10 WUs but no Points!
Spongebob25
Hardware configuration: ASUS ROG STRIX Z790-E
i7-14700K 5.6GHz
G.skill DDR5 RAM 48 GB 7200 MT/s
NVIDIA 4080 Reference Card
Samsung SSD 980 PRO 1TB
Samsung SSD 990 PRO 2TB
Post by Spongebob25 »
According to Extreme OC, I turned in 10 WU on 11-30-12 at 3:00pm, but I received 0 points.--> http://folding.extremeoverclocking.com/ ... =&u=355574
Can someone please look into this for me?
P5-133XL
Machine #2:
Machine 3:
Re: 10 WUs but no Points!
Post by P5-133XL »
Look at the logs. FAHControl has 3 tabs, the last is "logs". click do not follow and refresh. Then copy and paste it here between [code] [/code] tags.
Bad wus or unstable system? Need to see the log.
Spongebob25
i7-14700K 5.6GHz
Here is my log from 11-30-12
*********************** Log Started 2012-11-30T08:37:21Z ***********************
08:37:21:************************* Folding@home Client *************************
08:37:21:      Website: http://folding.stanford.edu/
08:37:21:    Copyright: (c) 2009-2012 Stanford University
08:37:21:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:37:21:         Args: --lifeline 5092 --command-port=36330
08:37:21:       Config: E:/fah data/config.xml
08:37:21:******************************** Build ********************************
08:37:21:      Version: 7.2.9
08:37:21:         Date: Oct 3 2012
08:37:21:         Time: 18:05:48
08:37:21:      SVN Rev: 3578
08:37:21:       Branch: fah/trunk/client
08:37:21:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
08:37:21:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
08:37:21:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
08:37:21:     Platform: win32 XP
08:37:21:         Bits: 32
08:37:21:         Mode: Release
08:37:21:******************************* System ********************************
08:37:21:          CPU: Intel(R) Core(TM) i7 CPU 980 @ 3.33GHz
08:37:21:       CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
08:37:21:         CPUs: 12
08:37:21:       Memory: 11.99GiB
08:37:21:  Free Memory: 10.05GiB
08:37:21:      Threads: WINDOWS_THREADS
08:37:21:   On Battery: false
08:37:21:   UTC offset: -6
08:37:21:          PID: 4240
08:37:21:          CWD: E:/fah data
08:37:21:           OS: Windows 8 Pro
08:37:21:      OS Arch: AMD64
08:37:21:         GPUs: 2
08:37:21:        GPU 0: NVIDIA:3 GK107 [GeForce GTX 670]
08:37:21:        GPU 1: NVIDIA:3 GK107 [GeForce GTX 670]
08:37:21:         CUDA: 3.0
08:37:21:  CUDA Driver: 5000
08:37:21:Win32 Service: false
08:37:21:***********************************************************************
08:37:21:<config>
08:37:21:  <!-- FahCore Control -->
08:37:21:  <checkpoint v='30'/>
08:37:21:  <cpu-affinity v='true'/>
08:37:21:
08:37:21:  <!-- Folding Slot Configuration -->
08:37:21:  <gpu v='true'/>
08:37:21:
08:37:21:  <!-- Network -->
08:37:21:  <proxy v=':8080'/>
08:37:21:
08:37:21:  <!-- User Information -->
08:37:21:  <passkey v='********************************'/>
08:37:21:  <team v='80856'/>
08:37:21:  <user v='Spongebob25'/>
08:37:21:
08:37:21:  <!-- Folding Slots -->
08:37:21:  <slot id='0' type='GPU'>
08:37:21:    <client-type v='beta'/>
08:37:21:  </slot>
08:37:21:  <slot id='1' type='GPU'>
08:37:21:  </slot>
08:37:21:  <slot id='2' type='SMP'>
08:37:21:    <cpus v='-1'/>
08:37:21:  </slot>
08:37:21:</config>
08:37:21:Trying to access database...
08:37:21:Successfully acquired database lock
08:37:21:Enabled folding slot 00: READY gpu:0:"GK107 [GeForce GTX 670]"
08:37:21:Enabled folding slot 01: READY gpu:1:"GK107 [GeForce GTX 670]"
08:37:21:Enabled folding slot 02: READY smp:12
08:37:21:WU03:FS00:Starting
08:37:21:WU03:FS00:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 03 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -gpu 0
08:37:21:WU03:FS00:Started FahCore on PID 1664
08:37:22:WU03:FS00:Core PID:2308
08:37:22:WU03:FS00:FahCore 0x15 started
08:37:22:WU04:FS01:Starting
08:37:22:WU04:FS01:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 04 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -gpu 1
08:37:22:WU04:FS01:Started FahCore on PID 4844
08:37:22:WU04:FS01:Core PID:1404
08:37:22:WU04:FS01:FahCore 0x15 started
08:37:22:WU03:FS00:0x15:
08:37:22:WU03:FS00:0x15:*------------------------------*
08:37:22:WU03:FS00:0x15:Folding@Home GPU Core
08:37:22:WU03:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
08:37:22:WU03:FS00:0x15:Build host             AmoebaRemote
08:37:22:WU03:FS00:0x15:Board Type             NVIDIA/CUDA
08:37:22:WU03:FS00:0x15:Core                   15
08:37:22:WU01:FS02:Starting
08:37:22:WU03:FS00:0x15:Window's signal control handler registered.
08:37:22:WU01:FS02:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -np 12
08:37:22:WU03:FS00:0x15:Preparing to commence simulation
08:37:22:WU01:FS02:Started FahCore on PID 3792
08:37:22:WU03:FS00:0x15:- Looking at optimizations...
08:37:22:WU03:FS00:0x15:- Files status OK
08:37:22:WU03:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:37:22:WU03:FS00:0x15:- Expanded 60291 -> 264278 (decompressed 438.3 percent)
08:37:22:WU03:FS00:0x15:Called DecompressByteArray: compressed_data_size=60291 data_size=264278, decompressed_data_size=264278 diff=0
08:37:22:WU03:FS00:0x15:- Digital signature verified
08:37:22:WU03:FS00:0x15:Project: 8054 (Run 0, Clone 1541, Gen 34)
08:37:22:WU03:FS00:0x15:Assembly optimizations on if available.
08:37:22:WU03:FS00:0x15:Entering M.D.
08:37:22:WU04:FS01:0x15:
08:37:22:WU04:FS01:0x15:*------------------------------*
08:37:22:WU04:FS01:0x15:Folding@Home GPU Core
08:37:22:WU04:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
08:37:22:WU04:FS01:0x15:Build host             AmoebaRemote
08:37:22:WU04:FS01:0x15:Board Type             NVIDIA/CUDA
08:37:22:WU04:FS01:0x15:Core                   15
08:37:22:WU04:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
08:37:22:WU04:FS01:0x15:Window's signal control handler registered.
08:37:22:WU04:FS01:0x15:Preparing to commence simulation
08:37:22:WU04:FS01:0x15:- Looking at optimizations...
08:37:22:WU04:FS01:0x15:- Files status OK
08:37:22:WU04:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:37:22:WU04:FS01:0x15:- Expanded 60238 -> 264278 (decompressed 438.7 percent)
08:37:22:WU04:FS01:0x15:Called DecompressByteArray: compressed_data_size=60238 data_size=264278, decompressed_data_size=264278 diff=0
08:37:22:WU04:FS01:0x15:- Digital signature verified
08:37:22:WU04:FS01:0x15:Project: 8054 (Run 0, Clone 2253, Gen 32)
08:37:22:WU04:FS01:0x15:Assembly optimizations on if available.
08:37:22:WU04:FS01:0x15:Entering M.D.
08:37:22:WU01:FS02:Core PID:2436
08:37:22:WU01:FS02:FahCore 0xa4 started
08:37:23:WU01:FS02:0xa4:
08:37:23:WU01:FS02:0xa4:*------------------------------*
08:37:23:WU01:FS02:0xa4:Folding@Home Gromacs GB Core
08:37:23:WU01:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
08:37:23:WU01:FS02:0xa4:Preparing to commence simulation
08:37:23:WU01:FS02:0xa4:- Ensuring status. Please wait.
08:37:24:WU03:FS00:0x15:Will resume from checkpoint file 03/wudata_01.ckp
08:37:24:WU03:FS00:0x15:Tpr hash 03/wudata_01.tpr:  398121558 4006156395 3468640279 1305015017 2675625077
08:37:24:WU03:FS00:0x15:GPU device id=0
08:37:24:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
08:37:24:WU03:FS00:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
08:37:24:WU03:FS00:0x15:Client config unavailable.
08:37:24:WU03:FS00:0x15:Starting GUI Server
08:37:24:WU04:FS01:0x15:Will resume from checkpoint file 04/wudata_01.ckp
08:37:24:WU04:FS01:0x15:Tpr hash 04/wudata_01.tpr:  1518902248 1763481873 566018976 1154438514 2700910811
08:37:24:WU04:FS01:0x15:GPU device id=1
08:37:24:WU04:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
08:37:24:WU04:FS01:0x15:Client config unavailable.
08:37:24:WU04:FS01:0x15:Starting GUI Server
08:37:32:WU01:FS02:0xa4:- Looking at optimizations...
08:37:32:WU01:FS02:0xa4:- Working with standard loops on this execution.
08:37:32:WU01:FS02:0xa4:- Previous termination of core was improper.
08:37:32:WU01:FS02:0xa4:- Files status OK
08:37:32:WU01:FS02:0xa4:- Expanded 687071 -> 1529696 (decompressed 222.6 percent)
08:37:32:WU01:FS02:0xa4:Called DecompressByteArray: compressed_data_size=687071 data_size=1529696, decompressed_data_size=1529696 diff=0
08:37:32:WU01:FS02:0xa4:- Digital signature verified
08:37:32:WU01:FS02:0xa4:Project: 8056 (Run 24, Clone 38, Gen 47)
08:37:32:WU01:FS02:0xa4:Entering M.D.
08:37:38:WU01:FS02:0xa4:Using Gromacs checkpoints
08:37:38:WU01:FS02:0xa4:Mapping NT from 12 to 12
08:37:38:WU01:FS02:0xa4:Resuming from checkpoint
08:37:38:WU01:FS02:0xa4:Verified 01/wudata_01.log
08:37:38:WU01:FS02:0xa4:Verified 01/wudata_01.trr
08:37:38:WU01:FS02:0xa4:Verified 01/wudata_01.xtc
08:37:38:WU01:FS02:0xa4:Verified 01/wudata_01.edr
08:37:38:WU01:FS02:0xa4:Completed 106820 out of 500000 steps  (21%)
08:38:14:WU01:FS02:0xa4:Completed 110000 out of 500000 steps  (22%)
08:38:25:WU04:FS01:0x15:Resuming from checkpoint
08:38:25:WU03:FS00:0x15:Resuming from checkpoint
08:38:25:WU04:FS01:0x15:fcCheckPointResume: retreived and current tpr file hash:
08:38:25:WU03:FS00:0x15:fcCheckPointResume: retreived and current tpr file hash:
08:38:25:WU04:FS01:0x15:   0   1518902248   1518902248
08:38:25:WU03:FS00:0x15:   0    398121558    398121558
08:38:25:WU04:FS01:0x15:   1   1763481873   1763481873
08:38:25:WU03:FS00:0x15:   1   4006156395   4006156395
08:38:25:WU04:FS01:0x15:   2    566018976    566018976
08:38:25:WU03:FS00:0x15:   2   3468640279   3468640279
08:38:25:WU04:FS01:0x15:   3   1154438514   1154438514
08:38:25:WU03:FS00:0x15:   3   1305015017   1305015017
08:38:25:WU04:FS01:0x15:   4   2700910811   2700910811
08:38:25:WU03:FS00:0x15:   4   2675625077   2675625077
08:38:25:WU04:FS01:0x15:fcCheckPointResume: file hashes same.
08:38:25:WU03:FS00:0x15:fcCheckPointResume: file hashes same.
08:38:25:WU04:FS01:0x15:fcCheckPointResume: state restored.
08:38:25:WU03:FS00:0x15:fcCheckPointResume: state restored.
08:38:25:WU04:FS01:0x15:fcCheckPointResume: name 04/wudata_01.log Verified 04/wudata_01.log
08:38:25:WU03:FS00:0x15:fcCheckPointResume: name 03/wudata_01.log Verified 03/wudata_01.log
08:38:25:WU04:FS01:0x15:fcCheckPointResume: name 04/wudata_01.trr Verified 04/wudata_01.trr
08:38:25:WU03:FS00:0x15:fcCheckPointResume: name 03/wudata_01.trr Verified 03/wudata_01.trr
08:38:25:WU04:FS01:0x15:fcCheckPointResume: name 04/wudata_01.xtc Verified 04/wudata_01.xtc
08:38:25:WU03:FS00:0x15:fcCheckPointResume: name 03/wudata_01.xtc Verified 03/wudata_01.xtc
08:38:25:WU04:FS01:0x15:fcCheckPointResume: name 04/wudata_01.edr Verified 04/wudata_01.edr
08:38:25:WU03:FS00:0x15:fcCheckPointResume: name 03/wudata_01.edr Verified 03/wudata_01.edr
08:38:25:WU04:FS01:0x15:fcCheckPointResume: state restored 2
08:38:25:WU03:FS00:0x15:fcCheckPointResume: state restored 2
08:38:25:WU04:FS01:0x15:Resumed from checkpoint
08:38:25:WU03:FS00:0x15:Resumed from checkpoint
08:38:25:WU04:FS01:0x15:Setting checkpoint frequency: 500000
08:38:25:WU03:FS00:0x15:Setting checkpoint frequency: 500000
08:38:25:WU04:FS01:0x15:Completed   7500001 out of 50000000 steps (15%).
08:38:25:WU03:FS00:0x15:Completed   7000001 out of 50000000 steps (14%).
08:38:25:WARNING:WU04:FS01:Detected clock skew (1 mins 03 secs), adjusting time estimates
08:39:25:WU01:FS02:0xa4:Completed 115000 out of 500000 steps  (23%)
08:40:32:WU03:FS00:0x15:Completed   7500000 out of 50000000 steps (15%).
08:40:36:WU04:FS01:0x15:Completed   8000000 out of 50000000 steps (16%).
08:40:40:WU01:FS02:0xa4:Completed 120000 out of 500000 steps  (24%)
08:41:54:WU01:FS02:0xa4:Completed 125000 out of 500000 steps  (25%)
08:42:40:WU03:FS00:0x15:Completed   8000000 out of 50000000 steps (16%).
08:42:48:WU04:FS01:0x15:Completed   8500000 out of 50000000 steps (17%).
08:43:11:WU01:FS02:0xa4:Completed 130000 out of 500000 steps  (26%)
08:44:26:WU01:FS02:0xa4:Completed 135000 out of 500000 steps  (27%)
08:44:48:WU03:FS00:0x15:Completed   8500000 out of 50000000 steps (17%).
