:Trying to access database...
02:33:11:Successfully acquired database lock
02:33:11:Enabled folding slot 00: READY smp:6
02:33:11:Enabled folding slot 01: PAUSED gpu:0:"GF108 [GeForce GT 420M]"
02:33:11:WU00:FS00:Starting
02:33:11:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 702 -lifeline 1852 -checkpoint 15 -np 6
02:33:11:WU00:FS00:Started FahCore on PID 3356
02:33:11:WU00:FS00:Core PID:3452
02:33:11:WU00:FS00:FahCore 0xa4 started
02:33:12:WU00:FS00:0xa4:
02:33:12:WU00:FS00:0xa4:*------------------------------*
02:33:12:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
02:33:12:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:33:12:WU00:FS00:0xa4:Preparing to commence simulation
02:33:12:WU00:FS00:0xa4:- Looking at optimizations...
02:33:12:WU00:FS00:0xa4:- Files status OK
02:33:12:WU00:FS00:0xa4:- Expanded 54175 -> 201536 (decompressed 372.0 percent)
02:33:12:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=54175 data_size=201536, decompressed_data_size=201536 diff=0
02:33:12:WU00:FS00:0xa4:- Digital signature verified
02:33:12:WU00:FS00:0xa4:Project: 7022 (Run 2, Clone 503, Gen 28)
02:33:12:WU00:FS00:0xa4:Assembly optimizations on if available.
02:33:12:WU00:FS00:0xa4:Entering M.D.
02:33:12:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
02:33:18:WU00:FS00:0xa4:Using Gromacs checkpoints
02:33:18:WU00:FS00:0xa4:Mapping NT from 6 to 6
02:33:18:WU00:FS00:0xa4:Resuming from checkpoint
02:33:18:WU00:FS00:0xa4:Verified 00/wudata_01.log
02:33:18:WU00:FS00:0xa4:Verified 00/wudata_01.trr
02:33:18:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
02:33:18:WU00:FS00:0xa4:Verified 00/wudata_01.edr
02:33:18:WU00:FS00:0xa4:Completed 7100001 out of 10000000 steps  (71%)
02:34:05:FS00:Paused
02:34:05:FS00:Shutting core down
02:34:12:WU00:FS00:0xa4:Client no longer detected. Shutting down core
02:34:12:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
02:34:12:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
02:34:33:Removing old file 'configs/config-20130125-110902.xml'
02:34:33:Saving configuration to config.xml
02:34:33:<config>
02:34:33:  <!-- Folding Slot Configuration -->
02:34:33:  <cause-pref v='PARKINSONS'/>
02:34:33:  <max-packet-size v='small'/>
02:34:33:
02:34:33:  <!-- Network -->
02:34:33:  <proxy v=':8080'/>
02:34:33:
02:34:33:  <!-- User Information -->
02:34:33:  <passkey v='********************************'/>
02:34:33:  <team v='223274'/>
02:34:33:  <user v='Syn007'/>
02:34:33:
02:34:33:  <!-- Work Unit Control -->
02:34:33:  <next-unit-percentage v='100'/>
02:34:33:
02:34:33:  <!-- Folding Slots -->
02:34:33:  <slot id='0' type='SMP'>
02:34:33:    <cpus v='8'/>
02:34:33:  </slot>
02:34:33:  <slot id='1' type='GPU'>
02:34:33:    <pause-on-start v='true'/>
02:34:33:  </slot>
02:34:33:</config>
02:34:41:FS00:Unpaused
02:34:42:WU00:FS00:Starting
02:34:42:WARNING:WU00:FS00:Changed SMP threads from 6 to 8 this can cause some work units to fail
02:34:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 702 -lifeline 1852 -checkpoint 15 -np 8
02:34:42:WU00:FS00:Started FahCore on PID 936
02:34:42:WU00:FS00:Core PID:5696
02:34:42:WU00:FS00:FahCore 0xa4 started
02:34:42:WU00:FS00:0xa4:
02:34:42:WU00:FS00:0xa4:*------------------------------*
02:34:42:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
02:34:42:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:34:42:WU00:FS00:0xa4:Preparing to commence simulation
02:34:42:WU00:FS00:0xa4:- Looking at optimizations...
