What's with project 70XX ????
Valkyrie
Post by Valkyrie »
Hi Folks:
Currently running 7007 (2, 428, 93) and getting 15+ min frames.
WU's of the same base credit usually run at ~5-6 min frames on this machine. Nothing else is running and clockspeed is normal, BUT .... temps are down 5-6 C while still reporting 100% CPU usage.
Seems to be progressing fine at a very slooowww pace. Any ideas?
Thanks,
V
edited subject to be more appropriate
Re: What's with project 7007????
Project 7007 is for FahCore_a4. That core can run with one or more CPU-cores.
If you post the first couple of pages of the log, showing the client initialization plus the part where it starts folding 7007 we can probably help. If it's not included in that part of the post, fill in your hardware profile so we can assess what might be happening.
Which CPU you have? Do you also fold with a GPU? Do you run some other DC project with FAH?
Valkyrie
Post by Valkyrie »
It's running on an I5-2450M @ 2.9 GHz running SMP only. F@H only.
20:40:20:WU00:FS00:0xa4:Completed 9100001 out of 10000000 steps  (91%)
20:45:16:WU00:FS00:0xa4:Completed 9200000 out of 10000000 steps  (92%)
20:50:15:WU00:FS00:0xa4:Completed 9300000 out of 10000000 steps  (93%)
20:55:29:WU00:FS00:0xa4:Completed 9400000 out of 10000000 steps  (94%)
21:00:30:WU00:FS00:0xa4:Completed 9500000 out of 10000000 steps  (95%)
21:05:29:WU00:FS00:0xa4:Completed 9600000 out of 10000000 steps  (96%)
21:10:29:WU00:FS00:0xa4:Completed 9700000 out of 10000000 steps  (97%)
21:17:19:WU00:FS00:0xa4:Completed 9800000 out of 10000000 steps  (98%)
21:22:20:WU00:FS00:0xa4:Completed 9900000 out of 10000000 steps  (99%)
21:22:21:WU01:FS00:Connecting to assign3.stanford.edu:8080
21:22:21:WU01:FS00:News: Welcome to Folding@Home
21:22:21:WU01:FS00:Assigned to work server 129.74.85.15
21:22:21:WU01:FS00:Requesting new work unit for slot 00: RUNNING smp:4 from 129.74.85.15
21:22:21:WU01:FS00:Connecting to 129.74.85.15:8080
21:22:22:WU01:FS00:Downloading 39.83KiB
21:22:22:WU01:FS00:Download complete
21:22:22:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:7007 run:2 clone:428 gen:93 core:0xa4 unit:0x000000f80001329c4dfb911716af4fdf
21:22:22:WU01:FS00:Downloading project 7007 description
21:22:22:WU01:FS00:Connecting to fah-web.stanford.edu:80
21:22:22:WU01:FS00:Project 7007 description downloaded successfully
21:27:20:WU00:FS00:0xa4:Completed 10000000 out of 10000000 steps  (100%)
21:27:20:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
21:27:30:WU00:FS00:0xa4:
21:27:30:WU00:FS00:0xa4:Finished Work Unit:
21:27:30:WU00:FS00:0xa4:- Reading up to 2179176 from "00/wudata_01.trr": Read 2179176
21:27:31:WU00:FS00:0xa4:trr file hash check passed.
21:27:31:WU00:FS00:0xa4:- Reading up to 226296 from "00/wudata_01.xtc": Read 226296
21:27:31:WU00:FS00:0xa4:xtc file hash check passed.
21:27:31:WU00:FS00:0xa4:edr file hash check passed.
21:27:31:WU00:FS00:0xa4:logfile size: 80585
21:27:31:WU00:FS00:0xa4:Leaving Run
21:27:32:WU00:FS00:0xa4:- Writing 2510529 bytes of core data to disk...
21:27:32:WU00:FS00:0xa4:Done: 2510017 -> 1894883 (compressed to 75.4 percent)
21:27:32:WU00:FS00:0xa4:  ... Done.
21:27:32:WU00:FS00:0xa4:- Shutting down core
21:27:32:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
21:27:33:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:27:33:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7011 run:0 clone:76 gen:88 core:0xa4 unit:0x000000d30001329c4dfb96642d60de75
21:27:33:WU00:FS00:Uploading 1.81MiB to 129.74.85.15
21:27:33:WU00:FS00:Connecting to 129.74.85.15:8080
21:27:33:WU01:FS00:Starting
21:27:33:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Dawn/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2420 -checkpoint 15 -np 4
21:27:33:WU01:FS00:Started FahCore on PID 3828
21:27:33:WU01:FS00:Core PID:5896
21:27:33:WU01:FS00:FahCore 0xa4 started
21:27:33:WU01:FS00:0xa4:
21:27:33:WU01:FS00:0xa4:*------------------------------*
21:27:33:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
21:27:33:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
21:27:33:WU01:FS00:0xa4:Preparing to commence simulation
21:27:33:WU01:FS00:0xa4:- Looking at optimizations...
21:27:33:WU01:FS00:0xa4:- Created dyn
21:27:33:WU01:FS00:0xa4:- Files status OK
21:27:33:WU01:FS00:0xa4:- Expanded 40279 -> 207472 (decompressed 515.0 percent)
21:27:33:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=40279 data_size=207472, decompressed_data_size=207472 diff=0
21:27:33:WU01:FS00:0xa4:- Digital signature verified
21:27:33:WU01:FS00:0xa4:Project: 7007 (Run 2, Clone 428, Gen 93)
21:27:33:WU01:FS00:0xa4:Assembly optimizations on if available.
21:27:33:WU01:FS00:0xa4:Entering M.D.
