Server Outage? [Connection issue resolved]
DocJonz
Post by DocJonz »
Is there a general server outage? I have 10+ clients (SMP's and GPU's) failing to connect to the assignment servers. Also, I cannot access Stanfords Folding site ... :?:
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: Server Outage?
Post by Jesse_V »
I can access the site just fine. I suspect something might be going on at your end. Firewall, Internet connection, ISP, etc.
DocJonz
Re: Server Outage?
Post by DocJonz »
Strange. Internet connection appears to be fine - no modem log issues, Win update and IS updates also work, general web surfing no problem ... will check the firewall, but it would seem odd to suddenly block such access for no reason ....
P5-133XL
Machine #2:
Machine 3:
Re: Server Outage?
Post by P5-133XL »
Use a browser and connect to one of those blocked servers. Do you get an OK?
I'm not having any problems with either the servers or the PG home.
DocJonz
Re: Server Outage? [Connection problem]
Post by DocJonz »
Well, couldn't find any issues ....given that there's a mix of Win flavours and Linux with different firewalls etc, it suggested a modem glitch or ISP block. Therefore, I did a remote restart of the modem (from work). Can't tell specifically if that fixed it, but things back to normal on returning home ..... glad Stanford hadn't actually gone up in a ball of smoke :lol:
