twin GTX560Ti can't get work
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
Post by dschief »
2 clients can't get any work, both 560Ti's. 2 gtx275's & 2 9800GTX+'s are fine. seems to be connecting but not getting appropriate server?
Launch directory: Z:\home\jim\gtx1
Executable: Z:\home\jim\gtx1\fah6.exe
Arguments: -oneunit -verbosity 9 -gpu 0 -forcegpu nvidia_fermi
[02:51:54] - Ask before connecting: No
[02:51:54] - User name: dschief (Team 13761)
[02:51:54] - User ID: xxxxx  xx8E
[02:51:54] - Machine ID: 2
[02:51:54]
[02:51:55] Loaded queue successfully.
[02:51:55] - Preparing to get new work unit...
[02:51:55] - Autosending finished units... [December 18 02:51:55 UTC]
[02:51:55] Trying to send all finished work units
[02:51:55] + Attempting to get work packet
[02:51:55] + No unsent completed units remaining.
[02:51:55] - Autosend completed
[02:51:55] - Will indicate memory of 3961 MB
[02:51:55] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 2
[02:51:55] - Connecting to assignment server
[02:51:55] Connecting to http://assign-GPU.stanford.edu:8080/
[02:51:55] Posted data.
[02:51:55] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[02:51:55] + Couldn't get work instructions.
[02:51:55] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[02:52:08] + Attempting to get work packet
[02:52:08] - Will indicate memory of 3961 MB
[02:52:08] - Connecting to assignment server
[02:52:08] Connecting to http://assign-GPU.stanford.edu:8080/
[02:52:08] Posted data.
[02:52:08] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[02:52:08] + Couldn't get work instructions.
[02:52:08] - Attempt #2  to get work failed, and no other work to do.
[02:52:33] + Attempting to get work packet
[02:52:33] - Will indicate memory of 3961 MB
[02:52:33] - Connecting to assignment server
[02:52:33] Connecting to http://assign-GPU.stanford.edu:8080/
[02:52:33] Posted data.
[02:52:33] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[02:52:33] + Couldn't get work instructions.
[02:52:33] - Attempt #3  to get work failed, and no other work to do.
[02:52:55] + Attempting to get work packet
[02:52:55] - Will indicate memory of 3961 MB
[02:52:55] - Connecting to assignment server
[02:52:55] Connecting to http://assign-GPU.stanford.edu:8080/
[02:52:55] Posted data.
[02:52:55] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[02:52:55] + Couldn't get work instructions.
[02:52:55] - Attempt #4  to get work failed, and no other work to do.
[02:53:39] + Attempting to get work packet
[02:53:39] - Will indicate memory of 3961 MB
[02:53:39] - Connecting to assignment server
[02:53:39] Connecting to http://assign-GPU.stanford.edu:8080/
[02:53:39] Posted data.
[02:53:39] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[02:53:39] + Couldn't get work instructions.
[02:53:39] - Attempt #5  to get work failed, and no other work to do.
[02:55:01] + Attempting to get work packet
[02:55:01] - Will indicate memory of 3961 MB
[02:55:01] - Connecting to assignment server
[02:55:01] Connecting to http://assign-GPU.stanford.edu:8080/
[02:55:01] Posted data.
[02:55:01] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[02:55:01] + Couldn't get work instructions.
[02:55:01] - Attempt #6  to get work failed, and no other work to do.
checked server stats but that did'nt help much
Update, now non fermi clients are'nt getting work either, 19:17 local time
Re: twin GTX560Ti can't get work
Serverstat is showing a number of servers are off-line (Reject). I'm not sure why but the Pande Group has been notified.
dschief
EVGA1060
Post by dschief »
UPDATE!! Found problem to be the one holding the Mouse!
Had been going in circles for hrs. then this am I saw it 6.23 looking back at me. As soon as I deleted it, & dropped in 6.41 everything fired up.
sorry for casting doubt upon the Hallowed halls of stanford
dschief wrote:UPDATE!! Found problem to be the one holding the Mouse!
More commonly known as PEBCAK or PEBKAC. ;)
