'No appropriate work server was available' (Solved)
KroontjesPen
Post by KroontjesPen »
For a while I received no new work.
Before I stopped and started my GPU client this what my log file gives.
[09:17:33] Completed 92%
[09:18:59] Completed 93%
[09:20:26] Completed 94%
[09:21:52] Completed 95%
[09:23:18] Completed 96%
[09:24:45] Completed 97%
[09:26:11] Completed 98%
[09:27:38] Completed 99%
[09:29:04] Completed 100%
[09:29:05] Successful run
[09:29:05] DynamicWrapper: Finished Work Unit: sleep=10000
[09:29:15] Reserved 76376 bytes for xtc file; Cosm status=0
[09:29:15] Allocated 76376 bytes for xtc file
[09:29:15] - Reading up to 76376 from "work/wudata_05.xtc": Read 76376
[09:29:15] Read 76376 bytes from xtc file; available packet space=786354088
[09:29:15] xtc file hash check passed.
[09:29:15] Reserved 15168 15168 786354088 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[09:29:15] Allocated 15168 bytes for arc file
[09:29:15] - Reading up to 15168 from "work/wudata_05.trr": Read 15168
[09:29:15] Read 15168 bytes from arc file; available packet space=786338920
[09:29:15] trr file hash check passed.
[09:29:15] Allocated 560 bytes for edr file
[09:29:15] Read bedfile
[09:29:15] edr file hash check passed.
[09:29:15] Allocated 12082 bytes for logfile
[09:29:15] Read logfile
[09:29:15] GuardedRun: success in DynamicWrapper
[09:29:15] GuardedRun: done
[09:29:15] Run: GuardedRun completed.
[09:29:16] + Opened results file
[09:29:16] - Writing 104698 bytes of core data to disk...
[09:29:16] Done: 104186 -> 96369 (compressed to 92.4 percent)
[09:29:16]   ... Done.
[09:29:16] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[09:29:16] Shutting down core
[09:29:16]
[09:29:16] Folding@home Core Shutdown: FINISHED_UNIT
[09:29:18] CoreStatus = 64 (100)
[09:29:18] Unit 5 finished with 97 percent of time to deadline remaining.
[09:29:18] Updated performance fraction: 0.981697
[09:29:18] Sending work to server
[09:29:18] Project: 5772 (Run 7, Clone 387, Gen 638)
[09:29:18] - Read packet limit of 540015616... Set to 524286976.
[09:29:18] + Attempting to send results [November 7 09:29:18 UTC]
[09:29:18] - Reading file work/wuresults_05.dat from core
[09:29:18]   (Read 96881 bytes from disk)
[09:29:18] Connecting to http://171.67.108.11:8080/
[09:29:39] - Couldn't send HTTP request to server
[09:29:39] + Could not connect to Work Server (results)
[09:29:39]     (171.67.108.11:8080)
[09:29:39] + Retrying using alternative port
[09:29:39] Connecting to http://171.67.108.11:80/
[09:30:00] - Couldn't send HTTP request to server
[09:30:00] + Could not connect to Work Server (results)
[09:30:00]     (171.67.108.11:80)
[09:30:00] - Error: Could not transmit unit 05 (completed November 7) to work server.
[09:30:00] - 1 failed uploads of this unit.
[09:30:00]   Keeping unit 05 in queue.
[09:30:00] Trying to send all finished work units
[09:30:00] Project: 5772 (Run 7, Clone 387, Gen 638)
[09:30:00] - Read packet limit of 540015616... Set to 524286976.
[09:30:00] + Attempting to send results [November 7 09:30:00 UTC]
[09:30:00] - Reading file work/wuresults_05.dat from core
[09:30:00]   (Read 96881 bytes from disk)
[09:30:00] Connecting to http://171.67.108.11:8080/
[09:30:21] - Couldn't send HTTP request to server
[09:30:21] + Could not connect to Work Server (results)
[09:30:21]     (171.67.108.11:8080)
[09:30:21] + Retrying using alternative port
[09:30:21] Connecting to http://171.67.108.11:80/
[09:30:42] - Couldn't send HTTP request to server
[09:30:42] + Could not connect to Work Server (results)
[09:30:42]     (171.67.108.11:80)
[09:30:42] - Error: Could not transmit unit 05 (completed November 7) to work server.
[09:30:42] - 2 failed uploads of this unit.
[09:30:42] - Read packet limit of 540015616... Set to 524286976.
[09:30:42] + Attempting to send results [November 7 09:30:42 UTC]
[09:30:42] - Reading file work/wuresults_05.dat from core
[09:30:42]   (Read 96881 bytes from disk)
[09:30:42] Connecting to http://171.67.108.25:8080/
[09:31:03] - Couldn't send HTTP request to server
[09:31:03] + Could not connect to Work Server (results)
[09:31:03]     (171.67.108.25:8080)
[09:31:03] + Retrying using alternative port
[09:31:03] Connecting to http://171.67.108.25:80/
[09:31:24] - Couldn't send HTTP request to server
[09:31:24] + Could not connect to Work Server (results)
[09:31:24]     (171.67.108.25:80)
[09:31:24]   Could not transmit unit 05 to Collection server; keeping in queue.
[09:31:24] + Sent 0 of 1 completed units to the server
[09:31:24] - Preparing to get new work unit...
[09:31:24] + Attempting to get work packet
[09:31:24] - Will indicate memory of 6142 MB
[09:31:24] - Connecting to assignment server
[09:31:24] Connecting to http://assign-GPU.stanford.edu:8080/
[09:31:45] - Couldn't send HTTP request to server
[09:31:45] + Could not connect to Assignment Server
[09:31:45] Connecting to http://assign-GPU.stanford.edu:80/
[09:32:06] - Couldn't send HTTP request to server
[09:32:06] + Could not connect to Assignment Server 2
[09:32:06] + Couldn't get work instructions.
[09:32:06] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[09:32:24] + Attempting to get work packet
[09:32:24] - Will indicate memory of 6142 MB
[09:32:24] - Connecting to assignment server
[09:32:24] Connecting to http://assign-GPU.stanford.edu:8080/
[09:32:45] - Couldn't send HTTP request to server
[09:32:45] + Could not connect to Assignment Server
[09:32:45] Connecting to http://assign-GPU.stanford.edu:80/
[09:33:06] - Couldn't send HTTP request to server
[09:33:06] + Could not connect to Assignment Server 2
[09:33:06] + Couldn't get work instructions.