21:27:39:WU00:FS00:Upload 34.58%
21:27:39:WU01:FS00:0xa4:Mapping NT from 4 to 4
21:27:39:WU01:FS00:0xa4:Completed 0 out of 10000000 steps  (0%)
21:27:45:WU00:FS00:Upload 69.15%
21:27:51:WU00:FS00:Upload complete
21:27:51:WU00:FS00:Server responded WORK_ACK (400)
21:27:51:WU00:FS00:Final credit estimate, 2607.00 points
21:27:51:WU00:FS00:Cleaning up
21:42:51:WU01:FS00:0xa4:Completed 100000 out of 10000000 steps  (1%)
21:57:58:WU01:FS00:0xa4:Completed 200000 out of 10000000 steps  (2%)
22:13:05:WU01:FS00:0xa4:Completed 300000 out of 10000000 steps  (3%)
22:28:20:WU01:FS00:0xa4:Completed 400000 out of 10000000 steps  (4%)
22:37:10:Server connection id=127 on 0.0.0.0:36330 from 127.0.0.1
22:37:16:FS00:Paused
22:37:16:FS00:Shutting core down
22:37:21:Server connection id=127 ended
22:37:24:WU01:FS00:0xa4:Client no longer detected. Shutting down core
22:37:24:WU01:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
22:37:25:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:56:44:Server connection id=128 on 0.0.0.0:36330 from 127.0.0.1
22:56:49:FS00:Unpaused
22:56:49:WU01:FS00:Starting
22:56:49:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Dawn/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2420 -checkpoint 15 -np 4
22:56:49:WU01:FS00:Started FahCore on PID 7164
22:56:49:WU01:FS00:Core PID:2964
22:56:49:WU01:FS00:FahCore 0xa4 started
22:56:49:WU01:FS00:0xa4:
22:56:49:WU01:FS00:0xa4:*------------------------------*
22:56:49:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
22:56:49:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
22:56:49:WU01:FS00:0xa4:Preparing to commence simulation
22:56:49:WU01:FS00:0xa4:- Looking at optimizations...
22:56:49:WU01:FS00:0xa4:- Files status OK
22:56:49:WU01:FS00:0xa4:- Expanded 40279 -> 207472 (decompressed 515.0 percent)
22:56:49:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=40279 data_size=207472, decompressed_data_size=207472 diff=0
22:56:49:WU01:FS00:0xa4:- Digital signature verified
22:56:49:WU01:FS00:0xa4:Project: 7007 (Run 2, Clone 428, Gen 93)
22:56:49:WU01:FS00:0xa4:Assembly optimizations on if available.
22:56:49:WU01:FS00:0xa4:Entering M.D.
22:56:55:WU01:FS00:0xa4:Using Gromacs checkpoints
22:56:55:WU01:FS00:0xa4:Mapping NT from 4 to 4
22:56:55:WU01:FS00:0xa4:Resuming from checkpoint
22:56:55:WU01:FS00:0xa4:Verified 01/wudata_01.log
22:56:55:WU01:FS00:0xa4:Verified 01/wudata_01.trr
22:56:55:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
22:56:55:WU01:FS00:0xa4:Verified 01/wudata_01.edr
22:56:55:WU01:FS00:0xa4:Completed 400001 out of 10000000 steps  (4%)
22:56:55:Server connection id=128 ended
23:12:00:WU01:FS00:0xa4:Completed 500000 out of 10000000 steps  (5%)
23:27:04:WU01:FS00:0xa4:Completed 600000 out of 10000000 steps  (6%)
23:42:08:WU01:FS00:0xa4:Completed 700000 out of 10000000 steps  (7%)
23:57:11:WU01:FS00:0xa4:Completed 800000 out of 10000000 steps  (8%)
00:12:45:WU01:FS00:0xa4:Completed 900000 out of 10000000 steps  (9%)
00:17:55:Server connection id=129 on 0.0.0.0:36330 from 127.0.0.1
00:18:42:Server connection id=129 ended
00:22:21:Server connection id=130 on 0.0.0.0:36330 from 127.0.0.1
00:24:29:Server connection id=130 ended
00:28:12:WU01:FS00:0xa4:Completed 1000000 out of 10000000 steps  (10%)
00:37:03:Server connection id=131 on 0.0.0.0:36330 from 127.0.0.1
00:37:14:Server connection id=131 ended
00:43:26:Server connection id=132 on 0.0.0.0:36330 from 127.0.0.1
00:43:32:WU01:FS00:0xa4:Completed 1100000 out of 10000000 steps  (11%)
00:59:07:WU01:FS00:0xa4:Completed 1200000 out of 10000000 steps  (12%)
01:08:30:Server connection id=132 ended
01:14:24:WU01:FS00:0xa4:Completed 1300000 out of 10000000 steps  (13%)
******************************** Date: 22/11/12 ********************************
01:29:37:WU01:FS00:0xa4:Completed 1400000 out of 10000000 steps  (14%)
01:44:42:WU01:FS00:0xa4:Completed 1500000 out of 10000000 steps  (15%)
01:59:44:WU01:FS00:0xa4:Completed 1600000 out of 10000000 steps  (16%)
02:14:47:WU01:FS00:0xa4:Completed 1700000 out of 10000000 steps  (17%)
Ravage7779
Post by Ravage7779 »
10 million steps? is that normal for that series?
Valkyrie
Post by Valkyrie »
Finished that POS WU and immediately picked up another that runs only slightly faster. What the heck is going on with these 7 series wu's? Did they even bother benching them?
PPD is about 1/3 of normal for this machine.
01:19:43:WU01:FS00:0xa4:Completed 9700000 out of 10000000 steps  (97%)
******************************** Date: 23/11/12 ********************************
01:34:46:WU01:FS00:0xa4:Completed 9800000 out of 10000000 steps  (98%)
01:49:50:WU01:FS00:0xa4:Completed 9900000 out of 10000000 steps  (99%)
01:49:50:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:49:50:WU00:FS00:News: Welcome to Folding@Home
01:49:50:WU00:FS00:Assigned to work server 129.74.85.15
01:49:50:WU00:FS00:Requesting new work unit for slot 00: RUNNING smp:4 from 129.74.85.15
01:49:50:WU00:FS00:Connecting to 129.74.85.15:8080
01:49:54:WU00:FS00:Downloading 38.04KiB
01:49:54:WU00:FS00:Download complete
01:49:54:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:7020 run:3 clone:74 gen:98 core:0xa4 unit:0x0000011c0001329c4dfba5a26b27f638
01:49:54:WU00:FS00:Downloading project 7020 description
01:49:54:WU00:FS00:Connecting to fah-web.stanford.edu:80
01:49:55:WU00:FS00:Project 7020 description downloaded successfully
02:06:29:WU01:FS00:0xa4:Completed 10000000 out of 10000000 steps  (100%)
02:06:30:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:06:40:WU01:FS00:0xa4:
02:06:40:WU01:FS00:0xa4:Finished Work Unit:
02:06:40:WU01:FS00:0xa4:- Reading up to 2146452 from "01/wudata_01.trr": Read 2146452
02:06:40:WU01:FS00:0xa4:trr file hash check passed.
02:06:40:WU01:FS00:0xa4:- Reading up to 119988 from "01/wudata_01.xtc": Read 119988
02:06:40:WU01:FS00:0xa4:xtc file hash check passed.
02:06:40:WU01:FS00:0xa4:edr file hash check passed.