02:34:42:WU00:FS00:0xa4:- Files status OK
02:34:42:WU00:FS00:0xa4:- Expanded 54175 -> 201536 (decompressed 372.0 percent)
02:34:42:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=54175 data_size=201536, decompressed_data_size=201536 diff=0
02:34:42:WU00:FS00:0xa4:- Digital signature verified
02:34:42:WU00:FS00:0xa4:Project: 7022 (Run 2, Clone 503, Gen 28)
02:34:42:WU00:FS00:0xa4:Assembly optimizations on if available.
02:34:42:WU00:FS00:0xa4:Entering M.D.
02:34:48:WU00:FS00:0xa4:Using Gromacs checkpoints
02:34:48:WU00:FS00:0xa4:Mapping NT from 8 to 8
02:34:48:WU00:FS00:0xa4:Resuming from checkpoint
02:34:48:WU00:FS00:0xa4:Verified 00/wudata_01.log
02:34:48:WU00:FS00:0xa4:Verified 00/wudata_01.trr
02:34:48:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
02:34:48:WU00:FS00:0xa4:Verified 00/wudata_01.edr
02:34:48:WU00:FS00:0xa4:Completed 7100001 out of 10000000 steps  (71%)
02:35:05:FS01:Unpaused
02:35:05:WU01:FS01:Starting
02:35:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 1852 -checkpoint 15 -gpu 0
02:35:05:WU01:FS01:Started FahCore on PID 4908
02:35:06:WU01:FS01:Core PID:5324
02:35:06:WU01:FS01:FahCore 0x15 started
02:35:06:WU01:FS01:0x15:
02:35:06:WU01:FS01:0x15:*------------------------------*
02:35:06:WU01:FS01:0x15:Folding@Home GPU Core
02:35:06:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
02:35:06:WU01:FS01:0x15:Build host             AmoebaRemote
02:35:06:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
02:35:06:WU01:FS01:0x15:Core                   15
02:35:06:WU01:FS01:0x15:Window's signal control handler registered.
02:35:06:WU01:FS01:0x15:Preparing to commence simulation
02:35:06:WU01:FS01:0x15:- Looking at optimizations...
02:35:06:WU01:FS01:0x15:- Files status OK
02:35:06:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
02:35:06:WU01:FS01:0x15:- Expanded 124906 -> 501826 (decompressed 401.7 percent)
02:35:06:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124906 data_size=501826, decompressed_data_size=501826 diff=0
02:35:06:WU01:FS01:0x15:- Digital signature verified
02:35:06:WU01:FS01:0x15:Project: 7623 (Run 258, Clone 0, Gen 205)
02:35:06:WU01:FS01:0x15:Assembly optimizations on if available.
02:35:06:WU01:FS01:0x15:Entering M.D.
02:35:08:WU01:FS01:0x15:Will resume from checkpoint file 01/wudata_01.ckp
02:35:08:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  2785221059 2237163940 2873424396 1062342728 1042357234
02:35:08:WU01:FS01:0x15:GPU device id=0
02:35:08:WU01:FS01:0x15:Working on Protein
02:35:08:WU01:FS01:0x15:Client config unavailable.
02:35:09:WU01:FS01:0x15:Starting GUI Server
02:36:22:WU01:FS01:0x15:Resuming from checkpoint
02:36:22:WU01:FS01:0x15:fcCheckPointResume: retreived and current tpr file hash:
02:36:22:WU01:FS01:0x15:   0   2785221059   2785221059
02:36:22:WU01:FS01:0x15:   1   2237163940   2237163940
02:36:22:WU01:FS01:0x15:   2   2873424396   2873424396
02:36:22:WU01:FS01:0x15:   3   1062342728   1062342728
02:36:22:WU01:FS01:0x15:   4   1042357234   1042357234
02:36:22:WU01:FS01:0x15:fcCheckPointResume: file hashes same.
02:36:22:WU01:FS01:0x15:fcCheckPointResume: state restored.
02:36:22:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
02:36:22:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
02:36:22:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
02:36:22:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
02:36:22:WU01:FS01:0x15:fcCheckPointResume: state restored 2
02:36:22:WU01:FS01:0x15:Resumed from checkpoint
02:36:22:WU01:FS01:0x15:Setting checkpoint frequency: 400000
02:36:22:WU01:FS01:0x15:Completed   1600001 out of 40000000 steps (4%).
