Folding@Home Benchmark 1.2.0 (GUI)
- Pande Group Member
FAHBench is the official Folding@Home GPU benchmark that measures the compute performance of GPUs for Folding@Home:
Download Link -> http://fahbench.com
1.2.0 Updates:
-Updated to use OpenMM 5.1 with significantly faster speed
-Accuracy checking disabled by default on GUI (enabled by default on Command Line mode)
-Stress Test option to do a very large number of steps
1.1.2 Updates:
-Made the errors due to CUDA JIT compilation more descriptive
1.1.1 Updates:
-Added a stress test option (1 million steps)
-Now checks for NaNs at the end and only once every 50000 steps for stress test
-Added performance estimate to progress counter
1.0 Updates:
-Added FAHBench GUI
Mod Edit: Updated Post - PantherX
1.2.0 Updates:
1.1.2 Updates:
1.1.1 Updates:
1.0 Updates:
-Added FAHBench GUI
Re: Folding@Home Benchmark Beta Testing
Are you getting numerous downloads of this swamping your connection? Download speed on the 6MB file is only 15-25KB/s on my 12mbit connection...
The openmm link: http://proteneer.com/blog/openmm.org ends in an 404 error.
It was pretty fast for me. I updated the openmm link, thanks
Machine #2:
Machine 3:
For me, it just give an error on an x64 Win7 system with 2x GTX460's that fold correctly: "Error loading library c:\temp\FAHBench_0_1\OpenMMOpenCL.dll: 126"
- Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
For me the same error:
C:\FAH> FAHBench.exe -deviceId 0 -platform CUDA -precision single
Explicit:
Error loading library C:\FAH/OpenMMOpenCL.dll: 126
C:\FAH>
Win7/64 Pro; CPU - i5 2500K; GPU - GTX 650 Ti; NV Driver 306.97
Explicit:
C:\FAH>
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
The download was also slow for me, and I also ran into the same error:
I notice the forward slash instead of a backslash. Perhaps that's the problem?
System:
Also, your "Folding@Home" link to http://proteneer.com/blog/folding.stanford.edu is a 404.
Even though it didn't work, I do like the molecule artwork that you were able to draw in the command line.
C:\Users\Admin\Downloads\bench>FAHBench.exe -deviceId 0 -platform CUDA -precisio
n single
O O
P R O T E N E E R C--N \ \ N
| C C=O / \-C
C / | N-C \
.C-C C/ C C | C
/ \ O | | / N |
C C | | O C C /-C
\_N_/ \ N _C_ C | / O / C
C-/ \_C/ \N-/ \ N /-C-\ C | | O /
| | C-/ \C/ N-/ \_ N\ /C\ -C N | |
O | | | \C/ C/ N/ \_C__/ \ C-\ C
C O | | | | C-/ N/ \-C
\_C C O | O | |
\ \-O C C O
C N Folding@Home C--N C
\ | Benchmark (Beta) | |
N--C O |
\ Yutong Zhao C=O
N proteneer@gmail.com /
O
for official stats, please visit www.fahbench.com
Explicit:
Error loading library C:\Users\Admin\Downloads\bench/OpenMMOpenCL.dll: 126
System:
22:46:28:******************************* System ********************************
22:46:28: CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
22:46:28: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:46:28: CPUs: 8
22:46:28: Memory: 7.98GiB
22:46:28: Free Memory: 6.74GiB
22:46:28: Threads: WINDOWS_THREADS
22:46:28: On Battery: false
22:46:28: UTC offset: -7
22:46:28: PID: 3156
22:46:28: CWD: C:/Users/Admin/AppData/Roaming/FAHClient
22:46:28: OS: Windows 7 Professional N
22:46:28: OS Arch: AMD64
22:46:28: GPUs: 1
22:46:28: GPU 0: NVIDIA:2 GF114 [GeForce GTX 560 Ti]
22:46:28: CUDA: 2.1
22:46:28: CUDA Driver: 5000
22:46:28:Win32 Service: false
22:46:28:***********************************************************************
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Do I actually have to install the whole CUDA5 Toolkit to try this? I've got Visual Studio Express already, as well as NVidia 310.90 WHQL driver, which does have CUDA5 support.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
Are you guys using the latest drivers? Also, can you try running
http://www.dependencywalker.com/
on the OpenMMOpenCL.dll file that came with the benchmark?
Unfortunately yes. The CUDA platform does a lot of JIT compilation and hence requires the nvcc compiler. We assume the user has the NVIDIA GPU COMPUTING TOOLKIT 5.0 installed (and hence why its able to find CUFF).Napoleon wrote:Do I actually have to install the whole CUDA5 Toolkit to try this? I've got Visual Studio Express already, as well as NVidia 310.90 WHQL driver, which does have CUDA5 support.
Updated the download with some additional libraries - please redownload. Should fix OpenMMOpenCL.dll errors.
Looks like the 126 error is fixed by installing the CUDA toolkit.
Having installed Visual Studio 2012 and then the CUDA toolkit rebooting I was stuck at the PATH error until I restarted the computer after adding the folder to the PATH list.
Having restarted with the computer I now get the following error:
It would look like by installing Visual Studio 2012 I have version 11 of MSVC?
Error launching CUDA compiler: -1
nvcc : fatal error : nvcc cannot find a supported cl version. Only MSVC 9.0 and
MSVC 10.0 are supported
Wikipedia wrote:Visual C++ 2012 (known also as Visual C++ 11.0) was released on April 15, 2012, and it is currently the latest stable release.
