missing credit for WU on 171.64.65.63 [p3064]
Locked
matte.2
Post by matte.2 »
Hi,
I seem to be missing the credits for a 3064 WU (Project: 3064 (Run 1, Clone 387, Gen 3))
Due to the recent stats-server issues I'm not 100% sure it's this one but I think it is because I got a weird message on sending it.
After 2 failed attempts to send it to 171.64.65.63 it was sent to http://171.64.122.76:8080/ and gave following message
[17:53:23] - Core type used on unit not what server demands.
[17:53:23] Successfully sent unit 08 to Collection server.
[17:53:23] + Sent 1 of 1 completed units to the server
thank's for checking
Marc
PS hereunder the FAHlog.txt from which I removed duplicate lines,
[07:57:03] + Attempting to send results
[07:57:03] - Reading file work/wuresults_07.dat from core
[07:57:03]   (Read 1860179 bytes from disk)
[07:57:03] Connecting to http://171.64.65.63:8080/
[07:57:47] Posted data.
[07:57:47] Initial: 0000; - Uploaded at ~40 kB/s
[07:57:48] - Averaged speed for that direction ~41 kB/s
[07:57:48] + Results successfully sent
[07:57:48] Thank you for your contribution to Folding@Home.
[07:57:48] + Number of Units Completed: 58
[08:00:08] - Warning: Could not delete all work unit files (7): Core returned invalid code
[08:00:08] Trying to send all finished work units
[08:00:08] + No unsent completed units remaining.
[08:00:08] - Preparing to get new work unit...
[08:00:08] + Attempting to get work packet
[08:00:08] - Will indicate memory of 2047 MB
[08:00:08] - Connecting to assignment server
[08:00:08] Connecting to http://assign.stanford.edu:8080/
[08:00:08] Posted data.
[08:00:08] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[08:00:08] + News From Folding@Home: Welcome to Folding@Home
[08:00:08] Loaded queue successfully.
[08:00:08] Connecting to http://171.64.65.63:8080/
[08:00:10] Posted data.
[08:00:10] Initial: 0000; - Receiving payload (expected size: 608920)
[08:00:17] - Downloaded at ~84 kB/s
[08:00:17] - Averaged speed for that direction ~218 kB/s
[08:00:17] + Received work.
[08:00:17] Trying to send all finished work units
[08:00:17] + No unsent completed units remaining.
[08:00:17] + Closed connections
[08:00:17]
[08:00:17] + Processing work unit
[08:00:17] Core required: FahCore_a1.exe
[08:00:17] Core found.
[08:00:17] Working on Unit 08 [April 25 08:00:17]
[08:00:17] + Working ...
[08:00:17] - Calling 'mpiexec -channel auto -np 4 FahCore_a1.exe -dir work/ -suffix 08 -checkpoint 10 -forceasm -verbose -lifeline 312 -version 591'
[08:00:17]
[08:00:17] *------------------------------*
[08:00:17] Folding@Home Gromacs SMP Core
[08:00:17] Version 1.74 (March 10, 2007)
[08:00:17]
[08:00:17] Preparing to commence simulation
[08:00:17] - Ensuring status. Please wait.
[08:00:34] - Assembly optimizations manually forced on.
[08:00:34] - Not checking prior termination.
[08:00:34] - Expanded 608408 -> 3266341 (decompressed 536.8 percent)
[08:00:34] - Starting from initial work packet
[08:00:34]
[08:00:34] Project: 3064 (Run 1, Clone 387, Gen 3)
[08:00:34]
[08:00:34] Assembly optimizations on if available.
[08:00:34] Entering M.D.
[08:00:41] Protein: p3064_lambdaProteinWriting local files
[08:00:41]
[08:00:41] xtra SSE boost OK.
[08:00:41]
[08:00:41] Extra SSE boost OK.
[08:00:41] Writing local files
[08:00:41] Completed 0 out of 5000000 steps  (0 percent)
[08:11:35] Timered checkpoint triggered.
