Project: 3051 (Run 4, Clone 62, Gen 8) Repeated EUEs at 65%
Lexs
Post by Lexs »
I got Project 3051 (Run 4, Clone 62, Gen 8) EUE at 65% for quite some time now, and already changed from Windows 5.91beta6 to 5.92beta with Deino already, but it doesn't get better, still EUE at 65%.
Deleting the unit and/or workfiles doesn't help either as I always get the exactly same WU re-assigned.
Please help ! I'm pausing folding on SMP for now as I can't get an other WU.
[10:36:08] Core required: FahCore_a1.exe
[10:36:08] Core found.
[10:36:08] Working on Unit 07 [April 24 10:36:08]
[10:36:08] + Working ...
[10:36:09]
[10:36:09] *------------------------------*
[10:36:09] Folding@Home Gromacs SMP Core
[10:36:09] Version 1.76 (February 23, 2008)
[10:36:09]
[10:36:09] Preparing to commence simulation
[10:36:09] - Ensuring status. Please wait.
[10:36:26] - Looking at optimizations...
[10:36:26] - Working with standard loops on this execution.
[10:36:26] - Created dyn
[10:36:26] - Files status OK
[10:36:26] as improper.
[10:36:26] - Expanded 283541 -> 1506425 (decompressed 531.2 percent)
[10:36:26] - Failed to delete work/wudata_07.bed
[10:36:26] Warning:Entering M.D.
[10:36:26] ray files
[10:36:26] - Starting from initial work packet
[10:36:26]
[10:36:26] Project: 3051 (Run 4, Clone 62, Gen 8)
[10:36:26]
[10:36:26] Entering M.D.
[10:36:26] ta_07.pdo
[10:36:26] - Failed to delete work/wudata_07.xvg
[10:36:26] Warning: check for stray files
[10:36:26]
[10:36:26]
[10:36:33] Rejecting checkpoint
[10:36:33] Protein: 9675 p3029_SMP-emsv-03
[10:36:33] Writing local files
[10:36:33] Extra SSE boost OK.
[10:36:33] Completed 0 out of 10000000 steps (0 percent)
[03:50:47] Writing local files
[03:50:47] Completed 6500000 out of 10000000 steps (65 percent)
[03:59:49] Warning: long 1-4 interactions
[03:59:49] Gromacs cannot continue further.
[03:59:49] Going to send back what have done.
[03:59:49] logfile size: 171724
[03:59:49] - Writing 172260 bytes of core data to disk...
[03:59:49] ... Done.
[03:59:49] - Failed to delete work/wudata_07.sas
[03:59:49] - Failed to delete work/wudata_07.goe
[03:59:49] Warning: check for stray files
[04:01:49]
[04:01:49] Folding@home Core Shutdown: EARLY_UNIT_END
[04:01:49]
[04:01:53] CoreStatus = 63 (99)
[04:01:53] + Error starting Folding@Home core or unexpected system termination of core.
[04:01:53] - Attempting to download new core...
[04:01:53] + Downloading new core: FahCore_a1.exe
Re: Project: 3051 (Run 4, Clone 62, Gen 8) Repeated EUEs at 65%
If you didn't do it yet, you might want to submit partial result with qfix : viewtopic.php?f=8&t=191 ;)
