MSI Lightning GTX 680 recognition.
WhimsicalFunTime
Post by WhimsicalFunTime »
I've had my N680 Lightning for a long time now, and no matter how many whitelists I download, even if I enable beta, it never wants to fold. It's always recognized as a GF114 GPU, and just refuses to work. I just don't understand it :(
Any assistance offered would be amazing.
:******************************* System ********************************
22:57:46:          CPU: AMD Phenom(tm) II X4 955 Processor
22:57:46:       CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
22:57:46:         CPUs: 4
22:57:46:       Memory: 7.96GiB
22:57:46:  Free Memory: 5.86GiB
22:57:46:      Threads: WINDOWS_THREADS
22:57:46:   On Battery: false
22:57:46:   UTC offset: -6
22:57:46:          PID: 1564
22:57:46:          CWD: C:/Users/Tyler/AppData/Roaming/FAHClient
22:57:46:           OS: Windows 7 Professional
22:57:46:      OS Arch: AMD64
22:57:46:         GPUs: 2
22:57:46:        GPU 0: NVIDIA:1 G92 [GeForce GTS 250]
22:57:46:        GPU 1: NVIDIA:2 GF114 [GeForce GTX 680]
22:57:46:         CUDA: 3.0
22:57:46:  CUDA Driver: 5000
22:57:46:Win32 Service: false
22:57:46:***********************************************************************
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Re: MSI Lightning GTX 680 recognition.
Post by GreyWhiskers »
I don't know the answer to the question - but the issue has been around for a while. See the thread I posted here. Same issue - the GTX680 erroneously being identified as a GF114. Part of the thread indicates there may have been duplicate entries in the whitelist that made the problem worse.
GTX 680 & 560 TI Folding Together
Different issue.
Current GPUs.txt file shows this...
0x10de:0x1180:2:3:GK104 [GeForce GTX 680]
So if running the V7.1.52 client, it needs to be upgraded to the V7.2.9 client. If already running the V7.2.9 client, stop the client, delete the GPUs.txt file in the FAHClient Data folder, and the restart the client to force an update.
P.S. Hello WhimsicalFunTime, welcome to the forum.
WhimsicalFunTime
7im wrote:Different issue.
Thanks for the welcome :)
I've done as you said, yet, it seems to update as the client loads, but it still displays the GF114 silicon thing. I'm going to include all of the logs here, as well as both GPU dumps in my system, as even though the 680 doesn't fold, the GTS 250 should as well and it never functions properly. The visual thing always just displays "loading" on the status portion.
It may be worth mentioning that the MSI Lightning 680 has quite a few differences from most 680's. Namely it features unlocked voltage, but there are countless voltage options and monitoring tools incorporated into it, so maybe the issue is the BIOS of the card isn't being read properly? The card has a dual BIOS switch, which at one setting is the heavily modified MSI standard BIOS. The other is a Liquid Nitrogen BIOS that unrestricts everything, but currently I have Image
*********************** Log Started 2012-11-30T03:42:23Z ***********************
03:42:23:************************* Folding@home Client *************************
03:42:23:      Website: http://folding.stanford.edu/
03:42:23:    Copyright: (c) 2009-2012 Stanford University
03:42:23:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:42:23:         Args: --lifeline 4748 --command-port=36330
03:42:23:       Config: C:/Users/Tyler/AppData/Roaming/FAHClient/config.xml
03:42:23:******************************** Build ********************************
03:42:23:      Version: 7.2.9
03:42:23:         Date: Oct 3 2012
03:42:23:         Time: 18:05:48
03:42:23:      SVN Rev: 3578
03:42:23:       Branch: fah/trunk/client
03:42:23:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:42:23:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:42:23:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
03:42:23:     Platform: win32 XP
03:42:23:         Bits: 32
03:42:23:         Mode: Release
03:42:23:******************************* System ********************************
03:42:23:          CPU: AMD Phenom(tm) II X4 955 Processor
03:42:23:       CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
03:42:23:         CPUs: 4
03:42:23:       Memory: 7.96GiB
03:42:23:  Free Memory: 5.29GiB
03:42:23:      Threads: WINDOWS_THREADS
03:42:23:   On Battery: false
03:42:23:   UTC offset: -6
03:42:23:          PID: 4628
03:42:23:          CWD: C:/Users/Tyler/AppData/Roaming/FAHClient
03:42:23:           OS: Windows 7 Professional
03:42:23:      OS Arch: AMD64
03:42:23:         GPUs: 2
03:42:23:        GPU 0: NVIDIA:1 G92 [GeForce GTS 250]
03:42:23:        GPU 1: NVIDIA:2 GF114 [GeForce GTX 680]
03:42:23:         CUDA: 3.0
03:42:23:  CUDA Driver: 5000
03:42:23:Win32 Service: false
03:42:23:***********************************************************************
03:42:23:<config>
03:42:23:  <!-- Folding Slot Configuration -->
03:42:23:  <gpu v='true'/>
03:42:23:  <smp v='false'/>
03:42:23:
03:42:23:  <!-- Network -->
03:42:23:  <proxy v=':8080'/>
03:42:23:
03:42:23:  <!-- User Information -->
03:42:23:  <user v='WhimsicalFunTime'/>
03:42:23:
03:42:23:  <!-- Folding Slots -->
03:42:23:  <slot id='0' type='GPU'/>
03:42:23:  <slot id='1' type='GPU'/>
03:42:23:</config>
03:42:23:Trying to access database...
