AMD Radeon HD 6670
AMD Radeon HD 6670
I think i've got it all setup correctly in FAH, but the estimated PPD and estimated TPF are both "unknown" and the progress just sits at 0%. It says its "running" and the project is 11292. Is this card supported? What am I missing?
Re: AMD Radeon HD 6670
Please post the beginning of your log file that shows your system configuration up to the beginning of processing of the 11292 WU. Which version of the AMD Catalyst drivers are installed? The most recent folding stable driver package is 12.8, some people have been able to get later versions to fold at a reduced rate.
01:13:19:************************* Folding@home Client *************************
01:13:19: Website: http://folding.stanford.edu/
01:13:19: Copyright: (c) 2009-2012 Stanford University
01:13:19: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:13:19: Args: --lifeline 7972 --command-port=36330
01:13:19: Config: C:/Users/Chris/AppData/Roaming/FAHClient/config.xml
01:13:19:******************************** Build ********************************
01:13:19: Version: 7.2.9
01:13:19: Date: Oct 3 2012
01:13:19: Time: 18:05:48
01:13:19: SVN Rev: 3578
01:13:19: Branch: fah/trunk/client
01:13:19: Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:13:19: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:13:19: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:13:19: Platform: win32 XP
01:13:19: Bits: 32
01:13:19: Mode: Release
01:13:19:******************************* System ********************************
01:13:19: CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
01:13:19: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
01:13:19: CPUs: 8
01:13:19: Memory: 15.88GiB
01:13:19: Free Memory: 12.65GiB
01:13:19: Threads: WINDOWS_THREADS
01:13:19: On Battery: false
01:13:19: UTC offset: -7
01:13:19: PID: 5228
01:13:19: CWD: C:/Users/Chris/AppData/Roaming/FAHClient
01:13:19: OS: Windows 7 Professional
01:13:19: OS Arch: AMD64
01:13:19: GPUs: 1
01:13:19: GPU 0: ATI:4 Whistler [AMD Radeon HD 6600 Series]
01:13:19: CUDA: Not detected
01:13:19:Win32 Service: false
01:13:19:***********************************************************************
01:13:19:<config>
01:13:19: <!-- FahCore Control -->
01:13:19: <checkpoint v='5'/>
01:13:19: <cpu-usage v='86'/>
01:13:19:
01:13:19: <!-- Network -->
01:13:19: <proxy v=':8080'/>
01:13:19:
01:13:19: <!-- User Information -->
01:13:19: <passkey v='********************************'/>
01:13:19: <team v='223311'/>
01:13:19: <user v='phiniac'/>
01:13:19:
01:13:19: <!-- Folding Slots -->
01:13:19: <slot id='0' type='SMP'>
01:13:19: <client-type v='bigadv'/>
01:13:19: <cpus v='4'/>
01:13:19: </slot>
01:13:19: <slot id='1' type='GPU'>
01:13:19: <client-type v='beta'/>
01:13:19: <cuda-index v='0'/>
01:13:19: <opencl-index v='0'/>
01:13:19: </slot>
01:13:19:</config>
01:13:19:Trying to access database...
01:13:19:Successfully acquired database lock
01:13:19:Enabled folding slot 00: READY smp:4
01:13:19:Enabled folding slot 01: READY gpu:0:"Whistler [AMD Radeon HD 6600 Series]"
01:13:19:WARNING:WU01:Missing data files, dumping
01:13:19:WARNING:WU00:Missing data files, dumping
01:13:19:WU01:FS01:Cleaning up
01:13:19:WU00:FS00:Cleaning up
01:13:19:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:13:19:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
01:13:19:WU01:FS01:News: Welcome to Folding@Home
01:13:19:WU01:FS01:Assigned to work server 171.67.108.44
01:13:19:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:"Whistler [AMD Radeon HD 6600 Series]" from 171.67.108.44
01:13:19:WU01:FS01:Connecting to 171.67.108.44:8080
01:13:19:WU00:FS00:News: Welcome to Folding@Home
01:13:19:WU00:FS00:Assigned to work server 171.64.65.81
01:13:20:WU00:FS00:Requesting new work unit for slot 00: READY smp:4 from 171.64.65.81
01:13:20:WU00:FS00:Connecting to 171.64.65.81:8080
01:13:20:WU01:FS01:Downloading 44.21KiB
01:13:20:WU00:FS00:Downloading 367.67KiB
01:13:20:WU01:FS01:Download complete
01:13:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11292 run:8 clone:8 gen:17 core:0x16 unit:0x0000001d6652edbc4caa47c400000053
01:13:20:WU01:FS01:Starting
01:13:20:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Chris/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 702 -lifeline 5228 -checkpoint 5 -cpu 86 -gpu 0
01:13:20:WU01:FS01:Started FahCore on PID 2212
01:13:20:WU01:FS01:Core PID:6900
01:13:20:WU01:FS01:FahCore 0x16 started
01:13:21:WU01:FS01:0x16:
01:13:21:WU01:FS01:0x16:*------------------------------*
01:13:21:WU01:FS01:0x16:Folding@Home GPU Core
01:13:21:WU01:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
01:13:21:WU01:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
01:13:21:WU01:FS01:0x16:Build host: user-f6d030f24f
01:13:21:WU01:FS01:0x16:Board Type: AMD/OpenCL
01:13:21:WU01:FS01:0x16:Core : x=16
01:13:21:WU01:FS01:0x16: Window's signal control handler registered.
