It continues calculating after 100% finished.
--- Opening Log file [December 23 23:38:35 UTC]
# Windows GPU Systray Edition #################################################
Folding@Home Client Version 6.41r2
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Sattva\Application Data\Folding@home-gpu
[23:38:35] Gpu type=2 species=30.
[23:39:52] - Ask before connecting: Yes
[23:39:52] - User name: Sattva (Team 0)
[23:39:52] - User ID not found locally
[23:39:52] + Requesting User ID from server
[23:39:52] - Presenting message box asking to network.
[23:39:58] - Machine ID: 2
[23:39:58]
[23:39:58] Work directory not found. Creating...
[23:39:58] Could not open work queue, generating new queue...
[23:39:58] Initialization complete
[23:39:58] - Preparing to get new work unit...
[23:39:58] Cleaning up work directory
[23:39:58] + Attempting to get work packet
[23:39:58] Gpu type=2 species=30.
[23:39:58] - Connecting to assignment server
[23:39:59] - Successful: assigned to (171.67.108.11).
[23:39:59] + News From Folding@Home: Welcome to Folding@Home
[23:39:59] Loaded queue successfully.
[23:39:59] Gpu type=2 species=30.
[23:40:01] + Connections closed: You may now disconnect
[23:40:01]
[23:40:01] + Processing work unit
[23:40:01] Core required: FahCore_11.exe
[23:40:01] Core not found.
[23:40:01] - Core is not present or corrupted.
[23:40:01] - Attempting to download new core...
[23:40:01] + Downloading new core: FahCore_11.exe
[23:40:01] - Presenting message box asking to network.
[23:40:05] + 10240 bytes downloaded
[23:40:05] + 20480 bytes downloaded
[23:40:06] + 30720 bytes downloaded
[23:40:06] + 40960 bytes downloaded
[23:40:06] + 51200 bytes downloaded
[23:40:06] + 61440 bytes downloaded
[23:40:06] + 71680 bytes downloaded
[23:40:06] + 81920 bytes downloaded
[23:40:06] + 92160 bytes downloaded
[23:40:06] + 102400 bytes downloaded
[23:40:06] + 112640 bytes downloaded
[23:40:06] + 122880 bytes downloaded
[23:40:06] + 133120 bytes downloaded
[23:40:06] + 143360 bytes downloaded
[23:40:06] + 153600 bytes downloaded
[23:40:06] + 163840 bytes downloaded
[23:40:06] + 174080 bytes downloaded
[23:40:07] + 184320 bytes downloaded
[23:40:07] + 194560 bytes downloaded
[23:40:07] + 204800 bytes downloaded
[23:40:07] + 215040 bytes downloaded
[23:40:07] + 225280 bytes downloaded
[23:40:07] + 235520 bytes downloaded
[23:40:07] + 245760 bytes downloaded
[23:40:07] + 256000 bytes downloaded
[23:40:07] + 266240 bytes downloaded
[23:40:07] + 276480 bytes downloaded
[23:40:07] + 286720 bytes downloaded
[23:40:07] + 296960 bytes downloaded
[23:40:07] + 307200 bytes downloaded
[23:40:07] + 317440 bytes downloaded
[23:40:08] + 327680 bytes downloaded
[23:40:08] + 337920 bytes downloaded
[23:40:08] + 348160 bytes downloaded
[23:40:08] + 358400 bytes downloaded
[23:40:08] + 368640 bytes downloaded
[23:40:08] + 378880 bytes downloaded
[23:40:08] + 389120 bytes downloaded
[23:40:08] + 399360 bytes downloaded
[23:40:08] + 409600 bytes downloaded
[23:40:08] + 419840 bytes downloaded
[23:40:08] + 430080 bytes downloaded
[23:40:08] + 440320 bytes downloaded
[23:40:08] Gpu type=2 species=30.
