128.143.231.201:8080/
patonb
Post by patonb »
I can't get past this:
--- Opening Log file [January 27 22:22:34 UTC]
# Linux SMP Console Edition ###################################################
                       Folding@Home Client Version 6.34
                          http://folding.stanford.edu
Launch directory: /home/brent/fah
Executable: ./fah6
Arguments: -send all -smp -bigadv -verbosity 9
[22:22:34] - Ask before connecting: No
[22:22:34] - User name: patonb (Team 12864)
[22:22:34] - User ID: 14466BDC3AABA2F1
[22:22:34] - Machine ID: 1
[22:22:34]
[22:22:34] Loaded queue successfully.
[22:22:34] Deleting incompletely fetched item (4) from queue position #1
[22:22:34] - Warning: Could not delete all work unit files (1): Core file absent
[22:22:34] Attempting to return result(s) to server...
[22:22:34] Trying to send all finished work units
[22:22:34] Project: 8101 (Run 1, Clone 3, Gen 181)
[22:22:34] + Attempting to send results [January 27 22:22:34 UTC]
[22:22:34] - Reading file work/wuresults_00.dat from core
[22:22:34]   (Read 91519344 bytes from disk)
[22:22:34] Connecting to http://128.143.231.201:8080/
[22:25:44] - Couldn't send HTTP request to server
[22:25:44] + Could not connect to Work Server (results)
[22:25:44]     (128.143.231.201:8080)
[22:25:44] + Retrying using alternative port
[22:25:44] Connecting to http://128.143.231.201:80/
[22:28:53] - Couldn't send HTTP request to server
[22:28:53] + Could not connect to Work Server (results)
[22:28:53]     (128.143.231.201:80)
[22:28:53] - Error: Could not transmit unit 00 (completed January 27) to work server.
[22:28:53] - 3 failed uploads of this unit.
[22:28:53] + Attempting to send results [January 27 22:28:53 UTC]
[22:28:53] - Reading file work/wuresults_00.dat from core
[22:28:53]   (Read 91519344 bytes from disk)
[22:28:53] Connecting to http://128.143.199.97:8080/
[22:32:03] - Couldn't send HTTP request to server
[22:32:03] + Could not connect to Work Server (results)
[22:32:03]     (128.143.199.97:8080)
[22:32:03] + Retrying using alternative port
[22:32:03] Connecting to http://128.143.199.97:80/
[22:35:12] - Couldn't send HTTP request to server
[22:35:12] + Could not connect to Work Server (results)
[22:35:12]     (128.143.199.97:80)
[22:35:12]   Could not transmit unit 00 to Collection server; keeping in queue.
[22:35:12] Project: 8101 (Run 1, Clone 3, Gen 181)
[22:35:12] + Attempting to send results [January 27 22:35:12 UTC]
[22:35:12] - Reading file work/wuresults_00.dat from core
[22:35:12]   (Read 91519344 bytes from disk)
[22:35:12] Connecting to http://128.143.231.201:8080/
Trying the address yielded a connection issue, and server status page says full but accepting
I also can not download anything either
bollix47
Re: 128.143.231.201:8080/
Post by bollix47 »
Trying 128.143.231.201 in my browser results in a blank page which means the server is working okay. Full and Accepting are correct and indicate the server is both assigning and receiving. There's no indication the server is experiencing a problem that I can see. Have you tried re-booting your computer and router to make sure your communications is totally reset?
patonb
Post by patonb »
Yha after an hour of trying it just suddenly now downloaded and seems to be uploading too.
I had rebooted 2 machines and tried both with same results.. But as it's now oing through..... It's got me.
rhavern
Post by rhavern »
I too have been having problems connecting to this server. I have rebooted to no avail.
Folding since 1 WU=1 point
kasson
Pande Group Member
Post by kasson »
Thanks--we'll keep an eye on things. From everything we can tell, the server is behaving normally.
If you are having problems, does a traceroute yield anything strange?
kasson
Pande Group Member
Post by kasson »
PS the University of Virginia *backup* internet connection was down yesterday afternoon from 4:30 - 7:10pm EST. The primary connection was fine during that time. However, if there were some stale routes, etc. you might have seen problems.
patonb
Post by patonb »
That explains a lot, my unit started uploading at 4:15 est and just chugged for a while, then ran into issuse till my post above at 7:09 est.
I didn't trace route it, but i had ping'd it, and was getting over 100ms per ping, and it usuallys under 20ms