[09:33:06] - Attempt #2  to get work failed, and no other work to do.
[09:33:18] + Attempting to get work packet
[09:33:18] - Will indicate memory of 6142 MB
[09:33:18] - Connecting to assignment server
[09:33:18] Connecting to http://assign-GPU.stanford.edu:8080/
[09:33:39] - Couldn't send HTTP request to server
[09:33:39] + Could not connect to Assignment Server
[09:33:39] Connecting to http://assign-GPU.stanford.edu:80/
[09:34:00] - Couldn't send HTTP request to server
[09:34:00] + Could not connect to Assignment Server 2
[09:34:00] + Couldn't get work instructions.
[09:34:00] - Attempt #3  to get work failed, and no other work to do.
[09:34:26] + Attempting to get work packet
[09:34:26] - Will indicate memory of 6142 MB
[09:34:26] - Connecting to assignment server
[09:34:26] Connecting to http://assign-GPU.stanford.edu:8080/
[09:34:47] - Couldn't send HTTP request to server
[09:34:47] + Could not connect to Assignment Server
[09:34:47] Connecting to http://assign-GPU.stanford.edu:80/
[09:35:08] - Couldn't send HTTP request to server
[09:35:08] + Could not connect to Assignment Server 2
[09:35:08] + Couldn't get work instructions.
[09:35:08] - Attempt #4  to get work failed, and no other work to do.
[09:35:50] + Attempting to get work packet
[09:35:50] - Will indicate memory of 6142 MB
[09:35:50] - Connecting to assignment server
[09:35:50] Connecting to http://assign-GPU.stanford.edu:8080/
[09:36:11] - Couldn't send HTTP request to server
[09:36:11] + Could not connect to Assignment Server
[09:36:11] Connecting to http://assign-GPU.stanford.edu:80/
[09:36:32] - Couldn't send HTTP request to server
[09:36:32] + Could not connect to Assignment Server 2
[09:36:32] + Couldn't get work instructions.
[09:36:32] - Attempt #5  to get work failed, and no other work to do.
[09:38:07] + Attempting to get work packet
[09:38:07] - Will indicate memory of 6142 MB
[09:38:07] - Connecting to assignment server
[09:38:07] Connecting to http://assign-GPU.stanford.edu:8080/
[09:38:28] - Couldn't send HTTP request to server
[09:38:28] + Could not connect to Assignment Server
[09:38:28] Connecting to http://assign-GPU.stanford.edu:80/
[09:38:49] - Couldn't send HTTP request to server
[09:38:49] + Could not connect to Assignment Server 2
[09:38:49] + Couldn't get work instructions.
[09:38:49] - Attempt #6  to get work failed, and no other work to do.
[09:41:42] + Attempting to get work packet
[09:41:42] - Will indicate memory of 6142 MB
[09:41:42] - Connecting to assignment server
[09:41:42] Connecting to http://assign-GPU.stanford.edu:8080/
[09:42:03] - Couldn't send HTTP request to server
[09:42:03] + Could not connect to Assignment Server
[09:42:03] Connecting to http://assign-GPU.stanford.edu:80/
[09:42:24] - Couldn't send HTTP request to server
[09:42:24] + Could not connect to Assignment Server 2
[09:42:24] + Couldn't get work instructions.
[09:42:24] - Attempt #7  to get work failed, and no other work to do.
[09:47:45] + Attempting to get work packet
[09:47:45] - Will indicate memory of 6142 MB
[09:47:45] - Connecting to assignment server
[09:47:45] Connecting to http://assign-GPU.stanford.edu:8080/
[09:48:06] - Couldn't send HTTP request to server
[09:48:06] + Could not connect to Assignment Server
[09:48:06] Connecting to http://assign-GPU.stanford.edu:80/
[09:48:27] - Couldn't send HTTP request to server
[09:48:27] + Could not connect to Assignment Server 2
[09:48:27] + Couldn't get work instructions.
[09:48:27] - Attempt #8  to get work failed, and no other work to do.
[09:59:14] + Attempting to get work packet
[09:59:14] - Will indicate memory of 6142 MB
[09:59:14] - Connecting to assignment server
[09:59:14] Connecting to http://assign-GPU.stanford.edu:8080/
[09:59:15] Posted data.
[09:59:15] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[09:59:15] + Couldn't get work instructions.
[09:59:15] - Attempt #9  to get work failed, and no other work to do.
[10:20:48] + Attempting to get work packet
[10:20:48] - Will indicate memory of 6142 MB
[10:20:48] - Connecting to assignment server
[10:20:48] Connecting to http://assign-GPU.stanford.edu:8080/
[10:20:49] Posted data.
[10:20:49] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:20:49] + Couldn't get work instructions.
[10:20:49] - Attempt #10  to get work failed, and no other work to do.
[10:43:05] ***** Got a SIGTERM signal (2)
[10:43:05] Killing all core threads
Folding@Home Client Shutdown.
After I stopped and started my GPU client this what my log file gives.
--- Opening Log file [November 7 10:43:12 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Users\admin\AppData\Roaming\Folding@home-gpu
Arguments: -verbosity 9
[10:43:12] - Ask before connecting: No
[10:43:12] - User name: KroontjesPen (Team 92)
[10:43:12] - User ID: xxxxxxxxxx
[10:43:12] - Machine ID: 2
[10:43:12]
[10:43:12] Loaded queue successfully.
[10:43:12] Initialization complete
[10:43:12] - Preparing to get new work unit...
[10:43:12] - Autosending finished units... [November 7 10:43:12 UTC]
[10:43:12] + Attempting to get work packet
[10:43:12] Trying to send all finished work units
[10:43:12] Project: 5772 (Run 7, Clone 387, Gen 638)
[10:43:12] - Read packet limit of 540015616... Set to 524286976.
[10:43:12] + Attempting to send results [November 7 10:43:12 UTC]
[10:43:12] - Will indicate memory of 6142 MB
[10:43:12] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 7
[10:43:12] - Connecting to assignment server
[10:43:12] Connecting to http://assign-GPU.stanford.edu:8080/
[10:43:12] - Reading file work/wuresults_05.dat from core
[10:43:12]   (Read 96881 bytes from disk)
[10:43:12] Connecting to http://171.67.108.11:8080/
[10:43:14] Posted data.
[10:43:14] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:43:14] + Couldn't get work instructions.
[10:43:14] - Attempt #1  to get work failed, and no other work to do.
[10:43:20] Posted data.
