Generated an unstable machine error at 65%. Uploaded the result.
Has since then completed.
Project 7623 (Run 130, Clone 0, Gen 91)
and several of Project 8018 (has completed succesfully 240+ workunits and has been running dedicated for 2 months give or take the odd reboot).
Stock Nvidia GTX 460, Win XP.
I wont post the log as we've all seen enough generic logs with an UNSTABLE MACHINE error attached to them. This one doesnt seem to differ in any way to any ive seen in the past.
Project: 7624 (Run 278, Clone 0, Gen 78) - NaN Error
v00d00
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Re: Project: 7624 (Run 278, Clone 0, Gen 78) - NaN Error
There's no record of Project: 7623 (Run 130, Clone 0, Gen 91) being completed so there's really no way to tell if the instability originated in the WU itself or originated in your hardware. All I can do is wait for more reports from others.
Following up on the old report waiting in the queue, the WU mentioned in the title has been successfully completed by another user as has the next one mentioned in your post by a different user:
Hi ******* (team *****),
Your WU (P7624 R278 C0 G78) was added to the stats database on 2012-11-19 09:02:47 for 5187 points of credit.
Your WU (P7623 R130 C0 G91) was added to the stats database on 2012-11-19 09:02:47 for 5187 points of credit.
