128.143.231.201 - Bigadv transfer and assignment failed
Nicolas_orleans
Post by Nicolas_orleans »
Dear all,
I am experiencing issues with Bigadv server 128.143.231.201 that has been previously working 24/7 for the last 35 days (23 successful 8101/8102).
This has last during last 6 hours of unsuccessful download attempts, below the last 2 attempts (focus on key failure). After the last failure, assignement sever 4 rolled me out another SMP server though I am using -bigadv.
10:18:23:WU00:FS00:Download 91.59%
[10:18:23:ERROR:WU00:FS00:Exception: Transfer failed
10:33:06:WU00:FS00:Download 17.04%
10:33:06:ERROR:WU00:FS00:Exception: Transfer failed
10:33:06:WU00:FS00:Connecting to assign3.stanford.edu:8080
10:33:12:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 23
I would like to highlight 10002: Received short response, expected 272 bytes, got 23, that in my experience is a symptom of server malfunction.
Full log
*********************** Log Started 2012-11-10T08:59:31Z ***********************
08:59:31:************************* Folding@home Client *************************
08:59:31:    Website: http://folding.stanford.edu/
08:59:31:  Copyright: (c) 2009-2012 Stanford University
08:59:31:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:59:31:       Args: --child --lifeline 1342 /etc/fahclient/config.xml --run-as
08:59:31:             fahclient --pid-file=/var/run/fahclient.pid --daemon
08:59:31:     Config: /etc/fahclient/config.xml
08:59:31:******************************** Build ********************************
08:59:31:    Version: 7.2.9
08:59:31:       Date: Oct 3 2012
08:59:31:       Time: 10:34:06
08:59:31:    SVN Rev: 3578
08:59:31:     Branch: fah/trunk/client
08:59:31:   Compiler: GNU 4.4.7
08:59:31:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
08:59:31:             -fno-unsafe-math-optimizations -msse2
08:59:31:   Platform: linux2 3.2.0-1-amd64
08:59:31:       Bits: 64
08:59:31:       Mode: Release
08:59:31:******************************* System ********************************
08:59:31:        CPU:
08:59:31:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 2
08:59:31:       CPUs: 32
08:59:31:     Memory: 31.41GiB
08:59:31:Free Memory: 30.69GiB
08:59:31:    Threads: POSIX_THREADS
08:59:31: On Battery: false
08:59:31: UTC offset: 8
08:59:31:        PID: 1426
08:59:31:        CWD: /var/lib/fahclient
08:59:31:         OS: Linux 3.2.0-32-generic x86_64
08:59:31:    OS Arch: AMD64
08:59:31:       GPUs: 1
08:59:31:      GPU 0: NVIDIA:2 GF108 [GeForce GT 430]
08:59:31:       CUDA: 2.1
08:59:31:CUDA Driver: 4020
08:59:31:***********************************************************************
08:59:31:Started thread 1 on PID 1426
08:59:31:<config>
08:59:31:  <!-- Client Control -->
08:59:31:  <cycle-rate v='4'/>
08:59:31:  <cycles v='-1'/>
08:59:31:  <data-directory v='.'/>
08:59:31:  <disable-project-lookup v='false'/>
08:59:31:  <exec-directory v='/usr/bin'/>
08:59:31:  <exit-when-done v='false'/>
08:59:31:  <threads v='4'/>
08:59:31:
08:59:31:  <!-- Configuration -->
08:59:31:  <config-rotate v='true'/>
08:59:31:  <config-rotate-dir v='configs'/>
08:59:31:  <config-rotate-max v='16'/>
08:59:31:
08:59:31:  <!-- Debugging -->
08:59:31:  <assignment-servers>
08:59:31:    assign3.stanford.edu:8080 assign4.stanford.edu:80
08:59:31:  </assignment-servers>
08:59:31:  <capture-directory v='capture'/>
08:59:31:  <capture-sockets v='false'/>
08:59:31:  <debug-sockets v='false'/>
08:59:31:  <exception-locations v='true'/>
