171.67.108.44 - Unable to connect to turn work units in
hornsfan01
Post by hornsfan01 »
I am getting the following errors in my logfile:
*********************** Log Started 2013-01-17T01:51:57Z ***********************
01:52:02:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:52:02:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:52:02:ERROR:WU02:FS00:Exception: Could not get an assignment
01:52:20:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:52:41:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:53:02:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:53:02:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:53:02:ERROR:WU02:FS00:Exception: Could not get an assignment
01:53:03:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:53:24:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:54:03:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:54:24:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:54:39:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:54:40:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:54:40:ERROR:WU02:FS00:Exception: Could not get an assignment
01:55:40:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:56:01:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
01:57:17:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:57:17:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:57:17:ERROR:WU02:FS00:Exception: Could not get an assignment
01:58:17:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:58:38:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:01:31:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:01:31:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:01:31:ERROR:WU02:FS00:Exception: Could not get an assignment
02:02:32:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:02:53:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:08:22:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:08:22:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:08:22:ERROR:WU02:FS00:Exception: Could not get an assignment
02:09:23:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:09:44:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:19:28:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:19:28:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:19:28:ERROR:WU02:FS00:Exception: Could not get an assignment
02:20:29:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
02:20:50:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
(I don't know how to include all that in a scrollable window so I pasted it in a quote.)
I have a work unit that says 100% ready to send but it has failed to send on 7 consecutive attempts. Slot 01 is folding. Slot 02 is stuck on "Download 0.0%"
I've been folding for about 2 months and haven't run into this before. Any suggestions? Let me know if further information would be helpful.
Re: Unable to connect to server to turn work units in
Replace [quote] ... [/quote] with [code] ... [/code].
Go to http://fah-web.stanford.edu/pybeta/serverstat.html and observe that 171.67.108.44 is DOWN. (Somebody at Stanford needs to restart the server or something like that.) All you can do is to be patient.
Ordinarily when a Work Server is down, there's a backup server called a Collection Server that can accept the upload. I need to figure out why that's not working for you. It might be a server configuration issue or a client bug.
Kornflake
Post by Kornflake »
I can report the same issue and the collection server is not collecting my WU either.
mmonnin
Post by mmonnin »
Same here for past hour or so. AMD GPU is stuck doing nothing.
DeeGee
Hardware configuration: Asus Crosshair Hero VIII, AMD Ryzen 3950x, 2x8GB 3600MHz DDR4, Radeon VII, Win10
Asus Crosshair Hero VII, Amd Ryzen 3900x, 2x16GB 3200MHz DDR4, GeForce 980 TI, Kubuntu 19.10
Post by DeeGee »
Yup, something seems to be broken:
01:09:50:WU01:FS00:0x16:Completed  47000000 out of 50000000 steps (94%).
01:13:03:WU01:FS00:0x16:Completed  47500000 out of 50000000 steps (95%).
01:13:04:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:13:08:WU00:FS00:News: Welcome to Folding@Home
01:13:08:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:13:08:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:13:08:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:13:08:ERROR:WU00:FS00:Exception: Could not get an assignment
01:13:09:WU00:FS00:News: Welcome to Folding@Home
01:13:09:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:13:09:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:13:09:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:13:09:ERROR:WU00:FS00:Exception: Could not get an assignment
01:13:44:WU02:FS01:0xa4:Completed 160000 out of 2000000 steps  (8%)
01:14:08:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:14:12:WU00:FS00:News: Welcome to Folding@Home
01:14:12:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:14:12:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:14:12:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:14:12:ERROR:WU00:FS00:Exception: Could not get an assignment
01:15:45:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:15:46:WU00:FS00:News: Welcome to Folding@Home
01:15:46:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:15:46:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:15:46:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:15:46:ERROR:WU00:FS00:Exception: Could not get an assignment
01:16:16:WU01:FS00:0x16:Completed  48000000 out of 50000000 steps (96%).
01:18:23:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:18:23:WU00:FS00:News: Welcome to Folding@Home
01:18:23:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:18:23:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:18:23:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:18:23:ERROR:WU00:FS00:Exception: Could not get an assignment
01:19:25:WU02:FS01:0xa4:Completed 180000 out of 2000000 steps  (9%)
01:19:28:WU01:FS00:0x16:Completed  48500000 out of 50000000 steps (97%).