03:42:23:Successfully acquired database lock
03:42:23:Enabled folding slot 00: READY gpu:0:"G92 [GeForce GTS 250]"
03:42:23:Enabled folding slot 01: READY gpu:1:"GF114 [GeForce GTX 680]"
03:42:23:WU00:FS00:Starting
03:42:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 0
03:42:23:WU00:FS00:Started FahCore on PID 1228
03:42:23:WU00:FS00:Core PID:3380
03:42:23:WU00:FS00:FahCore 0x11 started
03:42:23:WU01:FS01:Starting
03:42:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:42:23:WU01:FS01:Started FahCore on PID 4608
03:42:23:WU01:FS01:Core PID:4140
03:42:23:WU01:FS01:FahCore 0x15 started
03:42:23:WU00:FS00:0x11:
03:42:23:WU00:FS00:0x11:*------------------------------*
03:42:23:WU00:FS00:0x11:Folding@Home GPU Core
03:42:23:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
03:42:23:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
03:42:23:WU00:FS00:0x11:Build host: amoeba
03:42:23:WU00:FS00:0x11:Board Type: Nvidia
03:42:23:WU00:FS00:0x11:Core      :
03:42:23:WU00:FS00:0x11:Preparing to commence simulation
03:42:23:WU00:FS00:0x11:- Ensuring status. Please wait.
03:42:23:WU01:FS01:0x15:
03:42:23:WU01:FS01:0x15:*------------------------------*
03:42:23:WU01:FS01:0x15:Folding@Home GPU Core
03:42:23:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:42:23:WU01:FS01:0x15:Build host             AmoebaRemote
03:42:23:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
03:42:23:WU01:FS01:0x15:Core                   15
03:42:23:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:42:23:WU01:FS01:0x15:Window's signal control handler registered.
03:42:23:WU01:FS01:0x15:Preparing to commence simulation
03:42:23:WU01:FS01:0x15:- Ensuring status. Please wait.
03:42:26:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
03:42:32:WU00:FS00:0x11:- Looking at optimizations...
03:42:32:WU00:FS00:0x11:- Working with standard loops on this execution.
03:42:32:WU00:FS00:0x11:- Previous termination of core was improper.
03:42:32:WU00:FS00:0x11:- Going to use standard loops.
03:42:32:WU00:FS00:0x11:- Files status OK
03:42:32:WU00:FS00:0x11:- Expanded 62885 -> 336799 (decompressed 535.5 percent)
03:42:32:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=62885 data_size=336799, decompressed_data_size=336799 diff=0
03:42:32:WU00:FS00:0x11:- Digital signature verified
03:42:32:WU00:FS00:0x11:Project: 10503 (Run 383, Clone 0, Gen 1529)
03:42:32:WU00:FS00:0x11:Entering M.D.
03:42:32:WU01:FS01:0x15:- Looking at optimizations...
03:42:32:WU01:FS01:0x15:- Working with standard loops on this execution.
03:42:32:WU01:FS01:0x15:- Previous termination of core was improper.
03:42:32:WU01:FS01:0x15:- Files status OK
03:42:32:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:42:32:WU01:FS01:0x15:- Expanded 60162 -> 264278 (decompressed 439.2 percent)
03:42:32:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=60162 data_size=264278, decompressed_data_size=264278 diff=0
03:42:32:WU01:FS01:0x15:- Digital signature verified
03:42:32:WU01:FS01:0x15:Project: 8054 (Run 0, Clone 797, Gen 65)
03:42:32:WU01:FS01:0x15:Entering M.D.
03:42:34:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  4283056788 556025170 3914027291 1503877234 1576810029
03:42:34:WU01:FS01:0x15:GPU device id=1
03:42:34:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:42:34:WU01:FS01:0x15:Client config unavailable.