08:59:31:  <gpu-assignment-servers>
08:59:31:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
08:59:31:  </gpu-assignment-servers>
08:59:31:  <stack-traces v='false'/>
08:59:31:
08:59:31:  <!-- Error Handling -->
08:59:31:  <max-slot-errors v='5'/>
08:59:31:  <max-unit-errors v='5'/>
08:59:31:
08:59:31:  <!-- FahCore Control -->
08:59:31:  <checkpoint v='15'/>
08:59:31:  <core-dir v='cores'/>
08:59:31:  <core-priority v='idle'/>
08:59:31:  <cpu-affinity v='false'/>
08:59:31:  <cpu-usage v='100'/>
08:59:31:  <no-assembly v='false'/>
08:59:31:
08:59:31:  <!-- Folding Slot Configuration -->
08:59:31:  <cause-pref v='ANY'/>
08:59:31:  <client-subtype v='LINUX'/>
08:59:31:  <client-type v='normal'/>
08:59:31:  <cpu-species v='X86_PENTIUM_II'/>
08:59:31:  <cpu-type v='AMD64'/>
08:59:31:  <cpus v='-1'/>
08:59:31:  <cuda-index v='0'/>
08:59:31:  <gpu v='false'/>
08:59:31:  <gpu-usage v='100'/>
08:59:31:  <max-packet-size v='normal'/>
08:59:31:  <opencl-index v='0'/>
08:59:31:  <os-species v='UNKNOWN'/>
08:59:31:  <os-type v='LINUX'/>
08:59:31:  <project-key v='0'/>
08:59:31:  <smp v='true'/>
08:59:31:
08:59:31:  <!-- Logging -->
08:59:31:  <log v='log.txt'/>
08:59:31:  <log-color v='true'/>
08:59:31:  <log-crlf v='false'/>
08:59:31:  <log-date v='false'/>
08:59:31:  <log-date-periodically v='21600'/>
08:59:31:  <log-debug v='true'/>
08:59:31:  <log-domain v='false'/>
08:59:31:  <log-header v='true'/>
08:59:31:  <log-level v='true'/>
08:59:31:  <log-no-info-header v='true'/>
08:59:31:  <log-redirect v='false'/>
08:59:31:  <log-rotate v='true'/>
08:59:31:  <log-rotate-dir v='logs'/>
08:59:31:  <log-rotate-max v='16'/>
08:59:31:  <log-short-level v='false'/>
08:59:31:  <log-simple-domains v='true'/>
08:59:31:  <log-thread-id v='false'/>
08:59:31:  <log-thread-prefix v='true'/>
08:59:31:  <log-time v='true'/>
08:59:31:  <log-to-screen v='true'/>
08:59:31:  <log-truncate v='false'/>
08:59:31:  <verbosity v='5'/>
08:59:31:
08:59:31:  <!-- Network -->
08:59:31:  <proxy v=':8080'/>
08:59:31:  <proxy-enable v='false'/>
08:59:31:  <proxy-pass v=''/>
08:59:31:  <proxy-user v=''/>
08:59:31:
08:59:31:  <!-- Process Control -->
08:59:31:  <child v='true'/>
08:59:31:  <daemon v='true'/>
08:59:31:  <pid v='false'/>
08:59:31:  <pid-file v='/var/run/fahclient.pid'/>
08:59:31:  <respawn v='false'/>
08:59:31:  <service v='false'/>
08:59:31:
08:59:31:  <!-- Remote Command Server -->
08:59:31:  <command-address v='0.0.0.0'/>
08:59:31:  <command-allow v='127.0.0.1'/>
08:59:31:  <command-allow-no-pass v='127.0.0.1'/>
08:59:31:  <command-deny v='0.0.0.0/0'/>
08:59:31:  <command-deny-no-pass v='0.0.0.0/0'/>
08:59:31:  <command-port v='36330'/>
08:59:31:
08:59:31:  <!-- Slot Control -->
08:59:31:  <max-shutdown-wait v='60'/>
08:59:31:  <pause-on-battery v='false'/>
08:59:31:  <pause-on-start v='false'/>
08:59:31:
08:59:31:  <!-- User Information -->
08:59:31:  <machine-id v='0'/>
08:59:31:  <passkey v='********************************'/>
08:59:31:  <team v='33'/>
08:59:31:  <user v='Nicolas_orleans'/>
08:59:31:
08:59:31:  <!-- Work Unit Control -->
08:59:31:  <dump-after-deadline v='true'/>
08:59:31:  <max-queue v='16'/>
08:59:31:  <max-units v='0'/>
08:59:31:  <next-unit-percentage v='99'/>
08:59:31:
08:59:31:  <!-- Folding Slots -->
08:59:31:  <slot id='0' type='SMP'>
08:59:31:    <client-type v='bigadv'/>
08:59:31:    <max-packet-size v='big'/>
08:59:31:  </slot>
08:59:31:</config>
08:59:31:Switching to user fahclient
08:59:31:Trying to access database...
