Can't connect to 128.143.231.201
patonb
Post by patonb »
Trying to upload results and I'm not able to do so.
[16:08:09] - Preparing to get new work unit...
[16:08:09] - Autosending finished units... [December 7 16:08:09 UTC]
[16:08:09] Trying to send all finished work units
[16:08:09] Cleaning up work directory
[16:08:09] Project: 8101 (Run 9, Clone 10, Gen 110)
[16:08:09] + Attempting to get work packet
[16:08:09] Passkey found
[16:08:09] + Attempting to send results [December 7 16:08:09 UTC]
[16:08:09] - Will indicate memory of 12033 MB
[16:08:09] - Reading file work/wuresults_01.dat from core
[16:08:09] - Connecting to assignment server
[16:08:09] Connecting to http://assign.stanford.edu:8080/
[16:08:14]   (Read 91519038 bytes from disk)
[16:08:14] Connecting to http://128.143.231.201:8080/
[16:08:14] - Couldn't send HTTP request to server
[16:08:14] + Could not connect to Work Server (results)
[16:08:14]     (128.143.231.201:8080)
[16:08:14] + Retrying using alternative port
[16:08:14] Connecting to http://128.143.231.201:80/
[16:08:14]     (128.143.231.201:80)
[16:08:14] - Error: Could not transmit unit 01 (completed December 7) to work server.
[16:08:14] - 4 failed uploads of this unit.
[16:08:14] + Attempting to send results [December 7 16:08:14 UTC]
[16:08:14] - Reading file work/wuresults_01.dat from core
[16:08:14] Connecting to http://128.143.199.97:8080/
[16:08:14]     (128.143.199.97:8080)
[16:08:14] Connecting to http://128.143.199.97:80/
[16:08:14]     (128.143.199.97:80)
[16:08:14]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:08:14] + Sent 0 of 1 completed units to the server
[16:08:14] - Autosend completed
[16:08:14] - Could not CosmHTTPOpen
[16:08:14] + Could not connect to Assignment Server
[16:08:14] Connecting to http://assign2.stanford.edu:80/
[16:08:14] + Could not connect to Assignment Server 2
[16:08:14] + Couldn't get work instructions.
[16:08:14] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[16:08:18] + Attempting to get work packet
[16:08:18] Passkey found
[16:08:18] - Will indicate memory of 12033 MB
[16:08:18] - Connecting to assignment server
[16:08:18] Connecting to http://assign.stanford.edu:8080/
[16:08:19] Posted data.
[16:08:19] Initial: 8F80; - Successful: assigned to (128.143.231.201).
[16:08:19] + News From Folding@Home: Welcome to Folding@Home
[16:08:19] Loaded queue successfully.
[16:08:19] Sent data
[16:08:19] Connecting to http://128.143.231.201:8080/
[16:08:25] Posted data.
[16:08:25] Initial: 0000; - Receiving payload (expected size: 30292050)
[16:09:05] - Downloaded at ~739 kB/s
[16:09:05] - Averaged speed for that direction ~751 kB/s
[16:09:05] + Received work.
[16:09:05] + Closed connections
[16:09:05]
[16:09:05] + Processing work unit
[16:09:05] Core required: FahCore_a5.exe
[16:09:05] Core found.
[16:09:05] Working on queue slot 02 [December 7 16:09:05 UTC]
[16:09:05] + Working ...
[16:09:05] - Calling './FahCore_a5.exe -dir work/ -nice 19 -suffix 02 -np 24 -checkpoint 30 -verbose -lifeline 1530 -version 634'
[16:09:05]
[16:09:05] *------------------------------*
[16:09:05] Folding@Home Gromacs SMP Core
[16:09:05] Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
[16:09:05]
[16:09:05] Preparing to commence simulation
csvanefalk
Re: Can't connect to 128.143.231.201
Post by csvanefalk »
Have you gone through the troubleshooting checklist?
The server in question has a CPU load of 24.05, that is most likely where the problem is.
patonb
Post by patonb »
Noty sure of youre "steps", but I rebooted, system is headless, and a reboot has solved this before.
I've gone to ther server address and it opened, so I'm at a loss ion the next stage
csvanefalk
The steps are stickied in this forum. You should always follow them before opening a separate thread on server issues, to avoid clogging things up. In your case it is an upload issue, so be sure to checkout that section. For future reference, here they are: viewtopic.php?f=18&t=17794
Like I said, the server in question has unusually high CPU load. It is most likely congested and hence you cannot talk to it. Give it some time and see if it clears up, you should be able to keep folding another WU in the meantime. If it stops trying to reconnect, try resetting your client to kickstart the upload.
patonb wrote:Noty sure of youre "steps", but I rebooted, system is headless, and a reboot has solved this before.
There is a Do This First topic stickied at the top of this forum, those would be the steps referred to. As for the high load mentioned by csvanefalk, I don't know where he is getting that. The highest load listed in the logs the last 24 hours for 128.143.231.201 is 0.25.
Please post more of your log, the few minutes shown do not provide enough information. As for connecting to the WS, you did manage to do so and download another WU as shown in the log:
csvanefalk
Joe_H is right, I accidentally checked 128.143.231.202, which at the time I checked it had a CPU load of 24.05. Disregard it.
csvanefalk wrote:Joe_H is right, I accidentally checked 128.143.231.202, which at the time I checked it had a CPU load of 24.05. Disregard it.
That also has not had a high load reported. Which link were you using? The old ones are no longer updated, there should be "pybeta" in the URL to point to the current server stats and logs. If you start with the link at the top of the page, that will get you there.
I did find one possible source for a link to a page that shows the high number for .202, but that page was last updated in September. I have added a note to that section of the troubleshooting topic. If your link was from somewhere else, post the location and I will see about getting it updated.
csvanefalk
I was using the outdated links, I saw the notice just now (the one I looked at was http://fah-web.stanford.edu/localinfo/contact.SMP.html). Sorry for the mixup. Is there a reason these links are still provided if they are (seemingly) useless for troubleshooting due to not being updated anymore?
patonb
Post by patonb »
So I did check the servers as I said, I was able to open all of them fine..
As you saw in the log it has no problem downloading, and my other system is running just fine too.