02:06:40:WU01:FS00:0xa4:logfile size: 86171
02:06:40:WU01:FS00:0xa4:Leaving Run
02:06:40:WU01:FS00:0xa4:- Writing 2377083 bytes of core data to disk...
02:06:41:WU01:FS00:0xa4:Done: 2376571 -> 12450 (compressed to 0.5 percent)
02:06:41:WU01:FS00:0xa4:  ... Done.
02:06:42:WU01:FS00:0xa4:- Shutting down core
02:06:42:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:06:42:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:06:42:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7007 run:2 clone:428 gen:93 core:0xa4 unit:0x000000f80001329c4dfb911716af4fdf
02:06:42:WU01:FS00:Uploading 12.66KiB to 129.74.85.15
02:06:42:WU00:FS00:Starting
02:06:42:WU01:FS00:Connecting to 129.74.85.15:8080
02:06:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Dawn/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2796 -checkpoint 15 -np 4
02:06:42:WU00:FS00:Started FahCore on PID 4636
02:06:42:WU00:FS00:Core PID:4580
02:06:42:WU00:FS00:FahCore 0xa4 started
02:06:43:WU00:FS00:0xa4:
02:06:43:WU00:FS00:0xa4:*------------------------------*
02:06:43:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
02:06:43:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:06:43:WU00:FS00:0xa4:Preparing to commence simulation
02:06:43:WU00:FS00:0xa4:- Looking at optimizations...
02:06:43:WU00:FS00:0xa4:- Created dyn
02:06:43:WU00:FS00:0xa4:- Files status OK
02:06:43:WU00:FS00:0xa4:- Expanded 38438 -> 197212 (decompressed 513.0 percent)
02:06:43:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=38438 data_size=197212, decompressed_data_size=197212 diff=0
02:06:43:WU00:FS00:0xa4:- Digital signature verified
02:06:43:WU00:FS00:0xa4:Project: 7020 (Run 3, Clone 74, Gen 98)
02:06:43:WU00:FS00:0xa4:Assembly optimizations on if available.
02:06:43:WU00:FS00:0xa4:Entering M.D.
02:06:43:WU01:FS00:Upload complete
02:06:43:WU01:FS00:Server responded WORK_ACK (400)
02:06:43:WU01:FS00:Final credit estimate, 1574.00 points
02:06:43:WU01:FS00:Cleaning up
02:06:49:WU00:FS00:0xa4:Mapping NT from 4 to 4
02:06:49:WU00:FS00:0xa4:Completed 0 out of 10000000 steps  (0%)
02:21:18:WU00:FS00:0xa4:Completed 100000 out of 10000000 steps  (1%)
02:35:46:WU00:FS00:0xa4:Completed 200000 out of 10000000 steps  (2%)
02:42:08:Server connection id=19 on 0.0.0.0:36330 from 127.0.0.1
02:50:41:WU00:FS00:0xa4:Completed 300000 out of 10000000 steps  (3%)
02:51:52:Server connection id=19 ended
02:58:26:Server connection id=20 on 0.0.0.0:36330 from 127.0.0.1
02:59:22:Server connection id=20 ended
03:05:44:WU00:FS00:0xa4:Completed 400000 out of 10000000 steps  (4%)
03:20:17:WU00:FS00:0xa4:Completed 500000 out of 10000000 steps  (5%)
03:34:48:WU00:FS00:0xa4:Completed 600000 out of 10000000 steps  (6%)
03:49:21:WU00:FS00:0xa4:Completed 700000 out of 10000000 steps  (7%)
04:03:53:WU00:FS00:0xa4:Completed 800000 out of 10000000 steps  (8%)
04:18:24:WU00:FS00:0xa4:Completed 900000 out of 10000000 steps  (9%)
04:32:54:WU00:FS00:0xa4:Completed 1000000 out of 10000000 steps  (10%)
04:45:37:Server connection id=21 on 0.0.0.0:36330 from 127.0.0.1
Until somebody answers the question asked above about whehter 10000000 steps is right or wrong, we can't answer your basic question. If it was benchmarked with a different number of steps and that number has changed, there's an obvious answer to your question -- but then the question becomes how did it get changed. If it has always been 10000000 steps, then there was a problem with the benchmarking. I don't know enough to answer either set of questions.
Valkyrie
Post by Valkyrie »
Thanks Bruce....I didn't realize we were in a holding pattern.
I just noticed that another machine has picked up 7017(1,296,87) also with 10000000 steps and also running rather high TPF. That machine is also running a Fermi GPU that was recently "updated" to the 2.25 client. Starting to feel a bit stuck in the muck here!
Valkyrie
Post by Valkyrie »
Here's a bit of context. The 2450M machine finshed the 7020(3,74,98) with ten million steps after a day or so for ~1698 points. It then picked up 7647(222,1,58) with a base credit of 2250 points and 2.5 million steps with 37-40 min frames for an estimated ~4500 ppd. In the past these 2250 point wu's usually get more like 4000 ppd on this machine due to interruptions which is fine as it's a general use machine.
edit: Temps are back up to normal on this 7647 wu. The 7020 just completed was apparently credited about 1.1 times more than the original estimate. Still low performance for this system.