08:59:31:Successfully acquired database lock
08:59:31:Enabled folding slot 00: READY smp:32
08:59:31:Started thread 4 on PID 1426
08:59:31:Started thread 7 on PID 1426
08:59:31:Started thread 5 on PID 1426
08:59:31:Started thread 6 on PID 1426
08:59:31:Started thread 3 on PID 1426
09:00:10:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
09:00:10:Started thread 8 on PID 1426
09:00:32:WU00:FS00:Connecting to assign3.stanford.edu:8080
09:00:34:WU00:FS00:News: Welcome to Folding@Home
09:00:34:WU00:FS00:Assigned to work server 128.143.231.201
09:00:34:WU00:FS00:Requesting new work unit for slot 00: READY smp:32 from 128.143.231.201
09:00:34:WU00:FS00:Connecting to 128.143.231.201:8080
09:00:42:WU00:FS00:Downloading 28.90MiB
09:00:57:WU00:FS00:Download 0.22%
09:01:31:WU00:FS00:Download 0.43%
09:01:39:WU00:FS00:Download 0.65%
09:01:51:WU00:FS00:Download 0.86%
09:02:02:WU00:FS00:Download 1.08%
09:02:17:WU00:FS00:Download 1.51%
09:02:24:WU00:FS00:Download 1.73%
09:02:34:WU00:FS00:Download 2.38%
09:02:43:WU00:FS00:Download 2.59%
09:02:53:WU00:FS00:Download 3.03%
09:03:05:WU00:FS00:Download 3.46%
09:03:12:WU00:FS00:Download 3.68%
09:03:18:WU00:FS00:Download 3.89%
09:03:34:WU00:FS00:Download 4.11%
09:03:45:WU00:FS00:Download 4.54%
09:04:02:WU00:FS00:Download 4.76%
09:04:10:WU00:FS00:Download 4.97%
09:04:20:WU00:FS00:Download 5.19%
09:04:26:WU00:FS00:Download 5.41%
09:04:36:WU00:FS00:Download 5.62%
09:04:52:WU00:FS00:Download 5.84%
09:05:07:WU00:FS00:Download 6.05%
09:05:38:WU00:FS00:Download 6.27%
09:05:45:WU00:FS00:Download 6.49%
09:05:52:WU00:FS00:Download 6.70%
09:06:05:WU00:FS00:Download 6.92%
09:06:29:WU00:FS00:Download 7.14%
09:06:39:WU00:FS00:Download 7.35%
09:06:56:WU00:FS00:Download 7.57%
09:07:03:WU00:FS00:Download 7.78%
09:07:12:WU00:FS00:Download 8.00%
09:07:32:WU00:FS00:Download 8.22%
09:07:43:WU00:FS00:Download 8.43%
09:08:01:WU00:FS00:Download 8.65%
09:08:09:WU00:FS00:Download 8.87%
09:08:15:WU00:FS00:Download 9.08%
09:08:25:WU00:FS00:Download 9.30%
09:08:48:WU00:FS00:Download 9.51%
09:09:00:WU00:FS00:Download 9.73%
09:09:14:WU00:FS00:Download 9.95%
09:09:26:WU00:FS00:Download 10.16%
09:09:35:WU00:FS00:Download 10.38%
09:09:41:WU00:FS00:Download 10.81%
09:09:51:WU00:FS00:Download 11.03%
09:10:01:WU00:FS00:Download 11.24%
09:10:07:WU00:FS00:Download 11.46%
09:10:15:WU00:FS00:Download 11.68%
09:10:24:WU00:FS00:Download 11.89%
09:10:31:WU00:FS00:Download 12.11%
09:10:37:WU00:FS00:Download 12.33%
09:10:53:WU00:FS00:Download 12.54%
09:11:01:WU00:FS00:Download 12.76%
09:11:09:WU00:FS00:Download 12.97%
09:11:25:WU00:FS00:Download 13.19%
09:11:41:WU00:FS00:Download 13.62%
09:11:50:WU00:FS00:Download 13.84%
09:12:01:WU00:FS00:Download 14.06%
09:12:09:WU00:FS00:Download 14.27%
09:12:29:WU00:FS00:Download 14.70%
09:12:43:WU00:FS00:Download 14.92%
09:12:49:WU00:FS00:Download 15.14%
09:12:58:WU00:FS00:Download 15.57%
09:13:07:WU00:FS00:Download 15.78%
09:13:31:WU00:FS00:Download 16.00%
09:13:41:WU00:FS00:Download 16.22%
09:13:52:WU00:FS00:Download 16.43%
09:14:27:WU00:FS00:Download 16.65%
09:14:43:WU00:FS00:Download 17.08%
09:15:00:WU00:FS00:Download 17.30%
09:15:14:WU00:FS00:Download 17.51%
09:15:38:WU00:FS00:Download 17.73%
09:15:56:WU00:FS00:Download 17.95%
09:16:09:WU00:FS00:Download 18.16%
09:16:45:WU00:FS00:Download 18.38%
09:17:00:WU00:FS00:Download 18.81%
09:17:10:WU00:FS00:Download 19.03%
09:17:20:WU00:FS00:Download 19.24%
09:17:26:WU00:FS00:Download 19.46%