08:45:01:WU04:FS01:0x15:Completed   9000000 out of 50000000 steps (18%).
08:45:41:WU01:FS02:0xa4:Completed 140000 out of 500000 steps  (28%)
08:46:55:WU01:FS02:0xa4:Completed 145000 out of 500000 steps  (29%)
08:46:56:WU03:FS00:0x15:Completed   9000000 out of 50000000 steps (18%).
08:47:14:WU04:FS01:0x15:Completed   9500000 out of 50000000 steps (19%).
08:48:10:WU01:FS02:0xa4:Completed 150000 out of 500000 steps  (30%)
08:49:03:WU03:FS00:0x15:Completed   9500000 out of 50000000 steps (19%).
08:49:22:WU01:FS02:0xa4:Completed 155000 out of 500000 steps  (31%)
08:49:27:WU04:FS01:0x15:Completed  10000000 out of 50000000 steps (20%).
08:50:36:WU01:FS02:0xa4:Completed 160000 out of 500000 steps  (32%)
08:51:11:WU03:FS00:0x15:Completed  10000000 out of 50000000 steps (20%).
08:51:41:WU04:FS01:0x15:Completed  10500000 out of 50000000 steps (21%).
08:51:50:WU01:FS02:0xa4:Completed 165000 out of 500000 steps  (33%)
08:53:04:WU01:FS02:0xa4:Completed 170000 out of 500000 steps  (34%)
08:53:19:WU03:FS00:0x15:Completed  10500000 out of 50000000 steps (21%).
08:53:54:WU04:FS01:0x15:Completed  11000000 out of 50000000 steps (22%).
08:54:18:WU01:FS02:0xa4:Completed 175000 out of 500000 steps  (35%)
08:55:27:WU03:FS00:0x15:Completed  11000000 out of 50000000 steps (22%).
08:55:33:WU01:FS02:0xa4:Completed 180000 out of 500000 steps  (36%)
08:56:07:WU04:FS01:0x15:Completed  11500000 out of 50000000 steps (23%).
08:56:46:WU01:FS02:0xa4:Completed 185000 out of 500000 steps  (37%)
08:57:35:WU03:FS00:0x15:Completed  11500000 out of 50000000 steps (23%).
08:58:01:WU01:FS02:0xa4:Completed 190000 out of 500000 steps  (38%)
08:58:20:WU04:FS01:0x15:Completed  12000000 out of 50000000 steps (24%).
08:59:15:WU01:FS02:0xa4:Completed 195000 out of 500000 steps  (39%)
08:59:43:WU03:FS00:0x15:Completed  12000000 out of 50000000 steps (24%).
09:00:33:WU04:FS01:0x15:Completed  12500000 out of 50000000 steps (25%).
09:01:51:WU03:FS00:0x15:Completed  12500000 out of 50000000 steps (25%).
09:02:45:WU04:FS01:0x15:Completed  13000000 out of 50000000 steps (26%).
09:03:59:WU03:FS00:0x15:Completed  13000000 out of 50000000 steps (26%).
09:04:57:WU04:FS01:0x15:Completed  13500000 out of 50000000 steps (27%).
09:06:06:WU03:FS00:0x15:Completed  13500000 out of 50000000 steps (27%).
09:07:08:WU04:FS01:0x15:Completed  14000000 out of 50000000 steps (28%).
09:08:14:WU03:FS00:0x15:Completed  14000000 out of 50000000 steps (28%).
09:09:20:WU04:FS01:0x15:Completed  14500000 out of 50000000 steps (29%).
09:10:22:WU03:FS00:0x15:Completed  14500000 out of 50000000 steps (29%).
09:11:31:WU04:FS01:0x15:Completed  15000000 out of 50000000 steps (30%).
09:12:29:WU03:FS00:0x15:Completed  15000000 out of 50000000 steps (30%).
09:13:43:WU04:FS01:0x15:Completed  15500000 out of 50000000 steps (31%).
09:14:37:WU03:FS00:0x15:Completed  15500000 out of 50000000 steps (31%).
09:15:19:WU01:FS02:0xa4:Completed 200000 out of 500000 steps  (40%)
09:15:54:WU04:FS01:0x15:Completed  16000000 out of 50000000 steps (32%).
09:16:45:WU03:FS00:0x15:Completed  16000000 out of 50000000 steps (32%).
09:17:23:WU01:FS02:0xa4:Completed 205000 out of 500000 steps  (41%)
09:18:06:WU04:FS01:0x15:Completed  16500000 out of 50000000 steps (33%).
09:18:37:WU01:FS02:0xa4:Completed 210000 out of 500000 steps  (42%)
09:18:52:WU03:FS00:0x15:Completed  16500000 out of 50000000 steps (33%).
09:19:50:WU01:FS02:0xa4:Completed 215000 out of 500000 steps  (43%)
09:20:18:WU04:FS01:0x15:Completed  17000000 out of 50000000 steps (34%).
09:21:00:WU03:FS00:0x15:Completed  17000000 out of 50000000 steps (34%).
09:21:04:WU01:FS02:0xa4:Completed 220000 out of 500000 steps  (44%)
09:22:19:WU01:FS02:0xa4:Completed 225000 out of 500000 steps  (45%)
09:22:29:WU04:FS01:0x15:Completed  17500000 out of 50000000 steps (35%).
09:23:08:WU03:FS00:0x15:Completed  17500000 out of 50000000 steps (35%).
09:23:32:WU01:FS02:0xa4:Completed 230000 out of 500000 steps  (46%)
09:24:41:WU04:FS01:0x15:Completed  18000000 out of 50000000 steps (36%).
09:24:46:WU01:FS02:0xa4:Completed 235000 out of 500000 steps  (47%)
09:25:15:WU03:FS00:0x15:Completed  18000000 out of 50000000 steps (36%).
09:26:00:WU01:FS02:0xa4:Completed 240000 out of 500000 steps  (48%)
09:26:52:WU04:FS01:0x15:Completed  18500000 out of 50000000 steps (37%).
09:27:13:WU01:FS02:0xa4:Completed 245000 out of 500000 steps  (49%)
09:27:23:WU03:FS00:0x15:Completed  18500000 out of 50000000 steps (37%).
09:28:27:WU01:FS02:0xa4:Completed 250000 out of 500000 steps  (50%)
09:29:04:WU04:FS01:0x15:Completed  19000000 out of 50000000 steps (38%).
09:29:31:WU03:FS00:0x15:Completed  19000000 out of 50000000 steps (38%).
09:29:40:WU01:FS02:0xa4:Completed 255000 out of 500000 steps  (51%)
09:30:54:WU01:FS02:0xa4:Completed 260000 out of 500000 steps  (52%)
09:31:15:WU04:FS01:0x15:Completed  19500000 out of 50000000 steps (39%).
09:31:38:WU03:FS00:0x15:Completed  19500000 out of 50000000 steps (39%).
09:32:08:WU01:FS02:0xa4:Completed 265000 out of 500000 steps  (53%)
09:33:22:WU01:FS02:0xa4:Completed 270000 out of 500000 steps  (54%)
09:33:27:WU04:FS01:0x15:Completed  20000000 out of 50000000 steps (40%).
09:33:46:WU03:FS00:0x15:Completed  20000000 out of 50000000 steps (40%).
09:34:37:WU01:FS02:0xa4:Completed 275000 out of 500000 steps  (55%)
09:35:38:WU04:FS01:0x15:Completed  20500000 out of 50000000 steps (41%).
09:35:50:WU01:FS02:0xa4:Completed 280000 out of 500000 steps  (56%)
09:35:54:WU03:FS00:0x15:Completed  20500000 out of 50000000 steps (41%).
09:37:06:WU01:FS02:0xa4:Completed 285000 out of 500000 steps  (57%)
09:37:50:WU04:FS01:0x15:Completed  21000000 out of 50000000 steps (42%).
09:38:01:WU03:FS00:0x15:Completed  21000000 out of 50000000 steps (42%).
09:38:20:WU01:FS02:0xa4:Completed 290000 out of 500000 steps  (58%)
09:39:33:WU01:FS02:0xa4:Completed 295000 out of 500000 steps  (59%)
09:40:02:WU04:FS01:0x15:Completed  21500000 out of 50000000 steps (43%).
09:40:09:WU03:FS00:0x15:Completed  21500000 out of 50000000 steps (43%).
09:40:46:WU01:FS02:0xa4:Completed 300000 out of 500000 steps  (60%)
09:42:00:WU01:FS02:0xa4:Completed 305000 out of 500000 steps  (61%)
09:42:13:WU04:FS01:0x15:Completed  22000000 out of 50000000 steps (44%).
09:42:17:WU03:FS00:0x15:Completed  22000000 out of 50000000 steps (44%).
09:43:13:WU01:FS02:0xa4:Completed 310000 out of 500000 steps  (62%)
09:44:25:WU03:FS00:0x15:Completed  22500000 out of 50000000 steps (45%).
09:44:25:WU04:FS01:0x15:Completed  22500000 out of 50000000 steps (45%).
09:44:27:WU01:FS02:0xa4:Completed 315000 out of 500000 steps  (63%)
09:45:42:WU01:FS02:0xa4:Completed 320000 out of 500000 steps  (64%)
09:46:32:WU03:FS00:0x15:Completed  23000000 out of 50000000 steps (46%).
09:46:36:WU04:FS01:0x15:Completed  23000000 out of 50000000 steps (46%).
09:46:56:WU01:FS02:0xa4:Completed 325000 out of 500000 steps  (65%)
09:48:11:WU01:FS02:0xa4:Completed 330000 out of 500000 steps  (66%)
09:48:40:WU03:FS00:0x15:Completed  23500000 out of 50000000 steps (47%).
09:48:48:WU04:FS01:0x15:Completed  23500000 out of 50000000 steps (47%).
09:49:27:WU01:FS02:0xa4:Completed 335000 out of 500000 steps  (67%)
09:50:42:WU01:FS02:0xa4:Completed 340000 out of 500000 steps  (68%)
09:50:48:WU03:FS00:0x15:Completed  24000000 out of 50000000 steps (48%).
09:51:00:WU04:FS01:0x15:Completed  24000000 out of 50000000 steps (48%).
09:51:57:WU01:FS02:0xa4:Completed 345000 out of 500000 steps  (69%)
09:52:55:WU03:FS00:0x15:Completed  24500000 out of 50000000 steps (49%).
09:53:11:WU01:FS02:0xa4:Completed 350000 out of 500000 steps  (70%)
09:53:11:WU04:FS01:0x15:Completed  24500000 out of 50000000 steps (49%).
09:54:25:WU01:FS02:0xa4:Completed 355000 out of 500000 steps  (71%)
09:55:03:WU03:FS00:0x15:Completed  25000000 out of 50000000 steps (50%).
09:55:23:WU04:FS01:0x15:Completed  25000000 out of 50000000 steps (50%).
09:55:39:WU01:FS02:0xa4:Completed 360000 out of 500000 steps  (72%)
09:56:54:WU01:FS02:0xa4:Completed 365000 out of 500000 steps  (73%)
09:57:11:WU03:FS00:0x15:Completed  25500000 out of 50000000 steps (51%).
09:57:34:WU04:FS01:0x15:Completed  25500000 out of 50000000 steps (51%).
09:58:08:WU01:FS02:0xa4:Completed 370000 out of 500000 steps  (74%)
09:59:18:WU03:FS00:0x15:Completed  26000000 out of 50000000 steps (52%).
09:59:23:WU01:FS02:0xa4:Completed 375000 out of 500000 steps  (75%)
09:59:46:WU04:FS01:0x15:Completed  26000000 out of 50000000 steps (52%).
10:00:37:WU01:FS02:0xa4:Completed 380000 out of 500000 steps  (76%)
10:01:26:WU03:FS00:0x15:Completed  26500000 out of 50000000 steps (53%).
10:01:51:WU01:FS02:0xa4:Completed 385000 out of 500000 steps  (77%)
10:01:58:WU04:FS01:0x15:Completed  26500000 out of 50000000 steps (53%).
10:03:04:WU01:FS02:0xa4:Completed 390000 out of 500000 steps  (78%)
10:03:34:WU03:FS00:0x15:Completed  27000000 out of 50000000 steps (54%).
10:04:09:WU04:FS01:0x15:Completed  27000000 out of 50000000 steps (54%).
10:04:18:WU01:FS02:0xa4:Completed 395000 out of 500000 steps  (79%)
10:05:32:WU01:FS02:0xa4:Completed 400000 out of 500000 steps  (80%)
10:05:42:WU03:FS00:0x15:Completed  27500000 out of 50000000 steps (55%).
10:06:21:WU04:FS01:0x15:Completed  27500000 out of 50000000 steps (55%).
10:06:46:WU01:FS02:0xa4:Completed 405000 out of 500000 steps  (81%)
10:07:49:WU03:FS00:0x15:Completed  28000000 out of 50000000 steps (56%).
10:08:00:WU01:FS02:0xa4:Completed 410000 out of 500000 steps  (82%)
10:08:32:WU04:FS01:0x15:Completed  28000000 out of 50000000 steps (56%).
10:09:14:WU01:FS02:0xa4:Completed 415000 out of 500000 steps  (83%)
10:09:57:WU03:FS00:0x15:Completed  28500000 out of 50000000 steps (57%).
10:10:28:WU01:FS02:0xa4:Completed 420000 out of 500000 steps  (84%)
10:10:44:WU04:FS01:0x15:Completed  28500000 out of 50000000 steps (57%).
10:11:41:WU01:FS02:0xa4:Completed 425000 out of 500000 steps  (85%)
10:12:05:WU03:FS00:0x15:Completed  29000000 out of 50000000 steps (58%).
10:12:55:WU01:FS02:0xa4:Completed 430000 out of 500000 steps  (86%)
10:12:55:WU04:FS01:0x15:Completed  29000000 out of 50000000 steps (58%).
10:14:10:WU01:FS02:0xa4:Completed 435000 out of 500000 steps  (87%)
10:14:13:WU03:FS00:0x15:Completed  29500000 out of 50000000 steps (59%).
10:15:07:WU04:FS01:0x15:Completed  29500000 out of 50000000 steps (59%).
10:15:24:WU01:FS02:0xa4:Completed 440000 out of 500000 steps  (88%)
10:16:21:WU03:FS00:0x15:Completed  30000000 out of 50000000 steps (60%).
10:16:38:WU01:FS02:0xa4:Completed 445000 out of 500000 steps  (89%)
10:17:19:WU04:FS01:0x15:Completed  30000000 out of 50000000 steps (60%).
10:17:53:WU01:FS02:0xa4:Completed 450000 out of 500000 steps  (90%)
10:18:29:WU03:FS00:0x15:Completed  30500000 out of 50000000 steps (61%).
10:19:07:WU01:FS02:0xa4:Completed 455000 out of 500000 steps  (91%)
10:19:30:WU04:FS01:0x15:Completed  30500000 out of 50000000 steps (61%).