Here's the log before the reboot right up to the end of the previous unit and d/l and run on the stuck one:
[10:09:07] Completed 250000 out of 250000 steps  (100%)
[10:09:17] DynamicWrapper: Finished Work Unit: sleep=10000
[10:09:27]
[10:09:27] Finished Work Unit:
[10:09:27] - Reading up to 64340496 from "work/wudata_09.trr": Read 64340496
[10:09:27] trr file hash check passed.
[10:09:28] - Reading up to 31618628 from "work/wudata_09.xtc": Read 31618628
[10:09:28] xtc file hash check passed.
[10:09:28] edr file hash check passed.
[10:09:28] logfile size: 192145
[10:09:28] Leaving Run
[10:09:30] - Writing 96312145 bytes of core data to disk...
[10:09:46] Done: 96311633 -> 91575760 (compressed to 5.8 percent)
[10:09:46]   ... Done.
[10:10:05] - Shutting down core
[10:10:05]
[10:10:05] Folding@home Core Shutdown: FINISHED_UNIT
[10:10:07] CoreStatus = 64 (100)
[10:10:07] Unit 9 finished with 52 percent of time to deadline remaining.
[10:10:07] Updated performance fraction: 0.564352
[10:10:07] Sending work to server
[10:10:07] Project: 8101 (Run 11, Clone 12, Gen 39)
[10:10:07] + Attempting to send results [December 3 10:10:07 UTC]
[10:10:07] - Reading file work/wuresults_09.dat from core
[10:10:08]   (Read 91576272 bytes from disk)
[10:10:08] Connecting to http://128.143.231.201:8080/
[10:24:57] - Autosending finished units... [December 3 10:24:57 UTC]
[10:24:57] Trying to send all finished work units
[10:24:57] - Already sending work
[10:24:57] + Sent 0 of 1 completed units to the server
[10:24:57] - Autosend completed
[10:36:30] Posted data.
[10:36:30] Initial: 0000; - Uploaded at ~56 kB/s
[10:36:30] - Averaged speed for that direction ~54 kB/s
[10:36:30] + Results successfully sent
[10:36:30] Thank you for your contribution to Folding@Home.
[10:36:30] + Number of Units Completed: 19
[10:36:34] Trying to send all finished work units
[10:36:34] + No unsent completed units remaining.
[10:36:34] - Preparing to get new work unit...
[10:36:34] Cleaning up work directory
[10:36:35] + Attempting to get work packet
[10:36:35] Passkey found
[10:36:35] - Will indicate memory of 12033 MB
[10:36:35] - Connecting to assignment server
[10:36:35] Connecting to http://assign.stanford.edu:8080/
[10:36:36] Posted data.
[10:36:36] Initial: 8F80; - Successful: assigned to (128.143.231.201).
[10:36:36] + News From Folding@Home: Welcome to Folding@Home
[10:36:36] Loaded queue successfully.
[10:36:36] Sent data
[10:36:36] Connecting to http://128.143.231.201:8080/
[10:36:42] Posted data.
[10:36:42] Initial: 0000; - Receiving payload (expected size: 30306701)
[10:37:16] - Downloaded at ~870 kB/s
[10:37:16] - Averaged speed for that direction ~719 kB/s
[10:37:16] + Received work.
[10:37:16] Trying to send all finished work units
[10:37:16] + No unsent completed units remaining.
[10:37:16] + Closed connections
[10:37:16]
[10:37:16] + Processing work unit
[10:37:16] Core required: FahCore_a5.exe
[10:37:16] Core found.
[10:37:16] Working on queue slot 00 [December 3 10:37:16 UTC]
[10:37:16] + Working ...
[10:37:16] - Calling './FahCore_a5.exe -dir work/ -nice 19 -suffix 00 -np 24 -checkpoint 30 -verbose -lifeline 1530 -version 634'
[10:37:16]
[10:37:16] *------------------------------*
[10:37:16] Folding@Home Gromacs SMP Core
[10:37:16] Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
[10:37:16]
[10:37:16] Preparing to commence simulation
[10:37:16] - Looking at optimizations...
[10:37:16] - Created dyn
[10:37:16] - Files status OK
[10:37:19] - Expanded 30306189 -> 33158020 (decompressed 109.4 percent)
[10:37:19] Called DecompressByteArray: compressed_data_size=30306189 data_size=33158020, decompressed_data_size=33158020 diff=0
[10:37:19] - Digital signature verified
[10:37:19]
[10:37:19] Project: 8101 (Run 9, Clone 10, Gen 109)
[10:37:19]
[10:37:19] Assembly optimizations on if available.
[10:37:19] Entering M.D.
[10:37:25] Mapping NT from 24 to 24
[10:37:31] Completed 0 out of 250000 steps  (0%)
[11:05:28] Completed 2500 out of 250000 steps  (1%)
[11:32:54] Completed 5000 out of 250000 steps  (2%)
[12:00:21] Completed 7500 out of 250000 steps  (3%)
[12:27:49] Completed 10000 out of 250000 steps  (4%)
[12:55:20] Completed 12500 out of 250000 steps  (5%)
[13:22:52] Completed 15000 out of 250000 steps  (6%)
[13:50:25] Completed 17500 out of 250000 steps  (7%)
[14:17:55] Completed 20000 out of 250000 steps  (8%)
[14:45:28] Completed 22500 out of 250000 steps  (9%)
[15:12:57] Completed 25000 out of 250000 steps  (10%)
[15:40:28] Completed 27500 out of 250000 steps  (11%)
[16:07:57] Completed 30000 out of 250000 steps  (12%)
[16:24:57] - Autosending finished units... [December 3 16:24:57 UTC]
[16:24:57] Trying to send all finished work units
[16:24:57] + No unsent completed units remaining.
[16:24:57] - Autosend completed
[16:35:25] Completed 32500 out of 250000 steps  (13%)
[17:02:56] Completed 35000 out of 250000 steps  (14%)
[17:30:27] Completed 37500 out of 250000 steps  (15%)
[17:57:57] Completed 40000 out of 250000 steps  (16%)
[18:25:26] Completed 42500 out of 250000 steps  (17%)
[18:52:56] Completed 45000 out of 250000 steps  (18%)
[19:20:26] Completed 47500 out of 250000 steps  (19%)
[19:47:55] Completed 50000 out of 250000 steps  (20%)
[20:15:25] Completed 52500 out of 250000 steps  (21%)
[20:42:55] Completed 55000 out of 250000 steps  (22%)
[21:10:28] Completed 57500 out of 250000 steps  (23%)
[21:38:03] Completed 60000 out of 250000 steps  (24%)
[22:05:35] Completed 62500 out of 250000 steps  (25%)
[22:24:57] - Autosending finished units... [December 3 22:24:57 UTC]
[22:24:57] Trying to send all finished work units
[22:24:57] + No unsent completed units remaining.
