Folding not running on GTX 570/GT 220
driscoll42
Post by driscoll42 »
So I installed F@H v7.1.52 on my computer and while the CPU works just fine my GPUs aren't working at all. I have a GTX 570 and a GT 220 with the latest drivers (306.97). F@H recognizes the GPUs, downloads the WU for them but the logs give me errors.
Edit 2: SOLVED. See below for the solution
Edit: Few things I have tried. I've updated the GPUs.txt, made sure it's not running as a service, still working.
Log
*********************** Log Started 2012-10-27T21:34:06Z ***********************
21:34:06:************************* Folding@home Client *************************
21:34:06:      Website: http://folding.stanford.edu/
21:34:06:    Copyright: (c) 2009-2012 Stanford University
21:34:06:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:34:06:         Args: --lifeline 8684 --command-port=36330
21:34:06:       Config: E:/FAHClient/config.xml
21:34:06:******************************** Build ********************************
21:34:06:      Version: 7.1.52
21:34:06:         Date: Mar 20 2012
21:34:06:         Time: 19:37:42
21:34:06:      SVN Rev: 3515
21:34:06:       Branch: fah/trunk/client
21:34:06:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
21:34:06:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
21:34:06:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
21:34:06:     Platform: win32 XP
21:34:06:         Bits: 32
21:34:06:         Mode: Release
21:34:06:******************************* System ********************************
21:34:06:          CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
21:34:06:       CPU ID: GenuineIntel Family 6 Model 26 Stepping 4
21:34:06:         CPUs: 8
21:34:06:       Memory: 12.00GiB
21:34:06:  Free Memory: 2.29GiB
21:34:06:      Threads: WINDOWS_THREADS
21:34:06:   On Battery: false
21:34:06:   UTC offset: -5
21:34:06:          PID: 684
21:34:06:          CWD: E:/FAHClient
21:34:06:           OS: Windows 7 Ultimate
21:34:06:      OS Arch: AMD64
21:34:06:         GPUs: 3
21:34:06:        GPU 0: NVIDIA:1 GT216 [GeForce GT 220]
21:34:06:        GPU 1: FERMI:1 GF110 [Geforce GTX 570]
21:34:06:        GPU 2: UNSUPPORTED: Rage XL (Intel Corporation)
21:34:06:         CUDA: 2.0
21:34:06:  CUDA Driver: 5000
21:34:06:Win32 Service: false
21:34:06:***********************************************************************
21:34:06:<config>
21:34:06:  <!-- Folding Slot Configuration -->
21:34:06:  <gpu v='true'/>
21:34:06:
21:34:06:  <!-- Network -->
21:34:06:  <proxy v=':8080'/>
21:34:06:
21:34:06:  <!-- User Information -->
21:34:06:  <passkey v='********************************'/>
21:34:06:  <team v='111065'/>
21:34:06:  <user v='driscoll42'/>
21:34:06:
21:34:06:  <!-- Folding Slots -->
21:34:06:  <slot id='0' type='GPU'/>
21:34:06:  <slot id='1' type='GPU'/>
21:34:06:  <slot id='2' type='SMP'/>
21:34:06:</config>
21:34:06:Trying to access database...
21:34:06:Successfully acquired database lock
21:34:06:Enabled folding slot 00: READY gpu:0:"GT216 [GeForce GT 220]"
21:34:06:Enabled folding slot 01: READY gpu:1:"GF110 [Geforce GTX 570]"
21:34:06:Enabled folding slot 02: READY smp:8
21:34:06:WU01:FS01:Starting
21:34:06:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 701 -lifeline 684 -checkpoint 15 -gpu 1
21:34:06:WU01:FS01:Started FahCore on PID 8248
21:34:06:WU01:FS01:Core PID:11940
21:34:06:WU01:FS01:FahCore 0x15 started
21:34:07:WU00:FS00:Starting
21:34:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 701 -lifeline 684 -checkpoint 15 -gpu 0
21:34:07:WU00:FS00:Started FahCore on PID 7492
21:34:07:WU00:FS00:Core PID:8592
21:34:07:WU00:FS00:FahCore 0x11 started
21:34:07:WU01:FS01:0x15:
21:34:07:WU01:FS01:0x15:*------------------------------*
21:34:07:WU01:FS01:0x15:Folding@Home GPU Core
21:34:07:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
21:34:07:WU01:FS01:0x15:Build host             AmoebaRemote
21:34:07:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
21:34:07:WU01:FS01:0x15:Core                   15
21:34:07:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
21:34:07:WU01:FS01:0x15:Window's signal control handler registered.