10:20:23:WU01:FS02:0xa4:Completed 460000 out of 500000 steps  (92%)
10:20:36:WU03:FS00:0x15:Completed  31000000 out of 50000000 steps (62%).
10:21:37:WU01:FS02:0xa4:Completed 465000 out of 500000 steps  (93%)
10:21:42:WU04:FS01:0x15:Completed  31000000 out of 50000000 steps (62%).
10:22:45:WU03:FS00:0x15:Completed  31500000 out of 50000000 steps (63%).
10:22:53:WU01:FS02:0xa4:Completed 470000 out of 500000 steps  (94%)
10:23:54:WU04:FS01:0x15:Completed  31500000 out of 50000000 steps (63%).
10:24:07:WU01:FS02:0xa4:Completed 475000 out of 500000 steps  (95%)
10:24:53:WU03:FS00:0x15:Completed  32000000 out of 50000000 steps (64%).
10:25:22:WU01:FS02:0xa4:Completed 480000 out of 500000 steps  (96%)
10:26:05:WU04:FS01:0x15:Completed  32000000 out of 50000000 steps (64%).
10:26:37:WU01:FS02:0xa4:Completed 485000 out of 500000 steps  (97%)
10:27:01:WU03:FS00:0x15:Completed  32500000 out of 50000000 steps (65%).
10:27:54:WU01:FS02:0xa4:Completed 490000 out of 500000 steps  (98%)
10:28:17:WU04:FS01:0x15:Completed  32500000 out of 50000000 steps (65%).
10:29:09:WU03:FS00:0x15:Completed  33000000 out of 50000000 steps (66%).
10:29:10:WU01:FS02:0xa4:Completed 495000 out of 500000 steps  (99%)
10:29:11:WU00:FS02:Connecting to assign3.stanford.edu:8080
10:29:11:WU00:FS02:News: Welcome to Folding@Home
10:29:11:WU00:FS02:Assigned to work server 171.67.108.59
10:29:11:WU00:FS02:Requesting new work unit for slot 02: RUNNING smp:12 from 171.67.108.59
10:29:11:WU00:FS02:Connecting to 171.67.108.59:8080
10:29:12:WU00:FS02:Downloading 673.38KiB
10:29:13:WU00:FS02:Download complete
10:29:13:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8056 run:15 clone:40 gen:53 core:0xa4 unit:0x000000486652edcb506cedf58de68c24
10:30:25:WU01:FS02:0xa4:Completed 500000 out of 500000 steps  (100%)
10:30:26:WU01:FS02:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
10:30:29:WU04:FS01:0x15:Completed  33000000 out of 50000000 steps (66%).
10:30:36:WU01:FS02:0xa4:
10:30:36:WU01:FS02:0xa4:Finished Work Unit:
10:30:36:WU01:FS02:0xa4:- Reading up to 877812 from "01/wudata_01.trr": Read 877812
10:30:36:WU01:FS02:0xa4:trr file hash check passed.
10:30:36:WU01:FS02:0xa4:- Reading up to 958376 from "01/wudata_01.xtc": Read 958376
10:30:36:WU01:FS02:0xa4:xtc file hash check passed.
10:30:36:WU01:FS02:0xa4:edr file hash check passed.
10:30:36:WU01:FS02:0xa4:logfile size: 27787
10:30:36:WU01:FS02:0xa4:Leaving Run
10:30:37:WU01:FS02:0xa4:- Writing 1872947 bytes of core data to disk...
10:30:37:WU01:FS02:0xa4:Done: 1872435 -> 1803583 (compressed to 96.3 percent)
10:30:37:WU01:FS02:0xa4:  ... Done.
10:30:38:WU01:FS02:0xa4:- Shutting down core
10:30:38:WU01:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
10:30:38:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:30:38:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:8056 run:24 clone:38 gen:47 core:0xa4 unit:0x000000446652edcb506cee6c82afe049
10:30:38:WU01:FS02:Uploading 1.72MiB to 171.67.108.59
10:30:38:WU00:FS02:Starting
10:30:38:WU01:FS02:Connecting to 171.67.108.59:8080
10:30:38:WU00:FS02:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -np 12
10:30:38:WU00:FS02:Started FahCore on PID 4312
10:30:39:WU00:FS02:Core PID:3060
10:30:39:WU00:FS02:FahCore 0xa4 started
10:30:39:WU00:FS02:0xa4:
10:30:39:WU00:FS02:0xa4:*------------------------------*
10:30:39:WU00:FS02:0xa4:Folding@Home Gromacs GB Core
10:30:39:WU00:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
10:30:39:WU00:FS02:0xa4:Preparing to commence simulation
10:30:39:WU00:FS02:0xa4:- Looking at optimizations...
10:30:39:WU00:FS02:0xa4:- Created dyn
10:30:39:WU00:FS02:0xa4:- Files status OK
10:30:39:WU00:FS02:0xa4:- Expanded 689030 -> 1532720 (decompressed 222.4 percent)
10:30:39:WU00:FS02:0xa4:Called DecompressByteArray: compressed_data_size=689030 data_size=1532720, decompressed_data_size=1532720 diff=0
10:30:39:WU00:FS02:0xa4:- Digital signature verified
10:30:39:WU00:FS02:0xa4:Project: 8056 (Run 15, Clone 40, Gen 53)
10:30:39:WU00:FS02:0xa4:Assembly optimizations on if available.
10:30:39:WU00:FS02:0xa4:Entering M.D.
10:30:45:WU00:FS02:0xa4:Mapping NT from 12 to 12
10:30:45:WU00:FS02:0xa4:Completed 0 out of 500000 steps  (0%)
10:30:46:WU01:FS02:Upload complete
10:30:46:WU01:FS02:Server responded WORK_ACK (400)
10:30:46:WU01:FS02:Final credit estimate, 319.00 points
10:30:46:WU01:FS02:Cleaning up
10:31:18:WU03:FS00:0x15:Completed  33500000 out of 50000000 steps (67%).
10:32:02:WU00:FS02:0xa4:Completed 5000 out of 500000 steps  (1%)
10:32:41:WU04:FS01:0x15:Completed  33500000 out of 50000000 steps (67%).
10:33:15:WU00:FS02:0xa4:Completed 10000 out of 500000 steps  (2%)
10:33:26:WU03:FS00:0x15:Completed  34000000 out of 50000000 steps (68%).
10:34:30:WU00:FS02:0xa4:Completed 15000 out of 500000 steps  (3%)
10:34:52:WU04:FS01:0x15:Completed  34000000 out of 50000000 steps (68%).
10:35:35:WU03:FS00:0x15:Completed  34500000 out of 50000000 steps (69%).
10:35:47:WU00:FS02:0xa4:Completed 20000 out of 500000 steps  (4%)
10:37:03:WU00:FS02:0xa4:Completed 25000 out of 500000 steps  (5%)
10:37:04:WU04:FS01:0x15:Completed  34500000 out of 50000000 steps (69%).
10:37:43:WU03:FS00:0x15:Completed  35000000 out of 50000000 steps (70%).
10:38:17:WU00:FS02:0xa4:Completed 30000 out of 500000 steps  (6%)
10:39:16:WU04:FS01:0x15:Completed  35000000 out of 50000000 steps (70%).
10:39:31:WU00:FS02:0xa4:Completed 35000 out of 500000 steps  (7%)
10:39:51:WU03:FS00:0x15:Completed  35500000 out of 50000000 steps (71%).
10:40:44:WU00:FS02:0xa4:Completed 40000 out of 500000 steps  (8%)
10:41:27:WU04:FS01:0x15:Completed  35500000 out of 50000000 steps (71%).
10:41:58:WU00:FS02:0xa4:Completed 45000 out of 500000 steps  (9%)
10:41:59:WU03:FS00:0x15:Completed  36000000 out of 50000000 steps (72%).
10:43:12:WU00:FS02:0xa4:Completed 50000 out of 500000 steps  (10%)
10:43:39:WU04:FS01:0x15:Completed  36000000 out of 50000000 steps (72%).
10:44:07:WU03:FS00:0x15:Completed  36500000 out of 50000000 steps (73%).
10:44:26:WU00:FS02:0xa4:Completed 55000 out of 500000 steps  (11%)
10:45:39:WU00:FS02:0xa4:Completed 60000 out of 500000 steps  (12%)
10:45:51:WU04:FS01:0x15:Completed  36500000 out of 50000000 steps (73%).
10:46:15:WU03:FS00:0x15:Completed  37000000 out of 50000000 steps (74%).
10:46:54:WU00:FS02:0xa4:Completed 65000 out of 500000 steps  (13%)
10:48:02:WU04:FS01:0x15:Completed  37000000 out of 50000000 steps (74%).
10:48:06:WU00:FS02:0xa4:Completed 70000 out of 500000 steps  (14%)
10:48:23:WU03:FS00:0x15:Completed  37500000 out of 50000000 steps (75%).
10:49:19:WU00:FS02:0xa4:Completed 75000 out of 500000 steps  (15%)
10:50:14:WU04:FS01:0x15:Completed  37500000 out of 50000000 steps (75%).
10:50:30:WU03:FS00:0x15:Completed  38000000 out of 50000000 steps (76%).
10:50:32:WU00:FS02:0xa4:Completed 80000 out of 500000 steps  (16%)
10:51:45:WU00:FS02:0xa4:Completed 85000 out of 500000 steps  (17%)
10:52:26:WU04:FS01:0x15:Completed  38000000 out of 50000000 steps (76%).
10:52:38:WU03:FS00:0x15:Completed  38500000 out of 50000000 steps (77%).
10:53:00:WU00:FS02:0xa4:Completed 90000 out of 500000 steps  (18%)
10:54:14:WU00:FS02:0xa4:Completed 95000 out of 500000 steps  (19%)
10:54:38:WU04:FS01:0x15:Completed  38500000 out of 50000000 steps (77%).
10:54:46:WU03:FS00:0x15:Completed  39000000 out of 50000000 steps (78%).
10:55:29:WU00:FS02:0xa4:Completed 100000 out of 500000 steps  (20%)
10:56:41:WU00:FS02:0xa4:Completed 105000 out of 500000 steps  (21%)
10:56:49:WU04:FS01:0x15:Completed  39000000 out of 50000000 steps (78%).
10:56:54:WU03:FS00:0x15:Completed  39500000 out of 50000000 steps (79%).
10:57:55:WU00:FS02:0xa4:Completed 110000 out of 500000 steps  (22%)
10:59:01:WU04:FS01:0x15:Completed  39500000 out of 50000000 steps (79%).
10:59:02:WU03:FS00:0x15:Completed  40000000 out of 50000000 steps (80%).
10:59:09:WU00:FS02:0xa4:Completed 115000 out of 500000 steps  (23%)
11:00:24:WU00:FS02:0xa4:Completed 120000 out of 500000 steps  (24%)
11:01:09:WU03:FS00:0x15:Completed  40500000 out of 50000000 steps (81%).
11:01:12:WU04:FS01:0x15:Completed  40000000 out of 50000000 steps (80%).
11:01:37:WU00:FS02:0xa4:Completed 125000 out of 500000 steps  (25%)
11:02:51:WU00:FS02:0xa4:Completed 130000 out of 500000 steps  (26%)
11:03:17:WU03:FS00:0x15:Completed  41000000 out of 50000000 steps (82%).
11:03:24:WU04:FS01:0x15:Completed  40500000 out of 50000000 steps (81%).
11:04:04:WU00:FS02:0xa4:Completed 135000 out of 500000 steps  (27%)
11:05:16:WU00:FS02:0xa4:Completed 140000 out of 500000 steps  (28%)
11:05:25:WU03:FS00:0x15:Completed  41500000 out of 50000000 steps (83%).
11:05:36:WU04:FS01:0x15:Completed  41000000 out of 50000000 steps (82%).
11:06:30:WU00:FS02:0xa4:Completed 145000 out of 500000 steps  (29%)
11:07:33:WU03:FS00:0x15:Completed  42000000 out of 50000000 steps (84%).
11:07:42:WU00:FS02:0xa4:Completed 150000 out of 500000 steps  (30%)
11:07:47:WU04:FS01:0x15:Completed  41500000 out of 50000000 steps (83%).
11:08:57:WU00:FS02:0xa4:Completed 155000 out of 500000 steps  (31%)
11:09:40:WU03:FS00:0x15:Completed  42500000 out of 50000000 steps (85%).
11:09:59:WU04:FS01:0x15:Completed  42000000 out of 50000000 steps (84%).
11:10:12:WU00:FS02:0xa4:Completed 160000 out of 500000 steps  (32%)
11:11:26:WU00:FS02:0xa4:Completed 165000 out of 500000 steps  (33%)
11:11:48:WU03:FS00:0x15:Completed  43000000 out of 50000000 steps (86%).
11:12:10:WU04:FS01:0x15:Completed  42500000 out of 50000000 steps (85%).
11:12:40:WU00:FS02:0xa4:Completed 170000 out of 500000 steps  (34%)
11:13:54:WU00:FS02:0xa4:Completed 175000 out of 500000 steps  (35%)
11:13:56:WU03:FS00:0x15:Completed  43500000 out of 50000000 steps (87%).
11:14:22:WU04:FS01:0x15:Completed  43000000 out of 50000000 steps (86%).
11:15:11:WU00:FS02:0xa4:Completed 180000 out of 500000 steps  (36%)
11:16:04:WU03:FS00:0x15:Completed  44000000 out of 50000000 steps (88%).
11:16:25:WU00:FS02:0xa4:Completed 185000 out of 500000 steps  (37%)
11:16:33:WU04:FS01:0x15:Completed  43500000 out of 50000000 steps (87%).
11:17:38:WU00:FS02:0xa4:Completed 190000 out of 500000 steps  (38%)
11:18:11:WU03:FS00:0x15:Completed  44500000 out of 50000000 steps (89%).
11:18:45:WU04:FS01:0x15:Completed  44000000 out of 50000000 steps (88%).
11:18:53:WU00:FS02:0xa4:Completed 195000 out of 500000 steps  (39%)
11:20:07:WU00:FS02:0xa4:Completed 200000 out of 500000 steps  (40%)
11:20:19:WU03:FS00:0x15:Completed  45000000 out of 50000000 steps (90%).
11:20:57:WU04:FS01:0x15:Completed  44500000 out of 50000000 steps (89%).
11:21:21:WU00:FS02:0xa4:Completed 205000 out of 500000 steps  (41%)
11:22:27:WU03:FS00:0x15:Completed  45500000 out of 50000000 steps (91%).
11:22:35:WU00:FS02:0xa4:Completed 210000 out of 500000 steps  (42%)
11:23:08:WU04:FS01:0x15:Completed  45000000 out of 50000000 steps (90%).
11:23:49:WU00:FS02:0xa4:Completed 215000 out of 500000 steps  (43%)
11:24:35:WU03:FS00:0x15:Completed  46000000 out of 50000000 steps (92%).
