Project: 3065 (Run 4, Clone 234, Gen 3), no credit
tmoble
Post by tmoble »
[09:20:01] - Preparing to get new work unit...
[09:20:01] + Attempting to get work packet
[09:20:01] - Connecting to assignment server
[09:20:01] - Successful: assigned to (171.64.65.63).
[09:20:01] + News From Folding@Home: Welcome to Folding@Home
[09:20:01] Loaded queue successfully.
[09:20:05] + Closed connections
[09:20:05]
[09:20:05] + Processing work unit
[09:20:05] Core required: FahCore_a1.exe
[09:20:05] Core found.
[09:20:05] Working on Unit 07 [April 24 09:20:05]
[09:20:05] + Working ...
[09:20:05]
[09:20:05] *------------------------------*
[09:20:05] Folding@Home Gromacs SMP Core
[09:20:05] Version 1.74 (March 10, 2007)
[09:20:05]
[09:20:05] Preparing to commence simulation
[09:20:05] - Ensuring status. Please wait.
[09:20:07] - Starting from initial work packet
[09:20:07]
[09:20:07] Project: 3065 (Run 4, Clone 234, Gen 3)
[09:20:07]
[09:20:07] Assembly optimizations on if available.
[09:20:07] Entering M.D.
[09:20:25] ial work pa- Starting from initial work packet
[09:20:25]
[09:20:25] Project: 3065 (Run 4, Clone 234, Gen 3)
[09:20:25]
[09:20:25] Entering M.D.
[09:20:31] Rejecting checkpoint
[09:20:32] ProteiExtra SSE boost OK.
[09:20:32] a5_99sb_big
[09:20:32] Writing local files
[09:20:32] Extra SSE boost OK.
[09:20:32] Completed 0 out of 2500000 steps  (0 percent)
[09:41:09] Writing local files
[09:41:09] Completed 25000 out of 2500000 steps  (1 percent)
17:48:54] Completed 2475000 out of 2500000 steps  (99 percent)
[18:08:54] Writing local files
[18:08:54] Completed 2500000 out of 2500000 steps  (100 percent)
[18:08:54] Writing final coordinates.
[18:08:55] Past main M.D. loop
[18:08:55] Will end MPI now
[18:09:55]
[18:09:55] Finished Work Unit:
[18:09:55] - Reading up to 1601592 from "work/wudata_07.arc": Read 1601592
[18:09:55] - Reading up to 489384 from "work/wudata_07.xtc": Read 489384
[18:09:55] goefile size: 0
[18:09:55] logfile size: 78812
[18:09:55] Leaving Run
[18:09:56] - Writing 2271632 bytes of core data to disk...
[18:09:56]   ... Done.
[18:09:56] - Failed to delete work/wudata_07.sas
[18:09:56] - Failed to delete work/wudata_07.goe
[18:09:56] Warning:  check for stray files
[18:09:56] - Shutting down core
[18:11:56]
[18:11:56] Folding@home Core Shutdown: FINISHED_UNIT
[18:11:56]
[18:12:00] CoreStatus = 64 (100)
[18:12:00] Sending work to server
[18:12:00] + Attempting to send results
[18:12:33] + Results successfully sent
[18:12:33] Thank you for your contribution to Folding@Home.
[18:12:33] + Number of Units Completed: 26
but no credit?
tmoble
Re: Project: 3065 (Run 4, Clone 234, Gen 3), no credit
Post by tmoble »
the run took about 33 hours, about right for this box. around 20 mins/step. now working on another 3065:
3065 (Run 2, Clone 109, Gen 2)
apd183
Hardware configuration: - Core 2 Duo E6400, 3GB RAM, Win Vista, 1 v5 CPU Client, 1 v6 CPU Client
- Pentium 4 3.xGHz, 1GB RAM, Win XP w/ v6 CPU Client
- 3x Pentium 4 2.26GHz, 1GB RAM
-- Win 2000 w/ v5 CPU Client
-- Win Vista w/ v6 CPU Client
-- Ubuntu 8 w/ v6 CPU Client
Post by apd183 »
The stats are running behind right now. See this thread: viewtopic.php?f=18&t=2300#p20483