03:42:35:WU01:FS01:0x15:Starting GUI Server
03:42:38:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  3724000730 663355715 2209956047 3134241877 1251359680
03:42:38:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
03:43:38:WU01:FS01:0x15:Finished fah_main status=59
03:43:38:WU01:FS01:0x15:mdrun_gpu returned 59
03:43:38:WU01:FS01:0x15:GPU memtest failure
03:43:38:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
03:43:38:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:43:38:WU01:FS01:Starting
03:43:38:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:43:38:WU01:FS01:Started FahCore on PID 5104
03:43:38:WU01:FS01:Core PID:4148
03:43:38:WU01:FS01:FahCore 0x15 started
03:43:38:WU01:FS01:0x15:*------------------------------*
03:43:38:WU01:FS01:0x15:Folding@Home GPU Core
03:43:38:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:43:38:WU01:FS01:0x15:Build host             AmoebaRemote
03:43:38:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
03:43:38:WU01:FS01:0x15:Core                   15
03:43:38:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:43:38:WU01:FS01:0x15:Window's signal control handler registered.
03:43:38:WU01:FS01:0x15:Preparing to commence simulation
03:43:38:WU01:FS01:0x15:- Looking at optimizations...
03:43:38:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
03:43:38:WU01:FS01:0x15:- Created dyn
03:43:38:WU01:FS01:0x15:- Files status OK
03:43:38:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:43:38:WU01:FS01:0x15:- Expanded 60162 -> 264278 (decompressed 439.2 percent)
03:43:38:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=60162 data_size=264278, decompressed_data_size=264278 diff=0
03:43:38:WU01:FS01:0x15:- Digital signature verified
03:43:38:WU01:FS01:0x15:Project: 8054 (Run 0, Clone 797, Gen 65)
03:43:38:WU01:FS01:0x15:Assembly optimizations on if available.
03:43:38:WU01:FS01:0x15:Entering M.D.
03:43:40:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  4283056788 556025170 3914027291 1503877234 1576810029
03:43:40:WU01:FS01:0x15:GPU device id=1
03:43:40:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:43:40:WU01:FS01:0x15:Client config unavailable.
03:43:40:WU01:FS01:0x15:Starting GUI Server
03:44:43:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:44:43:WARNING:WU01:FS01:Too many errors, failing
03:44:43:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:8054 run:0 clone:797 gen:65 core:0x15 unit:0x0000004e6953ee2f50626abb2c3c1783
03:44:43:WU01:FS01:Connecting to 171.67.108.143:8080
03:44:44:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
03:44:44:WU02:FS01:News: Welcome to Folding@Home
03:44:44:WU02:FS01:Assigned to work server 171.67.108.143
03:44:44:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:"GF114 [GeForce GTX 680]" from 171.67.108.143
03:44:44:WU02:FS01:Connecting to 171.67.108.143:8080
03:44:47:WU01:FS01:Server responded WORK_QUIT (404)
03:44:47:WARNING:WU01:FS01:Server did not like results, dumping
03:44:47:WU01:FS01:Cleaning up
03:44:47:WU02:FS01:Downloading 59.20KiB
03:44:48:WU02:FS01:Download complete
03:44:48:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8054 run:0 clone:1179 gen:35 core:0x15 unit:0x0000002d6953ee2f50626adcb012ef0d
03:44:48:WU02:FS01:Starting
03:44:48:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:44:48:WU02:FS01:Started FahCore on PID 4220
03:44:48:WU02:FS01:Core PID:4264
03:44:48:WU02:FS01:FahCore 0x15 started
03:44:48:WU02:FS01:0x15:
03:44:48:WU02:FS01:0x15:*------------------------------*
03:44:48:WU02:FS01:0x15:Folding@Home GPU Core
03:44:48:WU02:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:44:48:WU02:FS01:0x15:Build host             AmoebaRemote
03:44:48:WU02:FS01:0x15:Board Type             NVIDIA/CUDA
03:44:48:WU02:FS01:0x15:Core                   15
03:44:48:WU02:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:44:48:WU02:FS01:0x15:Window's signal control handler registered.
03:44:48:WU02:FS01:0x15:Preparing to commence simulation
03:44:48:WU02:FS01:0x15:- Looking at optimizations...
03:44:49:WU02:FS01:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
03:44:49:WU02:FS01:0x15:- Created dyn
03:44:49:WU02:FS01:0x15:- Files status OK
03:44:49:WU02:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:44:49:WU02:FS01:0x15:- Expanded 60112 -> 264278 (decompressed 439.6 percent)
03:44:49:WU02:FS01:0x15:Called DecompressByteArray: compressed_data_size=60112 data_size=264278, decompressed_data_size=264278 diff=0
03:44:49:WU02:FS01:0x15:- Digital signature verified
03:44:49:WU02:FS01:0x15:Project: 8054 (Run 0, Clone 1179, Gen 35)
03:44:49:WU02:FS01:0x15:Assembly optimizations on if available.