11:25:04:WU00:FS02:0xa4:Completed 220000 out of 500000 steps  (44%)
11:25:20:WU04:FS01:0x15:Completed  45500000 out of 50000000 steps (91%).
11:26:18:WU00:FS02:0xa4:Completed 225000 out of 500000 steps  (45%)
11:26:42:WU03:FS00:0x15:Completed  46500000 out of 50000000 steps (93%).
11:27:32:WU04:FS01:0x15:Completed  46000000 out of 50000000 steps (92%).
11:27:35:WU00:FS02:0xa4:Completed 230000 out of 500000 steps  (46%)
11:28:50:WU03:FS00:0x15:Completed  47000000 out of 50000000 steps (94%).
11:28:51:WU00:FS02:0xa4:Completed 235000 out of 500000 steps  (47%)
11:29:43:WU04:FS01:0x15:Completed  46500000 out of 50000000 steps (93%).
11:30:05:WU00:FS02:0xa4:Completed 240000 out of 500000 steps  (48%)
11:30:58:WU03:FS00:0x15:Completed  47500000 out of 50000000 steps (95%).
11:31:20:WU00:FS02:0xa4:Completed 245000 out of 500000 steps  (49%)
11:31:55:WU04:FS01:0x15:Completed  47000000 out of 50000000 steps (94%).
11:32:37:WU00:FS02:0xa4:Completed 250000 out of 500000 steps  (50%)
11:33:05:WU03:FS00:0x15:Completed  48000000 out of 50000000 steps (96%).
11:33:51:WU00:FS02:0xa4:Completed 255000 out of 500000 steps  (51%)
11:34:06:WU04:FS01:0x15:Completed  47500000 out of 50000000 steps (95%).
11:35:04:WU00:FS02:0xa4:Completed 260000 out of 500000 steps  (52%)
11:35:13:WU03:FS00:0x15:Completed  48500000 out of 50000000 steps (97%).
11:36:18:WU04:FS01:0x15:Completed  48000000 out of 50000000 steps (96%).
11:36:19:WU00:FS02:0xa4:Completed 265000 out of 500000 steps  (53%)
11:37:20:WU03:FS00:0x15:Completed  49000000 out of 50000000 steps (98%).
11:37:33:WU00:FS02:0xa4:Completed 270000 out of 500000 steps  (54%)
11:38:30:WU04:FS01:0x15:Completed  48500000 out of 50000000 steps (97%).
11:38:48:WU00:FS02:0xa4:Completed 275000 out of 500000 steps  (55%)
11:39:28:WU03:FS00:0x15:Completed  49500000 out of 50000000 steps (99%).
11:39:29:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
11:39:29:WU01:FS00:News: Welcome to Folding@Home
11:39:29:WU01:FS00:Assigned to work server 171.67.108.144
11:39:29:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GK107 [GeForce GTX 670]" from 171.67.108.144
11:39:29:WU01:FS00:Connecting to 171.67.108.144:8080
11:39:30:WU01:FS00:Downloading 56.75KiB
11:39:30:WU01:FS00:Download complete
11:39:30:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8057 run:0 clone:956 gen:2 core:0x15 unit:0x000000036953ee30508b38e29a03cc6b
11:40:03:WU00:FS02:0xa4:Completed 280000 out of 500000 steps  (56%)
11:40:41:WU04:FS01:0x15:Completed  49000000 out of 50000000 steps (98%).
11:41:19:WU00:FS02:0xa4:Completed 285000 out of 500000 steps  (57%)
11:41:36:WU03:FS00:0x15:Completed  50000000 out of 50000000 steps (100%).
11:41:36:WU03:FS00:0x15:Finished fah_main status=0
11:41:36:WU03:FS00:0x15:Successful run
11:41:36:WU03:FS00:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
11:41:46:WU03:FS00:0x15:Reserved 331100 bytes for xtc file; Cosm status=0
11:41:46:WU03:FS00:0x15:Allocated 331100 bytes for xtc file
11:41:46:WU03:FS00:0x15:- Reading up to 331100 from "03/wudata_01.xtc": Read 331100
11:41:46:WU03:FS00:0x15:Read 331100 bytes from xtc file; available packet space=786099364
11:41:46:WU03:FS00:0x15:xtc file hash check passed.
11:41:46:WU03:FS00:0x15:Reserved 20616 20616 786099364 bytes for arc file=<03/wudata_01.trr> Cosm status=0
11:41:46:WU03:FS00:0x15:Allocated 20616 bytes for arc file
11:41:46:WU03:FS00:0x15:- Reading up to 20616 from "03/wudata_01.trr": Read 20616
11:41:46:WU03:FS00:0x15:Read 20616 bytes from arc file; available packet space=786078748
11:41:46:WU03:FS00:0x15:trr file hash check passed.
11:41:46:WU03:FS00:0x15:Allocated 544 bytes for edr file
11:41:46:WU03:FS00:0x15:Read bedfile
11:41:46:WU03:FS00:0x15:edr file hash check passed.
11:41:46:WU03:FS00:0x15:Allocated 37180 bytes for logfile
11:41:46:WU03:FS00:0x15:Read logfile
11:41:46:WU03:FS00:0x15:GuardedRun: success in DynamicWrapper
11:41:46:WU03:FS00:0x15:GuardedRun: done
11:41:46:WU03:FS00:0x15:Run: GuardedRun completed.
11:41:48:WU03:FS00:0x15:+ Opened results file
11:41:48:WU03:FS00:0x15:- Writing 389952 bytes of core data to disk...
11:41:48:WU03:FS00:0x15:Done: 389440 -> 358470 (compressed to 92.0 percent)
11:41:48:WU03:FS00:0x15:  ... Done.
11:41:48:WU03:FS00:0x15:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
11:41:48:WU03:FS00:0x15:Shutting down core
11:41:48:WU03:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
11:41:48:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:41:48:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:8054 run:0 clone:1541 gen:34 core:0x15 unit:0x000000286953ee2f50626afc56f641bc
11:41:48:WU03:FS00:Uploading 350.57KiB to 171.67.108.143
11:41:48:WU03:FS00:Connecting to 171.67.108.143:8080
11:41:48:WU01:FS00:Starting
11:41:48:WU01:FS00:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -gpu 0
11:41:49:WU01:FS00:Started FahCore on PID 2244
11:41:49:WU01:FS00:Core PID:40
11:41:49:WU01:FS00:FahCore 0x15 started
11:41:50:WU03:FS00:Upload complete
11:41:50:WU03:FS00:Server responded WORK_ACK (400)
11:41:50:WU03:FS00:Final credit estimate, 2387.00 points
11:41:50:WU03:FS00:Cleaning up
11:41:50:WU01:FS00:0x15:
11:41:50:WU01:FS00:0x15:*------------------------------*
11:41:50:WU01:FS00:0x15:Folding@Home GPU Core
11:41:50:WU01:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
11:41:50:WU01:FS00:0x15:Build host             AmoebaRemote
11:41:50:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
11:41:50:WU01:FS00:0x15:Core                   15
11:41:50:WU01:FS00:0x15:Window's signal control handler registered.
11:41:50:WU01:FS00:0x15:Preparing to commence simulation
11:41:50:WU01:FS00:0x15:- Looking at optimizations...
11:41:50:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
11:41:50:WU01:FS00:0x15:- Created dyn
11:41:50:WU01:FS00:0x15:- Files status OK
11:41:50:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
11:41:50:WU01:FS00:0x15:- Expanded 57604 -> 261042 (decompressed 453.1 percent)
11:41:50:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=57604 data_size=261042, decompressed_data_size=261042 diff=0
11:41:50:WU01:FS00:0x15:- Digital signature verified
11:41:50:WU01:FS00:0x15:Project: 8057 (Run 0, Clone 956, Gen 2)
11:41:50:WU01:FS00:0x15:Assembly optimizations on if available.
11:41:50:WU01:FS00:0x15:Entering M.D.
11:41:51:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  4244660438 2289383540 511911715 718765633 2406788595
11:41:51:WU01:FS00:0x15:GPU device id=0
11:41:52:WU01:FS00:0x15:Working on Giving Russians Opium May Alter Current Situation
11:41:52:WU01:FS00:0x15:Client config unavailable.
11:41:52:WU01:FS00:0x15:Starting GUI Server
11:42:31:WU00:FS02:0xa4:Completed 290000 out of 500000 steps  (58%)
11:42:53:WU04:FS01:0x15:Completed  49500000 out of 50000000 steps (99%).
11:42:54:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
11:42:54:WU02:FS01:News: Welcome to Folding@Home
11:42:54:WU02:FS01:Assigned to work server 171.67.108.143
11:42:54:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:"GK107 [GeForce GTX 670]" from 171.67.108.143
11:42:54:WU02:FS01:Connecting to 171.67.108.143:8080
11:42:55:WU02:FS01:Downloading 59.24KiB
11:42:55:WU02:FS01:Download complete
11:42:55:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8054 run:0 clone:2288 gen:40 core:0x15 unit:0x0000002e6953ee2f50626b3f75b0832c
11:43:00:WU01:FS00:0x15:Setting checkpoint frequency: 500000
11:43:00:WU01:FS00:0x15:Completed         3 out of 50000000 steps (0%).
11:43:46:WU00:FS02:0xa4:Completed 295000 out of 500000 steps  (59%)
11:45:04:WU04:FS01:0x15:Completed  50000000 out of 50000000 steps (100%).
11:45:05:WU04:FS01:0x15:Finished fah_main status=0
11:45:05:WU04:FS01:0x15:Successful run
11:45:05:WU04:FS01:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
11:45:05:WU00:FS02:0xa4:Completed 300000 out of 500000 steps  (60%)
11:45:09:WU01:FS00:0x15:Completed    500000 out of 50000000 steps (1%).
11:45:15:WU04:FS01:0x15:Reserved 329896 bytes for xtc file; Cosm status=0
11:45:15:WU04:FS01:0x15:Allocated 329896 bytes for xtc file
11:45:15:WU04:FS01:0x15:- Reading up to 329896 from "04/wudata_01.xtc": Read 329896
11:45:15:WU04:FS01:0x15:Read 329896 bytes from xtc file; available packet space=786100568
11:45:15:WU04:FS01:0x15:xtc file hash check passed.
11:45:15:WU04:FS01:0x15:Reserved 20616 20616 786100568 bytes for arc file=<04/wudata_01.trr> Cosm status=0
11:45:15:WU04:FS01:0x15:Allocated 20616 bytes for arc file
11:45:15:WU04:FS01:0x15:- Reading up to 20616 from "04/wudata_01.trr": Read 20616
11:45:15:WU04:FS01:0x15:Read 20616 bytes from arc file; available packet space=786079952
11:45:15:WU04:FS01:0x15:trr file hash check passed.
11:45:15:WU04:FS01:0x15:Allocated 544 bytes for edr file
11:45:15:WU04:FS01:0x15:Read bedfile
11:45:15:WU04:FS01:0x15:edr file hash check passed.
11:45:15:WU04:FS01:0x15:Allocated 37180 bytes for logfile
11:45:15:WU04:FS01:0x15:Read logfile
11:45:15:WU04:FS01:0x15:GuardedRun: success in DynamicWrapper
11:45:15:WU04:FS01:0x15:GuardedRun: done
11:45:15:WU04:FS01:0x15:Run: GuardedRun completed.
11:45:17:WU04:FS01:0x15:+ Opened results file
11:45:17:WU04:FS01:0x15:- Writing 388748 bytes of core data to disk...
11:45:17:WU04:FS01:0x15:Done: 388236 -> 357144 (compressed to 91.9 percent)
11:45:17:WU04:FS01:0x15:  ... Done.
11:45:17:WU04:FS01:0x15:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
11:45:17:WU04:FS01:0x15:Shutting down core
11:45:17:WU04:FS01:0x15:Folding@home Core Shutdown: FINISHED_UNIT
11:45:18:WU04:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:45:18:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:8054 run:0 clone:2253 gen:32 core:0x15 unit:0x000000266953ee2f50626b3bdea9152b
11:45:18:WU04:FS01:Uploading 349.27KiB to 171.67.108.143
11:45:18:WU04:FS01:Connecting to 171.67.108.143:8080
11:45:18:WU02:FS01:Starting
11:45:18:WU02:FS01:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -gpu 1
11:45:18:WU02:FS01:Started FahCore on PID 4292
11:45:18:WU02:FS01:Core PID:3836
11:45:18:WU02:FS01:FahCore 0x15 started
11:45:19:WU02:FS01:0x15:
11:45:19:WU02:FS01:0x15:*------------------------------*
11:45:19:WU02:FS01:0x15:Folding@Home GPU Core
11:45:19:WU02:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
11:45:19:WU02:FS01:0x15:Build host             AmoebaRemote
11:45:19:WU02:FS01:0x15:Board Type             NVIDIA/CUDA
11:45:19:WU02:FS01:0x15:Core                   15
11:45:19:WU02:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
11:45:19:WU02:FS01:0x15:Window's signal control handler registered.
11:45:19:WU02:FS01:0x15:Preparing to commence simulation
11:45:19:WU02:FS01:0x15:- Looking at optimizations...
11:45:19:WU02:FS01:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
11:45:19:WU02:FS01:0x15:- Created dyn
11:45:19:WU02:FS01:0x15:- Files status OK
11:45:19:WU02:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
11:45:19:WU02:FS01:0x15:- Expanded 60151 -> 264278 (decompressed 439.3 percent)
11:45:19:WU02:FS01:0x15:Called DecompressByteArray: compressed_data_size=60151 data_size=264278, decompressed_data_size=264278 diff=0
11:45:19:WU02:FS01:0x15:- Digital signature verified
11:45:19:WU02:FS01:0x15:Project: 8054 (Run 0, Clone 2288, Gen 40)
11:45:19:WU02:FS01:0x15:Assembly optimizations on if available.
11:45:19:WU02:FS01:0x15:Entering M.D.
11:45:19:WU04:FS01:Upload complete
11:45:19:WU04:FS01:Server responded WORK_ACK (400)
11:45:19:WU04:FS01:Final credit estimate, 2387.00 points
11:45:19:WU04:FS01:Cleaning up
11:45:21:WU02:FS01:0x15:Tpr hash 02/wudata_01.tpr:  1502179783 2958696790 3189292647 866832264 1350079086
11:45:21:WU02:FS01:0x15:GPU device id=1
11:45:21:WU02:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
11:45:21:WU02:FS01:0x15:Client config unavailable.
11:45:21:WU02:FS01:0x15:Starting GUI Server
11:46:15:WU00:FS02:0xa4:Completed 305000 out of 500000 steps  (61%)
11:46:30:WU02:FS01:0x15:Setting checkpoint frequency: 500000
11:46:30:WU02:FS01:0x15:Completed         3 out of 50000000 steps (0%).
11:47:18:WU01:FS00:0x15:Completed   1000000 out of 50000000 steps (2%).