[10:43:21] Initial: 0000; - Uploaded at ~10 kB/s
[10:43:21] - Averaged speed for that direction ~46 kB/s
[10:43:21] + Results successfully sent
[10:43:21] Thank you for your contribution to Folding@Home.
[10:43:21] + Number of Units Completed: 8804
[10:43:21] + Sent 1 of 1 completed units to the server
[10:43:21] - Autosend completed
[10:43:31] + Attempting to get work packet
[10:43:31] - Will indicate memory of 6142 MB
[10:43:31] - Connecting to assignment server
[10:43:31] Connecting to http://assign-GPU.stanford.edu:8080/
[10:43:32] Posted data.
[10:43:32] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:43:32] + Couldn't get work instructions.
[10:43:32] - Attempt #2  to get work failed, and no other work to do.
[10:43:52] + Attempting to get work packet
[10:43:52] - Will indicate memory of 6142 MB
[10:43:52] - Connecting to assignment server
[10:43:52] Connecting to http://assign-GPU.stanford.edu:8080/
[10:43:53] Posted data.
[10:43:53] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:43:53] + Couldn't get work instructions.
[10:43:53] - Attempt #3  to get work failed, and no other work to do.
[10:44:26] + Attempting to get work packet
[10:44:26] - Will indicate memory of 6142 MB
[10:44:26] - Connecting to assignment server
[10:44:26] Connecting to http://assign-GPU.stanford.edu:8080/
[10:44:27] Posted data.
[10:44:27] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:44:27] + Couldn't get work instructions.
[10:44:27] - Attempt #4  to get work failed, and no other work to do.
[10:45:15] + Attempting to get work packet
[10:45:15] - Will indicate memory of 6142 MB
[10:45:15] - Connecting to assignment server
[10:45:15] Connecting to http://assign-GPU.stanford.edu:8080/
[10:45:16] Posted data.
[10:45:16] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:45:16] + Couldn't get work instructions.
[10:45:16] - Attempt #5  to get work failed, and no other work to do.
[10:45:34] Opening http://foldingforum.org/...
[10:46:51] + Attempting to get work packet
[10:46:51] - Will indicate memory of 6142 MB
[10:46:51] - Connecting to assignment server
[10:46:51] Connecting to http://assign-GPU.stanford.edu:8080/
[10:46:52] Posted data.
[10:46:52] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:46:52] + Couldn't get work instructions.
[10:46:52] - Attempt #6  to get work failed, and no other work to do.
[10:49:37] + Attempting to get work packet
[10:49:37] - Will indicate memory of 6142 MB
[10:49:37] - Connecting to assignment server
[10:49:37] Connecting to http://assign-GPU.stanford.edu:8080/
[10:49:38] Posted data.
[10:49:38] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:49:38] + Couldn't get work instructions.
[10:49:38] - Attempt #7  to get work failed, and no other work to do.
[10:55:10] + Attempting to get work packet
[10:55:10] - Will indicate memory of 6142 MB
[10:55:10] - Connecting to assignment server
[10:55:10] Connecting to http://assign-GPU.stanford.edu:8080/
[10:55:11] Posted data.
[10:55:11] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[10:55:11] + Couldn't get work instructions.
[10:55:11] - Attempt #8  to get work failed, and no other work to do.
[11:06:05] + Attempting to get work packet
[11:06:05] - Will indicate memory of 6142 MB
[11:06:05] - Connecting to assignment server
[11:06:05] Connecting to http://assign-GPU.stanford.edu:8080/
[11:06:06] Posted data.
[11:06:06] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[11:06:06] + Couldn't get work instructions.
[11:06:06] - Attempt #9  to get work failed, and no other work to do.
http://assign-gpu.stanford.edu:8080/ gives an OK
Hopefully this is enough information.
Rolo
Hardware configuration: Zaphod: i5-2500K@4.2GHz, 8GB DDR3-2133, GTX580@882/1765/2037
Trillian: i5-2500K@4.2GHz, 8GB DDR3-2133, GTX580@795/1590/2004
Beeblebrox: Conroe E6700@3.0GHz, 4x1GB Corsair Dominator PC8500 DDR2@900, Gigabyte GA-965P-DQ6v3.3, MSI N260GTX-T2D896-OC@621/1296/1080/1.125v (65nm-192core)
Hotblack: Wolfdale E7500@3.66, 2x2GB Crucial Ballistix PC8500 DDR2@1000, Gigabyte GA-965P-DQ6v3.3, MSI N260GTX-T2D896-OC@621/1296/1080/1.125v (65nm-192core)
"Empty work server assignment"
Post by Rolo »
Our economy is so bad that both GTX260 slots can't get work since 09:23Z; restarting client doesn't fix.
assign-GPU.stanford.edu resolves to vsp10v-vz01.stanford.edu and reports OK.
12:40:53:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:40:53:WU02:FS00:News: Welcome to Folding@Home
12:40:53:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
12:40:53:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
12:40:53:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
12:40:53:ERROR:WU02:FS00:Exception: Could not get an assignment
SMP and GTX580s are folding OK.
b.sogard
Re: 'No appropriate work server was available'
Post by b.sogard »
My GT240 running under client 7.2.9 has been reporting the same thing for a few hours now. Nothing has changed in the configuration, sometime while I was sleeping the client returned a WU and hasn't been able to get a new one.
JacobKlein
Post by JacobKlein »
I too am getting errors saying "Empty work server assignment" and "Exception: Could not get an assignment"
... trying to get work for my 2 GTS 240 GPUs.
Did we do something wrong?
Note: Going to http://assign-gpu.stanford.edu/ results in a page that says "OK", which is very confusing, since my situation is not OK.
