8056 (Run 49, Clone 29, Gen 60) - abnormally high TPF
championlly
Post by championlly »
i've been folding almost 24/7 on my notebook (i7-2670QM + GT555M) for the last 9 months,
this is the first time i've come across an unit with unusually long TFP.
usually something with base credit of 196pts shouldn't take more than 3~4hours to fold,
anyone help on this?
pls see screenshot attached:
*temperature & clock speeds are all normal in case you are wondering
*the interval on the graph is when i restarted the folding program
i7-2670QM | DDR3-1333 8GB | GT555M 2GB oc @ 730/1800 | Seagate 750GB 7200rpm | Win7HP 64-bit
P5-133XL
Machine #2:
Machine 3:
Re: 8056 (Run 49, Clone 29, Gen 60) - abnormally high TPF
Post by P5-133XL »
When dealing with extremely long TPF's (for A4's), the first thing that you look at is the task manager (process tab) to see if there is another process other than FAHCore_a4 that is using a significant amount of CPU usage (5-10% is plenty to cause this). If you do not see another process then you look at the folding log to see if the TPF's are consistent. If the times vary significantly, then it is assumed that you have an external-to-folding intermittent process that is causing havoc to folding. If TPF's are consistent, then assume a bad WU and you can kill it.
championlly
nothing is consuming significant cpu time other than Fah_corea4.exe itself.
in the past, even if i'm watching youtube & browsing the web, it never falls below 2000PPD - let alone 17PPD.
how do i go about killing the unit?
k1wi
Post by k1wi »
If you posted your log that would be helpful. Sometimes it is as simple as the WU having way more steps than its suppose to...
championlly
*********************** Log Started 2012-12-06T03:16:39Z ***********************
03:16:39:WU01:FS00:Starting
03:16:39:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 702 -lifeline 4656 -checkpoint 30 -np 8
03:16:39:WU01:FS00:Started FahCore on PID 4780
03:16:39:WU01:FS00:Core PID:4792
03:16:39:WU01:FS00:FahCore 0xa4 started
03:16:40:WU01:FS00:0xa4:
03:16:40:WU01:FS00:0xa4:*------------------------------*
03:16:40:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
03:16:40:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:16:40:WU01:FS00:0xa4:Preparing to commence simulation
03:16:40:WU01:FS00:0xa4:- Looking at optimizations...
03:16:40:WU01:FS00:0xa4:- Files status OK
03:16:40:WU01:FS00:0xa4:- Expanded 846178 -> 1531712 (decompressed 181.0 percent)
03:16:40:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=846178 data_size=1531712, decompressed_data_size=1531712 diff=0
03:16:40:WU01:FS00:0xa4:- Digital signature verified
03:16:40:WU01:FS00:0xa4:Project: 8056 (Run 49, Clone 29, Gen 60)
03:16:40:WU01:FS00:0xa4:Assembly optimizations on if available.
03:16:40:WU01:FS00:0xa4:Entering M.D.
03:16:46:WU01:FS00:0xa4:Using Gromacs checkpoints
03:16:46:WU01:FS00:0xa4:Mapping NT from 8 to 8
03:16:46:WU01:FS00:0xa4:Resuming from checkpoint
03:16:46:WU01:FS00:0xa4:Verified 01/wudata_01.log
03:16:46:WU01:FS00:0xa4:Verified 01/wudata_01.trr
03:16:46:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
03:16:46:WU01:FS00:0xa4:Verified 01/wudata_01.edr
03:16:47:WU01:FS00:0xa4:Completed 662770 out of 30500000 steps  (2%)
03:27:30:FS00:Paused
03:27:31:FS00:Shutting core down
03:27:40:WU01:FS00:0xa4:Client no longer detected. Shutting down core
03:27:40:WU01:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
03:27:40:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
i dont really know how to read the log.
it seems to have cut off after i restarted my computer,
3.27.40 is when i pause the unit.
k1wi
Post by k1wi »
30500000 steps seems quite a lot
championlly
30.5million steps for a 196pts unit does sound like a bit of problem,
how do i go abt killing it?
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
To delete this WU first pause folding. Then go to the Work folder (Start->All programs->FAHClient->Data Directory->Work) Delete the folder named 01. Un-pause folding. You should get a new WU.
championlly
yup, that work. i got a new unit that looks 'normal',
thanks for ur help guys!! :)
championlly wrote:30.5million steps for a 196pts unit does sound like a bit of problem,
Definitely a bad WU, the normal step count for the Project 8056 WU's I have processed is 500,000. I have reported it as a bad WU.
The WU (P8056,R49,C29,G60) has been reported as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
realkenzaburo
Hardware configuration: i7-3930 + Noctua NH-D14 (regular speed, no overclocking)
32GB RipjawsZ 1866mhz
Asus GeForce GTX 670 Dircet CU II, 2GB
Windows 7 Professional 64
Post by realkenzaburo »
Hallo All,
sorry this is my first post, but I thought I used this thread instead of opening a new one, since it is with regards to the same WU:
The same WU is currently running on my computer, with an abnormal long TFP (8056 (49, 29, 60):
The status bar:
ETA 4.22 days
Base Credit: 192,22
Est. Credit: 219,89
Est. PPD 47,17
Est. TFP: 1 hours 07 mins
Running on a i7-3930 no other application.
