SMP servers rejecting?
DocJonz
Post by DocJonz »
Have a couple of WU's struggling to link to;
128.143.231.201 and
128.143.199.96
Most of 'Kasson's' 'SMP' servers look like they are in 'Reject' on the server stats ..... is this the issue?
[08:45:00] - Machine ID: 2
[08:45:00]
[08:45:00] Loaded queue successfully.
[08:45:00] Deleting incompletely fetched item (4) from queue position #3
[08:45:00] - Warning: Could not delete all work unit files (3): Core file absent
[08:45:00] - Preparing to get new work unit...
[08:45:00] - Autosending finished units... [December 30 08:45:00 UTC]
[08:45:00] Cleaning up work directory
[08:45:00] Trying to send all finished work units
[08:45:00] Project: 6980 (Run 0, Clone 61, Gen 291)
[08:45:00] + Attempting to get work packet
[08:45:00] Passkey found
[08:45:00] + Attempting to send results [December 30 08:45:00 UTC]
[08:45:00] - Will indicate memory of 2775 MB
[08:45:00] - Reading file work/wuresults_02.dat from core
[08:45:00] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[08:45:00] - Connecting to assignment server
[08:45:00] Connecting to http://assign.stanford.edu:8080/
[08:45:00]   (Read 3522175 bytes from disk)
[08:45:00] Connecting to http://128.143.199.96:8080/
[08:45:01] Posted data.
[08:45:01] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[08:45:01] + Couldn't get work instructions.
[08:45:01] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[08:45:12] + Attempting to get work packet
[08:45:12] Passkey found
[08:45:12] - Will indicate memory of 2775 MB
[08:45:12] - Connecting to assignment server
[08:45:12] Connecting to http://assign.stanford.edu:8080/
[08:45:13] Posted data.
[08:45:13] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[08:45:13] + Couldn't get work instructions.
[08:45:13] - Attempt #2  to get work failed, and no other work to do.
[08:45:21] - Couldn't send HTTP request to server
[08:45:21] + Could not connect to Work Server (results)
[08:45:21]     (128.143.199.96:8080)
[08:45:21] + Retrying using alternative port
[08:45:21] Connecting to http://128.143.199.96:80/
[08:45:30] + Attempting to get work packet
[08:45:30] Passkey found
[08:45:30] - Will indicate memory of 2775 MB
[08:45:30] - Connecting to assignment server
[08:45:30] Connecting to http://assign.stanford.edu:8080/
[08:45:30] Posted data.
[08:45:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[08:45:30] + Couldn't get work instructions.
[08:45:30] - Attempt #3  to get work failed, and no other work to do.
[08:45:42] - Couldn't send HTTP request to server
[08:45:42] + Could not connect to Work Server (results)
[08:45:42]     (128.143.199.96:80)
[08:45:42] - Error: Could not transmit unit 02 (completed December 30) to work server.
[08:45:42] - 5 failed uploads of this unit.
[08:45:42] + Attempting to send results [December 30 08:45:42 UTC]
[08:45:42] - Reading file work/wuresults_02.dat from core
[08:45:42]   (Read 3522175 bytes from disk)
[08:45:42] Connecting to http://128.143.231.201:8080/
[08:45:58] + Attempting to get work packet
[08:45:58] Passkey found
[08:45:58] - Will indicate memory of 2775 MB
[08:45:58] - Connecting to assignment server
[08:45:58] Connecting to http://assign.stanford.edu:8080/
[08:45:59] Posted data.
[08:45:59] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[08:45:59] + Couldn't get work instructions.
[08:45:59] - Attempt #4  to get work failed, and no other work to do.
[08:46:40] + Attempting to get work packet
[08:46:40] Passkey found
[08:46:40] - Will indicate memory of 2775 MB
[08:46:40] - Connecting to assignment server
[08:46:40] Connecting to http://assign.stanford.edu:8080/
[08:46:40] Posted data.
[08:46:40] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[08:46:40] + Couldn't get work instructions.
[08:46:40] - Attempt #5  to get work failed, and no other work to do.
[08:48:14] + Attempting to get work packet
[08:48:14] Passkey found
[08:48:14] - Will indicate memory of 2775 MB
[08:48:14] - Connecting to assignment server
[08:48:14] Connecting to http://assign.stanford.edu:8080/
[08:48:14] Posted data.
[08:48:14] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[08:48:14] + Couldn't get work instructions.
[08:48:14] - Attempt #6  to get work failed, and no other work to do.
[08:48:50] - Couldn't send HTTP request to server
[08:48:50] + Could not connect to Work Server (results)
[08:48:50]     (128.143.231.201:8080)
[08:48:50] + Retrying using alternative port
[08:48:50] Connecting to http://128.143.231.201:80/
[08:49:11] - Couldn't send HTTP request to server
[08:49:11] + Could not connect to Work Server (results)
[08:49:11]     (128.143.231.201:80)
[08:49:11]   Could not transmit unit 02 to Collection server; keeping in queue.
[08:49:11] + Sent 0 of 1 completed units to the server
[08:49:11] - Autosend completed
[08:50:59] + Attempting to get work packet
[08:51:00] Passkey found
[08:51:00] - Will indicate memory of 2775 MB
[08:51:00] - Connecting to assignment server
[08:51:00] Connecting to http://assign.stanford.edu:8080/
[08:51:01] Posted data.
[08:51:01] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[08:51:01] + Couldn't get work instructions.
[08:51:01] - Attempt #7  to get work failed, and no other work to do.
[08:56:28] + Attempting to get work packet
[08:56:28] Passkey found
[08:56:28] - Will indicate memory of 2775 MB
[08:56:28] - Connecting to assignment server
[08:56:28] Connecting to http://assign.stanford.edu:8080/
[08:56:29] Posted data.
[08:56:29] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[08:56:29] + Couldn't get work instructions.
[08:56:29] - Attempt #8  to get work failed, and no other work to do.
Folding Stats (now via v8 webclient)
bollix47
Re: SMP servers rejecting?
Post by bollix47 »
Being in "Reject" would certainly cause the client some problems for downloading and uploading. The client should be able to download work from other servers. Some work servers may have a separate collection server to take the upload but at least one of those(128.143.199.97) is also showing "Reject".
Whether the cause is actually a problem or they're doing some kind of maintenance I do not know but doing maintenance in the early morning hours is a fairly common practice. Since it's very early on a Sunday morning here in the eastern time zone where those servers are located we can only be patient and wait for the situation to be rectified.
I'll keep an eye on the status and if it lasts much longer I'll ping the necessary people.
-alias-
Post by -alias- »
The work server on 128.143.231.201 are in problems, thats for sure. I have 4 810x WU´s waiting to be uploaded!
bollix47
Post by bollix47 »
The servers appear to be coming back up. One of my earlier failed attempts to 128.143.231.202 has already uploaded.
-alias-
Post by -alias- »
Thanks, same here, all of my failed are now uploaded.
DocJonz
Post by DocJonz »
Yep - looks like servers are back in business :D
kasson
Pande Group Member
Post by kasson »
The University of Virginia had a brief problem with our primary and backup internet connections, reported at 3:44am EST this morning, backup connection resolved at 4:48am.