21:34:07:WU01:FS01:0x15:Preparing to commence simulation
21:34:07:WU01:FS01:0x15:- Looking at optimizations...
21:34:07:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
21:34:07:WU01:FS01:0x15:- Created dyn
21:34:07:WU01:FS01:0x15:- Files status OK
21:34:07:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
21:34:07:WU01:FS01:0x15:- Expanded 60384 -> 264278 (decompressed 437.6 percent)
21:34:07:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=60384 data_size=264278, decompressed_data_size=264278 diff=0
21:34:07:WU01:FS01:0x15:- Digital signature verified
21:34:07:WU01:FS01:0x15:Project: 8054 (Run 0, Clone 1360, Gen 9)
21:34:07:WU02:FS02:Starting
21:34:07:WU01:FS01:0x15:Assembly optimizations on if available.
21:34:07:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 701 -lifeline 684 -checkpoint 15 -np 8
21:34:07:WU01:FS01:0x15:Entering M.D.
21:34:07:WU02:FS02:Started FahCore on PID 7924
21:34:07:WU02:FS02:Core PID:6912
21:34:07:WU02:FS02:FahCore 0xa4 started
21:34:07:WU00:FS00:0x11:
21:34:07:WU00:FS00:0x11:*------------------------------*
21:34:07:WU00:FS00:0x11:Folding@Home GPU Core
21:34:07:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
21:34:07:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
21:34:07:WU00:FS00:0x11:Build host: amoeba
21:34:07:WU00:FS00:0x11:Board Type: Nvidia
21:34:07:WU00:FS00:0x11:Core      :
21:34:07:WU00:FS00:0x11:Preparing to commence simulation
21:34:07:WU00:FS00:0x11:- Ensuring status. Please wait.
21:34:08:WU02:FS02:0xa4:
21:34:08:WU02:FS02:0xa4:*------------------------------*
21:34:08:WU02:FS02:0xa4:Folding@Home Gromacs GB Core
21:34:08:WU02:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
21:34:08:WU02:FS02:0xa4:Preparing to commence simulation
21:34:08:WU02:FS02:0xa4:- Looking at optimizations...
21:34:08:WU02:FS02:0xa4:- Files status OK
21:34:08:WU02:FS02:0xa4:- Expanded 548467 -> 846200 (decompressed 154.2 percent)
21:34:08:WU02:FS02:0xa4:Called DecompressByteArray: compressed_data_size=548467 data_size=846200, decompressed_data_size=846200 diff=0
21:34:08:WU02:FS02:0xa4:- Digital signature verified
21:34:08:WU02:FS02:0xa4:Project: 7646 (Run 25, Clone 2, Gen 36)
21:34:08:WU02:FS02:0xa4:Assembly optimizations on if available.
21:34:08:WU02:FS02:0xa4:Entering M.D.
21:34:09:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
21:34:09:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  2745443358 4066278464 112660000 1593974585 638235287
21:34:09:WU01:FS01:0x15:GPU device id=1
21:34:09:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
21:34:09:WU01:FS01:0x15:Client config unavailable.