[22:24:57] - Autosend completed
[22:33:07] Completed 65000 out of 250000 steps  (26%)
[23:00:40] Completed 67500 out of 250000 steps  (27%)
[23:28:13] Completed 70000 out of 250000 steps  (28%)
[23:55:42] Completed 72500 out of 250000 steps  (29%)
[00:23:14] Completed 75000 out of 250000 steps  (30%)
[00:50:44] Completed 77500 out of 250000 steps  (31%)
[01:18:16] Completed 80000 out of 250000 steps  (32%)
[01:45:47] Completed 82500 out of 250000 steps  (33%)
[02:13:17] Completed 85000 out of 250000 steps  (34%)
[02:40:46] Completed 87500 out of 250000 steps  (35%)
[03:08:15] Completed 90000 out of 250000 steps  (36%)
[03:35:42] Completed 92500 out of 250000 steps  (37%)
[04:03:13] Completed 95000 out of 250000 steps  (38%)
[04:24:57] - Autosending finished units... [December 4 04:24:57 UTC]
[04:24:57] Trying to send all finished work units
[04:24:57] + No unsent completed units remaining.
[04:24:57] - Autosend completed
[04:30:42] Completed 97500 out of 250000 steps  (39%)
[04:58:11] Completed 100000 out of 250000 steps  (40%)
[05:25:39] Completed 102500 out of 250000 steps  (41%)
[05:53:11] Completed 105000 out of 250000 steps  (42%)
[06:20:40] Completed 107500 out of 250000 steps  (43%)
[06:48:11] Completed 110000 out of 250000 steps  (44%)
[07:15:41] Completed 112500 out of 250000 steps  (45%)
[07:43:10] Completed 115000 out of 250000 steps  (46%)
[08:10:40] Completed 117500 out of 250000 steps  (47%)
[08:38:11] Completed 120000 out of 250000 steps  (48%)
[09:05:40] Completed 122500 out of 250000 steps  (49%)
[09:33:11] Completed 125000 out of 250000 steps  (50%)
[10:00:40] Completed 127500 out of 250000 steps  (51%)
[10:24:57] - Autosending finished units... [December 4 10:24:57 UTC]
[10:24:57] + No unsent completed units remaining.
[10:28:08] Completed 130000 out of 250000 steps  (52%)
[10:55:38] Completed 132500 out of 250000 steps  (53%)
[11:23:07] Completed 135000 out of 250000 steps  (54%)
[11:50:37] Completed 137500 out of 250000 steps  (55%)
[12:18:07] Completed 140000 out of 250000 steps  (56%)
[12:45:40] Completed 142500 out of 250000 steps  (57%)
[13:13:13] Completed 145000 out of 250000 steps  (58%)
[13:40:43] Completed 147500 out of 250000 steps  (59%)
[14:08:14] Completed 150000 out of 250000 steps  (60%)
[14:35:44] Completed 152500 out of 250000 steps  (61%)
[15:03:16] Completed 155000 out of 250000 steps  (62%)
[15:30:49] Completed 157500 out of 250000 steps  (63%)
[15:58:20] Completed 160000 out of 250000 steps  (64%)
[16:24:57] - Autosending finished units... [December 4 16:24:57 UTC]
[16:25:53] Completed 162500 out of 250000 steps  (65%)
[16:53:25] Completed 165000 out of 250000 steps  (66%)
[17:20:55] Completed 167500 out of 250000 steps  (67%)
[17:48:26] Completed 170000 out of 250000 steps  (68%)
[18:15:56] Completed 172500 out of 250000 steps  (69%)
[18:43:27] Completed 175000 out of 250000 steps  (70%)
[19:10:59] Completed 177500 out of 250000 steps  (71%)
[19:38:29] Completed 180000 out of 250000 steps  (72%)
[20:05:55] Completed 182500 out of 250000 steps  (73%)
[20:33:26] Completed 185000 out of 250000 steps  (74%)
[21:00:56] Completed 187500 out of 250000 steps  (75%)
[21:28:25] Completed 190000 out of 250000 steps  (76%)
[21:55:54] Completed 192500 out of 250000 steps  (77%)
[22:23:24] Completed 195000 out of 250000 steps  (78%)
[22:24:57] - Autosending finished units... [December 4 22:24:57 UTC]
[22:50:52] Completed 197500 out of 250000 steps  (79%)
[23:18:24] Completed 200000 out of 250000 steps  (80%)
[23:45:59] Completed 202500 out of 250000 steps  (81%)
[00:13:30] Completed 205000 out of 250000 steps  (82%)
[00:41:00] Completed 207500 out of 250000 steps  (83%)
[01:08:32] Completed 210000 out of 250000 steps  (84%)
[01:36:02] Completed 212500 out of 250000 steps  (85%)
[02:03:34] Completed 215000 out of 250000 steps  (86%)
[02:31:02] Completed 217500 out of 250000 steps  (87%)
[02:58:34] Completed 220000 out of 250000 steps  (88%)
[03:26:07] Completed 222500 out of 250000 steps  (89%)
[03:53:37] Completed 225000 out of 250000 steps  (90%)
[04:21:09] Completed 227500 out of 250000 steps  (91%)
[04:24:57] - Autosending finished units... [December 5 04:24:57 UTC]
[04:48:39] Completed 230000 out of 250000 steps  (92%)
[05:16:11] Completed 232500 out of 250000 steps  (93%)
[05:43:43] Completed 235000 out of 250000 steps  (94%)
[06:11:16] Completed 237500 out of 250000 steps  (95%)
[06:38:50] Completed 240000 out of 250000 steps  (96%)
[07:06:16] Completed 242500 out of 250000 steps  (97%)
[07:33:45] Completed 245000 out of 250000 steps  (98%)
[08:01:11] Completed 247500 out of 250000 steps  (99%)
[08:28:36] Completed 250000 out of 250000 steps  (100%)
[08:28:46] DynamicWrapper: Finished Work Unit: sleep=10000
[08:28:56]
[08:28:56] Finished Work Unit:
[08:28:56] - Reading up to 64340496 from "work/wudata_00.trr": Read 64340496
[08:28:56] trr file hash check passed.