RTM version number: 17.00.50727.1
Yes it's looking for CUFFT in the 5.0 toolkit.k1wi wrote:Looks like the 126 error is fixed by installing the CUDA toolkit.
It would look like by installing Visual Studio 2012 I have version 11 of MSVC?Code: Select all
Error launching CUDA compiler: -1 nvcc : fatal error : nvcc cannot find a supported cl version. Only MSVC 9.0 and MSVC 10.0 are supported
We compiled our code using Visual Studio 2008 (MSVC 9.0)- you can get the free express version here:
http://www.microsoft.com/en-us/download ... px?id=6506
Please don't use 2012 (MSVC11?) it's not supported. I'm not sure about 2010 (MSVC10).
Again, make sure the PATH includes the folder in which Visual Studio 2008's cl.exe is installed.
Will I have to uninstall VS2012 before installing 08?
Might be useful to put that information on http://fahbench.com/ as your link goes to the 2012 version. ah already done.
No you don't need to uninstall VS2012. You just need to set your PATH so it points to the cl.exe in VS 2008k1wi wrote:Will I have to uninstall VS2012 before installing 08?
I should have the prerequisites in place now, but "FAHBench.exe -deviceID 0 -platform CUDA -precision single" only reports "Invalid Device (please set valid deviceID by using --display-devices)". Output from --display-devices is
FWIW, FAH v7.2.9 reports
I didn't install the development driver in the CUDA toolkit, as it seemed to be pretty old (306.23, IIRC). 310.90 WHQL should support CUDA5. The nvcc.exe is the first thing in the PATH, now that the CUDA toolkit is installed. Tried both regular console and admin console, same result.
I can run for example "Stereo Disparity Computation" sample program which came with the toolkit, so I assume the toolkit installation was successful. According to GPU-Z it actually seems to do something on the GT430 because core clock briefly jumps from idle (50MHz) to 3D (810MHz).
What else could I try? Or is it just that my GT430 is too old to run the benchmark?
EDIT: if I try to run cl.exe from the console, I get "The program can't start because mspdb110.dll is missing from your computer. Try reinstalling the program to fix this problem." Well, this is a fresh install of the Visual Studio 2012 Express and all Windows updates are also installed, so I'm stumped with that one.
EDIT2: Never mind, I suppose I'll just have to try with the older version of VS Express.
=== 1 OpenCL platform(s) found: ===
-- 0 --
PROFILE = FULL_PROFILE
VERSION = OpenCL 1.1 CUDA 4.2.1
NAME = NVIDIA CUDA
VENDOR = NVIDIA Corporation
EXTENSIONS = cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_d3d9_sharing cl_nv_d
3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_compiler_options cl_nv_device_attribute_
query cl_nv_pragma_unroll
=== 1 OpenCL device(s) found on platform:
-- 0 --
DEVICE_NAME = GeForce GT 430
DEVICE_VENDOR = NVIDIA Corporation
DEVICE_VERSION = OpenCL 1.1 CUDA
DRIVER_VERSION = 310.90
DEVICE_MAX_COMPUTE_UNITS = 2
DEVICE_MAX_CLOCK_FREQUENCY = 1620
DEVICE_GLOBAL_MEM_SIZE = 1073741824
-- 1 --
DEVICE_NAME = ION
DEVICE_VERSION = OpenCL 1.0 CUDA
DEVICE_MAX_CLOCK_FREQUENCY = 1500
DEVICE_GLOBAL_MEM_SIZE = 536870912
Invalid Platform (please use either OpenCL or CUDA)
20:08:11:******************************* System ********************************
20:08:11: CPU: Intel(R) Atom(TM) CPU 330 @ 1.60GHz
20:08:11: CPU ID: GenuineIntel Family 6 Model 28 Stepping 2
20:08:11: CPUs: 4
20:08:11: Memory: 2.75GiB
20:08:11: Free Memory: 1.53GiB
20:08:11: Threads: WINDOWS_THREADS
20:08:11: On Battery: false
20:08:11: UTC offset: 2
20:08:11: PID: 5004
20:08:11: CWD: C:/FAH/Data
20:08:11: OS: Windows 7 Ultimate
20:08:11: OS Arch: AMD64
20:08:11: GPUs: 2
20:08:11: GPU 0: NVIDIA:1 C?? [ION]
20:08:11: GPU 1: NVIDIA:2 GF108 [GeForce GT 430]
20:08:11: CUDA: 2.1
20:08:11: CUDA Driver: 5000
20:08:11:Win32 Service: false
20:08:11:***********************************************************************
Stereo Disparity Computation (SAD SIMD Intrinsics)
A CUDA program that demonstrates how to compute a stereo disparity map using SIMD SAD (Sum of Absolute Difference) intrinsics. Requires Compute Capability 2.0 or higher. Minspec: GeForce 400
GPU Device 0: "GeForce GT 430" with compute capability 2.1
> GPU device has 2 Multi-Processors, SM 2.1 compute capabilities
Loaded <../3_Imaging/stereoDisparity/data/stereo.im0.640x533.ppm> as image 0
Loaded <../3_Imaging/stereoDisparity/data/stereo.im1.640x533.ppm> as image 1
Launching CUDA stereoDisparityKernel()
Input Size [640x533], Kernel size [17x17], Disparities [-16:0]
GPU processing time : 12.7466 (ms)
Pixel throughput : 26.762 Mpixels/sec
GPU Checksum = 4293895789, GPU image: <output_GPU.pgm>
Computing CPU reference...
