Project: 7610 (Run 12, Clone 0, Gen 214) - (102 = 0x66)error
ice_724637
Post by ice_724637 »
Wasn't able to get this WU to start correctly. No matter what I did, I got this error after a few seconds.
Never had this error before. Had my system (current OC) stable for months.
I used StressTest for a few hours. Tested 9.70738e+14 FP operations.
I then tried folding it without OC (stock clocks and voltages for cpu,gpu&ram) - same Problem.
Tried it with 'Disable highly optimized assembly...' - same Problem.
I stopped 'FAHClient' via console and deleted the coresponding (only) WU in the Work folder. Hope this is the correct method - didn't find any other.
Log file:
*********************** Log Started 2013-01-05T05:21:09Z ***********************
05:21:09:Started thread 1 on PID 999
05:21:09:************************* Folding@home Client *************************
05:21:09:    Website: http://folding.stanford.edu/
05:21:09:  Copyright: (c) 2009-2012 Stanford University
05:21:09:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:21:09:       Args: --child --lifeline 983 /etc/fahclient/config.xml --run-as fahclient
05:21:09:             --pid-file=/var/run/fahclient.pid --daemon
05:21:09:     Config: /etc/fahclient/config.xml
05:21:09:******************************** Build ********************************
05:21:09:    Version: 7.1.52
05:21:09:       Date: Mar 20 2012
05:21:09:       Time: 13:19:11
05:21:09:    SVN Rev: 3515
05:21:09:     Branch: fah/trunk/client
05:21:09:   Compiler: GNU 4.6.2
05:21:09:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
05:21:09:             -fno-unsafe-math-optimizations -msse2
05:21:09:   Platform: linux2 3.2.0-1-amd64
05:21:09:       Bits: 64
05:21:09:       Mode: Release
05:21:09:******************************* System ********************************
05:21:09:        CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
05:21:09:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
05:21:09:       CPUs: 4
05:21:09:     Memory: 7.32GiB
05:21:09:Free Memory: 6.95GiB
05:21:09:    Threads: POSIX_THREADS
05:21:09: On Battery: false
05:21:09: UTC offset: 1
05:21:09:        PID: 999
05:21:09:        CWD: /var/lib/fahclient
05:21:09:         OS: Linux 3.2.0-35-generic x86_64
05:21:09:    OS Arch: AMD64
05:21:09:       GPUs: 0
05:21:09:       CUDA: Not detected
05:21:09:***********************************************************************
05:21:09:<config>
05:21:09:  <!-- Client Control -->
05:21:09:  <cycle-rate v='4'/>
05:21:09:  <cycles v='-1'/>
05:21:09:  <data-directory v='.'/>
05:21:09:  <disable-project-lookup v='false'/>
05:21:09:  <exec-directory v='/usr/bin'/>
05:21:09:  <exit-when-done v='false'/>
05:21:09:  <threads v='4'/>
05:21:09:
05:21:09:  <!-- Configuration -->
05:21:09:  <config-rotate v='true'/>
05:21:09:  <config-rotate-dir v='configs'/>
05:21:09:  <config-rotate-max v='16'/>
05:21:09:
05:21:09:  <!-- Debugging -->
05:21:09:  <assignment-servers>
05:21:09:    assign3.stanford.edu:8080 assign4.stanford.edu:80
05:21:09:  </assignment-servers>
05:21:09:  <capture-directory v='capture'/>
05:21:09:  <capture-sockets v='false'/>
05:21:09:  <debug-sockets v='false'/>
05:21:09:  <exception-locations v='true'/>
05:21:09:  <gpu-assignment-servers>
05:21:09:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
05:21:09:  </gpu-assignment-servers>
05:21:09:  <stack-traces v='false'/>
05:21:09:
05:21:09:  <!-- Error Handling -->
05:21:09:  <max-slot-errors v='5'/>
05:21:09:  <max-unit-errors v='5'/>
05:21:09:
05:21:09:  <!-- FahCore Control -->
05:21:09:  <checkpoint v='15'/>
05:21:09:  <core-dir v='cores'/>
05:21:09:  <core-priority v='idle'/>
05:21:09:  <cpu-affinity v='false'/>
05:21:09:  <cpu-usage v='100'/>
05:21:09:  <no-assembly v='false'/>
05:21:09:
05:21:09:  <!-- Folding Slot Configuration -->
05:21:09:  <client-subtype v='LINUX'/>
05:21:09:  <client-type v='normal'/>
05:21:09:  <cpu-species v='X86_PENTIUM_II'/>
05:21:09:  <cpu-type v='AMD64'/>
05:21:09:  <cpus v='-1'/>
05:21:09:  <cuda-index v='0'/>
05:21:09:  <gpu v='false'/>
05:21:09:  <gpu-usage v='100'/>
05:21:09:  <max-packet-size v='normal'/>
05:21:09:  <opencl-index v='0'/>
05:21:09:  <os-species v='UNKNOWN'/>
05:21:09:  <os-type v='LINUX'/>
05:21:09:  <project-key v='0'/>
05:21:09:  <smp v='true'/>
05:21:09:
05:21:09:  <!-- Logging -->
05:21:09:  <log v='log.txt'/>
05:21:09:  <log-color v='true'/>
05:21:09:  <log-crlf v='false'/>
05:21:09:  <log-date v='false'/>
05:21:09:  <log-date-periodically v='21600'/>
05:21:09:  <log-debug v='true'/>
05:21:09:  <log-domain v='false'/>
05:21:09:  <log-header v='true'/>
05:21:09:  <log-level v='true'/>
05:21:09:  <log-no-info-header v='true'/>
05:21:09:  <log-redirect v='false'/>
05:21:09:  <log-rotate v='true'/>
05:21:09:  <log-rotate-dir v='logs'/>
05:21:09:  <log-rotate-max v='16'/>
05:21:09:  <log-short-level v='false'/>
05:21:09:  <log-simple-domains v='true'/>
05:21:09:  <log-thread-id v='false'/>
05:21:09:  <log-thread-prefix v='true'/>
