Couple of questions
Couple of questions
1. Is there any way to limit how much CPU to allocate to the project? eg say I would rather it was limited to 80% rather than 100% could I do this?
2. I know it is "safe" to have my CPU running at 100% all the time but will it significantly reduce my computer's lifespan? I have a desktop with i5 3570K processor with Akasa Nero fan. I've been monitoring the temperatures and so far the max temp for either of the cores is 56C.
edit: If you want to know where I first heard of Folding@home, it was from the 2009 magazine "101 Computer Projects"
- Hardware configuration: Zaphod: i5-2500K@4.2GHz, 8GB DDR3-2133, GTX580@882/1765/2037
Trillian: i5-2500K@4.2GHz, 8GB DDR3-2133, GTX580@795/1590/2004
Beeblebrox: Conroe E6700@3.0GHz, 4x1GB Corsair Dominator PC8500 DDR2@900, Gigabyte GA-965P-DQ6v3.3, MSI N260GTX-T2D896-OC@621/1296/1080/1.125v (65nm-192core)
Hotblack: Wolfdale E7500@3.66, 2x2GB Crucial Ballistix PC8500 DDR2@1000, Gigabyte GA-965P-DQ6v3.3, MSI N260GTX-T2D896-OC@621/1296/1080/1.125v (65nm-192core) - Location: Pike's Peak
Re: Couple of questions
Yes, there's a way to limit CPU by percentage; it's a flag somewhere (sorry, can't tell you where, wiki perhaps). I've found that CPU folding is really unobtrusive (OS scheduler), even when gaming.
Technically, I suppose your CPU's lifespan can be reduced from, like, 50 years to 45 years but effectively speaking, no.
You have a K model at only 56C? Are you running stock speeds?
It's not overclocked. It's running at the stock speed of 3.4Ghz, and it has a premium thermal paste.
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
If you fold with 3 cores, you'd be using 75% of your CPU. You can change from the default smp:4 for your CPU to smp:3 by clicking Configure --> Slots --> Edit.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
Some client versions have an adjustment for CPU utilization but it doesn't work when you're running SMP -- only when you're running a uniprocessor client. Napoleon's recommendation to use less than the maximum number of CPUs is the only real option for SMP.
I did use the throttling option with SMP:4 and it did lower utilisation on all four cores per perfmon.
K-model CPUs OC easily at stock voltage 4.2GHz+.
What percentage did you set that would give you a total CPU utilization of 80% on a Quad?Rolo wrote:I did use the throttling option with SMP:4 and it did lower utilisation on all four cores per perfmon.
One more thing does doing this use up much bandwidth? Do you need to be connected to the internet continually or do you just need internet connection for the software to download a new project then when the project is finished so the results are uploaded from your computer?
FAH uses internet connection only to download new work and upload results, no continuous use.
Core options | cpu-usagebruce wrote:What percentage did you set that would give you a total CPU utilization of 80% on a Quad?Rolo wrote:I did use the throttling option with SMP:4 and it did lower utilisation on all four cores per perfmon.
cf. https://fah-web.stanford.edu/projects/F ... tUserGuide
This setting is global and affected GPU usage by injecting intervals (bounced between 0 and 100%).
I know what setting to use. Please confirm that you actually can achieve 80% total utilizaton by setting some unknown value for cpu-usage.
You can use cpu-usage as a global value if you choose, but you can set it in each slot, too but if you can't actually achieve a total of 80% then you have not answered the OP's question.
Mea culpa: it does only limit one core's utilisation and it only keeps the other cores from being pegged. Originally, I used 90% and it appeared to affect all cores since they were all hovering between 90 and 100% (with other background tasks running, of course).
I used 50% and it is quite clear that only one core is throttled, leaving the others bouncing in the high 90's; with no value specified, all cores remain flat at 100%.
