I see some posts on these WU's.
What to do? - Like 4-5 days to complete?
SMP 8 @3.6 GHz - you got to be kidding me?
Project 7611 (2,72,158) - 1 Hr 6 min/frame?
- Hardware configuration: MB: GB GA-EP45-UD3P GB GA-P55-UD3R
CPU: Intel Q9550 C2Q (@3.4 GHz) Intel i7-860 (@3.762 Ghz)
RAM: 8GB Mushkin 996622 Ascent 996580 Mushkin 8GB 2x 996782 frosty
GPU: 2x EVGA GTX260-216 SC (@1350) Gigabyte GeForce 210
OS: Vista 64b Vista 32b
Folding: 2x GPU SMPx8
[updated 8/26/12 - i7 Vista v7.1.52 updated] - Location: Bradenton, FL
Machine #2:
Machine 3:
Re: Project 7611 (2,72,158) - 1 Hr 6 min/frame?
The obvious question: Are you GPU folding with an AMD video card?
Check your task manager for non-folding applications using a significant amount of CPU usage. 5-10% is plenty to cause this.
If you are using v7 then estimated TPF's can be significantly off when starting.
Then there is also a potentially buggy WU as an issue but it is more likely one of the above issues.
Tks for the speedy reply -
Dedicated Folder with NVidia card Not Folding. Everest Monitor shows 8x100% CPU. 50% complete as of now. a4 core using 99%.
Machine #2:
Machine 3:
Check the log and look at the TPF's for this WU. Are they wildly variable or consistent?
If highly variable then I would assume that you have an intermittent outside application that is doing a number on your SMP folding. If it is consistent then buggy WU to be dumped.
Have a look at this thread, especially tjlane's posts on page 2.
OK, Looks like frames are consistent.
I really do not know how to dump a v7 WU.
I'll keep looking in the meantime. Tks.
Ok, I deleted the 01 folder in \Work.
PS - I got a new 00 folder.
Tks again.
Let's get to folding On!
Tks again.
