Existing Points Associated With New Passkey
rplate
- Hardware configuration: Windows 10 || CPU: Intel i5-6500 3.20 GHz || GPU: AMD Radeon R9 290
I searched the topics and couldn't find a clear answer, but I just signed up for a passkey and was hoping there was a way to associate the stats from my existing donor name to my new passkey. Is this possible? Or do I have to just start from scratch again?
Re: Existing Points Associated With New Passkey
Welcome to foldingforum.org, rplate.
There's absolutely no need to start over. A passkey has never been REQUIRED although it's strongly recommended. Yhe official stats categorizes all points based on your settings of User name and Team number. Adding a passkey will not change that. If you've used more than one passkey you can also enter that value into the search criteria but leaving that field blank will give you all of the stats for the search data that you've entered.
Once points are recorded, there's no way to change any of the keys associated with those points.
rplate
OK, thanks!