05:21:09:  <log-time v='true'/>
05:21:09:  <log-to-screen v='true'/>
05:21:09:  <log-truncate v='false'/>
05:21:09:  <verbosity v='5'/>
05:21:09:
05:21:09:  <!-- Network -->
05:21:09:  <proxy v=':8080'/>
05:21:09:  <proxy-enable v='false'/>
05:21:09:  <proxy-pass v=''/>
05:21:09:  <proxy-user v=''/>
05:21:09:
05:21:09:  <!-- Process Control -->
05:21:09:  <child v='true'/>
05:21:09:  <daemon v='true'/>
05:21:09:  <pid v='false'/>
05:21:09:  <pid-file v='/var/run/fahclient.pid'/>
05:21:09:  <respawn v='false'/>
05:21:09:  <service v='false'/>
05:21:09:
05:21:09:  <!-- Remote Command Server -->
05:21:09:  <command-address v='0.0.0.0'/>
05:21:09:  <command-allow v='127.0.0.1'/>
05:21:09:  <command-allow-no-pass v='127.0.0.1'/>
05:21:09:  <command-deny v='0.0.0.0/0'/>
05:21:09:  <command-deny-no-pass v='0.0.0.0/0'/>
05:21:09:  <command-port v='36330'/>
05:21:09:
05:21:09:  <!-- Slot Control -->
05:21:09:  <max-shutdown-wait v='60'/>
05:21:09:  <pause-on-battery v='false'/>
05:21:09:  <pause-on-start v='false'/>
05:21:09:
05:21:09:  <!-- User Information -->
05:21:09:  <machine-id v='0'/>
05:21:09:  <passkey v='********************************'/>
05:21:09:  <team v='0'/>
05:21:09:  <user v='ice_724637'/>
05:21:09:
05:21:09:  <!-- Work Unit Control -->
05:21:09:  <dump-after-deadline v='true'/>
05:21:09:  <max-queue v='16'/>
05:21:09:  <max-units v='0'/>
05:21:09:  <next-unit-percentage v='99'/>
05:21:09:
05:21:09:  <!-- Folding Slots -->
05:21:09:  <slot id='0' type='SMP'/>
05:21:09:</config>
05:21:09:Switching to user fahclient
05:21:09:Trying to access database...
05:21:09:Successfully acquired database lock
05:21:09:Enabled folding slot 00: READY smp:4
05:21:09:Started thread 3 on PID 999
05:21:09:WU01:FS00:Starting
05:21:09:Started thread 4 on PID 999
05:21:09:Started thread 6 on PID 999
05:21:09:Started thread 5 on PID 999
05:21:09:Started thread 7 on PID 999
05:21:09:WU01:FS00:Removing old file './work/01/logfile_01-20121229-150426.txt'
05:21:09:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
05:21:09:WU01:FS00:Started FahCore on PID 1028
05:21:09:Started thread 8 on PID 999
05:21:09:WU01:FS00:Core PID:1040
05:21:09:WU01:FS00:FahCore 0xa4 started
05:21:09:WU01:FS00:0xa4:
05:21:09:WU01:FS00:0xa4:*------------------------------*
05:21:09:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
05:21:09:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:21:09:WU01:FS00:0xa4:Preparing to commence simulation
05:21:09:WU01:FS00:0xa4:- Ensuring status. Please wait.
05:21:19:WU01:FS00:0xa4:- Looking at optimizations...
05:21:19:WU01:FS00:0xa4:- Working with standard loops on this execution.
05:21:19:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
05:21:19:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
05:21:19:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
05:21:19:WU01:FS00:0xa4:- Digital signature verified
05:21:19:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
05:21:19:WU01:FS00:0xa4:Entering M.D.
05:21:27:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:21:28:WU01:FS00:Starting
05:21:28:WU01:FS00:Removing old file './work/01/logfile_01-20121229-155125.txt'
05:21:28:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
05:21:28:WU01:FS00:Started FahCore on PID 2024
05:21:28:Started thread 9 on PID 999
05:21:28:WU01:FS00:Core PID:2028
05:21:28:WU01:FS00:FahCore 0xa4 started
05:21:28:WU01:FS00:0xa4:
05:21:28:WU01:FS00:0xa4:*------------------------------*
05:21:28:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
05:21:28:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:21:28:WU01:FS00:0xa4:Preparing to commence simulation
05:21:28:WU01:FS00:0xa4:- Ensuring status. Please wait.
05:21:37:WU01:FS00:0xa4:- Looking at optimizations...
05:21:37:WU01:FS00:0xa4:- Working with standard loops on this execution.
05:21:37:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
05:21:38:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
05:21:38:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
05:21:38:WU01:FS00:0xa4:- Digital signature verified
05:21:38:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
05:21:38:WU01:FS00:0xa4:Entering M.D.
05:21:44:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:22:28:WU01:FS00:Starting
05:22:28:WU01:FS00:Removing old file './work/01/logfile_01-20121229-170726.txt'
05:22:28:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
05:22:28:WU01:FS00:Started FahCore on PID 2036
05:22:28:Started thread 10 on PID 999
05:22:28:WU01:FS00:Core PID:2040
05:22:28:WU01:FS00:FahCore 0xa4 started
05:22:28:WU01:FS00:0xa4:
05:22:28:WU01:FS00:0xa4:*------------------------------*
05:22:28:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
05:22:28:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:22:28:WU01:FS00:0xa4:Preparing to commence simulation
05:22:28:WU01:FS00:0xa4:- Ensuring status. Please wait.
05:22:37:WU01:FS00:0xa4:- Looking at optimizations...
05:22:37:WU01:FS00:0xa4:- Working with standard loops on this execution.
