Search for Teams
Hiyachoppy
Search for Teams
I used to own a PS3 and had a team that I set up on there. I don't remember the team number, is there a way to search for teams?
art_l_j_PlanetAMD64
Re: Search for Teams
The PS3 client is no longer supported, but if you go here, you can search for any team by name.Hiyachoppy wrote:I used to own a PS3 and had a team that I set up on there. I don't remember the team number, is there a way to search for teams?
Hope this helps!
art_l_j_PlanetAMD64
Over 1.04 Billion Total Points
Over 185,000 Work Units
Over 3,800,000 PPD
Overall rank (if points are combined) 20 of 1721690
In memory of my Mother May 12th 1923 - February 10th 2012
Over 3,800,000 PPD
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Welcome to the Folding@home support forum Hyachoppy!
There's a way, and it's relatively easy. Go to this page: http://fah-web.stanford.edu/cgi-bin/mai ... =teamstats and then type in the "team name" field. Then hit the enter key or press "Search". If you don't type the team name exactly, try changing the drop-down to "is like" and you'll get more results that way. Good luck.
Edit: art_l_j_PlanetAMD64 is exactly right.
uncle fuzzy
If you know the name you folded under, you can go to the All Users list at EOC and search (left side). The search results will show user and team. Click team and look at the url. The team number will be at the end.
http://folding.extremeoverclocking.com/ ... ist.php?s=
I found nothing with the name you used here.
You can also seach by name here to find the team.
http://fah-web.stanford.edu/cgi-bin/mai ... =userstats
