trouble installing FAH on a new machine
nogginthenog
Post by nogginthenog »
I have just built a new folding PC, a Q6600 on Xp Sp3, tried FAh fah-installer_7.1.52_x86.exe and fah-installer_7.2.9_x86.exe but both bring up a message saying the app cannot start because the config file is wrong.
Never had this problem before on several machines, any hints ?
I did notice, the config file created had differences from the sample file, in that it had v='xxx' rather than value='xxx' items in the config entries. Changing this made no difference.
Happy New Year to all folders !
uncle fuzzy
Re: trouble installing FAH on a new machine
Post by uncle fuzzy »
Run the uninstall program and try again with a fresh download of 7.2.9. I haven't seen that problem with a half dozen installs.
edit- check the box to remove data files while uninstalling
bollix47
Post by bollix47 »
Windows XP does have a couple of requirements in order for the FAHClient to function correctly.
Do you have .net and C++ installed as stated in the link above?
nogginthenog
Sorted now thanks for the tips, running like a rocket now !