13:59:13:Enabled folding slot 00: READY gpu:0:"G92 [GeForce GTS 240]"
13:59:13:Enabled folding slot 01: READY gpu:2:"G92 [GeForce GTS 240]"
13:59:13:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
13:59:13:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
13:59:17:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
13:59:17:WU01:FS01:News: Welcome to Folding@Home
13:59:17:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:59:17:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
13:59:18:WU01:FS01:News: Welcome to Folding@Home
13:59:18:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:59:18:ERROR:WU01:FS01:Exception: Could not get an assignment
13:59:18:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
13:59:23:WU00:FS00:News: Welcome to Folding@Home
13:59:23:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:59:23:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
13:59:25:WU01:FS01:News: Welcome to Folding@Home
13:59:25:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:59:25:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
13:59:26:WU01:FS01:News: Welcome to Folding@Home
13:59:26:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:59:26:ERROR:WU01:FS01:Exception: Could not get an assignment
13:59:27:WU00:FS00:News: Welcome to Folding@Home
13:59:27:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:59:27:ERROR:WU00:FS00:Exception: Could not get an assignment
13:59:28:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
13:59:31:WU00:FS00:News: Welcome to Folding@Home
13:59:31:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:59:31:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
13:59:40:WU00:FS00:News: Welcome to Folding@Home
13:59:40:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:59:40:ERROR:WU00:FS00:Exception: Could not get an assignment
14:00:18:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
14:00:19:WU01:FS01:News: Welcome to Folding@Home
14:00:19:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
14:00:19:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
14:00:19:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
14:00:19:ERROR:WU01:FS01:Exception: Could not get an assignment
14:00:28:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:00:28:WU00:FS00:News: Welcome to Folding@Home
14:00:28:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
14:00:28:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
14:00:28:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
14:00:28:ERROR:WU00:FS00:Exception: Could not get an assignment
14:01:55:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
14:02:02:WU01:FS01:News: Welcome to Folding@Home
14:02:02:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
14:02:02:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
14:02:02:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
14:02:02:ERROR:WU01:FS01:Exception: Could not get an assignment
14:02:05:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:02:05:WU00:FS00:News: Welcome to Folding@Home
14:02:05:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
14:02:05:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
14:02:06:WU00:FS00:News: Welcome to Folding@Home
14:02:06:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
14:02:06:ERROR:WU00:FS00:Exception: Could not get an assignment
14:04:33:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
14:04:36:WU01:FS01:News: Welcome to Folding@Home
14:04:36:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
14:04:36:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
14:04:37:WU01:FS01:News: Welcome to Folding@Home
14:04:37:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
14:04:37:ERROR:WU01:FS01:Exception: Could not get an assignment
14:04:42:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:04:46:WU00:FS00:News: Welcome to Folding@Home
14:04:46:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
14:04:46:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
14:04:49:WU00:FS00:News: Welcome to Folding@Home
14:04:49:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
14:04:49:ERROR:WU00:FS00:Exception: Could not get an assignment
Treefrog
Hardware configuration: Windows 7 Professional 64 SP1
Intel Core2Quad 2.66Ghz
nVidia GeForce 275GTX (ForceWare 285.62)
4 GB RAM
Sound Blaster Audigy 2
FAH v7
Post by Treefrog »
Yep same issue here. Haven't had work to do since around 9:11AM GMT. I'm using a GTX 275.
*********************** Log Started 2012-11-07T08:12:39Z ***********************
08:12:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
08:13:32:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
08:13:32:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
08:13:33:WU00:FS00:News: Welcome to Folding@Home
08:13:33:WU00:FS00:Assigned to work server 171.67.108.11
08:13:33:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GT200b [GeForce GTX 275]" from 171.67.108.11
08:13:33:WU00:FS00:Connecting to 171.67.108.11:8080
08:13:34:WU00:FS00:Downloading 44.89KiB
08:13:35:WU00:FS00:Download complete
08:13:35:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:5772 run:12 clone:365 gen:1154 core:0x11 unit:0x246a422a509a182e0482016d000c168c
08:13:35:WU00:FS00:Starting
08:13:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Danny/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 702 -lifeline 1332 -checkpoint 10 -gpu 0
08:13:35:WU00:FS00:Started FahCore on PID 4756
08:13:35:WU00:FS00:Core PID:6132
08:13:35:WU00:FS00:FahCore 0x11 started
08:13:36:WU00:FS00:0x11:
08:13:36:WU00:FS00:0x11:*------------------------------*
08:13:36:WU00:FS00:0x11:Folding@Home GPU Core
08:13:36:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
08:13:36:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
08:13:36:WU00:FS00:0x11:Build host: amoeba
08:13:36:WU00:FS00:0x11:Board Type: Nvidia
08:13:36:WU00:FS00:0x11:Core      :
08:13:36:WU00:FS00:0x11:Preparing to commence simulation
08:13:36:WU00:FS00:0x11:- Looking at optimizations...
08:13:36:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
08:13:36:WU00:FS00:0x11:- Created dyn
08:13:36:WU00:FS00:0x11:- Files status OK
08:13:36:WU00:FS00:0x11:- Expanded 45459 -> 251112 (decompressed 552.3 percent)
08:13:36:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=45459 data_size=251112, decompressed_data_size=251112 diff=0
08:13:36:WU00:FS00:0x11:- Digital signature verified
08:13:36:WU00:FS00:0x11:Project: 5772 (Run 12, Clone 365, Gen 1154)
08:13:36:WU00:FS00:0x11:Assembly optimizations on if available.
08:13:36:WU00:FS00:0x11:Entering M.D.
08:13:41:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  4153105354 1444298179 3257082407 2663091450 209642377
08:13:41:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
08:13:42:WU00:FS00:0x11:Working on Protein
08:13:43:WU00:FS00:0x11:Client config unavailable.