11:47:32:WU00:FS02:0xa4:Completed 310000 out of 500000 steps  (62%)
11:48:42:WU02:FS01:0x15:Completed    500000 out of 50000000 steps (1%).
11:48:51:WU00:FS02:0xa4:Completed 315000 out of 500000 steps  (63%)
11:49:26:WU01:FS00:0x15:Completed   1500000 out of 50000000 steps (3%).
11:50:07:WU00:FS02:0xa4:Completed 320000 out of 500000 steps  (64%)
11:50:55:WU02:FS01:0x15:Completed   1000000 out of 50000000 steps (2%).
11:51:25:WU00:FS02:0xa4:Completed 325000 out of 500000 steps  (65%)
11:51:35:WU01:FS00:0x15:Completed   2000000 out of 50000000 steps (4%).
11:52:44:WU00:FS02:0xa4:Completed 330000 out of 500000 steps  (66%)
11:53:08:WU02:FS01:0x15:Completed   1500000 out of 50000000 steps (3%).
11:53:44:WU01:FS00:0x15:Completed   2500000 out of 50000000 steps (5%).
11:54:02:WU00:FS02:0xa4:Completed 335000 out of 500000 steps  (67%)
11:55:19:WU00:FS02:0xa4:Completed 340000 out of 500000 steps  (68%)
11:55:21:WU02:FS01:0x15:Completed   2000000 out of 50000000 steps (4%).
11:55:52:WU01:FS00:0x15:Completed   3000000 out of 50000000 steps (6%).
11:56:35:WU00:FS02:0xa4:Completed 345000 out of 500000 steps  (69%)
11:57:34:WU02:FS01:0x15:Completed   2500000 out of 50000000 steps (5%).
11:57:53:WU00:FS02:0xa4:Completed 350000 out of 500000 steps  (70%)
11:58:01:WU01:FS00:0x15:Completed   3500000 out of 50000000 steps (7%).
11:59:10:WU00:FS02:0xa4:Completed 355000 out of 500000 steps  (71%)
11:59:47:WU02:FS01:0x15:Completed   3000000 out of 50000000 steps (6%).
12:00:10:WU01:FS00:0x15:Completed   4000000 out of 50000000 steps (8%).
12:00:28:WU00:FS02:0xa4:Completed 360000 out of 500000 steps  (72%)
12:01:46:WU00:FS02:0xa4:Completed 365000 out of 500000 steps  (73%)
12:02:00:WU02:FS01:0x15:Completed   3500000 out of 50000000 steps (7%).
12:02:18:WU01:FS00:0x15:Completed   4500000 out of 50000000 steps (9%).
12:03:02:WU00:FS02:0xa4:Completed 370000 out of 500000 steps  (74%)
12:04:13:WU02:FS01:0x15:Completed   4000000 out of 50000000 steps (8%).
12:04:22:WU00:FS02:0xa4:Completed 375000 out of 500000 steps  (75%)
12:04:27:WU01:FS00:0x15:Completed   5000000 out of 50000000 steps (10%).
12:05:41:WU00:FS02:0xa4:Completed 380000 out of 500000 steps  (76%)
12:06:26:WU02:FS01:0x15:Completed   4500000 out of 50000000 steps (9%).
12:06:36:WU01:FS00:0x15:Completed   5500000 out of 50000000 steps (11%).
12:06:59:WU00:FS02:0xa4:Completed 385000 out of 500000 steps  (77%)
12:08:16:WU00:FS02:0xa4:Completed 390000 out of 500000 steps  (78%)
12:08:39:WU02:FS01:0x15:Completed   5000000 out of 50000000 steps (10%).
12:08:45:WU01:FS00:0x15:Completed   6000000 out of 50000000 steps (12%).
12:09:32:WU00:FS02:0xa4:Completed 395000 out of 500000 steps  (79%)
12:10:48:WU00:FS02:0xa4:Completed 400000 out of 500000 steps  (80%)
12:10:52:WU02:FS01:0x15:Completed   5500000 out of 50000000 steps (11%).
12:10:53:WU01:FS00:0x15:Completed   6500000 out of 50000000 steps (13%).
12:12:05:WU00:FS02:0xa4:Completed 405000 out of 500000 steps  (81%)
12:13:02:WU01:FS00:0x15:Completed   7000000 out of 50000000 steps (14%).
12:13:05:WU02:FS01:0x15:Completed   6000000 out of 50000000 steps (12%).
12:13:22:WU00:FS02:0xa4:Completed 410000 out of 500000 steps  (82%)
12:14:38:WU00:FS02:0xa4:Completed 415000 out of 500000 steps  (83%)
12:15:10:WU01:FS00:0x15:Completed   7500000 out of 50000000 steps (15%).
12:15:18:WU02:FS01:0x15:Completed   6500000 out of 50000000 steps (13%).
12:15:57:WU00:FS02:0xa4:Completed 420000 out of 500000 steps  (84%)
12:17:17:WU00:FS02:0xa4:Completed 425000 out of 500000 steps  (85%)
12:17:19:WU01:FS00:0x15:Completed   8000000 out of 50000000 steps (16%).
12:17:31:WU02:FS01:0x15:Completed   7000000 out of 50000000 steps (14%).
12:18:37:WU00:FS02:0xa4:Completed 430000 out of 500000 steps  (86%)
12:19:27:WU01:FS00:0x15:Completed   8500000 out of 50000000 steps (17%).
12:19:44:WU02:FS01:0x15:Completed   7500000 out of 50000000 steps (15%).
12:19:58:WU00:FS02:0xa4:Completed 435000 out of 500000 steps  (87%)
12:21:20:WU00:FS02:0xa4:Completed 440000 out of 500000 steps  (88%)
12:21:36:WU01:FS00:0x15:Completed   9000000 out of 50000000 steps (18%).
12:21:57:WU02:FS01:0x15:Completed   8000000 out of 50000000 steps (16%).
12:22:39:WU00:FS02:0xa4:Completed 445000 out of 500000 steps  (89%)
12:23:45:WU01:FS00:0x15:Completed   9500000 out of 50000000 steps (19%).
12:23:57:WU00:FS02:0xa4:Completed 450000 out of 500000 steps  (90%)
12:24:10:WU02:FS01:0x15:Completed   8500000 out of 50000000 steps (17%).
12:25:16:WU00:FS02:0xa4:Completed 455000 out of 500000 steps  (91%)
12:25:53:WU01:FS00:0x15:Completed  10000000 out of 50000000 steps (20%).
12:26:23:WU02:FS01:0x15:Completed   9000000 out of 50000000 steps (18%).
12:26:36:WU00:FS02:0xa4:Completed 460000 out of 500000 steps  (92%)
12:27:55:WU00:FS02:0xa4:Completed 465000 out of 500000 steps  (93%)
12:28:02:WU01:FS00:0x15:Completed  10500000 out of 50000000 steps (21%).
12:28:36:WU02:FS01:0x15:Completed   9500000 out of 50000000 steps (19%).
12:29:15:WU00:FS02:0xa4:Completed 470000 out of 500000 steps  (94%)
12:30:11:WU01:FS00:0x15:Completed  11000000 out of 50000000 steps (22%).
12:30:34:WU00:FS02:0xa4:Completed 475000 out of 500000 steps  (95%)
12:30:49:WU02:FS01:0x15:Completed  10000000 out of 50000000 steps (20%).
12:31:52:WU00:FS02:0xa4:Completed 480000 out of 500000 steps  (96%)
12:32:19:WU01:FS00:0x15:Completed  11500000 out of 50000000 steps (23%).
12:33:02:WU02:FS01:0x15:Completed  10500000 out of 50000000 steps (21%).
12:33:09:WU00:FS02:0xa4:Completed 485000 out of 500000 steps  (97%)
12:34:26:WU00:FS02:0xa4:Completed 490000 out of 500000 steps  (98%)
12:34:28:WU01:FS00:0x15:Completed  12000000 out of 50000000 steps (24%).
12:35:15:WU02:FS01:0x15:Completed  11000000 out of 50000000 steps (22%).
12:35:45:WU00:FS02:0xa4:Completed 495000 out of 500000 steps  (99%)
12:35:46:WU03:FS02:Connecting to assign3.stanford.edu:8080
12:35:46:WU03:FS02:News: Welcome to Folding@Home
12:35:46:WU03:FS02:Assigned to work server 171.67.108.59
12:35:46:WU03:FS02:Requesting new work unit for slot 02: RUNNING smp:12 from 171.67.108.59
12:35:46:WU03:FS02:Connecting to 171.67.108.59:8080
12:35:47:WU03:FS02:Downloading 672.66KiB
12:35:48:WU03:FS02:Download complete
12:35:48:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8056 run:3 clone:43 gen:53 core:0xa4 unit:0x0000004a6652edcb506ced56d3bb6f26
12:36:36:WU01:FS00:0x15:Completed  12500000 out of 50000000 steps (25%).
12:37:04:WU00:FS02:0xa4:Completed 500000 out of 500000 steps  (100%)
12:37:04:WU00:FS02:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:37:15:WU00:FS02:0xa4:
12:37:15:WU00:FS02:0xa4:Finished Work Unit:
12:37:15:WU00:FS02:0xa4:- Reading up to 880080 from "00/wudata_01.trr": Read 880080
12:37:15:WU00:FS02:0xa4:trr file hash check passed.
12:37:15:WU00:FS02:0xa4:- Reading up to 963032 from "00/wudata_01.xtc": Read 963032
12:37:15:WU00:FS02:0xa4:xtc file hash check passed.
12:37:15:WU00:FS02:0xa4:edr file hash check passed.
12:37:15:WU00:FS02:0xa4:logfile size: 26944
12:37:15:WU00:FS02:0xa4:Leaving Run
12:37:15:WU00:FS02:0xa4:- Writing 1879028 bytes of core data to disk...
12:37:16:WU00:FS02:0xa4:Done: 1878516 -> 1809853 (compressed to 96.3 percent)
12:37:16:WU00:FS02:0xa4:  ... Done.
12:37:16:WU00:FS02:0xa4:- Shutting down core
12:37:16:WU00:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
12:37:17:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:37:17:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:8056 run:15 clone:40 gen:53 core:0xa4 unit:0x000000486652edcb506cedf58de68c24
12:37:17:WU00:FS02:Uploading 1.73MiB to 171.67.108.59
Spongebob25
i7-14700K 5.6GHz
Part 2 of log
[code]
12:37:17:WU00:FS02:Connecting to 171.67.108.59:8080
12:37:17:WU03:FS02:Starting
12:37:17:WU03:FS02:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe" -dir 03 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -np 12
12:37:17:WU03:FS02:Started FahCore on PID 4588
12:37:17:WU03:FS02:Core PID:4336
12:37:17:WU03:FS02:FahCore 0xa4 started
12:37:18:WU03:FS02:0xa4:
12:37:18:WU03:FS02:0xa4:*------------------------------*
12:37:18:WU03:FS02:0xa4:Folding@Home Gromacs GB Core
12:37:18:WU03:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
12:37:18:WU03:FS02:0xa4:Preparing to commence simulation
12:37:18:WU03:FS02:0xa4:- Looking at optimizations...
12:37:18:WU03:FS02:0xa4:- Created dyn
12:37:18:WU03:FS02:0xa4:- Files status OK
12:37:18:WU03:FS02:0xa4:- Expanded 688287 -> 1531568 (decompressed 222.5 percent)
12:37:18:WU03:FS02:0xa4:Called DecompressByteArray: compressed_data_size=688287 data_size=1531568, decompressed_data_size=1531568 diff=0
12:37:18:WU03:FS02:0xa4:- Digital signature verified
12:37:18:WU03:FS02:0xa4:Project: 8056 (Run 3, Clone 43, Gen 53)
12:37:18:WU03:FS02:0xa4:Assembly optimizations on if available.
12:37:18:WU03:FS02:0xa4:Entering M.D.
12:37:24:WU03:FS02:0xa4:Mapping NT from 12 to 12
12:37:24:WU03:FS02:0xa4:Completed 0 out of 500000 steps  (0%)
12:37:25:WU00:FS02:Upload complete
12:37:25:WU00:FS02:Server responded WORK_ACK (400)
12:37:25:WU00:FS02:Final credit estimate, 1595.00 points
12:37:25:WU00:FS02:Cleaning up
12:37:28:WU02:FS01:0x15:Completed  11500000 out of 50000000 steps (23%).
12:38:42:WU03:FS02:0xa4:Completed 5000 out of 500000 steps  (1%)
12:38:45:WU01:FS00:0x15:Completed  13000000 out of 50000000 steps (26%).
12:39:41:WU02:FS01:0x15:Completed  12000000 out of 50000000 steps (24%).
12:40:01:WU03:FS02:0xa4:Completed 10000 out of 500000 steps  (2%)
12:40:54:WU01:FS00:0x15:Completed  13500000 out of 50000000 steps (27%).
12:41:19:WU03:FS02:0xa4:Completed 15000 out of 500000 steps  (3%)
12:41:54:WU02:FS01:0x15:Completed  12500000 out of 50000000 steps (25%).
12:42:41:WU03:FS02:0xa4:Completed 20000 out of 500000 steps  (4%)
12:43:02:WU01:FS00:0x15:Completed  14000000 out of 50000000 steps (28%).
12:43:59:WU03:FS02:0xa4:Completed 25000 out of 500000 steps  (5%)
12:44:07:WU02:FS01:0x15:Completed  13000000 out of 50000000 steps (26%).
12:45:11:WU01:FS00:0x15:Completed  14500000 out of 50000000 steps (29%).
12:45:17:WU03:FS02:0xa4:Completed 30000 out of 500000 steps  (6%)
12:46:20:WU02:FS01:0x15:Completed  13500000 out of 50000000 steps (27%).
12:46:36:WU03:FS02:0xa4:Completed 35000 out of 500000 steps  (7%)
12:47:20:WU01:FS00:0x15:Completed  15000000 out of 50000000 steps (30%).
12:47:55:WU03:FS02:0xa4:Completed 40000 out of 500000 steps  (8%)
12:48:33:WU02:FS01:0x15:Completed  14000000 out of 50000000 steps (28%).
12:49:13:WU03:FS02:0xa4:Completed 45000 out of 500000 steps  (9%)
12:49:29:WU01:FS00:0x15:Completed  15500000 out of 50000000 steps (31%).
12:50:33:WU03:FS02:0xa4:Completed 50000 out of 500000 steps  (10%)
12:50:46:WU02:FS01:0x15:Completed  14500000 out of 50000000 steps (29%).
12:51:38:WU01:FS00:0x15:Completed  16000000 out of 50000000 steps (32%).
12:51:51:WU03:FS02:0xa4:Completed 55000 out of 500000 steps  (11%)
12:52:59:WU02:FS01:0x15:Completed  15000000 out of 50000000 steps (30%).