03:44:49:WU02:FS01:0x15:Entering M.D.
03:44:50:WU02:FS01:0x15:Tpr hash 02/wudata_01.tpr:  1786752685 429463781 7302727 2617705861 2715685700
03:44:50:WU02:FS01:0x15:GPU device id=1
03:44:50:WU02:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:44:50:WU02:FS01:0x15:Client config unavailable.
03:44:50:WU02:FS01:0x15:Starting GUI Server
03:45:53:WU02:FS01:0x15:Finished fah_main status=59
03:45:53:WU02:FS01:0x15:mdrun_gpu returned 59
03:45:53:WU02:FS01:0x15:GPU memtest failure
03:45:53:WU02:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
03:45:53:WARNING:WU02:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:45:53:WU02:FS01:Starting
03:45:53:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:45:53:WU02:FS01:Started FahCore on PID 4032
03:45:53:WU02:FS01:Core PID:3612
03:45:53:WU02:FS01:FahCore 0x15 started
03:45:54:WU02:FS01:0x15:
03:45:54:WU02:FS01:0x15:*------------------------------*
03:45:54:WU02:FS01:0x15:Folding@Home GPU Core
03:45:54:WU02:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:45:54:WU02:FS01:0x15:Build host             AmoebaRemote
03:45:54:WU02:FS01:0x15:Board Type             NVIDIA/CUDA
03:45:54:WU02:FS01:0x15:Core                   15
03:45:54:WU02:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:45:54:WU02:FS01:0x15:Window's signal control handler registered.
03:45:54:WU02:FS01:0x15:Preparing to commence simulation
03:45:54:WU02:FS01:0x15:- Looking at optimizations...
03:45:54:WU02:FS01:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
03:45:54:WU02:FS01:0x15:- Created dyn
03:45:54:WU02:FS01:0x15:- Files status OK
03:45:54:WU02:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:45:54:WU02:FS01:0x15:- Expanded 60112 -> 264278 (decompressed 439.6 percent)
03:45:54:WU02:FS01:0x15:Called DecompressByteArray: compressed_data_size=60112 data_size=264278, decompressed_data_size=264278 diff=0
03:45:54:WU02:FS01:0x15:- Digital signature verified
03:45:54:WU02:FS01:0x15:Project: 8054 (Run 0, Clone 1179, Gen 35)
03:45:54:WU02:FS01:0x15:Assembly optimizations on if available.
03:45:54:WU02:FS01:0x15:Entering M.D.
03:45:56:WU02:FS01:0x15:Tpr hash 02/wudata_01.tpr:  1786752685 429463781 7302727 2617705861 2715685700
03:45:56:WU02:FS01:0x15:GPU device id=1
03:45:56:WU02:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:45:56:WU02:FS01:0x15:Client config unavailable.
03:45:56:WU02:FS01:0x15:Starting GUI Server
03:46:59:WU02:FS01:0x15:Finished fah_main status=59
03:46:59:WU02:FS01:0x15:mdrun_gpu returned 59
03:46:59:WU02:FS01:0x15:GPU memtest failure
03:46:59:WU02:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
03:46:59:WARNING:WU02:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:47:00:WU02:FS01:Starting
03:47:00:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:47:00:WU02:FS01:Started FahCore on PID 4452
03:47:00:WU02:FS01:Core PID:1100
03:47:00:WU02:FS01:FahCore 0x15 started
03:47:00:WU02:FS01:0x15:
03:47:00:WU02:FS01:0x15:*------------------------------*
03:47:00:WU02:FS01:0x15:Folding@Home GPU Core
03:47:00:WU02:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:47:00:WU02:FS01:0x15:Build host             AmoebaRemote
03:47:00:WU02:FS01:0x15:Board Type             NVIDIA/CUDA
03:47:00:WU02:FS01:0x15:Core                   15
03:47:00:WU02:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:47:00:WU02:FS01:0x15:Window's signal control handler registered.
03:47:00:WU02:FS01:0x15:Preparing to commence simulation
03:47:00:WU02:FS01:0x15:- Looking at optimizations...