[23:40:08] + 450560 bytes downloaded
[23:40:08] + 460800 bytes downloaded
[23:40:08] + 471040 bytes downloaded
[23:40:09] + 481280 bytes downloaded
[23:40:09] + 491520 bytes downloaded
[23:40:09] + 501760 bytes downloaded
[23:40:09] + 512000 bytes downloaded
[23:40:09] + 522240 bytes downloaded
[23:40:09] + 532480 bytes downloaded
[23:40:09] + 542720 bytes downloaded
[23:40:09] + 552960 bytes downloaded
[23:40:09] + 563200 bytes downloaded
[23:40:09] + 573440 bytes downloaded
[23:40:09] + 583680 bytes downloaded
[23:40:09] + 593920 bytes downloaded
[23:40:09] + 604160 bytes downloaded
[23:40:09] + 614400 bytes downloaded
[23:40:09] + 624640 bytes downloaded
[23:40:10] + 634880 bytes downloaded
[23:40:10] + 645120 bytes downloaded
[23:40:10] + 655360 bytes downloaded
[23:40:10] + 665067 bytes downloaded
[23:40:10] Verifying core Core_11.fah...
[23:40:10] Signature is VALID
[23:40:10]
[23:40:10] Trying to unzip core FahCore_11.exe
[23:40:10] Decompressed FahCore_11.exe (1908736 bytes) successfully
[23:40:15] + Core successfully engaged
[23:40:21]
[23:40:21] + Processing work unit
[23:40:21] Core required: FahCore_11.exe
[23:40:21] Core found.
[23:40:21] Working on queue slot 01 [December 23 23:40:21 UTC]
[23:40:21] + Working ...
[23:40:22]
[23:40:22] *------------------------------*
[23:40:22] Folding@Home GPU Core
[23:40:22] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:40:22]
[23:40:22] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:40:22] Build host: amoeba
[23:40:22] Board Type: Nvidia
[23:40:22] Core :
[23:40:22] Preparing to commence simulation
[23:40:22] - Looking at optimizations...
[23:40:22] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[23:40:22] - Created dyn
[23:40:22] - Files status OK
[23:40:22] - Expanded 46699 -> 252912 (decompressed 541.5 percent)
[23:40:22] Called DecompressByteArray: compressed_data_size=46699 data_size=252912, decompressed_data_size=252912 diff=0
[23:40:22] - Digital signature verified
[23:40:22]
[23:40:22] Project: 5767 (Run 6, Clone 24, Gen 3228)
[23:40:22]
[23:40:22] Assembly optimizations on if available.
[23:40:22] Entering M.D.
[23:40:28] Tpr hash work/wudata_01.tpr: 689558038 3544914840 2794658532 3228227924 500177688
[23:40:28]
[23:40:28] Calling fah_main args: 14 usage=100
[23:40:28]
[23:40:44] Opening C:\Documents and Settings\Sattva\Application Data\Folding@home-gpu\MyFolding.html...
[23:41:02] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Sattva...
[23:50:32] CoreStatus = 62 (98)
[23:50:32] + Restarting core (settings changed)
[23:50:32]
[23:50:32] + Processing work unit
[23:50:32] Core required: FahCore_11.exe
[23:50:32] Core found.
[23:50:32] Working on queue slot 01 [December 23 23:50:32 UTC]
[23:50:32] + Working ...
[23:50:32]
[23:50:32] *------------------------------*
[23:50:32] Folding@Home GPU Core
[23:50:32] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:50:32]
[23:50:32] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:50:32] Build host: amoeba
[23:50:32] Board Type: Nvidia
[23:50:32] Core :
[23:50:32] Preparing to commence simulation
[23:50:32] - Ensuring status. Please wait.
[23:50:44] CoreStatus = 62 (98)
[23:50:44] + Restarting core (settings changed)
[23:50:44]
[23:50:44] + Processing work unit
[23:50:44] Core required: FahCore_11.exe
[23:50:44] Core found.
[23:50:44] Working on queue slot 01 [December 23 23:50:44 UTC]
[23:50:44] + Working ...
[23:50:44]
[23:50:44] *------------------------------*
[23:50:44] Folding@Home GPU Core
[23:50:44] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:50:44]
[23:50:44] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:50:44] Build host: amoeba
[23:50:44] Board Type: Nvidia
[23:50:44] Core :
[23:50:44] Preparing to commence simulation
[23:50:44] - Ensuring status. Please wait.