05:22:37:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
05:22:38:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
05:22:38:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
05:22:38:WU01:FS00:0xa4:- Digital signature verified
05:22:38:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
05:22:38:WU01:FS00:0xa4:Entering M.D.
05:22:44:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:24:05:WU01:FS00:Starting
05:24:05:WU01:FS00:Removing old file './work/01/logfile_01-20121231-123541.txt'
05:24:05:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
05:24:05:WU01:FS00:Started FahCore on PID 2855
05:24:05:Started thread 11 on PID 999
05:24:05:WU01:FS00:Core PID:2859
05:24:05:WU01:FS00:FahCore 0xa4 started
05:24:06:WU01:FS00:0xa4:
05:24:06:WU01:FS00:0xa4:*------------------------------*
05:24:06:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
05:24:06:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:24:06:WU01:FS00:0xa4:Preparing to commence simulation
05:24:06:WU01:FS00:0xa4:- Ensuring status. Please wait.
05:24:15:WU01:FS00:0xa4:- Looking at optimizations...
05:24:15:WU01:FS00:0xa4:- Working with standard loops on this execution.
05:24:15:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
05:24:15:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
05:24:15:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
05:24:15:WU01:FS00:0xa4:- Digital signature verified
05:24:15:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
05:24:15:WU01:FS00:0xa4:Entering M.D.
05:24:21:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:26:42:WU01:FS00:Starting
05:26:42:WU01:FS00:Removing old file './work/01/logfile_01-20121231-123641.txt'
05:26:42:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
05:26:42:WU01:FS00:Started FahCore on PID 2949
05:26:42:Started thread 12 on PID 999
05:26:42:WU01:FS00:Core PID:2953
05:26:42:WU01:FS00:FahCore 0xa4 started
05:26:43:WU01:FS00:0xa4:
05:26:43:WU01:FS00:0xa4:*------------------------------*
05:26:43:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
05:26:43:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:26:43:WU01:FS00:0xa4:Preparing to commence simulation
05:26:43:WU01:FS00:0xa4:- Ensuring status. Please wait.
05:26:52:WU01:FS00:0xa4:- Looking at optimizations...
05:26:52:WU01:FS00:0xa4:- Working with standard loops on this execution.
05:26:52:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
05:26:52:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
05:26:52:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
05:26:52:WU01:FS00:0xa4:- Digital signature verified
05:26:52:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
05:26:52:WU01:FS00:0xa4:Entering M.D.
05:26:58:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:30:57:WU01:FS00:Starting
05:30:57:WU01:FS00:Removing old file './work/01/logfile_01-20121231-123818.txt'
05:30:57:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
05:30:57:WU01:FS00:Started FahCore on PID 2973
05:30:57:Started thread 13 on PID 999
05:30:57:WU01:FS00:Core PID:2977
05:30:57:WU01:FS00:FahCore 0xa4 started
05:30:57:WU01:FS00:0xa4:
05:30:57:WU01:FS00:0xa4:*------------------------------*
05:30:57:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
05:30:57:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:30:57:WU01:FS00:0xa4:Preparing to commence simulation
05:30:57:WU01:FS00:0xa4:- Ensuring status. Please wait.
05:31:06:WU01:FS00:0xa4:- Looking at optimizations...
05:31:06:WU01:FS00:0xa4:- Working with standard loops on this execution.
05:31:06:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
05:31:07:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
05:31:07:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
05:31:07:WU01:FS00:0xa4:- Digital signature verified
05:31:07:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
05:31:07:WU01:FS00:0xa4:Entering M.D.
05:31:13:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
******************************** Date: 05/01/13 ********************************
11:59:07:WU01:FS00:Starting
11:59:07:WU01:FS00:Removing old file './work/01/logfile_01-20121231-124056.txt'
11:59:07:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
11:59:07:WU01:FS00:Started FahCore on PID 4312
11:59:07:Started thread 14 on PID 999
11:59:07:WU01:FS00:Core PID:4321
11:59:07:WU01:FS00:FahCore 0xa4 started
11:59:08:WU01:FS00:0xa4:
11:59:08:WU01:FS00:0xa4:*------------------------------*
11:59:08:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
11:59:08:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:59:08:WU01:FS00:0xa4:Preparing to commence simulation
11:59:08:WU01:FS00:0xa4:- Ensuring status. Please wait.
11:59:17:WU01:FS00:0xa4:- Looking at optimizations...
11:59:17:WU01:FS00:0xa4:- Working with standard loops on this execution.
11:59:17:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
11:59:17:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
11:59:17:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
11:59:17:WU01:FS00:0xa4:- Digital signature verified
11:59:17:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
11:59:17:WU01:FS00:0xa4:Entering M.D.
11:59:26:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:10:13:WU01:FS00:Starting
12:10:13:WU01:FS00:Removing old file './work/01/logfile_01-20121231-124510.txt'
12:10:13:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
12:10:13:WU01:FS00:Started FahCore on PID 4683
12:10:13:Started thread 15 on PID 999
12:10:13:WU01:FS00:Core PID:4687
12:10:13:WU01:FS00:FahCore 0xa4 started
12:10:13:WU01:FS00:0xa4:
12:10:13:WU01:FS00:0xa4:*------------------------------*
12:10:13:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:10:13:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:10:13:WU01:FS00:0xa4:Preparing to commence simulation
12:10:13:WU01:FS00:0xa4:- Ensuring status. Please wait.
12:10:22:WU01:FS00:0xa4:- Looking at optimizations...
12:10:22:WU01:FS00:0xa4:- Working with standard loops on this execution.
12:10:22:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
12:10:23:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
12:10:23:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
12:10:23:WU01:FS00:0xa4:- Digital signature verified
12:10:23:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
12:10:23:WU01:FS00:0xa4:Entering M.D.