09:17:35:WU00:FS00:Download 19.89%
09:17:45:WU00:FS00:Download 20.11%
09:17:51:WU00:FS00:Download 20.33%
09:18:03:WU00:FS00:Download 20.54%
09:18:15:WU00:FS00:Download 20.76%
09:18:45:WU00:FS00:Download 21.19%
09:19:22:WU00:FS00:Download 21.41%
09:19:33:WU00:FS00:Download 21.62%
09:19:41:WU00:FS00:Download 21.84%
09:19:54:WU00:FS00:Download 22.06%
09:20:26:WU00:FS00:Download 22.27%
09:20:48:WU00:FS00:Download 22.49%
09:21:02:WU00:FS00:Download 22.70%
09:21:13:WU00:FS00:Download 22.92%
09:21:23:WU00:FS00:Download 23.14%
09:21:38:WU00:FS00:Download 23.35%
09:21:44:WU00:FS00:Download 23.57%
09:21:55:WU00:FS00:Download 23.79%
09:22:14:WU00:FS00:Download 24.00%
09:22:26:WU00:FS00:Download 24.22%
09:23:10:WU00:FS00:Download 24.43%
09:23:51:WU00:FS00:Download 24.65%
09:24:02:WU00:FS00:Download 24.87%
09:24:17:WU00:FS00:Download 25.08%
09:24:26:WU00:FS00:Download 25.30%
09:24:34:WU00:FS00:Download 25.52%
09:24:42:WU00:FS00:Download 25.73%
09:24:53:WU00:FS00:Download 25.95%
09:25:07:WU00:FS00:Download 26.16%
09:25:31:WU00:FS00:Download 26.38%
09:25:37:WU00:FS00:Download 26.60%
09:25:51:WU00:FS00:Download 26.81%
09:25:58:WU00:FS00:Download 27.25%
09:26:09:WU00:FS00:Download 27.89%
09:26:16:WU00:FS00:Download 28.11%
09:26:29:WU00:FS00:Download 28.33%
09:26:46:WU00:FS00:Download 28.54%
09:27:08:WU00:FS00:Download 28.76%
09:27:40:WU00:FS00:Download 28.98%
09:27:52:WU00:FS00:Download 29.19%
09:28:11:WU00:FS00:Download 29.62%
09:28:20:WU00:FS00:Download 29.84%
09:28:28:WU00:FS00:Download 30.06%
09:28:38:WU00:FS00:Download 30.27%
09:28:53:WU00:FS00:Download 30.49%
09:29:09:WU00:FS00:Download 30.71%
09:29:19:WU00:FS00:Download 30.92%
09:29:32:WU00:FS00:Download 31.14%
09:29:42:WU00:FS00:Download 31.57%
09:30:00:WU00:FS00:Download 32.00%
09:30:36:WU00:FS00:Download 32.22%
09:30:46:WU00:FS00:Download 32.43%
09:31:20:WU00:FS00:Download 32.65%
09:31:30:WU00:FS00:Download 32.87%
09:31:39:WU00:FS00:Download 33.08%
09:31:45:WU00:FS00:Download 33.30%
09:31:52:WU00:FS00:Download 33.73%
09:32:08:WU00:FS00:Download 33.95%
09:32:17:WU00:FS00:Download 34.16%
09:32:26:WU00:FS00:Download 34.38%
09:32:34:WU00:FS00:Download 34.60%
09:32:44:WU00:FS00:Download 34.81%
09:32:53:WU00:FS00:Download 35.03%
09:33:05:WU00:FS00:Download 35.25%
09:33:12:WU00:FS00:Download 35.46%
09:33:26:WU00:FS00:Download 35.89%
09:33:39:WU00:FS00:Download 36.11%
09:33:56:WU00:FS00:Download 36.33%
09:34:09:WU00:FS00:Download 36.54%
09:34:39:WU00:FS00:Download 36.76%
09:34:58:WU00:FS00:Download 36.98%
09:35:07:WU00:FS00:Download 37.19%
09:35:16:WU00:FS00:Download 37.41%
09:35:22:WU00:FS00:Download 37.62%
09:35:30:WU00:FS00:Download 37.84%
09:35:43:WU00:FS00:Download 38.27%
09:35:50:WU00:FS00:Download 38.92%
09:35:57:WU00:FS00:Download 39.35%
09:36:09:WU00:FS00:Download 39.79%
09:36:18:WU00:FS00:Download 40.22%
09:36:25:WU00:FS00:Download 40.44%
09:36:33:WU00:FS00:Download 40.65%
09:36:40:WU00:FS00:Download 40.87%
09:36:47:WU00:FS00:Download 41.30%
09:36:57:WU00:FS00:Download 41.73%
09:37:03:WU00:FS00:Download 42.17%
09:37:15:WU00:FS00:Download 42.60%
09:37:21:WU00:FS00:Download 43.03%
09:37:31:WU00:FS00:Download 43.25%
09:37:39:WU00:FS00:Download 43.46%
09:37:46:WU00:FS00:Download 43.90%
09:38:11:WU00:FS00:Download 44.11%
09:38:22:WU00:FS00:Download 44.33%
09:38:32:WU00:FS00:Download 44.54%
09:38:47:WU00:FS00:Download 44.76%
09:38:58:WU00:FS00:Download 44.98%
09:39:04:WU00:FS00:Download 45.19%
