08:51:40:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
08:51:41:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:51:41:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:7087 run:0 clone:4 gen:56 core:0xa4 unit:0x0000010c0001329c502dad95d686d3fd
08:51:41:WU00:FS00:Uploading 14.65MiB to 129.74.85.15
08:51:41:WU01:FS00:Starting
08:51:41:WU00:FS00:Connecting to 129.74.85.15:8080
08:51:48:WU00:FS00:Upload 0.85%
09:03:05:WU00:FS00:Upload 99.43%
09:03:11:WU00:FS00:Upload complete
09:03:11:WU00:FS00:Server responded WORK_QUIT (404)
09:03:11:WARNING:WU00:FS00:Server did not like results, dumping
09:03:11:WU00:FS00:Cleaning up
Project: 7087 (Run 0, Clone 4, Gen 56)
Re: Project: 7087 (Run 0, Clone 4, Gen 56)
The WU was returned successfully by someone else:
Hi xxxxxx (team xxxx),
Your WU (P7087 R0 C4 G56) was added to the stats database on 2012-11-20 16:07:52 for 6702.28 points of credit.
I finished it today.But 'Server did not like results, dumping' . How could this happenning? why others can got points.But I can`t?Just Because i`m the second one that who returned this WU?
I calculated it for 4 days, but got 0 points, it is correct?
Basically, when a WU is returned the server software performs validity checks and if something is found that leads it to believe there's something wrong it will dump it so as not to mess up the science.
We would need to see the complete log from the initial download to the upload plus the System Info section and the Configuration section before we could even begin to guess.
P5-133XL
Machine #2:
Machine 3:
A server did not like the results error is typically caused by data corruption of the results that was not caught before by the client. It could be transmission through the internet, but also corruption beforehand while located on the HD or as it passed through RAM. While that is not terribly helpful because the problem is potentially rather broad but perhaps that information may be useful in the diagnostic process if you can associate it with some other problem you are having.
maybe it`s Internet problem when uploading data to server.My isp is not stable,It always download failed.
Suggestion:
Plz change the words.Your may say 'result was corruped' instead of 'Server did not like results'.It is too unacceptable for user.
Suggestion:
Failed again, is there anything wrong with server?
*********************** Log Started 2012-11-25T01:49:58Z ***********************
01:49:58:************************* Folding@home Client *************************
01:49:58: Website: http://folding.stanford.edu/
01:49:58: Copyright: (c) 2009-2012 Stanford University
01:49:58: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:49:58: Args: --lifeline 1584 --command-port=36330
01:49:58: Config: D:/ProgramData/FAHClient/config.xml
01:49:58:******************************** Build ********************************
01:49:58: Version: 7.2.9
01:49:58: Date: Oct 3 2012
01:49:58: Time: 18:05:48
01:49:58: SVN Rev: 3578
01:49:58: Branch: fah/trunk/client
01:49:58: Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:49:58: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:49:58: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:49:58: Platform: win32 XP
01:49:58: Bits: 32
01:49:58: Mode: Release
01:49:58:******************************* System ********************************
01:49:58: CPU: Intel(R) Core(TM) i3 CPU M 350 @ 2.27GHz
01:49:58: CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
01:49:58: CPUs: 4
01:49:58: Memory: 3.80GiB
01:49:58: Free Memory: 2.93GiB
01:49:58: Threads: WINDOWS_THREADS
01:49:58: On Battery: false
01:49:58: UTC offset: 8
01:49:58: PID: 2272
01:49:58: CWD: D:/ProgramData/FAHClient
01:49:58: OS: Windows 7 Ultimate
01:49:58: OS Arch: AMD64
01:49:58: GPUs: 0
01:49:58: CUDA: Not detected
01:49:58:Win32 Service: false
01:49:58:***********************************************************************
01:49:58:<config>
01:49:58: <!-- FahCore Control -->
01:49:58: <checkpoint v='3'/>
01:49:58:
01:49:58: <!-- Folding Slot Configuration -->
01:49:58: <extra-core-args v='-forceasm'/>
01:49:58:
01:49:58: <!-- Network -->
01:49:58: <proxy v='202.55.5.245:8081'/>
01:49:58:
01:49:58: <!-- Slot Control -->
01:49:58: <pause-on-battery v='true'/>
01:49:58:
01:49:58: <!-- User Information -->
01:49:58: <passkey v='********************************'/>
01:49:58: <team v='3213'/>
01:49:58: <user v='vmzy'/>
01:49:58:
01:49:58: <!-- Folding Slots -->
01:49:58: <slot id='0' type='SMP'>
01:49:58: <cpus v='-1'/>
01:49:58: </slot>
01:49:58:</config>
01:49:58:Trying to access database...