[08:28:56] - Reading up to 31619704 from "work/wudata_00.xtc": Read 31619704
[08:28:57] xtc file hash check passed.
[08:28:57] edr file hash check passed.
[08:28:57] logfile size: 192490
[08:28:57] Leaving Run
[08:29:01] - Writing 96313566 bytes of core data to disk...
[08:29:16] Done: 96313054 -> 91577881 (compressed to 5.8 percent)
[08:29:16]   ... Done.
[08:29:35] - Shutting down core
[08:29:35]
[08:29:35] Folding@home Core Shutdown: FINISHED_UNIT
[08:29:38] CoreStatus = 64 (100)
[08:29:38] Unit 0 finished with 52 percent of time to deadline remaining.
[08:29:38] Updated performance fraction: 0.555913
[08:29:38] Sending work to server
[08:29:38] Project: 8101 (Run 9, Clone 10, Gen 109)
[08:29:38] + Attempting to send results [December 5 08:29:38 UTC]
[08:29:38] - Reading file work/wuresults_00.dat from core
[08:29:38]   (Read 91578393 bytes from disk)
[08:29:38] Connecting to http://128.143.231.201:8080/
[08:54:02] - Couldn't send HTTP request to server
[08:54:02] + Could not connect to Work Server (results)
[08:54:02]     (128.143.231.201:8080)
[08:54:02] + Retrying using alternative port
[08:54:02] Connecting to http://128.143.231.201:80/
[09:21:32] Posted data.
[09:21:32] Initial: 0000; + Results successfully sent
[09:21:32] Thank you for your contribution to Folding@Home.
[09:21:32] + Number of Units Completed: 20
[09:21:37] Trying to send all finished work units
[09:21:37] + No unsent completed units remaining.
[09:21:37] - Preparing to get new work unit...
[09:21:37] Cleaning up work directory
[09:21:39] + Attempting to get work packet
[09:21:39] Passkey found
[09:21:39] - Will indicate memory of 12033 MB
[09:21:39] - Connecting to assignment server
[09:21:39] Connecting to http://assign.stanford.edu:8080/
[09:21:39] Posted data.
[09:21:39] Initial: 8F80; - Successful: assigned to (128.143.231.201).
[09:21:39] + News From Folding@Home: Welcome to Folding@Home
[09:21:39] Loaded queue successfully.
[09:21:39] Sent data
[09:21:39] Connecting to http://128.143.231.201:8080/
[09:21:46] Posted data.
[09:21:46] Initial: 0000; - Receiving payload (expected size: 30306704)
[09:22:19] - Downloaded at ~896 kB/s
[09:22:19] - Averaged speed for that direction ~754 kB/s
[09:22:19] + Received work.
[09:22:19] Trying to send all finished work units
[09:22:19] + No unsent completed units remaining.
[09:22:19] + Closed connections
[09:22:19]
[09:22:19] + Processing work unit
[09:22:19] Core required: FahCore_a5.exe
[09:22:19] Core found.
[09:22:19] Working on queue slot 01 [December 5 09:22:19 UTC]
[09:22:19] + Working ...
[09:22:19] - Calling './FahCore_a5.exe -dir work/ -nice 19 -suffix 01 -np 24 -checkpoint 30 -verbose -lifeline 1530 -version 634'
[09:22:19]
[09:22:19] *------------------------------*
[09:22:19] Folding@Home Gromacs SMP Core
[09:22:19] Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
[09:22:19]
[09:22:19] Preparing to commence simulation
[09:22:19] - Looking at optimizations...
[09:22:19] - Created dyn
[09:22:19] - Files status OK
[09:22:21] - Expanded 30306192 -> 33158020 (decompressed 109.4 percent)
[09:22:21] Called DecompressByteArray: compressed_data_size=30306192 data_size=33158020, decompressed_data_size=33158020 diff=0
[09:22:21] - Digital signature verified
[09:22:21]
[09:22:21] Project: 8101 (Run 9, Clone 10, Gen 110)
[09:22:21]
[09:22:21] Assembly optimizations on if available.
[09:22:21] Entering M.D.
[09:22:28] Mapping NT from 24 to 24
[09:22:34] Completed 0 out of 250000 steps  (0%)
[09:50:25] Completed 2500 out of 250000 steps  (1%)
[10:17:49] Completed 5000 out of 250000 steps  (2%)
[10:24:57] - Autosending finished units... [December 5 10:24:57 UTC]
[10:45:11] Completed 7500 out of 250000 steps  (3%)
[11:12:35] Completed 10000 out of 250000 steps  (4%)
[11:39:57] Completed 12500 out of 250000 steps  (5%)
[12:07:24] Completed 15000 out of 250000 steps  (6%)
[12:34:46] Completed 17500 out of 250000 steps  (7%)
[13:02:10] Completed 20000 out of 250000 steps  (8%)
[13:29:32] Completed 22500 out of 250000 steps  (9%)
[13:56:54] Completed 25000 out of 250000 steps  (10%)
[14:24:17] Completed 27500 out of 250000 steps  (11%)
[14:51:38] Completed 30000 out of 250000 steps  (12%)
[15:19:00] Completed 32500 out of 250000 steps  (13%)
[15:46:23] Completed 35000 out of 250000 steps  (14%)
[16:13:48] Completed 37500 out of 250000 steps  (15%)
[16:24:57] - Autosending finished units... [December 5 16:24:57 UTC]
[16:41:12] Completed 40000 out of 250000 steps  (16%)
[17:08:36] Completed 42500 out of 250000 steps  (17%)
[17:36:00] Completed 45000 out of 250000 steps  (18%)
[18:03:25] Completed 47500 out of 250000 steps  (19%)
[18:30:49] Completed 50000 out of 250000 steps  (20%)
[18:58:12] Completed 52500 out of 250000 steps  (21%)
[19:25:35] Completed 55000 out of 250000 steps  (22%)
[19:52:57] Completed 57500 out of 250000 steps  (23%)
[20:20:21] Completed 60000 out of 250000 steps  (24%)
[20:47:46] Completed 62500 out of 250000 steps  (25%)
[21:15:10] Completed 65000 out of 250000 steps  (26%)