23:49:53:WU00:FS00:0xa4:Completed 8800000 out of 10000000 steps  (88%)
00:04:28:WU00:FS00:0xa4:Completed 8900000 out of 10000000 steps  (89%)
00:18:57:WU00:FS00:0xa4:Completed 9000000 out of 10000000 steps  (90%)
00:34:58:WU00:FS00:0xa4:Completed 9100000 out of 10000000 steps  (91%)
00:49:29:WU00:FS00:0xa4:Completed 9200000 out of 10000000 steps  (92%)
01:04:30:WU00:FS00:0xa4:Completed 9300000 out of 10000000 steps  (93%)
01:19:01:WU00:FS00:0xa4:Completed 9400000 out of 10000000 steps  (94%)
01:33:31:WU00:FS00:0xa4:Completed 9500000 out of 10000000 steps  (95%)
01:48:19:WU00:FS00:0xa4:Completed 9600000 out of 10000000 steps  (96%)
******************************** Date: 24/11/12 ********************************
02:03:03:WU00:FS00:0xa4:Completed 9700000 out of 10000000 steps  (97%)
02:11:52:Server connection id=32 on 0.0.0.0:36330 from 127.0.0.1
02:13:09:Server connection id=32 ended
02:15:51:Server connection id=33 on 0.0.0.0:36330 from 127.0.0.1
02:16:08:Server connection id=33 ended
02:18:03:WU00:FS00:0xa4:Completed 9800000 out of 10000000 steps  (98%)
02:32:34:WU00:FS00:0xa4:Completed 9900000 out of 10000000 steps  (99%)
02:32:34:WU01:FS00:Connecting to assign3.stanford.edu:8080
02:32:34:WU01:FS00:News: Welcome to Folding@Home
02:32:34:WU01:FS00:Assigned to work server 171.64.65.101
02:32:34:WU01:FS00:Requesting new work unit for slot 00: RUNNING smp:4 from 171.64.65.101
02:32:34:WU01:FS00:Connecting to 171.64.65.101:8080
02:32:35:WU01:FS00:Downloading 534.93KiB
02:32:36:WU01:FS00:Download complete
02:32:36:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:7647 run:222 clone:1 gen:58 core:0xa4 unit:0x00000050664f2dcd4fa7feaf1ce38064
02:37:18:Server connection id=34 on 0.0.0.0:36330 from 127.0.0.1
02:38:10:Server connection id=34 ended
02:43:29:Server connection id=35 on 0.0.0.0:36330 from 127.0.0.1
02:45:20:Server connection id=35 ended
02:47:19:WU00:FS00:0xa4:Completed 10000000 out of 10000000 steps  (100%)
02:47:20:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:47:30:WU00:FS00:0xa4:
02:47:30:WU00:FS00:0xa4:Finished Work Unit:
02:47:30:WU00:FS00:0xa4:- Reading up to 2033736 from "00/wudata_01.trr": Read 2033736
02:47:30:WU00:FS00:0xa4:trr file hash check passed.
02:47:30:WU00:FS00:0xa4:- Reading up to 113928 from "00/wudata_01.xtc": Read 113928
02:47:30:WU00:FS00:0xa4:xtc file hash check passed.
02:47:30:WU00:FS00:0xa4:edr file hash check passed.
02:47:30:WU00:FS00:0xa4:logfile size: 83025
02:47:30:WU00:FS00:0xa4:Leaving Run
02:47:33:WU00:FS00:0xa4:- Writing 2255161 bytes of core data to disk...
02:47:33:WU00:FS00:0xa4:Done: 2254649 -> 11670 (compressed to 0.5 percent)
02:47:33:WU00:FS00:0xa4:  ... Done.
02:47:34:WU00:FS00:0xa4:- Shutting down core
02:47:34:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:47:34:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:47:34:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7020 run:3 clone:74 gen:98 core:0xa4 unit:0x0000011c0001329c4dfba5a26b27f638
02:47:34:WU00:FS00:Uploading 11.90KiB to 129.74.85.15
02:47:34:WU01:FS00:Starting
02:47:34:WU00:FS00:Connecting to 129.74.85.15:8080
02:47:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Dawn/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2796 -checkpoint 15 -np 4
02:47:34:WU01:FS00:Started FahCore on PID 2396
02:47:34:WU01:FS00:Core PID:4884
02:47:34:WU01:FS00:FahCore 0xa4 started
02:47:35:WU01:FS00:0xa4:
02:47:35:WU01:FS00:0xa4:*------------------------------*
02:47:35:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
02:47:35:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:47:35:WU01:FS00:0xa4:Preparing to commence simulation
02:47:35:WU01:FS00:0xa4:- Looking at optimizations...
02:47:35:WU01:FS00:0xa4:- Created dyn
02:47:35:WU00:FS00:Upload complete
02:47:35:WU01:FS00:0xa4:- Files status OK
02:47:35:WU00:FS00:Server responded WORK_ACK (400)
02:47:35:WU01:FS00:0xa4:- Expanded 547254 -> 846588 (decompressed 154.6 percent)
02:47:35:WU00:FS00:Final credit estimate, 1689.00 points
02:47:35:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=547254 data_size=846588, decompressed_data_size=846588 diff=0
02:47:35:WU01:FS00:0xa4:- Digital signature verified
02:47:35:WU01:FS00:0xa4:Project: 7647 (Run 222, Clone 1, Gen 58)
02:47:35:WU01:FS00:0xa4:Assembly optimizations on if available.
02:47:35:WU01:FS00:0xa4:Entering M.D.
02:47:35:WU00:FS00:Cleaning up
02:47:40:WU01:FS00:0xa4:Mapping NT from 4 to 4
02:47:41:WU01:FS00:0xa4:Completed 0 out of 2500000 steps  (0%)
02:52:36:Server connection id=36 on 0.0.0.0:36330 from 127.0.0.1
02:53:23:Server connection id=36 ended
02:58:32:Server connection id=37 on 0.0.0.0:36330 from 127.0.0.1
02:59:18:Server connection id=37 ended
03:27:06:WU01:FS00:0xa4:Completed 25000 out of 2500000 steps  (1%)
03:41:53:Server connection id=38 on 0.0.0.0:36330 from 127.0.0.1
03:42:09:Server connection id=38 ended
04:02:16:Server connection id=39 on 0.0.0.0:36330 from 127.0.0.1
04:02:24:FS00:Paused
04:02:24:FS00:Shutting core down
04:02:29:WU01:FS00:0xa4:Client no longer detected. Shutting down core
04:02:29:WU01:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
04:02:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:02:29:Server connection id=39 ended
04:57:59:Server connection id=40 on 0.0.0.0:36330 from 127.0.0.1
04:58:03:FS00:Unpaused
04:58:03:WU01:FS00:Starting
04:58:03:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Dawn/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2796 -checkpoint 15 -np 4
04:58:03:WU01:FS00:Started FahCore on PID 3424
04:58:03:WU01:FS00:Core PID:4352
04:58:03:WU01:FS00:FahCore 0xa4 started
04:58:04:WU01:FS00:0xa4:
04:58:04:WU01:FS00:0xa4:*------------------------------*
04:58:04:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
04:58:04:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
04:58:04:WU01:FS00:0xa4:Preparing to commence simulation
04:58:04:WU01:FS00:0xa4:- Looking at optimizations...
04:58:04:WU01:FS00:0xa4:- Files status OK
04:58:04:WU01:FS00:0xa4:- Expanded 547254 -> 846588 (decompressed 154.6 percent)
04:58:04:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=547254 data_size=846588, decompressed_data_size=846588 diff=0
04:58:04:WU01:FS00:0xa4:- Digital signature verified
04:58:04:WU01:FS00:0xa4:Project: 7647 (Run 222, Clone 1, Gen 58)
04:58:04:WU01:FS00:0xa4:Assembly optimizations on if available.
04:58:04:WU01:FS00:0xa4:Entering M.D.