01:49:58:Successfully acquired database lock
01:49:59:Enabled folding slot 00: READY smp:4
01:50:00:WU01:FS00:Starting
01:50:00:WU01:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 702 -lifeline 2272 -checkpoint 3 -np 4 -forceasm
01:50:01:WU01:FS00:Started FahCore on PID 2564
01:50:01:WU01:FS00:Core PID:2620
01:50:01:WU01:FS00:FahCore 0xa4 started
01:50:02:WU01:FS00:0xa4:
01:50:02:WU01:FS00:0xa4:*------------------------------*
01:50:02:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
01:50:02:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:50:02:WU01:FS00:0xa4:Preparing to commence simulation
01:50:02:WU01:FS00:0xa4:- Assembly optimizations manually forced on.
01:50:02:WU01:FS00:0xa4:- Not checking prior termination.
01:50:02:WU01:FS00:0xa4:- Expanded 1022771 -> 2527872 (decompressed 247.1 percent)
01:50:02:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1022771 data_size=2527872, decompressed_data_size=2527872 diff=0
01:50:02:WU01:FS00:0xa4:- Digital signature verified
01:50:02:WU01:FS00:0xa4:Project: 8069 (Run 0, Clone 168, Gen 1)
01:50:02:WU01:FS00:0xa4:Assembly optimizations on if available.
01:50:02:WU01:FS00:0xa4:Entering M.D.
01:50:03:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
01:50:08:WU01:FS00:0xa4:Using Gromacs checkpoints
01:50:09:WU01:FS00:0xa4:Mapping NT from 4 to 4
01:50:09:WU01:FS00:0xa4:Resuming from checkpoint
01:50:09:WU01:FS00:0xa4:Verified 01/wudata_01.log
01:50:10:WU01:FS00:0xa4:Verified 01/wudata_01.trr
01:50:10:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
01:50:10:WU01:FS00:0xa4:Verified 01/wudata_01.edr
01:50:10:WU01:FS00:0xa4:Completed 220750 out of 250000 steps (88%)
01:53:53:WU01:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
01:59:33:WU01:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
02:05:20:WU01:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
02:10:28:WU01:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
02:15:40:WU01:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
02:20:25:WU01:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
02:25:00:WU01:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
02:29:39:WU01:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
02:34:17:WU01:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
02:39:05:WU01:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
02:39:48:FS00:Finishing
02:43:44:WU01:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
02:48:23:WU01:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
02:48:24:WU00:FS00:Connecting to assign3.stanford.edu:8080
02:48:24:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:48:27:WU00:FS00:News: Welcome to Folding@Home
02:48:27:WU00:FS00:Assigned to work server 171.67.108.35
02:48:27:WU00:FS00:Requesting new work unit for slot 00: RUNNING smp:4 from 171.67.108.35
02:48:27:WU00:FS00:Connecting to 171.67.108.35:8080
02:48:32:WU00:FS00:Downloading 1001.33KiB
02:48:34:WU01:FS00:0xa4:
02:48:34:WU01:FS00:0xa4:Finished Work Unit:
02:48:34:WU01:FS00:0xa4:- Reading up to 1567212 from "01/wudata_01.trr": Read 1567212
02:48:34:WU01:FS00:0xa4:trr file hash check passed.
02:48:34:WU01:FS00:0xa4:- Reading up to 1758596 from "01/wudata_01.xtc": Read 1758596
02:48:34:WU01:FS00:0xa4:xtc file hash check passed.
02:48:34:WU01:FS00:0xa4:edr file hash check passed.
02:48:34:WU01:FS00:0xa4:logfile size: 37587
02:48:34:WU01:FS00:0xa4:Leaving Run
02:48:35:WU01:FS00:0xa4:- Writing 3372667 bytes of core data to disk...
02:48:36:WU01:FS00:0xa4:Done: 3372155 -> 3244343 (compressed to 96.2 percent)
02:48:36:WU01:FS00:0xa4: ... Done.
02:48:37:WU01:FS00:0xa4:- Shutting down core
02:48:37:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:48:37:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:48:38:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8069 run:0 clone:168 gen:1 core:0xa4 unit:0x000000016652edb350ad593845878ff6
02:48:38:WU01:FS00:Uploading 3.09MiB to 171.67.108.35
02:48:38:WU01:FS00:Connecting to 171.67.108.35:8080
02:48:49:WU01:FS00:Upload 2.02%
02:48:54:WU00:FS00:Download 6.39%
02:49:32:WU00:FS00:Download 12.78%
02:49:35:WU01:FS00:Upload 4.04%
02:49:35:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
02:49:35:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8069 run:0 clone:168 gen:1 core:0xa4 unit:0x000000016652edb350ad593845878ff6
02:49:35:WU01:FS00:Uploading 3.09MiB to 171.67.108.35
02:49:35:WU01:FS00:Connecting to 171.67.108.35:8080
02:49:42:WU01:FS00:Upload 4.04%
02:49:48:WU01:FS00:Upload 10.10%
02:49:54:WU01:FS00:Upload 14.14%
02:50:02:WU01:FS00:Upload 18.18%
02:50:13:WU01:FS00:Upload 20.20%
02:50:20:WU01:FS00:Upload 24.24%
02:50:30:WU01:FS00:Upload 28.28%
02:50:36:WU01:FS00:Upload 32.32%
02:50:45:WU01:FS00:Upload 38.37%
02:50:52:WU01:FS00:Upload 42.41%
02:51:00:WU01:FS00:Upload 48.47%
02:51:07:WU01:FS00:Upload 52.51%
02:51:16:WU01:FS00:Upload 54.53%
02:51:41:WU01:FS00:Upload 60.59%
02:51:41:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
02:51:41:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8069 run:0 clone:168 gen:1 core:0xa4 unit:0x000000016652edb350ad593845878ff6
02:51:41:WU01:FS00:Uploading 3.09MiB to 171.67.108.35
02:51:41:WU01:FS00:Connecting to 171.67.108.35:8080
02:51:47:WU01:FS00:Upload 6.06%
02:51:55:WU01:FS00:Upload 10.10%
02:52:05:WU01:FS00:Upload 14.14%
02:52:18:WU01:FS00:Upload 16.16%
02:52:40:WU00:FS00:Download 19.17%
02:52:47:WU01:FS00:Upload 20.20%
02:52:47:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
02:53:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8069 run:0 clone:168 gen:1 core:0xa4 unit:0x000000016652edb350ad593845878ff6
02:53:19:WU01:FS00:Uploading 3.09MiB to 171.67.108.35
02:53:19:WU01:FS00:Connecting to 171.67.108.35:8080
02:53:26:WU01:FS00:Upload 6.06%
02:53:38:WU01:FS00:Upload 12.12%
02:53:47:WU01:FS00:Upload 18.18%
02:54:02:WU01:FS00:Upload 22.22%
02:54:22:WU01:FS00:Upload 24.24%
02:54:51:WU01:FS00:Upload 26.26%
02:55:43:WU01:FS00:Upload 28.28%
02:56:09:WU01:FS00:Upload 30.30%
02:56:32:WU01:FS00:Upload 32.32%
02:57:05:WU01:FS00:Upload 34.33%
02:57:28:WU01:FS00:Upload 36.35%
02:57:49:WU01:FS00:Upload 38.37%
02:58:17:WU01:FS00:Upload 40.39%
02:58:36:WU01:FS00:Upload 42.41%
02:59:05:WU01:FS00:Upload 44.43%
02:59:32:WU01:FS00:Upload 46.45%
02:59:57:WU01:FS00:Upload 48.47%
02:59:57:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
02:59:57:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8069 run:0 clone:168 gen:1 core:0xa4 unit:0x000000016652edb350ad593845878ff6
02:59:57:WU01:FS00:Uploading 3.09MiB to 171.67.108.35
02:59:57:WU01:FS00:Connecting to 171.67.108.35:8080
03:00:03:WU01:FS00:Upload 4.04%
03:00:09:WU01:FS00:Upload 12.12%
03:00:15:WU01:FS00:Upload 18.18%
03:00:22:WU01:FS00:Upload 26.26%
03:00:29:WU01:FS00:Upload 34.33%
03:00:36:WU01:FS00:Upload 42.41%
03:00:43:WU01:FS00:Upload 50.49%
03:00:49:WU01:FS00:Upload 56.55%
03:00:55:WU01:FS00:Upload 62.61%
03:01:02:WU01:FS00:Upload 70.69%
03:01:08:WU01:FS00:Upload 76.75%
03:01:15:WU01:FS00:Upload 84.83%
03:01:22:WU01:FS00:Upload 92.91%
03:01:28:WU01:FS00:Upload 100.00%
03:01:29:WU01:FS00:Upload complete
03:01:29:WU01:FS00:Server responded WORK_QUIT (404)
03:01:29:WARNING:WU01:FS00:Server did not like results, dumping
03:01:29:WU01:FS00:Cleaning up
Nothing wrong with the server that I can see looking at the server status page or the server log. My machines have turned in nearly a dozen WU's to this server over the last 24 hours without any issues.vmzy wrote:Failed again, is there anything wrong with server?
In addition, the two WU's you have posted about get returned to two totally different servers. It looks like the problem is either with your system or your network connection.
I never got 'Server responded WORK_QUIT (404)' before.But I got it twice this week(I got 0 points this week).
Maybe it`s my network connection problem.
PinHead
- Hardware configuration: Quad Q9550 2.83 contains the GPU 57xx - running SMP and GPU
vmzy,
If you look at your log, you will find 4 "Failed to send results to work server: Transfer failed" messages in the 10 minutes prior to your successful upload.