12:10:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:13:46:Started thread 16 on PID 999
12:13:46:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
12:15:12:FS00:Paused
12:15:17:FS00:Unpaused
12:15:17:WU01:FS00:Starting
12:15:17:WU01:FS00:Removing old file './work/01/logfile_01-20121231-125201.txt'
12:15:17:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
12:15:17:WU01:FS00:Started FahCore on PID 4773
12:15:17:Started thread 17 on PID 999
12:15:17:WU01:FS00:Core PID:4777
12:15:17:WU01:FS00:FahCore 0xa4 started
12:15:17:WU01:FS00:0xa4:
12:15:17:WU01:FS00:0xa4:*------------------------------*
12:15:17:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:15:17:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:15:17:WU01:FS00:0xa4:Preparing to commence simulation
12:15:17:WU01:FS00:0xa4:- Ensuring status. Please wait.
12:15:26:WU01:FS00:0xa4:- Looking at optimizations...
12:15:26:WU01:FS00:0xa4:- Working with standard loops on this execution.
12:15:26:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
12:15:27:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
12:15:27:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
12:15:27:WU01:FS00:0xa4:- Digital signature verified
12:15:27:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
12:15:27:WU01:FS00:0xa4:Entering M.D.
12:15:33:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:16:35:FS00:Finishing
12:16:40:FS00:Paused
12:16:42:FS00:Unpaused
12:16:42:WU01:FS00:Starting
12:16:42:WU01:FS00:Removing old file './work/01/logfile_01-20121231-130307.txt'
12:16:42:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
12:16:42:WU01:FS00:Started FahCore on PID 4785
12:16:42:Started thread 18 on PID 999
12:16:42:WU01:FS00:Core PID:4789
12:16:42:WU01:FS00:FahCore 0xa4 started
12:16:43:WU01:FS00:0xa4:
12:16:43:WU01:FS00:0xa4:*------------------------------*
12:16:43:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:16:43:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:16:43:WU01:FS00:0xa4:Preparing to commence simulation
12:16:43:WU01:FS00:0xa4:- Ensuring status. Please wait.
12:16:52:WU01:FS00:0xa4:- Looking at optimizations...
12:16:52:WU01:FS00:0xa4:- Working with standard loops on this execution.
12:16:52:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
12:16:52:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
12:16:52:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
12:16:52:WU01:FS00:0xa4:- Digital signature verified
12:16:52:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
12:16:52:WU01:FS00:0xa4:Entering M.D.
12:16:58:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:18:20:WU01:FS00:Starting
12:18:20:WU01:FS00:Removing old file './work/01/logfile_01-20121231-132104.txt'
12:18:20:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
12:18:20:WU01:FS00:Started FahCore on PID 4800
12:18:20:Started thread 19 on PID 999
12:18:20:WU01:FS00:Core PID:4804
12:18:20:WU01:FS00:FahCore 0xa4 started
12:18:20:WU01:FS00:0xa4:
12:18:20:WU01:FS00:0xa4:*------------------------------*
12:18:20:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:18:20:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:18:20:WU01:FS00:0xa4:Preparing to commence simulation
12:18:20:WU01:FS00:0xa4:- Ensuring status. Please wait.
12:18:29:WU01:FS00:0xa4:- Looking at optimizations...
12:18:29:WU01:FS00:0xa4:- Working with standard loops on this execution.
12:18:29:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
12:18:29:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
12:18:29:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
12:18:29:WU01:FS00:0xa4:- Digital signature verified
12:18:29:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
12:18:29:WU01:FS00:0xa4:Entering M.D.
12:18:36:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:20:57:WU01:FS00:Starting
12:20:57:WU01:FS00:Removing old file './work/01/logfile_01-20121231-133522.txt'
12:20:57:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
12:20:57:WU01:FS00:Started FahCore on PID 4864
12:20:57:Started thread 20 on PID 999
12:20:57:WU01:FS00:Core PID:4868
12:20:57:WU01:FS00:FahCore 0xa4 started
12:20:57:WU01:FS00:0xa4:
12:20:57:WU01:FS00:0xa4:*------------------------------*
12:20:57:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:20:57:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:20:57:WU01:FS00:0xa4:Preparing to commence simulation
12:20:57:WU01:FS00:0xa4:- Ensuring status. Please wait.
12:21:06:WU01:FS00:0xa4:- Looking at optimizations...
12:21:06:WU01:FS00:0xa4:- Working with standard loops on this execution.
12:21:06:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
12:21:07:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
12:21:07:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
12:21:07:WU01:FS00:0xa4:- Digital signature verified
12:21:07:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
12:21:07:WU01:FS00:0xa4:Entering M.D.
12:21:13:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:25:11:WU01:FS00:Starting
12:25:11:WU01:FS00:Removing old file './work/01/logfile_01-20121231-135006.txt'
12:25:11:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
12:25:11:WU01:FS00:Started FahCore on PID 4881
12:25:11:Started thread 21 on PID 999
12:25:11:WU01:FS00:Core PID:4885
12:25:11:WU01:FS00:FahCore 0xa4 started
12:25:12:WU01:FS00:0xa4:
12:25:12:WU01:FS00:0xa4:*------------------------------*
12:25:12:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:25:12:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:25:12:WU01:FS00:0xa4:Preparing to commence simulation
12:25:12:WU01:FS00:0xa4:- Ensuring status. Please wait.
12:25:21:WU01:FS00:0xa4:- Looking at optimizations...
12:25:21:WU01:FS00:0xa4:- Working with standard loops on this execution.
12:25:21:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
12:25:21:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
12:25:21:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
12:25:21:WU01:FS00:0xa4:- Digital signature verified
12:25:21:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
12:25:21:WU01:FS00:0xa4:Entering M.D.