03:47:00:WU02:FS01:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
03:47:00:WU02:FS01:0x15:- Created dyn
03:47:00:WU02:FS01:0x15:- Files status OK
03:47:00:WU02:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:47:00:WU02:FS01:0x15:- Expanded 60112 -> 264278 (decompressed 439.6 percent)
03:47:00:WU02:FS01:0x15:Called DecompressByteArray: compressed_data_size=60112 data_size=264278, decompressed_data_size=264278 diff=0
03:47:00:WU02:FS01:0x15:- Digital signature verified
03:47:00:WU02:FS01:0x15:Project: 8054 (Run 0, Clone 1179, Gen 35)
03:47:00:WU02:FS01:0x15:Assembly optimizations on if available.
03:47:00:WU02:FS01:0x15:Entering M.D.
03:47:02:WU02:FS01:0x15:Tpr hash 02/wudata_01.tpr:  1786752685 429463781 7302727 2617705861 2715685700
03:47:02:WU02:FS01:0x15:GPU device id=1
03:47:02:WU02:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:47:02:WU02:FS01:0x15:Client config unavailable.
03:47:02:WU02:FS01:0x15:Starting GUI Server
03:48:05:WU02:FS01:0x15:Finished fah_main status=59
03:48:05:WU02:FS01:0x15:mdrun_gpu returned 59
03:48:05:WU02:FS01:0x15:GPU memtest failure
03:48:05:WU02:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
03:48:05:WARNING:WU02:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:48:37:WU02:FS01:Starting
03:48:37:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:48:37:WU02:FS01:Started FahCore on PID 4604
03:48:37:WU02:FS01:Core PID:3808
03:48:37:WU02:FS01:FahCore 0x15 started
03:48:37:WU02:FS01:0x15:
03:48:37:WU02:FS01:0x15:*------------------------------*
03:48:37:WU02:FS01:0x15:Folding@Home GPU Core
03:48:37:WU02:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:48:37:WU02:FS01:0x15:Build host             AmoebaRemote
03:48:37:WU02:FS01:0x15:Board Type             NVIDIA/CUDA
03:48:37:WU02:FS01:0x15:Core                   15
03:48:37:WU02:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:48:37:WU02:FS01:0x15:Window's signal control handler registered.
03:48:37:WU02:FS01:0x15:Preparing to commence simulation
03:48:37:WU02:FS01:0x15:- Looking at optimizations...
03:48:37:WU02:FS01:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
03:48:37:WU02:FS01:0x15:- Created dyn
03:48:37:WU02:FS01:0x15:- Files status OK
03:48:37:WU02:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:48:37:WU02:FS01:0x15:- Expanded 60112 -> 264278 (decompressed 439.6 percent)
03:48:37:WU02:FS01:0x15:Called DecompressByteArray: compressed_data_size=60112 data_size=264278, decompressed_data_size=264278 diff=0
03:48:37:WU02:FS01:0x15:- Digital signature verified
03:48:37:WU02:FS01:0x15:Project: 8054 (Run 0, Clone 1179, Gen 35)
03:48:37:WU02:FS01:0x15:Assembly optimizations on if available.
03:48:37:WU02:FS01:0x15:Entering M.D.
03:48:39:WU02:FS01:0x15:Tpr hash 02/wudata_01.tpr:  1786752685 429463781 7302727 2617705861 2715685700
03:48:39:WU02:FS01:0x15:GPU device id=1
03:48:39:WU02:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:48:39:WU02:FS01:0x15:Client config unavailable.
03:48:39:WU02:FS01:0x15:Starting GUI Server
03:49:43:WU02:FS01:0x15:Finished fah_main status=59
03:49:43:WU02:FS01:0x15:mdrun_gpu returned 59
03:49:43:WU02:FS01:0x15:GPU memtest failure
03:49:43:WU02:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
03:49:43:WARNING:WU02:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:51:14:WU02:FS01:Starting
03:51:14:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:51:14:WU02:FS01:Started FahCore on PID 2104
03:51:14:WU02:FS01:Core PID:3332
03:51:14:WU02:FS01:FahCore 0x15 started
03:51:14:WU02:FS01:0x15:
03:51:14:WU02:FS01:0x15:*------------------------------*
03:51:14:WU02:FS01:0x15:Folding@Home GPU Core
03:51:14:WU02:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:51:14:WU02:FS01:0x15:Build host             AmoebaRemote
03:51:14:WU02:FS01:0x15:Board Type             NVIDIA/CUDA
03:51:14:WU02:FS01:0x15:Core                   15
03:51:14:WU02:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:51:14:WU02:FS01:0x15:Window's signal control handler registered.
03:51:14:WU02:FS01:0x15:Preparing to commence simulation
03:51:14:WU02:FS01:0x15:- Looking at optimizations...