09:39:15:WU00:FS00:Download 45.41%
09:39:40:WU00:FS00:Download 45.63%
09:39:50:WU00:FS00:Download 45.84%
09:40:01:WU00:FS00:Download 46.06%
09:40:17:WU00:FS00:Download 46.27%
09:40:26:WU00:FS00:Download 46.49%
09:40:41:WU00:FS00:Download 46.92%
09:40:51:WU00:FS00:Download 47.14%
09:40:58:WU00:FS00:Download 47.35%
09:41:08:WU00:FS00:Download 47.57%
09:41:16:WU00:FS00:Download 47.79%
09:41:24:WU00:FS00:Download 48.00%
09:41:35:WU00:FS00:Download 48.22%
09:41:43:WU00:FS00:Download 48.44%
09:41:50:WU00:FS00:Download 48.65%
09:42:20:WU00:FS00:Download 48.87%
09:42:30:WU00:FS00:Download 49.08%
09:42:39:WU00:FS00:Download 49.30%
09:42:47:WU00:FS00:Download 49.52%
09:42:58:WU00:FS00:Download 49.95%
09:43:10:WU00:FS00:Download 50.17%
09:43:22:WU00:FS00:Download 50.38%
09:43:32:WU00:FS00:Download 50.60%
09:43:39:WU00:FS00:Download 50.81%
09:43:52:WU00:FS00:Download 51.25%
09:44:06:WU00:FS00:Download 51.46%
09:44:16:WU00:FS00:Download 51.68%
09:44:25:WU00:FS00:Download 52.11%
09:44:33:WU00:FS00:Download 52.33%
09:44:47:WU00:FS00:Download 52.54%
09:44:54:WU00:FS00:Download 52.76%
09:45:04:WU00:FS00:Download 52.98%
09:45:12:WU00:FS00:Download 53.41%
09:45:18:WU00:FS00:Download 53.63%
09:45:29:WU00:FS00:Download 54.06%
09:45:41:WU00:FS00:Download 54.49%
09:45:51:WU00:FS00:Download 54.71%
09:46:01:WU00:FS00:Download 54.92%
09:46:10:WU00:FS00:Download 55.14%
09:46:32:WU00:FS00:Download 55.36%
09:46:54:WU00:FS00:Download 55.57%
09:47:01:WU00:FS00:Download 55.79%
09:47:07:WU00:FS00:Download 56.00%
09:47:20:WU00:FS00:Download 56.22%
09:47:30:WU00:FS00:Download 56.65%
09:47:40:WU00:FS00:Download 56.87%
09:47:52:WU00:FS00:Download 57.09%
09:48:18:WU00:FS00:Download 57.30%
09:48:28:WU00:FS00:Download 57.52%
09:48:42:WU00:FS00:Download 57.73%
09:48:57:WU00:FS00:Download 57.95%
09:49:11:WU00:FS00:Download 58.17%
09:49:26:WU00:FS00:Download 58.38%
09:49:34:WU00:FS00:Download 58.60%
09:49:46:WU00:FS00:Download 58.82%
09:49:54:WU00:FS00:Download 59.03%
09:50:02:WU00:FS00:Download 59.25%
09:50:08:WU00:FS00:Download 59.46%
09:50:14:WU00:FS00:Download 60.11%
09:50:34:WU00:FS00:Download 60.55%
09:50:35:Server connection id=1 ended
09:50:48:WU00:FS00:Download 60.98%
09:51:14:WU00:FS00:Download 61.19%
09:51:30:WU00:FS00:Download 61.63%
09:51:39:WU00:FS00:Download 61.84%
09:51:47:WU00:FS00:Download 62.28%
09:52:05:WU00:FS00:Download 62.49%
09:52:21:WU00:FS00:Download 62.71%
09:52:29:WU00:FS00:Download 62.92%
09:52:37:WU00:FS00:Download 63.14%
09:52:43:WU00:FS00:Download 63.36%
09:52:49:WU00:FS00:Download 63.57%
09:52:55:WU00:FS00:Download 63.79%
09:53:05:WU00:FS00:Download 64.22%
09:53:24:WU00:FS00:Download 64.44%
09:53:30:WU00:FS00:Download 64.65%
09:53:37:WU00:FS00:Download 64.87%
09:53:46:WU00:FS00:Download 65.52%
09:53:52:WU00:FS00:Download 65.73%
09:54:03:WU00:FS00:Download 65.95%
09:54:13:WU00:FS00:Download 66.17%
09:54:36:WU00:FS00:Download 66.38%
09:54:43:WU00:FS00:Download 66.60%
09:54:53:WU00:FS00:Download 66.82%
09:55:04:WU00:FS00:Download 67.03%
09:55:18:WU00:FS00:Download 67.25%
09:55:32:WU00:FS00:Download 67.46%
09:55:43:WU00:FS00:Download 67.68%
09:55:55:WU00:FS00:Download 67.90%
09:56:07:WU00:FS00:Download 68.11%
09:56:14:WU00:FS00:Download 68.55%
09:56:21:WU00:FS00:Download 68.76%
09:56:31:WU00:FS00:Download 68.98%
09:56:40:WU00:FS00:Download 69.19%
09:57:28:WU00:FS00:Download 69.41%
09:57:38:WU00:FS00:Download 69.63%
09:57:54:WU00:FS00:Download 69.84%
09:58:01:WU00:FS00:Download 70.06%