12:53:11:WU03:FS02:0xa4:Completed 60000 out of 500000 steps  (12%)
12:53:46:WU01:FS00:0x15:Completed  16500000 out of 50000000 steps (33%).
12:54:30:WU03:FS02:0xa4:Completed 65000 out of 500000 steps  (13%)
12:55:12:WU02:FS01:0x15:Completed  15500000 out of 50000000 steps (31%).
12:55:48:WU03:FS02:0xa4:Completed 70000 out of 500000 steps  (14%)
12:55:55:WU01:FS00:0x15:Completed  17000000 out of 50000000 steps (34%).
12:57:07:WU03:FS02:0xa4:Completed 75000 out of 500000 steps  (15%)
12:57:25:WU02:FS01:0x15:Completed  16000000 out of 50000000 steps (32%).
12:58:04:WU01:FS00:0x15:Completed  17500000 out of 50000000 steps (35%).
12:58:24:WU03:FS02:0xa4:Completed 80000 out of 500000 steps  (16%)
12:59:38:WU02:FS01:0x15:Completed  16500000 out of 50000000 steps (33%).
12:59:43:WU03:FS02:0xa4:Completed 85000 out of 500000 steps  (17%)
13:00:13:WU01:FS00:0x15:Completed  18000000 out of 50000000 steps (36%).
13:01:01:WU03:FS02:0xa4:Completed 90000 out of 500000 steps  (18%)
13:01:50:WU02:FS01:0x15:Completed  17000000 out of 50000000 steps (34%).
13:02:19:WU03:FS02:0xa4:Completed 95000 out of 500000 steps  (19%)
13:02:22:WU01:FS00:0x15:Completed  18500000 out of 50000000 steps (37%).
13:03:38:WU03:FS02:0xa4:Completed 100000 out of 500000 steps  (20%)
13:04:03:WU02:FS01:0x15:Completed  17500000 out of 50000000 steps (35%).
13:04:30:WU01:FS00:0x15:Completed  19000000 out of 50000000 steps (38%).
13:04:57:WU03:FS02:0xa4:Completed 105000 out of 500000 steps  (21%)
13:06:16:WU02:FS01:0x15:Completed  18000000 out of 50000000 steps (36%).
13:06:18:WU03:FS02:0xa4:Completed 110000 out of 500000 steps  (22%)
13:06:39:WU01:FS00:0x15:Completed  19500000 out of 50000000 steps (39%).
13:07:36:WU03:FS02:0xa4:Completed 115000 out of 500000 steps  (23%)
13:08:28:WU02:FS01:0x15:Completed  18500000 out of 50000000 steps (37%).
13:08:48:WU01:FS00:0x15:Completed  20000000 out of 50000000 steps (40%).
13:08:58:WU03:FS02:0xa4:Completed 120000 out of 500000 steps  (24%)
13:10:19:WU03:FS02:0xa4:Completed 125000 out of 500000 steps  (25%)
13:10:41:WU02:FS01:0x15:Completed  19000000 out of 50000000 steps (38%).
13:10:57:WU01:FS00:0x15:Completed  20500000 out of 50000000 steps (41%).
13:11:40:WU03:FS02:0xa4:Completed 130000 out of 500000 steps  (26%)
13:12:54:WU02:FS01:0x15:Completed  19500000 out of 50000000 steps (39%).
13:13:01:WU03:FS02:0xa4:Completed 135000 out of 500000 steps  (27%)
13:13:06:WU01:FS00:0x15:Completed  21000000 out of 50000000 steps (42%).
13:14:21:WU03:FS02:0xa4:Completed 140000 out of 500000 steps  (28%)
13:15:06:WU02:FS01:0x15:Completed  20000000 out of 50000000 steps (40%).
13:15:14:WU01:FS00:0x15:Completed  21500000 out of 50000000 steps (43%).
13:15:42:WU03:FS02:0xa4:Completed 145000 out of 500000 steps  (29%)
13:17:02:WU03:FS02:0xa4:Completed 150000 out of 500000 steps  (30%)
13:17:19:WU02:FS01:0x15:Completed  20500000 out of 50000000 steps (41%).
13:17:23:WU01:FS00:0x15:Completed  22000000 out of 50000000 steps (44%).
13:18:22:WU03:FS02:0xa4:Completed 155000 out of 500000 steps  (31%)
13:19:31:WU02:FS01:0x15:Completed  21000000 out of 50000000 steps (42%).
13:19:32:WU01:FS00:0x15:Completed  22500000 out of 50000000 steps (45%).
13:19:41:WU03:FS02:0xa4:Completed 160000 out of 500000 steps  (32%)
13:21:02:WU03:FS02:0xa4:Completed 165000 out of 500000 steps  (33%)
13:21:41:WU01:FS00:0x15:Completed  23000000 out of 50000000 steps (46%).
13:21:44:WU02:FS01:0x15:Completed  21500000 out of 50000000 steps (43%).
13:22:21:WU03:FS02:0xa4:Completed 170000 out of 500000 steps  (34%)
13:23:39:WU03:FS02:0xa4:Completed 175000 out of 500000 steps  (35%)
13:23:50:WU01:FS00:0x15:Completed  23500000 out of 50000000 steps (47%).
13:23:57:WU02:FS01:0x15:Completed  22000000 out of 50000000 steps (44%).
13:24:58:WU03:FS02:0xa4:Completed 180000 out of 500000 steps  (36%)
13:25:58:WU01:FS00:0x15:Completed  24000000 out of 50000000 steps (48%).
13:26:09:WU02:FS01:0x15:Completed  22500000 out of 50000000 steps (45%).
13:26:18:WU03:FS02:0xa4:Completed 185000 out of 500000 steps  (37%)
13:27:38:WU03:FS02:0xa4:Completed 190000 out of 500000 steps  (38%)
13:28:07:WU01:FS00:0x15:Completed  24500000 out of 50000000 steps (49%).
13:28:22:WU02:FS01:0x15:Completed  23000000 out of 50000000 steps (46%).
13:28:58:WU03:FS02:0xa4:Completed 195000 out of 500000 steps  (39%)
13:30:16:WU01:FS00:0x15:Completed  25000000 out of 50000000 steps (50%).
13:30:18:WU03:FS02:0xa4:Completed 200000 out of 500000 steps  (40%)
13:30:35:WU02:FS01:0x15:Completed  23500000 out of 50000000 steps (47%).
13:31:37:WU03:FS02:0xa4:Completed 205000 out of 500000 steps  (41%)
13:32:25:WU01:FS00:0x15:Completed  25500000 out of 50000000 steps (51%).
13:32:48:WU02:FS01:0x15:Completed  24000000 out of 50000000 steps (48%).
13:32:54:WU03:FS02:0xa4:Completed 210000 out of 500000 steps  (42%)
13:34:15:WU03:FS02:0xa4:Completed 215000 out of 500000 steps  (43%)
13:34:33:WU01:FS00:0x15:Completed  26000000 out of 50000000 steps (52%).
13:35:01:WU02:FS01:0x15:Completed  24500000 out of 50000000 steps (49%).
13:35:34:WU03:FS02:0xa4:Completed 220000 out of 500000 steps  (44%)
13:36:42:WU01:FS00:0x15:Completed  26500000 out of 50000000 steps (53%).
13:36:54:WU03:FS02:0xa4:Completed 225000 out of 500000 steps  (45%)
13:37:14:WU02:FS01:0x15:Completed  25000000 out of 50000000 steps (50%).
13:38:13:WU03:FS02:0xa4:Completed 230000 out of 500000 steps  (46%)
13:38:51:WU01:FS00:0x15:Completed  27000000 out of 50000000 steps (54%).
13:39:27:WU02:FS01:0x15:Completed  25500000 out of 50000000 steps (51%).
13:39:31:WU03:FS02:0xa4:Completed 235000 out of 500000 steps  (47%)
13:40:52:WU03:FS02:0xa4:Completed 240000 out of 500000 steps  (48%)
13:41:00:WU01:FS00:0x15:Completed  27500000 out of 50000000 steps (55%).
13:41:40:WU02:FS01:0x15:Completed  26000000 out of 50000000 steps (52%).
13:42:10:WU03:FS02:0xa4:Completed 245000 out of 500000 steps  (49%)
13:43:09:WU01:FS00:0x15:Completed  28000000 out of 50000000 steps (56%).
13:43:29:WU03:FS02:0xa4:Completed 250000 out of 500000 steps  (50%)
13:43:53:WU02:FS01:0x15:Completed  26500000 out of 50000000 steps (53%).
13:44:48:WU03:FS02:0xa4:Completed 255000 out of 500000 steps  (51%)
13:45:18:WU01:FS00:0x15:Completed  28500000 out of 50000000 steps (57%).
13:46:05:WU03:FS02:0xa4:Completed 260000 out of 500000 steps  (52%)
13:46:06:WU02:FS01:0x15:Completed  27000000 out of 50000000 steps (54%).
13:47:23:WU03:FS02:0xa4:Completed 265000 out of 500000 steps  (53%)
13:47:26:WU01:FS00:0x15:Completed  29000000 out of 50000000 steps (58%).
13:48:19:WU02:FS01:0x15:Completed  27500000 out of 50000000 steps (55%).
13:48:40:WU03:FS02:0xa4:Completed 270000 out of 500000 steps  (54%)
13:49:35:WU01:FS00:0x15:Completed  29500000 out of 50000000 steps (59%).
13:49:56:WU03:FS02:0xa4:Completed 275000 out of 500000 steps  (55%)
13:50:32:WU02:FS01:0x15:Completed  28000000 out of 50000000 steps (56%).
13:51:12:WU03:FS02:0xa4:Completed 280000 out of 500000 steps  (56%)
13:51:44:WU01:FS00:0x15:Completed  30000000 out of 50000000 steps (60%).
13:52:28:WU03:FS02:0xa4:Completed 285000 out of 500000 steps  (57%)
13:52:45:WU02:FS01:0x15:Completed  28500000 out of 50000000 steps (57%).
13:53:43:WU03:FS02:0xa4:Completed 290000 out of 500000 steps  (58%)
13:53:53:WU01:FS00:0x15:Completed  30500000 out of 50000000 steps (61%).
13:54:58:WU02:FS01:0x15:Completed  29000000 out of 50000000 steps (58%).
13:54:59:WU03:FS02:0xa4:Completed 295000 out of 500000 steps  (59%)
13:56:02:WU01:FS00:0x15:Completed  31000000 out of 50000000 steps (62%).
13:56:15:WU03:FS02:0xa4:Completed 300000 out of 500000 steps  (60%)
13:57:11:WU02:FS01:0x15:Completed  29500000 out of 50000000 steps (59%).
13:57:31:WU03:FS02:0xa4:Completed 305000 out of 500000 steps  (61%)
13:58:10:WU01:FS00:0x15:Completed  31500000 out of 50000000 steps (63%).
13:58:46:WU03:FS02:0xa4:Completed 310000 out of 500000 steps  (62%)
13:59:24:WU02:FS01:0x15:Completed  30000000 out of 50000000 steps (60%).
14:00:04:WU03:FS02:0xa4:Completed 315000 out of 500000 steps  (63%)
14:00:19:WU01:FS00:0x15:Completed  32000000 out of 50000000 steps (64%).
14:01:22:WU03:FS02:0xa4:Completed 320000 out of 500000 steps  (64%)
14:01:37:WU02:FS01:0x15:Completed  30500000 out of 50000000 steps (61%).
14:02:28:WU01:FS00:0x15:Completed  32500000 out of 50000000 steps (65%).
14:02:39:WU03:FS02:0xa4:Completed 325000 out of 500000 steps  (65%)
14:03:50:WU02:FS01:0x15:Completed  31000000 out of 50000000 steps (62%).
14:03:56:WU03:FS02:0xa4:Completed 330000 out of 500000 steps  (66%)
14:04:37:WU01:FS00:0x15:Completed  33000000 out of 50000000 steps (66%).
14:05:12:WU03:FS02:0xa4:Completed 335000 out of 500000 steps  (67%)
14:06:03:WU02:FS01:0x15:Completed  31500000 out of 50000000 steps (63%).
14:06:30:WU03:FS02:0xa4:Completed 340000 out of 500000 steps  (68%)
14:06:46:WU01:FS00:0x15:Completed  33500000 out of 50000000 steps (67%).
14:07:47:WU03:FS02:0xa4:Completed 345000 out of 500000 steps  (69%)
14:08:16:WU02:FS01:0x15:Completed  32000000 out of 50000000 steps (64%).
14:08:54:WU01:FS00:0x15:Completed  34000000 out of 50000000 steps (68%).
14:09:03:WU03:FS02:0xa4:Completed 350000 out of 500000 steps  (70%)
14:10:19:WU03:FS02:0xa4:Completed 355000 out of 500000 steps  (71%)
14:10:29:WU02:FS01:0x15:Completed  32500000 out of 50000000 steps (65%).
14:11:03:WU01:FS00:0x15:Completed  34500000 out of 50000000 steps (69%).
14:11:35:WU03:FS02:0xa4:Completed 360000 out of 500000 steps  (72%)
14:12:42:WU02:FS01:0x15:Completed  33000000 out of 50000000 steps (66%).
14:12:52:WU03:FS02:0xa4:Completed 365000 out of 500000 steps  (73%)
14:13:12:WU01:FS00:0x15:Completed  35000000 out of 50000000 steps (70%).
14:14:08:WU03:FS02:0xa4:Completed 370000 out of 500000 steps  (74%)
14:14:55:WU02:FS01:0x15:Completed  33500000 out of 50000000 steps (67%).
14:15:21:WU01:FS00:0x15:Completed  35500000 out of 50000000 steps (71%).
14:15:25:WU03:FS02:0xa4:Completed 375000 out of 500000 steps  (75%)
14:16:41:WU03:FS02:0xa4:Completed 380000 out of 500000 steps  (76%)
14:17:08:WU02:FS01:0x15:Completed  34000000 out of 50000000 steps (68%).
14:17:29:WU01:FS00:0x15:Completed  36000000 out of 50000000 steps (72%).
14:17:56:WU03:FS02:0xa4:Completed 385000 out of 500000 steps  (77%)
14:19:13:WU03:FS02:0xa4:Completed 390000 out of 500000 steps  (78%)
14:19:21:WU02:FS01:0x15:Completed  34500000 out of 50000000 steps (69%).
14:19:38:WU01:FS00:0x15:Completed  36500000 out of 50000000 steps (73%).
14:20:31:WU03:FS02:0xa4:Completed 395000 out of 500000 steps  (79%)
14:21:34:WU02:FS01:0x15:Completed  35000000 out of 50000000 steps (70%).
14:21:47:WU01:FS00:0x15:Completed  37000000 out of 50000000 steps (74%).
14:21:49:WU03:FS02:0xa4:Completed 400000 out of 500000 steps  (80%)
14:23:05:WU03:FS02:0xa4:Completed 405000 out of 500000 steps  (81%)
14:23:47:WU02:FS01:0x15:Completed  35500000 out of 50000000 steps (71%).