03:51:14:WU02:FS01:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
03:51:14:WU02:FS01:0x15:- Created dyn
03:51:14:WU02:FS01:0x15:- Files status OK
03:51:14:WU02:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:51:14:WU02:FS01:0x15:- Expanded 60112 -> 264278 (decompressed 439.6 percent)
03:51:14:WU02:FS01:0x15:Called DecompressByteArray: compressed_data_size=60112 data_size=264278, decompressed_data_size=264278 diff=0
03:51:14:WU02:FS01:0x15:- Digital signature verified
03:51:14:WU02:FS01:0x15:Project: 8054 (Run 0, Clone 1179, Gen 35)
03:51:14:WU02:FS01:0x15:Assembly optimizations on if available.
03:51:14:WU02:FS01:0x15:Entering M.D.
03:51:16:WU02:FS01:0x15:Tpr hash 02/wudata_01.tpr:  1786752685 429463781 7302727 2617705861 2715685700
03:51:16:WU02:FS01:0x15:GPU device id=1
03:51:16:WU02:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:51:16:WU02:FS01:0x15:Client config unavailable.
03:51:16:WU02:FS01:0x15:Starting GUI Server
03:52:20:WARNING:WU02:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:52:20:WARNING:WU02:FS01:Too many errors, failing
03:52:20:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:8054 run:0 clone:1179 gen:35 core:0x15 unit:0x0000002d6953ee2f50626adcb012ef0d
03:52:20:WU02:FS01:Connecting to 171.67.108.143:8080
03:52:20:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
03:52:20:WU02:FS01:Server responded WORK_QUIT (404)
03:52:20:WARNING:WU02:FS01:Server did not like results, dumping
03:52:21:WU02:FS01:Cleaning up
03:52:21:WU01:FS01:News: Welcome to Folding@Home
03:52:21:WU01:FS01:Assigned to work server 171.67.108.143
03:52:21:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:"GF114 [GeForce GTX 680]" from 171.67.108.143
03:52:21:WU01:FS01:Connecting to 171.67.108.143:8080
03:52:22:WU01:FS01:Downloading 59.30KiB
03:52:22:WU01:FS01:Download complete
03:52:22:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8054 run:0 clone:2992 gen:7 core:0x15 unit:0x0000000a6953ee2f50626b7d021d0742
03:52:22:WU01:FS01:Starting
03:52:22:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:52:22:WU01:FS01:Started FahCore on PID 3468
03:52:22:WU01:FS01:Core PID:2840
03:52:22:WU01:FS01:FahCore 0x15 started
03:52:23:WU01:FS01:0x15:
03:52:23:WU01:FS01:0x15:*------------------------------*
03:52:23:WU01:FS01:0x15:Folding@Home GPU Core
03:52:23:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:52:23:WU01:FS01:0x15:Build host             AmoebaRemote
03:52:23:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
03:52:23:WU01:FS01:0x15:Core                   15
03:52:23:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:52:23:WU01:FS01:0x15:Window's signal control handler registered.
03:52:23:WU01:FS01:0x15:Preparing to commence simulation
03:52:23:WU01:FS01:0x15:- Looking at optimizations...
03:52:23:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
03:52:23:WU01:FS01:0x15:- Created dyn
03:52:23:WU01:FS01:0x15:- Files status OK
03:52:23:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:52:23:WU01:FS01:0x15:- Expanded 60208 -> 264278 (decompressed 438.9 percent)
03:52:23:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=60208 data_size=264278, decompressed_data_size=264278 diff=0
03:52:23:WU01:FS01:0x15:- Digital signature verified
03:52:23:WU01:FS01:0x15:Project: 8054 (Run 0, Clone 2992, Gen 7)
03:52:23:WU01:FS01:0x15:Assembly optimizations on if available.
03:52:23:WU01:FS01:0x15:Entering M.D.
03:52:24:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  4167690975 1230743283 906115087 3750976734 3126915494
03:52:24:WU01:FS01:0x15:GPU device id=1
03:52:24:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:52:24:WU01:FS01:0x15:Client config unavailable.
03:52:25:WU01:FS01:0x15:Starting GUI Server
03:53:28:WU01:FS01:0x15:Finished fah_main status=59
03:53:28:WU01:FS01:0x15:mdrun_gpu returned 59
03:53:28:WU01:FS01:0x15:GPU memtest failure
03:53:28:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
03:53:28:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:53:29:WU01:FS01:Starting
03:53:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:53:29:WU01:FS01:Started FahCore on PID 1600
03:53:29:WU01:FS01:Core PID:5072
03:53:29:WU01:FS01:FahCore 0x15 started
03:53:29:WU01:FS01:0x15:
03:53:29:WU01:FS01:0x15:*------------------------------*
03:53:29:WU01:FS01:0x15:Folding@Home GPU Core
03:53:29:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:53:29:WU01:FS01:0x15:Build host             AmoebaRemote
03:53:29:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
03:53:29:WU01:FS01:0x15:Core                   15
03:53:29:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:53:29:WU01:FS01:0x15:Window's signal control handler registered.