21:34:09:WU01:FS01:0x15:Starting GUI Server
21:34:13:WU02:FS02:0xa4:Using Gromacs checkpoints
21:34:13:WU02:FS02:0xa4:Mapping NT from 8 to 8
21:34:14:WU02:FS02:0xa4:Resuming from checkpoint
21:34:14:WU02:FS02:0xa4:Verified 02/wudata_01.log
21:34:14:WU02:FS02:0xa4:Verified 02/wudata_01.trr
21:34:14:WU02:FS02:0xa4:Verified 02/wudata_01.xtc
21:34:14:WU02:FS02:0xa4:Verified 02/wudata_01.edr
21:34:14:WU02:FS02:0xa4:Completed 6770 out of 2500000 steps  (0%)
21:34:16:WU00:FS00:0x11:- Looking at optimizations...
21:34:16:WU00:FS00:0x11:- Working with standard loops on this execution.
21:34:16:WU00:FS00:0x11:- Previous termination of core was improper.
21:34:16:WU00:FS00:0x11:- Going to use standard loops.
21:34:16:WU00:FS00:0x11:- Files status OK
21:34:16:WU00:FS00:0x11:- Expanded 46694 -> 252912 (decompressed 541.6 percent)
21:34:16:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=46694 data_size=252912, decompressed_data_size=252912 diff=0
21:34:16:WU00:FS00:0x11:- Digital signature verified
21:34:17:WU00:FS00:0x11:Project: 5768 (Run 6, Clone 82, Gen 2832)
21:34:17:WU00:FS00:0x11:Entering M.D.
21:34:22:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  1222372691 3697303675 944226630 1518400648 985996285
21:34:22:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
21:35:16:WU01:FS01:0x15:Finished fah_main status=59
21:35:16:WU01:FS01:0x15:mdrun_gpu returned 59
21:35:16:WU01:FS01:0x15:GPU memtest failure
21:35:16:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
GT 220
*********************** Log Started 2012-10-27T20:37:56Z ***********************
20:37:57:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:37:58:WU00:FS00:News: Welcome to Folding@Home
20:37:58:WU00:FS00:Assigned to work server 171.67.108.11
20:37:58:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GT216 [GeForce GT 220]" from 171.67.108.11
20:37:58:WU00:FS00:Connecting to 171.67.108.11:8080
20:37:58:WU00:FS00:Downloading 46.10KiB
20:37:58:WU00:FS00:Download complete
20:37:58:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:5768 run:6 clone:82 gen:2832 core:0x11 unit:0x774ea238508c46450b10005200061688
20:37:59:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah
20:37:59:WU00:FS00:Connecting to www.stanford.edu:80
20:37:59:WU00:FS00:FahCore 11: Downloading 648.82KiB
20:38:01:WU00:FS00:FahCore 11: Download complete
20:38:01:WU00:FS00:Valid core signature
20:38:01:WU00:FS00:Unpacked 1.82MiB to cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe
20:38:01:WU00:FS00:Starting
20:38:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 701 -lifeline 8644 -checkpoint 15 -gpu 0
20:38:01:WU00:FS00:Started FahCore on PID 524
20:38:02:WU00:FS00:Core PID:8040
20:38:02:WU00:FS00:FahCore 0x11 started
20:38:02:WU00:FS00:Downloading project 5768 description
20:38:02:WU00:FS00:Connecting to fah-web.stanford.edu:80
20:38:02:WU00:FS00:0x11:
20:38:02:WU00:FS00:0x11:*------------------------------*
20:38:02:WU00:FS00:0x11:Folding@Home GPU Core
20:38:02:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
20:38:02:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
20:38:02:WU00:FS00:0x11:Build host: amoeba
20:38:02:WU00:FS00:0x11:Board Type: Nvidia
20:38:02:WU00:FS00:0x11:Core      :
20:38:02:WU00:FS00:0x11:Preparing to commence simulation
20:38:02:WU00:FS00:0x11:- Looking at optimizations...
20:38:02:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
20:38:02:WU00:FS00:Project 5768 description downloaded successfully
20:38:02:WU00:FS00:0x11:- Created dyn
20:38:02:WU00:FS00:0x11:- Files status OK
20:38:02:WU00:FS00:0x11:- Expanded 46694 -> 252912 (decompressed 541.6 percent)
20:38:02:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=46694 data_size=252912, decompressed_data_size=252912 diff=0
20:38:02:WU00:FS00:0x11:- Digital signature verified
20:38:02:WU00:FS00:0x11:Project: 5768 (Run 6, Clone 82, Gen 2832)
20:38:02:WU00:FS00:0x11:Assembly optimizations on if available.