14:23:56:WU01:FS00:0x15:Completed  37500000 out of 50000000 steps (75%).
14:24:20:WU03:FS02:0xa4:Completed 410000 out of 500000 steps  (82%)
14:25:36:WU03:FS02:0xa4:Completed 415000 out of 500000 steps  (83%)
14:26:00:WU02:FS01:0x15:Completed  36000000 out of 50000000 steps (72%).
14:26:05:WU01:FS00:0x15:Completed  38000000 out of 50000000 steps (76%).
14:26:52:WU03:FS02:0xa4:Completed 420000 out of 500000 steps  (84%)
14:28:06:WU03:FS02:0xa4:Completed 425000 out of 500000 steps  (85%)
14:28:13:WU01:FS00:0x15:Completed  38500000 out of 50000000 steps (77%).
14:28:13:WU02:FS01:0x15:Completed  36500000 out of 50000000 steps (73%).
14:29:22:WU03:FS02:0xa4:Completed 430000 out of 500000 steps  (86%)
14:30:22:WU01:FS00:0x15:Completed  39000000 out of 50000000 steps (78%).
14:30:26:WU02:FS01:0x15:Completed  37000000 out of 50000000 steps (74%).
14:30:38:WU03:FS02:0xa4:Completed 435000 out of 500000 steps  (87%)
14:31:55:WU03:FS02:0xa4:Completed 440000 out of 500000 steps  (88%)
14:32:31:WU01:FS00:0x15:Completed  39500000 out of 50000000 steps (79%).
14:32:39:WU02:FS01:0x15:Completed  37500000 out of 50000000 steps (75%).
14:33:11:WU03:FS02:0xa4:Completed 445000 out of 500000 steps  (89%)
14:34:29:WU03:FS02:0xa4:Completed 450000 out of 500000 steps  (90%)
14:34:40:WU01:FS00:0x15:Completed  40000000 out of 50000000 steps (80%).
14:34:53:WU02:FS01:0x15:Completed  38000000 out of 50000000 steps (76%).
14:35:46:WU03:FS02:0xa4:Completed 455000 out of 500000 steps  (91%)
14:36:48:WU01:FS00:0x15:Completed  40500000 out of 50000000 steps (81%).
14:37:03:WU03:FS02:0xa4:Completed 460000 out of 500000 steps  (92%)
14:37:06:WU02:FS01:0x15:Completed  38500000 out of 50000000 steps (77%).
******************************** Date: 30/11/12 ********************************
14:38:22:WU03:FS02:0xa4:Completed 465000 out of 500000 steps  (93%)
14:38:57:WU01:FS00:0x15:Completed  41000000 out of 50000000 steps (82%).
14:39:19:WU02:FS01:0x15:Completed  39000000 out of 50000000 steps (78%).
14:39:40:WU03:FS02:0xa4:Completed 470000 out of 500000 steps  (94%)
14:40:57:WU03:FS02:0xa4:Completed 475000 out of 500000 steps  (95%)
14:41:06:WU01:FS00:0x15:Completed  41500000 out of 50000000 steps (83%).
14:41:32:WU02:FS01:0x15:Completed  39500000 out of 50000000 steps (79%).
14:42:12:WU03:FS02:0xa4:Completed 480000 out of 500000 steps  (96%)
14:43:15:WU01:FS00:0x15:Completed  42000000 out of 50000000 steps (84%).
14:43:28:WU03:FS02:0xa4:Completed 485000 out of 500000 steps  (97%)
14:43:45:WU02:FS01:0x15:Completed  40000000 out of 50000000 steps (80%).
14:44:44:WU03:FS02:0xa4:Completed 490000 out of 500000 steps  (98%)
14:45:23:WU01:FS00:0x15:Completed  42500000 out of 50000000 steps (85%).
14:45:58:WU02:FS01:0x15:Completed  40500000 out of 50000000 steps (81%).
14:46:00:WU03:FS02:0xa4:Completed 495000 out of 500000 steps  (99%)
14:46:01:WU00:FS02:Connecting to assign3.stanford.edu:8080
14:46:01:WU00:FS02:News: Welcome to Folding@Home
14:46:01:WU00:FS02:Assigned to work server 171.67.108.35
14:46:01:WU00:FS02:Requesting new work unit for slot 02: RUNNING smp:12 from 171.67.108.35
14:46:01:WU00:FS02:Connecting to 171.67.108.35:8080
14:46:02:WU00:FS02:Downloading 1000.53KiB
14:46:04:WU00:FS02:Download complete
14:46:04:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8069 run:1 clone:18 gen:22 core:0xa4 unit:0x000000176652edb350ad5b87e5ceed96
14:47:15:WU03:FS02:0xa4:Completed 500000 out of 500000 steps  (100%)
14:47:16:WU03:FS02:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:47:26:WU03:FS02:0xa4:
14:47:26:WU03:FS02:0xa4:Finished Work Unit:
14:47:26:WU03:FS02:0xa4:- Reading up to 879216 from "03/wudata_01.trr": Read 879216
14:47:26:WU03:FS02:0xa4:trr file hash check passed.
14:47:26:WU03:FS02:0xa4:- Reading up to 962572 from "03/wudata_01.xtc": Read 962572
14:47:26:WU03:FS02:0xa4:xtc file hash check passed.
14:47:26:WU03:FS02:0xa4:edr file hash check passed.
14:47:26:WU03:FS02:0xa4:logfile size: 26931
14:47:26:WU03:FS02:0xa4:Leaving Run
14:47:28:WU03:FS02:0xa4:- Writing 1877691 bytes of core data to disk...
14:47:29:WU03:FS02:0xa4:Done: 1877179 -> 1808919 (compressed to 96.3 percent)
14:47:29:WU03:FS02:0xa4:  ... Done.
14:47:29:WU03:FS02:0xa4:- Shutting down core
14:47:29:WU03:FS02:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:47:30:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:47:30:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:8056 run:3 clone:43 gen:53 core:0xa4 unit:0x0000004a6652edcb506ced56d3bb6f26
14:47:30:WU03:FS02:Uploading 1.73MiB to 171.67.108.59
14:47:30:WU03:FS02:Connecting to 171.67.108.59:8080
14:47:30:WU00:FS02:Starting
14:47:30:WU00:FS02:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -np 12
14:47:30:WU00:FS02:Started FahCore on PID 4632
14:47:30:WU00:FS02:Core PID:1628
14:47:30:WU00:FS02:FahCore 0xa4 started
14:47:31:WU00:FS02:0xa4:
14:47:31:WU00:FS02:0xa4:*------------------------------*
14:47:31:WU00:FS02:0xa4:Folding@Home Gromacs GB Core
14:47:31:WU00:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
14:47:31:WU00:FS02:0xa4:Preparing to commence simulation
14:47:31:WU00:FS02:0xa4:- Looking at optimizations...
14:47:31:WU00:FS02:0xa4:- Created dyn
14:47:31:WU00:FS02:0xa4:- Files status OK
14:47:31:WU00:FS02:0xa4:- Expanded 1024034 -> 2527872 (decompressed 246.8 percent)
14:47:31:WU00:FS02:0xa4:Called DecompressByteArray: compressed_data_size=1024034 data_size=2527872, decompressed_data_size=2527872 diff=0
14:47:31:WU00:FS02:0xa4:- Digital signature verified
14:47:31:WU00:FS02:0xa4:Project: 8069 (Run 1, Clone 18, Gen 22)
14:47:31:WU00:FS02:0xa4:Assembly optimizations on if available.
14:47:31:WU00:FS02:0xa4:Entering M.D.
14:47:32:WU01:FS00:0x15:Completed  43000000 out of 50000000 steps (86%).
14:47:37:WU03:FS02:Upload complete
14:47:37:WU03:FS02:Server responded WORK_ACK (400)
14:47:37:WU03:FS02:Final credit estimate, 1573.00 points
14:47:37:WU03:FS02:Cleaning up
14:47:37:WU00:FS02:0xa4:Mapping NT from 12 to 12
14:47:37:WU00:FS02:0xa4:Completed 0 out of 250000 steps  (0%)
14:48:11:WU02:FS01:0x15:Completed  41000000 out of 50000000 steps (82%).
14:48:50:WU00:FS02:0xa4:Completed 2500 out of 250000 steps  (1%)
14:49:41:WU01:FS00:0x15:Completed  43500000 out of 50000000 steps (87%).
14:50:03:WU00:FS02:0xa4:Completed 5000 out of 250000 steps  (2%)
14:50:24:WU02:FS01:0x15:Completed  41500000 out of 50000000 steps (83%).
14:51:16:WU00:FS02:0xa4:Completed 7500 out of 250000 steps  (3%)
14:51:50:WU01:FS00:0x15:Completed  44000000 out of 50000000 steps (88%).
14:52:28:WU00:FS02:0xa4:Completed 10000 out of 250000 steps  (4%)
14:52:37:WU02:FS01:0x15:Completed  42000000 out of 50000000 steps (84%).
14:53:42:WU00:FS02:0xa4:Completed 12500 out of 250000 steps  (5%)
14:53:58:WU01:FS00:0x15:Completed  44500000 out of 50000000 steps (89%).
14:54:50:WU02:FS01:0x15:Completed  42500000 out of 50000000 steps (85%).
14:54:54:WU00:FS02:0xa4:Completed 15000 out of 250000 steps  (6%)
14:56:07:WU01:FS00:0x15:Completed  45000000 out of 50000000 steps (90%).
14:56:08:WU00:FS02:0xa4:Completed 17500 out of 250000 steps  (7%)
14:57:03:WU02:FS01:0x15:Completed  43000000 out of 50000000 steps (86%).
14:57:21:WU00:FS02:0xa4:Completed 20000 out of 250000 steps  (8%)
14:58:16:WU01:FS00:0x15:Completed  45500000 out of 50000000 steps (91%).
14:58:32:WU00:FS02:0xa4:Completed 22500 out of 250000 steps  (9%)
14:59:16:WU02:FS01:0x15:Completed  43500000 out of 50000000 steps (87%).
14:59:43:WU00:FS02:0xa4:Completed 25000 out of 250000 steps  (10%)
15:00:24:WU01:FS00:0x15:Completed  46000000 out of 50000000 steps (92%).
15:00:56:WU00:FS02:0xa4:Completed 27500 out of 250000 steps  (11%)
15:01:29:WU02:FS01:0x15:Completed  44000000 out of 50000000 steps (88%).
15:02:09:WU00:FS02:0xa4:Completed 30000 out of 250000 steps  (12%)
15:02:33:WU01:FS00:0x15:Completed  46500000 out of 50000000 steps (93%).
15:03:21:WU00:FS02:0xa4:Completed 32500 out of 250000 steps  (13%)
15:03:42:WU02:FS01:0x15:Completed  44500000 out of 50000000 steps (89%).
15:04:34:WU00:FS02:0xa4:Completed 35000 out of 250000 steps  (14%)
15:04:42:WU01:FS00:0x15:Completed  47000000 out of 50000000 steps (94%).
15:05:44:WU00:FS02:0xa4:Completed 37500 out of 250000 steps  (15%)
15:05:55:WU02:FS01:0x15:Completed  45000000 out of 50000000 steps (90%).
15:06:50:WU01:FS00:0x15:Completed  47500000 out of 50000000 steps (95%).
15:06:56:WU00:FS02:0xa4:Completed 40000 out of 250000 steps  (16%)
15:08:06:WU00:FS02:0xa4:Completed 42500 out of 250000 steps  (17%)
15:08:08:WU02:FS01:0x15:Completed  45500000 out of 50000000 steps (91%).
15:08:59:WU01:FS00:0x15:Completed  48000000 out of 50000000 steps (96%).
15:09:18:WU00:FS02:0xa4:Completed 45000 out of 250000 steps  (18%)
15:10:21:WU02:FS01:0x15:Completed  46000000 out of 50000000 steps (92%).
15:10:30:WU00:FS02:0xa4:Completed 47500 out of 250000 steps  (19%)
15:11:08:WU01:FS00:0x15:Completed  48500000 out of 50000000 steps (97%).
15:11:40:WU00:FS02:0xa4:Completed 50000 out of 250000 steps  (20%)
15:12:34:WU02:FS01:0x15:Completed  46500000 out of 50000000 steps (93%).
15:12:51:WU00:FS02:0xa4:Completed 52500 out of 250000 steps  (21%)
15:13:16:WU01:FS00:0x15:Completed  49000000 out of 50000000 steps (98%).
15:14:05:WU00:FS02:0xa4:Completed 55000 out of 250000 steps  (22%)
15:14:47:WU02:FS01:0x15:Completed  47000000 out of 50000000 steps (94%).
15:15:16:WU00:FS02:0xa4:Completed 57500 out of 250000 steps  (23%)
15:15:25:WU01:FS00:0x15:Completed  49500000 out of 50000000 steps (99%).
15:15:26:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
15:15:26:WU03:FS00:News: Welcome to Folding@Home
15:15:27:WU03:FS00:Assigned to work server 171.67.108.144
15:15:27:WU03:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GK107 [GeForce GTX 670]" from 171.67.108.144
15:15:27:WU03:FS00:Connecting to 171.67.108.144:8080
15:15:27:WU03:FS00:Downloading 56.74KiB
15:15:27:WU03:FS00:Download complete
15:15:27:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8057 run:0 clone:722 gen:13 core:0x15 unit:0x0000000e6953ee30508b38d120ea7337
15:16:26:WU00:FS02:0xa4:Completed 60000 out of 250000 steps  (24%)
15:17:00:WU02:FS01:0x15:Completed  47500000 out of 50000000 steps (95%).
15:17:34:WU01:FS00:0x15:Completed  50000000 out of 50000000 steps (100%).
15:17:34:WU01:FS00:0x15:Finished fah_main status=0
15:17:34:WU01:FS00:0x15:Successful run
15:17:34:WU01:FS00:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
15:17:39:WU00:FS02:0xa4:Completed 62500 out of 250000 steps  (25%)
15:17:44:WU01:FS00:0x15:Reserved 327004 bytes for xtc file; Cosm status=0
15:17:44:WU01:FS00:0x15:Allocated 327004 bytes for xtc file
15:17:44:WU01:FS00:0x15:- Reading up to 327004 from "01/wudata_01.xtc": Read 327004
15:17:44:WU01:FS00:0x15:Read 327004 bytes from xtc file; available packet space=786103460
15:17:44:WU01:FS00:0x15:xtc file hash check passed.
15:17:44:WU01:FS00:0x15:Reserved 20400 20400 786103460 bytes for arc file=<01/wudata_01.trr> Cosm status=0
15:17:44:WU01:FS00:0x15:Allocated 20400 bytes for arc file
15:17:44:WU01:FS00:0x15:- Reading up to 20400 from "01/wudata_01.trr": Read 20400
15:17:44:WU01:FS00:0x15:Read 20400 bytes from arc file; available packet space=786083060
15:17:44:WU01:FS00:0x15:trr file hash check passed.