12:25:27:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:32:03:WU01:FS00:Starting
12:32:03:WU01:FS00:Removing old file './work/01/logfile_01-20130103-055933.txt'
12:32:03:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
12:32:03:WU01:FS00:Started FahCore on PID 4896
12:32:03:Started thread 22 on PID 999
12:32:03:WU01:FS00:Core PID:4900
12:32:03:WU01:FS00:FahCore 0xa4 started
12:32:03:WU01:FS00:0xa4:
12:32:03:WU01:FS00:0xa4:*------------------------------*
12:32:03:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:32:03:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:32:03:WU01:FS00:0xa4:Preparing to commence simulation
12:32:03:WU01:FS00:0xa4:- Ensuring status. Please wait.
12:32:12:WU01:FS00:0xa4:- Looking at optimizations...
12:32:12:WU01:FS00:0xa4:- Working with standard loops on this execution.
12:32:12:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
12:32:12:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
12:32:12:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
12:32:12:WU01:FS00:0xa4:- Digital signature verified
12:32:12:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
12:32:12:WU01:FS00:0xa4:Entering M.D.
12:32:19:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:43:08:WU01:FS00:Starting
12:43:08:WU01:FS00:Removing old file './work/01/logfile_01-20130103-060033.txt'
12:43:08:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
12:43:08:WU01:FS00:Started FahCore on PID 4933
12:43:08:Started thread 23 on PID 999
12:43:08:WU01:FS00:Core PID:4937
12:43:08:WU01:FS00:FahCore 0xa4 started
12:43:09:WU01:FS00:0xa4:
12:43:09:WU01:FS00:0xa4:*------------------------------*
12:43:09:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
12:43:09:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:43:09:WU01:FS00:0xa4:Preparing to commence simulation
12:43:09:WU01:FS00:0xa4:- Ensuring status. Please wait.
12:43:18:WU01:FS00:0xa4:- Looking at optimizations...
12:43:18:WU01:FS00:0xa4:- Working with standard loops on this execution.
12:43:18:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
12:43:18:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
12:43:18:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
12:43:18:WU01:FS00:0xa4:- Digital signature verified
12:43:18:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
12:43:18:WU01:FS00:0xa4:Entering M.D.
12:43:24:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:01:05:WU01:FS00:Starting
13:01:05:WU01:FS00:Removing old file './work/01/logfile_01-20130103-060211.txt'
13:01:05:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
13:01:05:WU01:FS00:Started FahCore on PID 5131
13:01:05:Started thread 24 on PID 999
13:01:05:WU01:FS00:Core PID:5135
13:01:05:WU01:FS00:FahCore 0xa4 started
13:01:05:WU01:FS00:0xa4:
13:01:05:WU01:FS00:0xa4:*------------------------------*
13:01:05:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
13:01:05:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:01:05:WU01:FS00:0xa4:Preparing to commence simulation
13:01:05:WU01:FS00:0xa4:- Ensuring status. Please wait.
13:01:15:WU01:FS00:0xa4:- Looking at optimizations...
13:01:15:WU01:FS00:0xa4:- Working with standard loops on this execution.
13:01:15:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
13:01:15:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
13:01:15:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
13:01:15:WU01:FS00:0xa4:- Digital signature verified
13:01:15:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
13:01:15:WU01:FS00:0xa4:Entering M.D.
13:01:21:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:29:41:Server connection id=1 ended
13:30:07:WU01:FS00:Starting
13:30:07:WU01:FS00:Removing old file './work/01/logfile_01-20130103-060448.txt'
13:30:07:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
13:30:07:WU01:FS00:Started FahCore on PID 5272
13:30:07:Started thread 25 on PID 999
13:30:07:WU01:FS00:Core PID:5276
13:30:07:WU01:FS00:FahCore 0xa4 started
13:30:08:WU01:FS00:0xa4:
13:30:08:WU01:FS00:0xa4:*------------------------------*
13:30:08:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
13:30:08:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:30:08:WU01:FS00:0xa4:Preparing to commence simulation
13:30:08:WU01:FS00:0xa4:- Ensuring status. Please wait.
13:30:17:WU01:FS00:0xa4:- Looking at optimizations...
13:30:17:WU01:FS00:0xa4:- Working with standard loops on this execution.
13:30:17:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
13:30:17:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
13:30:17:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
13:30:17:WU01:FS00:0xa4:- Digital signature verified
13:30:17:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
13:30:17:WU01:FS00:0xa4:Entering M.D.
13:30:24:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:17:06:WU01:FS00:Starting
14:17:06:WU01:FS00:Removing old file './work/01/logfile_01-20130103-060902.txt'
14:17:06:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
14:17:06:WU01:FS00:Started FahCore on PID 5397
14:17:06:Started thread 26 on PID 999
14:17:06:WU01:FS00:Core PID:5401
14:17:06:WU01:FS00:FahCore 0xa4 started
14:17:06:WU01:FS00:0xa4:
14:17:06:WU01:FS00:0xa4:*------------------------------*
14:17:06:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
14:17:06:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:17:06:WU01:FS00:0xa4:Preparing to commence simulation
14:17:06:WU01:FS00:0xa4:- Ensuring status. Please wait.
14:17:16:WU01:FS00:0xa4:- Looking at optimizations...
14:17:16:WU01:FS00:0xa4:- Working with standard loops on this execution.
14:17:16:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
14:17:16:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
14:17:16:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
14:17:16:WU01:FS00:0xa4:- Digital signature verified
14:17:16:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
14:17:16:WU01:FS00:0xa4:Entering M.D.
14:17:22:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:33:07:WU01:FS00:Starting
15:33:07:WU01:FS00:Removing old file './work/01/logfile_01-20130103-061554.txt'
15:33:07:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
15:33:07:WU01:FS00:Started FahCore on PID 5418
15:33:07:Started thread 27 on PID 999
15:33:07:WU01:FS00:Core PID:5422
15:33:07:WU01:FS00:FahCore 0xa4 started
15:33:07:WU01:FS00:0xa4:
15:33:07:WU01:FS00:0xa4:*------------------------------*
15:33:07:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
15:33:07:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:33:07:WU01:FS00:0xa4:Preparing to commence simulation
15:33:07:WU01:FS00:0xa4:- Ensuring status. Please wait.