20:38:02:WU00:FS00:0x11:Entering M.D.
20:38:08:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  1222372691 3697303675 944226630 1518400648 985996285
20:38:08:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
20:58:21:FS00:Paused
20:58:21:FS00:Shutting core down
20:59:22:WARNING:FS00:Killing WU00
20:59:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:01:57:FS00:Unpaused
21:01:57:WU00:FS00:Starting
21:01:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 701 -lifeline 8644 -checkpoint 15 -gpu 0
21:01:57:WU00:FS00:Started FahCore on PID 7244
21:01:58:WU00:FS00:Core PID:12120
21:01:58:WU00:FS00:FahCore 0x11 started
21:01:58:WU00:FS00:0x11:
21:01:58:WU00:FS00:0x11:*------------------------------*
21:01:58:WU00:FS00:0x11:Folding@Home GPU Core
21:01:58:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
21:01:58:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
21:01:58:WU00:FS00:0x11:Build host: amoeba
21:01:58:WU00:FS00:0x11:Board Type: Nvidia
21:01:58:WU00:FS00:0x11:Core      :
21:01:58:WU00:FS00:0x11:Preparing to commence simulation
21:01:58:WU00:FS00:0x11:- Ensuring status. Please wait.
21:02:07:WU00:FS00:0x11:- Looking at optimizations...
21:02:07:WU00:FS00:0x11:- Working with standard loops on this execution.
21:02:07:WU00:FS00:0x11:- Previous termination of core was improper.
21:02:07:WU00:FS00:0x11:- Files status OK
21:02:07:WU00:FS00:0x11:- Expanded 46694 -> 252912 (decompressed 541.6 percent)
21:02:07:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=46694 data_size=252912, decompressed_data_size=252912 diff=0
21:02:07:WU00:FS00:0x11:- Digital signature verified
21:02:07:WU00:FS00:0x11:Project: 5768 (Run 6, Clone 82, Gen 2832)
21:02:07:WU00:FS00:0x11:Entering M.D.
21:02:13:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  1222372691 3697303675 944226630 1518400648 985996285
21:02:13:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
The GT 570
20:37:57:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
20:37:58:WU01:FS01:News: Welcome to Folding@Home
20:37:58:WU01:FS01:Assigned to work server 171.67.108.143
20:37:58:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:"GF110 [Geforce GTX 570]" from 171.67.108.143
20:37:58:WU01:FS01:Connecting to 171.67.108.143:8080
20:37:58:WU01:FS01:Downloading 59.47KiB
20:37:59:WU01:FS01:Download complete
20:37:59:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:8054 run:0 clone:1360 gen:9 core:0x15 unit:0x0000000a6953ee2f50626aec703f7964
20:37:59:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
20:37:59:WU01:FS01:Connecting to www.stanford.edu:80
20:37:59:WU01:FS01:FahCore 15: Downloading 1.88MiB
20:38:05:WU01:FS01:FahCore 15: 96.63%
20:38:05:WU01:FS01:FahCore 15: Download complete
20:38:05:WU01:FS01:Valid core signature
20:38:05:WU01:FS01:Unpacked 7.71MiB to cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe
20:38:05:WU01:FS01:Starting
20:38:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 701 -lifeline 8644 -checkpoint 15 -gpu 1
20:38:05:WU01:FS01:Started FahCore on PID 4592
20:38:05:WU01:FS01:Core PID:12024
20:38:05:WU01:FS01:FahCore 0x15 started
20:38:06:WU01:FS01:Downloading project 8054 description
20:38:06:WU01:FS01:Connecting to fah-web.stanford.edu:80
20:38:06:WU01:FS01:0x15:
20:38:06:WU01:FS01:0x15:*------------------------------*
20:38:06:WU01:FS01:0x15:Folding@Home GPU Core
20:38:06:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
20:38:06:WU01:FS01:0x15:Build host             AmoebaRemote
20:38:06:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
20:38:06:WU01:FS01:0x15:Core                   15
20:38:06:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
20:38:06:WU01:FS01:0x15:Window's signal control handler registered.