[21:42:32] Completed 67500 out of 250000 steps  (27%)
[22:09:55] Completed 70000 out of 250000 steps  (28%)
[22:24:57] - Autosending finished units... [December 5 22:24:57 UTC]
[22:37:18] Completed 72500 out of 250000 steps  (29%)
[23:04:41] Completed 75000 out of 250000 steps  (30%)
[23:32:04] Completed 77500 out of 250000 steps  (31%)
[23:59:28] Completed 80000 out of 250000 steps  (32%)
[00:26:56] Completed 82500 out of 250000 steps  (33%)
[00:54:26] Completed 85000 out of 250000 steps  (34%)
[01:21:53] Completed 87500 out of 250000 steps  (35%)
[01:49:20] Completed 90000 out of 250000 steps  (36%)
[02:16:46] Completed 92500 out of 250000 steps  (37%)
[02:44:10] Completed 95000 out of 250000 steps  (38%)
[03:11:35] Completed 97500 out of 250000 steps  (39%)
[03:38:59] Completed 100000 out of 250000 steps  (40%)
[04:06:29] Completed 102500 out of 250000 steps  (41%)
[04:24:57] - Autosending finished units... [December 6 04:24:57 UTC]
[04:34:01] Completed 105000 out of 250000 steps  (42%)
[05:01:37] Completed 107500 out of 250000 steps  (43%)
[05:29:08] Completed 110000 out of 250000 steps  (44%)
[05:56:43] Completed 112500 out of 250000 steps  (45%)
[06:24:09] Completed 115000 out of 250000 steps  (46%)
[06:51:34] Completed 117500 out of 250000 steps  (47%)
[07:19:01] Completed 120000 out of 250000 steps  (48%)
[07:46:25] Completed 122500 out of 250000 steps  (49%)
[08:13:52] Completed 125000 out of 250000 steps  (50%)
[08:41:20] Completed 127500 out of 250000 steps  (51%)
[09:08:48] Completed 130000 out of 250000 steps  (52%)
[09:36:15] Completed 132500 out of 250000 steps  (53%)
[10:03:41] Completed 135000 out of 250000 steps  (54%)
[10:24:57] - Autosending finished units... [December 6 10:24:57 UTC]
[10:31:09] Completed 137500 out of 250000 steps  (55%)
[10:58:38] Completed 140000 out of 250000 steps  (56%)
[11:26:06] Completed 142500 out of 250000 steps  (57%)
[11:53:33] Completed 145000 out of 250000 steps  (58%)
[12:20:58] Completed 147500 out of 250000 steps  (59%)
[12:48:25] Completed 150000 out of 250000 steps  (60%)
[13:15:54] Completed 152500 out of 250000 steps  (61%)
[13:43:23] Completed 155000 out of 250000 steps  (62%)
[14:10:51] Completed 157500 out of 250000 steps  (63%)
[14:38:22] Completed 160000 out of 250000 steps  (64%)
[15:05:51] Completed 162500 out of 250000 steps  (65%)
[15:33:18] Completed 165000 out of 250000 steps  (66%)
[16:00:48] Completed 167500 out of 250000 steps  (67%)
[16:24:57] - Autosending finished units... [December 6 16:24:57 UTC]
[16:28:16] Completed 170000 out of 250000 steps  (68%)
[16:55:43] Completed 172500 out of 250000 steps  (69%)
[17:23:12] Completed 175000 out of 250000 steps  (70%)
[17:50:37] Completed 177500 out of 250000 steps  (71%)
[18:18:03] Completed 180000 out of 250000 steps  (72%)
[18:45:29] Completed 182500 out of 250000 steps  (73%)
[19:12:55] Completed 185000 out of 250000 steps  (74%)
[19:40:21] Completed 187500 out of 250000 steps  (75%)
[20:07:47] Completed 190000 out of 250000 steps  (76%)
[20:35:13] Completed 192500 out of 250000 steps  (77%)
[21:02:40] Completed 195000 out of 250000 steps  (78%)
[21:30:05] Completed 197500 out of 250000 steps  (79%)
[21:57:35] Completed 200000 out of 250000 steps  (80%)
[22:24:57] - Autosending finished units... [December 6 22:24:57 UTC]
[22:25:03] Completed 202500 out of 250000 steps  (81%)
[22:52:28] Completed 205000 out of 250000 steps  (82%)
[23:19:56] Completed 207500 out of 250000 steps  (83%)
[23:47:24] Completed 210000 out of 250000 steps  (84%)
[00:14:51] Completed 212500 out of 250000 steps  (85%)
[00:42:18] Completed 215000 out of 250000 steps  (86%)
[01:09:48] Completed 217500 out of 250000 steps  (87%)
[01:37:20] Completed 220000 out of 250000 steps  (88%)
[02:04:48] Completed 222500 out of 250000 steps  (89%)
[02:32:18] Completed 225000 out of 250000 steps  (90%)
[02:59:46] Completed 227500 out of 250000 steps  (91%)
[03:27:13] Completed 230000 out of 250000 steps  (92%)
[03:54:44] Completed 232500 out of 250000 steps  (93%)
[04:22:10] Completed 235000 out of 250000 steps  (94%)
[04:24:57] - Autosending finished units... [December 7 04:24:57 UTC]
[04:49:41] Completed 237500 out of 250000 steps  (95%)
[05:17:11] Completed 240000 out of 250000 steps  (96%)
[05:44:37] Completed 242500 out of 250000 steps  (97%)
[06:12:06] Completed 245000 out of 250000 steps  (98%)
[06:39:35] Completed 247500 out of 250000 steps  (99%)
[07:07:02] Completed 250000 out of 250000 steps  (100%)
[07:07:12] DynamicWrapper: Finished Work Unit: sleep=10000
[07:07:22]
[07:07:22] Finished Work Unit:
[07:07:22] - Reading up to 64340496 from "work/wudata_01.trr": Read 64340496
[07:07:22] trr file hash check passed.
[07:07:22] - Reading up to 31559032 from "work/wudata_01.xtc": Read 31559032
[07:07:22] xtc file hash check passed.
[07:07:22] edr file hash check passed.
[07:07:22] logfile size: 192486
[07:07:22] Leaving Run
[07:07:23] - Writing 96252890 bytes of core data to disk...