04:58:10:WU01:FS00:0xa4:Using Gromacs checkpoints
04:58:10:WU01:FS00:0xa4:Mapping NT from 4 to 4
04:58:10:WU01:FS00:0xa4:Resuming from checkpoint
04:58:10:WU01:FS00:0xa4:Verified 01/wudata_01.log
04:58:10:WU01:FS00:0xa4:Verified 01/wudata_01.trr
04:58:10:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
04:58:10:WU01:FS00:0xa4:Verified 01/wudata_01.edr
04:58:10:WU01:FS00:0xa4:Completed 38120 out of 2500000 steps  (1%)
04:58:14:Server connection id=40 ended
05:15:37:Server connection id=41 on 0.0.0.0:36330 from 127.0.0.1
05:16:36:WU01:FS00:0xa4:Completed 50000 out of 2500000 steps  (2%)
05:17:25:Server connection id=41 ended
05:23:59:Server connection id=42 on 0.0.0.0:36330 from 127.0.0.1
05:25:06:Server connection id=42 ended
05:31:31:Server connection id=43 on 0.0.0.0:36330 from 127.0.0.1
Mactin
Re: What's with project 70XX ????
Post by Mactin »
My experience with these 600 base point 70xx WUs is that one in ten or one in twenty of them will fold really slow.
Since they have a high PPD with the majority of them, the slow ones dont bother me to much. If you care about points, cross your fingers and dont take it personal.
Valkyrie wrote:The 7020 just completed was apparently credited about 1.1 times more than the original estimate.
That would be the 10% bonus for core A4 projects that was announced back in July in the blog. It was announced that the bonus would be applied for at least 3 months, still is being added with no end date having been announced.
Valkyrie
Post by Valkyrie »
@Mactin thanks for that. I too have run many of these wu's with good performance. I report the bad ones in the hope that the dev's will be able to improve the project.
Joe_H ...I remember reading something about that......Thanks!
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Post by Napoleon »
See also this post by tjlane: Re: Project 7611 (0, 23, 259) - High TPF. It may not be related to the OP's problem, but it mentions a rarely occurring bug in the A4 core itself.
UPDATE. This seems pretty weird as well. With a compression ratio that high, I presume the contents of the returned WU are just a piece of garbage repeated over and over again...
UPDATE. I recall reporting similar über-compression myself with project:7042 run:0 clone:0 gen:3 WU, viewtopic.php?f=66&t=22321&#p227898. Perhaps these two WUs could use some looking into, despite the apparently successful completion? I checked some old logs, and having good compression on the results seems like an anomaly to me:
[root@localhost logs]# grep -h ":0xa4:Done" *.txt
19:29:29:WU00:FS00:0xa4:Done: 1872238 -> 1803607 (compressed to 96.3 percent)
05:30:27:WU01:FS00:0xa4:Done: 1875820 -> 1807015 (compressed to 96.3 percent)
05:54:06:WU00:FS00:0xa4:Done: 4574443 -> 15634 (compressed to 0.3 percent)
16:19:24:WU01:FS00:0xa4:Done: 1871838 -> 1803033 (compressed to 96.3 percent)
02:22:31:WU00:FS00:0xa4:Done: 1873147 -> 1804350 (compressed to 96.3 percent)
12:23:51:WU01:FS00:0xa4:Done: 1875810 -> 1807077 (compressed to 96.3 percent)
22:48:15:WU00:FS00:0xa4:Done: 1877379 -> 1808589 (compressed to 96.3 percent)
08:43:49:WU01:FS00:0xa4:Done: 1872301 -> 1803716 (compressed to 96.3 percent)
18:55:55:WU00:FS00:0xa4:Done: 1877320 -> 1808665 (compressed to 96.3 percent)
05:08:02:WU01:FS00:0xa4:Done: 1876098 -> 1807478 (compressed to 96.3 percent)
08:00:38:WU00:FS00:0xa4:Done: 4768021 -> 3366870 (compressed to 70.6 percent)
18:10:58:WU01:FS00:0xa4:Done: 1877396 -> 1808445 (compressed to 96.3 percent)
04:20:27:WU00:FS00:0xa4:Done: 1874734 -> 1806059 (compressed to 96.3 percent)
08:18:46:WU01:FS00:0xa4:Done: 4799471 -> 3820881 (compressed to 79.6 percent)
18:36:36:WU00:FS00:0xa4:Done: 1878992 -> 1810201 (compressed to 96.3 percent)
05:10:41:WU01:FS00:0xa4:Done: 1874937 -> 1806153 (compressed to 96.3 percent)
19:05:29:WU00:FS00:0xa4:Done: 1874672 -> 1805954 (compressed to 96.3 percent)
01:14:48:WU00:FS00:0xa4:Done: 1253670 -> 1193387 (compressed to 95.1 percent)
05:48:37:WU01:FS00:0xa4:Done: 1252237 -> 1192100 (compressed to 95.1 percent)
15:58:16:WU00:FS00:0xa4:Done: 1874252 -> 1805514 (compressed to 96.3 percent)
05:05:29:WU00:FS00:0xa4:Done: 1879310 -> 1809928 (compressed to 96.3 percent)
15:13:03:WU01:FS00:0xa4:Done: 1874484 -> 1805702 (compressed to 96.3 percent)
20:00:06:WU00:FS00:0xa4:Done: 1250196 -> 1190086 (compressed to 95.1 percent)
06:10:30:WU01:FS00:0xa4:Done: 1878632 -> 1809749 (compressed to 96.3 percent)
18:12:22:WU00:FS00:0xa4:Done: 1880861 -> 1811801 (compressed to 96.3 percent)
04:22:45:WU01:FS00:0xa4:Done: 1877324 -> 1808556 (compressed to 96.3 percent)
19:28:23:WU00:FS00:0xa4:Done: 1876955 -> 1808003 (compressed to 96.3 percent)
05:36:12:WU01:FS00:0xa4:Done: 1876186 -> 1803111 (compressed to 96.1 percent)
15:15:30:WU00:FS00:0xa4:Done: 2288704 -> 2193026 (compressed to 95.8 percent)
00:15:53:WU01:FS00:0xa4:Done: 2286636 -> 2191379 (compressed to 95.8 percent)
10:53:09:WU00:FS00:0xa4:Done: 1875043 -> 1805853 (compressed to 96.3 percent)
19:56:14:WU01:FS00:0xa4:Done: 2289078 -> 2193471 (compressed to 95.8 percent)
06:13:50:WU00:FS00:0xa4:Done: 1881990 -> 1813018 (compressed to 96.3 percent)
16:09:55:WU00:FS00:0xa4:Done: 2286151 -> 2190691 (compressed to 95.8 percent)
01:15:11:WU01:FS00:0xa4:Done: 2287000 -> 2191591 (compressed to 95.8 percent)
10:05:15:WU00:FS00:0xa4:Done: 2287879 -> 2192193 (compressed to 95.8 percent)
19:30:40:WU01:FS00:0xa4:Done: 2290604 -> 2194658 (compressed to 95.8 percent)
02:56:03:WU00:FS00:0xa4:Done: 1880998 -> 1812050 (compressed to 96.3 percent)
12:09:35:WU01:FS00:0xa4:Done: 2286922 -> 2191413 (compressed to 95.8 percent)
20:58:08:WU00:FS00:0xa4:Done: 1642022 -> 1580169 (compressed to 96.2 percent)
06:58:28:WU01:FS00:0xa4:Done: 3360520 -> 3205311 (compressed to 95.3 percent)
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
Valkyrie
Post by Valkyrie »
Currently running 7020(3,130,84) and it has 10 million steps but is doing around 4.5 min per frame. When it finishes I'll see what it compresses like. The 7647 that just completed did not seem to compress very much.
