Combining myselves
Combining myselves
I'm Barry from team 174828 but I was also Barry from team 35586 (several years ago). Is there a way to combine them so my user page will show information from both teams under "Contributions by team and project"? I got a passkey recently when I started folding for my current team but all I know about the old team is the email address (it's one of three addresses, I think).
Re: Combining myselves
All points from "Barry" are already combined on a single page with all the teams listed.
http://fah-web2.stanford.edu/cgi-bin/ma ... name=Barry
Your problem is going to be separating out only the points that are yours. That's easy to do if you have been using a passkey but otherwise can't be done.
Once points are submitted, no adjustments will be made.
If I set the same passkey for both of myselves, would there be a webpage that shows only my points from both teams? I tried the page http://fah-web2.stanford.edu/cgi-bin/ma ... e&passkey= and appended my passkey but it just listed a bunch of nonames and none were from my team. Tried it with https too.
P5-133XL
Machine #2:
Machine 3:
You can't retroactively assign your passkey. Those points were never submitted with a passkey so assigning the passkey to the old user won't help except for any new WU's submitted to the old team.
