Gigabyte GTX 660 problem
Creedan
Post by Creedan »
Hi, I'm running the new 7.2.9 client and have up to date drivers but when I run the GPU slot it just sits at 0%. What am I missing here?
Thanks
bollix47
Re: Gigabyte GTX 660 problem
Post by bollix47 »
Welcome to the folding support forum Creedan.
Please copy/paste your log between code tags showing all three sections.
If you're unsure how to do that see: viewtopic.php?p=225958#p225958
Also, please see: viewtopic.php?f=83&t=22458&p=224392#p224392
Creedan
Post by Creedan »
01:27:29:Adding folding slot 00: READY gpu:0:"GK106 [GeForce GTX 660]"
01:27:29:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
01:27:30:Removing old file 'configs/config-20121020-172450.xml'
01:27:30:Saving configuration to config.xml
01:27:30:<config>
01:27:30: <!-- FahCore Control -->
01:27:30: <checkpoint v='10'/>
01:27:30: <cpu-affinity v='true'/>
01:27:30:
01:27:30: <!-- Folding Slot Configuration -->
01:27:30: <client-type v='advanced'/>
01:27:30:
01:27:30: <!-- Network -->
01:27:30: <proxy v=':8080'/>
01:27:30:
01:27:30: <!-- User Information -->
01:27:30: <passkey v='********************************'/>
01:27:30: <team v='44529'/>
01:27:30: <user v='Creedan'/>
01:27:30:
01:27:30: <!-- Folding Slots -->
01:27:30: <slot id='1' type='SMP'>
01:27:30: <cpus v='2'/>
01:27:30: </slot>
01:27:30: <slot id='0' type='GPU'/>
01:27:30:</config>
01:27:30:WU01:FS00:News: Welcome to Folding@Home
01:27:30:WU01:FS00:Assigned to work server 171.67.108.142
01:27:30:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"GK106 [GeForce GTX 660]" from 171.67.108.142
01:27:30:WU01:FS00:Connecting to 171.67.108.142:8080
01:27:30:WU01:FS00:Downloading 161.47KiB
01:27:31:WU01:FS00:Download complete
01:27:31:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8018 run:1235 clone:3 gen:0 core:0x15 unit:0x000000006953ee2e500f1f97f0745b02
01:27:31:WU01:FS00:Starting
01:27:31:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Darren/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVI ... ore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 4340 -checkpoint 10 -gpu 0
01:27:31:WU01:FS00:Started FahCore on PID 5876
01:27:31:WU01:FS00:Core PID:5908
01:27:31:WU01:FS00:FahCore 0x15 started
01:27:32:WU01:FS00:0x15:
01:27:32:WU01:FS00:0x15:*------------------------------*
01:27:32:WU01:FS00:0x15:Folding@Home GPU Core
01:27:32:WU01:FS00:0x15:Version 2.22 (Thu Dec 8 17:08:05 PST 2011)
01:27:32:WU01:FS00:0x15:Build host SimbiosNvdWin7
01:27:32:WU01:FS00:0x15:Board Type NVIDIA/CUDA
01:27:32:WU01:FS00:0x15:Core 15
01:27:32:WU01:FS00:0x15:Window's signal control handler registered.
01:27:32:WU01:FS00:0x15:Preparing to commence simulation
01:27:32:WU01:FS00:0x15:- Looking at optimizations...
01:27:32:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
01:27:32:WU01:FS00:0x15:- Created dyn
01:27:32:WU01:FS00:0x15:- Files status OK
01:27:32:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:27:32:WU01:FS00:0x15:- Expanded 164838 -> 660986 (decompressed 400.9 percent)
01:27:32:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=164838 data_size=660986, decompressed_data_size=660986 diff=0
01:27:32:WU01:FS00:0x15:- Digital signature verified
01:27:32:WU01:FS00:0x15:Project: 8018 (Run 1235, Clone 3, Gen 0)
01:27:32:WU01:FS00:0x15:Assembly optimizations on if available.
01:27:32:WU01:FS00:0x15:Entering M.D.
01:27:34:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr: 457096653 3395863122 3550737125 3078009279 4096111155
01:27:34:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
01:27:34:WU01:FS00:0x15:Working on GRowing Old MAkes el Chrono Sweat
01:27:34:WU01:FS00:0x15:Client config unavailable.
01:27:34:WU01:FS00:0x15:Starting GUI Server
Welcome to foldingforum.org, Creedan.
It's generally helpful if you post the first page of the log where your system is described (click "Refresh") or to add it to your User Control Panel Profile, but I didn't need it this time. Stanford is still in the process of updating the FahCore that's required by Kepler.
You'll need to do this manually since they didn't update your machine yet.
1) Shut down FAHClient.
2) Open the "data directory"
3) Delete the folder called "cores"
4) Restart FAH.
Creedan
Post by Creedan »
That did the trick. Thanks for the help.