03:53:29:WU01:FS01:0x15:Preparing to commence simulation
03:53:29:WU01:FS01:0x15:- Looking at optimizations...
03:53:29:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
03:53:29:WU01:FS01:0x15:- Created dyn
03:53:29:WU01:FS01:0x15:- Files status OK
03:53:29:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:53:29:WU01:FS01:0x15:- Expanded 60208 -> 264278 (decompressed 438.9 percent)
03:53:29:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=60208 data_size=264278, decompressed_data_size=264278 diff=0
03:53:29:WU01:FS01:0x15:- Digital signature verified
03:53:29:WU01:FS01:0x15:Project: 8054 (Run 0, Clone 2992, Gen 7)
03:53:29:WU01:FS01:0x15:Assembly optimizations on if available.
03:53:29:WU01:FS01:0x15:Entering M.D.
03:53:31:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  4167690975 1230743283 906115087 3750976734 3126915494
03:53:31:WU01:FS01:0x15:GPU device id=1
03:53:31:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:53:31:WU01:FS01:0x15:Client config unavailable.
03:53:31:WU01:FS01:0x15:Starting GUI Server
03:54:32:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:54:32:WU01:FS01:Starting
03:54:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:54:32:WU01:FS01:Started FahCore on PID 3476
03:54:32:WU01:FS01:Core PID:4752
03:54:32:WU01:FS01:FahCore 0x15 started
03:54:32:WU01:FS01:0x15:
03:54:32:WU01:FS01:0x15:*------------------------------*
03:54:32:WU01:FS01:0x15:Folding@Home GPU Core
03:54:32:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:54:32:WU01:FS01:0x15:Build host             AmoebaRemote
03:54:32:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
03:54:32:WU01:FS01:0x15:Core                   15
03:54:32:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:54:32:WU01:FS01:0x15:Window's signal control handler registered.
03:54:32:WU01:FS01:0x15:Preparing to commence simulation
03:54:32:WU01:FS01:0x15:- Looking at optimizations...
03:54:32:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
03:54:32:WU01:FS01:0x15:- Created dyn
03:54:32:WU01:FS01:0x15:- Files status OK
03:54:32:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:54:32:WU01:FS01:0x15:- Expanded 60208 -> 264278 (decompressed 438.9 percent)
03:54:32:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=60208 data_size=264278, decompressed_data_size=264278 diff=0
03:54:32:WU01:FS01:0x15:- Digital signature verified
03:54:32:WU01:FS01:0x15:Project: 8054 (Run 0, Clone 2992, Gen 7)
03:54:32:WU01:FS01:0x15:Assembly optimizations on if available.
03:54:32:WU01:FS01:0x15:Entering M.D.
03:54:34:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  4167690975 1230743283 906115087 3750976734 3126915494
03:54:34:WU01:FS01:0x15:GPU device id=1
03:54:34:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:54:34:WU01:FS01:0x15:Client config unavailable.
03:54:34:WU01:FS01:0x15:Starting GUI Server
03:55:35:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
03:56:09:WU01:FS01:Starting
03:56:09:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tyler/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 4628 -checkpoint 15 -gpu 1
03:56:09:WU01:FS01:Started FahCore on PID 3808
03:56:09:WU01:FS01:Core PID:4732
03:56:09:WU01:FS01:FahCore 0x15 started
03:56:09:WU01:FS01:0x15:
03:56:09:WU01:FS01:0x15:*------------------------------*
03:56:09:WU01:FS01:0x15:Folding@Home GPU Core
03:56:09:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
03:56:09:WU01:FS01:0x15:Build host             AmoebaRemote
03:56:09:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
03:56:09:WU01:FS01:0x15:Core                   15
03:56:09:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
03:56:09:WU01:FS01:0x15:Window's signal control handler registered.
03:56:09:WU01:FS01:0x15:Preparing to commence simulation
03:56:09:WU01:FS01:0x15:- Looking at optimizations...
03:56:09:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
03:56:09:WU01:FS01:0x15:- Created dyn
03:56:09:WU01:FS01:0x15:- Files status OK
03:56:09:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:56:09:WU01:FS01:0x15:- Expanded 60208 -> 264278 (decompressed 438.9 percent)
03:56:09:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=60208 data_size=264278, decompressed_data_size=264278 diff=0
03:56:09:WU01:FS01:0x15:- Digital signature verified
03:56:09:WU01:FS01:0x15:Project: 8054 (Run 0, Clone 2992, Gen 7)
03:56:09:WU01:FS01:0x15:Assembly optimizations on if available.