01:22:37:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:22:40:WU00:FS00:News: Welcome to Folding@Home
01:22:40:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:22:40:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:22:41:WU00:FS00:News: Welcome to Folding@Home
01:22:41:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:22:41:ERROR:WU00:FS00:Exception: Could not get an assignment
01:22:41:WU01:FS00:0x16:Completed  49000000 out of 50000000 steps (98%).
01:25:06:WU02:FS01:0xa4:Completed 200000 out of 2000000 steps  (10%)
01:25:54:WU01:FS00:0x16:Completed  49500000 out of 50000000 steps (99%).
01:29:07:WU01:FS00:0x16:Completed  50000000 out of 50000000 steps (100%).
01:29:25:WU01:FS00:0x16:Finished fah_main
01:29:25:WU01:FS00:0x16:Successful run
01:29:25:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
01:29:28:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:29:29:WU00:FS00:News: Welcome to Folding@Home
01:29:29:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:29:29:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:29:29:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:29:29:ERROR:WU00:FS00:Exception: Could not get an assignment
01:29:35:WU01:FS00:0x16:Reserved 2446576 bytes for xtc file; Cosm status=0
01:29:35:WU01:FS00:0x16:Allocated 2446576 bytes for xtc file
01:29:35:WU01:FS00:0x16:- Reading up to 2446576 from "01/wudata_01.xtc": Read 2446576
01:29:35:WU01:FS00:0x16:Read 2446576 bytes from xtc file; available packet space=783983888
01:29:35:WU01:FS00:0x16:xtc file hash check passed.
01:29:35:WU01:FS00:0x16:Reserved 75840 75840 783983888 bytes for arc file=<01/wudata_01.trr> Cosm status=0
01:29:35:WU01:FS00:0x16:Allocated 75840 bytes for arc file
01:29:35:WU01:FS00:0x16:- Reading up to 75840 from "01/wudata_01.trr": Read 75840
01:29:35:WU01:FS00:0x16:Read 75840 bytes from arc file; available packet space=783908048
01:29:35:WU01:FS00:0x16:trr file hash check passed.
01:29:35:WU01:FS00:0x16:Allocated 544 bytes for edr file
01:29:35:WU01:FS00:0x16:Read bedfile
01:29:35:WU01:FS00:0x16:edr file hash check passed.
01:29:35:WU01:FS00:0x16:Allocated 120007 bytes for logfile
01:29:35:WU01:FS00:0x16:Read logfile
01:29:35:WU01:FS00:0x16:GuardedRun: success in DynamicWrapper
01:29:35:WU01:FS00:0x16:GuardedRun: done
01:29:35:WU01:FS00:0x16:Run: GuardedRun completed.
01:29:37:WU01:FS00:0x16:+ Opened results file
01:29:37:WU01:FS00:0x16:- Writing 2643479 bytes of core data to disk...
01:29:38:WU01:FS00:0x16:Done: 2642967 -> 2488277 (compressed to 94.1 percent)
01:29:38:WU01:FS00:0x16:  ... Done.
01:29:38:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
01:29:38:WU01:FS00:0x16:Shutting down core
01:29:38:WU01:FS00:0x16:Folding@home Core Shutdown: FINISHED_UNIT
01:29:39:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:29:39:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
01:29:39:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
01:29:39:WU01:FS00:Connecting to 171.67.108.44:8080
01:30:21:WU01:FS00:Upload 2.63%
01:30:21:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
01:30:21:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
01:30:21:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
01:30:21:WU01:FS00:Connecting to 171.67.108.44:8080
01:30:48:WU02:FS01:0xa4:Completed 220000 out of 2000000 steps  (11%)
01:31:03:WU01:FS00:Upload 2.63%
01:31:03:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
01:31:21:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
01:31:21:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
01:31:21:WU01:FS00:Connecting to 171.67.108.44:8080
01:32:03:WU01:FS00:Upload 2.63%
01:32:03:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
01:32:58:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
01:32:58:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
01:32:58:WU01:FS00:Connecting to 171.67.108.44:8080
01:33:40:WU01:FS00:Upload 2.63%
01:33:40:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
01:35:35:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
01:35:35:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
01:35:35:WU01:FS00:Connecting to 171.67.108.44:8080
01:36:17:WU01:FS00:Upload 2.63%