02:40:23:WU00:FS00:0xa4:Completed 7200000 out of 10000000 steps  (72%)
02:46:26:WU00:FS00:0xa4:Completed 7300000 out of 10000000 steps  (73%)
02:51:22:Removing old file 'configs/config-20130126-020134.xml'
02:51:22:Saving configuration to config.xml
02:51:22:<config>
02:51:22:  <!-- Folding Slot Configuration -->
02:51:22:  <cause-pref v='CANCER'/>
02:51:22:  <max-packet-size v='small'/>
02:51:22:
02:51:22:  <!-- Network -->
02:51:22:  <proxy v=':8080'/>
02:51:22:
02:51:22:  <!-- User Information -->
02:51:22:  <passkey v='********************************'/>
02:51:22:  <team v='223274'/>
02:51:22:  <user v='Syn007'/>
02:51:22:
02:51:22:  <!-- Work Unit Control -->
02:51:22:  <next-unit-percentage v='100'/>
02:51:22:
02:51:22:  <!-- Folding Slots -->
02:51:22:  <slot id='0' type='SMP'>
02:51:22:    <cpus v='8'/>
02:51:22:  </slot>
02:51:22:  <slot id='1' type='GPU'>
02:51:22:    <pause-on-start v='true'/>
02:51:22:  </slot>
02:51:22:</config>
02:52:30:WU00:FS00:0xa4:Completed 7400000 out of 10000000 steps  (74%)
02:56:21:Removing old file 'configs/config-20130126-062136.xml'
02:56:21:Saving configuration to config.xml
02:56:21:<config>
02:56:21:  <!-- Folding Slot Configuration -->
02:56:21:  <cause-pref v='PARKINSONS'/>
02:56:21:  <max-packet-size v='small'/>
02:56:21:
02:56:21:  <!-- Network -->
02:56:21:  <proxy v=':8080'/>
02:56:21:
02:56:21:  <!-- User Information -->
02:56:21:  <passkey v='********************************'/>
02:56:21:  <team v='223274'/>
02:56:21:  <user v='Syn007'/>
02:56:21:
02:56:21:  <!-- Work Unit Control -->
02:56:21:  <next-unit-percentage v='100'/>
02:56:21:
02:56:21:  <!-- Folding Slots -->
02:56:21:  <slot id='0' type='SMP'>
02:56:21:    <cpus v='8'/>
02:56:21:  </slot>
02:56:21:  <slot id='1' type='GPU'>
02:56:21:    <pause-on-start v='true'/>
02:56:21:  </slot>
02:56:21:</config>
02:58:54:WU00:FS00:0xa4:Completed 7500000 out of 10000000 steps  (75%)
03:04:56:WU00:FS00:0xa4:Completed 7600000 out of 10000000 steps  (76%)
03:10:49:WU00:FS00:0xa4:Completed 7700000 out of 10000000 steps  (77%)
03:16:48:WU00:FS00:0xa4:Completed 7800000 out of 10000000 steps  (78%)
03:21:43:WU01:FS01:0x15:Completed   2000000 out of 40000000 steps (5%).
03:22:44:WU00:FS00:0xa4:Completed 7900000 out of 10000000 steps  (79%)
03:28:37:WU00:FS00:0xa4:Completed 8000000 out of 10000000 steps  (80%)
03:34:31:WU00:FS00:0xa4:Completed 8100000 out of 10000000 steps  (81%)
03:39:02:WU00:FS00:0xa4:Completed 8200000 out of 10000000 steps  (82%)
03:43:34:WU00:FS00:0xa4:Completed 8300000 out of 10000000 steps  (83%)
03:48:05:WU00:FS00:0xa4:Completed 8400000 out of 10000000 steps  (84%)
03:52:36:WU00:FS00:0xa4:Completed 8500000 out of 10000000 steps  (85%)
03:57:07:WU00:FS00:0xa4:Completed 8600000 out of 10000000 steps  (86%)
04:01:37:WU00:FS00:0xa4:Completed 8700000 out of 10000000 steps  (87%)
04:06:09:WU00:FS00:0xa4:Completed 8800000 out of 10000000 steps  (88%)
04:10:39:WU00:FS00:0xa4:Completed 8900000 out of 10000000 steps  (89%)
04:17:09:WU00:FS00:0xa4:Completed 9000000 out of 10000000 steps  (90%)
04:23:52:WU00:FS00:0xa4:Completed 9100000 out of 10000000 steps  (91%)
04:28:39:WU01:FS01:0x15:Completed   2400000 out of 40000000 steps (6%).