08:13:43:WU00:FS00:0x11:Starting GUI Server
08:14:17:WU00:FS00:0x11:Completed 1%
08:14:50:WU00:FS00:0x11:Completed 2%
08:15:24:WU00:FS00:0x11:Completed 3%
08:15:58:WU00:FS00:0x11:Completed 4%
08:16:31:WU00:FS00:0x11:Completed 5%
08:17:05:WU00:FS00:0x11:Completed 6%
08:17:39:WU00:FS00:0x11:Completed 7%
08:18:12:WU00:FS00:0x11:Completed 8%
08:18:46:WU00:FS00:0x11:Completed 9%
08:19:20:WU00:FS00:0x11:Completed 10%
08:19:53:WU00:FS00:0x11:Completed 11%
08:20:27:WU00:FS00:0x11:Completed 12%
08:21:01:WU00:FS00:0x11:Completed 13%
08:21:34:WU00:FS00:0x11:Completed 14%
08:22:08:WU00:FS00:0x11:Completed 15%
08:22:42:WU00:FS00:0x11:Completed 16%
08:23:16:WU00:FS00:0x11:Completed 17%
08:23:52:WU00:FS00:0x11:Completed 18%
08:24:28:WU00:FS00:0x11:Completed 19%
08:25:05:WU00:FS00:0x11:Completed 20%
08:25:43:WU00:FS00:0x11:Completed 21%
08:26:21:WU00:FS00:0x11:Completed 22%
08:26:59:WU00:FS00:0x11:Completed 23%
08:27:37:WU00:FS00:0x11:Completed 24%
08:28:16:WU00:FS00:0x11:Completed 25%
08:28:54:WU00:FS00:0x11:Completed 26%
08:29:33:WU00:FS00:0x11:Completed 27%
08:30:12:WU00:FS00:0x11:Completed 28%
08:30:51:WU00:FS00:0x11:Completed 29%
08:31:30:WU00:FS00:0x11:Completed 30%
08:32:09:WU00:FS00:0x11:Completed 31%
08:32:49:WU00:FS00:0x11:Completed 32%
08:33:28:WU00:FS00:0x11:Completed 33%
08:34:08:WU00:FS00:0x11:Completed 34%
08:34:48:WU00:FS00:0x11:Completed 35%
08:35:28:WU00:FS00:0x11:Completed 36%
08:36:08:WU00:FS00:0x11:Completed 37%
08:36:48:WU00:FS00:0x11:Completed 38%
08:37:28:WU00:FS00:0x11:Completed 39%
08:38:08:WU00:FS00:0x11:Completed 40%
08:38:48:WU00:FS00:0x11:Completed 41%
08:39:28:WU00:FS00:0x11:Completed 42%
08:40:08:WU00:FS00:0x11:Completed 43%
08:40:48:WU00:FS00:0x11:Completed 44%
08:41:29:WU00:FS00:0x11:Completed 45%
08:42:09:WU00:FS00:0x11:Completed 46%
08:42:50:WU00:FS00:0x11:Completed 47%
08:43:30:WU00:FS00:0x11:Completed 48%
08:44:11:WU00:FS00:0x11:Completed 49%
08:44:52:WU00:FS00:0x11:Completed 50%
08:45:32:WU00:FS00:0x11:Completed 51%
08:46:13:WU00:FS00:0x11:Completed 52%
08:46:53:WU00:FS00:0x11:Completed 53%
08:47:34:WU00:FS00:0x11:Completed 54%
08:48:14:WU00:FS00:0x11:Completed 55%
08:48:55:WU00:FS00:0x11:Completed 56%
08:49:35:WU00:FS00:0x11:Completed 57%
08:50:15:WU00:FS00:0x11:Completed 58%
08:50:56:WU00:FS00:0x11:Completed 59%
08:51:36:WU00:FS00:0x11:Completed 60%
08:52:17:WU00:FS00:0x11:Completed 61%
08:52:57:WU00:FS00:0x11:Completed 62%
08:53:37:WU00:FS00:0x11:Completed 63%
08:54:17:WU00:FS00:0x11:Completed 64%
08:54:59:WU00:FS00:0x11:Completed 65%
08:55:47:WU00:FS00:0x11:Completed 66%
08:56:26:WU00:FS00:0x11:Completed 67%
08:57:06:WU00:FS00:0x11:Completed 68%
08:57:46:WU00:FS00:0x11:Completed 69%
08:58:27:WU00:FS00:0x11:Completed 70%
08:59:09:WU00:FS00:0x11:Completed 71%
08:59:50:WU00:FS00:0x11:Completed 72%
09:00:32:WU00:FS00:0x11:Completed 73%
09:01:13:WU00:FS00:0x11:Completed 74%
09:01:55:WU00:FS00:0x11:Completed 75%
09:02:36:WU00:FS00:0x11:Completed 76%
09:03:18:WU00:FS00:0x11:Completed 77%
09:04:00:WU00:FS00:0x11:Completed 78%
09:04:42:WU00:FS00:0x11:Completed 79%
09:05:24:WU00:FS00:0x11:Completed 80%
09:06:06:WU00:FS00:0x11:Completed 81%
09:06:51:WU00:FS00:0x11:Completed 82%
09:07:31:WU00:FS00:0x11:Completed 83%
09:08:16:WU00:FS00:0x11:Completed 84%
09:08:56:WU00:FS00:0x11:Completed 85%
09:09:39:WU00:FS00:0x11:Completed 86%
09:10:22:WU00:FS00:0x11:Completed 87%
09:11:04:WU00:FS00:0x11:Completed 88%
09:11:43:WU00:FS00:0x11:Run: exception thrown during GuardedRun
09:11:43:WU00:FS00:0x11:Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
09:11:43:WU00:FS00:0x11:Going to send back what have done -- stepsTotalG=15000000
09:11:43:WU00:FS00:0x11:Work fraction=0.8883 steps=15000000.
09:11:47:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:11:47:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:5772 run:12 clone:365 gen:1154 core:0x11 unit:0x246a422a509a182e0482016d000c168c
09:11:47:WU00:FS00:Uploading 637B to 171.67.108.11
09:11:47:WU00:FS00:Connecting to 171.67.108.11:8080
09:11:48:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:11:48:WU00:FS00:Upload complete
09:11:48:WU00:FS00:Server responded WORK_ACK (400)
09:11:48:WU00:FS00:Cleaning up
09:11:54:WU02:FS00:News: Welcome to Folding@Home
09:11:54:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:11:54:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:12:01:WU02:FS00:News: Welcome to Folding@Home
09:12:01:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:12:01:ERROR:WU02:FS00:Exception: Could not get an assignment
09:12:01:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:12:22:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:12:22:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:12:29:WU02:FS00:News: Welcome to Folding@Home
09:12:29:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:12:29:ERROR:WU02:FS00:Exception: Could not get an assignment
09:13:01:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:13:01:WU02:FS00:News: Welcome to Folding@Home
09:13:01:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:13:01:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:13:02:WU02:FS00:News: Welcome to Folding@Home
09:13:02:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:13:02:ERROR:WU02:FS00:Exception: Could not get an assignment
09:14:38:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:14:39:WU02:FS00:News: Welcome to Folding@Home
09:14:39:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:14:39:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:14:40:WU02:FS00:News: Welcome to Folding@Home
09:14:40:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:14:40:ERROR:WU02:FS00:Exception: Could not get an assignment
09:17:15:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:17:22:WU02:FS00:News: Welcome to Folding@Home
09:17:22:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:17:22:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:17:23:WU02:FS00:News: Welcome to Folding@Home
09:17:23:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:17:23:ERROR:WU02:FS00:Exception: Could not get an assignment
09:21:30:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:21:30:WU02:FS00:News: Welcome to Folding@Home
09:21:30:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:21:30:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:21:31:WU02:FS00:News: Welcome to Folding@Home
09:21:31:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:21:31:ERROR:WU02:FS00:Exception: Could not get an assignment
09:23:35:FS00:Paused
09:23:36:FS00:Unpaused
09:23:37:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:23:37:WU02:FS00:News: Welcome to Folding@Home
09:23:37:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:23:37:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:23:38:WU02:FS00:News: Welcome to Folding@Home
09:23:38:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:23:38:ERROR:WU02:FS00:Exception: Could not get an assignment
09:25:14:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:25:19:WU02:FS00:News: Welcome to Folding@Home
09:25:19:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:25:19:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:25:23:WU02:FS00:News: Welcome to Folding@Home
09:25:23:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:25:23:ERROR:WU02:FS00:Exception: Could not get an assignment
09:27:51:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:27:52:WU02:FS00:News: Welcome to Folding@Home
09:27:52:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
09:27:52:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:27:55:WU02:FS00:News: Welcome to Folding@Home
09:27:55:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
09:27:55:ERROR:WU02:FS00:Exception: Could not get an assignment
09:32:05:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:32:26:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:32:26:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:32:47:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:32:47:ERROR:WU02:FS00:Exception: Could not get an assignment
09:38:57:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:39:18:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:39:18:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:39:39:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:39:39:ERROR:WU02:FS00:Exception: Could not get an assignment
09:50:02:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
09:50:04:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: No connection could be made because the target machine actively refused it.