[23:50:54] - Looking at optimizations...
[23:50:54] - Not checking prior termination.
[23:50:54] - Expanded 46699 -> 252912 (decompressed 541.5 percent)
[23:50:54] Called DecompressByteArray: compressed_data_size=46699 data_size=252912, decompressed_data_size=252912 diff=0
[23:50:54] - Digital signature verified
[23:50:54]
[23:50:54] Project: 5767 (Run 6, Clone 24, Gen 3228)
[23:50:54]
[23:50:54] Assembly optimizations on if available.
[23:50:54] Entering M.D.
[23:51:00] Tpr hash work/wudata_01.tpr: 689558038 3544914840 2794658532 3228227924 500177688
[23:51:00]
[23:51:00] Calling fah_main args: 14 usage=100
[23:51:00]
[23:57:55] Gpu type=2 species=30.
[23:58:17] Gpu type=2 species=30.
[23:58:35] Gpu type=2 species=30.
[00:00:35] Gpu type=2 species=30.
[00:00:50] Gpu type=2 species=30.
[00:01:56] Opening http://foldingforum.org/...
[00:03:18] Gpu type=2 species=30.
Folding@Home Client Shutdown.
--- Opening Log file [December 24 00:06:39 UTC]
[00:06:39] - Ask before connecting: Yes
[00:06:39] - User name: Sattva (Team 0)
[00:06:39] - User ID: 5D00360E7ACA19FF
[00:06:39] - Machine ID: 2
[00:06:39]
[00:06:39] Gpu type=2 species=30.
[00:06:39] Loaded queue successfully.
[00:06:39] Initialization complete
[00:06:39]
[00:06:39] + Processing work unit
[00:06:39] Core required: FahCore_11.exe
[00:06:39] Core found.
[00:06:39] Working on queue slot 01 [December 24 00:06:39 UTC]
[00:06:39] + Working ...
[00:06:39]
[00:06:39] *------------------------------*
[00:06:39] Folding@Home GPU Core
[00:06:39] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[00:06:39]
[00:06:39] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:06:39] Build host: amoeba
[00:06:39] Board Type: Nvidia
[00:06:39] Core :
[00:06:39] Preparing to commence simulation
[00:06:39] - Ensuring status. Please wait.
[00:06:43] Gpu type=2 species=30.
[00:06:49] - Looking at optimizations...
[00:06:49] - Working with standard loops on this execution.
[00:06:49] - Previous termination of core was improper.
[00:06:49] - Files status OK
[00:06:49] - Expanded 46699 -> 252912 (decompressed 541.5 percent)
[00:06:49] Called DecompressByteArray: compressed_data_size=46699 data_size=252912, decompressed_data_size=252912 diff=0
[00:06:49] - Digital signature verified
[00:06:49]
[00:06:49] Project: 5767 (Run 6, Clone 24, Gen 3228)
[00:06:49]
[00:06:49] Entering M.D.
[00:06:55] Tpr hash work/wudata_01.tpr: 689558038 3544914840 2794658532 3228227924 500177688
[00:06:55]
[00:06:55] Calling fah_main args: 14 usage=100
[00:06:55]
[02:01:15] Gpu type=2 species=30.
--- Opening Log file [December 24 08:53:30 UTC]
[08:53:30] - Ask before connecting: Yes
[08:53:30] - User name: Sattva (Team 0)
[08:53:30] - User ID: 5D00360E7ACA19FF
[08:53:30] - Machine ID: 2
[08:53:30]
[08:53:30] Gpu type=2 species=30.
[08:53:31] Loaded queue successfully.
[08:53:31] Initialization complete
[08:53:31]
[08:53:31] + Processing work unit
[08:53:31] Core required: FahCore_11.exe
[08:53:31] Core found.
[08:53:31] Working on queue slot 01 [December 24 08:53:31 UTC]
[08:53:31] + Working ...