09:58:10:WU00:FS00:Download 70.28%
09:58:16:WU00:FS00:Download 70.49%
09:58:25:WU00:FS00:Download 70.71%
09:58:31:WU00:FS00:Download 70.92%
09:58:38:WU00:FS00:Download 71.14%
09:58:50:WU00:FS00:Download 71.57%
09:59:02:WU00:FS00:Download 71.79%
09:59:15:WU00:FS00:Download 72.22%
09:59:23:WU00:FS00:Download 72.44%
09:59:32:WU00:FS00:Download 72.65%
09:59:42:WU00:FS00:Download 72.87%
09:59:59:WU00:FS00:Download 73.09%
10:00:17:WU00:FS00:Download 73.30%
10:00:33:WU00:FS00:Download 73.52%
10:00:44:WU00:FS00:Download 73.74%
10:00:55:WU00:FS00:Download 73.95%
10:01:06:WU00:FS00:Download 74.17%
10:01:14:WU00:FS00:Download 74.38%
10:01:36:WU00:FS00:Download 74.60%
10:01:53:WU00:FS00:Download 74.82%
10:02:08:WU00:FS00:Download 75.03%
10:02:32:WU00:FS00:Download 75.47%
10:02:59:WU00:FS00:Download 75.68%
10:03:15:WU00:FS00:Download 75.90%
10:03:21:WU00:FS00:Download 76.11%
10:03:42:WU00:FS00:Download 76.33%
10:03:57:WU00:FS00:Download 76.55%
10:04:20:WU00:FS00:Download 76.76%
10:04:43:WU00:FS00:Download 76.98%
10:04:54:WU00:FS00:Download 77.20%
10:05:07:WU00:FS00:Download 77.41%
10:05:19:WU00:FS00:Download 77.84%
10:05:31:WU00:FS00:Download 78.06%
10:05:37:WU00:FS00:Download 78.28%
10:05:43:WU00:FS00:Download 78.49%
10:05:56:WU00:FS00:Download 78.71%
10:06:19:WU00:FS00:Download 78.92%
10:06:28:WU00:FS00:Download 79.14%
10:06:40:WU00:FS00:Download 79.36%
10:06:51:WU00:FS00:Download 79.57%
10:07:10:WU00:FS00:Download 79.79%
10:07:28:WU00:FS00:Download 80.22%
10:07:36:WU00:FS00:Download 80.65%
10:07:49:WU00:FS00:Download 80.87%
10:07:59:WU00:FS00:Download 81.09%
10:08:09:WU00:FS00:Download 81.30%
10:08:30:WU00:FS00:Download 81.52%
10:08:40:WU00:FS00:Download 81.74%
10:09:25:WU00:FS00:Download 81.95%
10:10:03:WU00:FS00:Download 82.17%
10:10:11:WU00:FS00:Download 82.38%
10:10:17:WU00:FS00:Download 82.60%
10:10:37:WU00:FS00:Download 82.82%
10:10:49:WU00:FS00:Download 83.03%
10:10:56:WU00:FS00:Download 83.25%
10:11:06:WU00:FS00:Download 83.68%
10:11:21:WU00:FS00:Download 83.90%
10:11:30:WU00:FS00:Download 84.11%
10:11:42:WU00:FS00:Download 84.33%
10:11:51:WU00:FS00:Download 84.55%
10:12:00:WU00:FS00:Download 84.76%
10:12:11:WU00:FS00:Download 85.20%
10:12:21:WU00:FS00:Download 85.41%
10:12:30:WU00:FS00:Download 85.84%
10:12:36:WU00:FS00:Download 86.28%
10:12:45:WU00:FS00:Download 86.49%
10:12:51:WU00:FS00:Download 87.36%
10:12:57:WU00:FS00:Download 87.57%
10:13:13:WU00:FS00:Download 87.79%
10:13:24:WU00:FS00:Download 88.01%
10:13:33:WU00:FS00:Download 88.22%
10:13:44:WU00:FS00:Download 88.44%
10:13:56:WU00:FS00:Download 88.66%
10:14:03:WU00:FS00:Download 88.87%
10:14:19:WU00:FS00:Download 89.30%
10:14:32:WU00:FS00:Download 89.52%
10:14:46:WU00:FS00:Download 89.74%
10:14:59:WU00:FS00:Download 90.17%
10:15:08:WU00:FS00:Download 90.39%
10:15:17:WU00:FS00:Download 90.60%
10:15:31:WU00:FS00:Download 90.82%
10:15:38:WU00:FS00:Download 91.03%
10:16:54:WU00:FS00:Download 91.25%
10:18:16:WU00:FS00:Download 91.47%
10:18:23:WU00:FS00:Connecting to assign3.stanford.edu:8080
10:18:25:WU00:FS00:News: Welcome to Folding@Home
10:18:25:WU00:FS00:Assigned to work server 128.143.231.201
10:18:25:WU00:FS00:Requesting new work unit for slot 00: READY smp:32 from 128.143.231.201
10:18:25:WU00:FS00:Connecting to 128.143.231.201:8080
10:18:35:WU00:FS00:Downloading 28.90MiB
10:18:46:WU00:FS00:Download 0.43%
10:18:55:WU00:FS00:Download 0.65%
10:19:22:WU00:FS00:Download 0.87%