04:29:55:WU00:FS00:0xa4:Completed 9200000 out of 10000000 steps  (92%)
04:36:09:WU00:FS00:0xa4:Completed 9300000 out of 10000000 steps  (93%)
04:42:10:WU00:FS00:0xa4:Completed 9400000 out of 10000000 steps  (94%)
04:48:09:WU00:FS00:0xa4:Completed 9500000 out of 10000000 steps  (95%)
04:54:07:WU00:FS00:0xa4:Completed 9600000 out of 10000000 steps  (96%)
05:00:06:WU00:FS00:0xa4:Completed 9700000 out of 10000000 steps  (97%)
05:06:06:WU00:FS00:0xa4:Completed 9800000 out of 10000000 steps  (98%)
05:10:58:WU00:FS00:0xa4:Completed 9900000 out of 10000000 steps  (99%)
05:15:29:WU00:FS00:0xa4:Completed 10000000 out of 10000000 steps  (100%)
05:15:29:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
05:15:30:WU02:FS00:Connecting to assign3.stanford.edu:8080
05:15:31:WU02:FS00:News: Welcome to Folding@Home
05:15:31:WU02:FS00:Assigned to work server 129.74.85.15
05:15:31:WU02:FS00:Requesting new work unit for slot 00: RUNNING smp:8 from 129.74.85.15
05:15:31:WU02:FS00:Connecting to 129.74.85.15:8080
05:15:33:WU02:FS00:Downloading 54.34KiB
05:15:33:WU02:FS00:Download complete
05:15:33:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:7010 run:0 clone:106 gen:43 core:0xa4 unit:0x000000600001329c4dfb94d82cc86b94
05:15:33:WU02:FS00:Downloading project 7010 description
05:15:33:WU02:FS00:Connecting to fah-web.stanford.edu:80
05:15:35:WU02:FS00:Project 7010 description downloaded successfully
05:15:39:WU00:FS00:0xa4:
05:15:39:WU00:FS00:0xa4:Finished Work Unit:
05:15:39:WU00:FS00:0xa4:- Reading up to 2077368 from "00/wudata_01.trr": Read 2077368
05:15:39:WU00:FS00:0xa4:trr file hash check passed.
05:15:39:WU00:FS00:0xa4:- Reading up to 216504 from "00/wudata_01.xtc": Read 216504
05:15:39:WU00:FS00:0xa4:xtc file hash check passed.
05:15:39:WU00:FS00:0xa4:edr file hash check passed.
05:15:39:WU00:FS00:0xa4:logfile size: 81614
05:15:39:WU00:FS00:0xa4:Leaving Run
05:15:42:WU00:FS00:0xa4:- Writing 2399958 bytes of core data to disk...
05:15:43:WU00:FS00:0xa4:Done: 2399446 -> 1869444 (compressed to 77.9 percent)
05:15:43:WU00:FS00:0xa4:  ... Done.
05:15:43:WU00:FS00:0xa4:- Shutting down core
05:15:43:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
05:15:44:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:15:44:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:7022 run:2 clone:503 gen:28 core:0xa4 unit:0x000000340001329c4dfba89c3771b693
05:15:44:WU00:FS00:Uploading 1.78MiB to 129.74.85.15
05:15:44:WU02:FS00:Starting
05:15:44:WU00:FS00:Connecting to 129.74.85.15:8080
05:15:44:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 702 -lifeline 1852 -checkpoint 15 -np 8
05:15:44:WU02:FS00:Started FahCore on PID 2928
05:15:44:WU02:FS00:Core PID:2448
05:15:44:WU02:FS00:FahCore 0xa4 started
05:15:44:WU02:FS00:0xa4:
05:15:44:WU02:FS00:0xa4:*------------------------------*
05:15:44:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
05:15:44:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:15:44:WU02:FS00:0xa4:Preparing to commence simulation
05:15:44:WU02:FS00:0xa4:- Looking at optimizations...
