Project: 3064 (Run 5, Clone 209, Gen 2)
Jeannie
Post by Jeannie »
EUE at 22% -
[06:16:47] Completed 1100000 out of 5000000 steps (22 percent)
[06:19:01] Warning: long 1-4 interactions
[09:16:48] At least 3 hours since checkpoint written...
[09:16:48]
[09:16:48] Folding@home Core Shutdown: EARLY_UNIT_END
This has happened twice on my stock Q66 running Windows Vista, SMP 5.91
Re: Project: 3064 (Run 5, Clone 209, Gen 2)
You might want to submit partial results to tell the system this WU will not complete on your computer : viewtopic.php?f=8&t=191 ;)
zorzyk
Hardware configuration: abit IP35 PRO,
Q6600/B3 3042 MHz (9*338) / CPU VCore 1.3550V,
DDR2 4x1GB: Corsair Twin2X DDR2 800MHz CL4-4-4-12 DHX @ 845 MHz CL4-4-4-12 / 2.2V
Post by zorzyk »
I encountred the same "1-4 long interaction" error 2 days ago:
[23:55:23] 17:33:25] Project: 3062 (Run 3, Clone 77, Gen 26)
[17:33:25]
[17:33:25] Assembly optimizations on if available.
[17:33:25] Entering M.D.
[17:33:31] Rejecting checkpoint
[17:33:32] ProteinWriting local files
[17:33:32] Extra SSE boost OK.
[17:33:32]
[17:33:32] Writing local files
[17:33:32] Completed 0 out of 5000000 steps  (0 percent)
[17:42:51] Writing local files
[23:57:43] Completed 2050000 out of 5000000 steps  (41 percent)
[23:57:43] Warning:  long 1-4 interactions
[23:57:43] Gromacs cannot continue further.
[23:57:43] Going to send back what have done.
[23:57:43] logfile size: 59743
[23:57:43] - Writing 60279 bytes of core data to disk...
[23:57:43]   ... Done.
[23:57:43] - Failed to delete work/wudata_01.arc
[23:57:43] - Failed to delete work/wudata_01.sas
[23:57:43] - Failed to delete work/wudata_01.goe
[23:57:43] Warning:  check for stray files
[23:59:43]
[23:59:43] Folding@home Core Shutdown: EARLY_UNIT_END
[23:59:43]
[23:59:46] CoreStatus = 7B (123)
[23:59:46] Client-core communications error: ERROR 0x7b
[23:59:46] Deleting current work unit & continuing...
Fortunately internet was switched off by night, and client could not connect to assignment sever :). I rolled back the copy made at 23:30 and tried to continue. After next same EUE (at 46%) I decided to boost CPU VCore voltage one step further - that cured problems and I've finished the WU without any problem.
I see projecsts 30xx are more demanding for the hardware than 2653's were. Maybe it would be necessary to inspect OC settings that worked well until now.
rbrandman
Pande Group Member
Post by rbrandman »
Thanks for your post. I've alerted the researcher in charge of this project about the errors you are seeing.
Relly
DanEnsign
Pande Group Member
Post by DanEnsign »
Please see viewtopic.php?f=19&t=2704&p=24859#p24773.
joce
Post by joce »
Same issue here :
[16:29:28] *------------------------------*
[16:29:28] Folding@Home Gromacs SMP Core
[16:29:28] Version 1.74 (March 10, 2007)
[16:29:28]
[16:29:28] Preparing to commence simulation
[16:29:28] - Ensuring status. Please wait.
[16:29:45] - Assembly optimizations manually forced on.
[16:29:45] - Not checking prior termination.
[16:29:45] - Expanded 609872 -> 3263429 (decompressed 535.1 percent)
[16:29:45] - Starting from initial work packet
[16:29:45]
[16:29:45] Project: 3064 (Run 2, Clone 51, Gen 49)
[16:29:45]
[16:29:46] Assembly optimizations on if available.
[16:29:46] Entering M.D.
[16:29:52] Protein: p3064_lambdaProteinWriting local files
[16:29:52] Extra SSE boost OK.
[16:29:52]
[16:29:52] Writing local files
[16:29:52] Completed 0 out of 5000000 steps  (0 percent)
[16:44:52] Timered checkpoint triggered.
[16:50:45] Writing local files
[16:50:45] Completed 50000 out of 5000000 steps  (1 percent)
[17:05:46] Timered checkpoint triggered.
[17:12:00] Writing local files
[17:12:00] Completed 100000 out of 5000000 steps  (2 percent)
[17:27:01] Timered checkpoint triggered.
[17:32:22] Writing local files
[17:32:22] Completed 150000 out of 5000000 steps  (3 percent)
[17:47:23] Timered checkpoint triggered.
[17:52:45] Writing local files
[17:52:45] Completed 200000 out of 5000000 steps  (4 percent)
[18:07:45] Timered checkpoint triggered.
[18:08:18] - Autosending finished units...
[18:08:18] Trying to send all finished work units
[18:08:18] + No unsent completed units remaining.
[18:08:18] - Autosend completed
[18:13:09] Writing local files
[18:13:09] Completed 250000 out of 5000000 steps  (5 percent)
[18:28:09] Timered checkpoint triggered.
[18:33:32] Writing local files
[18:33:33] Completed 300000 out of 5000000 steps  (6 percent)
[18:48:33] Timered checkpoint triggered.
[18:53:55] Writing local files
[18:53:55] Completed 350000 out of 5000000 steps  (7 percent)
[19:08:55] Timered checkpoint triggered.
[19:14:19] Writing local files
[19:14:20] Completed 400000 out of 5000000 steps  (8 percent)
[19:29:20] Timered checkpoint triggered.
[19:34:43] Writing local files
[19:34:43] Completed 450000 out of 5000000 steps  (9 percent)
[19:49:43] Timered checkpoint triggered.
[19:55:07] Writing local files
[19:55:07] Completed 500000 out of 5000000 steps  (10 percent)
[20:10:07] Timered checkpoint triggered.
[20:15:35] Writing local files
[20:15:35] Completed 550000 out of 5000000 steps  (11 percent)
[20:30:35] Timered checkpoint triggered.
[20:35:57] Writing local files
[20:35:57] Completed 600000 out of 5000000 steps  (12 percent)
[20:49:48] Gromacs cannot continue further.
[20:49:48] Going to send back what have done.
[20:49:48] logfile size: 24290
[20:49:48] - Writing 24826 bytes of core data to disk...
[20:49:48]   ... Done.
[20:49:48] - Failed to delete work/wudata_04.arc
[20:49:48] - Failed to delete work/wudata_04.chk
[20:49:48] - Failed to delete work/wudata_04.sas
[20:49:48] - Failed to delete work/wudata_04.goe
[20:49:48] Warning:  check for stray files
[20:51:48]
[20:51:48] Folding@home Core Shutdown: EARLY_UNIT_END
[20:51:48]
[00:08:18] - Autosending finished units...
[00:08:18] Trying to send all finished work units
[00:08:18] + No unsent completed units remaining.
[00:08:18] - Autosend completed
[06:08:18] - Autosending finished units...
[06:08:18] Trying to send all finished work units
[06:08:18] + No unsent completed units remaining.
[06:08:18] - Autosend completed
Macpro 2,66 GHz Quad, 6 Go DDR3, ATI Radeon HD 4870 512 Mo