[08:20:10] Writing local files
[08:20:10] Completed 50000 out of 5000000 steps  (1 percent)
[08:30:11] Timered checkpoint triggered.
[08:40:10] Timered checkpoint triggered.
[08:40:22] Writing local files
[23:54:39] Completed 2350000 out of 5000000 steps  (47 percent)
[00:04:39] Timered checkpoint triggered.
[00:14:39] Timered checkpoint triggered.
[00:14:52] Writing local files
[00:14:52] Completed 2400000 out of 5000000 steps  (48 percent)
[17:48:50] Completed 5000000 out of 5000000 steps  (100 percent)
[17:48:50] Writing final coordinates.
[17:48:50] Past main M.D. loop
[17:48:50] Will end MPI now
[17:49:50]
[17:49:50] Finished Work Unit:
[17:49:50] - Reading up to 518424 from "work/wudata_08.arc": Read 518424
[17:49:50] - Reading up to 969496 from "work/wudata_08.xtc": Read 969496
[17:49:50] goefile size: 0
[17:49:50] logfile size: 140918
[17:49:50] Leaving Run
[17:49:55] - Writing 1829882 bytes of core data to disk...
[17:49:55]   ... Done.
[17:49:55] - Failed to delete work/wudata_08.sas
[17:49:55] - Failed to delete work/wudata_08.goe
[17:49:55] Warning:  check for stray files
[17:49:55] - Shutting down core
[17:51:55]
[17:51:55] Folding@home Core Shutdown: FINISHED_UNIT
[17:51:55]
[17:51:58] CoreStatus = 64 (100)
[17:51:58] Unit 8 finished with 61 percent of time to deadline remaining.
[17:51:58] Updated performance fraction: 0.662374
[17:51:58] Sending work to server
[17:51:58] + Attempting to send results
[17:51:58] - Reading file work/wuresults_08.dat from core
[17:51:58]   (Read 1829882 bytes from disk)
[17:51:58] Connecting to http://171.64.65.63:8080/
[17:52:19] - Couldn't send HTTP request to server
[17:52:19] + Could not connect to Work Server (results)
[17:52:19]     (171.64.65.63:8080)
[17:52:19] - Error: Could not transmit unit 08 (completed April 26) to work server.
[17:52:19] - 1 failed uploads of this unit.
[17:52:19]   Keeping unit 08 in queue.
[17:52:19] Trying to send all finished work units
[17:52:19] + Attempting to send results
[17:52:19] - Reading file work/wuresults_08.dat from core
[17:52:19]   (Read 1829882 bytes from disk)
[17:52:19] Connecting to http://171.64.65.63:8080/
[17:52:40] - Couldn't send HTTP request to server
[17:52:40] + Could not connect to Work Server (results)
[17:52:40]     (171.64.65.63:8080)
[17:52:40] - Error: Could not transmit unit 08 (completed April 26) to work server.
[17:52:40] - 2 failed uploads of this unit.
[17:52:40] + Attempting to send results
[17:52:40] - Reading file work/wuresults_08.dat from core
[17:52:40]   (Read 1829882 bytes from disk)
[17:52:40] Connecting to http://171.64.122.76:8080/
[17:53:23] Posted data.
[17:53:23] Initial: 0000; - Uploaded at ~41 kB/s
[17:53:23] - Averaged speed for that direction ~41 kB/s
[17:53:23] - Preparing to get new work unit...
[17:53:23] + Attempting to get work packet
[17:53:23] - Will indicate memory of 2047 MB
[17:53:23] - Connecting to assignment server
edit : join config info
[settings]
username=Duffelcoat-minion-1480
team=53338
asknet=no
bigpackets=yes
machineid=2
local=58
[http]
active=no
host=localhost
port=8080
usereg=no
[core]
checkpoint=10
[clienttype]
type=3
Re: missing credit for WU on 171.64.65.63
Locked