Your network equipment might need a reset.
The message WORK_QUIT (404) seems to be the server's way of saying that the fundamental problem (in this case, a corrupt WU) cannot be corrected no matter how many times the WU is re-uploaded. This instructs the client to discard it rather than continue to retry the upload.
Successfully upload a WU just now with another isp.
I can confirm that 'WORK_QUIT (404)' was caused by isp connection.
14:30:51:WU01:FS00:Connecting to assign3.stanford.edu:8080
14:30:52:WU01:FS00:News: Welcome to Folding@Home
14:30:52:WU01:FS00:Assigned to work server 129.64.95.82
14:30:52:WU01:FS00:Requesting new work unit for slot 00: RUNNING smp:4 from 129.64.95.82
14:30:52:WU01:FS00:Connecting to 129.64.95.82:8080
14:30:54:WU01:FS00:Downloading 648.66KiB
14:30:56:WU01:FS00:Download complete
14:30:56:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7200 run:54 clone:1 gen:402 core:0xa4 unit:0x0000024407ba4bae4da7245b688950f8
14:30:57:WU01:FS00:Downloading project 7200 description
14:30:57:WU01:FS00:Connecting to fah-web.stanford.edu:80
14:30:58:WU01:FS00:Project 7200 description downloaded successfully
14:39:27:WU00:FS00:0xa4:Completed 500000 out of 500000 steps (100%)
14:39:28:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:39:38:WU00:FS00:0xa4:
14:39:38:WU00:FS00:0xa4:Finished Work Unit:
14:39:38:WU00:FS00:0xa4:- Reading up to 878784 from "00/wudata_01.trr": Read 878784
14:39:38:WU00:FS00:0xa4:trr file hash check passed.
14:39:38:WU00:FS00:0xa4:- Reading up to 962960 from "00/wudata_01.xtc": Read 962960
14:39:38:WU00:FS00:0xa4:xtc file hash check passed.
14:39:38:WU00:FS00:0xa4:edr file hash check passed.
14:39:38:WU00:FS00:0xa4:logfile size: 48811
14:39:38:WU00:FS00:0xa4:Leaving Run
14:39:41:WU00:FS00:0xa4:- Writing 1899527 bytes of core data to disk...
14:39:41:WU00:FS00:0xa4:Done: 1899015 -> 1810194 (compressed to 95.3 percent)
14:39:41:WU00:FS00:0xa4: ... Done.
14:39:42:WU00:FS00:0xa4:- Shutting down core
14:39:42:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:39:42:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:39:43:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8056 run:35 clone:34 gen:79 core:0xa4 unit:0x0000006d6652edcb506ceefd944deee1
14:39:43:WU00:FS00:Uploading 1.73MiB to 171.67.108.59
14:39:43:WU01:FS00:Starting
14:39:43:WU00:FS00:Connecting to 171.67.108.59:8080
14:39:43:WU01:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 702 -lifeline 2400 -checkpoint 3 -np 4 -forceasm
14:39:43:WU01:FS00:Started FahCore on PID 3412
14:39:43:WU01:FS00:Core PID:3116
14:39:43:WU01:FS00:FahCore 0xa4 started
14:39:44:WU01:FS00:0xa4:
14:39:44:WU01:FS00:0xa4:*------------------------------*
14:39:44:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
14:39:44:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:39:44:WU01:FS00:0xa4:Preparing to commence simulation
14:39:44:WU01:FS00:0xa4:- Assembly optimizations manually forced on.
14:39:44:WU01:FS00:0xa4:- Not checking prior termination.
14:39:44:WU01:FS00:0xa4:- Expanded 663719 -> 1297016 (decompressed 195.4 percent)
14:39:44:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=663719 data_size=1297016, decompressed_data_size=1297016 diff=0
14:39:44:WU01:FS00:0xa4:- Digital signature verified
14:39:44:WU01:FS00:0xa4:Project: 7200 (Run 54, Clone 1, Gen 402)
14:39:44:WU01:FS00:0xa4:Assembly optimizations on if available.
14:39:44:WU01:FS00:0xa4:Entering M.D.
14:39:49:WU00:FS00:Upload 18.10%
14:39:50:WU01:FS00:0xa4:Mapping NT from 4 to 4
14:39:55:WU00:FS00:Upload 36.19%
14:40:01:WU00:FS00:Upload 54.29%
14:40:06:WU01:FS00:0xa4:Completed 0 out of 750000 steps (0%)
14:40:07:WU00:FS00:Upload 72.39%
14:40:13:WU00:FS00:Upload 90.48%
14:40:17:WU00:FS00:Upload complete
14:40:17:WU00:FS00:Server responded WORK_ACK (400)
14:40:17:WU00:FS00:Final credit estimate, 444.00 points
14:40:17:WU00:FS00:Cleaning up
