WU won't load/run 5766 6, 426, 10
schapman1978
Post by schapman1978 »
I've been running FAH for a couple weeks and have had no problems with WU loading or running. Now all of a sudden one won't run or load. It runs my CPU level ones but not my GPU ones.
WU 5766 (6, 426, 10)
I've restarted, powered down, paused, restarted, over more than 12 horus no luck. Any help, as I'm stuck at 50% production.
bollix47
Re: WU won't load/run 5766 6, 426, 10
Post by bollix47 »
Welcome to the folding support forum schapman1978.
There were problems with some servers last night and some work units were assigned to GPUs that they can't run. Feel free to delete the WU. If you're unsure how to do that you can copy and paste your log here and we can be more specific.
Basically, with the GPU slot paused, it involves clicking on Start>All Programs>FAHClient>Data Directory>work and deleting the two digit folder that corresponds with the WUxx for your GPU in your log if you're using version 7 of the client.
schapman1978
I now see how to delete the WU's when they're hung. It resolved the issue and my computer is folding again like before. Thanks!
schapman1978 wrote:I now see how to delete the WU's when they're hung. It resolved the issue and my computer is folding again like before. Thanks!
We recommend NOT deleting WUs if there is any alternative. When that's the last possible choice, then you have to use it, especially when we know there's a plan in place to fix the problem that got you into that situation.