10:19:29:WU00:FS00:Download 1.08%
10:19:38:WU00:FS00:Download 1.51%
10:19:49:WU00:FS00:Download 1.73%
10:20:01:WU00:FS00:Download 1.95%
10:20:10:WU00:FS00:Download 2.16%
10:20:21:WU00:FS00:Download 2.38%
10:20:27:WU00:FS00:Download 2.60%
10:20:34:WU00:FS00:Download 2.81%
10:20:51:WU00:FS00:Download 3.24%
10:21:04:WU00:FS00:Download 3.68%
10:21:10:WU00:FS00:Download 3.89%
10:21:24:WU00:FS00:Download 4.11%
10:21:31:WU00:FS00:Download 4.33%
10:21:39:WU00:FS00:Download 4.54%
10:21:45:WU00:FS00:Download 4.76%
10:22:04:WU00:FS00:Download 4.97%
10:22:53:WU00:FS00:Download 5.19%
10:23:17:WU00:FS00:Download 5.41%
10:23:32:WU00:FS00:Download 5.62%
10:23:42:WU00:FS00:Download 5.84%
10:23:51:WU00:FS00:Download 6.06%
10:24:02:WU00:FS00:Download 6.27%
10:24:08:WU00:FS00:Download 6.49%
10:24:23:WU00:FS00:Download 6.70%
10:24:39:WU00:FS00:Download 6.92%
10:24:59:WU00:FS00:Download 7.14%
10:25:07:WU00:FS00:Download 7.35%
10:25:15:WU00:FS00:Download 7.57%
10:25:35:WU00:FS00:Download 8.00%
10:25:54:WU00:FS00:Download 8.22%
10:26:00:WU00:FS00:Download 8.44%
10:26:09:WU00:FS00:Download 8.87%
10:26:17:WU00:FS00:Download 9.30%
10:26:24:WU00:FS00:Download 9.95%
10:26:34:WU00:FS00:Download 10.17%
10:26:42:WU00:FS00:Download 10.38%
10:26:57:WU00:FS00:Download 10.60%
10:27:21:WU00:FS00:Download 10.81%
10:27:29:WU00:FS00:Download 11.03%
10:27:44:WU00:FS00:Download 11.46%
10:27:55:WU00:FS00:Download 11.68%
10:28:04:WU00:FS00:Download 11.90%
10:28:18:WU00:FS00:Download 12.11%
10:28:30:WU00:FS00:Download 12.33%
10:28:45:WU00:FS00:Download 12.54%
10:28:52:WU00:FS00:Download 12.76%
10:29:03:WU00:FS00:Download 12.98%
10:29:27:WU00:FS00:Download 13.41%
10:29:33:WU00:FS00:Download 13.63%
10:29:41:WU00:FS00:Download 13.84%
10:29:53:WU00:FS00:Download 14.06%
10:30:04:WU00:FS00:Download 14.27%
10:30:12:WU00:FS00:Download 14.49%
10:30:19:WU00:FS00:Download 14.71%
10:30:30:WU00:FS00:Download 14.92%
10:30:37:WU00:FS00:Download 15.36%
10:30:44:WU00:FS00:Download 15.57%
10:30:54:WU00:FS00:Download 15.79%
10:31:13:WU00:FS00:Download 16.01%
10:31:27:WU00:FS00:Download 16.22%
10:31:35:WU00:FS00:Download 16.44%
10:31:45:WU00:FS00:Download 16.65%
10:32:46:WU00:FS00:Download 16.87%
10:33:12:WU00:FS00:Connecting to assign4.stanford.edu:80
10:33:14:WU00:FS00:News: Welcome to Folding@Home
10:33:14:WU00:FS00:Assigned to work server 128.143.231.202
10:33:14:WU00:FS00:Requesting new work unit for slot 00: READY smp:32 from 128.143.231.202
10:33:14:WU00:FS00:Connecting to 128.143.231.202:8080
10:33:16:WU00:FS00:Downloading 3.63MiB
10:33:22:WU00:FS00:Download 6.88%
10:33:32:WU00:FS00:Download 10.32%
10:33:39:WU00:FS00:Download 13.77%
10:33:48:WU00:FS00:Download 15.49%
10:34:04:WU00:FS00:Download 17.21%
10:34:13:WU00:FS00:Download 18.93%
10:34:22:WU00:FS00:Download 20.65%
10:34:31:WU00:FS00:Download 24.09%
10:34:37:WU00:FS00:Download 25.81%
10:34:45:WU00:FS00:Download 27.53%
10:34:56:WU00:FS00:Download 29.25%
10:35:39:WU00:FS00:Download 30.97%
10:35:47:WU00:FS00:Download 32.70%
10:35:55:WU00:FS00:Download 36.14%
10:36:13:WU00:FS00:Download 37.86%
10:37:28:WU00:FS00:Download 39.58%
10:37:39:WU00:FS00:Download 43.02%
10:37:47:WU00:FS00:Download 44.74%
10:37:54:WU00:FS00:Download 46.46%
10:38:05:WU00:FS00:Download 49.90%
10:38:13:WU00:FS00:Download 53.35%
10:38:24:WU00:FS00:Download 56.79%
10:38:34:WU00:FS00:Download 60.23%
10:38:40:WU00:FS00:Download 61.95%
10:38:47:WU00:FS00:Download 63.67%
10:38:54:WU00:FS00:Download 65.39%