01:36:17:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
01:36:32:WU02:FS01:0xa4:Completed 240000 out of 2000000 steps  (12%)
01:39:50:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
01:39:50:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
01:39:50:WU01:FS00:Connecting to 171.67.108.44:8080
01:40:32:WU01:FS00:Upload 2.63%
01:40:32:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
01:40:34:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:40:38:WU00:FS00:News: Welcome to Folding@Home
01:40:38:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:40:38:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:40:38:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:40:38:ERROR:WU00:FS00:Exception: Could not get an assignment
01:42:15:WU02:FS01:0xa4:Completed 260000 out of 2000000 steps  (13%)
01:46:41:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
01:46:41:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
01:46:41:WU01:FS00:Connecting to 171.67.108.44:8080
01:47:23:WU01:FS00:Upload 2.63%
01:47:23:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
01:47:57:WU02:FS01:0xa4:Completed 280000 out of 2000000 steps  (14%)
01:53:40:WU02:FS01:0xa4:Completed 300000 out of 2000000 steps  (15%)
01:57:47:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
01:57:47:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
01:57:47:WU01:FS00:Connecting to 171.67.108.44:8080
01:58:29:WU01:FS00:Upload 2.63%
01:58:29:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
01:58:31:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
01:58:31:WU00:FS00:News: Welcome to Folding@Home
01:58:31:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
01:58:31:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
01:58:32:WU00:FS00:News: Welcome to Folding@Home
01:58:32:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
01:58:32:ERROR:WU00:FS00:Exception: Could not get an assignment
01:59:23:WU02:FS01:0xa4:Completed 320000 out of 2000000 steps  (16%)
02:05:06:WU02:FS01:0xa4:Completed 340000 out of 2000000 steps  (17%)
02:10:49:WU02:FS01:0xa4:Completed 360000 out of 2000000 steps  (18%)
02:15:43:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
02:15:43:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
02:15:43:WU01:FS00:Connecting to 171.67.108.44:8080
02:16:25:WU01:FS00:Upload 2.63%
02:16:25:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
02:16:31:WU02:FS01:0xa4:Completed 380000 out of 2000000 steps  (19%)
02:22:12:WU02:FS01:0xa4:Completed 400000 out of 2000000 steps  (20%)
02:27:33:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:27:33:WU00:FS00:News: Welcome to Folding@Home
02:27:33:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
02:27:33:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
02:27:34:WU00:FS00:News: Welcome to Folding@Home
02:27:34:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
02:27:34:ERROR:WU00:FS00:Exception: Could not get an assignment
02:27:53:WU02:FS01:0xa4:Completed 420000 out of 2000000 steps  (21%)
02:33:36:WU02:FS01:0xa4:Completed 440000 out of 2000000 steps  (22%)
******************************** Date: 17/01/13 ********************************
02:39:20:WU02:FS01:0xa4:Completed 460000 out of 2000000 steps  (23%)
02:44:45:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
02:44:45:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
02:44:45:WU01:FS00:Connecting to 171.67.108.44:8080
02:45:05:WU02:FS01:0xa4:Completed 480000 out of 2000000 steps  (24%)
02:45:27:WU01:FS00:Upload 2.63%
02:45:27:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
02:50:51:WU02:FS01:0xa4:Completed 500000 out of 2000000 steps  (25%)
02:56:37:WU02:FS01:0xa4:Completed 520000 out of 2000000 steps  (26%)
03:02:22:WU02:FS01:0xa4:Completed 540000 out of 2000000 steps  (27%)
03:08:07:WU02:FS01:0xa4:Completed 560000 out of 2000000 steps  (28%)
03:13:49:WU02:FS01:0xa4:Completed 580000 out of 2000000 steps  (29%)
03:14:32:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:14:32:WU00:FS00:News: Welcome to Folding@Home
03:14:32:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
03:14:32:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
