Radeon 7950 not folding. No WUs or problem?
fredsat
Hardware configuration: i5-3570K ivy @ 4.5GHz
G.Skill RipJaws X 1600 stock
Windows 7 Ultimate
Sapphire HD7950 @ 1150/1500 stable clocks
Post by fredsat »
Hey all,
thanks for your attention. I have been folding a few days now, but I have never managed to have my GPU card fold anything. It seems like it has been recognized by the client, and I've tried different drivers (12.10, 12.11...) always using atiman between an install and the other. I've also tried to run it at stock clocks, but nothing. I can post my latest session log, which seems to show no WU is available for my GPU :( .
I just wanted to make sure that there's no issue with my card or drivers. I am aware of the fact that it might be just that no WU has been created. But before I sit back and wait I want to make sure I did everything I could!
Thank you...
*********************** Log Started 2013-01-17T04:14:37Z ***********************
04:14:37:************************* Folding@home Client *************************
04:14:37:      Website: http://folding.stanford.edu/
04:14:37:    Copyright: (c) 2009-2012 Stanford University
04:14:37:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:14:37:         Args: --lifeline 4196 --command-port=36330
04:14:37:       Config: E:/Users/*******/AppData/Roaming/FAHClient/config.xml
04:14:37:******************************** Build ********************************
04:14:37:      Version: 7.2.9
04:14:37:         Date: Oct 3 2012
04:14:37:         Time: 18:05:48
04:14:37:      SVN Rev: 3578
04:14:37:       Branch: fah/trunk/client
04:14:37:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:14:37:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:14:37:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
04:14:37:     Platform: win32 XP
04:14:37:         Bits: 32
04:14:37:         Mode: Release
04:14:37:******************************* System ********************************
04:14:37:          CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
04:14:37:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:14:37:         CPUs: 4
04:14:37:       Memory: 7.89GiB
04:14:37:  Free Memory: 5.74GiB
04:14:37:      Threads: WINDOWS_THREADS
04:14:37:   On Battery: false
04:14:37:   UTC offset: -6
04:14:37:          PID: 3316
04:14:37:          CWD:********************************************
04:14:37:           OS: Windows 7 Ultimate
04:14:37:      OS Arch: AMD64
04:14:37:         GPUs: 1
04:14:37:        GPU 0: ATI:4 Tahiti PRO [Radeon HD 7950]
04:14:37:         CUDA: Not detected
04:14:37:Win32 Service: false
04:14:37:***********************************************************************
04:14:37:<config>
04:14:37:  <!-- Folding Slot Configuration -->
04:14:37:  <cause-pref v='**************'/>
04:14:37:  <gpu v='true'/>
04:14:37:
04:14:37:  <!-- Network -->
04:14:37:  <proxy v=':8080'/>
04:14:37:
04:14:37:  <!-- User Information -->
04:14:37:  <team v='46729'/>
04:14:37:  <user v='***************/>
04:14:37:
04:14:37:  <!-- Folding Slots -->
04:14:37:  <slot id='1' type='SMP'/>
04:14:37:  <slot id='0' type='GPU'/>
04:14:37:</config>
04:14:37:Trying to access database...
04:14:37:Successfully acquired database lock
04:14:37:Enabled folding slot 01: READY smp:4
04:14:37:Enabled folding slot 00: READY gpu:0:"Tahiti PRO [Radeon HD 7950]"
04:14:37:WU00:FS01:Starting
04:14:37:WU00:FS01:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/Users/*********/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 702 -lifeline 3316 -checkpoint 15 -np 4
04:14:37:WU00:FS01:Started FahCore on PID 5680
04:14:37:WU00:FS01:Core PID:4992
04:14:37:WU00:FS01:FahCore 0xa4 started
04:14:37:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:14:38:WU01:FS00:News: Welcome to Folding@Home
04:14:38:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:14:38:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:14:38:WU00:FS01:0xa4:
04:14:38:WU00:FS01:0xa4:*------------------------------*
04:14:38:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
04:14:38:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:14:38:WU00:FS01:0xa4:Preparing to commence simulation
04:14:38:WU00:FS01:0xa4:- Looking at optimizations...
04:14:38:WU00:FS01:0xa4:- Files status OK
04:14:38:WU00:FS01:0xa4:- Expanded 525178 -> 1190624 (decompressed 226.7 percent)
04:14:38:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=525178 data_size=1190624, decompressed_data_size=1190624 diff=0
04:14:38:WU00:FS01:0xa4:- Digital signature verified
04:14:38:WU00:FS01:0xa4:Project: 8028 (Run 1684, Clone 4, Gen 9)
04:14:38:WU00:FS01:0xa4:Assembly optimizations on if available.
04:14:38:WU00:FS01:0xa4:Entering M.D.