05:15:44:WU02:FS00:0xa4:- Created dyn
05:15:44:WU02:FS00:0xa4:- Files status OK
05:15:44:WU02:FS00:0xa4:- Expanded 55132 -> 208564 (decompressed 378.2 percent)
05:15:44:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=55132 data_size=208564, decompressed_data_size=208564 diff=0
05:15:44:WU02:FS00:0xa4:- Digital signature verified
05:15:44:WU02:FS00:0xa4:Project: 7010 (Run 0, Clone 106, Gen 43)
05:15:45:WU02:FS00:0xa4:
05:15:45:WU02:FS00:0xa4:Assembly optimizations on if available.
05:15:45:WU02:FS00:0xa4:Entering M.D.
05:15:50:WU02:FS00:0xa4:Mapping NT from 8 to 8
05:15:50:WU02:FS00:0xa4:Completed 0 out of 10000000 steps  (0%)
05:15:50:WU00:FS00:Upload 17.52%
05:15:56:WU00:FS00:Upload 35.05%
05:16:02:WU00:FS00:Upload 49.07%
05:16:08:WU00:FS00:Upload 66.59%
05:16:14:WU00:FS00:Upload 84.11%
05:16:20:WU00:FS00:Upload 100.00%
05:16:21:WU00:FS00:Upload complete
05:16:21:WU00:FS00:Server responded WORK_ACK (400)
05:16:21:WU00:FS00:Final credit estimate, 2632.00 points
05:16:21:WU00:FS00:Cleaning up
art_l_j_PlanetAMD64
Re: Lost Points on PRCG 7022
Post by art_l_j_PlanetAMD64 »
From Project 7022:
Technical details
This project (WW 22 ext/folded 395K) is set for 600.00 points, a preferred deadline of 8.00 days, and a final deadline 11.00 days. This project uses the GRO-A4 FAH core software and is hosted by Folding@home server 129.74.85.15.
art_l_j_PlanetAMD64
Over 1.04 Billion Total Points
Over 185,000 Work Units
Over 3,800,000 PPD
Overall rank (if points are combined) 20 of 1721690
In memory of my Mother May 12th 1923 - February 10th 2012
There is no result yet in the database for this WU. It looks like the 895 pts was the award for a different WU:
Hi Syn007 (team 223274),
Your WU (P2974 R101 C13 G5) was added to the stats database on 2013-01-30 22:06:37 for 895 points of credit.
bollix47
Post by bollix47 »
After another stats update it is now in the database:
Your WU (P7022 R2 C503 G28) was added to the stats database on 2013-01-31 01:10:13 for 2896.08 points of credit.
The points should show up in the 3rd party stats in their next update.
It's a good practice to wait 3-4 hours after an upload before declaring it missing. :ewink:
Syn0101
Post by Syn0101 »
Oh, the 895 points must be from another system at my office which coincide within the same hour. 1st time i encountered delayed results. Just checked again and 2896 points has just been awarded on my 196th completed WU.
1) Is the database for a specific WU available for public view?
About your reply with the quote showing :
2) Am i able to retrieve this info on my own?
So far, I'm only aware of
http://folding.stanford.edu/English/Stats
http://fah-web.stanford.edu/pybeta/serverstat.html
http://fah-web.stanford.edu/psummary.html
but i couldn't retrieve info out of them as specific as yours.
bollix47
Post by bollix47 »
No, the database is not open to public viewing. I'm sure you can appreciate that opening it up to tens of thousands of donors could put a strain on the resources. The occasional check by a mod does not have a significant impact.
Currently you have a number of sources for your stats which include:
1. Official - updated hourly most of the time but depending on the timing of the upload it could take 2 hours to show up in your stats
2. 3rd party stats (EOC, kakao, etc) - updated every 3 hours but depending on the timing of the upload you might have to wait until the next 3 hour update
Your stats on EOC: http://folding.extremeoverclocking.com/ ... =&u=628771 - the missing points should show up on their next update
Your stats on kakao: http://kakaostats.com/usum.php?u=1864934 - latest update shows the points you were concerned about
There are other 3rd party folding stats sites but the two above are linked at the top of every forum page.
Syn0101
Post by Syn0101 »
Ah, thanks for the clarification. The extra 2 links will come in handy.
I'll be more patient next time instead of freaking out when the stats doesn't appear within 1-2 hours.
Appreciate all the replies :)