03:14:33:WU00:FS00:News: Welcome to Folding@Home
03:14:33:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
03:14:33:ERROR:WU00:FS00:Exception: Could not get an assignment
03:19:31:WU02:FS01:0xa4:Completed 600000 out of 2000000 steps  (30%)
03:25:13:WU02:FS01:0xa4:Completed 620000 out of 2000000 steps  (31%)
03:30:56:WU02:FS01:0xa4:Completed 640000 out of 2000000 steps  (32%)
03:31:44:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
03:31:44:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
03:31:44:WU01:FS00:Connecting to 171.67.108.44:8080
03:32:26:WU01:FS00:Upload 2.63%
03:32:26:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
03:36:38:WU02:FS01:0xa4:Completed 660000 out of 2000000 steps  (33%)
03:42:20:WU02:FS01:0xa4:Completed 680000 out of 2000000 steps  (34%)
03:48:02:WU02:FS01:0xa4:Completed 700000 out of 2000000 steps  (35%)
03:53:44:WU02:FS01:0xa4:Completed 720000 out of 2000000 steps  (36%)
03:59:28:WU02:FS01:0xa4:Completed 740000 out of 2000000 steps  (37%)
04:05:13:WU02:FS01:0xa4:Completed 760000 out of 2000000 steps  (38%)
04:10:55:WU02:FS01:0xa4:Completed 780000 out of 2000000 steps  (39%)
04:16:39:WU02:FS01:0xa4:Completed 800000 out of 2000000 steps  (40%)
04:22:23:WU02:FS01:0xa4:Completed 820000 out of 2000000 steps  (41%)
04:28:07:WU02:FS01:0xa4:Completed 840000 out of 2000000 steps  (42%)
04:30:32:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:30:33:WU00:FS00:News: Welcome to Folding@Home
04:30:33:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:30:33:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
04:30:33:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:30:33:ERROR:WU00:FS00:Exception: Could not get an assignment
04:33:53:WU02:FS01:0xa4:Completed 860000 out of 2000000 steps  (43%)
04:39:37:WU02:FS01:0xa4:Completed 880000 out of 2000000 steps  (44%)
04:45:21:WU02:FS01:0xa4:Completed 900000 out of 2000000 steps  (45%)
04:47:45:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:19 clone:10 gen:42 core:0x16 unit:0x000001246652edbc4d94b89f3c700de0
04:47:45:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
04:47:45:WU01:FS00:Connecting to 171.67.108.44:8080
04:48:27:WU01:FS00:Upload 2.63%
04:48:27:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
codysluder
Post by codysluder »
Kornflake wrote:I can report the same issue and the collection server is not collecting my WU either.
Does your long show a connection attempt to a CS? If so, what is the IP address?
If you're running V7, there should also be data at the bottom of the Work Unit panel on the right giving the IP addresses of the Work Server and the Collection Server. DeeGee's log doesn't show that information and it would be nice to know what serverstat says about that server.
DeeGee
Post by DeeGee »
The finished work unit server ip seems to be 171.67.108.44 and collection server ip is just zeroes? (0.0.0.0).
art_l_j_PlanetAMD64
Post by art_l_j_PlanetAMD64 »
DeeGee wrote:The finished work unit server ip seems to be 171.67.108.44 and collection server ip is just zeroes? (0.0.0.0).
A collection server of 0.0.0.0 just means "no separate collection server". The completed WU is sent back to the Work Server, and if that fails, it is retried after a delay. Having a CS is just a backup to the WS, normally all WUs are returned to the WS. (I had to ask about this myself here, that's how I knew the answer.)
Last edited by art_l_j_PlanetAMD64 on Thu Jan 17, 2013 11:14 am, edited 1 time in total.
art_l_j_PlanetAMD64
Over 1.04 Billion Total Points
Over 185,000 Work Units
Over 3,800,000 PPD
Overall rank (if points are combined) 20 of 1721690
In memory of my Mother May 12th 1923 - February 10th 2012
codysluder
bruce wrote:Ordinarily when a Work Server is down, there's a backup server called a Collection Server that can accept the upload. I need to figure out why that's not working for you. It might be a server configuration issue or a client bug.
@bruce:
We figured it out. No Collection Server was configured.
1337LutZ
Re: 171.67.108.44 - Unable to connect to turn work units in
Post by 1337LutZ »
As of tonight i also have this issue. It wont upload/download.