[07:07:38] Done: 96252378 -> 91518526 (compressed to 5.8 percent)
[07:07:39]   ... Done.
[07:07:56] - Shutting down core
[07:07:56]
[07:07:56] Folding@home Core Shutdown: FINISHED_UNIT
[07:07:58] CoreStatus = 64 (100)
[07:07:58] Unit 1 finished with 52 percent of time to deadline remaining.
[07:07:58] Updated performance fraction: 0.549396
[07:07:58] Sending work to server
[07:07:58] Project: 8101 (Run 9, Clone 10, Gen 110)
[07:07:58] + Attempting to send results [December 7 07:07:58 UTC]
[07:07:58] - Reading file work/wuresults_01.dat from core
[07:07:58]   (Read 91519038 bytes from disk)
[07:07:58] Connecting to http://128.143.231.201:8080/
[07:07:58] - Couldn't send HTTP request to server
[07:07:58] + Could not connect to Work Server (results)
[07:07:58]     (128.143.231.201:8080)
[07:07:58] + Retrying using alternative port
[07:07:58] Connecting to http://128.143.231.201:80/
[07:07:58]     (128.143.231.201:80)
[07:07:58] - Error: Could not transmit unit 01 (completed December 7) to work server.
[07:07:58] - 1 failed uploads of this unit.
[07:07:58]   Keeping unit 01 in queue.
[07:07:58] Trying to send all finished work units
[07:07:58] - 2 failed uploads of this unit.
[07:07:58] Connecting to http://128.143.199.97:8080/
[07:07:58]     (128.143.199.97:8080)
[07:07:58] Connecting to http://128.143.199.97:80/
[07:07:58]     (128.143.199.97:80)
[07:07:58]   Could not transmit unit 01 to Collection server; keeping in queue.
[07:07:58] + Sent 0 of 1 completed units to the server
[07:07:58] - Preparing to get new work unit...
[07:07:58] Cleaning up work directory
[07:08:00] + Attempting to get work packet
[07:08:00] Passkey found
[07:08:00] - Will indicate memory of 12033 MB
[07:08:00] - Connecting to assignment server
[07:08:00] Connecting to http://assign.stanford.edu:8080/
[07:08:00] - Could not CosmHTTPOpen
[07:08:00] + Could not connect to Assignment Server
[07:08:00] Connecting to http://assign2.stanford.edu:80/
[07:08:00] + Could not connect to Assignment Server 2
[07:08:00] + Couldn't get work instructions.
[07:08:00] - Attempt #1  to get work failed, and no other work to do.
[07:08:14] + Attempting to get work packet
[07:08:14] Passkey found
[07:08:14] - Will indicate memory of 12033 MB
[07:08:14] - Connecting to assignment server
[07:08:14] Connecting to http://assign.stanford.edu:8080/
[07:08:14] - Could not CosmHTTPOpen
[07:08:14] + Could not connect to Assignment Server
[07:08:14] Connecting to http://assign2.stanford.edu:80/
[07:08:14] + Could not connect to Assignment Server 2
[07:08:14] + Couldn't get work instructions.
[07:08:14] - Attempt #2  to get work failed, and no other work to do.
[07:08:34] + Attempting to get work packet
[07:08:34] Passkey found
[07:08:34] - Will indicate memory of 12033 MB
[07:08:34] - Connecting to assignment server
[07:08:34] Connecting to http://assign.stanford.edu:8080/
[07:08:34] - Could not CosmHTTPOpen
[07:08:34] + Could not connect to Assignment Server
[07:08:34] Connecting to http://assign2.stanford.edu:80/
[07:08:34] + Could not connect to Assignment Server 2
[07:08:34] + Couldn't get work instructions.
[07:08:34] - Attempt #3  to get work failed, and no other work to do.
[07:09:01] + Attempting to get work packet
[07:09:01] Passkey found
[07:09:01] - Will indicate memory of 12033 MB
[07:09:01] - Connecting to assignment server
[07:09:01] Connecting to http://assign.stanford.edu:8080/
[07:09:01] - Could not CosmHTTPOpen
[07:09:01] + Could not connect to Assignment Server
[07:09:01] Connecting to http://assign2.stanford.edu:80/
[07:09:01] + Could not connect to Assignment Server 2
[07:09:01] + Couldn't get work instructions.
[07:09:01] - Attempt #4  to get work failed, and no other work to do.
[07:09:55] + Attempting to get work packet
[07:09:55] Passkey found
[07:09:55] - Will indicate memory of 12033 MB
[07:09:55] - Connecting to assignment server
[07:09:55] Connecting to http://assign.stanford.edu:8080/
[07:09:55] - Could not CosmHTTPOpen
[07:09:55] + Could not connect to Assignment Server
[07:09:55] Connecting to http://assign2.stanford.edu:80/
[07:09:55] + Could not connect to Assignment Server 2
[07:09:55] + Couldn't get work instructions.
[07:09:55] - Attempt #5  to get work failed, and no other work to do.
[07:11:22] + Attempting to get work packet
[07:11:22] Passkey found
[07:11:22] - Will indicate memory of 12033 MB
[07:11:22] - Connecting to assignment server
[07:11:22] Connecting to http://assign.stanford.edu:8080/
[07:11:22] - Could not CosmHTTPOpen
[07:11:22] + Could not connect to Assignment Server
[07:11:22] Connecting to http://assign2.stanford.edu:80/
[07:11:22] + Could not connect to Assignment Server 2
[07:11:22] + Couldn't get work instructions.
[07:11:22] - Attempt #6  to get work failed, and no other work to do.
[07:14:16] + Attempting to get work packet
[07:14:16] Passkey found
[07:14:16] - Will indicate memory of 12033 MB
[07:14:16] - Connecting to assignment server
[07:14:16] Connecting to http://assign.stanford.edu:8080/
[07:14:16] - Could not CosmHTTPOpen
[07:14:16] + Could not connect to Assignment Server
[07:14:16] Connecting to http://assign2.stanford.edu:80/
[07:14:16] + Could not connect to Assignment Server 2
[07:14:16] + Couldn't get work instructions.
[07:14:16] - Attempt #7  to get work failed, and no other work to do.