10:39:00:WU00:FS00:Download 67.11%
10:39:16:WU00:FS00:Download 70.55%
10:39:22:WU00:FS00:Download 72.27%
10:39:31:WU00:FS00:Download 74.00%
10:39:38:WU00:FS00:Download 75.72%
10:39:52:WU00:FS00:Download 77.44%
10:40:03:WU00:FS00:Download 79.16%
10:40:13:WU00:FS00:Download 80.88%
10:40:20:WU00:FS00:Download 86.04%
10:40:31:WU00:FS00:Download 89.48%
10:40:42:WU00:FS00:Download 91.20%
10:40:55:WU00:FS00:Download 92.92%
10:41:01:WU00:FS00:Download 94.65%
10:41:09:WU00:FS00:Download 96.37%
10:41:20:WU00:FS00:Download 99.81%
10:41:20:WU00:FS00:Download complete
10:41:20:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:6098 run:3 clone:64 gen:297 core:0xa3 unit:0x000001790a3b1e594e91ddaac0ee4cb1
10:41:20:WU00:FS00:Starting
10:41:20:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3 -dir 00 -suffix 01 -version 702 -lifeline 1426 -checkpoint 15 -np 32
10:41:20:WU00:FS00:Started FahCore on PID 3070
10:41:20:Started thread 9 on PID 1426
10:41:21:WU00:FS00:Core PID:3074
10:41:21:WU00:FS00:FahCore 0xa3 started
10:41:21:WU00:FS00:Downloading project 6098 description
10:41:21:WU00:FS00:Connecting to fah-web.stanford.edu:80
10:41:21:WU00:FS00:0xa3:
10:41:21:WU00:FS00:0xa3:*------------------------------*
10:41:21:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
10:41:21:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
10:41:21:WU00:FS00:0xa3:Preparing to commence simulation
10:41:21:WU00:FS00:0xa3:- Looking at optimizations...
10:41:21:WU00:FS00:0xa3:- Created dyn
10:41:21:WU00:FS00:0xa3:- Files status OK
10:41:21:WU00:FS00:0xa3:- Expanded 3807907 -> 4136808 (decompressed 108.6 percent)
10:41:21:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3807907 data_size=4136808, decompressed_data_size=4136808 diff=0
10:41:21:WU00:FS00:0xa3:- Digital signature verified
10:41:21:WU00:FS00:0xa3:Project: 6098 (Run 3, Clone 64, Gen 297)
10:41:21:WU00:FS00:0xa3:Assembly optimizations on if available.
10:41:21:WU00:FS00:0xa3:Entering M.D.
10:41:25:WU00:FS00:Project 6098 description downloaded successfully
10:41:27:WU00:FS00:0xa3:Mapping NT from 32 to 32
10:41:28:WU00:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
10:45:16:WU00:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
10:46:17:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
10:46:17:Started thread 10 on PID 1426
10:48:37:WU00:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
10:52:14:WU00:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
10:55:35:WU00:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
10:56:35:Server connection id=2 ended
MSI Z77A-GD55 - Core i5-3550 - EVGA GTX 980 Ti Hybrid @ 1366 MHz - Ubuntu 24.04 - 6.8 kernel
MSI MPG B550 - Ryzen 5 5600X - PNY RTX 4080 Super @ 2715 MHz - Ubuntu 24.04 - 6.8 kernel
P5-133XL
Machine #2:
Machine 3:
Re: 128.143.231.201 - Bigadv transfer and assignment failed
Post by P5-133XL »
You've got network issues: Your downloads are timing-out and thereby failing
It took 8 minutes to download a 3 MB WU once connected to a different server after timing out twice to the bigadv server. It is probably a network issue on his end or between him and Stanford. If it was on the Stanford end we would be seeing many more reports of problems.
Grandpa_01
Post by Grandpa_01 »
Possibly but at the same time it mirrors prior issues with Stanford servers and may be worth watching. :wink:
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