08:41:15:WU01:FS00:News: Welcome to Folding@Home
08:41:15:WU00:FS00:Uploading 2.37MiB to 171.67.108.44
08:41:15:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
08:41:15:WU00:FS00:Connecting to 171.67.108.44:8080
08:41:15:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:41:15:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
08:41:15:ERROR:WU01:FS00:Exception: Could not get an assignment
08:41:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:41:16:WU01:FS00:News: Welcome to Folding@Home
08:41:16:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
08:41:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:41:17:WU01:FS00:News: Welcome to Folding@Home
08:41:17:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
08:41:17:ERROR:WU01:FS00:Exception: Could not get an assignment
08:41:18:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
08:41:20:Server connection id=2 on 0.0.0.0:36330 from 25.173.86.123
08:41:36:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:41:36:WU00:FS00:Connecting to 171.67.108.44:80
08:41:46:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
08:41:54:Server connection id=4 on 0.0.0.0:36330 from 25.173.86.123
08:41:57:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.44:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:42:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11292 run:3 clone:67 gen:13 core:0x16 unit:0x000000326652edbc4d096da24bba5e58
08:42:15:WU00:FS00:Uploading 2.37MiB to 171.67.108.44
08:42:15:WU00:FS00:Connecting to 171.67.108.44:8080
08:42:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:42:16:WU01:FS00:News: Welcome to Folding@Home
08:42:16:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
08:42:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
08:42:17:WU01:FS00:News: Welcome to Folding@Home
08:42:17:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
08:42:17:ERROR:WU01:FS00:Exception: Could not get an assignment
Ripshod
Post by Ripshod »
managed to upload and it threw an error and dumped my results :(
09:26:26:FS01:Unpaused
09:26:26:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11292 run:9 clone:91 gen:10 core:0x16 unit:0x000000306652edbc4d096dbfe3996ab9
09:26:26:WARNING:WU00:FS01:Produced no results, failing
09:26:26:WARNING:WU00:FS01:Missing original Unit data, cannot send dump report
09:26:26:WU00:FS01:Cleaning up
Now it won't download a new one:
09:26:26:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
09:26:27:WU01:FS01:News: Welcome to Folding@Home
09:26:27:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:26:27:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
09:26:28:WU01:FS01:News: Welcome to Folding@Home
09:26:28:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:26:28:ERROR:WU01:FS01:Exception: Could not get an assignment
*********************** Log Started 2013-01-15T09:27:27Z ***********************
09:27:27:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:27:28:WU00:FS01:News: Welcome to Folding@Home
09:27:28:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:27:28:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:27:28:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:27:28:ERROR:WU00:FS01:Exception: Could not get an assignment
09:27:29:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:27:29:WU00:FS01:News: Welcome to Folding@Home
09:27:29:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:27:29:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:27:30:WU00:FS01:News: Welcome to Folding@Home
09:27:30:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:27:30:ERROR:WU00:FS01:Exception: Could not get an assignment
09:28:29:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:28:29:WU00:FS01:News: Welcome to Folding@Home
09:28:29:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:28:29:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:28:30:WU00:FS01:News: Welcome to Folding@Home
09:28:30:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:28:30:ERROR:WU00:FS01:Exception: Could not get an assignment
09:30:06:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:30:07:WU00:FS01:News: Welcome to Folding@Home
09:30:07:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:30:07:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:30:07:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:30:07:ERROR:WU00:FS01:Exception: Could not get an assignment
09:32:43:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:32:44:WU00:FS01:News: Welcome to Folding@Home
09:32:44:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:32:44:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:32:45:WU00:FS01:News: Welcome to Folding@Home
09:32:45:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:32:45:ERROR:WU00:FS01:Exception: Could not get an assignment
09:36:57:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:36:58:WU00:FS01:News: Welcome to Folding@Home
09:36:58:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:36:58:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:36:59:WU00:FS01:News: Welcome to Folding@Home
09:36:59:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:36:59:ERROR:WU00:FS01:Exception: Could not get an assignment
09:43:49:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:43:50:WU00:FS01:News: Welcome to Folding@Home
09:43:50:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:43:50:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:43:50:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:43:50:ERROR:WU00:FS01:Exception: Could not get an assignment
*********************** Log Started 2013-01-15T09:54:09Z ***********************
09:54:09:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:54:09:WU00:FS01:News: Welcome to Folding@Home
09:54:09:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:54:09:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:54:10:WU00:FS01:News: Welcome to Folding@Home
09:54:10:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:54:10:ERROR:WU00:FS01:Exception: Could not get an assignment
09:54:10:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:54:11:WU00:FS01:News: Welcome to Folding@Home
09:54:11:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:54:11:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:54:11:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:54:11:ERROR:WU00:FS01:Exception: Could not get an assignment
09:55:10:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:55:11:WU00:FS01:News: Welcome to Folding@Home
09:55:11:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:55:11:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:55:11:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:55:11:ERROR:WU00:FS01:Exception: Could not get an assignment
09:56:47:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:56:48:WU00:FS01:News: Welcome to Folding@Home