03:56:09:WU01:FS01:0x15:Entering M.D.
03:56:11:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  4167690975 1230743283 906115087 3750976734 3126915494
03:56:11:WU01:FS01:0x15:GPU device id=1
03:56:11:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
03:56:11:WU01:FS01:0x15:Client config unavailable.
03:56:11:WU01:FS01:0x15:Starting GUI Server
the client never updates the log past here.
Delete the GPU slots and reinstall the client. Does the new log show updated GPU info?
WhimsicalFunTime
Yes, it got past that point. Now I'm seeing an error in the logs than states "GPU MEMTEST" is failing. Generally I would be concerned over that but I can bench this card stable at memory speeds well over 7000Mhz effective. So the memory can't possibly be bad.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Just because you think it is stable, does not make it so. Try running one of the 3rd party GPU memory testing utilities
WhimsicalFunTime
Sorry for the wait, gents. Spent the weekend at a ranch with no internet connectivity.
Here is the result from the memory test conducted on the GTX 680.
WhimsicalFunTime
Bumping for assistance.
dawhippersnapper
Hardware configuration: i7 3770, 2 x i7 2600k, gtx 680 SC+, 2x E7-4830, 4 x Xeon L5520, other random hardware
Post by dawhippersnapper »
Mine is recognized improperly like yours, but works fine. I have the EVGA GTX 680 SC+ it's very unlocked too, and I had a lot of issues making it stable in every application and test. For some things I had to underclock the memory by about 50mhz and core by about 35mhz. Now it's running quite a bit better though. The PhysX stuff in general seemed to cause the most problems.
codysluder
Post by codysluder »
The current GPUs.txt recognizes it as a Kepler:
There's another topic about some problems with the Assignment Server today. Your first problem may have been fixed but if you're still having problems, it might be a second problem.
See viewtopic.php?f=85&t=23200
jmrios
Re: GTX 680 Classified recognized as Fermi?
Post by jmrios »
Mod note: moved post from topic where folding failed because system was Linux
Hi, to the OP sorry for posting my question in your post, but since I have a pair of EVGA GTX 680s, the FTW ones, not the Classified, and my GPUs are also recognized as GF114, I believe that open another post, to ask a similar question is unnecessary.
I'm using the FAH client Version: 7.2.9 on Windows 7.
Well, first of all, my cards are receiving WUs y running without any issues, but they are recognized as GF114.
06:57:36: GPU 0: NVIDIA:2 GF114 [GeForce GTX 680]
06:57:36: GPU 1: NVIDIA:2 GF114 [GeForce GTX 680]
According to GPU-Z, the device ID of my cards are 10DE - 1180.
I already followed the steps described in this post, and my client keeps recognizing my cards as GF114.
For additional info, I did the procedure while having WUs on the cards, I paused the client, and exit FAH control to delete de GPUs.txt, when restarted, it created another GPUs.txt, this .txt contains: 0x10de:0x1180:2:3:GK104 [GeForce GTX 680], but my cards are still recognized as GF114, but as I said before, they are running without any issue, In fact they are running now the projects 8073 and 8074, on FahCore: 0x15, with about 35k PPD each.
What should I do? Or I can leave it alone? Since the cards are running ok?
Thanks
If they are running okay, I would leave it alone on the "If it ain't broke, don't fix it" line of reasoning. In the future if the GPU slots do give you issues, there are some suggestions in this thread. Basically, delete the GPUs.txt file and 7.2.9 will download the most recent version. You may need to delete and recreate the folding slots so they get recognized properly.
If you see GK104 in GPUs.txt and the client says it's a GF114 with the same device codes, you probably have two copies of GPUs.txt on your system and only one is in the "right" place. There should be a shortcut in the "All Programs" directory that points to FAHClient's Data Directory.
jmrios
Post by jmrios »
bruce wrote:If you see GK104 in GPUs.txt and the client says it's a GF114 with the same device codes, you probably have two copies of GPUs.txt on your system and only one is in the "right" place. There should be a shortcut in the "All Programs" directory that points to FAHClient's Data Directory.
It's odd, the only GPUs.txt on my pc, is located on the folder that I've installed my FAH Client that the shortcut in "All Programs" directs to. The only thing that I could do, is unistalling the client, delete all traces of it, reinstall and try again. But since It's working right, I think I'm ok. My only concern is about a theorical performance loss on the 680s because the misidentification, but as I said before, they're working right I think, currently they picked 7626s, and the estimated PPD are 44k each.