[08:53:39]
[08:53:39] *------------------------------*
[08:53:39] Folding@Home GPU Core
[08:53:39] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[08:53:39]
[08:53:39] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:53:39] Build host: amoeba
[08:53:39] Board Type: Nvidia
[08:53:39] Core :
[08:53:39] Preparing to commence simulation
[08:53:39] - Ensuring status. Please wait.
[08:53:49] - Looking at optimizations...
[08:53:49] - Working with standard loops on this execution.
[08:53:49] - Previous termination of core was improper.
[08:53:49] - Going to use standard loops.
[08:53:49] - Files status OK
[08:53:49] - Expanded 46699 -> 252912 (decompressed 541.5 percent)
[08:53:49] Called DecompressByteArray: compressed_data_size=46699 data_size=252912, decompressed_data_size=252912 diff=0
[08:53:49] - Digital signature verified
[08:53:49]
[08:53:49] Project: 5767 (Run 6, Clone 24, Gen 3228)
[08:53:49]
[08:53:49] Entering M.D.
[08:53:55] Tpr hash work/wudata_01.tpr: 689558038 3544914840 2794658532 3228227924 500177688
[08:53:55]
[08:53:55] Calling fah_main args: 14 usage=100
[08:53:55]
[08:54:21] Gpu type=2 species=30.
--- Opening Log file [December 24 09:44:03 UTC]
[09:44:03] - Ask before connecting: Yes
[09:44:03] - User name: Sattva (Team 0)
[09:44:03] - User ID: 5D00360E7ACA19FF
[09:44:03] - Machine ID: 2
[09:44:03]
[09:44:03] Gpu type=2 species=30.
[09:44:03] Loaded queue successfully.
[09:44:03] Initialization complete
[09:44:03]
[09:44:03] + Processing work unit
[09:44:03] Core required: FahCore_11.exe
[09:44:03] Core found.
[09:44:03] Working on queue slot 01 [December 24 09:44:03 UTC]
[09:44:03] + Working ...
[09:44:03]
[09:44:03] *------------------------------*
[09:44:03] Folding@Home GPU Core
[09:44:03] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[09:44:03]
[09:44:03] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:44:03] Build host: amoeba
[09:44:03] Board Type: Nvidia
[09:44:03] Core :
[09:44:03] Preparing to commence simulation
[09:44:03] - Ensuring status. Please wait.
[09:44:08] Gpu type=2 species=30.
[09:44:13] - Looking at optimizations...
[09:44:13] - Working with standard loops on this execution.
[09:44:13] - Previous termination of core was improper.
[09:44:13] - Going to use standard loops.
[09:44:13] - Files status OK
[09:44:13] - Expanded 46699 -> 252912 (decompressed 541.5 percent)
[09:44:13] Called DecompressByteArray: compressed_data_size=46699 data_size=252912, decompressed_data_size=252912 diff=0
[09:44:13] - Digital signature verified
[09:44:13]
[09:44:13] Project: 5767 (Run 6, Clone 24, Gen 3228)
[09:44:13]
[09:44:13] Entering M.D.
[09:44:19] Tpr hash work/wudata_01.tpr: 689558038 3544914840 2794658532 3228227924 500177688
[09:44:19]
[09:44:19] Calling fah_main args: 14 usage=100
[09:44:19]
[16:51:24] + Working...
[19:51:48] Printing Queue Information
Current Queue:
Slot 02 Empty/Deleted
Slot 03 Empty/Deleted
Slot 04 Empty/Deleted
Slot 05 Empty/Deleted
Slot 06 Empty/Deleted
Slot 07 Empty/Deleted
Slot 08 Empty/Deleted
Slot 09 Empty/Deleted
Slot 00 Empty/Deleted
Slot 01 *Active
Project: 5767 (Run 6, Clone 24, Gen 3228), Core: 11
Work server: 171.67.108.11:8080
Collection server: 171.67.108.25
Download date: December 23 23:40:01
Deadline date: December 26 23:40:01
PF: 0.000000 based on last 0 slot(s)
[19:51:58] Printing Queue Information
Current Queue:
Slot 01 *Active
[19:54:12] Opening http://foldingforum.org/...