09:56:48:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:56:48:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:56:48:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:56:48:ERROR:WU00:FS01:Exception: Could not get an assignment
09:59:24:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
09:59:25:WU00:FS01:News: Welcome to Folding@Home
09:59:25:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:59:25:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
09:59:26:WU00:FS01:News: Welcome to Folding@Home
09:59:26:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:59:26:ERROR:WU00:FS01:Exception: Could not get an assignment
10:03:39:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:03:39:WU00:FS01:News: Welcome to Folding@Home
10:03:39:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:03:39:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:03:40:WU00:FS01:News: Welcome to Folding@Home
10:03:40:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:03:40:ERROR:WU00:FS01:Exception: Could not get an assignment
10:10:30:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:10:31:WU00:FS01:News: Welcome to Folding@Home
10:10:31:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:10:31:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:10:31:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:10:31:ERROR:WU00:FS01:Exception: Could not get an assignment
10:21:36:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:21:37:WU00:FS01:News: Welcome to Folding@Home
10:21:37:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:21:37:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:21:37:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:21:37:ERROR:WU00:FS01:Exception: Could not get an assignment
10:24:59:FS01:Paused
10:25:11:FS01:Unpaused
10:25:11:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:25:12:WU00:FS01:News: Welcome to Folding@Home
10:25:12:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:25:12:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:25:13:WU00:FS01:News: Welcome to Folding@Home
10:25:13:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:25:13:ERROR:WU00:FS01:Exception: Could not get an assignment
10:26:49:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:26:49:WU00:FS01:News: Welcome to Folding@Home
10:26:49:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:26:49:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:26:50:WU00:FS01:News: Welcome to Folding@Home
10:26:50:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:26:50:ERROR:WU00:FS01:Exception: Could not get an assignment
10:29:26:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:29:26:WU00:FS01:News: Welcome to Folding@Home
10:29:26:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:29:26:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:29:27:WU00:FS01:News: Welcome to Folding@Home
10:29:27:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:29:27:ERROR:WU00:FS01:Exception: Could not get an assignment
10:33:40:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:33:40:WU00:FS01:News: Welcome to Folding@Home
10:33:40:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:33:40:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:33:41:WU00:FS01:News: Welcome to Folding@Home
10:33:41:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:33:41:ERROR:WU00:FS01:Exception: Could not get an assignment
10:34:37:FS01:Paused
10:35:07:FS01:Unpaused
10:35:07:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:35:08:WU00:FS01:News: Welcome to Folding@Home
10:35:08:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:35:08:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:35:08:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:35:08:ERROR:WU00:FS01:Exception: Could not get an assignment
10:36:44:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:36:45:WU00:FS01:News: Welcome to Folding@Home
10:36:45:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:36:45:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:36:45:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:36:45:ERROR:WU00:FS01:Exception: Could not get an assignment
10:39:21:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:39:22:WU00:FS01:News: Welcome to Folding@Home
10:39:22:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:39:22:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:39:23:WU00:FS01:News: Welcome to Folding@Home
10:39:23:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:39:23:ERROR:WU00:FS01:Exception: Could not get an assignment
10:43:36:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:43:36:WU00:FS01:News: Welcome to Folding@Home
10:43:36:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:43:36:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:43:37:WU00:FS01:News: Welcome to Folding@Home
10:43:37:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:43:37:ERROR:WU00:FS01:Exception: Could not get an assignment
10:50:27:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
10:50:28:WU00:FS01:News: Welcome to Folding@Home
10:50:28:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:50:28:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
10:50:28:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:50:28:ERROR:WU00:FS01:Exception: Could not get an assignment
10:59:45:FS01:Paused
11:01:21:FS01:Unpaused
11:01:22:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
11:01:22:WU00:FS01:News: Welcome to Folding@Home
11:01:22:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:01:22:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
11:01:23:WU00:FS01:News: Welcome to Folding@Home
11:01:23:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:01:23:ERROR:WU00:FS01:Exception: Could not get an assignment
11:02:59:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
11:02:59:WU00:FS01:News: Welcome to Folding@Home
11:02:59:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:02:59:WU00:FS01:Connecting to assign-GPU.stanford.edu:8080
11:03:00:WU00:FS01:News: Welcome to Folding@Home
11:03:00:WARNING:WU00:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:03:00:ERROR:WU00:FS01:Exception: Could not get an assignment
1090T / HD5770 / HD7950
Brazos
Post by Brazos »
I can report that I'm having the same issue here.
The WS is back up since 11:30 PST according to the server status page, and appears to be accepting returns okay. Post if you are still experiencing any problems.
Ripshod wrote:managed to upload and it threw an error and dumped my results
Looking at that brief log extract, there is not enough information to say if the error was related to the WS being down. More of the log from before that point would be needed, but the error seems to be reporting a folding file connected to the finished WU missing from your system - not an upload error.
1337LutZ
Post by 1337LutZ »
Confirmed that the server is indeed back on track!