Here is the extract from my log:
10:30:34:WU01:FS00:Starting
10:30:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/XXXXXXXXXXX/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 702 -lifeline 4700 -checkpoint 5 -np 12
10:30:34:WU01:FS00:Started FahCore on PID 3848
10:30:34:WU01:FS00:Core PID:4684
10:30:34:WU01:FS00:FahCore 0xa4 started
10:30:35:WU01:FS00:0xa4:
10:30:35:WU01:FS00:0xa4:*------------------------------*
10:30:35:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
10:30:35:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:30:35:WU01:FS00:0xa4:Preparing to commence simulation
10:30:35:WU01:FS00:0xa4:- Looking at optimizations...
10:30:35:WU01:FS00:0xa4:- Files status OK
10:30:35:WU01:FS00:0xa4:- Expanded 846178 -> 1531712 (decompressed 181.0 percent)
10:30:35:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=846178 data_size=1531712, decompressed_data_size=1531712 diff=0
10:30:35:WU01:FS00:0xa4:- Digital signature verified
10:30:35:WU01:FS00:0xa4:Project: 8056 (Run 49, Clone 29, Gen 60)
10:30:35:WU01:FS00:0xa4:Assembly optimizations on if available.
10:30:35:WU01:FS00:0xa4:Entering M.D.
10:30:41:WU01:FS00:0xa4:Using Gromacs checkpoints
10:30:41:WU01:FS00:0xa4:Mapping NT from 12 to 12
10:30:41:WU01:FS00:0xa4:Resuming from checkpoint
10:30:41:WU01:FS00:0xa4:Verified 01/wudata_01.log
10:30:41:WU01:FS00:0xa4:Verified 01/wudata_01.trr
10:30:41:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
10:30:41:WU01:FS00:0xa4:Verified 01/wudata_01.edr
10:30:41:WU01:FS00:0xa4:Completed 2869590 out of 30500000 steps  (9%)
bollix47
Post by bollix47 »
Welcome to the folding support forum realkenzaburo.
Feel free to delete the WU using P5-133XL's instructions above. You want to delete folder 01.
I've resubmitted the report in case the first one slipped thru a crack:
Thank you bollix47.
arvidab
Post by arvidab »
Just got it too.
Already deleted and started a fresh (good) one. 2700K, normal 8056-TPF ~50sec.
19:54:34:WU01:FS00:Starting
19:54:34:WU01:FS00:Running FahCore: /home/eir/fah7/FAHCoreWrapper /home/eir/fah7/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 702 -lifeline 3079 -checkpoint 3 -np 8
19:54:34:WU01:FS00:Started FahCore on PID 4759
19:54:34:Started thread 34 on PID 3079
19:54:34:WU01:FS00:Core PID:4763
19:54:34:WU01:FS00:FahCore 0xa4 started
19:54:35:WU01:FS00:0xa4:
19:54:35:WU01:FS00:0xa4:*------------------------------*
19:54:35:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
19:54:35:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
19:54:35:WU01:FS00:0xa4:Preparing to commence simulation
19:54:35:WU01:FS00:0xa4:- Looking at optimizations...
19:54:35:WU01:FS00:0xa4:- Created dyn
19:54:35:WU01:FS00:0xa4:- Files status OK
19:54:35:WU01:FS00:0xa4:- Expanded 846178 -> 1531712 (decompressed 181.0 percent)
19:54:35:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=846178 data_size=1531712, decompressed_data_size=1531712 diff=0
19:54:35:WU01:FS00:0xa4:- Digital signature verified
19:54:35:WU01:FS00:0xa4:Project: 8056 (Run 49, Clone 29, Gen 60)
19:54:35:WU01:FS00:0xa4:Assembly optimizations on if available.
19:54:35:WU01:FS00:0xa4:Entering M.D.
19:54:39:WU00:FS00:Upload complete
19:54:39:WU00:FS00:Server responded WORK_ACK (400)
19:54:39:WU00:FS00:Final credit estimate, 6825.00 points
19:54:39:WU00:FS00:Cleaning up
19:54:40:WU01:FS00:0xa4:Completed 0 out of 30500000 steps  (0%)
20:45:40:WU01:FS00:0xa4:Completed 305000 out of 30500000 steps  (1%)
21:36:35:WU01:FS00:0xa4:Completed 610000 out of 30500000 steps  (2%)
22:27:32:WU01:FS00:0xa4:Completed 915000 out of 30500000 steps  (3%)
23:18:29:WU01:FS00:0xa4:Completed 1220000 out of 30500000 steps  (4%)
******************************** Date: 29/12/12 ********************************
00:09:32:WU01:FS00:0xa4:Completed 1525000 out of 30500000 steps  (5%)
01:00:32:WU01:FS00:0xa4:Completed 1830000 out of 30500000 steps  (6%)