09:50:04:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
09:50:06:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: No connection could be made because the target machine actively refused it.
09:50:06:ERROR:WU02:FS00:Exception: Could not get an assignment
10:07:59:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
10:08:03:WU02:FS00:News: Welcome to Folding@Home
10:08:03:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:08:03:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
10:08:03:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:08:03:ERROR:WU02:FS00:Exception: Could not get an assignment
10:37:01:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
10:37:02:WU02:FS00:News: Welcome to Folding@Home
10:37:02:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
10:37:02:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
10:37:03:WU02:FS00:News: Welcome to Folding@Home
10:37:03:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
10:37:03:ERROR:WU02:FS00:Exception: Could not get an assignment
11:14:46:FS00:Paused
11:14:47:FS00:Unpaused
11:14:47:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:14:48:WU02:FS00:News: Welcome to Folding@Home
11:14:48:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:14:48:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:14:49:WU02:FS00:News: Welcome to Folding@Home
11:14:49:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:14:49:ERROR:WU02:FS00:Exception: Could not get an assignment
11:16:24:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:16:25:WU02:FS00:News: Welcome to Folding@Home
11:16:25:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:16:25:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:16:26:WU02:FS00:News: Welcome to Folding@Home
11:16:26:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:16:26:ERROR:WU02:FS00:Exception: Could not get an assignment
11:19:02:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:19:02:WU02:FS00:News: Welcome to Folding@Home
11:19:02:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:19:02:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:19:03:WU02:FS00:News: Welcome to Folding@Home
11:19:03:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:19:03:ERROR:WU02:FS00:Exception: Could not get an assignment
11:23:16:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:23:17:WU02:FS00:News: Welcome to Folding@Home
11:23:17:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:23:17:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:23:26:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 23
11:23:26:ERROR:WU02:FS00:Exception: Could not get an assignment
11:30:07:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:30:08:WU02:FS00:News: Welcome to Folding@Home
11:30:08:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:30:08:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:30:09:WU02:FS00:News: Welcome to Folding@Home
11:30:09:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:30:09:ERROR:WU02:FS00:Exception: Could not get an assignment
11:33:58:FS00:Paused
11:34:00:FS00:Unpaused
11:34:00:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:34:12:WU02:FS00:News: Welcome to Folding@Home
11:34:12:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:34:12:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:34:14:WU02:FS00:News: Welcome to Folding@Home
11:34:14:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:34:14:ERROR:WU02:FS00:Exception: Could not get an assignment
11:35:37:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:35:38:WU02:FS00:News: Welcome to Folding@Home
11:35:38:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:35:38:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:35:38:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:35:38:ERROR:WU02:FS00:Exception: Could not get an assignment
11:38:14:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:38:15:WU02:FS00:News: Welcome to Folding@Home
11:38:15:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:38:15:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:38:16:WU02:FS00:News: Welcome to Folding@Home
11:38:16:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:38:16:ERROR:WU02:FS00:Exception: Could not get an assignment
11:42:28:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:42:38:WU02:FS00:News: Welcome to Folding@Home
11:42:38:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:42:38:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:42:45:WU02:FS00:News: Welcome to Folding@Home
11:42:45:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:42:45:ERROR:WU02:FS00:Exception: Could not get an assignment
11:49:20:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
11:49:21:WU02:FS00:News: Welcome to Folding@Home
11:49:21:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
11:49:21:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
11:49:21:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
11:49:21:ERROR:WU02:FS00:Exception: Could not get an assignment
12:00:25:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:00:26:WU02:FS00:News: Welcome to Folding@Home
12:00:26:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
12:00:26:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
12:00:27:WU02:FS00:News: Welcome to Folding@Home
12:00:27:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
12:00:27:ERROR:WU02:FS00:Exception: Could not get an assignment
12:18:22:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:18:23:WU02:FS00:News: Welcome to Folding@Home
12:18:23:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
12:18:23:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
12:18:24:WU02:FS00:News: Welcome to Folding@Home
12:18:24:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
12:18:24:ERROR:WU02:FS00:Exception: Could not get an assignment
12:47:24:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:47:25:WU02:FS00:News: Welcome to Folding@Home
12:47:25:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
12:47:25:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
12:47:26:WU02:FS00:News: Welcome to Folding@Home
12:47:26:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
12:47:26:ERROR:WU02:FS00:Exception: Could not get an assignment
13:06:54:FS00:Paused
13:06:58:FS00:Unpaused
13:06:58:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
13:06:59:WU02:FS00:News: Welcome to Folding@Home
13:06:59:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:06:59:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
13:07:00:WU02:FS00:News: Welcome to Folding@Home
13:07:00:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:07:00:ERROR:WU02:FS00:Exception: Could not get an assignment
13:08:35:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
13:08:45:WU02:FS00:News: Welcome to Folding@Home
13:08:45:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:08:45:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
13:08:46:WU02:FS00:News: Welcome to Folding@Home
13:08:46:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:08:46:ERROR:WU02:FS00:Exception: Could not get an assignment
13:11:13:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
13:11:20:WU02:FS00:News: Welcome to Folding@Home
13:11:20:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:11:20:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
13:11:20:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:11:20:ERROR:WU02:FS00:Exception: Could not get an assignment
13:15:27:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
13:15:28:WU02:FS00:News: Welcome to Folding@Home
13:15:28:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:15:28:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
13:15:28:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:15:28:ERROR:WU02:FS00:Exception: Could not get an assignment
13:22:18:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
13:22:19:WU02:FS00:News: Welcome to Folding@Home
13:22:19:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:22:19:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
13:22:19:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:22:19:ERROR:WU02:FS00:Exception: Could not get an assignment
13:33:24:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
13:33:24:WU02:FS00:News: Welcome to Folding@Home
13:33:24:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:33:24:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
13:33:25:WU02:FS00:News: Welcome to Folding@Home
13:33:25:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:33:25:ERROR:WU02:FS00:Exception: Could not get an assignment
13:51:21:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
13:51:33:WU02:FS00:News: Welcome to Folding@Home
13:51:33:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
13:51:33:WU02:FS00:Connecting to assign-GPU.stanford.edu:8080
13:51:34:WU02:FS00:News: Welcome to Folding@Home
13:51:34:WARNING:WU02:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
13:51:34:ERROR:WU02:FS00:Exception: Could not get an assignment
Rolo
Post by Rolo »
How many PPD do we get for unemployment? :D
[WHGT]Cyberman
Hardware configuration: none anymore, FAH doesn't want it, it seems.