15:33:17:WU01:FS00:0xa4:- Looking at optimizations...
15:33:17:WU01:FS00:0xa4:- Working with standard loops on this execution.
15:33:17:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
15:33:17:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
15:33:17:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
15:33:17:WU01:FS00:0xa4:- Digital signature verified
15:33:17:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
15:33:17:WU01:FS00:0xa4:Entering M.D.
15:33:24:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:26:08:Started thread 28 on PID 999
17:26:08:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
17:26:22:FS00:Paused
17:26:30:FS00:Unpaused
17:26:30:WU01:FS00:Starting
17:26:30:WU01:FS00:Removing old file './work/01/logfile_01-20130103-062659.txt'
17:26:30:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
17:26:30:WU01:FS00:Started FahCore on PID 5536
17:26:30:Started thread 29 on PID 999
17:26:30:WU01:FS00:Core PID:5540
17:26:30:WU01:FS00:FahCore 0xa4 started
17:26:30:WU01:FS00:0xa4:
17:26:30:WU01:FS00:0xa4:*------------------------------*
17:26:30:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:26:30:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:26:30:WU01:FS00:0xa4:Preparing to commence simulation
17:26:30:WU01:FS00:0xa4:- Ensuring status. Please wait.
17:26:39:WU01:FS00:0xa4:- Looking at optimizations...
17:26:39:WU01:FS00:0xa4:- Working with standard loops on this execution.
17:26:39:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
17:26:40:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
17:26:40:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
17:26:40:WU01:FS00:0xa4:- Digital signature verified
17:26:40:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
17:26:40:WU01:FS00:0xa4:Entering M.D.
17:26:46:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:28:07:WU01:FS00:Starting
17:28:07:WU01:FS00:Removing old file './work/01/logfile_01-20130103-064456.txt'
17:28:07:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
17:28:07:WU01:FS00:Started FahCore on PID 5550
17:28:07:Started thread 30 on PID 999
17:28:07:WU01:FS00:Core PID:5554
17:28:07:WU01:FS00:FahCore 0xa4 started
17:28:08:WU01:FS00:0xa4:
17:28:08:WU01:FS00:0xa4:*------------------------------*
17:28:08:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:28:08:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:28:08:WU01:FS00:0xa4:Preparing to commence simulation
17:28:08:WU01:FS00:0xa4:- Ensuring status. Please wait.
17:28:17:WU01:FS00:0xa4:- Looking at optimizations...
17:28:17:WU01:FS00:0xa4:- Working with standard loops on this execution.
17:28:17:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
17:28:17:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
17:28:17:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
17:28:17:WU01:FS00:0xa4:- Digital signature verified
17:28:17:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
17:28:17:WU01:FS00:0xa4:Entering M.D.
17:28:23:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:30:44:WU01:FS00:Starting
17:30:44:WU01:FS00:Removing old file './work/01/logfile_01-20130103-065913.txt'
17:30:44:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
17:30:44:WU01:FS00:Started FahCore on PID 5567
17:30:44:Started thread 31 on PID 999
17:30:44:WU01:FS00:Core PID:5571
17:30:44:WU01:FS00:FahCore 0xa4 started
17:30:45:WU01:FS00:0xa4:
17:30:45:WU01:FS00:0xa4:*------------------------------*
17:30:45:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:30:45:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:30:45:WU01:FS00:0xa4:Preparing to commence simulation
17:30:45:WU01:FS00:0xa4:- Ensuring status. Please wait.
17:30:54:WU01:FS00:0xa4:- Looking at optimizations...
17:30:54:WU01:FS00:0xa4:- Working with standard loops on this execution.
17:30:54:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
17:30:54:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
17:30:54:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
17:30:54:WU01:FS00:0xa4:- Digital signature verified
17:30:54:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
17:30:54:WU01:FS00:0xa4:Entering M.D.
17:31:00:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:34:59:WU01:FS00:Starting
17:34:59:WU01:FS00:Removing old file './work/01/logfile_01-20130103-071358.txt'
17:34:59:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 999 -checkpoint 15 -np 4
17:34:59:WU01:FS00:Started FahCore on PID 5583
17:34:59:Started thread 32 on PID 999
17:34:59:WU01:FS00:Core PID:5587
17:34:59:WU01:FS00:FahCore 0xa4 started
17:34:59:WU01:FS00:0xa4:
17:34:59:WU01:FS00:0xa4:*------------------------------*
17:34:59:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:34:59:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:34:59:WU01:FS00:0xa4:Preparing to commence simulation
17:34:59:WU01:FS00:0xa4:- Ensuring status. Please wait.
17:35:08:WU01:FS00:0xa4:- Looking at optimizations...
17:35:08:WU01:FS00:0xa4:- Working with standard loops on this execution.
17:35:08:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
17:35:09:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
17:35:09:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
17:35:09:WU01:FS00:0xa4:- Digital signature verified
17:35:09:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
17:35:09:WU01:FS00:0xa4:Entering M.D.