[07:19:41] + Attempting to get work packet
[07:19:41] Passkey found
[07:19:41] - Will indicate memory of 12033 MB
[07:19:41] - Connecting to assignment server
[07:19:41] Connecting to http://assign.stanford.edu:8080/
[07:19:41] - Could not CosmHTTPOpen
[07:19:41] + Could not connect to Assignment Server
[07:19:41] Connecting to http://assign2.stanford.edu:80/
[07:19:41] + Could not connect to Assignment Server 2
[07:19:41] + Couldn't get work instructions.
[07:19:41] - Attempt #8  to get work failed, and no other work to do.
[07:30:23] + Attempting to get work packet
[07:30:23] Passkey found
[07:30:23] - Will indicate memory of 12033 MB
[07:30:23] - Connecting to assignment server
[07:30:23] Connecting to http://assign.stanford.edu:8080/
[07:30:23] - Could not CosmHTTPOpen
[07:30:23] + Could not connect to Assignment Server
[07:30:23] Connecting to http://assign2.stanford.edu:80/
[07:30:23] + Could not connect to Assignment Server 2
[07:30:23] + Couldn't get work instructions.
[07:30:23] - Attempt #9  to get work failed, and no other work to do.
[07:51:57] + Attempting to get work packet
[07:51:57] Passkey found
[07:51:57] - Will indicate memory of 12033 MB
[07:51:57] - Connecting to assignment server
[07:51:57] Connecting to http://assign.stanford.edu:8080/
[07:51:57] - Could not CosmHTTPOpen
[07:51:57] + Could not connect to Assignment Server
[07:51:57] Connecting to http://assign2.stanford.edu:80/
[07:51:57] + Could not connect to Assignment Server 2
[07:51:57] + Couldn't get work instructions.
[07:51:57] - Attempt #10  to get work failed, and no other work to do.
[08:34:39] + Attempting to get work packet
[08:34:39] Passkey found
[08:34:39] - Will indicate memory of 12033 MB
[08:34:39] - Connecting to assignment server
[08:34:39] Connecting to http://assign.stanford.edu:8080/
[08:34:39] - Could not CosmHTTPOpen
[08:34:39] + Could not connect to Assignment Server
[08:34:39] Connecting to http://assign2.stanford.edu:80/
[08:34:39] + Could not connect to Assignment Server 2
[08:34:39] + Couldn't get work instructions.
[08:34:39] - Attempt #11  to get work failed, and no other work to do.
[09:22:46] + Attempting to get work packet
[09:22:46] Passkey found
[09:22:46] - Will indicate memory of 12033 MB
[09:22:46] - Connecting to assignment server
[09:22:46] Connecting to http://assign.stanford.edu:8080/
[09:22:46] - Could not CosmHTTPOpen
[09:22:46] + Could not connect to Assignment Server
[09:22:46] Connecting to http://assign2.stanford.edu:80/
[09:22:46] + Could not connect to Assignment Server 2
[09:22:46] + Couldn't get work instructions.
[09:22:46] - Attempt #12  to get work failed, and no other work to do.
[10:11:00] + Attempting to get work packet
[10:11:00] Passkey found
[10:11:00] - Will indicate memory of 12033 MB
[10:11:00] - Connecting to assignment server
[10:11:00] Connecting to http://assign.stanford.edu:8080/
[10:11:00] - Could not CosmHTTPOpen
[10:11:00] + Could not connect to Assignment Server
[10:11:00] Connecting to http://assign2.stanford.edu:80/
[10:11:00] + Could not connect to Assignment Server 2
[10:11:00] + Couldn't get work instructions.
[10:11:00] - Attempt #13  to get work failed, and no other work to do.
[10:24:57] - Autosending finished units... [December 7 10:24:57 UTC]
[10:24:57] Project: 8101 (Run 9, Clone 10, Gen 110)
[10:24:57] + Attempting to send results [December 7 10:24:57 UTC]
[10:24:57] - Reading file work/wuresults_01.dat from core
[10:24:58]   (Read 91519038 bytes from disk)
[10:24:58] Connecting to http://128.143.231.201:8080/
[10:24:58] - Couldn't send HTTP request to server
[10:24:58] + Could not connect to Work Server (results)
[10:24:58]     (128.143.231.201:8080)
[10:24:58] + Retrying using alternative port
[10:24:58] Connecting to http://128.143.231.201:80/
[10:24:58]     (128.143.231.201:80)
[10:24:58] - Error: Could not transmit unit 01 (completed December 7) to work server.
[10:24:58] - 3 failed uploads of this unit.
[10:24:58] + Attempting to send results [December 7 10:24:58 UTC]
[10:24:58] - Reading file work/wuresults_01.dat from core
[10:24:58] Connecting to http://128.143.199.97:8080/
[10:24:58]     (128.143.199.97:8080)
[10:24:58] Connecting to http://128.143.199.97:80/
[10:24:58]     (128.143.199.97:80)
[10:24:58]   Could not transmit unit 01 to Collection server; keeping in queue.
[10:24:58] + Sent 0 of 1 completed units to the server
[10:24:58] - Autosend completed
[10:59:13] + Attempting to get work packet
[10:59:13] Passkey found
[10:59:13] - Will indicate memory of 12033 MB
[10:59:13] - Connecting to assignment server
[10:59:13] Connecting to http://assign.stanford.edu:8080/
[10:59:13] - Could not CosmHTTPOpen
[10:59:13] + Could not connect to Assignment Server
[10:59:13] Connecting to http://assign2.stanford.edu:80/
[10:59:13] + Could not connect to Assignment Server 2
[10:59:13] + Couldn't get work instructions.
[10:59:13] - Attempt #14  to get work failed, and no other work to do.
[11:47:13] + Attempting to get work packet
[11:47:13] Passkey found
[11:47:13] - Will indicate memory of 12033 MB
[11:47:13] - Connecting to assignment server
[11:47:13] Connecting to http://assign.stanford.edu:8080/
[11:47:13] - Could not CosmHTTPOpen
[11:47:13] + Could not connect to Assignment Server
[11:47:13] Connecting to http://assign2.stanford.edu:80/
[11:47:13] + Could not connect to Assignment Server 2
[11:47:13] + Couldn't get work instructions.
[11:47:13] - Attempt #15  to get work failed, and no other work to do.