15:17:44:WU01:FS00:0x15:Allocated 544 bytes for edr file
15:17:44:WU01:FS00:0x15:Read bedfile
15:17:44:WU01:FS00:0x15:edr file hash check passed.
15:17:44:WU01:FS00:0x15:Allocated 36779 bytes for logfile
15:17:44:WU01:FS00:0x15:Read logfile
15:17:44:WU01:FS00:0x15:GuardedRun: success in DynamicWrapper
15:17:44:WU01:FS00:0x15:GuardedRun: done
15:17:44:WU01:FS00:0x15:Run: GuardedRun completed.
15:17:44:WU01:FS00:0x15:+ Opened results file
15:17:44:WU01:FS00:0x15:- Writing 385239 bytes of core data to disk...
15:17:44:WU01:FS00:0x15:Done: 384727 -> 353483 (compressed to 91.8 percent)
15:17:44:WU01:FS00:0x15:  ... Done.
15:17:44:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:17:44:WU01:FS00:0x15:Shutting down core
15:17:44:WU01:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
15:17:45:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:17:45:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8057 run:0 clone:956 gen:2 core:0x15 unit:0x000000036953ee30508b38e29a03cc6b
15:17:45:WU01:FS00:Uploading 345.70KiB to 171.67.108.144
15:17:45:WU01:FS00:Connecting to 171.67.108.144:8080
15:17:45:WU03:FS00:Starting
15:17:45:WU03:FS00:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_15.fah/FahCore_15.exe" -dir 03 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -gpu 0
15:17:45:WU03:FS00:Started FahCore on PID 4436
15:17:46:WU03:FS00:Core PID:3288
15:17:46:WU03:FS00:FahCore 0x15 started
15:17:47:WU03:FS00:0x15:
15:17:47:WU03:FS00:0x15:*------------------------------*
15:17:47:WU03:FS00:0x15:Folding@Home GPU Core
15:17:47:WU03:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
15:17:47:WU03:FS00:0x15:Build host             AmoebaRemote
15:17:47:WU03:FS00:0x15:Board Type             NVIDIA/CUDA
15:17:47:WU03:FS00:0x15:Core                   15
15:17:47:WU03:FS00:0x15:Window's signal control handler registered.
15:17:47:WU03:FS00:0x15:Preparing to commence simulation
15:17:47:WU03:FS00:0x15:- Looking at optimizations...
15:17:47:WU03:FS00:0x15:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
15:17:47:WU03:FS00:0x15:- Created dyn
15:17:47:WU03:FS00:0x15:- Files status OK
15:17:47:WU03:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:17:47:WU03:FS00:0x15:- Expanded 57587 -> 261042 (decompressed 453.3 percent)
15:17:47:WU03:FS00:0x15:Called DecompressByteArray: compressed_data_size=57587 data_size=261042, decompressed_data_size=261042 diff=0
15:17:47:WU03:FS00:0x15:- Digital signature verified
15:17:47:WU03:FS00:0x15:Project: 8057 (Run 0, Clone 722, Gen 13)
15:17:47:WU03:FS00:0x15:Assembly optimizations on if available.
15:17:47:WU03:FS00:0x15:Entering M.D.
15:17:47:WU01:FS00:Upload complete
15:17:47:WU01:FS00:Server responded WORK_ACK (400)
15:17:47:WU01:FS00:Final credit estimate, 17929.00 points
15:17:47:WU01:FS00:Cleaning up
15:17:48:WU03:FS00:0x15:Tpr hash 03/wudata_01.tpr:  2319159288 2009054354 89311633 328243063 3458331233
15:17:48:WU03:FS00:0x15:GPU device id=0
15:17:48:WU03:FS00:0x15:Working on Giving Russians Opium May Alter Current Situation
15:17:48:WU03:FS00:0x15:Client config unavailable.
15:17:48:WU03:FS00:0x15:Starting GUI Server
15:18:43:WU00:FS02:0xa4:Completed 65000 out of 250000 steps  (26%)
15:18:57:WU03:FS00:0x15:Setting checkpoint frequency: 500000
15:18:57:WU03:FS00:0x15:Completed         3 out of 50000000 steps (0%).
15:19:13:WU02:FS01:0x15:Completed  48000000 out of 50000000 steps (96%).
15:19:55:WU00:FS02:0xa4:Completed 67500 out of 250000 steps  (27%)
15:21:06:WU03:FS00:0x15:Completed    500000 out of 50000000 steps (1%).
15:21:08:WU00:FS02:0xa4:Completed 70000 out of 250000 steps  (28%)
15:21:26:WU02:FS01:0x15:Completed  48500000 out of 50000000 steps (97%).
15:22:20:WU00:FS02:0xa4:Completed 72500 out of 250000 steps  (29%)
15:22:21:FS02:Paused
15:22:21:FS02:Shutting core down
15:22:24:WU00:FS02:0xa4:Client no longer detected. Shutting down core
15:22:24:WU00:FS02:0xa4:Folding@home Core Shutdown: CLIENT_DIED
15:22:25:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:22:31:FS00:Paused
15:22:31:FS00:Shutting core down
15:22:36:WU03:FS00:0x15:Client no longer detected. Shutting down core
15:22:36:WU03:FS00:0x15:Folding@home Core Shutdown: CLIENT_DIED
15:22:36:WU03:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:23:40:WU02:FS01:0x15:Completed  49000000 out of 50000000 steps (98%).
15:25:44:WU02:FS01:0x15:Completed  49500000 out of 50000000 steps (99%).
15:25:45:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
15:25:45:WU01:FS01:News: Welcome to Folding@Home
15:25:45:WU01:FS01:Assigned to work server 171.67.108.144
15:25:45:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:"GK107 [GeForce GTX 670]" from 171.67.108.144
15:25:45:WU01:FS01:Connecting to 171.67.108.144:8080
15:25:46:WU01:FS01:Downloading 56.91KiB
15:25:46:WU01:FS01:Download complete
15:25:46:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8057 run:0 clone:152 gen:40 core:0x15 unit:0x0000002f6953ee30508b38aa15af8e12
15:25:56:FS01:Finishing
15:27:49:WU02:FS01:0x15:Completed  50000000 out of 50000000 steps (100%).
15:27:50:WU02:FS01:0x15:Finished fah_main status=0
15:27:50:WU02:FS01:0x15:Successful run
15:27:50:WU02:FS01:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
15:28:00:WU02:FS01:0x15:Reserved 330136 bytes for xtc file; Cosm status=0
15:28:00:WU02:FS01:0x15:Allocated 330136 bytes for xtc file
15:28:00:WU02:FS01:0x15:- Reading up to 330136 from "02/wudata_01.xtc": Read 330136
15:28:00:WU02:FS01:0x15:Read 330136 bytes from xtc file; available packet space=786100328
15:28:00:WU02:FS01:0x15:xtc file hash check passed.
15:28:00:WU02:FS01:0x15:Reserved 20616 20616 786100328 bytes for arc file=<02/wudata_01.trr> Cosm status=0
15:28:00:WU02:FS01:0x15:Allocated 20616 bytes for arc file
15:28:00:WU02:FS01:0x15:- Reading up to 20616 from "02/wudata_01.trr": Read 20616
15:28:00:WU02:FS01:0x15:Read 20616 bytes from arc file; available packet space=786079712
15:28:00:WU02:FS01:0x15:trr file hash check passed.
15:28:00:WU02:FS01:0x15:Allocated 544 bytes for edr file
15:28:00:WU02:FS01:0x15:Read bedfile
15:28:00:WU02:FS01:0x15:edr file hash check passed.
15:28:00:WU02:FS01:0x15:Allocated 36775 bytes for logfile
15:28:00:WU02:FS01:0x15:Read logfile
15:28:00:WU02:FS01:0x15:GuardedRun: success in DynamicWrapper
15:28:00:WU02:FS01:0x15:GuardedRun: done
15:28:00:WU02:FS01:0x15:Run: GuardedRun completed.
15:28:05:WU02:FS01:0x15:+ Opened results file
15:28:05:WU02:FS01:0x15:- Writing 388583 bytes of core data to disk...
15:28:05:WU02:FS01:0x15:Done: 388071 -> 357116 (compressed to 92.0 percent)
15:28:05:WU02:FS01:0x15:  ... Done.
15:28:05:WU02:FS01:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
15:28:05:WU02:FS01:0x15:Shutting down core
15:28:05:WU02:FS01:0x15:Folding@home Core Shutdown: FINISHED_UNIT
15:28:05:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:28:05:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:8054 run:0 clone:2288 gen:40 core:0x15 unit:0x0000002e6953ee2f50626b3f75b0832c
15:28:05:WU02:FS01:Uploading 349.25KiB to 171.67.108.143
15:28:05:WU02:FS01:Connecting to 171.67.108.143:8080
15:28:05:WU01:FS01:Starting
15:28:05:WU01:FS01:Running FahCore: "E:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "E:/fah data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 702 -lifeline 4240 -checkpoint 30 -gpu 1
15:28:05:WU01:FS01:Started FahCore on PID 4416
15:28:05:WU01:FS01:Core PID:5000
15:28:05:WU01:FS01:FahCore 0x15 started
15:28:06:WU01:FS01:0x15:
15:28:06:WU01:FS01:0x15:*------------------------------*
15:28:06:WU01:FS01:0x15:Folding@Home GPU Core
15:28:06:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
15:28:06:WU01:FS01:0x15:Build host             AmoebaRemote
15:28:06:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
15:28:06:WU01:FS01:0x15:Core                   15
15:28:06:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
15:28:06:WU01:FS01:0x15:Window's signal control handler registered.
15:28:06:WU01:FS01:0x15:Preparing to commence simulation
15:28:06:WU01:FS01:0x15:- Looking at optimizations...
15:28:06:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:28:06:WU01:FS01:0x15:- Created dyn
15:28:06:WU01:FS01:0x15:- Files status OK
15:28:06:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:28:06:WU01:FS01:0x15:- Expanded 57762 -> 261042 (decompressed 451.9 percent)
15:28:06:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=57762 data_size=261042, decompressed_data_size=261042 diff=0
15:28:06:WU01:FS01:0x15:- Digital signature verified
15:28:06:WU01:FS01:0x15:Project: 8057 (Run 0, Clone 152, Gen 40)
15:28:06:WU01:FS01:0x15:Assembly optimizations on if available.
15:28:06:WU01:FS01:0x15:Entering M.D.
15:28:07:WU02:FS01:Upload complete
15:28:07:WU02:FS01:Server responded WORK_ACK (400)
15:28:07:WU02:FS01:Final credit estimate, 2387.00 points
15:28:07:WU02:FS01:Cleaning up
15:28:08:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  4063015404 1891086756 1647898856 2477578953 1585637157
15:28:08:WU01:FS01:0x15:GPU device id=1
15:28:08:WU01:FS01:0x15:Working on Giving Russians Opium May Alter Current Situation
15:28:08:WU01:FS01:0x15:Client config unavailable.
15:28:08:WU01:FS01:0x15:Starting GUI Server
15:28:32:FS01:Paused
15:28:32:FS01:Shutting core down
15:28:35:Lost lifeline PID 5092, exiting
15:28:36:WU01:FS01:0x15:Client no longer detected. Shutting down core
15:28:36:WU01:FS01:0x15:Folding@home Core Shutdown: CLIENT_DIED
15:28:36:Server connection id=1 ended
15:28:36:Clean exit
[/code]
P5-133XL
Machine #2:
Machine 3:
Re: 10 WUs but no Points!
Post by P5-133XL »
No errors there. More hours please, you've only covered 8 hours and the last time I heard there were 24 in a day. Also, EOC runs on CST you need to convert to local/UTC to find the right log to look at. If necessary, if it is not in the current log you can look in the log folder (Start->All programs->FAHClient->Data Directory->Logs).
In general, you are better off not using the affinity setting, unless you have a 3rd party utility controlling all processes or under-subscribed the CPU so that there is always a surplus of CPU time that can be allocated to external non-folding processes. The Affinity setting, locks processes to cores, so they can't adjust dynamically to loads on the CPU.
bollix47
Post by bollix47 »
Maybe this will help in your log search:
As you can see below it appears one or more of your GPUs received some core_11 work units which they couldn't successfully process to completion.
Hi Spongebob25 (team 80856),
Your WU (P5766 R8 C50 G1381) was added to the stats database on 2012-11-30 11:03:35 for 0 points of credit.
Your WU (P5767 R9 C106 G1822) was added to the stats database on 2012-11-30 11:03:35 for 0 points of credit.
Your WU (P5772 R10 C393 G682) was added to the stats database on 2012-11-30 11:03:35 for 0 points of credit.
From what I can see all three were downloaded at the same time, each of them took almost an hour from the time they were assigned until they were all uploaded at the same time, and three different CPUids were involved. :e?:
codysluder
Post by codysluder »
@ Spongebob25:
Where are the logs for those three WUs mentioned by bollix47?
Spongebob25
Hardware configuration: ASUS ROG STRIX Z790-E
i7-14700K 5.6GHz
G.skill DDR5 RAM 48 GB 7200 MT/s
NVIDIA 4080 Reference Card
Samsung SSD 980 PRO 1TB
Samsung SSD 990 PRO 2TB
Post by Spongebob25 »
Thanks everyone for your help. It looks like it must be one of my machines at work that did this. It will be some time Monday before I can get ahold of the logs.
Apparently Spongebob25 has quite a few different passkeys. Every time you introduce a new passkey or a new folding name, you'll have to complete 10 WUs using that particular pair. Most people find it best to use the same passkey everywhere and the same folding name.
Spongebob25
i7-14700K 5.6GHz
That's an interesting find Bruce. I only have one passkey and its the only one I use.
You may have only one that you use, but the records show more. This is usually from not entering the passkey exactly, and is why a copy and paste from the email it was sent in is recommended. Even that is not enough sometimes, people sometimes don't notice they leave off part of the passkey or add on a space character.
Spongebob25 wrote:That's an interesting find Bruce. I only have one passkey and its the only one I use.
Well, maybe there's somebody else using Spongebob25, but typing errors can explain both multiple passkeys being used and why you might think you've got more than 10 WUs credited to the "only" one you have.
Spongebob25
i7-14700K 5.6GHz
Hopefully, we all can get to the bottom of this Monday. I will be able to look trough and post the logs from my two work computers in reference to 11-30-12.
bollix47
Post by bollix47 »
Just for clarification, the OP's problem has nothing to do with QRB or passkey qualification.
On 2012-11-30 @ 19:00 there is a record of 10 work units being returned with no points, not no bonus points, but no points whatsoever.
http://kakaostats.com/usum.php?u=1317946
All three of the above mentioned WUs have been successfully returned which is a good indication that the WUs were not bad. So that leaves unstable system. No sense in speculating ... we'll await the logs.
