Is this the place for support?
Was something wrong with my post? I posted it over 12 hours ago.
HTPC-AMD X4 9850BE@2.5 4GB PC2 ATI HD5830 1GB ram no OC V7.2.9 on Windows 7 Home premium X64
Main PC AMD Phenom II X4 940@3GHz 8GB PC2 ATI HD5830 1GB ram no OC V7.2.9 on Windows 7 Home premium X64
Re: Is this the place for support?
As I unuderstand it the problem is not at your end so you may just need to wait. There is an issue reported and updated here
single 1070
Also, you posted a message at 2:58 and got a reply that included instructions to fix within 6 minutes.
single 1070
This post or this one?
Sometimes a post will be moved to a more appropriate thread. If you ever have a problem finding a post you're sure was submitted correctly you can always go to your User Control Panel (link above) and click on Show Your Posts.
I got an email stating that the post had been approved and when I followed the link from the Email it said that the post did not exist. So I was a bit confused as this was my first time posting here. But thank Now I know it is not on my fault I will wait for the situation to be resolved and then continue folding at that point.HaloJones wrote:As I understand it the problem is not at your end so you may just need to wait. There is an issue reported and updated here
Sorry I didnt get the reply. Hard to find what your looking for when it was not where you left itHaloJones wrote:Also, you posted a message at 2:58 and got a reply that included instructions to fix within 6 minutes.
Apologies for any confusion we may have caused. We may have moved your post to the more appropriate thread after approving it when we could have done it the other way around so that your e-mail would have directed you to the correct location.
It's been a little hectic around here for the past 24-36 hours so mistakes can happen but things seem to be getting better and hopefully all issues will be resolved soon.
LOOL i was absolutely certain it was my mistake. Because it usually is. AS I AM THE ORIGINAL OPERATOR ERRORbollix47 wrote:Apologies for any confusion we may have caused. We may have moved your post to the more appropriate thread after approving it when we could have done it the other way around so that your e-mail would have directed you to the correct location.
I was just a bit over sensitive as I was starring down the 2 million mark and was looking forward to bragging about it
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Wow, congratulations! There are plenty of people who never make it that far, so well done!Renigade wrote:I was just a bit over sensitive as I was starring down the 2 million mark and was looking forward to bragging about it
But there's always someone ahead of you to try to beat.