[12:35:18] + Attempting to get work packet
[12:35:18] Passkey found
[12:35:18] - Will indicate memory of 12033 MB
[12:35:18] - Connecting to assignment server
[12:35:18] Connecting to http://assign.stanford.edu:8080/
[12:35:18] - Could not CosmHTTPOpen
[12:35:18] + Could not connect to Assignment Server
[12:35:18] Connecting to http://assign2.stanford.edu:80/
[12:35:18] + Could not connect to Assignment Server 2
[12:35:18] + Couldn't get work instructions.
[12:35:18] - Attempt #16  to get work failed, and no other work to do.
[13:23:30] + Attempting to get work packet
[13:23:30] Passkey found
[13:23:30] - Will indicate memory of 12033 MB
[13:23:30] - Connecting to assignment server
[13:23:30] Connecting to http://assign.stanford.edu:8080/
[13:23:30] - Could not CosmHTTPOpen
[13:23:30] + Could not connect to Assignment Server
[13:23:30] Connecting to http://assign2.stanford.edu:80/
[13:23:30] + Could not connect to Assignment Server 2
[13:23:30] + Couldn't get work instructions.
[13:23:30] - Attempt #17  to get work failed, and no other work to do.
[14:11:45] + Attempting to get work packet
[14:11:45] Passkey found
[14:11:45] - Will indicate memory of 12033 MB
[14:11:45] - Connecting to assignment server
[14:11:45] Connecting to http://assign.stanford.edu:8080/
[14:11:45] - Could not CosmHTTPOpen
[14:11:45] + Could not connect to Assignment Server
[14:11:45] Connecting to http://assign2.stanford.edu:80/
[14:11:45] + Could not connect to Assignment Server 2
[14:11:45] + Couldn't get work instructions.
[14:11:45] - Attempt #18  to get work failed, and no other work to do.
[14:59:45] + Attempting to get work packet
[14:59:45] Passkey found
[14:59:45] - Will indicate memory of 12033 MB
[14:59:45] - Connecting to assignment server
[14:59:45] Connecting to http://assign.stanford.edu:8080/
[14:59:45] - Could not CosmHTTPOpen
[14:59:45] + Could not connect to Assignment Server
[14:59:45] Connecting to http://assign2.stanford.edu:80/
[14:59:45] + Could not connect to Assignment Server 2
[14:59:45] + Couldn't get work instructions.
[14:59:45] - Attempt #19  to get work failed, and no other work to do.
[15:47:52] + Attempting to get work packet
[15:47:52] Passkey found
[15:47:52] - Will indicate memory of 12033 MB
[15:47:52] - Connecting to assignment server
[15:47:52] Connecting to http://assign.stanford.edu:8080/
[15:47:52] - Could not CosmHTTPOpen
[15:47:52] + Could not connect to Assignment Server
[15:47:52] Connecting to http://assign2.stanford.edu:80/
[15:47:52] + Could not connect to Assignment Server 2
[15:47:52] + Couldn't get work instructions.
[15:47:52] - Attempt #20  to get work failed, and no other work to do.
Here's the log after reboot
--- Opening Log file [December 7 16:08:09 UTC]
# Linux SMP Console Edition ###################################################
                       Folding@Home Client Version 6.34
                          http://folding.stanford.edu
Launch directory: /home/brent/fah
Executable: ./fah6
Arguments: -smp -bigadv -verbosity 9
[16:08:09] - Ask before connecting: No
[16:08:09] - User name: patonb (Team 12864)
[16:08:09] - User ID: 14466BDC3AABA2F1
[16:08:09] - Machine ID: 1
[16:08:09]
[16:08:09] Loaded queue successfully.
[16:08:09] Deleting incompletely fetched item (4) from queue position #2
[16:08:09] - Warning: Could not delete all work unit files (2): Core file absent
[16:09:05]
[16:09:05]
[16:09:05]
[16:09:05] - Looking at optimizations...
[16:09:05] - Created dyn
[16:09:05] - Files status OK
[16:09:08] - Expanded 30291538 -> 33158020 (decompressed 109.4 percent)
[16:09:08] Called DecompressByteArray: compressed_data_size=30291538 data_size=33158020, decompressed_data_size=33158020 diff=0
[16:09:08] - Digital signature verified
[16:09:08]
[16:09:08] Project: 8101 (Run 4, Clone 9, Gen 118)
[16:09:08]
[16:09:08] Assembly optimizations on if available.
[16:09:08] Entering M.D.
[16:09:14] Mapping NT from 24 to 24
[16:09:21] Completed 0 out of 250000 steps  (0%)
[16:36:50] Completed 2500 out of 250000 steps  (1%)
[17:03:51] Completed 5000 out of 250000 steps  (2%)
[17:30:53] Completed 7500 out of 250000 steps  (3%)
[17:57:56] Completed 10000 out of 250000 steps  (4%)
[18:25:02] Completed 12500 out of 250000 steps  (5%)
[18:52:07] Completed 15000 out of 250000 steps  (6%)
[19:19:10] Completed 17500 out of 250000 steps  (7%)
[19:46:14] Completed 20000 out of 250000 steps  (8%)
[20:13:17] Completed 22500 out of 250000 steps  (9%)
Do you have any continuous downloads or uploads being done on your network such as torrents or streaming video? Those are known to interfere with establishing connections and successfully uploading or downloading F@H files. I am not seeing any errors besides the connection error to explain the failure to upload the previous WU. The server is up and others are successfully uploading WU's to it. The other server in the log, 128.143.199.97, is also up and accepting connections.
Edit:
Looks like it eventually uploaded -
Hi patonb (team 12864),
Your WU (P8101 R9 C10 G110) was added to the stats database on 2012-12-07 16:06:26 for 22607 points of credit.
csvanefalk wrote:I was using the outdated links, I saw the notice just now (the one I looked at was http://fah-web.stanford.edu/localinfo/contact.SMP.html). Sorry for the mixup. Is there a reason these links are still provided if they are (seemingly) useless for troubleshooting due to not being updated anymore?
They are part of documentation on the forum that needs to be updated. A number of F@H support info sites on the PG servers were moved to new servers several weeks ago, and in the process some of the old links were deprecated or dropped. If you spot another outdated item, report it and we can add it to the list to catch up on.
patonb
Post by patonb »
Yha, I had to use the flag -send all. Saddly I found it tooo late and it seems the extra 12hrs trying to upload screwed my qrb... Not happy about that at all.
No I have nothing else running that would use bandwidth, and have no idea why nothing would upload.