171.67.108.201 // http://assign-gpu.stanford.edu/ - no WUs?
Post by [WHGT]Cyberman »
Apparently this assignment server can't give my client any WUs.
Why is that? Is the GPU outdated already?
Anything I can do to get WUs?
(I'm giving Boinc the GPU for now, shouldn't go to waste :-))
Here's the log in any case:
*********************** Log Started 2012-11-07T16:27:42Z ***********************
16:27:42:************************* Folding@home Client *************************
16:27:42:      Website: http://folding.stanford.edu/
16:27:42:    Copyright: (c) 2009-2012 Stanford University
16:27:42:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:27:42:         Args: --lifeline 1372 --command-port=36330
16:27:42:       Config: C:/ProgramData/FAHClient/config.xml
16:27:42:******************************** Build ********************************
16:27:42:      Version: 7.1.52
16:27:42:         Date: Mar 20 2012
16:27:42:         Time: 19:37:42
16:27:42:      SVN Rev: 3515
16:27:42:       Branch: fah/trunk/client
16:27:42:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:27:42:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:27:42:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
16:27:42:     Platform: win32 XP
16:27:42:         Bits: 32
16:27:42:         Mode: Release
16:27:42:******************************* System ********************************
16:27:42:          CPU: AMD FX(tm)-6100 Six-Core Processor
16:27:42:       CPU ID: AuthenticAMD Family 21 Model 1 Stepping 2
16:27:42:         CPUs: 6
16:27:42:       Memory: 15.95GiB
16:27:42:  Free Memory: 9.92GiB
16:27:42:      Threads: WINDOWS_THREADS
16:27:42:   On Battery: false
16:27:42:   UTC offset: 1
16:27:42:          PID: 2764
16:27:42:          CWD: C:/ProgramData/FAHClient
16:27:42:           OS: Windows 7 Professional
16:27:42:      OS Arch: AMD64
16:27:42:         GPUs: 1
16:27:42:        GPU 0: ATI:4 Cayman XT [AMD Radeon HD 6900 Series]
16:27:42:         CUDA: Not detected
16:27:42:Win32 Service: false
16:27:42:***********************************************************************
16:27:42:<config>
16:27:42:  <service-description v='Folding@home Client'/>
16:27:42:  <service-restart v='true'/>
16:27:42:  <service-restart-delay v='5000'/>
16:27:42:
16:27:42:  <!-- Client Control -->
16:27:42:  <cycle-rate v='4'/>
16:27:42:  <cycles v='-1'/>
16:27:42:  <data-directory v='.'/>
16:27:42:  <disable-project-lookup v='false'/>
16:27:42:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
16:27:42:  <exit-when-done v='false'/>
16:27:42:  <threads v='4'/>
16:27:42:
16:27:42:  <!-- Configuration -->
16:27:42:  <config-rotate v='true'/>
16:27:42:  <config-rotate-dir v='configs'/>
16:27:42:  <config-rotate-max v='16'/>
16:27:42:
16:27:42:  <!-- Debugging -->
16:27:42:  <assignment-servers>
16:27:42:    assign3.stanford.edu:8080 assign4.stanford.edu:80
16:27:42:  </assignment-servers>
16:27:42:  <capture-directory v='capture'/>
16:27:42:  <capture-sockets v='false'/>
16:27:42:  <debug-sockets v='false'/>
16:27:42:  <exception-locations v='true'/>
16:27:42:  <gpu-assignment-servers>
16:27:42:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
16:27:42:  </gpu-assignment-servers>
16:27:42:  <stack-traces v='false'/>
16:27:42:
16:27:42:  <!-- Error Handling -->
16:27:42:  <max-slot-errors v='5'/>
16:27:42:  <max-unit-errors v='5'/>
16:27:42:
16:27:42:  <!-- FahCore Control -->
16:27:42:  <checkpoint v='5'/>
16:27:42:  <core-dir v='cores'/>
16:27:42:  <core-priority v='idle'/>
16:27:42:  <cpu-affinity v='false'/>
16:27:42:  <cpu-usage v='100'/>
16:27:42:  <no-assembly v='false'/>
16:27:42:
16:27:42:  <!-- Folding Slot Configuration -->
16:27:42:  <client-subtype v='STDCLI'/>
16:27:42:  <client-type v='normal'/>
16:27:42:  <cpu-species v='X86_AMD'/>
16:27:42:  <cpu-type v='AMD64'/>
16:27:42:  <cpus v='-1'/>
16:27:42:  <cuda-index v='0'/>
16:27:42:  <extra-core-args v='-verbose'/>
16:27:42:  <gpu v='true'/>
16:27:42:  <gpu-usage v='100'/>
16:27:42:  <max-packet-size v='normal'/>
16:27:42:  <opencl-index v='0'/>
16:27:42:  <os-species v='UNKNOWN'/>
16:27:42:  <os-type v='WIN32'/>
16:27:42:  <project-key v='0'/>
16:27:42:  <smp v='false'/>
16:27:42:
16:27:42:  <!-- Logging -->
16:27:42:  <log v='log.txt'/>
16:27:42:  <log-color v='false'/>
16:27:42:  <log-crlf v='true'/>
16:27:42:  <log-date v='false'/>
16:27:42:  <log-date-periodically v='21600'/>
16:27:42:  <log-debug v='true'/>
16:27:42:  <log-domain v='false'/>
16:27:42:  <log-header v='true'/>
16:27:42:  <log-level v='true'/>
16:27:42:  <log-no-info-header v='true'/>
16:27:42:  <log-redirect v='false'/>
16:27:42:  <log-rotate v='true'/>
16:27:42:  <log-rotate-dir v='logs'/>
16:27:42:  <log-rotate-max v='16'/>
16:27:42:  <log-short-level v='false'/>
16:27:42:  <log-simple-domains v='true'/>
16:27:42:  <log-thread-id v='false'/>
16:27:42:  <log-thread-prefix v='true'/>
16:27:42:  <log-time v='true'/>
16:27:42:  <log-to-screen v='true'/>
16:27:42:  <log-truncate v='false'/>
16:27:42:  <verbosity v='5'/>
16:27:42:
16:27:42:  <!-- Network -->
16:27:42:  <proxy v=':8080'/>
16:27:42:  <proxy-enable v='false'/>
16:27:42:  <proxy-pass v=''/>
16:27:42:  <proxy-user v=''/>
16:27:42:
16:27:42:  <!-- Process Control -->
16:27:42:  <child v='false'/>
16:27:42:  <daemon v='false'/>
16:27:42:  <pid v='false'/>
16:27:42:  <pid-file v='Folding@home Client.pid'/>
16:27:42:  <respawn v='false'/>
16:27:42:  <service v='false'/>
16:27:42:
16:27:42:  <!-- Remote Command Server -->