06:35:21:WU01:FS00:0xa4:Project: 7647 (Run 222, Clone 1, Gen 58)
06:35:21:WU01:FS00:0xa4:Assembly optimizations on if available.
06:35:21:WU01:FS00:0xa4:Entering M.D.
06:35:26:WU01:FS00:0xa4:Using Gromacs checkpoints
06:35:26:WU01:FS00:0xa4:Mapping NT from 4 to 4
06:35:27:WU01:FS00:0xa4:Resuming from checkpoint
06:35:27:WU01:FS00:0xa4:Verified 01/wudata_01.log
06:35:27:WU01:FS00:0xa4:Verified 01/wudata_01.trr
06:35:27:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
06:35:27:WU01:FS00:0xa4:Verified 01/wudata_01.edr
06:35:27:WU01:FS00:0xa4:Completed 2488100 out of 2500000 steps  (99%)
06:35:52:Server connection id=106 ended
06:53:58:WU01:FS00:0xa4:Completed 2500000 out of 2500000 steps  (100%)
06:53:59:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
06:54:09:WU01:FS00:0xa4:
06:54:09:WU01:FS00:0xa4:Finished Work Unit:
06:54:09:WU01:FS00:0xa4:- Reading up to 13363584 from "01/wudata_01.trr": Read 13363584
06:54:09:WU01:FS00:0xa4:trr file hash check passed.
06:54:09:WU01:FS00:0xa4:- Reading up to 1982264 from "01/wudata_01.xtc": Read 1982264
06:54:09:WU01:FS00:0xa4:xtc file hash check passed.
06:54:09:WU01:FS00:0xa4:edr file hash check passed.
06:54:09:WU01:FS00:0xa4:logfile size: 59554
06:54:09:WU01:FS00:0xa4:Leaving Run
06:54:09:WU01:FS00:0xa4:- Writing 15420566 bytes of core data to disk...
06:54:13:WU01:FS00:0xa4:Done: 15420054 -> 14680823 (compressed to 95.2 percent)
06:54:13:WU01:FS00:0xa4:  ... Done.
06:54:14:WU01:FS00:0xa4:- Shutting down core
06:54:14:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
06:54:15:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:54:15:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:7647 run:222 clone:1 gen:58 core:0xa4 unit:0x00000050664f2dcd4fa7feaf1ce38064
06:54:15:WU01:FS00:Uploading 14.00MiB to 171.64.65.101
06:54:15:WU00:FS00:Starting
06:54:15:WU01:FS00:Connecting to 171.64.65.101:8080
06:54:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Dawn/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2796 -checkpoint 15 -np 4
06:54:15:WU00:FS00:Started FahCore on PID 7020
06:54:15:WU00:FS00:Core PID:5284
06:54:15:WU00:FS00:FahCore 0xa4 started
06:54:15:WU00:FS00:0xa4:
06:54:15:WU00:FS00:0xa4:*------------------------------*
06:54:15:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
06:54:15:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
06:54:15:WU00:FS00:0xa4:Preparing to commence simulation
06:54:15:WU00:FS00:0xa4:- Looking at optimizations...
06:54:15:WU00:FS00:0xa4:- Created dyn
06:54:15:WU00:FS00:0xa4:- Files status OK
06:54:15:WU00:FS00:0xa4:- Expanded 49963 -> 197212 (decompressed 394.7 percent)
06:54:15:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=49963 data_size=197212, decompressed_data_size=197212 diff=0
06:54:15:WU00:FS00:0xa4:- Digital signature verified
06:54:15:WU00:FS00:0xa4:Project: 7020 (Run 3, Clone 130, Gen 84)
06:54:15:WU00:FS00:0xa4:Assembly optimizations on if available.
06:54:15:WU00:FS00:0xa4:Entering M.D.