17:35:15:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
*********************** Log Started 2013-01-05T17:52:10Z ***********************
17:52:10:Started thread 1 on PID 1005
17:52:10:************************* Folding@home Client *************************
17:52:10:    Website: http://folding.stanford.edu/
17:52:10:  Copyright: (c) 2009-2012 Stanford University
17:52:10:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:52:10:       Args: --child --lifeline 957 /etc/fahclient/config.xml --run-as fahclient
17:52:10:             --pid-file=/var/run/fahclient.pid --daemon
17:52:10:     Config: /etc/fahclient/config.xml
17:52:10:******************************** Build ********************************
17:52:10:    Version: 7.1.52
17:52:10:       Date: Mar 20 2012
17:52:10:       Time: 13:19:11
17:52:10:    SVN Rev: 3515
17:52:10:     Branch: fah/trunk/client
17:52:10:   Compiler: GNU 4.6.2
17:52:10:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
17:52:10:             -fno-unsafe-math-optimizations -msse2
17:52:10:   Platform: linux2 3.2.0-1-amd64
17:52:10:       Bits: 64
17:52:10:       Mode: Release
17:52:10:******************************* System ********************************
17:52:10:        CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
17:52:10:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
17:52:10:       CPUs: 4
17:52:10:     Memory: 7.32GiB
17:52:10:Free Memory: 7.08GiB
17:52:10:    Threads: POSIX_THREADS
17:52:10: On Battery: false
17:52:10: UTC offset: 1
17:52:10:        PID: 1005
17:52:10:        CWD: /var/lib/fahclient
17:52:10:         OS: Linux 3.2.0-35-generic x86_64
17:52:10:    OS Arch: AMD64
17:52:10:       GPUs: 0
17:52:10:       CUDA: Not detected
17:52:10:***********************************************************************
17:52:10:<config>
17:52:10:  <!-- Client Control -->
17:52:10:  <cycle-rate v='4'/>
17:52:10:  <cycles v='-1'/>
17:52:10:  <data-directory v='.'/>
17:52:10:  <disable-project-lookup v='false'/>
17:52:10:  <exec-directory v='/usr/bin'/>
17:52:10:  <exit-when-done v='false'/>
17:52:10:  <threads v='4'/>
17:52:10:
17:52:10:  <!-- Configuration -->
17:52:10:  <config-rotate v='true'/>
17:52:10:  <config-rotate-dir v='configs'/>
17:52:10:  <config-rotate-max v='16'/>
17:52:10:
17:52:10:  <!-- Debugging -->
17:52:10:  <assignment-servers>
17:52:10:    assign3.stanford.edu:8080 assign4.stanford.edu:80
17:52:10:  </assignment-servers>
17:52:10:  <capture-directory v='capture'/>
17:52:10:  <capture-sockets v='false'/>
17:52:10:  <debug-sockets v='false'/>
17:52:10:  <exception-locations v='true'/>
17:52:10:  <gpu-assignment-servers>
17:52:10:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
17:52:10:  </gpu-assignment-servers>
17:52:10:  <stack-traces v='false'/>
17:52:10:
17:52:10:  <!-- Error Handling -->
17:52:10:  <max-slot-errors v='5'/>
17:52:10:  <max-unit-errors v='5'/>
17:52:10:
17:52:10:  <!-- FahCore Control -->
17:52:10:  <checkpoint v='15'/>
17:52:10:  <core-dir v='cores'/>
17:52:10:  <core-priority v='idle'/>
17:52:10:  <cpu-affinity v='false'/>
17:52:10:  <cpu-usage v='100'/>
17:52:10:  <no-assembly v='false'/>
17:52:10:
17:52:10:  <!-- Folding Slot Configuration -->
17:52:10:  <client-subtype v='LINUX'/>
17:52:10:  <client-type v='normal'/>
17:52:10:  <cpu-species v='X86_PENTIUM_II'/>
17:52:10:  <cpu-type v='AMD64'/>
17:52:10:  <cpus v='-1'/>
17:52:10:  <cuda-index v='0'/>
17:52:10:  <gpu v='false'/>
17:52:10:  <gpu-usage v='100'/>
17:52:10:  <max-packet-size v='normal'/>
17:52:10:  <opencl-index v='0'/>
17:52:10:  <os-species v='UNKNOWN'/>
17:52:10:  <os-type v='LINUX'/>
17:52:10:  <project-key v='0'/>
17:52:10:  <smp v='true'/>
17:52:10:
17:52:10:  <!-- Logging -->
17:52:10:  <log v='log.txt'/>
17:52:10:  <log-color v='true'/>
17:52:10:  <log-crlf v='false'/>
17:52:10:  <log-date v='false'/>
17:52:10:  <log-date-periodically v='21600'/>
17:52:10:  <log-debug v='true'/>
17:52:10:  <log-domain v='false'/>
17:52:10:  <log-header v='true'/>
17:52:10:  <log-level v='true'/>
17:52:10:  <log-no-info-header v='true'/>
17:52:10:  <log-redirect v='false'/>
17:52:10:  <log-rotate v='true'/>
17:52:10:  <log-rotate-dir v='logs'/>
17:52:10:  <log-rotate-max v='16'/>
17:52:10:  <log-short-level v='false'/>
17:52:10:  <log-simple-domains v='true'/>
17:52:10:  <log-thread-id v='false'/>
17:52:10:  <log-thread-prefix v='true'/>
17:52:10:  <log-time v='true'/>
17:52:10:  <log-to-screen v='true'/>
17:52:10:  <log-truncate v='false'/>
17:52:10:  <verbosity v='5'/>
17:52:10:
17:52:10:  <!-- Network -->
17:52:10:  <proxy v=':8080'/>
17:52:10:  <proxy-enable v='false'/>
17:52:10:  <proxy-pass v=''/>
17:52:10:  <proxy-user v=''/>
17:52:10:
17:52:10:  <!-- Process Control -->
17:52:10:  <child v='true'/>
17:52:10:  <daemon v='true'/>
17:52:10:  <pid v='false'/>
17:52:10:  <pid-file v='/var/run/fahclient.pid'/>
17:52:10:  <respawn v='false'/>
17:52:10:  <service v='false'/>
17:52:10:
17:52:10:  <!-- Remote Command Server -->
17:52:10:  <command-address v='0.0.0.0'/>
17:52:10:  <command-allow v='127.0.0.1'/>
17:52:10:  <command-allow-no-pass v='127.0.0.1'/>
17:52:10:  <command-deny v='0.0.0.0/0'/>
17:52:10:  <command-deny-no-pass v='0.0.0.0/0'/>
17:52:10:  <command-port v='36330'/>
17:52:10:
17:52:10:  <!-- Slot Control -->
17:52:10:  <max-shutdown-wait v='60'/>
17:52:10:  <pause-on-battery v='false'/>
17:52:10:  <pause-on-start v='false'/>
17:52:10:
17:52:10:  <!-- User Information -->
17:52:10:  <machine-id v='0'/>
17:52:10:  <passkey v='********************************'/>
17:52:10:  <team v='0'/>
17:52:10:  <user v='ice_724637'/>
17:52:10:
17:52:10:  <!-- Work Unit Control -->
17:52:10:  <dump-after-deadline v='true'/>
17:52:10:  <max-queue v='16'/>
17:52:10:  <max-units v='0'/>
17:52:10:  <next-unit-percentage v='99'/>
17:52:10:
17:52:10:  <!-- Folding Slots -->
17:52:10:  <slot id='0' type='SMP'/>
17:52:10:</config>
17:52:10:Switching to user fahclient
17:52:10:Trying to access database...