16:27:42:  <command-address v='0.0.0.0'/>
16:27:42:  <command-allow v='127.0.0.1'/>
16:27:42:  <command-allow-no-pass v='127.0.0.1'/>
16:27:42:  <command-deny v='0.0.0.0/0'/>
16:27:42:  <command-deny-no-pass v='0.0.0.0/0'/>
16:27:42:  <command-port v='36330'/>
16:27:42:
16:27:42:  <!-- Slot Control -->
16:27:42:  <max-shutdown-wait v='60'/>
16:27:42:  <pause-on-battery v='false'/>
16:27:42:  <pause-on-start v='false'/>
16:27:42:
16:27:42:  <!-- User Information -->
16:27:42:  <machine-id v='0'/>
16:27:42:  <passkey v='********************************'/>
16:27:42:  <team v='213496'/>
16:27:42:  <user v='[WHGT]Cyberman'/>
16:27:42:
16:27:42:  <!-- Work Unit Control -->
16:27:42:  <dump-after-deadline v='true'/>
16:27:42:  <max-queue v='16'/>
16:27:42:  <max-units v='0'/>
16:27:42:  <next-unit-percentage v='99'/>
16:27:42:
16:27:42:  <!-- Folding Slots -->
16:27:42:  <slot id='0' type='GPU'/>
16:27:42:</config>
16:27:42:Trying to access database...
16:27:42:Successfully acquired database lock
16:27:42:Enabled folding slot 00: READY gpu:0:"Cayman XT [AMD Radeon HD 6900 Series]"
16:27:42:Started thread 1 on PID 2764
16:27:42:Started thread 3 on PID 2764
16:27:42:Started thread 4 on PID 2764
16:27:42:Started thread 6 on PID 2764
16:27:42:Started thread 5 on PID 2764
16:27:42:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:27:43:WU00:FS00:News: Welcome to Folding@Home
16:27:43:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
16:27:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
16:27:44:WU00:FS00:News: Welcome to Folding@Home
16:27:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
16:27:44:ERROR:WU00:FS00:Exception: Could not get an assignment
16:27:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:27:44:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
16:27:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
16:27:45:WU00:FS00:News: Welcome to Folding@Home
16:27:45:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
16:27:45:ERROR:WU00:FS00:Exception: Could not get an assignment
16:27:45:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
16:27:45:Started thread 7 on PID 2764
16:28:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:28:45:WU00:FS00:News: Welcome to Folding@Home
16:28:45:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
16:28:45:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
16:28:45:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
16:28:45:ERROR:WU00:FS00:Exception: Could not get an assignment
16:30:21:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:30:22:WU00:FS00:News: Welcome to Folding@Home
16:30:22:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
16:30:22:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
16:30:22:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
16:30:22:ERROR:WU00:FS00:Exception: Could not get an assignment
16:32:58:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:32:59:WU00:FS00:News: Welcome to Folding@Home
16:32:59:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
16:32:59:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
16:33:00:WU00:FS00:News: Welcome to Folding@Home
16:33:00:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
16:33:00:ERROR:WU00:FS00:Exception: Could not get an assignment
16:37:13:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:37:13:WU00:FS00:News: Welcome to Folding@Home
16:37:13:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
16:37:13:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
16:37:14:WU00:FS00:News: Welcome to Folding@Home
16:37:14:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
16:37:14:ERROR:WU00:FS00:Exception: Could not get an assignment
It seems I can't write a signature that both conveys my feelings and doesn't look like a miserable trolling attempt...
msgclb
Post by msgclb »
I too can't get any WUs on this HD 6870.
16:03:19:Trying to access database...
16:03:19:Successfully acquired database lock
16:03:19:Enabled folding slot 00: READY gpu:0:\"Barts XT [ATI Radeon HD 6800 Series]\"
16:03:19:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:03:19:WU00:FS00:News: Welcome to Folding@Home
16:03:19:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
16:03:19:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
16:03:20:WU00:FS00:News: Welcome to Folding@Home
16:03:20:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
16:03:20:ERROR:WU00:FS00:Exception: Could not get an assignment
16:30:45:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:30:46:WU00:FS00:News: Welcome to Folding@Home
16:30:46:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
16:30:46:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
16:30:46:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
16:30:46:ERROR:WU00:FS00:Exception: Could not get an assignment
TheWolf
Post by TheWolf »
There getting ready to roll out the GPU QRB.... :-) :-p
Krusher33
Post by Krusher33 »
We've got several members with AMD GPU's over at overclock.net are getting this same error. I myself have taken off the "advanced" flag and is now getting old units of 897pts. I've added the Beta flag instead of advanced too.
The server with WU's for AMD GPU's was out of work. As of 10:30 PST it shows work available again.
As for other servers, VSP12 is still down - see this topic - viewtopic.php?f=18&t=22779. Check the server status page for the status of other work servers.
KroontjesPen
This here working again. :biggrin:
