csystems wrote:I have a machine running ATI and NVidia cards. The ATI card is a FirePro 2460. Its not the most powerful, but is designed to run four displays. After installing the latest client, it found the card and assigned work unit to it, however the card will not finish the WU within the preferred or final deadline. perhaps the card/software should look at what the system estimate is and prevent a WU from being assigned if it won't complete on time?
Welcome to foldingofrorum.org, csystems.
There is some degree of assignment tailoring but not a lot. It works pretty well for SMP assignments which can be assigned based on the number of CPU-cores that you have but it's a lot harder with GPUs. In your case, as already has been noted, your AMD GPU is most likely not performing up to expectations because it is being starved for work. AMD had designed their drivers based on an assumption that there will always be a free CPU that can send/receive data between the GPU and main RAM and you're not operating it that way. As P5-133XL has suggested, changing SMP:8 to SMP:6 will reduce SMP performance somewhat (not as much as you might think) and increase the performance of your AMD GPU.
Depending on the relative speed of the GPU compared to your CPU, you may be better off (A) Running SMP:6 plus the GPU, or (B) Running SMP:8 and suspending folding on that GPU. As has been suggested, that choice is entirely up to you. (The drivers for NVidia GPUs don't have the same problem.) I don't fold on my Cedar since it only has 80 SPs but that might very well not apply to you, depending on your CPU.
Which version of Windows are you running? Which CPU do you have?