20:38:06:WU01:FS01:0x15:Preparing to commence simulation
20:38:06:WU01:FS01:0x15:- Looking at optimizations...
20:38:06:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
20:38:06:WU01:FS01:0x15:- Created dyn
20:38:06:WU01:FS01:0x15:- Files status OK
20:38:06:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:38:06:WU01:FS01:0x15:- Expanded 60384 -> 264278 (decompressed 437.6 percent)
20:38:06:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=60384 data_size=264278, decompressed_data_size=264278 diff=0
20:38:06:WU01:FS01:0x15:- Digital signature verified
20:38:06:WU01:FS01:0x15:Project: 8054 (Run 0, Clone 1360, Gen 9)
20:38:06:WU01:FS01:0x15:Assembly optimizations on if available.
20:38:06:WU01:FS01:0x15:Entering M.D.
20:38:06:WU01:FS01:Project 8054 description downloaded successfully
20:38:08:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  2745443358 4066278464 112660000 1593974585 638235287
20:38:08:WU01:FS01:0x15:GPU device id=1
20:38:08:WU01:FS01:0x15:Working on Good ROcking Metal Altar for Chronical Sinners
20:38:08:WU01:FS01:0x15:Client config unavailable.
20:38:08:WU01:FS01:0x15:Starting GUI Server
20:39:19:WU01:FS01:0x15:Finished fah_main status=59
20:39:19:WU01:FS01:0x15:mdrun_gpu returned 59
20:39:19:WU01:FS01:0x15:GPU memtest failure
20:39:19:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
Config.xml
21:48:01:Saving configuration to config.xml
21:48:01:<config>
21:48:01:  <!-- Folding Slot Configuration -->
21:48:01:  <gpu v='true'/>
21:48:01:
21:48:01:  <!-- Network -->
21:48:01:  <proxy v=':8080'/>
21:48:01:
21:48:01:  <!-- User Information -->
21:48:01:  <passkey v='********************************'/>
21:48:01:  <team v='111065'/>
21:48:01:  <user v='driscoll42'/>
21:48:01:
21:48:01:  <!-- Folding Slots -->
21:48:01:  <slot id='0' type='GPU'/>
21:48:01:  <slot id='1' type='GPU'/>
21:48:01:  <slot id='2' type='SMP'>
21:48:01:    <cpus v='2'/>
21:48:01:  </slot>
21:48:01:</config>
P5-133XL
Machine #2:
Machine 3:
Re: Folding not running on GTX 570/GT 220
Post by P5-133XL »
The 220 seems to be running. That card is a low-end card so that I would just give it more time to see if it completes a frame.
With the 570, seems to be HW. I would stop OC'ing if you are. Also check the cards temps. You also may be running into power issues as the source of the problem.
driscoll42
Thanks for trying to help, I'm not OCing it anymore beyond the stock and temps are fine. I did figure out the solution, a bit of Googling found that fredfoobar posted a solution here. Apparently the problem is that The symptom is hanging WUs, and it only seems to happen with mixed Fermi/non-Fermi GPUs. The order in which GPUs are being configured by FAHControl (and thus the GPU ID FAHClient passes to the cores) is not equal to the actual CUDA/OpenCL GPU ID, so Fermi WUs are trying to run on non-Fermi GPUs, and vice-versa. Hopefully this will be fixed in a future release - ensuring that GPUs are enumerated in CUDA/OpenCL ID order should do the trick.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
I'm happy, if you're happy. Glad it got fixed. I'll take note of the error and the fix.
Apparently there's no fix planned for this problem:
https://fah-web.stanford.edu/projects/F ... ticket/879