06:54:21:WU01:FS00:Upload 4.46%
06:54:21:WU00:FS00:0xa4:Mapping NT from 4 to 4
06:54:21:WU00:FS00:0xa4:Completed 0 out of 10000000 steps  (0%)
06:54:27:WU01:FS00:Upload 8.93%
06:54:33:WU01:FS00:Upload 13.39%
06:54:39:WU01:FS00:Upload 17.86%
06:54:45:WU01:FS00:Upload 22.32%
06:54:51:WU01:FS00:Upload 26.78%
06:54:57:WU01:FS00:Upload 31.25%
06:55:03:WU01:FS00:Upload 35.71%
06:55:09:WU01:FS00:Upload 40.18%
06:55:15:WU01:FS00:Upload 44.64%
06:55:21:WU01:FS00:Upload 49.10%
06:55:27:WU01:FS00:Upload 53.57%
06:55:33:WU01:FS00:Upload 58.03%
06:55:39:WU01:FS00:Upload 62.49%
06:55:45:WU01:FS00:Upload 66.96%
06:55:51:WU01:FS00:Upload 71.42%
06:55:57:WU01:FS00:Upload 75.89%
06:56:03:WU01:FS00:Upload 80.35%
06:56:09:WU01:FS00:Upload 84.81%
06:56:15:WU01:FS00:Upload 89.72%
06:56:21:WU01:FS00:Upload 94.19%
06:56:27:WU01:FS00:Upload 98.65%
06:56:31:WU01:FS00:Upload complete
06:56:31:WU01:FS00:Server responded WORK_ACK (400)
06:56:31:WU01:FS00:Final credit estimate, 10490.00 points
06:56:31:WU01:FS00:Cleaning up
06:58:42:WU00:FS00:0xa4:Completed 100000 out of 10000000 steps  (1%)
07:03:02:WU00:FS00:0xa4:Completed 200000 out of 10000000 steps  (2%)
07:07:20:WU00:FS00:0xa4:Completed 300000 out of 10000000 steps  (3%)
07:11:39:WU00:FS00:0xa4:Completed 400000 out of 10000000 steps  (4%)
07:15:57:WU00:FS00:0xa4:Completed 500000 out of 10000000 steps  (5%)
07:20:15:WU00:FS00:0xa4:Completed 600000 out of 10000000 steps  (6%)
07:24:33:WU00:FS00:0xa4:Completed 700000 out of 10000000 steps  (7%)
07:28:51:WU00:FS00:0xa4:Completed 800000 out of 10000000 steps  (8%)
07:33:10:WU00:FS00:0xa4:Completed 900000 out of 10000000 steps  (9%)
07:37:28:WU00:FS00:0xa4:Completed 1000000 out of 10000000 steps  (10%)
07:41:47:WU00:FS00:0xa4:Completed 1100000 out of 10000000 steps  (11%)
07:46:05:WU00:FS00:0xa4:Completed 1200000 out of 10000000 steps  (12%)
07:50:23:WU00:FS00:0xa4:Completed 1300000 out of 10000000 steps  (13%)
07:54:40:WU00:FS00:0xa4:Completed 1400000 out of 10000000 steps  (14%)
07:58:58:WU00:FS00:0xa4:Completed 1500000 out of 10000000 steps  (15%)
08:03:18:WU00:FS00:0xa4:Completed 1600000 out of 10000000 steps  (16%)
08:07:35:WU00:FS00:0xa4:Completed 1700000 out of 10000000 steps  (17%)
08:11:54:WU00:FS00:0xa4:Completed 1800000 out of 10000000 steps  (18%)
08:16:12:WU00:FS00:0xa4:Completed 1900000 out of 10000000 steps  (19%)
08:20:31:WU00:FS00:0xa4:Completed 2000000 out of 10000000 steps  (20%)
08:24:49:WU00:FS00:0xa4:Completed 2100000 out of 10000000 steps  (21%)
08:29:07:WU00:FS00:0xa4:Completed 2200000 out of 10000000 steps  (22%)
08:33:26:WU00:FS00:0xa4:Completed 2300000 out of 10000000 steps  (23%)
08:37:43:WU00:FS00:0xa4:Completed 2400000 out of 10000000 steps  (24%)
08:43:34:WU00:FS00:0xa4:Completed 2500000 out of 10000000 steps  (25%)
08:47:53:WU00:FS00:0xa4:Completed 2600000 out of 10000000 steps  (26%)
08:52:12:WU00:FS00:0xa4:Completed 2700000 out of 10000000 steps  (27%)
08:56:29:WU00:FS00:0xa4:Completed 2800000 out of 10000000 steps  (28%)
09:00:50:WU00:FS00:0xa4:Completed 2900000 out of 10000000 steps  (29%)
09:05:09:WU00:FS00:0xa4:Completed 3000000 out of 10000000 steps  (30%)
09:09:27:WU00:FS00:0xa4:Completed 3100000 out of 10000000 steps  (31%)
09:13:47:WU00:FS00:0xa4:Completed 3200000 out of 10000000 steps  (32%)
09:18:07:WU00:FS00:0xa4:Completed 3300000 out of 10000000 steps  (33%)
09:21:05:Server connection id=107 on 0.0.0.0:36330 from 127.0.0.1
09:21:42:Server connection id=107 ended
09:22:35:WU00:FS00:0xa4:Completed 3400000 out of 10000000 steps  (34%)
09:26:55:WU00:FS00:0xa4:Completed 3500000 out of 10000000 steps  (35%)
09:31:14:WU00:FS00:0xa4:Completed 3600000 out of 10000000 steps  (36%)
09:35:32:WU00:FS00:0xa4:Completed 3700000 out of 10000000 steps  (37%)
09:39:51:WU00:FS00:0xa4:Completed 3800000 out of 10000000 steps  (38%)
09:44:10:WU00:FS00:0xa4:Completed 3900000 out of 10000000 steps  (39%)
09:48:30:WU00:FS00:0xa4:Completed 4000000 out of 10000000 steps  (40%)
09:52:49:WU00:FS00:0xa4:Completed 4100000 out of 10000000 steps  (41%)
09:57:07:WU00:FS00:0xa4:Completed 4200000 out of 10000000 steps  (42%)
10:01:27:WU00:FS00:0xa4:Completed 4300000 out of 10000000 steps  (43%)
10:05:45:WU00:FS00:0xa4:Completed 4400000 out of 10000000 steps  (44%)
10:10:04:WU00:FS00:0xa4:Completed 4500000 out of 10000000 steps  (45%)
10:14:24:WU00:FS00:0xa4:Completed 4600000 out of 10000000 steps  (46%)
10:18:43:WU00:FS00:0xa4:Completed 4700000 out of 10000000 steps  (47%)
10:23:04:WU00:FS00:0xa4:Completed 4800000 out of 10000000 steps  (48%)
10:27:23:WU00:FS00:0xa4:Completed 4900000 out of 10000000 steps  (49%)
10:31:42:WU00:FS00:0xa4:Completed 5000000 out of 10000000 steps  (50%)
10:36:00:WU00:FS00:0xa4:Completed 5100000 out of 10000000 steps  (51%)
10:36:13:Server connection id=108 on 0.0.0.0:36330 from 127.0.0.1
10:36:23:Server connection id=108 ended
10:40:35:WU00:FS00:0xa4:Completed 5200000 out of 10000000 steps  (52%)
10:45:05:WU00:FS00:0xa4:Completed 5300000 out of 10000000 steps  (53%)
10:45:28:Server connection id=109 on 0.0.0.0:36330 from 127.0.0.1
10:49:34:WU00:FS00:0xa4:Completed 5400000 out of 10000000 steps  (54%)
10:54:06:WU00:FS00:0xa4:Completed 5500000 out of 10000000 steps  (55%)
Valkyrie
Post by Valkyrie »
Hi folks
Completed that fine running wu and it compressed to 65.5%. There is something about these slow running 70XX wu's. Hopefully someone from PG can enlighten us.