04:14:38:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:14:38:ERROR:WU01:FS00:Exception: Could not get an assignment
04:14:39:WU01:FS00:News: Welcome to Folding@Home
04:14:39:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:14:39:ERROR:WU01:FS00:Exception: Could not get an assignment
04:14:41:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
04:14:43:WU00:FS01:0xa4:Using Gromacs checkpoints
04:14:43:WU00:FS01:0xa4:Mapping NT from 4 to 4
04:14:43:WU00:FS01:0xa4:Resuming from checkpoint
04:14:43:WU00:FS01:0xa4:Verified 00/wudata_01.log
04:14:43:WU00:FS01:0xa4:Verified 00/wudata_01.trr
04:14:43:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
04:14:43:WU00:FS01:0xa4:Verified 00/wudata_01.edr
04:14:43:WU00:FS01:0xa4:Completed 162300 out of 500000 steps  (32%)
04:15:28:WU00:FS01:0xa4:Completed 165000 out of 500000 steps  (33%)
04:15:38:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:15:39:WU01:FS00:News: Welcome to Folding@Home
04:15:39:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:15:39:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:15:39:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:15:39:ERROR:WU01:FS00:Exception: Could not get an assignment
04:16:59:WU00:FS01:0xa4:Completed 170000 out of 500000 steps  (34%)
04:17:15:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:17:16:WU01:FS00:News: Welcome to Folding@Home
04:17:16:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:17:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:17:16:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:17:16:ERROR:WU01:FS00:Exception: Could not get an assignment
04:18:21:WU00:FS01:0xa4:Completed 175000 out of 500000 steps  (35%)
04:19:44:WU00:FS01:0xa4:Completed 180000 out of 500000 steps  (36%)
04:19:53:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:19:53:WU01:FS00:News: Welcome to Folding@Home
04:19:53:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:19:53:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:19:53:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:19:53:ERROR:WU01:FS00:Exception: Could not get an assignment
04:21:10:WU00:FS01:0xa4:Completed 185000 out of 500000 steps  (37%)
04:22:34:WU00:FS01:0xa4:Completed 190000 out of 500000 steps  (38%)
04:23:56:WU00:FS01:0xa4:Completed 195000 out of 500000 steps  (39%)
04:24:07:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:24:07:WU01:FS00:News: Welcome to Folding@Home
04:24:07:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:24:07:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:24:08:WU01:FS00:News: Welcome to Folding@Home
04:24:08:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:24:08:ERROR:WU01:FS00:Exception: Could not get an assignment
04:25:19:WU00:FS01:0xa4:Completed 200000 out of 500000 steps  (40%)
04:26:41:WU00:FS01:0xa4:Completed 205000 out of 500000 steps  (41%)
Re: Radeon 7950 not folding. No WUs or problem?
There are several things going on that could be keeping you from getting WU's for the 7950 over the past few days. But you will have to wait to see if any changes you make will get you a WU, the work server that had work for the ATI cards went down earlier today. See this topic.
As to why the card was not getting work, I am not certain. From the log it is recognized as being on the supported list. But it is possible that no work is currently set to be assigned to it. As for drivers, the latest known to be stable for folding is 12.8. Persons have managed to get installs of later versions to fold, but some extra work is required. One topic where this has been discussed is 12.10-12.11 Drivers. There are some other topics that have discussed this issue, the mentioned topic has links to some workarounds. But to see whether you need to use them, first you have to get a WU assigned and see if it works or not.
One other issue to go over is that the folding core for ATI GPU's uses up to a full core of your CPU to move data in and out of the GPU. So if you do keep folding on your 7950, you should adjust the SMP setting for that slot. Change the SMP setting from -1, the default which uses all cores available, to 3 or 2. 3 is one exception to the message in FAHControl of setting the number to an even number.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
If you care about points, you might consider getting a passkey
fredsat
Windows 7 Ultimate
Post by fredsat »
Hey,
thank you for the prompt answer. I've followed your advice: I put the core usage on the SMP at 3, restarted the client and it finally started to download the task again, although it was not folding. I have then read the indications found here and followed these steps:
1 - I ran two passes (just to be sure), of ATIMan logging as Administrator.
2 - Installed an unofficial 12.11 version of catalyst that uses the 12.8 version of WHQL, found here. I know it's unofficial and installed it at my own risk. It is not the one indicated on the forum page I've posted, but it works.
3 - Installed CAP_2.
4 - Opened F@H Control and now my GPU usage is 99±1%. Also, my PPD is now, after 10 min or so at 27065 instead of 14-15000.
I don't necessarily suggest that AMD users do the same. It worked on my rig though. My configuration is the following:
AsRock Z77-Extreme6
i5-3570K @ 4.5GHz
8GB Ripjaws X 1600
Windows 7 Ultimate
Sapphire HD7950 currently set to 1150/1500 and running great
I will keep using these modified drivers until F@H optimizes the client/WU's to the new ATI drivers (12.11 is still beta). I have no tested them yet on games and other programs. If any issue arises I will post it here.
Thanks again! :D
P.S: got myself a password, thanks for the advice!