17:52:10:Successfully acquired database lock
17:52:10:Enabled folding slot 00: READY smp:4
17:52:10:Started thread 3 on PID 1005
17:52:10:Started thread 4 on PID 1005
17:52:10:Started thread 5 on PID 1005
17:52:10:Started thread 7 on PID 1005
17:52:10:Started thread 6 on PID 1005
17:52:10:WU01:FS00:Starting
17:52:10:WU01:FS00:Removing old file './work/01/logfile_01-20130103-143858.txt'
17:52:10:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 1005 -checkpoint 15 -np 4
17:52:10:WU01:FS00:Started FahCore on PID 1023
17:52:10:Started thread 8 on PID 1005
17:52:10:WU01:FS00:Core PID:1027
17:52:10:WU01:FS00:FahCore 0xa4 started
17:52:10:WU01:FS00:0xa4:
17:52:10:WU01:FS00:0xa4:*------------------------------*
17:52:10:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:52:10:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:52:10:WU01:FS00:0xa4:Preparing to commence simulation
17:52:10:WU01:FS00:0xa4:- Ensuring status. Please wait.
17:52:19:WU01:FS00:0xa4:- Looking at optimizations...
17:52:19:WU01:FS00:0xa4:- Working with standard loops on this execution.
17:52:19:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
17:52:19:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
17:52:19:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
17:52:19:WU01:FS00:0xa4:- Digital signature verified
17:52:19:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
17:52:19:WU01:FS00:0xa4:Entering M.D.
17:52:26:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:52:26:WU01:FS00:Starting
17:52:26:WU01:FS00:Removing old file './work/01/logfile_01-20130103-200058.txt'
17:52:26:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 1005 -checkpoint 15 -np 4
17:52:26:WU01:FS00:Started FahCore on PID 2193
17:52:26:Started thread 9 on PID 1005
17:52:26:WU01:FS00:Core PID:2197
17:52:26:WU01:FS00:FahCore 0xa4 started
17:52:26:WU01:FS00:0xa4:
17:52:26:WU01:FS00:0xa4:*------------------------------*
17:52:26:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:52:26:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:52:26:WU01:FS00:0xa4:Preparing to commence simulation
17:52:26:WU01:FS00:0xa4:- Ensuring status. Please wait.
17:52:33:Started thread 10 on PID 1005
17:52:33:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
17:52:35:WU01:FS00:0xa4:- Looking at optimizations...
17:52:35:WU01:FS00:0xa4:- Working with standard loops on this execution.
17:52:35:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
17:52:36:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
17:52:36:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
17:52:36:WU01:FS00:0xa4:- Digital signature verified
17:52:36:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
17:52:36:WU01:FS00:0xa4:Entering M.D.
17:52:42:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:53:26:WU01:FS00:Starting
17:53:26:WU01:FS00:Removing old file './work/01/logfile_01-20130104-020058.txt'
17:53:26:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 701 -lifeline 1005 -checkpoint 15 -np 4
17:53:26:WU01:FS00:Started FahCore on PID 2552
17:53:26:Started thread 11 on PID 1005
17:53:26:WU01:FS00:Core PID:2556
17:53:26:WU01:FS00:FahCore 0xa4 started
17:53:26:WU01:FS00:0xa4:
17:53:26:WU01:FS00:0xa4:*------------------------------*
17:53:26:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:53:26:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:53:26:WU01:FS00:0xa4:Preparing to commence simulation
17:53:26:WU01:FS00:0xa4:- Ensuring status. Please wait.
17:53:35:WU01:FS00:0xa4:- Looking at optimizations...
17:53:35:WU01:FS00:0xa4:- Working with standard loops on this execution.
17:53:36:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
17:53:36:WU01:FS00:0xa4:- Expanded 29815 -> 644556 (decompressed 2161.8 percent)
17:53:36:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=29815 data_size=644556, decompressed_data_size=644556 diff=0
17:53:36:WU01:FS00:0xa4:- Digital signature verified
17:53:36:WU01:FS00:0xa4:Project: 7610 (Run 12, Clone 0, Gen 214)
17:53:36:WU01:FS00:0xa4:Entering M.D.
17:53:42:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Re: Project: 7610 (Run 12, Clone 0, Gen 214) - (102 = 0x66)e
That was probably the best way to handle it, the client is supposed to automatically report and move on to another WU after multiple errors. That was detected by the core as reported:
but sometimes does not get handled correctly. That problem has been reported already to the developers.
As for the WU, it might be bad, two others have reported failure and there is one successful report in the database.
P.S. The recommended verbosity level for V7 logging is 3. Settings of 4 or 5 actually make troubleshooting issues a bit harder as most of the additional information is just echoing default value settings.