14:01:42:WU00:FS00:0xa4:Completed 9300000 out of 10000000 steps  (93%)
14:06:00:WU00:FS00:0xa4:Completed 9400000 out of 10000000 steps  (94%)
14:10:17:WU00:FS00:0xa4:Completed 9500000 out of 10000000 steps  (95%)
14:14:36:WU00:FS00:0xa4:Completed 9600000 out of 10000000 steps  (96%)
14:18:54:WU00:FS00:0xa4:Completed 9700000 out of 10000000 steps  (97%)
14:23:13:WU00:FS00:0xa4:Completed 9800000 out of 10000000 steps  (98%)
14:27:31:WU00:FS00:0xa4:Completed 9900000 out of 10000000 steps  (99%)
14:27:32:WU01:FS00:Connecting to assign3.stanford.edu:8080
14:27:32:WU01:FS00:News: Welcome to Folding@Home
14:27:32:WU01:FS00:Assigned to work server 129.74.85.15
14:27:32:WU01:FS00:Requesting new work unit for slot 00: RUNNING smp:4 from 129.74.85.15
14:27:32:WU01:FS00:Connecting to 129.74.85.15:8080
14:27:33:WU01:FS00:Downloading 54.37KiB
14:27:33:WU01:FS00:Download complete
14:27:33:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:10084 run:1 clone:37 gen:66 core:0xa4 unit:0x000000a10001329c4ddbf42e288108f2
14:27:33:WU01:FS00:Downloading project 10084 description
14:27:33:WU01:FS00:Connecting to fah-web.stanford.edu:80
14:27:34:WU01:FS00:Project 10084 description downloaded successfully
14:31:50:WU00:FS00:0xa4:Completed 10000000 out of 10000000 steps  (100%)
14:31:50:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:32:00:WU00:FS00:0xa4:
14:32:00:WU00:FS00:0xa4:Finished Work Unit:
14:32:00:WU00:FS00:0xa4:- Reading up to 2033736 from "00/wudata_01.trr": Read 2033736
14:32:00:WU00:FS00:0xa4:trr file hash check passed.
14:32:00:WU00:FS00:0xa4:- Reading up to 211448 from "00/wudata_01.xtc": Read 211448
14:32:00:WU00:FS00:0xa4:xtc file hash check passed.
14:32:00:WU00:FS00:0xa4:edr file hash check passed.
14:32:00:WU00:FS00:0xa4:logfile size: 79179
14:32:00:WU00:FS00:0xa4:Leaving Run
14:32:04:WU00:FS00:0xa4:- Writing 2348835 bytes of core data to disk...
14:32:04:WU00:FS00:0xa4:Done: 2348323 -> 1540437 (compressed to 65.5 percent)
14:32:04:WU00:FS00:0xa4:  ... Done.
14:32:04:WU00:FS00:0xa4:- Shutting down core
14:32:04:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:32:05:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:32:05:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:7020 run:3 clone:130 gen:84 core:0xa4 unit:0x000000d80001329c4dfba5a7e3e57811
14:32:05:WU00:FS00:Uploading 1.47MiB to 129.74.85.15
14:32:05:WU01:FS00:Starting
14:32:05:WU00:FS00:Connecting to 129.74.85.15:8080
14:32:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Dawn/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2796 -checkpoint 15 -np 4
14:32:05:WU01:FS00:Started FahCore on PID 6160
14:32:05:WU01:FS00:Core PID:6540
14:32:05:WU01:FS00:FahCore 0xa4 started
14:32:05:WU01:FS00:0xa4:
14:32:05:WU01:FS00:0xa4:*------------------------------*
14:32:05:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
14:32:05:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:32:05:WU01:FS00:0xa4:Preparing to commence simulation
14:32:05:WU01:FS00:0xa4:- Looking at optimizations...
14:32:05:WU01:FS00:0xa4:- Created dyn
14:32:05:WU01:FS00:0xa4:- Files status OK
14:32:05:WU01:FS00:0xa4:- Expanded 55162 -> 203980 (decompressed 369.7 percent)
14:32:05:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=55162 data_size=203980, decompressed_data_size=203980 diff=0
14:32:05:WU01:FS00:0xa4:- Digital signature verified
14:32:05:WU01:FS00:0xa4:Project: 10084 (Run 1, Clone 37, Gen 66)
14:32:05:WU01:FS00:0xa4:Assembly optimizations on if available.
14:32:05:WU01:FS00:0xa4:Entering M.D.
14:32:11:WU00:FS00:Upload 42.53%
14:32:11:WU01:FS00:0xa4:Mapping NT from 4 to 4
14:32:11:WU01:FS00:0xa4:Completed 0 out of 10000000 steps  (0%)
14:32:17:WU00:FS00:Upload 85.06%
14:32:19:WU00:FS00:Upload complete
14:32:19:WU00:FS00:Server responded WORK_ACK (400)
14:32:19:WU00:FS00:Final credit estimate, 2912.00 points
14:32:20:WU00:FS00:Cleaning up
14:36:40:WU01:FS00:0xa4:Completed 100000 out of 10000000 steps  (1%)
14:41:09:WU01:FS00:0xa4:Completed 200000 out of 10000000 steps  (2%)
14:45:38:WU01:FS00:0xa4:Completed 300000 out of 10000000 steps  (3%)
14:48:30:Server connection id=112 on 0.0.0.0:36330 from 127.0.0.1
14:50:23:WU01:FS00:0xa4:Completed 400000 out of 10000000 steps  (4%)
chaosdsm
Hardware configuration: Current System folding on client 7.4.4 on GPU only
ASRock FM2A88X Extreme 6+ motherboard
AMD Athlon X4 860K CPU @ 4GHz
Watercooled EVGA GeForce GTX 970 FTW ACX 2.0 - typically folds @ 1454MHz Boost Core / 1502Mhz Memory
Windows 10 64bit
Samsung 850 EVO 500GB SSD - OS
2TB Western Digital SATA III HDD - storage
16GB (2x8GB) DDR3-1866 G.SKILL Ripjaws Z Series RAM
Corsair Air540 case
Antec EarthWatts 650 Watt PSU
Average folding temps on GPU ~60C (+/- 7C depending on WU being folded)
Post by chaosdsm »
viewtopic.php?f=19&t=22869 same project, same type of problem, different RCG. Fortunately, they seem to be few & far between. In the past 3 months I've had a total of 3 of them. For now, just have to live through them & report them... hopefully the programmers will eventually figure out what the problem is & fix it.
Folding rig: EVGA Z370 Classified K w/i7-8700 & Hyper 212 EVO - WIN7 PRO 64bit - EVGA 1660 Ti XC Gaming (soon to be water cooled) - Corsair Vengeance 16GB DDR4-2666 dual channel memory - Samsung 970 Pro 512GB M.2 SSD - EVGA SuperNova 850 Platinum PSU