01:13:21:WU01:FS01:0x16:Preparing to commence simulation
01:13:21:WU01:FS01:0x16:- Looking at optimizations...
01:13:21:WU01:FS01:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
01:13:21:WU01:FS01:0x16:- Created dyn
01:13:21:WU01:FS01:0x16:- Files status OK
01:13:21:WU01:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:13:21:WU01:FS01:0x16:- Expanded 44759 -> 171163 (decompressed 382.4 percent)
01:13:21:WU01:FS01:0x16:Called DecompressByteArray: compressed_data_size=44759 data_size=171163, decompressed_data_size=171163 diff=0
01:13:21:WU01:FS01:0x16:- Digital signature verified
01:13:21:WU01:FS01:0x16:Project: 11292 (Run 8, Clone 8, Gen 17)
01:13:21:WU01:FS01:0x16:Assembly optimizations on if available.
01:13:21:WU01:FS01:0x16:Entering M.D.
01:13:23:WU01:FS01:0x16:Tpr hash 01/wudata_01.tpr: 1840862616 1960897209 313171957 151549198 1593571991
01:13:23:WU01:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
01:13:23:WU01:FS01:0x16:Client config unavailable.
01:13:23:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
01:13:23:WU01:FS01:0x16:Starting GUI Server
01:13:23:WU00:FS00:Download complete
01:13:23:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10450 run:20 clone:0 gen:66 core:0xa4 unit:0x000000450a3b1e7550a539dc2524a121
01:13:23:WU00:FS00:Starting
01:13:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Chris/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 702 -lifeline 5228 -checkpoint 5 -cpu 86 -np 4
01:13:23:WU00:FS00:Started FahCore on PID 6416
01:13:23:WU00:FS00:Core PID:7392
01:13:23:WU00:FS00:FahCore 0xa4 started
01:13:24:WU00:FS00:Downloading project 10450 description
01:13:24:WU00:FS00:Connecting to fah-web.stanford.edu:80
01:13:24:WU00:FS00:0xa4:
01:13:24:WU00:FS00:0xa4:*------------------------------*
01:13:24:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:13:24:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:13:24:WU00:FS00:0xa4:Preparing to commence simulation
01:13:24:WU00:FS00:0xa4:- Looking at optimizations...
01:13:24:WU00:FS00:0xa4:- Created dyn
01:13:24:WU00:FS00:0xa4:- Files status OK
01:13:24:WU00:FS00:0xa4:- Expanded 375986 -> 690140 (decompressed 183.5 percent)
01:13:24:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=375986 data_size=690140, decompressed_data_size=690140 diff=0
01:13:24:WU00:FS00:0xa4:- Digital signature verified
01:13:24:WU00:FS00:0xa4:Project: 10450 (Run 20, Clone 0, Gen 66)
01:13:24:WU00:FS00:0xa4:Assembly optimizations on if available.
01:13:24:WU00:FS00:0xa4:Entering M.D.
01:13:24:WU00:FS00:Project 10450 description downloaded successfully
01:13:30:WU00:FS00:0xa4:Mapping NT from 4 to 4
01:13:30:WU00:FS00:0xa4:Completed 0 out of 2000000 steps (0%)
01:17:20:WU00:FS00:0xa4:Completed 20000 out of 2000000 steps (1%)
01:21:12:WU00:FS00:0xa4:Completed 40000 out of 2000000 steps (2%)Re: AMD Radeon HD 6670
i have 12.10 and i'm downloading 12.8 right now
downgraded to 12.8 and i don't see any difference
interestingly, after the downgrade i no longer have OpenCL
You may have to reinstall the OpenCL support. The installer/repair package may already be on your system, a path to that is mentioned in this post.
okay...that got opencl back but i'm still sitting at 0%
Has the folding moved from 0% yet? Just asking because some WU's take longer to complete a frame. If not, I have searched back and can provide some more links to directions persons have used to get a working install of the Catalyst drivers on their systems.Phiniac wrote:okay...that got opencl back but i'm still sitting at 0%
Step by step directions were posted by a F@H forum member, stickg1. Another forum poster, Krusher33, provided a link to some installation workarounds posted on the Overclock.net forums. Hope this gets you up and folding.
just got done downloading everything. I did a right click/finish on my current WU and i'm waiting for that to complete. But so far, yeah, the gpu WU is still sitting at 0%. I'll get started on the directions you linked to shortly and will post back with the results. I really appreciate your help with this, thank you very much!
what an absolute nightmare. Step one: uninstall catalyst driver=BSOD. Reboot=BSOD. System restore got me back up again. But anytime i tried to uninstall or reinstall catalyst drivers it gave me the dreaded blue screen. I've given up on GPU folding, I'm just happy to be up and running again the way i was before embarking on this mission. I've spent several hours on this and the wife is now pissed. I was just trying to catch up to her stats, which is odd considering i have the better computer. She has a i7 2600 running stock, i got a 3770k set to 4.5ghz. I've folded 100 wu's for 158k and she's folded 37 wu's for 172K points. Not sure why that is, but oh well....
jrweiss
Unfortunately, GPU Folding on AMD cards impacts CPU Folding MUCH more than you would think by the 2-3% CPU utilization indicated by the GPU FAHcore process in Task Manager. I found a while back that I lost more in my SMP productivity than my 4670 gave me back. That, along with driver issues and heat/power considerations drove me out of GPU Folding altogether (even though I now have a 7750 that is allegedly capable of handling the new FAHcores).
Some times it's just the luck of the draw in current projects that determines short-term PPD...
